    4. Fehler bei Installation javascript
      Thomas Braun Most Active @Don_Kanaille last edited by
      @don_kanaille
      Die Langfassung bitte.
      Und kopier die Kopiermarken mit.
        Don_Kanaille @Thomas Braun last edited by
        @thomas-braun du merkst: "Profi" am Werk 😉
        ```bash
        Skript v.2024-08-12
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v7+
              Architecture: arm
        OS is similar to: debian
        Model           : Raspberry Pi 3 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : 32 bit
        Systemuptime and Load:
         21:02:19 up 11 min,  1 user,  load average: 0.44, 0.75, 0.65
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Tue 2024-10-01 21:02:19 CEST
                   Universal time: Tue 2024-10-01 19:02:19 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            921M        519M        120M        0.0K        282M        347M
        Swap:            99M         67M         32M
        Total:          1.0G        586M        153M
        Active iob-Instances:   14
                  921 M total memory
                  519 M used memory
                  260 M active memory
                  470 M inactive memory
                  120 M free memory
                   36 M buffer memory
                  245 M swap cache
                   99 M total swap
                   67 M used swap
                   32 M free swap
        top - 21:02:20 up 11 min,  1 user,  load average: 0.44, 0.75, 0.65
        Tasks: 147 total,   1 running, 146 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  4.4 us,  1.5 sy,  0.0 ni, 94.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :    922.0 total,    119.8 free,    519.5 used,    282.7 buff/cache
        MiB Swap:    100.0 total,     33.0 free,     67.0 used.    347.4 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       29G  6.0G   22G  22% /
        devtmpfs       devtmpfs  333M     0  333M   0% /dev
        tmpfs          tmpfs     461M     0  461M   0% /dev/shm
        tmpfs          tmpfs     185M  976K  184M   1% /run
        /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
        tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
        [Tue Oct  1 20:50:57 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=5bd61bcd-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Tue Oct  1 20:51:00 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
        [Tue Oct  1 20:51:00 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
        [Tue Oct  1 20:51:00 2024] EXT4-fs (mmcblk0p2): recovery complete
        [Tue Oct  1 20:51:00 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Tue Oct  1 20:51:00 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Tue Oct  1 20:51:03 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        2.6G    /var/
        2.1G    /var/log/journal/d635fc1f496c4c02ae7bd23ec48bcbd2
        2.1G    /var/log
        273M    /var/cache
        Archived and active journals take up 2.0G in the file system.
        /opt/iobroker/backups:
        103M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        415M    /opt/iobroker/iobroker-data/
        291M    /opt/iobroker/iobroker-data/files
        142M    /opt/iobroker/iobroker-data/files/vis-2
        81M     /opt/iobroker/iobroker-data/files/vis-2/static
        80M     /opt/iobroker/iobroker-data/files/vis-2/static/js
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
        19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
        19M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
        15M     /opt/iobroker/iobroker-data/files/vis-2/static/js/376.1862d3de.chunk.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.17.0
        /usr/bin/node           v20.17.0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.3
        nodejs:
          Installed: 20.17.0-1nodesource1
          Candidate: 20.17.0-1nodesource1
          Version table:
         *** 20.17.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u5 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        Temp directories causing npm8 problem: 11
        Some problems detected, please run iob fix
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  6.0.11
        admin:          7.1.5
        javascript:     "javascript" not found
        nodejs modules from github:     1
        `-- wake_on_lan@1.0.0 (git+ssh://git@github.com/agnat/node_wake_on_lan.git#dd6404623ccf4bc55b0ba8788ba38312b55435a1)
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
        + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.roomba.0                 : roomba                : iobroker                                 - disabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
        + system.adapter.systeminfo.0             : systeminfo            : iobroker                                 -  enabled
        + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
          system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
          system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
        + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.5    , installed 7.1.5
        Adapter    "backitup"     : 3.0.22   , installed 3.0.22
        Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
        Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
        Adapter    "hue"          : 3.12.0   , installed 3.12.0
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Controller "js-controller": 6.0.11   , installed 6.0.11
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "roomba"       : 1.3.0    , installed 1.3.0
        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
        Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
        Adapter    "wled"         : 0.7.2    , installed 0.7.2
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Objects and States
        Objects:        1768
        States:         1393
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:2 https://deb.nodesource.com/node_20.x nodistro InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Reading package lists...
        Pending Updates: 2
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       12047      943/io.shelly.0
        tcp        0      0 127.0.0.1:37387         0.0.0.0:*               LISTEN      1001       17765      1097/io.yahka.0
        tcp        0      0 0.0.0.0:45877           0.0.0.0:*               LISTEN      1001       14853      1097/io.yahka.0
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14394      482/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14399      482/iobroker.js-con
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11647      494/sshd: /usr/sbin
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18458      1275/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12051      906/io.admin.0
        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       16850      1403/io.terminal.0
        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       12049      962/io.sonos.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          11649      494/sshd: /usr/sbin
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       14864      1384/io.wled.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11604      385/avahi-daemon: r
        udp        0      0 0.0.0.0:40278           0.0.0.0:*                           108        11606      385/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        11605      385/avahi-daemon: r
        udp6       0      0 :::45956                :::*                                108        11607      385/avahi-daemon: r
        udp6       0      0 fe80::6c8f:244d:28b:546 :::*                                0          15375      438/NetworkManager
        udp6       0      0 fe80::c41e:2eb1:39a:546 :::*                                0          990        438/NetworkManager
        2024-10-01 21:02:33.508  - info: mqtt.0 (985) Disconnected from 127.0.0.1
        2024-10-01 21:02:43.512  - info: mqtt.0 (985) Reconnected to 127.0.0.1
        2024-10-01 21:02:43.519  - error: mqtt.0 (985) Client error: Error: connect ECONNREFUSED 127.0.0.1:1883
        2024-10-01 21:02:43.520  - info: mqtt.0 (985) Disconnected from 127.0.0.1
        2024-10-01 21:02:53.524  - info: mqtt.0 (985) Reconnected to 127.0.0.1
        2024-10-01 21:02:53.529  - error: mqtt.0 (985) Client error: Error: connect ECONNREFUSED 127.0.0.1:1883
        2024-10-01 21:02:53.530  - info: mqtt.0 (985) Disconnected from 127.0.0.1
        2024-10-01 21:03:03.534  - info: mqtt.0 (985) Reconnected to 127.0.0.1
        2024-10-01 21:03:03.538  - error: mqtt.0 (985) Client error: Error: connect ECONNREFUSED 127.0.0.1:1883
        2024-10-01 21:03:03.539  - info: mqtt.0 (985) Disconnected from 127.0.0.1
        2024-10-01 21:03:13.541  - info: mqtt.0 (985) Reconnected to 127.0.0.1
        2024-10-01 21:03:13.546  - error: mqtt.0 (985) Client error: Error: connect ECONNREFUSED 127.0.0.1:1883
        2024-10-01 21:03:13.547  - info: mqtt.0 (985) Disconnected from 127.0.0.1
        2024-10-01 21:03:23.551  - info: mqtt.0 (985) Reconnected to 127.0.0.1
        2024-10-01 21:03:23.554  - error: mqtt.0 (985) Client error: Error: connect ECONNREFUSED 127.0.0.1:1883
        2024-10-01 21:03:23.555  - info: mqtt.0 (985) Disconnected from 127.0.0.1
        2024-10-01 21:03:33.557  - info: mqtt.0 (985) Reconnected to 127.0.0.1
        2024-10-01 21:03:33.562  - error: mqtt.0 (985) Client error: Error: connect ECONNREFUSED 127.0.0.1:1883
        2024-10-01 21:03:33.563  - info: mqtt.0 (985) Disconnected from 127.0.0.1
        2024-10-01 21:03:43.568  - info: mqtt.0 (985) Reconnected to 127.0.0.1
        2024-10-01 21:03:43.578  - error: mqtt.0 (985) Client error: Error: connect ECONNREFUSED 127.0.0.1:1883
        2024-10-01 21:03:43.579  - info: mqtt.0 (985) Disconnected from 127.0.0.1
        2024-10-01 21:03:53.582  - info: mqtt.0 (985) Reconnected to 127.0.0.1
        2024-10-01 21:03:53.585  - error: mqtt.0 (985) Client error: Error: connect ECONNREFUSED 127.0.0.1:1883
        2024-10-01 21:03:53.586  - info: mqtt.0 (985) Disconnected from 127.0.0.1
          Thomas Braun Most Active @Don_Kanaille last edited by Thomas Braun
          @don_kanaille sagte in Fehler bei Installation javascript:
          Installier da mal ein 64Bit-System drauf. Besser aber gleich auf besserer Hardware, mit 1GB RAM kommst du nicht mehr allzuweit.
          Was stellst du mit dem Dateisystem an? Die Kiste IMMER sauber herunterfahren.
          iob fix so oft durchführen, bis da Null steht.
          Ist also nicht installiert.
          Pending Updates: 2
          Updates einspielen.
          Mit dem mqtt stimmt was nicht. Läuft der Server?
            Don_Kanaille @Thomas Braun last edited by Don_Kanaille
            @thomas-braun said in Fehler bei Installation javascript:
            meinst das spezielle Problem liegt am RAM? Bisher hat das für die paar Shellys immer locker gereicht - aber du hast sicher recht, wenn ich da jetzt insgesamt etwas mehr einsteigen möchte, wäre das wohl nicht verkehrt.
            Diese fürchtlichen hardresets, sprich stecker ziehen, sind zu 98% beim versuch javascript zu installieren entstanden... die Kiste hat auf gar nichts mehr gehört - blieb mir nichts anderes übrig... zumindest nichts, was ich kenne...
            erledigt
            habe den Ordener aus dem Verzeichnis via rm -r gelöscht - frag bitte nicht wieso... unwissende Verzweiflung? Versuche ich den Adapter neu zu installieren wird das doch sicher wieder erstellt werden..?
            Updates einspielen.
            vom iobroker? dachte ich hätte über
            iob stop
            iob update
            iob upgrade self
            iob upgrade
            iob start
            alles erwischt, was es zu updaten gibt..
            Die Meldungen kommen seit dem ich das ganze System geupdatet hatte.... gesehen hatte ich es, mich aber näher damit beschäftigt nicht. Hatte auch noch Probleme mit der localen Zeit - da haben die Shellys gemotzt, habe ich über
            iob diag
            aber gelöst bekommen.
              Ja, und damit zersemmelst du dir die npm-Datenbank. Warum macht man so einen Unfug?
              Dann lerne REISUB kennen.
              Nein, vom Betriebssystem.
              iob add javascript
              sagt?
                das ist eine hervorragende Frage... hättest du gesagt, dreh den PI um 180° hätte ich das wahrscheinlich auch für nen guten Tipp gehalten.... 🙂
                hab ich gerade gemacht - vielen Dank! (auf für die Zeit der letzten Posts!!)
                steht da jauch... "OS-Updates"... sorry.
                iob add javascript
                lässt den PI leider noch immer einfrieren..
                  Was heißt 'einfrieren'? Eine Installation (insbesonderen auf einer so durch die Mangel gedrehten Kiste) kann schon mal etwas länger dauern. Mit 1GB RAM ist sowieso Geduld angesagt.
                    ich kann über die IP Adresse nicht mehr auf iobroker zugreifen - "die Seite kann nicht geladen werden" und all meine Shellys werden im Homekit als "nicht erreichbar" abgezeigt...
                    meinst du ich sollte ihn einfach mal eine Zeit lang machen lassen? Bisher habe ich ihm max. ca. 5 Minuten gegeben... danach ging ich davon aus dass sich nichts mehr tut.
                    Meinst du das Ding ist noch zu retten? Oder sollte ich einfach neu aufsetzen... das wäre ärgerlich aber nicht hochdramatisch... ich würde dann nur gerne verstehen was passiert ist. javascript hat es nämlich auch schon vor meinr rm -r aktion nicht installiert... möchte ja lernen und nicht nur ausführen 🙂
                      Das kann deutlich länger dauern.
                        also das Ergebnis, wenn ich dem pi mehr zeit lasse ist, dass er mir diese Meldung mitgibt:
                        pi@iobroker:~ $ iob add javascript
                        NPM version: 10.8.2
                        Installing iobroker.javascript@8.7.6... (System call)
                        Try to solve ENOTEMPTY error automatically
                        Could not handle ENOTEMPTY, because no deletable files were found
                        npm error code ENOTEMPTY
                        npm error syscall rename
                        npm error path /opt/iobroker/node_modules/iobroker.javascript
                        npm error dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                        npm error errno -39
                        npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
                        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-02T05_28_10_771Z-debug-0.log
                        host.iobroker Cannot install iobroker.javascript@8.7.6: 217
                        dann habe ich iob fix drüber laufen lassen, Ergebnis:
                        NPM version: 10.8.2
                        host.iobroker Cannot install iobroker.javascript@8.7.6: undefined
                        javascript adapter
                        1190
