    4. jarvis v3.2.x - just another remarkable vis
      MCU @MeinzIsAs last edited by MCU
      @meinzisas Was steht hier drin?
      jarvis.0.settings.language
      Wechselt der Inhalt auch dauernd?
      Welche web-Instanz ist vorhanden / wird genutzt? web.0
      Kannst du mal ein Video machen, damit es sehen kann, was genau passiert?
      ScreenToGif
      https://github.com/Zefau/ioBroker.jarvis/issues/2808
      simatec created this issue in Zefau/ioBroker.jarvis
      closed Adapter Settings laden nicht #2808
      MeinzIsAs 2 Replies Last reply Reply Quote 0
      • MeinzIsAs
        MeinzIsAs @MCU last edited by MeinzIsAs
        @mcu In language steht nix drinn. Den hab ich beim Probieren wegen dem Problem mal gelöscht. Der Wert vorher war de-DE.
        Jarvis_Config.mp4
        Hab das mal als Video hochgeladen. So läuft das in der Dauerschleife.
        web-Instanz ist web.0
        • MeinzIsAs
          @mcu Das steht bei Seite untersuchen in Chrome.
          [2024-09-24T04:20:32.603Z] Try to connect
           "Upload Configuration": {"en": "Upload Configuration", "de": "Upload Configuration", "ru": "Upload Configuration", "pt": "Upload Configuration", "nl": "Upload Configuration", "fr": "Upload Configuration", "es": "Upload Configuration", "pl": "Upload Configuration", "it": "Upload Configuration", "zh-cn": "Upload Configuration"},
           "Download Configuration": {"en": "Download Configuration", "de": "Download Configuration", "ru": "Download Configuration", "pt": "Download Configuration", "nl": "Download Configuration", "fr": "Download Configuration", "es": "Download Configuration", "pl": "Download Configuration", "it": "Download Configuration", "zh-cn": "Download Configuration"},
           "Restore": {"en": "Restore", "de": "Restore", "ru": "Restore", "pt": "Restore", "nl": "Restore", "fr": "Restore", "es": "Restore", "pl": "Restore", "it": "Restore", "zh-cn": "Restore"},
           "Cancel": {"en": "Cancel", "de": "Cancel", "ru": "Cancel", "pt": "Cancel", "nl": "Cancel", "fr": "Cancel", "es": "Cancel", "pl": "Cancel", "it": "Cancel", "zh-cn": "Cancel"},
           "Please be aware that backups will be deleted when the adapter is updated.": {"en": "Please be aware that backups will be deleted when the adapter is updated.", "de": "Please be aware that backups will be deleted when the adapter is updated.", "ru": "Please be aware that backups will be deleted when the adapter is updated.", "pt": "Please be aware that backups will be deleted when the adapter is updated.", "nl": "Please be aware that backups will be deleted when the adapter is updated.", "fr": "Please be aware that backups will be deleted when the adapter is updated.", "es": "Please be aware that backups will be deleted when the adapter is updated.", "pl": "Please be aware that backups will be deleted when the adapter is updated.", "it": "Please be aware that backups will be deleted when the adapter is updated.", "zh-cn": "Please be aware that backups will be deleted when the adapter is updated."},
           "Devices": {"en": "Devices", "de": "Devices", "ru": "Devices", "pt": "Devices", "nl": "Devices", "fr": "Devices", "es": "Devices", "pl": "Devices", "it": "Devices", "zh-cn": "Devices"},
           "Layout": {"en": "Layout", "de": "Layout", "ru": "Layout", "pt": "Layout", "nl": "Layout", "fr": "Layout", "es": "Layout", "pl": "Layout", "it": "Layout", "zh-cn": "Layout"},
           "Widgets": {"en": "Widgets", "de": "Widgets", "ru": "Widgets", "pt": "Widgets", "nl": "Widgets", "fr": "Widgets", "es": "Widgets", "pl": "Widgets", "it": "Widgets", "zh-cn": "Widgets"},
           "Settings": {"en": "Settings", "de": "Settings", "ru": "Settings", "pt": "Settings", "nl": "Settings", "fr": "Settings", "es": "Settings", "pl": "Settings", "it": "Settings", "zh-cn": "Settings"},
           "Styles": {"en": "Styles", "de": "Styles", "ru": "Styles", "pt": "Styles", "nl": "Styles", "fr": "Styles", "es": "Styles", "pl": "Styles", "it": "Styles", "zh-cn": "Styles"},
           "Scripts": {"en": "Scripts", "de": "Scripts", "ru": "Scripts", "pt": "Scripts", "nl": "Scripts", "fr": "Scripts", "es": "Scripts", "pl": "Scripts", "it": "Scripts", "zh-cn": "Scripts"},
           Get backups for "devices"...
           Get backups for "layout"...
           Get backups for "widgets"...
           Get backups for "settings"...
           Get backups for "styles"...
           Get backups for "scripts"...
           Got backups for "devices".
           Got backups for "layout".
           Got backups for "widgets".
           Got backups for "settings".
           Got backups for "styles".
           Got backups for "scripts".
           Message broker queried succesfully.
          3 jarvis Load setting "authentication" (radio) with value: none [object Object]
           jarvis Load setting "authenticationGroup" (select) with value: system.group.user,system.group.administrator [object Object]
          3 jarvis Load setting "authenticationConfiguration" (radio) with value: none [object Object]
           jarvis Load setting "authenticationConfigurationGroup" (select) with value: system.group.user,system.group.administrator [object Object]
           jarvis Load setting "certPublic" (select) with value:  [object Object]
           jarvis Load setting "certPrivate" (select) with value:  [object Object]
           jarvis Load setting "certChained" (select) with value:  [object Object]
           jarvis Load setting "socketPort" (number) with value: 8400 [object Object]
           jarvis Load setting "socketSecure" (checkbox) with value: false [object Object]
           jarvis Load setting "authenticationPassword" (password) with value:  [object Object]
           jarvis Load setting "authenticationConfigurationPassword" (password) with value:  [object Object]
          Instances.tsx:1090 Width: xl
           [2024-09-24T04:20:33.693Z] Try to connect
           [2024-09-24T04:20:34.972Z] Try to connect
          Wiederholen sich immer die selben Einträge. Wenn ich die Konfigseite so laufen lasse, hört das Laden dann irgendwann auf und die Werte stehen drinn.
            Meikie @MeinzIsAs last edited by
            ich habe jetzt die Version v3.2.0-rc.5 installiert in Kombination mit dem neuen Admin-Panel 7.1.3.
            Leider funktioniert seit dem update mein iobroker sehr störrisch. Ich habe unter Übersicht jetzt 2 Jarvis. Einmal mit dem Port 8400, welche auch Funktioniert und einmal mit Port: undefined, welche nicht funktioniert.
            Wie bekomme ich die alte Version weg?
            Vielen Dank für die Hilfe.
            Meike
              MCU @Meikie last edited by
              @Homoran @Thomas-Braun Weiß jemand, wie man solch alte Einträge (Übersicht Anzeige Jarvis mit altem Port 8082, der aber nicht genutzt wird-> undefined) weg bekommt?
              Upload?
              Wo werden die Einträge gespeichert?
              Muss man evtl. jarvis komplett entfernen, damit auch alle Einträge einmal gelöscht werden.
                Thomas Braun Most Active @MCU last edited by Thomas Braun
                @mcu
                Da ich keine GUI hier laufen habe kann ich dazu nichts erhellendes beitragen.
                Zwei Instanzen am Start?
                iob diag
                wäre mal wieder hilfreich.
                  MCU @Meikie last edited by MCU
                  @meikie
                  Warum? Wegen der Übersicht?
                  Jarvis ist noch beta!, da sind noch einige offene Punkte.
                  VORHER bitte ein Bild mit dem undefined, möchte es mit in die Doku nehmen. Danke.
                  Man kann in der Übersicht den fehlerhaften Eintrag entfernen.
                  rechts unten klicken und dann das Element anklicken, welches entfernt werden soll. Auf den blauen Haken klicken.
                  -> Element hat einen grauen Haken
                  dann unten rechts auf den grünen Haken klicken und es wird gespeichert.
                    Meikie @MCU last edited by Meikie
                    @mcu Vielen Dank.
                    Aber es ist ja nicht wirklich gelöscht, sondern nur ausgeblendet. Kann man das nicht irgendwo entfernen. Es muss ja noch irgendwo ein Verweis zur alten Version sein.
                      @meikie Weiß ich leider nicht. Müsste man beim iobroker.admin mal ein Issue setzen.
                      Danke für das Bild, hab in die Doku mit aufgenommen.
                        hotspot_2 @MCU last edited by
                        Hallo, weiß jemand wie ich in jarvis einen Wert von Watt Stunden in kilowatt Stunden umrechen kann? Mit einer Nachkommastelle? Geht das oder muss ich da ein Blockly oder sowas machen?
                        also 36500 Wh in 36,5 kWh wäre die Umrechnung z.B.
                          MCU @hotspot_2 last edited by
                          @hotspot_2
                          https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/geraet/datenpunkt-eigenschaft/berechnungen-mit-val#division
                            MiWolf last edited by
                            Hi zusammen,
                            vielleicht könnt ihr mir helfen, ich habe heute Jarvis auf v3.2.0-rc.5 aktualisiert, das hat soweit auch alles funktioniert. Anfangs läuft auch alles schick, nach einiger Zeit (wenn der Tab sich schlafen legt?) kommt es zu folgender Fehlermeldung und Jarvis wird frecherweise deaktiviert..:
                            jarvis.0 2024-09-30 17:23:17.856	info	terminating
                            jarvis.0 2024-09-30 17:23:17.354	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                            jarvis.0 2024-09-30 17:23:17.353	info	terminating
                            jarvis.0 2024-09-30 17:23:17.352	info	Adapter stopped und unloaded.
                            jarvis.0 2024-09-30 17:23:17.351	error	unhandled promise rejection: null
                            jarvis.0 2024-09-30 17:23:17.350	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            jarvis.0 2024-09-30 17:18:41.414	warn	Failed moving user scripts due to "ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.jarvis/../../iobroker-data/files/0_userdata.0/jarvis-scripts'"!
                            jarvis.0 2024-09-30 17:18:36.098	info	Connection: WebSocket opened on port 8400 using http...
                            jarvis.0 2024-09-30 17:18:35.933	info	starting. Version 3.2.0-rc.5 in /opt/iobroker/node_modules/iobroker.jarvis, node: v20.17.0, js-controller: 6.0.11
                            Unter Dateien / Benutzerdaten hat Jarvis den entsprechenden Ordner angelegt...
                            Beste Grüße
                            Mirko
                              MCU @MiWolf last edited by
                              @miwolf Der Ordner ist angelegt. Wenn du jetzt jarvis wieder startest, passiert was?
                                MiWolf @MCU last edited by MiWolf
                                @mcu
                                Es gibt leider keine Änderung. Der Ordner war ja auch schon vorher da (im IOBroker unter Dateien)...
                                Beste Grüße Mirko
                                jarvis.0 2024-10-01 11:03:02.561	info	Adapter stopped und unloaded.
                                jarvis.0 2024-10-01 11:03:02.560	error	unhandled promise rejection: null
                                jarvis.0 2024-10-01 11:03:02.559	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                jarvis.0 2024-10-01 11:01:36.829	warn	Failed moving user scripts due to "ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/iobroker.jarvis/../../iobroker-data/files/0_userdata.0/jarvis-scripts'"!
                                jarvis.0 2024-10-01 11:01:31.535	info	Connection: WebSocket opened on port 8400 using http...
                                jarvis.0 2024-10-01 11:01:31.372	info	starting. Version 3.2.0-rc.5 in /opt/iobroker/node_modules/iobroker.jarvis, node: v20.17.0, js-controller: 6.0.11
                                Nachtrag:
                                ich habe gerade gesehen, das bei mir unter /opt/iobroker/iobroker-data/files kein Ordner 0_userdata.0 existiert. Da findet sich nur admin.admin, backitup.admin und discorvery.admin. Spannenderweise sehe in im IOBroker unter "Dateien" die entsprechende Ordnerstruktur..
                                Ich erzeuge mal die Ordner händisch und melde mich wieder.
                                Btw: Das was bei mir "nicht" normal ist... Ich hab eine Redis-Installation, wo der Redis-Server auf einem anderen System als den Raspi läuft.. ansonsten ist es eine frische Installation die via BackitUp wieder hergestellt wurde...
                                Nachtrag 2:
                                lege ich die Ordnerstruktur im Filesystem händisch an, startet Jarvis problemlos..
                                Nachtrag 3:
                                leider scheint das aber nicht die Ursache für die Exception gewesen zu sein, die besteht leider weiterhin:
                                  MCU @MiWolf last edited by MCU
                                  @miwolf Nutzt du denn scripts?
                                  Was sagt denn der Browser-LOG (F12)?
                                  Admin Version 7?
                                    @mcu
                                    In der Console bekomme ich die folgende Fehlermeldung:
                                    Ich bin mal durch den Code debugged und bin hier gelandet 🙂
                                    Ich hab keine Scripts und kein CustomCSS
                                    Admin ist Version 7.1.5.
                                      Steph 0 last edited by
                                      ich habe seit meinem Umstieg auf auf einen nginx Reverse-Proxy einen seltsamen Effekt, desen Ursache ich nicht verstehe:
                                      Grundsätzlich funktioniert der Zugriff auf die Jarvis (rc5) Instanz via Reverse-Proxy (https://jarvis.xx.xx) einwandfrei.
                                      Jetzt habe ich die Config so ergänzt, dass der Zugriff aus meinem LAN ohne Autentifizierung möglich ist (IP Whitelist), von außerhalb meines LANs habe ich eine Basic Auth davor gesetzt.
                                      Die Basic Auth funktioniert auch einwandfrei, solange ich von einem Desktop-Browser komme (getestet: Chrome & Edge unter Windows).
                                      Nutze ich jedoch Safari oder Chrome vom iPhone (IOS 18) aus, dann kann ich mich zwar auch via Basic Auth anmelden, danach laufe ich aber in einen Websocket-Timeout und das war es dann. Auch ein Reload hilft nicht, Browser-Cache habe ich (mehrfach) gelöscht.
                                      Ich sehe eigentlich keinen Unteschied, ob ich die Seite via Mobiltelefon oder via Desktop aufrufe, oder übersehe ich etwas?
                                      Danke für jeden Hinweis!
                                        Robbi12 @Steph 0 last edited by
                                        Hi. Wie bekomme ich es im Datenpunkt hin, dass das Icon in der jeweiligen Farbe blinkt.
                                          MCU @Robbi12 last edited by MCU
                                          @robbi12 Welche Abhängigkeit hat denn die Farbe zum Icon? Sollen unterschiedliche Icons abhängig vom Wert angezeigt werden?
                                          Zeig mal den jetzigen Stand vom Geräte-DP.
                                          https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/geraet/icon-stil
                                          https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/geraet/eingabewerte-fur-die-gerate-dp-state-felder#icon
                                          https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/geraet/eingabewerte-fur-die-gerate-dp-state-felder#icon-stil
                                            Robbi12 @MCU last edited by
                                            @mcu So habe ich es jetzt.
                                            {"Gelb blinkt":{"color":"#fefe00"},"Gelb":{"color":"#fefe00"},"Violett dunkel":{"color":"#6b14b8"},"Gruen blinkt":{"color":"#00ff00"},"Gruen":{"color":"#00ff00"}}
                                            Ich würde gerne bei Gelb blinkt auch gerne blinken lassen
                                            891
                                            243512
