    4. js-controller Lucy (v7.0.0) Alpha Test
    • Armilar
      Armilar Most Active Forum Testing @foxriver76 last edited by
      @foxriver76
      Läuft bei mir ebenfalls - ohne Probleme
      • Feuersturm
        Feuersturm @foxriver76 last edited by
        @foxriver76 Upgrade von js-controller 6 auf 7 lief auf meinem Testsystem ohne Probleme 👏
        iob diag vom aktualisierten Testsystem
        Skript v.2024-08-12
        *** BASE SYSTEM ***
         Static hostname: ioB-Prod-Testsystem
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
        Operating System: Ubuntu 22.04.5 LTS
                  Kernel: Linux 6.5.13-1-pve
            Architecture: x86-64
        OS is similar to: debian
        model name      : Intel(R) Celeron(R) CPU  N3150  @ 1.60GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         20:42:28 up 55 days,  6:44,  2 users,  load average: 2.94, 2.82, 3.09
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Fri 2024-09-27 20:42:28 CEST
                   Universal time: Fri 2024-09-27 18:42:28 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        proxmox
        HOME=/home/proxmox
        GROUPS=proxmox sudo iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            8.0G        2.3G        2.6G        0.0K        3.1G        5.7G
        Swap:           2.0G         38M        2.0G
        Total:           10G        2.3G        4.6G
        Active iob-Instances:   31
                 8000 M total memory
                 2303 M used memory
                 2091 M active memory
                 2891 M inactive memory
                 2638 M free memory
                    0 M buffer memory
                 3058 M swap cache
                 2048 M total swap
                   38 M used swap
                 2009 M free swap
        top - 20:42:28 up 55 days,  6:44,  2 users,  load average: 3.43, 2.93, 3.12
        Tasks:  69 total,   3 running,  66 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 11.8 us, 27.9 sy,  0.0 ni, 60.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   8000.0 total,   2638.3 free,   2303.0 used,   3058.8 buff/cache
        MiB Swap:   2048.0 total,   2009.2 free,     38.8 used.   5697.0 avail Mem
        *** FAILED SERVICES ***
          UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                          Type      Size  Used Avail Use% Mounted on
        /dev/mapper/data2-vm--6000--disk--0 ext4       40G   28G  9.4G  75% /
        none                                tmpfs     492K  4.0K  488K   1% /dev
        efivarfs                            efivarfs  128K   65K   59K  53% /sys/firmware/efi/efivars
        tmpfs                               tmpfs     7.7G     0  7.7G   0% /dev/shm
        tmpfs                               tmpfs     3.1G  172K  3.1G   1% /run
        tmpfs                               tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs                               tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
        tmpfs                               tmpfs     1.6G     0  1.6G   0% /run/user/1001
        dmesg: read kernel buffer failed: Operation not permitted
        Show mounted filesystems:
        TARGET SOURCE                              FSTYPE OPTIONS
        /      /dev/mapper/data2-vm--6000--disk--0 ext4   rw,relatime,stripe=16
        /var:
        3.6G    /var/
        2.9G    /var/log/journal
        2.9G    /var/log
        2.6G    /var/log/journal/db91a8d9813048b3b0d9627361bf92a2
        440M    /var/lib
        Archived and active journals take up 40.0M in the file system.
        /opt/iobroker/backups:
        2.9G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        2.9G    /opt/iobroker/iobroker-data/
        1.8G    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        575M    /opt/iobroker/iobroker-data/sonosCache
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        38M     /opt/iobroker/iobroker-data/objects.jsonl
        37M     /opt/iobroker/iobroker-data/files/radar-trap.admin/build/index.js.map
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
        26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.17.0
        /usr/bin/node           v20.17.0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.3
        nodejs:
          Installed: 20.17.0-1nodesource1
          Candidate: 20.17.0-1nodesource1
          Version table:
         *** 20.17.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             12.22.9~dfsg-1ubuntu3.6 500
                500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
             12.22.9~dfsg-1ubuntu3 500
                500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  7.0.0-alpha.0-20240926-91f9b082f
        admin:          7.1.5
        javascript:     8.8.3
        nodejs modules from github:     1
        | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
        Adapter State
        + system.adapter.admin.0                  : admin                 : ioB-Prod-Testsystem                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : ioB-Prod-Testsystem                      -  enabled
          system.adapter.daswetter.0              : daswetter             : ioB-Prod-Testsystem                      -  enabled
          system.adapter.devices.0                : devices               : ioB-Prod-Testsystem                      -  enabled
          system.adapter.dwd.0                    : dwd                   : ioB-Prod-Testsystem                      -  enabled
        + system.adapter.echarts.0                : echarts               : ioB-Prod-Testsystem                      -  enabled
        + system.adapter.esphome.0                : esphome               : ioB-Prod-Testsystem                      -  enabled
        + system.adapter.fritzbox.0               : fritzbox              : ioB-Prod-Testsystem                      -  enabled
        + system.adapter.fullcalendar.0           : fullcalendar          : ioB-Prod-Testsystem                      -  enabled
        + system.adapter.fully-tablet-control.0   : fully-tablet-control  : ioB-Prod-Testsystem                      -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : ioB-Prod-Testsystem                      -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : ioB-Prod-Testsystem                      -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : ioB-Prod-Testsystem                      -  enabled, port: 0
        + system.adapter.hue.0                    : hue                   : ioB-Prod-Testsystem                      -  enabled, port: 443
          system.adapter.ical.0                   : ical                  : ioB-Prod-Testsystem                      - disabled
          system.adapter.ical.1                   : ical                  : ioB-Prod-Testsystem                      - disabled
          system.adapter.ical.2                   : ical                  : ioB-Prod-Testsystem                      - disabled
          system.adapter.ical.3                   : ical                  : ioB-Prod-Testsystem                      - disabled
          system.adapter.ical.4                   : ical                  : ioB-Prod-Testsystem                      - disabled
          system.adapter.ical.5                   : ical                  : ioB-Prod-Testsystem                      -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : ioB-Prod-Testsystem                      -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioB-Prod-Testsystem                      -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioB-Prod-Testsystem                      -  enabled
          system.adapter.influxdb.0               : influxdb              : ioB-Prod-Testsystem                      - disabled, port: 8086
          system.adapter.influxdb.1               : influxdb              : ioB-Prod-Testsystem                      - disabled, port: 8086
        + system.adapter.javascript.0             : javascript            : ioB-Prod-Testsystem                      -  enabled
          system.adapter.mqtt.0                   : mqtt                  : ioB-Prod-Testsystem                      - disabled, port: 1883, bind: 0.0.0.0
        + system.adapter.nina.0                   : nina                  : ioB-Prod-Testsystem                      -  enabled
        + system.adapter.notification-manager.0   : notification-manager  : ioB-Prod-Testsystem                      -  enabled
          system.adapter.openweathermap.0         : openweathermap        : ioB-Prod-Testsystem                      -  enabled
        + system.adapter.proxmox.0                : proxmox               : ioB-Prod-Testsystem                      -  enabled, port: 8006
        + system.adapter.radar-trap.0             : radar-trap            : ioB-Prod-Testsystem                      -  enabled
          system.adapter.rainbird.0               : rainbird              : ioB-Prod-Testsystem                      - disabled
        + system.adapter.samsung.0                : samsung               : ioB-Prod-Testsystem                      -  enabled
        + system.adapter.scenes.0                 : scenes                : ioB-Prod-Testsystem                      -  enabled
        + system.adapter.scheduler.0              : scheduler             : ioB-Prod-Testsystem                      -  enabled
          system.adapter.seq.0                    : seq                   : ioB-Prod-Testsystem                      - disabled, port: 5341
          system.adapter.shuttercontrol.0         : shuttercontrol        : ioB-Prod-Testsystem                      - disabled
        + system.adapter.simple-api.0             : simple-api            : ioB-Prod-Testsystem                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          system.adapter.socketio.0               : socketio              : ioB-Prod-Testsystem                      - disabled, port: 8084, bind: 192.168.178.54, run as: admin
        + system.adapter.sonos.0                  : sonos                 : ioB-Prod-Testsystem                      -  enabled
          system.adapter.spotify-premium.0        : spotify-premium       : ioB-Prod-Testsystem                      - disabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : ioB-Prod-Testsystem                      -  enabled
          system.adapter.telegram.0               : telegram              : ioB-Prod-Testsystem                      - disabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : ioB-Prod-Testsystem                      -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : ioB-Prod-Testsystem                      -  enabled
        + system.adapter.unifi.0                  : unifi                 : ioB-Prod-Testsystem                      -  enabled
          system.adapter.valloxmv.0               : valloxmv              : ioB-Prod-Testsystem                      - disabled, port: 80
          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioB-Prod-Testsystem                      -  enabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioB-Prod-Testsystem                      -  enabled
          system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: ioB-Prod-Testsystem                      -  enabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioB-Prod-Testsystem                      -  enabled
          system.adapter.vis-2-widgets-radar-trap.0: vis-2-widgets-radar-trap: ioB-Prod-Testsystem                      -  enabled
        + system.adapter.vis-2.0                  : vis-2                 : ioB-Prod-Testsystem                      -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioB-Prod-Testsystem                      -  enabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioB-Prod-Testsystem                      -  enabled
          system.adapter.vis-history.0            : vis-history           : ioB-Prod-Testsystem                      -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioB-Prod-Testsystem                      -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : ioB-Prod-Testsystem                      -  enabled
          system.adapter.vis-map.0                : vis-map               : ioB-Prod-Testsystem                      -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioB-Prod-Testsystem                      -  enabled
          system.adapter.vis-metro.0              : vis-metro             : ioB-Prod-Testsystem                      -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioB-Prod-Testsystem                      -  enabled
          system.adapter.vis.0                    : vis                   : ioB-Prod-Testsystem                      -  enabled
        + system.adapter.web.0                    : web                   : ioB-Prod-Testsystem                      -  enabled, port: 8082, bind: 192.168.178.105, run as: admin
        + system.adapter.web.1                    : web                   : ioB-Prod-Testsystem                      -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
        + system.adapter.worx.0                   : worx                  : ioB-Prod-Testsystem                      -  enabled
        + system.adapter.ws.0                     : ws                    : ioB-Prod-Testsystem                      -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: beta
        Adapter    "admin"        : 7.1.5    , installed 7.1.5
        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
        Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
        Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
        Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
        Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
        Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
        Adapter    "hue"          : 3.12.0   , installed 3.12.0
        Adapter    "ical"         : 1.15.0   , installed 1.15.0
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 6.0.11   , installed 7.0.0
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "nina"         : 0.0.26   , installed 0.0.26
        Adapter    "notification-manager": 1.2.1, installed 1.2.1
        Adapter    "openweathermap": 1.1.2   , installed 1.1.2
        Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
        Adapter    "radar-trap"   : 2.2.2    , installed 2.2.2
        Adapter    "rainbird"     : 1.0.1    , installed 1.0.1
        Adapter    "samsung"      : 0.6.0    , installed 0.6.0
        Adapter    "scenes"       : 3.2.3    , installed 3.2.3
        Adapter    "scheduler"    : 1.4.1    , installed 1.4.1
        Adapter    "seq"          : 0.3.0    , installed 0.3.0
        Adapter    "shuttercontrol": 1.8.2   , installed 1.8.2
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "telegram"     : 3.9.0    , installed 3.9.0
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "valloxmv"     : 1.2.0    , installed 1.2.0
        Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
        Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
        Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
        Adapter    "vis-2-widgets-jaeger-design": 1.3.1, installed 1.3.1
        Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
        Adapter    "vis-2-widgets-radar-trap": 2.3.0, installed 2.3.0
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
        Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
        Adapter    "web"          : 6.3.1    , installed 6.3.1
        Adapter    "worx"         : 3.1.0    , installed 3.1.0
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Objects and States
        Objects:        14704
        States:         12204
        Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
        Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
        Hit:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
        Hit:4 https://apt.grafana.com stable InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          68633192   140/node
        tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1000       443174019  198874/python3
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       443154700  198216/iobroker.js-
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       443154198  198216/iobroker.js-
        tcp        0      0 192.168.178.105:8082    0.0.0.0:*               LISTEN      1000       443168107  198572/io.web.0
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          68635751   338/master
        tcp        0      0 192.168.178.105:2010    0.0.0.0:*               LISTEN      1000       443157045  198337/io.hm-rpc.0
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          68631545   1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          68633957   156/sshd: /usr/sbin
        tcp        0      0 192.168.178.105:9292    0.0.0.0:*               LISTEN      1000       443161197  198470/io.hm-rpc.1
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        68632546   109/systemd-resolve
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          68635752   338/master
        tcp6       0      0 :::8089                 :::*                    LISTEN      1000       443171384  198744/io.web.1
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       443156586  198252/io.admin.0
        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       443170086  198673/io.simple-ap
        tcp6       0      0 :::8084                 :::*                    LISTEN      1000       443171328  198710/io.ws.0
        tcp6       0      0 :::111                  :::*                    LISTEN      0          68631547   1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          68633959   156/sshd: /usr/sbin
        tcp6       0      0 :::3040                 :::*                    LISTEN      1000       443171930  198814/io.radar-tra
        tcp6       0      0 :::3000                 :::*                    LISTEN      108        442967241  196375/grafana
        tcp6       0      0 :::3500                 :::*                    LISTEN      0          68633200   140/node
        tcp6       0      0 :::3501                 :::*                    LISTEN      1000       443162816  198489/io.sonos.0
        udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1000       443174031  198874/python3
        udp        0      0 192.168.178.105:5353    0.0.0.0:*                           1000       443174030  198874/python3
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       443174026  198874/python3
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       443170615  198699/io.esphome.0
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        68632545   109/systemd-resolve
        udp        0      0 192.168.178.105:68      0.0.0.0:*                           101        441373288  88/systemd-networkd
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          68631546   1/init
        udp6       0      0 :::111                  :::*                                0          68631548   1/init
          darkiop Most Active last edited by
          Guten Morgen, bisher keine Auffälligkeiten auf dem Testsystem. Installation lief unauffällig durch.
          Grüße und ein schönes Wochenende!
            fastfoot @Gaspode last edited by
            @gaspode sagte in js-controller Lucy (v7.0.0) Alpha Test:
            Im Expertenmodus das Häkchen bei "Nutze Alpha-Repo (@next)" setzen
            ich lese immer Häkchen, kann aber keines finden. Installer Version 3.3.0, gerade runtergeladen. Auch ein Expertenmodus wird da nicht angeboten.
              sigi234 Forum Testing Most Active @fastfoot last edited by sigi234
              @fastfoot sagte in js-controller Lucy (v7.0.0) Alpha Test:
              Hast du ihn auch aktiviert? Soweit ich noch weiß auf das Logo doppelt klicken.
                fastfoot @sigi234 last edited by
                @sigi234 sagte in js-controller Lucy (v7.0.0) Alpha Test:
                Hatte ich natürlich nicht, habe einfach den Installer runtergeladen und ausgeführt. Doku, falls vorhanden, wo? Ist also nicht benutzerfreundlich bzw. wenn man Expertendinge machen will kann man ja auch fragen. Ist echt gut versteckt, aber Danke, hattest Recht und jetzt gibts auch den Haken mit dem Alphamodus 🙂
                  Kaum hat man den Haken gefunden und aktiviert, schon hat man den neuesten Controller und auch die Daten vom vorherigen System wurden alle übernommen. Wollte schon immer mal den neuen Installer probieren, ist wirklich klasse. Das vorige System hatte ich noch mit npx installiert
                    https://github.com/ioBroker/ioBroker.build/blob/master/Windows-Installer.md
                    @Gaspode
                    Sollte man in der Doku erwähnen.
                    Gaspode 1 Reply Last reply Reply Quote 1
                    • Gaspode
                      Gaspode @sigi234 last edited by Gaspode
                      @sigi234 said in js-controller Lucy (v7.0.0) Alpha Test:
                      Ja, allerdings war das ja ursprünglich als verstecktes Feature gedacht. Da wir jetzt offen dazu aufrufen, den Installer für Alpha-Versionen zu nutzen, sollte das wohl besser auch in die Doku. 😄
                      Ich kümmere mich drum.
                      Edit: https://github.com/ioBroker/ioBroker.docs/pull/550
                      @fastfoot said in js-controller Lucy (v7.0.0) Alpha Test:
                      Danke für das Feedback, freut mich, dass alles geklappt hat.
                      Gaspode69 created this issue in ioBroker/ioBroker.docs
                      closed Update Windows installer documentation #550
                      • mcm1957
                        mcm1957 @foxriver76 last edited by
                        @foxriver76
                        Ein Scan alle im repository gelisteten Adapter hat ergeben, dass folgende Adapter potenziell inkompatibel sein können und auf Grund der (an sich internen) Änderungen am Plug In System Störungen auslösen können:
                        • wegen dependency auf @iobroker/sentry-plugin:
                        ioBroker.dysonairpurifier
                        ioBroker.mielecloudservice
                        ioBroker.robonect
                        ioBroker.resol
                        ioBroker.wireguard
                        • wegen expliziter dependency auf iobroker.js-controller:
                        ioBroker.hausbus_de
                        • wegen expliziter dependency auf dev-server (*)
                        ioBroker.sonnen-charger
                        ioBroker.vis-map
                        (*) die falsche dependency zu dev-server wird wahrscheinlich keine Probleme bereiten außer dass unnötiger Code installiert wird.
                          Shadowhunter23 @mcm1957 last edited by
                          @mcm1957 sagte in js-controller Lucy (v7.0.0) Alpha Test:
                          ioBroker.robonect
                          ioBroker.resol
                          ioBroker.wireguard
                          Stellt sich die Frage bin wann https://github.com/Grizzelbee wieder online ist.
                          • Negalein
                            Negalein Global Moderator @Shadowhunter23 last edited by
                            @shadowhunter23 sagte in js-controller Lucy (v7.0.0) Alpha Test:
                            war vor 2 Wochen im Forum und auf Git.
                            auf GIT reagiert er auch zeitnah. Oder sonst per Mail (in der Lizenz auffindbar).
                              apollon77 @Negalein last edited by
                              @negalein Ich habe eine E-Mail vo Ihm. Er kümmert sich zeitnah darum
                                Shadowhunter23 last edited by Shadowhunter23
                                Wireguard Adapter Update auf 1.7.0 und danach js-controller.
                                System läuft aber eine Meldung beim Start die ich nicht zuordnen kann:
                                admin.0 2024-10-01 16:43:08.776	error	Cannot init i18n: Error: Cannot find i18n directory
                                Script v.2024-09-21
                                *** BASE SYSTEM ***
                                 Static hostname: iobroker
                                         Chassis: container ☐
                                  Virtualization: lxc
                                          Kernel: Linux 6.8.12-2-pve
                                OS is similar to:
                                model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : 64 bit
                                 16:50:33 up 4 days, 23:33,  1 user,  load average: 0.38, 0.76, 0.68
                                CPU threads: 4
                                *** LIFE CYCLE STATUS ***
                                Operating System is the current Debian stable version codenamed 'bookworm'!
                                *** TIME AND TIMEZONES ***
                                               Local time: Tue 2024-10-01 16:50:33 CEST
                                           Universal time: Tue 2024-10-01 14:50:33 UTC
                                                 RTC time: n/a
                                              NTP service: n/a
                                          RTC in local TZ: no
                                tobias
                                HOME=/home/tobias
                                GROUPS=tobias adm dialout sudo audio video plugdev users iobroker
                                iobroker
                                HOME=/home/iobroker
                                GROUPS=iobroker tty dialout audio video plugdev redis
                                *** DISPLAY-SERVER SETUP ***
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:             10G        3.7G        6.0G        499K        979M        7.0G
                                Swap:             0B          0B          0B
                                Total:           10G        3.7G        6.0G
                                Active iob-Instances:   50
                                        10240 M total memory
                                         3559 M used memory
                                         2678 M active memory
                                         1599 M inactive memory
                                         5746 M free memory
                                            0 M buffer memory
                                          934 M swap cache
                                            0 M total swap
                                            0 M used swap
                                            0 M free swap
                                top - 16:50:33 up 4 days, 23:33,  1 user,  load average: 0.38, 0.76, 0.68
                                Tasks:  80 total,   1 running,  79 sleeping,   0 stopped,   0 zombie
                                %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :  10240.0 total,   5745.3 free,   3560.7 used,    934.4 buff/cache
                                MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6679.3 avail Mem
                                *** DMESG CRITICAL ERRORS ***
                                No critical errors detected
                                *** FILESYSTEM ***
                                /dev/mapper/pve-vm--400--disk--0 ext4       20G   12G  7.3G  61% /
                                udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                                tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                                tmpfs                            tmpfs     3.1G  144K  3.1G   1% /run
                                tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1000
                                /      /dev/mapper/pve-vm--400--disk--0 ext4   rw,relatime,stripe=16
                                /var:
                                1.1G    /var/
                                495M    /var/lib
                                344M    /var/lib/redis
                                307M    /var/cache
                                303M    /var/cache/apt
                                Archived and active journals take up 290.2M in the file system.
                                306M    /opt/iobroker/backups/
                                706M    /opt/iobroker/iobroker-data/
                                573M    /opt/iobroker/iobroker-data/files
                                299M    /opt/iobroker/iobroker-data/files/javascript.admin
                                265M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                264M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                40M     /opt/iobroker/iobroker-data/objects.jsonl
                                38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                29M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.448016d7.js.map
                                24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.4ff93037.js.map
                                19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                                USB-Devices by-id:
                                HINT:
                                Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                tcp
                                HINT:
                                Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                                tcp
                                HINT:
                                Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
                                tcp
                                HINT:
                                Your zigbee.3 COM-Port is NOT matching 'by-id'. Please check your setting:
                                tcp
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                  Version table:
                                     18.19.0+dfsg-6~deb12u2 500
                                        500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                     18.19.0+dfsg-6~deb12u1 500
                                        500 http://security.debian.org bookworm-security/main amd64 Packages
                                Errors in npm tree: 0
                                ioBroker Status
                                At least one iobroker host is running.
                                Objects type: redis
                                States  type: redis
                                Hosts:
                                iobroker            iobroker (version: 7.0.0, hostname: iobroker      , alive, uptime: 435)
                                js-controller:  7.0.0-alpha.1-20241001-61327866b
                                admin:          7.2.0
                                javascript:     8.8.3
                                nodejs modules from github:     0
                                Adapter State
                                + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
                                + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
                                + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                                + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                                + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                                + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                                  system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                                + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                                + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                                  system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                  system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                                + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                  system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
                                + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                + system.adapter.mytime.0                 : mytime                : iobroker                                 -  enabled
                                + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                                + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
                                + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                                  system.adapter.octoprint.1              : octoprint             : iobroker                                 - disabled
                                  system.adapter.octoprint.2              : octoprint             : iobroker                                 - disabled
                                + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
                                + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                                + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
                                + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                                + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
                                + system.adapter.pushover.2               : pushover              : iobroker                                 -  enabled
                                + system.adapter.rest-api.0               : rest-api              : iobroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
                                + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                                + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
                                + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
                                + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
                                  system.adapter.sayit.4                  : sayit                 : iobroker                                 - disabled
                                + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                  system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
                                + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                                + system.adapter.text2command.1           : text2command          : iobroker                                 -  enabled
                                + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                  system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                                + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                                  system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                                  system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                + system.adapter.wireguard.0              : wireguard             : iobroker                                 -  enabled
                                + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.64:20108
                                + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.69:20108
                                + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.79:20108
                                + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.63:20108
                                + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.99:20108
                                + instance is alive
                                Adapter    "admin"        : 7.2.0    , installed 7.2.0
                                Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
                                Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                                Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                                Adapter    "email"        : 1.3.1    , installed 1.3.1
                                Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
                                Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                                Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                                Adapter    "iot"          : 3.4.2    , installed 3.4.2
                                Adapter    "lg-thinq"     : 1.0.2    , installed 1.0.2
                                Adapter    "mytime"       : 0.7.12   , installed 0.7.12
                                Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                                Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                                Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                                Adapter    "operating-hours": 1.1.0  , installed 1.1.0
                                Adapter    "ping"         : 1.7.9    , installed 1.7.9
                                Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                                Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
                                Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                                Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                                Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                                Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                                Adapter    "vis-icontwo"  : 1.6.3    , installed 1.6.3
                                Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                                Adapter    "wireguard"    : 1.7.0    , installed 1.7.0
                                Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                Objects and States
                                Objects:        12010
                                States:         10822
                                Hit:2 http://security.debian.org bookworm-security InRelease
                                Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                                Hit:5 https://packages.redis.io/deb bookworm InRelease
                                Reading package lists... Done
                                Pending Updates: 0
                                tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      106        37453821   170/redis-server 12
                                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       71946613   529095/io.mqtt.0
                                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       71947833   529236/io.shelly.1
                                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          37456351   1/init
                                tcp        0      0 192.168.0.222:9092      0.0.0.0:*               LISTEN      1001       71943709   529140/io.nuki.0
                                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          37461486   404/master
                                tcp6       0      0 :::3000                 :::*                    LISTEN      1001       71953639   529478/io.fullybrow
                                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          37461487   404/master
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          37454675   1/init
                                tcp6       0      0 :::111                  :::*                    LISTEN      0          37456353   1/init
                                tcp6       0      0 :::80                   :::*                    LISTEN      0          37461347   196/apache2
                                tcp6       0      0 ::1:6379                :::*                    LISTEN      106        37453822   170/redis-server 12
                                tcp6       0      0 :::8093                 :::*                    LISTEN      1001       71955034   529552/io.rest-api.
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       71957071   529767/io.web.0
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       71941360   528774/io.admin.0
                                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       71955337   529647/io.simple-ap
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       71947501   529019/io.chromecas
                                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       71946940   529216/io.shelly.0
                                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       71941981   529256/io.tuya.0
                                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       71941982   529256/io.tuya.0
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          37454669   90/dhclient
                                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          37456352   1/init
                                udp        0      0 192.168.0.222:123       0.0.0.0:*                           0          37461313   179/ntpd
                                udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          37461311   179/ntpd
                                udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          37461307   179/ntpd
                                udp6       0      0 :::111                  :::*                                0          37456354   1/init
                                udp6       0      0 fe80::8c62:1cff:fe4:123 :::*                                105        37456604   179/ntpd
                                udp6       0      0 ::1:123                 :::*                                0          37461315   179/ntpd
                                udp6       0      0 :::123                  :::*                                0          37461304   179/ntpd
                                2024-10-01 16:45:52.012  - info: host.iobroker instance system.adapter.sayit.0 in version "5.0.0" started with pid 529572
                                2024-10-01 16:45:54.615  - info: device-watcher.0 (529050) Instanz-Wachdog:
                                mytime.0: undefined
                                2024-10-01 16:45:56.042  - info: host.iobroker instance system.adapter.sayit.1 in version "5.0.0" started with pid 529592
                                2024-10-01 16:45:59.306  - info: device-watcher.0 (529050) Instanz-Wachdog:
                                rest-api.0: undefined
                                2024-10-01 16:46:00.018  - info: host.iobroker instance system.adapter.sayit.2 in version "5.0.0" started with pid 529607
                                2024-10-01 16:46:04.020  - info: host.iobroker instance system.adapter.sayit.3 in version "5.0.0" started with pid 529627
                                2024-10-01 16:46:08.013  - info: host.iobroker instance system.adapter.simple-api.0 in version "2.8.0" started with pid 529647
                                2024-10-01 16:46:12.011  - info: host.iobroker instance system.adapter.text2command.0 in version "3.0.3" started with pid 529667
                                2024-10-01 16:46:16.036  - info: host.iobroker instance system.adapter.text2command.1 in version "3.0.3" started with pid 529686
                                2024-10-01 16:46:20.015  - info: host.iobroker instance system.adapter.trashschedule.0 in version "3.3.0" started with pid 529706
                                2024-10-01 16:46:24.057  - info: host.iobroker instance system.adapter.vis-inventwo.0 in version "3.3.4" started with pid 529727
                                2024-10-01 16:46:24.697  - info: vis-inventwo.0 (529727) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v20.17.0, js-controller: 7.0.0-alpha.1-20241001-61327866b
                                2024-10-01 16:46:29.653  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
                                2024-10-01 16:46:32.017  - info: host.iobroker instance system.adapter.web.0 in version "6.3.1" started with pid 529767
                                2024-10-01 16:46:42.738  - info: device-watcher.0 (529050) Instanz-Wachdog:
                                web.0: undefined
                                                        v.2024-09-21
                                  Virtualization: lxc
                                Installation:           lxc
                                Kernel:                 x86_64
                                Userland:               64 bit
                                Timezone:               Europe/Berlin (CEST, +0200)
                                User-ID:                1000
                                Boot Target:            multi-user.target
                                Pending OS-Updates:     0
                                Pending iob updates:    0
                                Nodejs-Installation:
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                Recommended versions are nodejs 20.17.0 and npm 10.8.2
                                nodeJS installation is correct
                                MEMORY:
                                Mem:             10G        3.8G        6.0G        499K        979M        7.0G
                                Swap:             0B          0B          0B
                                Total:           10G        3.8G        6.0G
                                ioBroker Core:          js-controller           7.0.0-alpha.1-20241001-61327866b
                                                        admin                   7.2.0
                                Objects type: redis
                                States  type: redis
                                Objects:                12010
                                States:                 10822
                                Size of iob-Database:
                                4.0M    /opt/iobroker/iobroker-data/states.jsonl
                                • mcm1957
                                  mcm1957 @Shadowhunter23 last edited by
                                  @shadowhunter23 said in js-controller Lucy (v7.0.0) Alpha Test:
                                  Da fehlt wahrscheinlich dem admin ein Verzeichnis. Mach ein Issue beim admin auf.
                                  Diese i18n Verzeichnis / i18n System ist neu und ermöglicht (in Zukunft) dass Adapter lokele Übersetzungen bei Meldungen wie z.B. Notifications verwenden können ohne selsbt dafür code erstellen zu müssen. Ist aber explizit NICHT für logs gedacht da zumindest ich und die mesiten devs hier weder chinesische noch russische noch italienische ... Fehlermeldungen interpretireren können (und wollen).
                                  alpha js-controller lucy tester
                                  14
                                  35
                                  4876
