Alexa2 3.26.x
@thomas-braun habs mal versucht:
2024-08-24 23:46:36.892 - info: alexa2.0 (310) starting. Version 3.26.5 in /opt/iobroker/node_modules/iobroker.alexa2, node: v20.17.0, js-controller: 6.0.11 2024-08-24 23:46:36.916 - info: alexa2.0 (310) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged. 2024-08-24 23:46:36.917 - info: alexa2.0 (310) Use Override IP 192.168.2.85 for Proxy 2024-08-24 23:46:37.015 - error: alexa2.0 (310) Error: 2024-08-24 23:46:37.016 - error: alexa2.0 (310) Error: Please open http://192.168.2.85:38790/ with your browser and login to Amazon. The cookie will be output here after successfull login. 2024-08-24 23:46:37.771 - info: hmip.0 (295) hmip adapter connected and ready 2024-08-24 23:46:37.777 - error: weatherunderground.0 (280) no observations in response from https://api.weather.com/v3/wx/observations/current?apiKey=e1f10a1e78da46f5b10a1e78da96f525&geocode=0%2C0&units=m&language=de&format=json 2024-08-24 23:46:37.806 - error: weatherunderground.0 (280) WUnderground reported an error: --/{"code":"ERR_INVALID_URL","input":""} 2024-08-24 23:46:37.808 - error: weatherunderground.0 (280) No current observation data found in response 2024-08-24 23:46:38.022 - error: weatherunderground.0 (280) No forecast data found in response 2024-08-24 23:46:40.031 - info: weatherunderground.0 (280) Terminated (NO_ERROR): Without reason 2024-08-24 23:46:40.051 - info: host.raspberrypi4 instance system.adapter.discovery.0 in version "5.0.0" started with pid 325 2024-08-24 23:46:40.578 - info: host.raspberrypi4 instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR) 2024-08-24 23:46:40.787 - info: discovery.0 (325) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11 2024-08-24 23:46:44.019 - info: host.raspberrypi4 instance system.adapter.web.0 in version "6.3.0" started with pid 352 2024-08-24 23:46:44.850 - info: web.0 (352) starting. Version 6.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.11 2024-08-24 23:46:44.915 - info: web.0 (352) socket.io server listening on port 8082 2024-08-24 23:46:44.917 - info: web.0 (352) http server listening on port 8082 2024-08-24 23:46:48.006 - info: host.raspberrypi4 instance system.adapter.vis-2.0 in version "2.9.64" started with pid 367 2024-08-24 23:46:48.812 - info: vis-2.0 (367) starting. Version 2.9.64 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.17.0, js-controller: 6.0.11 2024-08-24 23:46:48.836 - error: vis-2.0 (367) No license found for vis-2. Please get one on https://iobroker.net ! 2024-08-24 23:46:52.051 - info: host.raspberrypi4 instance system.adapter.socketio.0 in version "6.7.1" started with pid 382 2024-08-24 23:46:52.832 - info: socketio.0 (382) starting. Version 6.7.1 in /opt/iobroker/node_modules/iobroker.socketio, node: v20.17.0, js-controller: 6.0.11 2024-08-24 23:46:52.857 - info: socketio.0 (382) socket.io server listening on port 8084 2024-08-24 23:46:56.054 - info: host.raspberrypi4 instance system.adapter.ws.0 in version "2.6.2" started with pid 403 2024-08-24 23:46:56.870 - info: ws.0 (403) starting. Version 2.6.2 in /opt/iobroker/node_modules/iobroker.ws, node: v20.17.0, js-controller: 6.0.11 2024-08-24 23:46:56.981 - error: ws.0 (403) port 8084 already in use 2024-08-24 23:46:56.982 - info: ws.0 (403) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2024-08-24 23:46:57.490 - info: ws.0 (403) terminating http server on port 8084 2024-08-24 23:46:57.502 - info: host.raspberrypi4 instance system.adapter.ws.0 terminated by request of the instance itself and will not be restarted, before user restarts it. 2024-08-24 23:46:57.502 - info: host.raspberrypi4 Do not restart adapter system.adapter.ws.0 because desired by instance 2024-08-24 23:47:00.013 - info: host.raspberrypi4 instance system.adapter.tradfri.0 in version "3.1.3" started with pid 430 2024-08-24 23:47:00.775 - info: tradfri.0 (430) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.tradfri, node: v20.17.0, js-controller: 6.0.11 2024-08-24 23:47:00.870 - info: tradfri.0 (430) Discovering the gateway automatically... 2024-08-24 23:47:00.944 - info: tradfri.0 (430) Found gateway gw-b072bf27b5f5 at 192.168.2.136 2024-08-24 23:47:01.141 - info: tradfri.0 (430) got all devices: [65548,65551,65553,65546,65556,65554,65558,65559,65549,65541,65540,65537,65550,65557] 2024-08-24 23:47:01.192 - warn: tradfri.0 (430) found unknown property with key 15019 2024-08-24 23:47:01.192 - warn: tradfri.0 (430) object was: {"3":{"0":"IKEA of Sweden","1":"TRADFRI SHORTCUT Button","2":"","3":"24.4.6","6":3,"7":4550,"8":0,"9":90},"5750":0,"9001":"TRADFRI SHORTCUT Button","9002":1625985939,"9003":65551,"9019":1,"9020":1724496436,"9054":0,"15009":[{"9003":0}],"15019":{"9039":224728,"9250":[{"9251":1,"9252":[{"9253":1,"9254":1,"9255":224728},{"9253":2,"9254":1,"9255":224730},{"9253":3,"9254":1,"9255":224729}]}]}} 2024-08-24 23:47:01.197 - warn: tradfri.0 (430) found unknown property with key 15019 2024-08-24 23:47:01.197 - warn: tradfri.0 (430) object was: {"3":{"0":"IKEA of Sweden","1":"TRADFRI SHORTCUT Button","2":"","3":"24.4.6","6":3,"7":4550,"8":0,"9":90},"5750":0,"9001":"Shortcut-Taste 2","9002":1666879445,"9003":65553,"9019":1,"9020":1724508036,"9054":0,"15009":[{"9003":0}],"15019":{"9039":224731,"9250":[{"9251":1,"9252":[{"9253":1,"9254":1,"9255":224731},{"9253":2,"9254":0,"9255":0},{"9253":3,"9254":1,"9255":224732}]}]}} 2024-08-24 23:47:01.221 - info: tradfri.0 (430) received all devices 2024-08-24 23:47:01.225 - info: tradfri.0 (430) got all groups: [165545,165538,165541,165537,165539,165544,165542] 2024-08-24 23:47:01.386 - info: tradfri.0 (430) got all scenes in group 165537: [224706,224707,224708,224709] 2024-08-24 23:47:01.397 - info: tradfri.0 (430) got all scenes in group 165538: [224714,224715,224716,224717] 2024-08-24 23:47:01.417 - info: tradfri.0 (430) got all scenes in group 165539: [224718,224728,224729,224730,224731,224732,224733] 2024-08-24 23:47:01.437 - info: tradfri.0 (430) got all scenes in group 165541: [] 2024-08-24 23:47:01.459 - info: tradfri.0 (430) got all scenes in group 165542: [] 2024-08-24 23:47:01.481 - info: tradfri.0 (430) got all scenes in group 165544: [] 2024-08-24 23:47:01.491 - info: tradfri.0 (430) got all scenes in group 165545: [] 2024-08-24 23:47:01.508 - info: tradfri.0 (430) updating possible scenes for group 165537: ["224706"] 2024-08-24 23:47:01.525 - info: tradfri.0 (430) updating possible scenes for group 165537: ["224706","224707"] 2024-08-24 23:47:01.542 - info: tradfri.0 (430) updating possible scenes for group 165537: ["224706","224707","224708"] 2024-08-24 23:47:01.574 - info: tradfri.0 (430) updating possible scenes for group 165537: ["224706","224707","224708","224709"] 2024-08-24 23:47:01.589 - info: tradfri.0 (430) updating possible scenes for group 165538: ["224714"] 2024-08-24 23:47:01.604 - info: tradfri.0 (430) updating possible scenes for group 165538: ["224714","224715"] 2024-08-24 23:47:01.620 - info: tradfri.0 (430) updating possible scenes for group 165538: ["224714","224715","224716"] 2024-08-24 23:47:01.633 - info: tradfri.0 (430) updating possible scenes for group 165538: ["224714","224715","224716","224717"] 2024-08-24 23:47:01.651 - info: tradfri.0 (430) updating possible scenes for group 165539: ["224718"] 2024-08-24 23:47:01.681 - info: tradfri.0 (430) updating possible scenes for group 165539: ["224718","224728"] 2024-08-24 23:47:01.688 - info: tradfri.0 (430) updating possible scenes for group 165539: ["224718","224728","224729"] 2024-08-24 23:47:01.696 - info: tradfri.0 (430) updating possible scenes for group 165539: ["224718","224728","224729","224730"] 2024-08-24 23:47:01.716 - info: tradfri.0 (430) updating possible scenes for group 165539: ["224718","224728","224729","224730","224731"] 2024-08-24 23:47:01.728 - info: tradfri.0 (430) updating possible scenes for group 165539: ["224718","224728","224729","224730","224731","224732"] 2024-08-24 23:47:01.741 - info: tradfri.0 (430) received all groups and scenes 2024-08-24 23:47:01.742 - info: tradfri.0 (430) updating possible scenes for group 165539: ["224718","224728","224729","224730","224731","224732","224733"] 2024-08-24 23:48:20.309 - info: admin.0 (158) failed connection to socket.io from ::ffff:192.168.2.75: Passport was not initialized 2024-08-24 23:48:25.085 - info: admin.0 (158) ==> Connected system.user.admin from ::ffff:192.168.2.75 2024-08-24 23:48:33.632 - info: admin.0 (158) ==> Connected system.user.admin from ::ffff:192.168.2.75 2024-08-24 23:48:47.914 - error: alexa2.0 (310) Error: Unexpected end of JSON input 2024-08-24 23:48:47.915 - info: alexa2.0 (310) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2024-08-24 23:48:48.448 - info: host.raspberrypi4 instance system.adapter.alexa2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2024-08-24 23:48:48.449 - info: host.raspberrypi4 Restart adapter system.adapter.alexa2.0 because enabled 2024-08-24 23:48:49.814 - info: host.raspberrypi4 instance system.adapter.alexa2.0 in version "3.26.5" started with pid 547 2024-08-24 23:48:50.618 - info: alexa2.0 (547) starting. Version 3.26.5 in /opt/iobroker/node_modules/iobroker.alexa2, node: v20.17.0, js-controller: 6.0.11 2024-08-24 23:48:50.637 - info: alexa2.0 (547) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged. 2024-08-24 23:48:50.643 - error: alexa2.0 (547) Adapter seems to have issues and crashed three times in a row. Disabling!! Please start again and check logs. 2024-08-24 23:48:51.644 - info: alexa2.0 (547) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2024-08-24 23:48:52.164 - info: host.raspberrypi4 instance system.adapter.alexa2.0 terminated by request of the instance itself and will not be restarted, before user restarts it. 2024-08-24 23:48:52.164 - info: host.raspberrypi4 Do not restart adapter system.adapter.alexa2.0 because desired by instance 2024-08-24 23:49:25.150 - info: admin.0 (158) <== Disconnect system.user.admin from ::ffff:192.168.2.75 -
@automatist2 sagte in Alexa2 3.26.x:
Was ist denn mit den anderen Adaptern los?
Lass da erstmal Ruhe einkehren. -
@thomas-braun hab mal 2 Adapter die ich aktuell nicht nutze deinstalliert und nochmal bei Amazon eingeloggt:
2024-08-25 00:57:01.604 - warn: web.0 (352) setTimeout called, but adapter is shutting down 2024-08-25 00:57:01.611 - info: host.raspberrypi4 iobroker Adapter "system.adapter.web.0" restarted. 2024-08-25 00:57:01.613 - info: host.raspberrypi4 stopInstance system.adapter.web.0 send kill signal 2024-08-25 00:57:01.616 - info: web.0 (352) Got terminate signal TERMINATE_YOURSELF 2024-08-25 00:57:01.658 - info: host.raspberrypi4 stopInstance system.adapter.web.0 send kill signal 2024-08-25 00:57:02.105 - info: web.0 (352) terminating 2024-08-25 00:57:02.106 - info: web.0 (352) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2024-08-25 00:57:02.614 - info: host.raspberrypi4 stopInstance timeout system.adapter.web.0 killing pid 352 2024-08-25 00:57:02.624 - info: host.raspberrypi4 instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2024-08-25 00:57:02.626 - info: host.raspberrypi4 iobroker exit 0 2024-08-25 00:57:05.987 - info: host.raspberrypi4 instance system.adapter.web.0 in version "6.3.0" started with pid 3910 2024-08-25 00:57:06.810 - info: web.0 (3910) starting. Version 6.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.11 2024-08-25 00:57:06.874 - info: web.0 (3910) socket.io server listening on port 8082 2024-08-25 00:57:06.877 - info: web.0 (3910) http server listening on port 8082 2024-08-25 00:57:22.162 - info: host.raspberrypi4 iobroker del telegram 2024-08-25 00:57:22.918 - info: host.raspberrypi4 iobroker Delete adapter "telegram" 2024-08-25 00:57:22.923 - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 1 instances of telegram 2024-08-25 00:57:22.935 - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 2 meta of telegram 2024-08-25 00:57:22.936 - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 1 adapter for telegram 2024-08-25 00:57:22.942 - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 1 channels of telegram 2024-08-25 00:57:22.946 - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 18 states of telegram 2024-08-25 00:57:22.950 - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 14 states of system.adapter.telegram 2024-08-25 00:57:22.952 - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 2 states (io.telegram.*) from states 2024-08-25 00:57:22.959 - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 1 states (system.adapter.telegram.*) from states 2024-08-25 00:57:23.561 - info: host.raspberrypi4 iobroker host.raspberrypi4 file telegram.admin deleted 2024-08-25 00:57:23.565 - info: host.raspberrypi4 iobroker host.raspberrypi4 object telegram deleted 2024-08-25 00:57:23.568 - info: host.raspberrypi4 iobroker host.raspberrypi4 object telegram.admin deleted 2024-08-25 00:57:23.569 - info: host.raspberrypi4 iobroker host.raspberrypi4 Deleting 38 object(s). 2024-08-25 00:57:23.614 - info: host.raspberrypi4 iobroker host.raspberrypi4 Deleting 3 state(s). 2024-08-25 00:57:23.659 - info: host.raspberrypi4 object deleted system.adapter.telegram.0 2024-08-25 00:57:25.515 - info: host.raspberrypi4 iobroker removed 77 packages in 2s 2024-08-25 00:57:25.516 - info: host.raspberrypi4 iobroker 119 packages are looking for funding run `npm fund` for details 2024-08-25 00:57:26.533 - info: host.raspberrypi4 iobroker exit 0 2024-08-25 00:58:48.235 - info: admin.0 (158) ==> Connected system.user.admin from ::ffff:192.168.2.170 2024-08-25 00:58:53.263 - info: admin.0 (158) <== Disconnect system.user.admin from ::ffff:192.168.2.170 2024-08-25 00:58:57.955 - info: host.raspberrypi4 instance system.adapter.alexa2.0 in version "3.26.5" started with pid 4055 2024-08-25 00:58:58.750 - info: alexa2.0 (4055) starting. Version 3.26.5 in /opt/iobroker/node_modules/iobroker.alexa2, node: v20.17.0, js-controller: 6.0.11 2024-08-25 00:58:58.769 - info: alexa2.0 (4055) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged. 2024-08-25 00:58:58.770 - info: alexa2.0 (4055) Use Override IP 192.168.2.85 for Proxy 2024-08-25 00:58:58.860 - error: alexa2.0 (4055) Error: 2024-08-25 00:58:58.860 - error: alexa2.0 (4055) Error: Please open http://192.168.2.85:38790/ with your browser and login to Amazon. The cookie will be output here after successfull login. 2024-08-25 00:59:05.384 - info: admin.0 (158) ==> Connected system.user.admin from ::ffff:192.168.2.170 2024-08-25 01:00:13.243 - error: alexa2.0 (4055) Error: Unexpected end of JSON input 2024-08-25 01:00:13.245 - info: alexa2.0 (4055) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2024-08-25 01:00:13.771 - info: host.raspberrypi4 instance system.adapter.alexa2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2024-08-25 01:00:13.772 - info: host.raspberrypi4 Restart adapter system.adapter.alexa2.0 because enabled 2024-08-25 01:00:15.177 - info: host.raspberrypi4 instance system.adapter.alexa2.0 in version "3.26.5" started with pid 4130 2024-08-25 01:00:15.964 - info: alexa2.0 (4130) starting. Version 3.26.5 in /opt/iobroker/node_modules/iobroker.alexa2, node: v20.17.0, js-controller: 6.0.11 2024-08-25 01:00:15.983 - info: alexa2.0 (4130) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged. 2024-08-25 01:00:15.986 - error: alexa2.0 (4130) Adapter seems to have issues and crashed three times in a row. Disabling!! Please start again and check logs. 2024-08-25 01:00:16.987 - info: alexa2.0 (4130) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2024-08-25 01:00:17.505 - info: host.raspberrypi4 instance system.adapter.alexa2.0 terminated by request of the instance itself and will not be restarted, before user restarts it. 2024-08-25 01:00:17.505 - info: host.raspberrypi4 Do not restart adapter system.adapter.alexa2.0 because desired by instance 2024-08-25 01:00:28.314 - info: admin.0 (158) <== Disconnect system.user.admin from ::ffff:192.168.2.170 -
Warum machst Du nicht das, was im Log zum x.Mal steht?
Please open http://192.168.2.85:38790/ with your browser and login to Amazon. The cookie will be output here after successfull login -
Am besten mal debug log aktivieren das man sieht was er tut. Das log dann posten bitte.
Ich hatte denselben Fehler. In den Proxy Einstellungen des Adapters den Punkt "Eigene IP oder Hostname für den Proxy-Link" mal überprüfen
Gibt es einen Datenpunkt der den Status vom Mikrofon anzeigt?
Man kann ja per Hardwaretaste am Gerät aktivieren oder deaktivieren. -
@spike2
Nein gibt es nicht.
Von Amazon ist ja keinerlei Zugriff aufs Micro per Software gewollt.
Für uns Smart Home bastler sicher doof, aber im Bezug auf Sicherheit (zumindest was eine Steuerung abgeht) aber schon verständlich.
ich habe seit gestern Probleme mit meinem Alexa Adapter.
Lief problemlos und aus heiterem Himmel "Verbunden mit Gerät oder Dienst" ein gelbes Ausrufezeichen.
Adatper neu gestartet, in den Logs kam der Hinweis ein neues Cookie zu erstellen.
Also Seite aufgerufen, eingeloggt, in der AlexaApp genehmigt. Dann kam der Hinweis "Cookie erstellt, Browser schließen" oder so ähnlich.
Und dann gingen im Adapter alle 3 Lampen auf rot und im Log steht:Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged. Adapter seems to have issues and crashed three times in a row. Disabling!! Please start again and check logs. Terminated (ADAPTER_REQUESTED_TERMINATION): Without reasonWenn ich im Adapter das AmazonCookie zurücksetzte, sind wieder "Verbunden mit Host" und "Lebenszeichen" grün, sobald ich das Cookie setze alle 3 rot.
Hat noch jemand das Problem, oder liegt es an mir?
Tom
@tom_w Log auf Debug bitte und dann posten bitte
Ich habe jetzt den Adapter nochmal neu gestartet und jetzt läuft er wieder, ohne ein neues Cookie zu erstellen.
Keine Ahnung warum, vorher mit zwei Rechnern das selbe Problem.
Danke dass du mir helfen wolltest.Gruß
Virtuelles Gerät, indem man einen on/of state in dem ioT Adapter zu den Alexa Geräten hinzufügt?
Wie bekommt man dann mit, von welcher Alexa der Befehl kam?
@ben1983
1.) Verstehe die Frage nicht
2.) gar nicht ... das unterstützt Amazon bei den Smart Home Skills nicht -
na legt man imioT Adapter einfach ein Gerät an, welches man dann mittels dem Skill schaltet, oder wie?
mit dem Alexa2 Adapter ging das aber mal ganz gut, da die Routine des entsprechenden Geräts geschaltet wurde.
- Es ist nicht virtuell. Du legst den Datenpunkt aus deinem Gerät (Rollo, Schalter oder sonst was) im IOT Adapter mit entsprechender Funktion (Typ) an und kannst dann über Gerätesuche in der App diese finden. Deine Alexa spricht dann direkt mit dem IOT Adapter der es weiterleitet zum Datenpunkt und diesen dann steuert/abfragt.
1.b Es hat nichts mit dem Alexa Adapter hier zu tun. - Unter History im Alexa adapter im Datenpunkt Name.
@johnnybahama Ja aber bei meinem konkreten beispiel:
das Licht soll in der Farbe geändert werden.
- Bspw. Alexa, licht auf Pink.
dann gibt es noch rainbow. da verändert sich das licht aber nicht, bzw. der befehl wird nicht erkannt.
Habe also eine Routine angelegt.
2. Bspw. Alexa, Rainbow.Müsste ich als den entsprechenden effekt auf ioT legen und dann in der routine entsprechend setzen?
ich habe es aktuell so, dass ein dp gesetzt wird, der dann den effekt setzt. -
@ben1983 sagte in Alexa2 3.26.x:
ich habe es aktuell so, dass ein dp gesetzt wird, der dann den effekt setzt.Du bist hier im falschen Thema, hier geht es um den Alexa2-Adapter. Der ist da um Informationen von den Alexa-Geräten zu erhalten und diese - in möglichen Rahmen - zu steuern, z.B. Musik abspielen, Sprachnachrichten ausgeben usw.
Die Fragen die du hast passen eher zum Thema des IoT-Adapter, der ist dazu da, bestehenden oder eigene Geräte - oder virtuelle Geräte, oder auch nur einen Datenpunkt - für z.B. die Alexa Geräte bereit zu stellen.
Und zumindest für mich wäre es hilfreich wenn du mit etwas mehr Worten und Details beschreiben würdest, was genau dein Problem ist. Im passenden Thread z.B. zu
Welcher Datenpunkt? Genaue Bezeichnung/Tyo (das ist bei IoT durchaus wichtig), "der dann den Effekt setzt" - wie? ein Skript?
Ggf. mach ein eigenes Thema dazu auf, den Adapter-Thread habe ich so schnell auch gerade nicht gefunden. -
@bananajoe Ich würde es auch gerne mit dem Alexa2 Adapter lösen,
aber der Liefert mir ja nicht mehr wie früher die Daten der History. (Also, dass ich auch sehe, was gesprochen wurde und von wem. (Ja habe auch schon verucht die history zu aktivieren, aber es funktioniert 1-2 mal, dann wieder nicht)
