    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    • Peter V.
      Peter V. @arteck last edited by
      @arteck
      habe leider (auch wenn nur bei Adapter Start) immer noch folgende Fehlermeldung:
      TypeError: Cannot read properties of undefined (reading 'hasOwnProperty') at Bluelink.setNewFullStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:665:66) at async Bluelink.readStatusVin (/opt/iobroker/node_modules/iobroker.bluelink/main.js:370:15) at async Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:333:11) at async Pe.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:292:17)
      Da der Fehler beim Adapterstart nur einmalig auftritt, kann ich damit leben.
        arteck Developer Most Active @Peter V. last edited by arteck
        @peter-v sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
        das ist keine Lösung.. schau bitte nochmal auf GIT
        ? F M 4 Replies Last reply Reply Quote 0
          A Former User @arteck last edited by
          @arteck
          aktuelle Version 3.0.3 bringt beim starten gleich das bei mir:
          2024-10-02 07:12:56.559  - info: host.iobroker instance system.adapter.bluelink.0 in version "3.0.3" (non-npm: Newan/ioBroker.bluelink) started with pid 2841
          2024-10-02 07:12:57.894  - info: bluelink.0 (2841) starting. Version 3.0.3 (non-npm: Newan/ioBroker.bluelink) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.17.0, js-controller: 6.0.11
          2024-10-02 07:12:57.903  - info: bluelink.0 (2841) Login to api
          2024-10-02 07:12:59.264  - info: bluelink.0 (2841) 1 Vehicles found
          2024-10-02 07:12:59.393  - info: bluelink.0 (2841) Read new update for KMHxxx from the server
          2024-10-02 07:13:00.005  - info: influxdb.0 (610) Store 1001 buffered influxDB history points
          2024-10-02 07:13:00.145  - error: bluelink.0 (2841) TypeError: newStatus.ccs2Status.state.VehiclehasOwnProperty is not a function
              at Bluelink.setNewFullStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:665:48)
          2024-10-02 07:13:00.149  - info: bluelink.0 (2841) Update for KMHxxx successfull
          Abholen direct von car bringt immer noch ein double-request Error, im Adapter habe ich die Abfragen auf 48 stehen, das funktioniert, er holt alle 30 Minuten vom Server hab.
          Direct pull vom Server geht auch ohne Fehler.
            fichte_112 @arteck last edited by
            @arteck
            Bei mir kommt beim Abholen der Daten folgende Fehlermeldung.
            TypeError: newStatus.ccs2Status.state.VehiclehasOwnProperty is not a function at Bluelink.setNewFullStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:665:48) at async Bluelink.readStatusVin (/opt/iobroker/node_modules/iobroker.bluelink/main.js:370:15) at async Bluelink.onStateChange (/opt/iobroker/node_modules/iobroker.bluelink/main.js:163:22)
              MichaelWit @arteck last edited by
              @arteck
              Ich bekomme mit der aktuellen Version folgenden Fehler:
              TypeError: Cannot read properties of undefined (reading '0') at Bluelink.setNewFullStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:587:89) at async Bluelink.readStatusVin (/opt/iobroker/node_modules/iobroker.bluelink/main.js:370:15) at async Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:333:11) at async Pe.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:292:17)
                @fichte_112 sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                installiert mal von GIT.. da fehlte ein punkt
                @ilovegym sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                hab ich aber auch.. bei meinem KIA
                  fichte_112 last edited by
                  @arteck Die Daten werden jetzt ohne Fehler abgeholt.
                  Vielen Dank
                    @arteck
                    Sieht jetzt gut aus.
                    Dankeschön 🙂
                      @arteck
                      Aktuelle Version 3.0.3 holt bei mir keine Daten des SOC ab, 12 v geht, aber der soc steht da immer bei 63,5%.. und zur Zeit sinds 59…
                      Bin auf die 3.0.1 zurück, da gehts…
                      Edit: 3.0.4 von Git hat auch das Problem... SOC wird nicht aktualisiert..
                        @arteck bei mir werden die Daten der Batterie auch nicht aktualisiert. Bin heute nicht gefahren. Daher habe ich es nicht bemerkt. Habe es aber gerade getestet.
                          arteck Developer Most Active @Guest last edited by
                          @ilovegym jetzt
                          F ? 2 Replies Last reply Reply Quote 0
                            @arteck bei mir funktioniert es jetzt.
                              @arteck
                              Vielen lieben Dank fuer deine Updates!
                              Mir ist jetzt folgendes aufgefallen:
                              Aktuelle Version installiert: 3.1.0 getestet:
                              force_refresh Server - geht
                              force_refresh Car - geht nicht, error - duplicate request, holt auch keine Daten
                              bluelink.0
                              2024-10-05 10:11:37.708	error	@EuropeVehicle.status: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/1efdaa96-ad82-4d6f-aacf-ea53b51423d9/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"71a12490-82f1-11ef-aba2-38615d933127"}
                              bluelink.0
                              2024-10-05 10:11:37.708	error	Error on API-Request Status, ErrorCount:1
                              door lock / unlock - geht nicht, error:
                              bluelink.0
                              2024-10-05 10:12:09.355	error	Error onStateChange ManagedBluelinkyError: @EuropeVehicle.unlock: [400] Bad Request on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/1efdaa96-ad82-4d6f-aacf-ea53b51423d9/control/door - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"8474efc0-82f1-11ef-aba2-df909eb82f85"}
                              start charging, geht, stop charging error:
                              bluelink.0
                              2024-10-05 10:20:04.208	error	Error onStateChange ManagedBluelinkyError: @EuropeVehicle.stopCharge: [400] Bad Request on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/1efdaa96-ad82-4d6f-aacf-ea53b51423d9/control/charge - {"retCode":"F","resCode":"4002","resMsg":"Invalid request body - Invalid deviceId. ","msgId":"9f88bd90-82f2-11ef-bd47-69d9b0cdd3fc"}
                              Folder general, location und odometer funktionieren.
                              andere Datenpunkte die nicht gefuellt werden(interessant hier charge, plugin) :
                              Peter V. 1 Reply Last reply Reply Quote 0
                              • Peter V.
                                Peter V. @Guest last edited by
                                @arteck
                                jetzt läuft es, auch die Position wird angezeigt.
                                Perfekt. Vielen Dank
                                • Peter V.
                                  Peter V. @Peter V. last edited by
                                  @arteck
                                  nach Update von 3.0.4 auf 3.1.0 folgender Fehler:
                                  TypeError: Cannot read properties of undefined (reading 'hasOwnProperty') at Bluelink.setNewFullStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:667:136) at async Bluelink.readStatusVin (/opt/iobroker/node_modules/iobroker.bluelink/main.js:370:17) at async Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:333:13) at async Pe.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:292:17)
                                    hasOwnProperty
                                    installier nochmal von GIT
                                    dann adapter auf debug stellen und nach ccs2Status: suchen
                                    danach kommt ein langer String den brauch ich ..
                                    alternativ in den Objects aufklappen und screenshot machen
                                    genauer schauen aber ich brauch das was unter
                                    vehicleStatusRaw.ccs2Status
                                    steht
                                    Peter V. 2 Replies Last reply Reply Quote 0
                                    • Peter V.
                                      Peter V. @arteck last edited by Peter V.
                                      @arteck ``````
                                      code_text
                                      ccs2Status: {"resCode":"0000","ServiceNo":"RVS-K","RetCode":"S","lastUpdateTime":"1728326849741","state":{"Vehicle":{"DrivingReady":0,"Body":{"Windshield":{"Front":{"Defog":{"State":0},"WasherFluid":{"LevelLow":0}},"Rear":{"Defog":{"State":0}}},"Hood":{"Open":0},"Lights":{"Rear":{"Right":{"TurnSignal":{"Warning":0},"StopLamp":{"Warning":0}},"Left":{"TurnSignal":{"Warning":0},"StopLamp":{"Warning":0}}},"Front":{"Right":{"High":{"Warning":0},"Low":{"Warning":0},"TurnSignal":{"Warning":0}},"Left":{"High":{"Warning":0},"Low":{"Warning":0},"TurnSignal":{"Warning":0}},"HeadLamp":{"SystemWarning":0}},"DischargeAlert":{"State":0},"TailLamp":{"Alert":0},"Hazard":{"Alert":0}},"Trunk":{"Open":0}},"Cabin":{"Window":{"Row2":{"Right":{"Open":0},"Left":{"Open":0}},"Row1":{"Passenger":{"Open":0},"Driver":{"Open":0}}},"SteeringWheel":{"Heat":{"State":0}},"Seat":{"Row2":{"Right":{"Climate":{"State":2}},"Left":{"Climate":{"State":2}}},"Row1":{"Passenger":{"Climate":{"State":2}},"Driver":{"Climate":{"State":2}}}},"HVAC":{"Row1":{"Driver":{"Temperature":{"Value":"OFF","Unit":0},"Blower":{"SpeedLevel":0}}},"Temperature":{"RangeType":1}},"Door":{"Row2":{"Right":{"Open":0,"Lock":0},"Left":{"Open":0,"Lock":0}},"Row1":{"Passenger":{"Open":0,"Lock":0},"Driver":{"Open":0,"Lock":0}}}},"Chassis":{"Axle":{"Tire":{"PressureLow":0},"Row1":{"Left":{"Tire":{"PressureLow":0}},"Right":{"Tire":{"PressureLow":0}}},"Row2":{"Left":{"Tire":{"PressureLow":0}},"Right":{"Tire":{"PressureLow":0}}}},"Brake":{"Fluid":{"Warning":0}}},"Drivetrain":{"Transmission":{"ParkingPosition":0},"InternalCombustionEngine":{"OilLevelWarning":0},"FuelSystem":{"DTE":{"Unit":1,"Total":401},"LowFuelWarning":0,"FuelLevel":59},"Odometer":13905.5},"Electronics":{"PowerSupply":{"Accessory":0},"Battery":{"Level":97,"SensorReliability":0},"FOB":{"LowBattery":0},"AutoCut":{"BatteryPreWarning":0}},"Green":{"Reservation":{"OffPeakTime":{"Mode":1},"Departure":{"Schedule2":{"Sun":0,"Sat":0,"Fri":0,"Thu":0,"Wed":0,"Tue":0,"Mon":0},"Schedule1":{"Sun":0,"Sat":0,"Fri":0,"Thu":0,"Wed":0,"Tue":0,"Mon":0}}},"ChargingInformation":{"SequenceDetails":510,"SequenceSubcode":-1}},"RemoteControl":{"SleepMode":1},"Date":"20241007184729.734","Location":{"GeoCoord":{"Latitude":47.973883,"Longitude":10.266247,"Type":0,"Altitude":0},"Speed":{"Value":0,"Unit":0},"TimeStamp":{"Year":2024,"Mon":10,"Day":7,"Hour":18,"Min":47,"Sec":28}},"Service":{"ConnectedCar":{"RemoteControl":{"Available":1,"WaitingTime":168}}}}}}
                                      • Peter V.
                                          @peter-v so guckmal jetzt ..von GIT
                                          Peter V. ? 2 Replies Last reply Reply Quote 0
                                          • Peter V.
                                            @arteck
                                            Jetzt ist es ohne Fehler.
                                            Genial, danke 😉
                                            1.0k
                                            2303
                                            860594
