    4. Fehler bei Installation javascript
      Don_Kanaille @Thomas Braun last edited by
      @thomas-braun das spuckt mir di diag aus...
      v.2024-08-12
      Static hostname: iobroker
      Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
      Kernel: Linux 6.1.21-v7+
      Architecture: arm
      Installation: native
      Kernel: armv7l
      Userland: 32 bit
      Timezone: Europe/Berlin (CEST, +0200)
      User-ID: 1000
      Display-Server: false
      Boot Target: multi-user.target
      Pending OS-Updates: 2
      Pending iob updates: 0
      Nodejs-Installation:
      /usr/bin/nodejs v20.17.0
      /usr/bin/node v20.17.0
      /usr/bin/npm 10.8.2
      /usr/bin/npx 10.8.2
      /usr/bin/corepack 0.29.3
      Recommended versions are nodejs 20.17.0 and npm 10.8.2
      MEMORY:
      total used free shared buff/cache available
      Mem: 921M 552M 120M 0.0K 248M 314M
      Swap: 99M 68M 31M
      Total: 1.0G 620M 152M
      Active iob-Instances: 14
      Upgrade policy: none
      ioBroker Core: js-controller 6.0.11
      admin 7.1.5
      ioBroker Status: iobroker is running on this host.
      Objects type: jsonl
      States type: jsonl
      • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
      • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects: 1768
      States: 1393
      Size of iob-Database:
      13M /opt/iobroker/iobroker-data/objects.jsonl
      648K /opt/iobroker/iobroker-data/states.jsonl
      Some problems detected, please run iob fix and try to have them fixed
      wie gesagt iob fix lief schon mehrfach drüber..
        Thomas Braun Most Active @Don_Kanaille last edited by
        @don_kanaille
        Die Langfassung bitte.
        Und kopier die Kopiermarken mit.
          @thomas-braun du merkst: "Profi" am Werk 😉
          ```bash
          Skript v.2024-08-12
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm
          OS is similar to: debian
          Model           : Raspberry Pi 3 Model B Rev 1.2
          Docker          : false
          Virtualization  : none
          Kernel          : armv7l
          Userland        : 32 bit
          Systemuptime and Load:
           21:02:19 up 11 min,  1 user,  load average: 0.44, 0.75, 0.65
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Tue 2024-10-01 21:02:19 CEST
                     Universal time: Tue 2024-10-01 19:02:19 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
          *** Display-Server-Setup ***
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            921M        519M        120M        0.0K        282M        347M
          Swap:            99M         67M         32M
          Total:          1.0G        586M        153M
                    921 M total memory
                    519 M used memory
                    260 M active memory
                    470 M inactive memory
                    120 M free memory
                     36 M buffer memory
                    245 M swap cache
                     99 M total swap
                     67 M used swap
                     32 M free swap
          top - 21:02:20 up 11 min,  1 user,  load average: 0.44, 0.75, 0.65
          Tasks: 147 total,   1 running, 146 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  4.4 us,  1.5 sy,  0.0 ni, 94.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :    922.0 total,    119.8 free,    519.5 used,    282.7 buff/cache
          MiB Swap:    100.0 total,     33.0 free,     67.0 used.    347.4 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4       29G  6.0G   22G  22% /
          devtmpfs       devtmpfs  333M     0  333M   0% /dev
          tmpfs          tmpfs     461M     0  461M   0% /dev/shm
          tmpfs          tmpfs     185M  976K  184M   1% /run
          /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
          tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
          [Tue Oct  1 20:50:57 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=5bd61bcd-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Tue Oct  1 20:51:00 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
          [Tue Oct  1 20:51:00 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
          [Tue Oct  1 20:51:00 2024] EXT4-fs (mmcblk0p2): recovery complete
          [Tue Oct  1 20:51:00 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Tue Oct  1 20:51:00 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Tue Oct  1 20:51:03 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          Show mounted filesystems:
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          2.6G    /var/
          2.1G    /var/log/journal/d635fc1f496c4c02ae7bd23ec48bcbd2
          2.1G    /var/log
          273M    /var/cache
          Archived and active journals take up 2.0G in the file system.
          /opt/iobroker/backups:
          103M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          415M    /opt/iobroker/iobroker-data/
          291M    /opt/iobroker/iobroker-data/files
          142M    /opt/iobroker/iobroker-data/files/vis-2
          81M     /opt/iobroker/iobroker-data/files/vis-2/static
          80M     /opt/iobroker/iobroker-data/files/vis-2/static/js
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
          19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
          19M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
          15M     /opt/iobroker/iobroker-data/files/vis-2/static/js/376.1862d3de.chunk.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Installed: 20.17.0-1nodesource1
            Candidate: 20.17.0-1nodesource1
            Version table:
           *** 20.17.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                  100 /var/lib/dpkg/status
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u5 500
                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
          Temp directories causing npm8 problem: 11
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  6.0.11
          admin:          7.1.5
          javascript:     "javascript" not found
          nodejs modules from github:     1
          `-- wake_on_lan@1.0.0 (git+ssh://git@github.com/agnat/node_wake_on_lan.git#dd6404623ccf4bc55b0ba8788ba38312b55435a1)
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
          + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.roomba.0                 : roomba                : iobroker                                 - disabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
          + system.adapter.systeminfo.0             : systeminfo            : iobroker                                 -  enabled
          + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
            system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
            system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
          + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.1.5    , installed 7.1.5
          Adapter    "backitup"     : 3.0.22   , installed 3.0.22
          Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
          Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
          Adapter    "hue"          : 3.12.0   , installed 3.12.0
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
          Controller "js-controller": 6.0.11   , installed 6.0.11
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "roomba"       : 1.3.0    , installed 1.3.0
          Adapter    "shelly"       : 7.0.0    , installed 7.0.0
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
          Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
          Adapter    "terminal"     : 1.0.0    , installed 1.0.0
          Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
          Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
          Adapter    "wled"         : 0.7.2    , installed 0.7.2
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Objects and States
          Objects:        1768
          States:         1393
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 https://deb.nodesource.com/node_20.x nodistro InRelease
          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
          Reading package lists...
          Pending Updates: 2
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       12047      943/io.shelly.0
          tcp        0      0 127.0.0.1:37387         0.0.0.0:*               LISTEN      1001       17765      1097/io.yahka.0
          tcp        0      0 0.0.0.0:45877           0.0.0.0:*               LISTEN      1001       14853      1097/io.yahka.0
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14394      482/iobroker.js-con
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14399      482/iobroker.js-con
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11647      494/sshd: /usr/sbin
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18458      1275/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12051      906/io.admin.0
          tcp6       0      0 :::8088                 :::*                    LISTEN      1001       16850      1403/io.terminal.0
          tcp6       0      0 :::3500                 :::*                    LISTEN      1001       12049      962/io.sonos.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          11649      494/sshd: /usr/sbin
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       14864      1384/io.wled.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11604      385/avahi-daemon: r
          udp        0      0 0.0.0.0:40278           0.0.0.0:*                           108        11606      385/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        11605      385/avahi-daemon: r
          udp6       0      0 :::45956                :::*                                108        11607      385/avahi-daemon: r
          udp6       0      0 fe80::6c8f:244d:28b:546 :::*                                0          15375      438/NetworkManager
          udp6       0      0 fe80::c41e:2eb1:39a:546 :::*                                0          990        438/NetworkManager
          2024-10-01 21:02:33.508  - info: mqtt.0 (985) Disconnected from 127.0.0.1
          2024-10-01 21:02:43.512  - info: mqtt.0 (985) Reconnected to 127.0.0.1
          2024-10-01 21:02:43.519  - error: mqtt.0 (985) Client error: Error: connect ECONNREFUSED 127.0.0.1:1883
          2024-10-01 21:02:43.520  - info: mqtt.0 (985) Disconnected from 127.0.0.1
          2024-10-01 21:02:53.524  - info: mqtt.0 (985) Reconnected to 127.0.0.1
          2024-10-01 21:02:53.529  - error: mqtt.0 (985) Client error: Error: connect ECONNREFUSED 127.0.0.1:1883
          2024-10-01 21:02:53.530  - info: mqtt.0 (985) Disconnected from 127.0.0.1
          2024-10-01 21:03:03.534  - info: mqtt.0 (985) Reconnected to 127.0.0.1
          2024-10-01 21:03:03.538  - error: mqtt.0 (985) Client error: Error: connect ECONNREFUSED 127.0.0.1:1883
          2024-10-01 21:03:03.539  - info: mqtt.0 (985) Disconnected from 127.0.0.1
          2024-10-01 21:03:13.541  - info: mqtt.0 (985) Reconnected to 127.0.0.1
          2024-10-01 21:03:13.546  - error: mqtt.0 (985) Client error: Error: connect ECONNREFUSED 127.0.0.1:1883
          2024-10-01 21:03:13.547  - info: mqtt.0 (985) Disconnected from 127.0.0.1
          2024-10-01 21:03:23.551  - info: mqtt.0 (985) Reconnected to 127.0.0.1
          2024-10-01 21:03:23.554  - error: mqtt.0 (985) Client error: Error: connect ECONNREFUSED 127.0.0.1:1883
          2024-10-01 21:03:23.555  - info: mqtt.0 (985) Disconnected from 127.0.0.1
          2024-10-01 21:03:33.557  - info: mqtt.0 (985) Reconnected to 127.0.0.1
          2024-10-01 21:03:33.562  - error: mqtt.0 (985) Client error: Error: connect ECONNREFUSED 127.0.0.1:1883
          2024-10-01 21:03:33.563  - info: mqtt.0 (985) Disconnected from 127.0.0.1
          2024-10-01 21:03:43.568  - info: mqtt.0 (985) Reconnected to 127.0.0.1
          2024-10-01 21:03:43.578  - error: mqtt.0 (985) Client error: Error: connect ECONNREFUSED 127.0.0.1:1883
          2024-10-01 21:03:43.579  - info: mqtt.0 (985) Disconnected from 127.0.0.1
          2024-10-01 21:03:53.582  - info: mqtt.0 (985) Reconnected to 127.0.0.1
          2024-10-01 21:03:53.585  - error: mqtt.0 (985) Client error: Error: connect ECONNREFUSED 127.0.0.1:1883
          2024-10-01 21:03:53.586  - info: mqtt.0 (985) Disconnected from 127.0.0.1
            Thomas Braun Most Active @Don_Kanaille last edited by Thomas Braun
            @don_kanaille sagte in Fehler bei Installation javascript:
            Installier da mal ein 64Bit-System drauf. Besser aber gleich auf besserer Hardware, mit 1GB RAM kommst du nicht mehr allzuweit.
            Was stellst du mit dem Dateisystem an? Die Kiste IMMER sauber herunterfahren.
            iob fix so oft durchführen, bis da Null steht.
            Ist also nicht installiert.
            Pending Updates: 2
            Updates einspielen.
            Mit dem mqtt stimmt was nicht. Läuft der Server?
              Don_Kanaille @Thomas Braun last edited by Don_Kanaille
              @thomas-braun said in Fehler bei Installation javascript:
              meinst das spezielle Problem liegt am RAM? Bisher hat das für die paar Shellys immer locker gereicht - aber du hast sicher recht, wenn ich da jetzt insgesamt etwas mehr einsteigen möchte, wäre das wohl nicht verkehrt.
              Diese fürchtlichen hardresets, sprich stecker ziehen, sind zu 98% beim versuch javascript zu installieren entstanden... die Kiste hat auf gar nichts mehr gehört - blieb mir nichts anderes übrig... zumindest nichts, was ich kenne...
              erledigt
              habe den Ordener aus dem Verzeichnis via rm -r gelöscht - frag bitte nicht wieso... unwissende Verzweiflung? Versuche ich den Adapter neu zu installieren wird das doch sicher wieder erstellt werden..?
              Updates einspielen.
              vom iobroker? dachte ich hätte über
              iob stop
              iob update
              iob upgrade self
              iob upgrade
              iob start
              alles erwischt, was es zu updaten gibt..
              Die Meldungen kommen seit dem ich das ganze System geupdatet hatte.... gesehen hatte ich es, mich aber näher damit beschäftigt nicht. Hatte auch noch Probleme mit der localen Zeit - da haben die Shellys gemotzt, habe ich über
              iob diag
              aber gelöst bekommen.
                Ja, und damit zersemmelst du dir die npm-Datenbank. Warum macht man so einen Unfug?
                Dann lerne REISUB kennen.
                Nein, vom Betriebssystem.
                iob add javascript
                sagt?
                  das ist eine hervorragende Frage... hättest du gesagt, dreh den PI um 180° hätte ich das wahrscheinlich auch für nen guten Tipp gehalten.... 🙂
                  hab ich gerade gemacht - vielen Dank! (auf für die Zeit der letzten Posts!!)
                  steht da jauch... "OS-Updates"... sorry.
                  iob add javascript
                  lässt den PI leider noch immer einfrieren..
                    Was heißt 'einfrieren'? Eine Installation (insbesonderen auf einer so durch die Mangel gedrehten Kiste) kann schon mal etwas länger dauern. Mit 1GB RAM ist sowieso Geduld angesagt.
                      ich kann über die IP Adresse nicht mehr auf iobroker zugreifen - "die Seite kann nicht geladen werden" und all meine Shellys werden im Homekit als "nicht erreichbar" abgezeigt...
                      meinst du ich sollte ihn einfach mal eine Zeit lang machen lassen? Bisher habe ich ihm max. ca. 5 Minuten gegeben... danach ging ich davon aus dass sich nichts mehr tut.
                      Meinst du das Ding ist noch zu retten? Oder sollte ich einfach neu aufsetzen... das wäre ärgerlich aber nicht hochdramatisch... ich würde dann nur gerne verstehen was passiert ist. javascript hat es nämlich auch schon vor meinr rm -r aktion nicht installiert... möchte ja lernen und nicht nur ausführen 🙂
                        Das kann deutlich länger dauern.
                          also das Ergebnis, wenn ich dem pi mehr zeit lasse ist, dass er mir diese Meldung mitgibt:
                          pi@iobroker:~ $ iob add javascript
                          NPM version: 10.8.2
                          Installing iobroker.javascript@8.7.6... (System call)
                          Try to solve ENOTEMPTY error automatically
                          Could not handle ENOTEMPTY, because no deletable files were found
                          npm error code ENOTEMPTY
                          npm error syscall rename
                          npm error path /opt/iobroker/node_modules/iobroker.javascript
                          npm error dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                          npm error errno -39
                          npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
                          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-02T05_28_10_771Z-debug-0.log
                          host.iobroker Cannot install iobroker.javascript@8.7.6: 217
                          dann habe ich iob fix drüber laufen lassen, Ergebnis:
                          NPM version: 10.8.2
                          host.iobroker Cannot install iobroker.javascript@8.7.6: undefined
                          javascript adapter
                          1190
