    4. BackItUp macht keine Backups mehr.
    • simatec
      simatec Developer Most Active @JB72 last edited by simatec
      @jb72 Was ist mit SSL? Hast du das überprüft? Laut deinem Log versucht Backitup per https zuzugreifen. Irgendwas ist da bei dir nicht korrekt. In der geposteten Config ist ssl aktiv. Ist das auch in deiner CCU aktiv? Wie erreichst du die ccu per http oder https?
      Bitte poste die vollständige Debug Ausgabe vom CCU Backup.
        JB72 @simatec last edited by
        @simatec
        backitup.0
        	2024-09-30 19:54:47.846	info	[ccu] backup will be activated at 01:30 every 1 day(s)
        backitup.0
        	2024-09-30 19:54:47.795	info	[iobroker] backup will be activated at 02:00 every 1 day(s)
        backitup.0
        	2024-09-30 19:54:47.742	debug	BackItUp has recognized a linux system
        backitup.0
        	2024-09-30 19:54:47.723	info	starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
        host.iobroker
        	2024-09-30 19:54:47.719	info	instance system.adapter.weatherunderground.0 having pid 13546 terminated with code 0 (NO_ERROR)
        backitup.0
        	2024-09-30 19:54:47.370	debug	Plugin sentry Initialize Plugin (enabled=true)
        backitup.0
        	2024-09-30 19:54:47.324	debug	States connected to redis: 127.0.0.1:9000
        backitup.0
        	2024-09-30 19:54:47.245	debug	States create User PubSub Client
        backitup.0
        	2024-09-30 19:54:47.244	debug	States create System PubSub Client
        backitup.0
        	2024-09-30 19:54:47.224	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        backitup.0
        	2024-09-30 19:54:47.189	debug	Objects connected to redis: 127.0.0.1:9001
        backitup.0
        	2024-09-30 19:54:47.184	debug	Objects client initialize lua scripts
        	2024-09-30 19:54:47.181	info	Terminated (NO_ERROR): Without reason
        backitup.0
        	2024-09-30 19:54:47.126	debug	Objects create User PubSub Client
        backitup.0
        	2024-09-30 19:54:47.125	debug	Objects create System PubSub Client
        backitup.0
        	2024-09-30 19:54:47.124	debug	Objects client ready ... initialize now
        backitup.0
        	2024-09-30 19:54:47.091	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        simatec 2 Replies Last reply Reply Quote 0
        • simatec
          @jb72 das ist aber nicht der Log vom Backup. Stelle die Instanz auf debug und führe ein Backup durch. Anschließend poste bitte den Log
          • simatec
            @jb72 Auf deine Einstellungen zu SSL in der CCU habe ich auch noch keine Antwort. Wie soll man dir so helfen, wenn du keine Fragen beantwortest?
              JB72 @simatec last edited by JB72
              @simatec
              Entschuldige, ich hatte gestern Geburtstag, war etwas schwierig in dem Trubel zu antworten. Hatte dir das eigentlich auch per PN geschrieben.
              SSL ist aus. Die IP ist korrekt wie sie nun drinnen steht. Ich habe die IP Adressen fest vergeben, also der Lease ist auf Maximum im Router eingestellt.
              backitup.0
              	2024-10-01 06:23:38.960	debug	[ccu/googledrive] Google Drive: Copy homematic_2024_10_01-06_23_33_3.73.9.20240130_backupiobroker.tar.sbk...
              backitup.0
              	2024-10-01 06:23:37.452	debug	[ccu/ccu] done
              backitup.0
              	2024-10-01 06:23:37.451	debug	[ccu/ccu] CCU-Backup is finish
              backitup.0
              	2024-10-01 06:23:37.450	debug	[ccu/ccu] CCU Session logout successful
              admin.0
              	2024-10-01 06:23:34.071	info	<== Disconnect system.user.admin from ::ffff:192.168.100.137 backitup
              admin.0
              backitup.0
              	2024-10-01 06:23:33.270	debug	[ccu/ccu] Requesting backup from CCU
              backitup.0
              	2024-10-01 06:23:33.269	debug	[ccu/ccu] CCU Version: 3.73.9.20240130
              backitup.0
              	2024-10-01 06:23:32.999	debug	[ccu/ccu] CCU-Backup started ...
              backitup.0
              	2024-10-01 06:23:31.191	debug	Backup has started ...
              Mehr passiert danach nicht mehr. Der Balken Homematic Backup starten bleibt "ausgegraut". Ich muss den Adapter schon neu starten, wenn ich erneut eine Aktion ausführen will.
              Googledrive ist weder zu voll, ich habe das Ganze auch einmal erneuert. Leider wird nicht mehr hochgeladen. Sorry noch mal für die lange Antwortzeit, aber Gestern war echt viel los.
              • simatec
                @jb72 ohhh alles Gute nachträglich...
                Funktioniert denn das iob Backup oder wird dies auch nicht auf GDrive gespeichert?
                  @simatec
                  Danke.
                  Ja ioBroker Backup wird auch auf Googledrive gespeichert. Das Log sieht dann gleich aus:
                  Log-Größe: 1.6 KB
                  Zeit
                  backitup.0
                  	2024-10-01 16:54:05.801	debug	[iobroker/googledrive] Google Drive: Copy iobroker_2024_10_01-16_53_54_VMBroker_backupiobroker.tar.gz...
                  backitup.0
                  	2024-10-01 16:54:02.635	debug	[iobroker/iobroker] done
                  backitup.0
                  	2024-10-01 16:54:01.602	debug	[iobroker/iobroker] This backup can only be restored with js-controller version up from 4.1
                  backitup.0
                  	2024-10-01 16:54:01.600	debug	[iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2024_10_01-16_53_54_VMBroker_backupiobroker.tar.gz
                  backitup.0
                  	2024-10-01 16:53:58.726	debug	[iobroker/iobroker] host.iobroker 15600 objects saved
                  backitup.0
                  	2024-10-01 16:53:58.001	debug	[iobroker/iobroker] host.iobroker 14218 states saved
                  backitup.0
                  	2024-10-01 16:53:54.691	debug	Backup has started ...
                  • simatec
                    @jb72 dann überprüfe bitte deine Speicherpfade in den Einstellungen von Backitup und autorisiere die Google Drive App für Backitup erneut.
                    Welche Version von Backitup ist installiert?
                      JB72 last edited by JB72
                      @simatec
                      Die aktuellste Version v3.0.22.
                      Ich habe gerade folgendes getan: Debug wieder auf Info gestellt, erneut Googledrive autorisiert und nun geht es wieder! Mir ist schleierhaft wie sich das einschleichen konnte. Bis zum 14.09. lief das alles wie am Schnürchen. Mir ist das wirklich erst letztes Wochenende aufgefallen, da mich mein Gewissen dazu getrieben hat, mal die komplette ioBroker/Proxmox Umgebung zu aktualisieren. Auch wie aus der .30 die .130 werden konnte, was die Homematic betrifft. Denn die .130 am Ende ist der ioBroker und nicht die Homematic. So läuft das sicher schon 3-4 Jahre.
                      Nun habe ich frische Backups. Ein neuer Container mit ioBroker ist bereit, nun muss ich einfach umziehen.
                      Danke für die Hilfe.
                      [gelöst]
                      • simatec
                        @jb72 Kannst du bitte das Thema auf [gelöst] setzen?
                        • souly75
                          souly75 last edited by
                          Hallo in die Runde, bei mir läuft auch wieder alles. Ich musste bei GoogleDrive den token erneuern.Keine Ahnung, warum der still und leise ablief und keine Fehlermeldung kam. Aber es läuft wieder und auf onedrive gab's keine Probleme.
                          Vielen Dank für die Hilfe.
                            @simatec
                            	Error: Cannot find module '/opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core/build/cjs/index.js'
                            Das einzige was ich gestern im Vorbereitung eines Wechsles getan habe, das mittlerweile abgekündigte Systeminfo zu deinstallieren. Wer das Problem hat nach der Deinstallation von Systeminfo: BackItUp Adapter neustarten.
                            [gelöst]
                            • Meister Mopper
                              Meister Mopper @JB72 last edited by
                              @jb72 sagte in BackItUp macht keine Backups mehr.:
                              [gelöst]
                              Das sollte dem Thread-Titel voranstehen, damit man bereits "von außen" sieht, dass das Problem gelöst ist.
                              • MartinP
                                MartinP @Meister Mopper last edited by MartinP
                                bei mir lag wohl ein ähnliches Problem vor...
                                Auch seit 30.9 keine Backups mehr ...
                                Fehlermeldung heute beim manuellen Auslösen
                                2024-10-04 07:28:26.139  - error: backitup.0 (494) Error: Cannot find module '/opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core/build/cjs/index.js'
                                Danach habe ich dann diesen Thread gesehen, aber der Adapter hat sich da schon von selbst neu gestartet
                                2024-10-04 07:29:11.677  - error: backitup.0 (494) Error: Cannot find module '/opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core/build/cjs/index.js'
                                2024-10-04 07:29:11.684  - silly: backitup.0 (494) States system redis pmessage io.messagebox.system.adapter.backitup.0/io.messagebox.system.adapter.backitup.0:{"command":"getFileSystemInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":226,"ack":false,"time":1728019751645},"_id":83766946}
                                2024-10-04 07:29:11.739  - silly: backitup.0 (494) sendTo "getFileSystemInfo" to system.adapter.admin.0 from system.adapter.backitup.0
                                2024-10-04 07:29:14.464  - silly: backitup.0 (494) States user redis pmessage backitup.0.oneClick.*/backitup.0.oneClick.iobroker:{"val":true,"ack":false,"ts":1728019754460,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1727743210123}
                                2024-10-04 07:31:47.288  - info: host.iobroker-test-sicher stopInstance system.adapter.backitup.0 (force=false, process=true)
                                2024-10-04 07:31:47.301  - silly: backitup.0 (494) States system redis pmessage system.adapter.backitup.0.sigKill/system.adapter.backitup.0.sigKill:{"val":-1,"ack":false,"ts":1728019907296,"q":0,"from":"system.host.iobroker-test-sicher","lc":1728019907296}
                                2024-10-04 07:31:47.302  - info: backitup.0 (494) Got terminate signal TERMINATE_YOURSELF
                                2024-10-04 07:31:47.311  - info: backitup.0 (494) cleaned everything up...
                                2024-10-04 07:31:47.316  - info: backitup.0 (494) terminating
                                2024-10-04 07:31:47.320  - debug: backitup.0 (494) Plugin sentry destroyed
                                2024-10-04 07:31:47.323  - info: backitup.0 (494) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2024-10-04 07:31:47.339  - info: host.iobroker-test-sicher stopInstance system.adapter.backitup.0 send kill signal
                                2024-10-04 07:31:47.831  - info: backitup.0 (494) terminating
                                2024-10-04 07:31:48.159  - info: host.iobroker-test-sicher instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-10-04 07:31:52.477  - info: host.iobroker-test-sicher instance system.adapter.backitup.0 in version "3.0.22" started with pid 78801
                                2024-10-04 07:31:55.638  - debug: backitup.0 (78801) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                2024-10-04 07:31:55.697  - debug: backitup.0 (78801) Objects client ready ... initialize now
                                2024-10-04 07:31:55.702  - debug: backitup.0 (78801) Objects create System PubSub Client
                                2024-10-04 07:31:55.703  - debug: backitup.0 (78801) Objects create User PubSub Client
                                2024-10-04 07:31:55.762  - debug: backitup.0 (78801) Objects client initialize lua scripts
                                2024-10-04 07:31:55.775  - debug: backitup.0 (78801) Objects connected to redis: 127.0.0.1:9001
                                2024-10-04 07:31:55.779  - silly: backitup.0 (78801) redis psubscribe cfg.o.system.user.*
                                2024-10-04 07:31:55.806  - silly: backitup.0 (78801) redis psubscribe cfg.o.enum.*
                                2024-10-04 07:31:55.810  - silly: backitup.0 (78801) objectDB connected
                                2024-10-04 07:31:55.814  - debug: backitup.0 (78801) Redis States: Use Redis connection: 127.0.0.1:9000
                                2024-10-04 07:31:55.884  - debug: backitup.0 (78801) States create System PubSub Client
                                2024-10-04 07:31:55.887  - debug: backitup.0 (78801) States create User PubSub Client
                                2024-10-04 07:31:55.989  - debug: backitup.0 (78801) States connected to redis: 127.0.0.1:9000
                                2024-10-04 07:31:55.992  - silly: backitup.0 (78801) statesDB connected
                                2024-10-04 07:31:56.167  - debug: backitup.0 (78801) Plugin sentry Initialize Plugin (enabled=true)
                                2024-10-04 07:31:57.959  - info: backitup.0 (78801) starting. Version 3.0.22 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
                                2024-10-04 07:31:58.054  - debug: backitup.0 (78801) BackItUp has recognized a linux system
                                2024-10-04 07:31:58.121  - silly: backitup.0 (78801) States system redis pmessage system.adapter.backitup.0.logLevel/system.adapter.backitup.0.logLevel:{"val":"silly","ack":true,"ts":1728019918084,"q":0,"from":"system.adapter.backitup.0","lc":1692783464076}
                                2024-10-04 07:31:58.180  - info: backitup.0 (78801) [iobroker] backup will be activated at 02:40 every 1 day(s)
                                2024-10-04 07:31:58.496  - debug: backitup.0 (78801) [iobroker] 10 40 02 */1 * *
                                2024-10-04 07:31:58.515  - debug: backitup.0 (78801) No backup file was found
                                2024-10-04 07:31:58.737  - silly: backitup.0 (78801) States user redis pmessage backitup.0.oneClick.*/backitup.0.oneClick.iobroker:{"val":false,"ack":true,"ts":1728019918732,"q":0,"from":"system.adapter.backitup.0","user":"system.user.admin","lc":1728019918732}
                                Manuelles Backup ist gerade durchgelaufen
                                07:34:19.920
                                INFO
                                gui
                                Backup gestartet ...
                                [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"debian","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/mnt/backup/Martin/iobroker","dirMinimal":"/backupDir/iobroker","user":"martin","pass":"****","port":"22","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"local","mount":"debian","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=3.1.1","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"backup/Martin/iobroker","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"nameSuffix":"","slaveSuffix":"","hostType":"Single","deleteBackupAfter":5,"dbName":"iobroker","host":"localhost","port":8086,"dbversion":"2.x","token":"wpdQ8Ct4T6-v-XH5gUCJqDdZfYKxt3nJXYcj5zq-A--OnKQGDtuMXjsYDm4JC0CzscdCuv_ozjZWiVRwk5yEEA==","protocol":"http","exe":"","dbType":"local","influxDBEvents":[],"influxDBMulti":false,"ignoreErrors":false,"deleteDataBase":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"debian","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/mnt/backup/Martin/iobroker","dirMinimal":"/backupDir/iobroker","user":"martin","pass":"****","port":"22","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"local","mount":"debian","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=3.1.1","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"backup/Martin/iobroker","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1728020061436}
                                07:34:30.103
                                DEBUG
                                iobroker
                                host.iobroker-test-sicher 2362 states saved
                                07:34:34.382
                                DEBUG
                                iobroker
                                host.iobroker-test-sicher 2799 objects saved
                                07:34:41.270
                                DEBUG
                                iobroker
                                Backup created: /opt/iobroker/backups/iobroker_2024_10_04-07_34_21_backupiobroker.tar.gz
                                07:34:41.324
                                DEBUG
                                iobroker
                                07:34:42.321
                                DEBUG
                                iobroker
                                done
                                07:34:42.564
                                DEBUG
                                influxDB
                                InfluxDB-Backup started ...
                                07:34:42.655
                                DEBUG
                                influxDB
                                Start InfluxDB Backup ...
                                07:34:42.670
                                DEBUG
                                influxDB
                                InfluxDB Backup tmp directory created
                                07:48:15.785
                                DEBUG
                                influxDB
                                Packed 20MB so far...
                                07:48:25.815
                                DEBUG
                                influxDB
                                Packed 42MB so far...
                                07:48:35.637
                                DEBUG
                                influxDB
                                Packed 66MB so far...
                                07:48:45.605
                                DEBUG
                                influxDB
                                Packed 92MB so far...
                                07:48:55.639
                                DEBUG
                                influxDB
                                Packed 116MB so far...
                                07:49:05.715
                                DEBUG
                                influxDB
                                Packed 130MB so far...
                                07:49:15.611
                                DEBUG
                                influxDB
                                Packed 149MB so far...
                                07:49:25.794
                                DEBUG
                                influxDB
                                Packed 171MB so far...
                                07:49:35.621
                                DEBUG
                                influxDB
                                Packed 201MB so far...
                                07:49:45.597
                                DEBUG
                                influxDB
                                Packed 233MB so far...
                                07:49:55.626
                                DEBUG
                                influxDB
                                Packed 265MB so far...
                                07:50:05.654
                                DEBUG
                                influxDB
                                Packed 295MB so far...
                                07:50:15.698
                                DEBUG
                                influxDB
                                Packed 333MB so far...
                                07:50:25.616
                                DEBUG
                                influxDB
                                Packed 365MB so far...
                                07:50:35.678
                                DEBUG
                                influxDB
                                Packed 400MB so far...
                                07:50:45.629
                                DEBUG
                                influxDB
                                Packed 438MB so far...
                                07:50:55.628
                                DEBUG
                                influxDB
                                Packed 478MB so far...
                                07:51:05.630
                                DEBUG
                                influxDB
                                Packed 511MB so far...
                                07:51:15.644
                                DEBUG
                                influxDB
                                Packed 540MB so far...
                                07:51:25.775
                                DEBUG
                                influxDB
                                Packed 567MB so far...
                                07:51:35.645
                                DEBUG
                                influxDB
                                Packed 604MB so far...
                                07:51:45.726
                                DEBUG
                                influxDB
                                Packed 639MB so far...
                                07:51:55.636
                                DEBUG
                                influxDB
                                Packed 671MB so far...
                                07:52:05.651
                                DEBUG
                                influxDB
                                Packed 699MB so far...
                                07:52:15.793
                                DEBUG
                                influxDB
                                Packed 736MB so far...
                                07:52:25.627
                                DEBUG
                                influxDB
                                Packed 776MB so far...
                                07:52:35.636
                                DEBUG
                                influxDB
                                Packed 810MB so far...
                                07:52:45.732
                                DEBUG
                                influxDB
                                Packed 851MB so far...
                                07:52:55.743
                                DEBUG
                                influxDB
                                Packed 889MB so far...
                                07:53:05.680
                                DEBUG
                                influxDB
                                Packed 925MB so far...
                                07:53:15.628
                                DEBUG
                                influxDB
                                Packed 956MB so far...
                                07:53:25.627
                                DEBUG
                                influxDB
                                Packed 991MB so far...
                                07:53:26.577
                                DEBUG
                                influxDB
                                Backup created: /opt/iobroker/backups/influxDB_2024_10_04-07_34_42_backupiobroker.tar.gz
                                07:53:26.615
                                DEBUG
                                influxDB
                                Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_10_04-07_34_42_backupiobroker"
                                07:53:27.545
                                DEBUG
                                influxDB
                                InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_10_04-07_34_42_backupiobroker" successfully deleted
                                07:53:27.618
                                DEBUG
                                influxDB
                                InfluxDB-Backup for is finish
                                07:53:27.631
                                DEBUG
                                influxDB
                                done
                                07:53:29.260
                                DEBUG
                                javascripts
                                Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                                07:53:29.353
                                DEBUG
                                javascripts
                                found Script: Solltemperatur_Arbeitszimmer
                                07:53:29.461
                                DEBUG
                                javascripts
                                found Script: ESP_RELAIS
                                07:53:29.618
                                DEBUG
                                javascripts
                                found Script: Sende_
                                07:53:29.765
                                DEBUG
                                javascripts
                                found Script: TEST_ESP_1
                                07:53:29.919
                                DEBUG
                                javascripts
                                found Script: Bewaesserung
                                07:53:30.080
                                DEBUG
                                javascripts
                                found Script: Test
                                07:53:30.236
                                DEBUG
                                javascripts
                                found Script: TestDECT
                                07:53:30.377
                                DEBUG
                                javascripts
                                found Script: Ressourcentest
                                07:53:30.533
                                DEBUG
                                javascripts
                                found Script: Weihnachten
                                07:53:30.681
                                DEBUG
                                javascripts
                                found Script: Gaszaehler
                                07:53:30.844
                                DEBUG
                                javascripts
                                found Script: Kuehlung
                                07:53:30.988
                                DEBUG
                                javascripts
                                found Script: Kalender
                                07:53:31.153
                                DEBUG
                                javascripts
                                found Script: Geräteüberwachung
                                07:53:31.294
                                DEBUG
                                javascripts
                                found Script: DOCSISV01
                                07:53:31.440
                                DEBUG
                                javascripts
                                found Script: Tester
                                07:53:31.593
                                DEBUG
                                javascripts
                                found Script: Kameras
                                07:53:31.745
                                DEBUG
                                javascripts
                                found Script: TestJs
                                07:53:31.977
                                DEBUG
                                javascripts
                                Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                                07:53:31.983
                                DEBUG
                                javascripts
                                Backup created: /opt/iobroker/backups/javascripts_2024_10_04-07_53_29_backupiobroker.tar.gz
                                07:53:32.011
                                DEBUG
                                javascripts
                                done
                                07:53:33.529
                                DEBUG
                                clean
                                done
                                07:53:33.712
                                DEBUG
                                historyHTML
                                new history html values created
                                07:53:33.866
                                DEBUG
                                historyHTML
                                done
                                [DEBUG] [historyHTML] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"debian","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/mnt/backup/Martin/iobroker","dirMinimal":"/backupDir/iobroker","user":"martin","pass":"****","port":"22","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"local","mount":"debian","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=3.1.1","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"backup/Martin/iobroker","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"nameSuffix":"","slaveSuffix":"","hostType":"Single","deleteBackupAfter":5,"dbName":"iobroker","host":"localhost","port":8086,"dbversion":"2.x","token":"wpdQ8Ct4T6-v-XH5gUCJqDdZfYKxt3nJXYcj5zq-A--OnKQGDtuMXjsYDm4JC0CzscdCuv_ozjZWiVRwk5yEEA==","protocol":"http","exe":"","dbType":"local","influxDBEvents":[],"influxDBMulti":false,"ignoreErrors":false,"deleteDataBase":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"debian","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/mnt/backup/Martin/iobroker","dirMinimal":"/backupDir/iobroker","user":"martin","pass":"****","port":"22","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"local","mount":"debian","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=3.1.1","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"backup/Martin/iobroker","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"04. Oktober 2024 um 07:53 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1728020061436,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                                07:53:33.994
                                DEBUG
                                historyJSON
                                new history json values created
                                07:53:34.033
                                DEBUG
                                historyJSON
                                done
                                [DEBUG] [historyJSON] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"debian","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/mnt/backup/Martin/iobroker","dirMinimal":"/backupDir/iobroker","user":"martin","pass":"****","port":"22","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"local","mount":"debian","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=3.1.1","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"backup/Martin/iobroker","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"nameSuffix":"","slaveSuffix":"","hostType":"Single","deleteBackupAfter":5,"dbName":"iobroker","host":"localhost","port":8086,"dbversion":"2.x","token":"wpdQ8Ct4T6-v-XH5gUCJqDdZfYKxt3nJXYcj5zq-A--OnKQGDtuMXjsYDm4JC0CzscdCuv_ozjZWiVRwk5yEEA==","protocol":"http","exe":"","dbType":"local","influxDBEvents":[],"influxDBMulti":false,"ignoreErrors":false,"deleteDataBase":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"debian","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/mnt/backup/Martin/iobroker","dirMinimal":"/backupDir/iobroker","user":"martin","pass":"****","port":"22","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"local","mount":"debian","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=3.1.1","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"backup/Martin/iobroker","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"04. Oktober 2024 um 07:53 Uhr"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1728020061436,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                                [DEBUG] [notification] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"debian","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/mnt/backup/Martin/iobroker","dirMinimal":"/backupDir/iobroker","user":"martin","pass":"****","port":"22","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"local","mount":"debian","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=3.1.1","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"backup/Martin/iobroker","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"nameSuffix":"","slaveSuffix":"","hostType":"Single","deleteBackupAfter":5,"dbName":"iobroker","host":"localhost","port":8086,"dbversion":"2.x","token":"wpdQ8Ct4T6-v-XH5gUCJqDdZfYKxt3nJXYcj5zq-A--OnKQGDtuMXjsYDm4JC0CzscdCuv_ozjZWiVRwk5yEEA==","protocol":"http","exe":"","dbType":"local","influxDBEvents":[],"influxDBMulti":false,"ignoreErrors":false,"deleteDataBase":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"debian","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/mnt/backup/Martin/iobroker","dirMinimal":"/backupDir/iobroker","user":"martin","pass":"****","port":"22","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"local","mount":"debian","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=3.1.1","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"backup/Martin/iobroker","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de","time":"04. Oktober 2024 um 07:53 Uhr"},"backupDir":"/opt/iobroker/backups","timestamp":1728020061436,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                                07:53:36.515
                                DEBUG
                                notification
                                done
                                07:53:36.818
                                INFO
                                gui
                                Das Backup wurde erfolgreich erstellt!
                                martin@iobroker-test-sicher:/opt/iobroker/backups$ ls -lt
                                total 10985840
                                -rw-rw-r--+ 1 iobroker iobroker      66514 Oct  4 07:53 javascripts_2024_10_04-07_53_29_backupiobroker.tar.gz
                                -rw-rw-r--+ 1 iobroker iobroker 1041943654 Oct  4 07:53 influxDB_2024_10_04-07_34_42_backupiobroker.tar.gz
                                -rw-rw-r--+ 1 iobroker iobroker    7262688 Oct  4 07:34 iobroker_2024_10_04-07_34_21_backupiobroker.tar.gz
                                -rw-rw-r--+ 1 iobroker iobroker      66513 Sep 30 02:50 javascripts_2024_09_30-02_50_27_backupiobroker.tar.gz
                                -rw-rw-r--+ 1 iobroker iobroker 1028603217 Sep 30 02:50 influxDB_2024_09_30-02_40_24_backupiobroker.tar.gz
                                -rw-rw-r--+ 1 iobroker iobroker    6353980 Sep 30 02:40 iobroker_2024_09_30-02_40_10_backupiobroker.tar.gz
                                Systeminfo hatte ich nicht installiert
                                Zur üblichen timergesteuerten Ausführungszeit 02:40 keine Auffälligkeiten
                                2024-10-04 02:40:10.071  - silly: backitup.0 (494) States user redis pmessage backitup.0.oneClick.*/backitup.0.oneClick.iobroker:{"val":true,"ack":true,"ts":1728002410066,"q":0,"from":"system.adapter.backitup.0","user":"system.user.admin","lc":1727743210123}
                                Ich würde raten, mal zu schauen, ob die letzten Tage die Backups sauber erstellt wurden, und ggfs. den Backitup Adapter neu zu starten, auch wenn man den Systeminfo Adapter nicht installiert hatte!
                                3438
