    4. Gelöst: PING Adapter stürzt ab
      michihorn last edited by michihorn
      Hallo ich habe den aktuellen PING Adapter 1.7.8 auf zwei unterschiedlichen Systemen installiert. Auf beiden Geräten erhalte ich die selbe Fehlermeldung:
      Log-Größe: 823 B
      ping.0
      Zeit
      debug
      Nachricht
      ping.0
      2024-09-30 13:03:55.711	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      ping.0
      2024-09-30 13:03:55.711	debug	Plugin sentry destroyed
      ping.0
      2024-09-30 13:03:55.709	info	terminating
      ping.0
      2024-09-30 13:03:55.186	error	Cannot read properties of undefined (reading 'init')
      ping.0
      2024-09-30 13:03:55.185	error	TypeError: Cannot read properties of undefined (reading 'init') at main (/opt/iobroker/node_modules/iobroker.ping/main.js:858:16)
      ping.0
      2024-09-30 13:03:55.181	error	unhandled promise rejection: Cannot read properties of undefined (reading 'init')
      ping.0
      2024-09-30 13:03:55.180	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      ping.0
      2024-09-30 13:03:55.047	info	starting. Version 1.7.8 in /opt/iobroker/node_modules/iobroker.ping, node: v20.17.0, js-controller: 6.0.11
      ping.0
      2024-09-30 13:03:54.048	debug	Plugin sentry Initialize Plugin (enabled=true)
      Ich habe auch das Sentry Plug-In mal ausgeschaltet, ohne Erfolg.
      ping.0
      2024-09-30 13:10:43.445	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      ping.0
      2024-09-30 13:10:43.444	info	terminating
      ping.0
      2024-09-30 13:10:42.938	error	Cannot read properties of undefined (reading 'init')
      ping.0
      2024-09-30 13:10:42.937	error	TypeError: Cannot read properties of undefined (reading 'init') at main (/opt/iobroker/node_modules/iobroker.ping/main.js:858:16)
      ping.0
      2024-09-30 13:10:42.936	error	unhandled promise rejection: Cannot read properties of undefined (reading 'init')
      ping.0
      2024-09-30 13:10:42.935	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      ping.0
      2024-09-30 13:10:42.814	info	starting. Version 1.7.8 in /opt/iobroker/node_modules/iobroker.ping, node: v20.17.0, js-controller: 6.0.11
      ping.0
      2024-09-30 13:10:42.153	debug	Plugin sentry destroyed because not initialized correctly
      ping.0
      2024-09-30 13:10:42.099	debug	Plugin sentry Do not initialize Plugin (enabled=false)
      ping.0
      2024-09-30 13:10:08.301	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      ping.0
      2024-09-30 13:10:08.300	info	terminating
      ping.0
      2024-09-30 13:10:07.794	error	Cannot read properties of undefined (reading 'init')
      ping.0
      2024-09-30 13:10:07.794	error	TypeError: Cannot read properties of undefined (reading 'init') at main (/opt/iobroker/node_modules/iobroker.ping/main.js:858:16)
      ping.0
      2024-09-30 13:10:07.792	error	unhandled promise rejection: Cannot read properties of undefined (reading 'init')
      ping.0
      2024-09-30 13:10:07.791	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      ping.0
      2024-09-30 13:10:07.657	info	starting. Version 1.7.8 in /opt/iobroker/node_modules/iobroker.ping, node: v20.17.0, js-controller: 6.0.11
      ping.0
      2024-09-30 13:10:06.989	debug	Plugin sentry destroyed because not initialized correctly
      ping.0
      2024-09-30 13:10:06.978	debug	Plugin sentry Do not initialize Plugin (enabled=false)
      Michael
      Meister Mopper 2 Replies Last reply Reply Quote 0
      • Meister Mopper
        Meister Mopper @michihorn last edited by
        @michihorn
        Zur Analyse
        iob stop
        iob fix
        iob start
        iob diag
        und das Ergebnis in </> Codetags hier reinstellen.
        • amg_666
          amg_666 @Meister Mopper last edited by amg_666
          @meister-mopper Brauchst du nicht zu machen, das ist ein issue (war auch schon bei 1.7.7 so), ist auf github gemeldet und "under investigation" 🙂
          https://github.com/ioBroker/ioBroker.ping/issues/188
          @michihorn Geh auf Version 1.7.6 zurück, die läuft
          da_Woody 1 Reply Last reply Reply Quote 3
          • Meister Mopper
            @michihorn
            Dann zurück auf 1.6.2 🤷‍♂️
              michihorn @Meister Mopper last edited by
              @meister-mopper Ich bin wie von amg_666 empfohlen auf 1.7.6 gegangen. Klappt ohne Fehlermeldungen.
              Danke Euch beiden.
              amg_666 1 Reply Last reply Reply Quote 1
              • da_Woody
                da_Woody @amg_666 last edited by
                @amg_666 warum jetzt wer ein issue extra für 1.7.8 gemacht hat, sei dahin gestellt. 😉
                wird ja schon bei 1.7.7 moniert, die es ja gar nicht mehr gibt. auch wenn sie als latest noch da steht...
                • amg_666
                  amg_666 @da_Woody last edited by
                  @da_woody sagte in Gelöst: PING Adapter stürzt ab:
                  Das hat mich auch leicht irritiert 🙂 Ich hatte das für 1.7.7 aufgemacht und da im Thread steht ja auch schon, dass die 1.7.8 das Problem nicht gelöst hat...
                  • mcm1957
                    mcm1957 @amg_666 last edited by mcm1957
                    Ein paar Worte zu diesem Thema - auch wenn ich nicht am ping Adapter mitentwickle:
                    ping 1.7.7 und 1.7.8 funktionieren derzeit nicht stabile (oder besser fast nie). Die Ursache mittlerweile geklärt (npm aktualisisert die dependency adapter-core nicht). An einer Lösung wird derzeit gearbeitet - kann aber noch dauern. Ev. werden die neueren ping Versionen auch js-controller 7 erfordern.
                    Derzeit bitte auf 1.7.6 bleiben.
                    Falls jemand noch eine 1.7.7 od .8 Installation hat bei der der ping adapter abstürzt würde mich (persönlich) der Output von npm ls interessieren:
                    cd /opt/iobroker
                    npm ls @iobroker/adapter-core
                    EDIT:
                    npm Befehle korrigiert
                    • Armilar
                      Armilar Most Active Forum Testing last edited by Armilar
                      @mcm1957 sagte in Gelöst: PING Adapter stürzt ab:
                      cd /opt/iobroker/node_modules
                      Ist ja kein Problem dem beim Absturz zu begleiten... Drehe den gleich wieder zurück
                      2024-09-30 18:44:52.440	info	Got terminate signal TERMINATE_YOURSELF
                      2024-09-30 18:44:52.977	info	terminating
                      2024-09-30 18:44:52.981	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2024-09-30 18:45:03.263	info	starting. Version 1.7.8 in /opt/iobroker/node_modules/iobroker.ping, node: v20.17.0, js-controller: 7.0.0-alpha.0-20240926-91f9b082f
                      2024-09-30 18:45:03.456	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2024-09-30 18:45:03.461	error	unhandled promise rejection: Cannot read properties of undefined (reading 'init')
                      2024-09-30 18:45:03.475	error	TypeError: Cannot read properties of undefined (reading 'init') at main (/opt/iobroker/node_modules/iobroker.ping/main.js:858:16)
                      2024-09-30 18:45:03.476	error	Cannot read properties of undefined (reading 'init')
                      2024-09-30 18:45:04.206	info	terminating
                      2024-09-30 18:45:04.210	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2024-09-30 18:45:42.540	info	starting. Version 1.7.8 in /opt/iobroker/node_modules/iobroker.ping, node: v20.17.0, js-controller: 7.0.0-alpha.0-20240926-91f9b082f
                      2024-09-30 18:45:42.718	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2024-09-30 18:45:42.723	error	unhandled promise rejection: Cannot read properties of undefined (reading 'init')
                      2024-09-30 18:45:42.731	error	TypeError: Cannot read properties of undefined (reading 'init') at main (/opt/iobroker/node_modules/iobroker.ping/main.js:858:16)
                      2024-09-30 18:45:42.734	error	Cannot read properties of undefined (reading 'init')
                      2024-09-30 18:45:43.337	info	terminating
                      2024-09-30 18:45:43.341	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                      Last login: Mon Sep 30 18:46:35 2024 from 192.168.1.193
                      armilar@iobroker:~$ cd /opt/iobroker/node_modules
                      armilar@iobroker:/opt/iobroker/node_modules$ npm ls adapter.core
                      [sudo] password for armilar:
                      iobroker.inst@3.0.0 /opt/iobroker
                      `-- (empty)
                      Habs mal mit dem JS-Controller 7 gemacht...
                      EDIT: Ist übrigens Ping v1.7.8
                      • mcm1957
                        mcm1957 @Armilar last edited by mcm1957
                        @armilar
                        DAN KE und sorry
                        Sollte heißen
                        cd /opt/iobroker
                        Man sollte nicht 3 Sachen parallel machen - Asche auf mein Haupt...
                        Nachtrag:
                        Der derzeitige js-controller 7 löst das Problem auch noch nicht. Will hier nicht auf Details eingehen damit nicht wild gebastelt wird und dann wieder wer jammert dass er sich sein System zerschossen hat ...
                        • Armilar
                          Armilar Most Active Forum Testing @mcm1957 last edited by
                          Man sollte nicht 3 Sachen paralle machen - Asche auf mein Haupt...
                          Man sollte nicht blind Befehle eingeben 😉 Hätte ich auch selbst drauf kommen können ...
                          armilar@iobroker:/opt/iobroker$ npm ls @iobroker/adapter-core
                          +-- iobroker.accuweather@1.5.0
                          | `-- @iobroker/adapter-core@3.1.6 overridden
                          +-- iobroker.admin@7.1.5
                          | +-- @iobroker/adapter-core@3.1.6 deduped
                          | `-- @iobroker/socket-classes@1.5.6
                          |   `-- @iobroker/adapter-core@3.1.6 deduped
                          +-- iobroker.alarm@3.6.2
                          +-- iobroker.alexa2@3.26.5
                          +-- iobroker.alias-manager@1.2.6
                          +-- iobroker.asuswrt@1.0.1
                          +-- iobroker.backitup@3.0.25
                          +-- iobroker.bosesoundtouch@0.11.1
                          +-- iobroker.broadlink2@2.3.0
                          +-- iobroker.cameras@2.1.2
                          +-- iobroker.chromecast@3.4.1
                          +-- iobroker.cloud@5.0.1
                          | `-- @iobroker/socket-classes@1.5.0
                          +-- iobroker.daikin-cloud@0.4.10 (git+ssh://git@github.com/Apollon77/ioBroker.daikin-cloud.git#f0e1a492aa9d56ab669a02af8652a2d5d8aaf2a8)
                          +-- iobroker.daswetter@3.1.16
                          +-- iobroker.deconz@1.5.0
                          +-- iobroker.discovery@5.0.0
                          +-- iobroker.dwd@2.8.5
                          +-- iobroker.echarts@1.9.2
                          +-- iobroker.email@1.3.1
                          +-- iobroker.energiefluss-erweitert@0.4.1
                          +-- iobroker.feiertage@1.2.0
                          +-- iobroker.firetv@2.1.0
                          +-- iobroker.followthesun@0.5.1
                          +-- iobroker.geofency@1.2.4
                          +-- iobroker.gigaset-elements@0.4.3
                          +-- iobroker.hass@1.4.0
                          +-- iobroker.hmip@1.24.3
                          +-- iobroker.homeconnect@1.4.1
                          +-- iobroker.homekit-controller@0.5.10
                          +-- iobroker.hoover@0.1.2
                          +-- iobroker.ical@1.15.0
                          +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
                          +-- iobroker.influxdb@4.0.2
                          +-- iobroker.info@2.0.0
                          +-- iobroker.iot@3.4.2
                          +-- iobroker.jarvis@3.2.0-rc.5
                          +-- iobroker.javascript@8.8.3
                          +-- iobroker.linux-control@1.1.5
                          +-- iobroker.logparser@2.2.2
                          +-- iobroker.luftdaten@4.0.0
                          +-- iobroker.mercedesme@0.2.3
                          +-- iobroker.mihome@1.4.0
                          +-- iobroker.moma@1.2.9
                          +-- iobroker.mqtt-client@2.0.1
                          +-- iobroker.mqtt@6.1.2
                          +-- iobroker.nina@0.0.26
                          +-- iobroker.notificationforandroidtv@3.0.4
                          +-- iobroker.nspanel-lovelace-ui@0.1.0-preAlpha.0 (git+ssh://git@github.com/ticaki/ioBroker.nspanel-lovelace-ui.git#0364d50fdf5b9ca37f1295d7b6d191d75616ae13)
                          +-- iobroker.nut@1.6.0
                          +-- iobroker.odl@4.0.0
                          +-- iobroker.onvif@1.1.4
                          +-- iobroker.openweathermap@1.1.2
                          +-- iobroker.pegelalarm@1.3.5
                          +-- iobroker.ping@1.7.8
                          +-- iobroker.pollenflug@2.0.0
                          +-- iobroker.pvforecast@3.0.0
                          +-- iobroker.scenes@3.2.3
                          +-- iobroker.shelly@8.2.1
                          +-- iobroker.shuttercontrol@1.8.2
                          +-- iobroker.simple-api@2.8.0
                          +-- iobroker.snmp@3.2.0
                          +-- iobroker.socketio@6.7.1
                          +-- iobroker.sonoff@3.1.2
                          +-- iobroker.sonos@3.0.0
                          +-- iobroker.sony-bravia@1.1.0
                          +-- iobroker.sourceanalytix@0.4.14
                          +-- iobroker.spotify-premium@1.5.0
                          +-- iobroker.squeezeboxrpc@1.3.15
                          +-- iobroker.tankerkoenig@3.4.0
                          +-- iobroker.telegram@3.9.0
                          +-- iobroker.terminal@1.0.0
                          +-- iobroker.text2command@3.0.3
                          +-- iobroker.tuya@3.16.0
                          +-- iobroker.upnp@1.0.21
                          +-- iobroker.uv-protect@0.6.3
                          +-- iobroker.virtualpowermeter@1.4.6
                          +-- iobroker.vis-google-fonts@1.0.4
                          +-- iobroker.vis-inventwo@3.3.4
                          +-- iobroker.vis-metro@1.2.0
                          +-- iobroker.vis@1.5.6
                          +-- iobroker.volumio@0.2.0
                          +-- iobroker.weather-warnings@0.6.7
                          +-- iobroker.weatherunderground@3.7.0
                          +-- iobroker.web@6.3.1
                          +-- iobroker.welcome@0.3.0
                          +-- iobroker.whatsapp-cmb@0.3.0
                          +-- iobroker.wifilight@2.0.1
                          +-- iobroker.wled@0.7.3-beta.0
                          | `-- @jey-cee/dm-utils@0.0.1
                          +-- iobroker.worx@3.1.0
                          +-- iobroker.ws@2.6.2
                          +-- iobroker.yahka@1.0.9
                          `-- iobroker.zigbee2mqtt@2.13.10
                            `-- @iobroker/dm-utils@0.1.9
                          • mcm1957
                            @armilar said in Gelöst: PING Adapter stürzt ab:
                            DANKE
                            Gott sei dank wars kein sudo rm -rf /
                            P.S: Bitte den Befehl NICHT testen - zumindest nicht bis vir der nächsten Neuinstallation.
                            Armilar 1 Reply Last reply Reply Quote 2
                            • Armilar
                              @mcm1957
                              Bei 32 VM Snapshots wird wohl noch ein funktionierendes dazwischen sein 😁
                                crunchip Forum Testing Most Active @Armilar last edited by
                                @armilar sagte in Gelöst: PING Adapter stürzt ab:
                                Bei 32 VM Snapshots
                                für was braucht man 32, sollte ein Fehler vorhanden sein, baust du weiterhin drauf auf
                                solltest du ein backup zurückspielen, sind alle snaps weg
                                MartinP Armilar 2 Replies Last reply Reply Quote 0
                                • MartinP
                                  MartinP @crunchip last edited by
                                  @crunchip Für was installiert man von einem PING(!) Adapter eine Beta version?
                                  Jedenfalls sollte man sich das GUT überlegen, wenn man nur ein Produktiv-System hat ...
                                    crunchip Forum Testing Most Active @MartinP last edited by crunchip
                                    @martinp naja, muss jeder selbst wissen
                                    ich fahre seit Jahren latest und hab nur ein produktiv System laufen
                                    alle Individualitäten könnte ich mit einem test-System gar nicht nachbilden, von daher hab ich das gelassen
                                    • Armilar
                                      Armilar Most Active Forum Testing @crunchip last edited by Armilar
                                      @crunchip sagte in Gelöst: PING Adapter stürzt ab:
                                      Ihr glaubt nicht wirklich, dass ich hier ein ernsthaftes Problem hatte oder in den letzten 7-8 Jahren mal ein ernsthaftes Problemchen gehabt hätte, geschweige ein Backup benötigt hätte?
                                      Der Test galt der Unauffindbarkeit des Problems im Ping-Adapter und der Chance, dass ein Entwickler einen Fehler in einem Adapter finden kann.
                                      Dafür habe ich mir einen Clone der ioBroker-Produktiv-VM erstellt und gemountet, das BETA mit dem 7ner JS-Controller installiert und die Ausgabe gepostet. Geht jederzeit, dass aktuelle Produktivsystem für ein paar Minuten zum Testsystem zu machen (ist nicht mal Zeitaufwand). Danach schaltest du den Clone wieder ab und startest das Prod-System.
                                      Läuft im Raid-5 auf einem ordentlichen Server und ist VM-seitig von Influx, Grafana, Zigbee, etc. getrennt.
                                      Natürlich mache ich auch Backups - für den wahrscheinlich nie eintreffenden Worst-Case...
                                      Die Snaps gehen 32 Tage in die Vergangenheit und wenn in dieser Zeit wirklich mal ein kleineres Problemchen aufgetaucht ist, dann drehst du die Zeit halt wieder auf den letzten funktionalen Stand... In der Regel der letzte Snapshot, da ansonsten schon die Watch-Dogs tagelang rumgemeckert hätten.
                                      crunchip 1 Reply Last reply Reply Quote 1
                                        bestreitet auch niemand, nur wollte ich für andere unerfahrene Lesende noch mal aufmerksam machen, dass ein snapshot kein backup darstellt, wie viele denken
                                        macht trotzdem keinen Sinn und je nach "Problemchen" nützt dir der Snap nicht die Bohne
                                        so mal als Darstellung
                                        • mcm1957
                                          mcm1957 @crunchip last edited by
                                          Ich glaub zum Thema Backup / Snapshot etc. ist jetzt alles gesagt.
                                          Wenn nicht bitte eigenes Topic öffnen. Das hat mit dem PING Adapter nicht mal am Rande zu tun.
                                          DANKE
                                          Armilar 1 Reply Last reply Reply Quote 4
                                          • amg_666
                                            amg_666 @michihorn last edited by
                                            @michihorn Die 1.7.9 ist raus, bei mir läuft sie einwandfrei, kannst ja mal dein Glück versuchen...
                                            da_Woody M 2 Replies Last reply Reply Quote 2
                                            1424
