    4. Test Adapter PSA v0.0.x Peugeot Opel Citroen
    • RaspiUser
      RaspiUser @mcm1957 last edited by
      @mcm1957 sagte in Test Adapter PSA v0.0.x Peugeot Opel Citroen:
      WIE hast du den Adapter gelöscht? Hoffe ntlich nicht mir 'sudo rm ...'
      Nö ... im ioBroker mit der Mülltonne ...
      ```bash
      Skript v.2024-08-12
      *** BASE SYSTEM ***
       Static hostname: VM-ioBroker
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-25-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: e0d6339-dirty-20220919_024111-d528eb931742
      OS is similar to:
      model name      : Westmere E56xx/L56xx/X56xx (Nehalem-C)
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       12:01:59 up 11 days, 23:55,  2 users,  load average: 0.25, 0.35, 0.20
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Thu 2024-10-03 12:01:59 CEST
                 Universal time: Thu 2024-10-03 10:01:59 UTC
                       RTC time: Thu 2024-10-03 10:01:59
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout cdrom floppy sudo audio dip video plugdev users netdev
      iobroker
      HOME=/home/iobroker
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            8.3G        3.0G        4.3G        602K        1.3G        5.3G
      Swap:           1.0G          0B        1.0G
      Total:          9.3G        3.0G        5.3G
      Active iob-Instances:   26
               7940 M total memory
               2873 M used memory
                668 M active memory
               2951 M inactive memory
               4060 M free memory
                312 M buffer memory
                955 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      top - 12:01:59 up 11 days, 23:55,  2 users,  load average: 0.25, 0.35, 0.20
      Tasks: 139 total,   1 running, 138 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 20.0 us, 20.0 sy,  0.0 ni, 60.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7940.7 total,   4059.8 free,   2874.4 used,   1267.9 buff/cache
      MiB Swap:    975.0 total,    975.0 free,      0.0 used.   5066.4 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     795M  588K  794M   1% /run
      /dev/sda1      ext4       48G  8.1G   38G  18% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     795M     0  795M   0% /run/user/1000
      [sudo] password for iobroker:
      [Sat Sep 21 12:06:36 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Sep 21 12:06:37 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      2.1G    /var/
      1.4G    /var/log/journal/27bb2095ba2b41ccb088ec3ad41fc1f5
      1.4G    /var/log
      514M    /var/cache
      Archived and active journals take up 214.8M in the file system.
      /opt/iobroker/backups:
      20M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      714M    /opt/iobroker/iobroker-data/
      589M    /opt/iobroker/iobroker-data/files
      441M    /opt/iobroker/iobroker-data/files/javascript.admin
      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      26M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
      8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
      8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c421aa81b69ded118718d3a5a7669f5d-if00-port0
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyUSB0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.4
      /usr/bin/node           v18.20.4
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      /usr/bin/corepack       0.28.0
      nodejs:
        Installed: 18.20.4-1nodesource1
        Candidate: 18.20.4-1nodesource1
        Version table:
       *** 18.20.4-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.20.3-1nodesource1 500
           18.20.2-1nodesource1 500
           18.20.1-1nodesource1 500
           18.20.0-1nodesource1 500
           18.19.1-1nodesource1 500
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
           18.19.0-1nodesource1 500
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.1.5
      javascript:     8.7.6
      nodejs modules from github:     1
      +-- iobroker.go-e@1.0.38 (git+ssh://git@github.com/MK-2001/ioBroker.go-e.git#68cec3c4c103f9fdcefd67295193823041c88a5c)
      Adapter State
      + system.adapter.admin.0                  : admin                 : VM-ioBroker                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : VM-ioBroker                              - disabled
      + system.adapter.alpha-ess.0              : alpha-ess             : VM-ioBroker                              -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : VM-ioBroker                              -  enabled
      + system.adapter.backitup.0               : backitup              : VM-ioBroker                              -  enabled
      + system.adapter.canbus.0                 : canbus                : VM-ioBroker                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : VM-ioBroker                              -  enabled
      + system.adapter.discovery.0              : discovery             : VM-ioBroker                              -  enabled
        system.adapter.esphome.0                : esphome               : VM-ioBroker                              - disabled
        system.adapter.feiertage.0              : feiertage             : VM-ioBroker                              -  enabled
      + system.adapter.frontier_silicon.0       : frontier_silicon      : VM-ioBroker                              -  enabled
        system.adapter.go-e.0                   : go-e                  : VM-ioBroker                              - disabled
      + system.adapter.hm-rega.0                : hm-rega               : VM-ioBroker                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : VM-ioBroker                              -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : VM-ioBroker                              -  enabled, port: 0
      + system.adapter.iqontrol.0               : iqontrol              : VM-ioBroker                              -  enabled
      + system.adapter.javascript.0             : javascript            : VM-ioBroker                              -  enabled
      + system.adapter.klf200.0                 : klf200                : VM-ioBroker                              -  enabled
      + system.adapter.lgtv.0                   : lgtv                  : VM-ioBroker                              -  enabled
        system.adapter.luftdaten.0              : luftdaten             : VM-ioBroker                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : VM-ioBroker                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.onkyo.0                  : onkyo                 : VM-ioBroker                              -  enabled
      + system.adapter.sainlogic.0              : sainlogic             : VM-ioBroker                              -  enabled, port: 1030, bind: 0.0.0.0
      + system.adapter.shuttercontrol.0         : shuttercontrol        : VM-ioBroker                              -  enabled
      + system.adapter.simple-api.0             : simple-api            : VM-ioBroker                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : VM-ioBroker                              -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.telegram.0               : telegram              : VM-ioBroker                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : VM-ioBroker                              -  enabled
        system.adapter.vw-connect.0             : vw-connect            : VM-ioBroker                              - disabled
      + system.adapter.web.0                    : web                   : VM-ioBroker                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : VM-ioBroker                              -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      │ (index) │   name   │                           url                           │ auto upgrade │
      │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
      │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "alpha-ess"    : 2.1.4    , installed 2.1.4
      Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
      Adapter    "backitup"     : 3.0.22   , installed 3.0.22
      Adapter    "canbus"       : 1.3.1    , installed 1.3.1
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "frontier_silicon": 0.3.0 , installed 0.3.0
      Adapter    "go-e"         : 1.0.29   , installed 1.0.38
      Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
      Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "klf200"       : 1.3.1    , installed 1.3.1
      Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
      Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
      Adapter    "sainlogic"    : 0.11.4   , installed 0.11.4
      Adapter    "shuttercontrol": 1.7.3   , installed 1.7.3
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects:        5974
      States:         4340
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       19241      1594/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       22102      1594/iobroker.js-co
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16670      537/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          310        1/init
      tcp        0      0 192.168.178.120:42001   0.0.0.0:*               LISTEN      1000       45375      2362/io.hm-rpc.0
      tcp        0      0 192.168.178.120:42010   0.0.0.0:*               LISTEN      1000       38784      2346/io.hm-rpc.1
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1000       23673      1920/io.sonoff.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       22657      1873/io.mqtt.0
      tcp        0      0 0.0.0.0:1030            0.0.0.0:*               LISTEN      1000       24726      2041/io.sainlogic.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       24774      2071/io.simple-api.
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       25743      2056/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       700429     12559/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          16672      537/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          14368      1/init
      udp        0      0 0.0.0.0:20000           0.0.0.0:*                           65534      755        592/cannelloni
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15690      387/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2001       1/init
      udp6       0      0 :::111                  :::*                                0          2478       1/init
            host: '192.168.178.100',
            protocol: 'http:',
            _redirectable: [Writable],
            [Symbol(kCapture)]: false,
            [Symbol(kBytesWritten)]: 0,
            [Symbol(kNeedDrain)]: false,
            [Symbol(corked)]: 0,
            [Symbol(kOutHeaders)]: [Object: null prototype],
            [Symbol(errored)]: null,
            [Symbol(kHighWaterMark)]: 16384,
            [Symbol(kRejectNonStandardBodyWrites)]: false,
            [Symbol(kUniqueHeaders)]: null
          data: '<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2 Final//EN">\n' +
            '<title>500 Internal Server Error</title>\n' +
            '<h1>Internal Server Error</h1>\n' +
            '<p>The server encountered an internal error and was unable to complete your request. Either the server is overloaded or there is an error in the application.</p>\n'
        status: 500
      2024-10-03 12:00:25.021  - info: host.VM-ioBroker instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 23674
      2024-10-03 12:00:26.720  - info: luftdaten.0 (23674) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.20.4, js-controller: 6.0.11
      2024-10-03 12:00:30.028  - info: luftdaten.0 (23674) [fillSensorData] error: connect EHOSTUNREACH 192.168.178.72:80
      2024-10-03 12:00:30.051  - info: luftdaten.0 (23674) Terminated (NO_ERROR): Without reason
      2024-10-03 12:00:30.580  - info: host.VM-ioBroker instance system.adapter.luftdaten.0 having pid 23674 terminated with code 0 (NO_ERROR)
        Thomas Braun Most Active @RaspiUser last edited by Thomas Braun
        @raspiuser sagte in Test Adapter PSA v0.0.x Peugeot Opel Citroen:
        Was muss ich hier (als ahnungsloser Linux-User) tun nachdem ich den Adapter gelöscht hatte?
        Nix. Aber du solltest einen eigenen user verwenden. Der 'iobroker' ist als Systemuser vorgesehen und nicht als regulärer Login. Der user gehört dann auch in die Gruppe 'adm' rein.
        Boot Target: graphical.target
        sudo systemctl set-default multi-user.target
        HINT:
        /dev/ttyUSB0
        Stell das richtig ein.
        Bring nodejs auf v20.
        iob nodejs-update
        RaspiUser 1 Reply Last reply Reply Quote 1
        • RaspiUser
          RaspiUser @Thomas Braun last edited by
          @thomas-braun Danke, wie sooft hast Du Antworten ...
          Ich habe beide Befehle ausgeführt (wobei ich nicht wirklich weiss, was ich da eigentlich tue ...), hier das Ergebnis:
          ```bash
          Skript v.2024-08-12
          *** BASE SYSTEM ***
                   Chassis: vm 🖴
            Virtualization: kvm
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
           14:18:01 up 3 min,  2 users,  load average: 0.71, 0.91, 0.42
          CPU threads: 4
                         Local time: Thu 2024-10-03 14:18:01 CEST
                     Universal time: Thu 2024-10-03 12:18:01 UTC
                           RTC time: Thu 2024-10-03 12:18:01
                        NTP service: active
                    RTC in local TZ: no
          iobroker
          HOME=/home/iobroker
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            8.3G        1.9G        6.3G        598K        362M        6.4G
          Swap:           1.0G          0B        1.0G
          Total:          9.3G        1.9G        7.3G
                   7940 M total memory
                   1817 M used memory
                    198 M active memory
                   1562 M inactive memory
                   6010 M free memory
                     31 M buffer memory
                    314 M swap cache
                    974 M total swap
                      0 M used swap
                    974 M free swap
          top - 14:18:02 up 3 min,  2 users,  load average: 0.71, 0.91, 0.42
          Tasks: 142 total,   1 running, 141 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us, 25.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   7940.7 total,   6010.7 free,   1817.4 used,    346.5 buff/cache
          MiB Swap:    975.0 total,    975.0 free,      0.0 used.   6123.3 avail Mem
          *** FILESYSTEM ***
          tmpfs          tmpfs     795M  584K  794M   1% /run
          /dev/sda1      ext4       48G  8.0G   38G  18% /
          [Thu Oct  3 14:14:08 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
          [Thu Oct  3 14:14:10 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
          /var:
          2.0G    /var/
          1.3G    /var/log/journal/27bb2095ba2b41ccb088ec3ad41fc1f5
          1.3G    /var/log
          544M    /var/cache
          Archived and active journals take up 216.4M in the file system.
          717M    /opt/iobroker/iobroker-data/
          27M     /opt/iobroker/iobroker-data/objects.jsonl
          USB-Devices by-id:
          HINT:
          /dev/ttyUSB0
          /usr/bin/nodejs         v20.17.0
          /usr/bin/node           v20.17.0
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.3
          nodejs:
            Installed: 20.17.0-1nodesource1
            Candidate: 20.17.0-1nodesource1
            Version table:
           *** 20.17.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          7.1.5
          javascript:     8.7.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        5974
          States:         4368
          Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
          Pending Updates: 0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16521      534/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14610      1/init
          tcp        0      0 0.0.0.0:1030            0.0.0.0:*               LISTEN      1000       19616      1282/io.sainlogic.0
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       16534      473/iobroker.js-con
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       15048      473/iobroker.js-con
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       16009      1090/io.mqtt.0
          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1000       16058      1157/io.sonoff.0
          tcp        0      0 192.168.178.120:42001   0.0.0.0:*               LISTEN      1000       18751      1008/io.hm-rpc.0
          tcp        0      0 192.168.178.120:42010   0.0.0.0:*               LISTEN      1000       18779      1019/io.hm-rpc.1
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       20611      1297/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       15712      717/io.admin.0
          tcp6       0      0 :::8087                 :::*                    LISTEN      1000       19642      1312/io.simple-api.
          tcp6       0      0 :::22                   :::*                    LISTEN      0          16523      534/sshd: /usr/sbin
          tcp6       0      0 :::111                  :::*                    LISTEN      0          13672      1/init
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17744      389/dhclient
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12759      1/init
          udp        0      0 0.0.0.0:20000           0.0.0.0:*                           65534      16532      547/cannelloni
          udp6       0      0 :::111                  :::*                                0          12762      1/init
          2024-10-03 14:16:48.599  - info: klf200.0 (1327) Setup objects for product Fenster Bad OG.
          2024-10-03 14:16:49.018  - info: klf200.0 (1327) Setup objects for product Rollo Bad OG.
          2024-10-03 14:16:49.978  - info: klf200.0 (1327) Setup objects for product Rollo Zimmer OG.
          2024-10-03 14:16:50.614  - info: klf200.0 (1327) Setting up notification handlers for removal...
          2024-10-03 14:16:50.615  - info: klf200.0 (1327) Setting up notification handlers for discovering new objects...
          2024-10-03 14:16:50.615  - info: klf200.0 (1327) Adapter is ready for use.
          2024-10-03 14:16:50.615  - info: klf200.0 (1327) Starting background state refresher...
          2024-10-03 14:16:50.616  - info: klf200.0 (1327) Automatic reboot enabled in configuration. Planning reboot job.
          2024-10-03 14:17:17.378  - info: admin.0 (717) <== Disconnect system.user.admin from ::ffff:192.168.178.20 admin
          Es bleiben noch 2 Fragen ...
          @thomas-braun sagte in Test Adapter PSA v0.0.x Peugeot Opel Citroen:
          Aha ... wie ?!
          Aha ... wie ?!
          Entschuldigung für die, wahrscheinlich dämlichen, Fragen ...
          (Ich bin in einem Alter, in dem ich sehr langsam lerne, dafür aber seeeeehr schnell vergesse ....)
            @raspiuser
            sudo adduser NEUER_USERNAME
            sudo usermod -aG adm,dialout,sudo,audio,video,plugdev,users,iobroker NEUER_USERNAME
            sudo reboot
            Und dann nur noch als NEUER_USERNAME anmelden und mit dem System agieren. NICHT als root und NICHT als iobroker anmelden.
            • RaspiUser
              OK ...
              ... Zigbee Thema ... sieht bei mir so aus ...
                Und um es rund zu machen:
                Trag statt /dev/ttyUSB0 im Zigbee-Adapter besser
                als Port ein.
                • RaspiUser
                  als Port ein
                  erl.
                  Aber einen (typischen) Fehler habe ich noch ... sorry ...
                  iobroker@VM-ioBroker:~$ iobroker@VM-ioBroker:~$ usermod -aG adm,dialout,sudo,audio,video,plugdev,users,iobroker raspiuser
                  -bash: usermod: Kommando nicht gefunden.
                    @raspiuser
                    Kan sein, dass usermod nicht im $PATH eines einfachen users liegt.
                    sudo usermod -aG adm,dialout,sudo,audio,video,plugdev,users,iobroker raspiuser
                    • RaspiUser
                      ... das mit "sudo" vorn dran habe ich (eigenverantwortlich) vorher schon probiert und dann lief der Befehl durch ...
                      Das "iob diag" mit dem neuen User dann nicht funktioniert ist dann wohl richtig, oder?
                      login as: raspiuser
                      raspiuser@192.168.178.120's password:
                      Linux VM-ioBroker 6.1.0-25-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.106-3 (2024-0                 8-26) x86_64
                      The programs included with the Debian GNU/Linux system are free software;
                      the exact distribution terms for each program are described in the
                      individual files in /usr/share/doc/*/copyright.
                      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                      permitted by applicable law.
                      Last login: Thu Oct  3 15:01:14 2024 from 192.168.178.20
                      raspiuser@VM-ioBroker:~$ iob diag
                      [sudo] Passwort für raspiuser:
                      bash: /home/iobroker/.diag.sh: Keine Berechtigung
                        Da fehlen Rechte in das fremde /home einzusteigen.
                        ls -l /home/
                        sagt?
                        RaspiUser 1 Reply Last reply Reply Quote 0
                        • RaspiUser
                          ls -l /home/
                          raspiuser@VM-ioBroker:~$ ls -l /home/
                          insgesamt 8
                          drwx------ 8 iobroker  iobroker  4096  3. Okt 13:53 iobroker
                          drwx------ 2 raspiuser raspiuser 4096  3. Okt 15:01 raspiuser
                            @raspiuser
                            sudo chmod g+rx /home/iobroker
                            • RaspiUser
                              RaspiUser @Thomas Braun last edited by RaspiUser
                              raspiuser@VM-ioBroker:~$ sudo chmod g+rx /home/iobroker
                              insgesamt 8
                              drwxr-x--- 8 iobroker  iobroker  4096  3. Okt 13:53 iobroker
                              ... und iob diag läuft ...
                              Aber das ist jetzt schon ganz schön weit weg vom ursprünglichen Thread ... 😉 ... vielen Dank !!!!
                                @raspiuser
                                Sollte jetzt passen.
                                  Stimmt. Hatte nicht gesehen das der Thread eigentlich ein anderes Thema hatte. Vielleicht kann das ein Mod hier rauslösen und in einen eigenen Thread überführen.
                                  • RaspiUser
                                    ... aber es hat heute angefangen mit dem löschen des PSA Adapters (#317) .... also doch irgendwie mit dem ursprüngleichen Thema ... 🙄
                                    citroen corsa corsa-e e208 opel peugeot psa
                                    44
                                    334
                                    47377
