    4. [Neuer Adapter] EuSec
    • Longbow
      Longbow last edited by
      @adnim
      Mhh kann so was passieren...
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: iobroker-Final
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.2.16-3-pve
          Architecture: x86-64
      model name      : Intel(R) Core(TM) i5-4590T CPU @ 2.00GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       17:18:05 up 14 days,  3:39,  3 users,  load average: 1.25, 1.22, 1.12
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Sat 2024-09-14 17:18:05 CEST
                 Universal time: Sat 2024-09-14 15:18:05 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      longbow
      HOME=/home/longbow
      GROUPS=longbow sudo users iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:             12G        5.5G        4.3G         90K        3.0G        7.4G
      Swap:           8.6G        126K        8.6G
      Total:           21G        5.5G         12G
      Active iob-Instances:   64
              12288 M total memory
               5271 M used memory
               1878 M active memory
               5748 M inactive memory
               4145 M free memory
                  0 M buffer memory
               2871 M swap cache
               8191 M total swap
                  0 M used swap
               8191 M free swap
      top - 17:18:05 up 14 days,  3:39,  3 users,  load average: 1.25, 1.22, 1.12
      Tasks:  93 total,   2 running,  91 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  12288.0 total,   4142.8 free,   5273.9 used,   2871.3 buff/cache
      MiB Swap:   8192.0 total,   8191.9 free,      0.1 used.   7014.1 avail Mem
      *** FAILED SERVICES ***
        UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--240--disk--0 ext4       94G   14G   76G  16% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
      tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
      tmpfs                            tmpfs     3.2G  136K  3.2G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1000
      dmesg: read kernel buffer failed: Operation not permitted
      Show mounted filesystems:
      TARGET                                                  SOURCE                           FSTYPE     OPTIONS
      /                                                       /dev/mapper/pve-vm--240--disk--0 ext4       rw,relatime,stripe=16
      |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=3251320k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
      | |-/run/user/1000                                      tmpfs                            tmpfs      rw,nosuid,nodev,relatime,size=1625656k,nr_inodes=406414,mode=700,uid=101000,gid=101000,inode64
      | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysctl.service             ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | `-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
      | |-/dev/mqueue                                         mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
      | |-/dev/.lxc/proc                                      proc                             proc       rw,relatime
      | |-/dev/.lxc/sys                                       sys                              sysfs      rw,relatime
      | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
      | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
      | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
      | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
      | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
      | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
      | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
      | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
      | | |-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
      | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
      | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
        |-/sys/fs/fuse/connections                            fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
        |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
        |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
        `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      /var:
      4.3G    /var/
      3.5G    /var/log/journal/4482dacb35484bddab24b914a301d279
      3.5G    /var/log
      712M    /var/cache
      Archived and active journals take up 19.3M in the file system.
      /opt/iobroker/backups:
      518M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.9G    /opt/iobroker/iobroker-data/
      1.3G    /opt/iobroker/iobroker-data/files
      441M    /opt/iobroker/iobroker-data/files/javascript.admin
      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      130M    /opt/iobroker/iobroker-data/states.jsonl
      55M     /opt/iobroker/iobroker-data/objects.jsonl
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.17.0
      /usr/bin/node           v20.17.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.17.0-1nodesource1
        Candidate: 20.17.0-1nodesource1
        Version table:
       *** 20.17.0-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.16.0-1nodesource1 600
           20.15.1-1nodesource1 600
           20.15.0-1nodesource1 600
           20.14.0-1nodesource1 600
           20.13.1-1nodesource1 600
           20.13.0-1nodesource1 600
           20.12.2-1nodesource1 600
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
           20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.0.23
      javascript:     8.7.6
      nodejs modules from github:     4
      +-- eufy-security-client@3.1.0 (git+ssh://git@github.com/bropat/eufy-security-client.git#27e7c87d67810667022cf6cabb0c46ab1b818654)
      +-- iobroker.roborock@0.6.11 (git+ssh://git@github.com/copystring/ioBroker.roborock.git#801511a70e1eeb3ae66f2608f9d6c86b8933e515)
      +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#fd3b7f9f362a348741cbe18d70a130d2bfee6727)
      +-- iobroker.vw-connect@0.6.0 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#1bea7002b834d672f998717c2232223d4d1d13af)
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : iobroker-Final                           -  enabled
      + system.adapter.admin.0                  : admin                 : iobroker-Final                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alarm.0                  : alarm                 : iobroker-Final                           -  enabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker-Final                           - disabled
      + system.adapter.backitup.0               : backitup              : iobroker-Final                           -  enabled
        system.adapter.bidirectional-counter.0  : bidirectional-counter : iobroker-Final                           - disabled
        system.adapter.chromecast.0             : chromecast            : iobroker-Final                           - disabled
      + system.adapter.cloud.0                  : cloud                 : iobroker-Final                           -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker-Final                           -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : iobroker-Final                           -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker-Final                           -  enabled
      + system.adapter.doorbird.0               : doorbird              : iobroker-Final                           -  enabled
        system.adapter.drag-indicator.0         : drag-indicator        : iobroker-Final                           - disabled
        system.adapter.dwd.0                    : dwd                   : iobroker-Final                           -  enabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-Final                           -  enabled
        system.adapter.eventlist.0              : eventlist             : iobroker-Final                           - disabled
      + system.adapter.fritzdect.0              : fritzdect             : iobroker-Final                           -  enabled
        system.adapter.fullcalendar.0           : fullcalendar          : iobroker-Final                           - disabled
      + system.adapter.geofency.0               : geofency              : iobroker-Final                           -  enabled, port: 7999, bind: 0.0.0.0
      + system.adapter.history.0                : history               : iobroker-Final                           -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker-Final                           -  enabled
        system.adapter.hm-rega.1                : hm-rega               : iobroker-Final                           - disabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-Final                           -  enabled, port: 18701
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-Final                           -  enabled, port: 12001
        system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-Final                           - disabled, port: 12001
      + system.adapter.homeconnect.0            : homeconnect           : iobroker-Final                           -  enabled
      + system.adapter.hue.0                    : hue                   : iobroker-Final                           -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : iobroker-Final                           -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-Final                           - disabled
        system.adapter.icons-freepic.0          : icons-freepic         : iobroker-Final                           - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker-Final                           - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker-Final                           - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker-Final                           - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker-Final                           - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-Final                           - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-Final                           - disabled
        system.adapter.icons-smarthome.0        : icons-smarthome       : iobroker-Final                           - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-Final                           - disabled
      + system.adapter.influxdb.0               : influxdb              : iobroker-Final                           -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker-Final                           -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker-Final                           -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker-Final                           -  enabled
      + system.adapter.klf200.0                 : klf200                : iobroker-Final                           -  enabled
        system.adapter.lightcontrol.0           : lightcontrol          : iobroker-Final                           - disabled
        system.adapter.linkeddevices.0          : linkeddevices         : iobroker-Final                           - disabled
      + system.adapter.modbus.0                 : modbus                : iobroker-Final                           -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker-Final                           -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.myenergi.0               : myenergi              : iobroker-Final                           -  enabled
      + system.adapter.net-tools.0              : net-tools             : iobroker-Final                           -  enabled
      + system.adapter.netatmo.0                : netatmo               : iobroker-Final                           -  enabled
      + system.adapter.nina.0                   : nina                  : iobroker-Final                           -  enabled
      + system.adapter.notification-manager.0   : notification-manager  : iobroker-Final                           -  enabled
      + system.adapter.nuki-extended.0          : nuki-extended         : iobroker-Final                           -  enabled
      + system.adapter.onvif.0                  : onvif                 : iobroker-Final                           -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899, 888
        system.adapter.openweathermap.0         : openweathermap        : iobroker-Final                           -  enabled
      + system.adapter.operating-hours.0        : operating-hours       : iobroker-Final                           -  enabled
        system.adapter.ping.0                   : ping                  : iobroker-Final                           - disabled
        system.adapter.places.0                 : places                : iobroker-Final                           - disabled
      + system.adapter.pollenflug.0             : pollenflug            : iobroker-Final                           -  enabled
      + system.adapter.proxmox.0                : proxmox               : iobroker-Final                           -  enabled, port: 8006
      + system.adapter.pushover.0               : pushover              : iobroker-Final                           -  enabled
      + system.adapter.reolink.0                : reolink               : iobroker-Final                           -  enabled
      + system.adapter.reolink.1                : reolink               : iobroker-Final                           -  enabled
      + system.adapter.reolink.2                : reolink               : iobroker-Final                           -  enabled
        system.adapter.robonect.0               : robonect              : iobroker-Final                           - disabled
      + system.adapter.roborock.0               : roborock              : iobroker-Final                           -  enabled
        system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker-Final                           - disabled, port: 8002
      + system.adapter.scenes.0                 : scenes                : iobroker-Final                           -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker-Final                           -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : iobroker-Final                           -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartgarden.0            : smartgarden           : iobroker-Final                           -  enabled
        system.adapter.smartthings.0            : smartthings           : iobroker-Final                           - disabled
        system.adapter.solaredge.0              : solaredge             : iobroker-Final                           -  enabled
        system.adapter.sonos.0                  : sonos                 : iobroker-Final                           - disabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-Final                           -  enabled
      + system.adapter.sql.0                    : sql                   : iobroker-Final                           -  enabled
      + system.adapter.statistics.0             : statistics            : iobroker-Final                           -  enabled
      + system.adapter.systeminfo.0             : systeminfo            : iobroker-Final                           -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-Final                           -  enabled
      + system.adapter.tr-064.0                 : tr-064                : iobroker-Final                           -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker-Final                           -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker-Final                           -  enabled
      + system.adapter.tuya.1                   : tuya                  : iobroker-Final                           -  enabled
      + system.adapter.tuya.2                   : tuya                  : iobroker-Final                           -  enabled
      + system.adapter.unifi.0                  : unifi                 : iobroker-Final                           -  enabled
      + system.adapter.upnp.0                   : upnp                  : iobroker-Final                           -  enabled
        system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobroker-Final                           - disabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker-Final                           - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-Final                           - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker-Final                           - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-Final                           -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker-Final                           -  enabled
        system.adapter.vis-history.0            : vis-history           : iobroker-Final                           -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-Final                           - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker-Final                           - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-Final                           -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-Final                           - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker-Final                           - disabled
        system.adapter.vis-map.0                : vis-map               : iobroker-Final                           - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker-Final                           - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-Final                           -  enabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker-Final                           - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker-Final                           -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker-Final                           - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-Final                           - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker-Final                           - disabled
        system.adapter.vis.0                    : vis                   : iobroker-Final                           -  enabled
      + system.adapter.vw-connect.0             : vw-connect            : iobroker-Final                           -  enabled
      + system.adapter.vw-connect.1             : vw-connect            : iobroker-Final                           -  enabled
      + system.adapter.weather-warnings.0       : weather-warnings      : iobroker-Final                           -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker-Final                           -  enabled
      + system.adapter.web.0                    : web                   : iobroker-Final                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.welcome.0                : welcome               : iobroker-Final                           -  enabled, port: 80, bind: 0.0.0.0, run as: admin
      + system.adapter.wolf-smartset.0          : wolf-smartset         : iobroker-Final                           -  enabled
      + system.adapter.wolf.0                   : wolf                  : iobroker-Final                           -  enabled, port: 12004, bind: 0.0.0.0
        system.adapter.yr.0                     : yr                    : iobroker-Final                           -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
      Adapter    "admin"        : 7.0.23   , installed 7.0.23
      Adapter    "alarm"        : 3.6.1    , installed 3.6.1
      Adapter    "backitup"     : 3.0.22   , installed 3.0.22
      Adapter    "bidirectional-counter": 2.2.0, installed 2.2.0
      Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
      Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "doorbird"     : 1.7.0    , installed 1.7.0
      Adapter    "drag-indicator": 2.2.0   , installed 2.2.0
      Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
      Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
      Adapter    "fullcalendar" : 2.4.2    , installed 2.4.2
      Adapter    "geofency"     : 1.2.4    , installed 1.2.4
      Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
      Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
      Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
      Adapter    "hue"          : 3.12.0   , installed 3.12.0
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "klf200"       : 1.2.0    , installed 1.2.0
      Adapter    "lightcontrol" : 0.8.0    , installed 0.8.0
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "modbus"       : 6.2.3    , installed 6.2.3
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
      Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "notification-manager": 1.1.2, installed 1.1.2
      Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "operating-hours": 1.1.0  , installed 1.1.0
      Adapter    "places"       : 1.2.0    , installed 1.2.0
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
      Adapter    "pushover"     : 4.1.0    , installed 3.0.6  [Updatable]
      Adapter    "reolink"      : 1.1.1    , installed 1.1.1
      Adapter    "robonect"     : 1.3.6    , installed 1.3.6
      Adapter    "roborock"     : 0.6.4    , installed 0.6.11
      Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
      Adapter    "scenes"       : 3.2.1    , installed 3.2.1
      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "solaredge"    : 1.4.1    , installed 1.4.1
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "weather-warnings": 0.6.7 , installed 0.6.7
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "welcome"      : 0.3.0    , installed 0.3.0
      Adapter    "wolf"         : 1.7.0    , installed 1.7.0
      Adapter    "wolf-smartset": 1.2.3    , installed 1.2.3
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Objects and States
      Objects:        58506
      States:         46276
      Hit:1 http://security.debian.org bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.178.240:18701   0.0.0.0:*               LISTEN      1001       512516892  381431/io.hm-rpc.0
      tcp        0      0 192.168.178.240:12001   0.0.0.0:*               LISTEN      1001       512517743  381442/io.hm-rpc.1
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          419981791  294/master
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       512511819  381099/iobroker.js-
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       512511824  381099/iobroker.js-
      tcp        0      0 0.0.0.0:8100            0.0.0.0:*               LISTEN      1001       512527792  382060/io.doorbird.
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       512521923  381635/io.shelly.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          419979059  1/systemd
      tcp        0      0 0.0.0.0:12004           0.0.0.0:*               LISTEN      1001       512526179  381961/io.wolf.0
      tcp6       0      0 :::7906                 :::*                    LISTEN      1001       512521448  381244/io.roborock.
      tcp6       0      0 :::8000                 :::*                    LISTEN      1001       512547557  382879/io.upnp.0
      tcp6       0      0 :::7999                 :::*                    LISTEN      1001       512516041  381395/io.geofency.
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       513254766  387362/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       512512795  381117/io.admin.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       512539420  382911/io.simple-ap
      tcp6       0      0 :::8095                 :::*                    LISTEN      1001       512534319  382574/io.onvif.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          419981792  294/master
      tcp6       0      0 :::6824                 :::*                    LISTEN      1001       512521447  381244/io.roborock.
      tcp6       0      0 :::1984                 :::*                    LISTEN      1001       512520456  381571/go2rtc_linux
      tcp6       0      0 :::80                   :::*                    LISTEN      1001       512537054  382784/io.welcome.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          419979061  1/systemd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          419980077  1/systemd
      tcp6       0      0 :::8554                 :::*                    LISTEN      1001       512518925  381571/go2rtc_linux
      tcp6       0      0 :::8555                 :::*                    LISTEN      1001       512518926  381571/go2rtc_linux
      tcp6       0      0 :::51989                :::*                    LISTEN      1001       512525054  382028/io.nuki-exte
      udp        0      0 192.168.178.240:5353    0.0.0.0:*                           1001       512521215  381756/io.tr-064.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       512522784  381868/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       512522785  381868/io.tuya.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          419979060  1/systemd
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       512542779  382879/io.upnp.0
      udp        0      0 0.0.0.0:35611           0.0.0.0:*                           1001       512537584  382879/io.upnp.0
      udp6       0      0 :::111                  :::*                                0          419979062  1/systemd
      udp6       0      0 :::8555                 :::*                                1001       512560717  383682/go2rtc
      2024-09-14 17:15:26.014  - info: host.iobroker-Final instance system.adapter.daswetter.0 in version "3.1.16" started with pid 428529
      2024-09-14 17:15:26.657  - info: web.0 (387362) <== Disconnect system.user.admin from ::ffff:192.168.178.38
      2024-09-14 17:15:26.677  - info: web.0 (387362) <== Disconnect system.user.admin from ::ffff:192.168.178.38
      2024-09-14 17:15:26.688  - info: web.0 (387362) ==> Connected system.user.admin from ::ffff:192.168.178.38
      2024-09-14 17:15:26.884  - info: web.0 (387362) <== Disconnect system.user.admin from ::ffff:192.168.178.38
      Copy text starting here:
                              v.2024-05-22
        Virtualization: lxc
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               64 bit
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      Boot Target:            graphical.target
      Pending OS-Updates:     0
      Pending iob updates:    1
      Nodejs-Installation:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      Recommended versions are nodejs 20.17.0 and npm 10.8.2
      MEMORY:
      Mem:             12G        5.5G        4.4G         90K        3.0G        7.4G
      Total:           21G        5.5G         12G
      ioBroker Core:          js-controller           6.0.11
                              admin                   7.0.23
      Objects type: jsonl
      States  type: jsonl
      Objects:                58506
      States:                 46276
      Size of iob-Database:
      59M     /opt/iobroker/iobroker-data/objects.jsonl
      132M    /opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
      longbow@iobroker-Final:~$
      • Longbow
        Kann mir keiner einen Tipp geben oder behilflich sein ?
          guitardoc @Longbow last edited by
          @longbow Der Security Client muss raus, den hast du dir bei irgendeinem Installationsversuch eingefangen:
          npm uninstall eufy-security-client
          • Longbow
            @guitardoc Danke, hat geklappt... der Adapter könnte installiert werden, nur leider werden meinen Cam, die Bilder angezeigt... spricht wie binde ich nun diese ein?
            G G 2 Replies Last reply Reply Quote 0
              @longbow Da kann ich dir leider nicht helfen, ich nutze den Adapter nur, um den Modus in Abhängigkeit von Anwesenheit und Tageszeit zu steuern.
                GMJ @Longbow last edited by GMJ
                @longbow
                So gehts -> http://IP_BROKER:PORT_BROKER_VIS/eusec.0/T8030P0815/last_event/T8213P0815.jpg
                In Vis in ein "Basic Image" in die URL
                astuermer 1 Reply Last reply Reply Quote 0
                • Longbow
                  @gmj Danke, das geht sehr gut.
                  Wie kann man das Live einfügen? Also aufrufen, bekommen?
                    @longbow
                    Kein Live Bild so einfach "da"
                    Nutze ich nicht.... denn man muss so wie ich das verstanden haben das Livebild starten (per datenpunkt triggern) dann gibt es einen Stream den man dann irgend wie einbinden könnte .... und danach den Stream wieder beenden. Sonst refresh Bild im widget in x ms einstellbar dann gibt es auktuelles wenn da.
                    • astuermer
                      astuermer @GMJ last edited by astuermer
                      @gmj sagte in [Neuer Adapter] EuSec:
                      @longbow
                      Da kommt bei mir leider nur das:
                      404
                      Oops! The page you're looking for can't be found. 😔
                      File /eusec.0/hier Pfad mit Dateiname.jpg not found
                      Update: Hat sich erledigt mit einem neuen Update. Was nachwievor nicht läuft, dass der Akkustand sich automatisch aktualisiert. Ich muss dazu jedesmal den Adapter neu starten.
                      • astuermer
                        astuermer last edited by
                        Was von Vorteil wäre: Timestamp pro Kamera.
                        Klar man kann es in der eufy App ins Bild integrieren, aber bei Tageslicht ist das nicht lesbar. Das wäre als Value pro Kamera toll 👍🏻
                          guitardoc last edited by guitardoc
                          @astuermer Bei mir liefert der eusec Adapter leider keine geänderten Werte in den Datenpunkten für motion_detected und person_detected. Die Datenpunkte stehen permanent auf false. Ich habe die Werte mal in SQL protokolliert - keine Änderung. Motion_detection steht aber auf true, Bewegungen werden in der app auch erkannt.
                          Hat jemand das gleiche Problem?
                          Fabio 1 Reply Last reply Reply Quote 0
                          • Fabio
                            Fabio @guitardoc last edited by
                            @guitardoc bekommst du auch Push aufs Handy?
                            Fabio
                              guitardoc @Fabio last edited by
                              @fabio Meinst du aus der App heraus? Da bekomme ich Mitteilungen ob Bewegung oder Person erkannt wurde.
                              • Fabio
                                Fabio @guitardoc last edited by Fabio
                                @guitardoc okay dann kann es daran nicht liegen. Adapter mal neu gestartet?
                                Evtl. im Adapter mal auf interne Verbindungen stellen und nicht auf P2P.
                                  @fabio OK, hab mal umgestellt und neu gestartet, mal sehen, ob es funktioniert. Die Datenpunkte hängen also daran, dass man Nachrichten aus der App aufs Handy bekommt?
                                  • Fabio
                                    @guitardoc ja so war’s bei mir mal, hatte bei einer Kamera die Benachrichtigung deaktiviert da kam nix im Adapter an. Einfach mal testen.
                                    Grüße Fabio
                                      @fabio Nein, hat leider nicht funktioniert. Im Adapter kommt nichts an wenn ich die Nachricht der Bewegung auf dem Telefon habe. Seltsam. Hab auf interne Verbindungen umgestellt und neu gestartet - in der Datenbank steht weiterhin nur ein einziger Wert: false.
                                      • Fabio
                                        @guitardoc dann gehe zurück auf P2P und probiere noch mal. Du kannst die Station auch mal neu starten.
                                        Ansonten weiß ich nicht woran das liegen kann. Kannst du die Kamera über die vorhandenen Datenpunkte denn steuern?
                                        Evtl. bitte ein Issues erstellen im jeden Fall aber mit Log damit @bropat sehen kann woran es liegt.
                                        Fabio
                                          @fabio Ich habe die Lautstärke der Kamera mal testweise über den Datenpunkt gesteuert, das hat funktioniert. Hab den Adapter jetzt mal auf debug gesetzt, vielleicht kann man da schon was erkennen.
                                            badsnoopy667 @guitardoc last edited by
                                            Mal so in die Runde gefragt:
                                            Ich spiele mit dem Gedanken eine Homebase S380 anzuschaffen und noch weitere Kameras.
                                            Aktuell nutze ich den eusec Adapter eigentlich nur um automatisiert die Kameras scharf zu schalten, wenn ich nicht zuhause bin und wieder aus, wenn jemand da ist.
                                            In der Adapter-Doku steht, dass die Homebase 3 nur rudimetär unterstützt wird. Kann mir jemand sagen, ob diese Funktion auch mit dem Homebase 3 funktioniert?
                                            Vielen Dank schonmal!
                                            adapter cameras doorbell eufy eufycam security
                                            160
                                            1173
                                            455740
