    3. Entwicklung
    4. Alexa2 3.26.x
    Alexa2 3.26.x
      Automatist2 @Thomas Braun last edited by
      @thomas-braun habs mal versucht:
      2024-08-24 23:46:36.892  - info: alexa2.0 (310) starting. Version 3.26.5 in /opt/iobroker/node_modules/iobroker.alexa2, node: v20.17.0, js-controller: 6.0.11
      2024-08-24 23:46:36.916  - info: alexa2.0 (310) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
      2024-08-24 23:46:36.917  - info: alexa2.0 (310) Use Override IP 192.168.2.85 for Proxy
      2024-08-24 23:46:37.015  - error: alexa2.0 (310) Error:
      2024-08-24 23:46:37.016  - error: alexa2.0 (310) Error: Please open http://192.168.2.85:38790/ with your browser and login to Amazon. The cookie will be output here after successfull login.
      2024-08-24 23:46:37.771  - info: hmip.0 (295) hmip adapter connected and ready
      2024-08-24 23:46:37.777  - error: weatherunderground.0 (280) no observations in response from https://api.weather.com/v3/wx/observations/current?apiKey=e1f10a1e78da46f5b10a1e78da96f525&geocode=0%2C0&units=m&language=de&format=json
      2024-08-24 23:46:37.806  - error: weatherunderground.0 (280) WUnderground reported an error: --/{"code":"ERR_INVALID_URL","input":""}
      2024-08-24 23:46:37.808  - error: weatherunderground.0 (280) No current observation data found in response
      2024-08-24 23:46:38.022  - error: weatherunderground.0 (280) No forecast data found in response
      2024-08-24 23:46:40.031  - info: weatherunderground.0 (280) Terminated (NO_ERROR): Without reason
      2024-08-24 23:46:40.051  - info: host.raspberrypi4 instance system.adapter.discovery.0 in version "5.0.0" started with pid 325
      2024-08-24 23:46:40.578  - info: host.raspberrypi4 instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
      2024-08-24 23:46:40.787  - info: discovery.0 (325) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
      2024-08-24 23:46:44.019  - info: host.raspberrypi4 instance system.adapter.web.0 in version "6.3.0" started with pid 352
      2024-08-24 23:46:44.850  - info: web.0 (352) starting. Version 6.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.11
      2024-08-24 23:46:44.915  - info: web.0 (352) socket.io server listening on port 8082
      2024-08-24 23:46:44.917  - info: web.0 (352) http server listening on port 8082
      2024-08-24 23:46:48.006  - info: host.raspberrypi4 instance system.adapter.vis-2.0 in version "2.9.64" started with pid 367
      2024-08-24 23:46:48.812  - info: vis-2.0 (367) starting. Version 2.9.64 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.17.0, js-controller: 6.0.11
      2024-08-24 23:46:48.836  - error: vis-2.0 (367) No license found for vis-2. Please get one on https://iobroker.net !
      2024-08-24 23:46:52.051  - info: host.raspberrypi4 instance system.adapter.socketio.0 in version "6.7.1" started with pid 382
      2024-08-24 23:46:52.832  - info: socketio.0 (382) starting. Version 6.7.1 in /opt/iobroker/node_modules/iobroker.socketio, node: v20.17.0, js-controller: 6.0.11
      2024-08-24 23:46:52.857  - info: socketio.0 (382) socket.io server listening on port 8084
      2024-08-24 23:46:56.054  - info: host.raspberrypi4 instance system.adapter.ws.0 in version "2.6.2" started with pid 403
      2024-08-24 23:46:56.870  - info: ws.0 (403) starting. Version 2.6.2 in /opt/iobroker/node_modules/iobroker.ws, node: v20.17.0, js-controller: 6.0.11
      2024-08-24 23:46:56.981  - error: ws.0 (403) port 8084 already in use
      2024-08-24 23:46:56.982  - info: ws.0 (403) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-08-24 23:46:57.490  - info: ws.0 (403) terminating http server on port 8084
      2024-08-24 23:46:57.502  - info: host.raspberrypi4 instance system.adapter.ws.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2024-08-24 23:46:57.502  - info: host.raspberrypi4 Do not restart adapter system.adapter.ws.0 because desired by instance
      2024-08-24 23:47:00.013  - info: host.raspberrypi4 instance system.adapter.tradfri.0 in version "3.1.3" started with pid 430
      2024-08-24 23:47:00.775  - info: tradfri.0 (430) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.tradfri, node: v20.17.0, js-controller: 6.0.11
      2024-08-24 23:47:00.870  - info: tradfri.0 (430) Discovering the gateway automatically...
      2024-08-24 23:47:00.944  - info: tradfri.0 (430) Found gateway gw-b072bf27b5f5 at 192.168.2.136
      2024-08-24 23:47:01.141  - info: tradfri.0 (430) got all devices: [65548,65551,65553,65546,65556,65554,65558,65559,65549,65541,65540,65537,65550,65557]
      2024-08-24 23:47:01.192  - warn: tradfri.0 (430) found unknown property with key 15019
      2024-08-24 23:47:01.192  - warn: tradfri.0 (430) object was: {"3":{"0":"IKEA of Sweden","1":"TRADFRI SHORTCUT Button","2":"","3":"24.4.6","6":3,"7":4550,"8":0,"9":90},"5750":0,"9001":"TRADFRI SHORTCUT Button","9002":1625985939,"9003":65551,"9019":1,"9020":1724496436,"9054":0,"15009":[{"9003":0}],"15019":{"9039":224728,"9250":[{"9251":1,"9252":[{"9253":1,"9254":1,"9255":224728},{"9253":2,"9254":1,"9255":224730},{"9253":3,"9254":1,"9255":224729}]}]}}
      2024-08-24 23:47:01.197  - warn: tradfri.0 (430) found unknown property with key 15019
      2024-08-24 23:47:01.197  - warn: tradfri.0 (430) object was: {"3":{"0":"IKEA of Sweden","1":"TRADFRI SHORTCUT Button","2":"","3":"24.4.6","6":3,"7":4550,"8":0,"9":90},"5750":0,"9001":"Shortcut-Taste 2","9002":1666879445,"9003":65553,"9019":1,"9020":1724508036,"9054":0,"15009":[{"9003":0}],"15019":{"9039":224731,"9250":[{"9251":1,"9252":[{"9253":1,"9254":1,"9255":224731},{"9253":2,"9254":0,"9255":0},{"9253":3,"9254":1,"9255":224732}]}]}}
      2024-08-24 23:47:01.221  - info: tradfri.0 (430) received all devices
      2024-08-24 23:47:01.225  - info: tradfri.0 (430) got all groups: [165545,165538,165541,165537,165539,165544,165542]
      2024-08-24 23:47:01.386  - info: tradfri.0 (430) got all scenes in group 165537: [224706,224707,224708,224709]
      2024-08-24 23:47:01.397  - info: tradfri.0 (430) got all scenes in group 165538: [224714,224715,224716,224717]
      2024-08-24 23:47:01.417  - info: tradfri.0 (430) got all scenes in group 165539: [224718,224728,224729,224730,224731,224732,224733]
      2024-08-24 23:47:01.437  - info: tradfri.0 (430) got all scenes in group 165541: []
      2024-08-24 23:47:01.459  - info: tradfri.0 (430) got all scenes in group 165542: []
      2024-08-24 23:47:01.481  - info: tradfri.0 (430) got all scenes in group 165544: []
      2024-08-24 23:47:01.491  - info: tradfri.0 (430) got all scenes in group 165545: []
      2024-08-24 23:47:01.508  - info: tradfri.0 (430) updating possible scenes for group 165537: ["224706"]
      2024-08-24 23:47:01.525  - info: tradfri.0 (430) updating possible scenes for group 165537: ["224706","224707"]
      2024-08-24 23:47:01.542  - info: tradfri.0 (430) updating possible scenes for group 165537: ["224706","224707","224708"]
      2024-08-24 23:47:01.574  - info: tradfri.0 (430) updating possible scenes for group 165537: ["224706","224707","224708","224709"]
      2024-08-24 23:47:01.589  - info: tradfri.0 (430) updating possible scenes for group 165538: ["224714"]
      2024-08-24 23:47:01.604  - info: tradfri.0 (430) updating possible scenes for group 165538: ["224714","224715"]
      2024-08-24 23:47:01.620  - info: tradfri.0 (430) updating possible scenes for group 165538: ["224714","224715","224716"]
      2024-08-24 23:47:01.633  - info: tradfri.0 (430) updating possible scenes for group 165538: ["224714","224715","224716","224717"]
      2024-08-24 23:47:01.651  - info: tradfri.0 (430) updating possible scenes for group 165539: ["224718"]
      2024-08-24 23:47:01.681  - info: tradfri.0 (430) updating possible scenes for group 165539: ["224718","224728"]
      2024-08-24 23:47:01.688  - info: tradfri.0 (430) updating possible scenes for group 165539: ["224718","224728","224729"]
      2024-08-24 23:47:01.696  - info: tradfri.0 (430) updating possible scenes for group 165539: ["224718","224728","224729","224730"]
      2024-08-24 23:47:01.716  - info: tradfri.0 (430) updating possible scenes for group 165539: ["224718","224728","224729","224730","224731"]
      2024-08-24 23:47:01.728  - info: tradfri.0 (430) updating possible scenes for group 165539: ["224718","224728","224729","224730","224731","224732"]
      2024-08-24 23:47:01.741  - info: tradfri.0 (430) received all groups and scenes
      2024-08-24 23:47:01.742  - info: tradfri.0 (430) updating possible scenes for group 165539: ["224718","224728","224729","224730","224731","224732","224733"]
      2024-08-24 23:48:20.309  - info: admin.0 (158) failed connection to socket.io from ::ffff:192.168.2.75: Passport was not initialized
      2024-08-24 23:48:25.085  - info: admin.0 (158) ==> Connected system.user.admin from ::ffff:192.168.2.75
      2024-08-24 23:48:33.632  - info: admin.0 (158) ==> Connected system.user.admin from ::ffff:192.168.2.75
      2024-08-24 23:48:47.914  - error: alexa2.0 (310) Error: Unexpected end of JSON input
      2024-08-24 23:48:47.915  - info: alexa2.0 (310) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2024-08-24 23:48:48.448  - info: host.raspberrypi4 instance system.adapter.alexa2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2024-08-24 23:48:48.449  - info: host.raspberrypi4 Restart adapter system.adapter.alexa2.0 because enabled
      2024-08-24 23:48:49.814  - info: host.raspberrypi4 instance system.adapter.alexa2.0 in version "3.26.5" started with pid 547
      2024-08-24 23:48:50.618  - info: alexa2.0 (547) starting. Version 3.26.5 in /opt/iobroker/node_modules/iobroker.alexa2, node: v20.17.0, js-controller: 6.0.11
      2024-08-24 23:48:50.637  - info: alexa2.0 (547) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
      2024-08-24 23:48:50.643  - error: alexa2.0 (547) Adapter seems to have issues and crashed three times in a row. Disabling!! Please start again and check logs.
      2024-08-24 23:48:51.644  - info: alexa2.0 (547) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-08-24 23:48:52.164  - info: host.raspberrypi4 instance system.adapter.alexa2.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2024-08-24 23:48:52.164  - info: host.raspberrypi4 Do not restart adapter system.adapter.alexa2.0 because desired by instance
      2024-08-24 23:49:25.150  - info: admin.0 (158) <== Disconnect system.user.admin from ::ffff:192.168.2.75
        Thomas Braun Most Active @Automatist2 last edited by
        @automatist2 sagte in Alexa2 3.26.x:
        Was ist denn mit den anderen Adaptern los?
        Lass da erstmal Ruhe einkehren.
          @thomas-braun hab mal 2 Adapter die ich aktuell nicht nutze deinstalliert und nochmal bei Amazon eingeloggt:
          2024-08-25 00:57:01.604  - warn: web.0 (352) setTimeout called, but adapter is shutting down
          2024-08-25 00:57:01.611  - info: host.raspberrypi4 iobroker Adapter "system.adapter.web.0" restarted.
          2024-08-25 00:57:01.613  - info: host.raspberrypi4 stopInstance system.adapter.web.0 send kill signal
          2024-08-25 00:57:01.616  - info: web.0 (352) Got terminate signal TERMINATE_YOURSELF
          2024-08-25 00:57:01.658  - info: host.raspberrypi4 stopInstance system.adapter.web.0 send kill signal
          2024-08-25 00:57:02.105  - info: web.0 (352) terminating
          2024-08-25 00:57:02.106  - info: web.0 (352) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-08-25 00:57:02.614  - info: host.raspberrypi4 stopInstance timeout system.adapter.web.0 killing pid 352
          2024-08-25 00:57:02.624  - info: host.raspberrypi4 instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-08-25 00:57:02.626  - info: host.raspberrypi4 iobroker exit 0
          2024-08-25 00:57:05.987  - info: host.raspberrypi4 instance system.adapter.web.0 in version "6.3.0" started with pid 3910
          2024-08-25 00:57:06.810  - info: web.0 (3910) starting. Version 6.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.11
          2024-08-25 00:57:06.874  - info: web.0 (3910) socket.io server listening on port 8082
          2024-08-25 00:57:06.877  - info: web.0 (3910) http server listening on port 8082
          2024-08-25 00:57:22.162  - info: host.raspberrypi4 iobroker del telegram
          2024-08-25 00:57:22.918  - info: host.raspberrypi4 iobroker Delete adapter "telegram"
          2024-08-25 00:57:22.923  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 1 instances of telegram
          2024-08-25 00:57:22.935  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 2 meta of telegram
          2024-08-25 00:57:22.936  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 1 adapter for telegram
          2024-08-25 00:57:22.942  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 1 channels of telegram
          2024-08-25 00:57:22.946  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 18 states of telegram
          2024-08-25 00:57:22.950  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 14 states of system.adapter.telegram
          2024-08-25 00:57:22.952  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 2 states (io.telegram.*) from states
          2024-08-25 00:57:22.959  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 1 states (system.adapter.telegram.*) from states
          2024-08-25 00:57:23.561  - info: host.raspberrypi4 iobroker host.raspberrypi4 file telegram.admin deleted
          2024-08-25 00:57:23.565  - info: host.raspberrypi4 iobroker host.raspberrypi4 object telegram deleted
          2024-08-25 00:57:23.568  - info: host.raspberrypi4 iobroker host.raspberrypi4 object telegram.admin deleted
          2024-08-25 00:57:23.569  - info: host.raspberrypi4 iobroker host.raspberrypi4 Deleting 38 object(s).
          2024-08-25 00:57:23.614  - info: host.raspberrypi4 iobroker host.raspberrypi4 Deleting 3 state(s).
          2024-08-25 00:57:23.659  - info: host.raspberrypi4 object deleted system.adapter.telegram.0
          2024-08-25 00:57:25.515  - info: host.raspberrypi4 iobroker removed 77 packages in 2s
          2024-08-25 00:57:25.516  - info: host.raspberrypi4 iobroker 119 packages are looking for funding  run `npm fund` for details
          2024-08-25 00:57:26.533  - info: host.raspberrypi4 iobroker exit 0
          2024-08-25 00:58:48.235  - info: admin.0 (158) ==> Connected system.user.admin from ::ffff:192.168.2.170
          2024-08-25 00:58:53.263  - info: admin.0 (158) <== Disconnect system.user.admin from ::ffff:192.168.2.170
          2024-08-25 00:58:57.955  - info: host.raspberrypi4 instance system.adapter.alexa2.0 in version "3.26.5" started with pid 4055
          2024-08-25 00:58:58.750  - info: alexa2.0 (4055) starting. Version 3.26.5 in /opt/iobroker/node_modules/iobroker.alexa2, node: v20.17.0, js-controller: 6.0.11
          2024-08-25 00:58:58.769  - info: alexa2.0 (4055) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
          2024-08-25 00:58:58.770  - info: alexa2.0 (4055) Use Override IP 192.168.2.85 for Proxy
          2024-08-25 00:58:58.860  - error: alexa2.0 (4055) Error:
          2024-08-25 00:58:58.860  - error: alexa2.0 (4055) Error: Please open http://192.168.2.85:38790/ with your browser and login to Amazon. The cookie will be output here after successfull login.
          2024-08-25 00:59:05.384  - info: admin.0 (158) ==> Connected system.user.admin from ::ffff:192.168.2.170
          2024-08-25 01:00:13.243  - error: alexa2.0 (4055) Error: Unexpected end of JSON input
          2024-08-25 01:00:13.245  - info: alexa2.0 (4055) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2024-08-25 01:00:13.771  - info: host.raspberrypi4 instance system.adapter.alexa2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          2024-08-25 01:00:13.772  - info: host.raspberrypi4 Restart adapter system.adapter.alexa2.0 because enabled
          2024-08-25 01:00:15.177  - info: host.raspberrypi4 instance system.adapter.alexa2.0 in version "3.26.5" started with pid 4130
          2024-08-25 01:00:15.964  - info: alexa2.0 (4130) starting. Version 3.26.5 in /opt/iobroker/node_modules/iobroker.alexa2, node: v20.17.0, js-controller: 6.0.11
          2024-08-25 01:00:15.983  - info: alexa2.0 (4130) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
          2024-08-25 01:00:15.986  - error: alexa2.0 (4130) Adapter seems to have issues and crashed three times in a row. Disabling!! Please start again and check logs.
          2024-08-25 01:00:16.987  - info: alexa2.0 (4130) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-08-25 01:00:17.505  - info: host.raspberrypi4 instance system.adapter.alexa2.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
          2024-08-25 01:00:17.505  - info: host.raspberrypi4 Do not restart adapter system.adapter.alexa2.0 because desired by instance
          2024-08-25 01:00:28.314  - info: admin.0 (158) <== Disconnect system.user.admin from ::ffff:192.168.2.170
            A Former User @Automatist2 last edited by A Former User
            @automatist2
            Warum machst Du nicht das, was im Log zum x.Mal steht?
              apollon77 last edited by
              Am besten mal debug log aktivieren das man sieht was er tut. Das log dann posten bitte.
                reddddich last edited by
                Ich hatte denselben Fehler. In den Proxy Einstellungen des Adapters den Punkt "Eigene IP oder Hostname für den Proxy-Link" mal überprüfen
                  spike2 last edited by
                  Gibt es einen Datenpunkt der den Status vom Mikrofon anzeigt?
                  Man kann ja per Hardwaretaste am Gerät aktivieren oder deaktivieren.
                  padrino 1 Reply Last reply Reply Quote 0
                  • padrino
                    padrino Most Active @spike2 last edited by padrino
                    @spike2
                    Nein gibt es nicht.
                    Von Amazon ist ja keinerlei Zugriff aufs Micro per Software gewollt.
                    Für uns Smart Home bastler sicher doof, aber im Bezug auf Sicherheit (zumindest was eine Steuerung abgeht) aber schon verständlich. 😌
                      Tom_W last edited by
                      ich habe seit gestern Probleme mit meinem Alexa Adapter.
                      Lief problemlos und aus heiterem Himmel "Verbunden mit Gerät oder Dienst" ein gelbes Ausrufezeichen.
                      Adatper neu gestartet, in den Logs kam der Hinweis ein neues Cookie zu erstellen.
                      Also Seite aufgerufen, eingeloggt, in der AlexaApp genehmigt. Dann kam der Hinweis "Cookie erstellt, Browser schließen" oder so ähnlich.
                      Und dann gingen im Adapter alle 3 Lampen auf rot und im Log steht:
                      Wenn ich im Adapter das AmazonCookie zurücksetzte, sind wieder "Verbunden mit Host" und "Lebenszeichen" grün, sobald ich das Cookie setze alle 3 rot.
                      Hat noch jemand das Problem, oder liegt es an mir?
                      Tom
                      da_Woody apollon77 2 Replies Last reply Reply Quote 0
                      • da_Woody
                        da_Woody @Tom_W last edited by
                        @tom_w sagte in Alexa2 3.26.x:
                        oder so ähnlich
                        gute beschreibung...
                          apollon77 @Tom_W last edited by
                          @tom_w Log auf Debug bitte und dann posten bitte
                            Tom_W @apollon77 last edited by
                            @apollon77
                            Ich habe jetzt den Adapter nochmal neu gestartet und jetzt läuft er wieder, ohne ein neues Cookie zu erstellen.
                            Keine Ahnung warum, vorher mit zwei Rechnern das selbe Problem.
                            Danke dass du mir helfen wolltest.
                            • Ben1983
                              Ben1983 @apollon77 last edited by
                              @apollon77
                              1. Virtuelles Gerät, indem man einen on/of state in dem ioT Adapter zu den Alexa Geräten hinzufügt?
                              2. Wie bekommt man dann mit, von welcher Alexa der Befehl kam?
                                apollon77 @Ben1983 last edited by
                                @ben1983
                                1.) Verstehe die Frage nicht
                                2.) gar nicht ... das unterstützt Amazon bei den Smart Home Skills nicht
                                • Ben1983
                                  @apollon77
                                  1. na legt man imioT Adapter einfach ein Gerät an, welches man dann mittels dem Skill schaltet, oder wie?
                                  2. mit dem Alexa2 Adapter ging das aber mal ganz gut, da die Routine des entsprechenden Geräts geschaltet wurde.
                                    JohnnyBahama @Ben1983 last edited by JohnnyBahama
                                    @ben1983
                                    1. Es ist nicht virtuell. Du legst den Datenpunkt aus deinem Gerät (Rollo, Schalter oder sonst was) im IOT Adapter mit entsprechender Funktion (Typ) an und kannst dann über Gerätesuche in der App diese finden. Deine Alexa spricht dann direkt mit dem IOT Adapter der es weiterleitet zum Datenpunkt und diesen dann steuert/abfragt.
                                      1.b Es hat nichts mit dem Alexa Adapter hier zu tun.
                                    2. Unter History im Alexa adapter im Datenpunkt Name.
                                    • Ben1983
                                      Ben1983 @JohnnyBahama last edited by
                                      @johnnybahama Ja aber bei meinem konkreten beispiel:
                                      das Licht soll in der Farbe geändert werden.
                                      1. Bspw. Alexa, licht auf Pink.
                                      dann gibt es noch rainbow. da verändert sich das licht aber nicht, bzw. der befehl wird nicht erkannt.
                                      Habe also eine Routine angelegt.
                                      2. Bspw. Alexa, Rainbow.
                                      Müsste ich als den entsprechenden effekt auf ioT legen und dann in der routine entsprechend setzen?
                                      ich habe es aktuell so, dass ein dp gesetzt wird, der dann den effekt setzt.
                                      • BananaJoe
                                        BananaJoe Most Active @Ben1983 last edited by
                                        @ben1983 sagte in Alexa2 3.26.x:
                                        Du bist hier im falschen Thema, hier geht es um den Alexa2-Adapter. Der ist da um Informationen von den Alexa-Geräten zu erhalten und diese - in möglichen Rahmen - zu steuern, z.B. Musik abspielen, Sprachnachrichten ausgeben usw.
                                        Die Fragen die du hast passen eher zum Thema des IoT-Adapter, der ist dazu da, bestehenden oder eigene Geräte - oder virtuelle Geräte, oder auch nur einen Datenpunkt - für z.B. die Alexa Geräte bereit zu stellen.
                                        Und zumindest für mich wäre es hilfreich wenn du mit etwas mehr Worten und Details beschreiben würdest, was genau dein Problem ist. Im passenden Thread z.B. zu
                                        Welcher Datenpunkt? Genaue Bezeichnung/Tyo (das ist bei IoT durchaus wichtig), "der dann den Effekt setzt" - wie? ein Skript?
                                        Ggf. mach ein eigenes Thema dazu auf, den Adapter-Thread habe ich so schnell auch gerade nicht gefunden.
                                        • Ben1983
                                          Ben1983 @BananaJoe last edited by
                                          @bananajoe Ich würde es auch gerne mit dem Alexa2 Adapter lösen,
                                          aber der Liefert mir ja nicht mehr wie früher die Daten der History. (Also, dass ich auch sehe, was gesprochen wurde und von wem. (Ja habe auch schon verucht die history zu aktivieren, aber es funktioniert 1-2 mal, dann wieder nicht)
                                          • BananaJoe
                                            @ben1983 also bei mir Funktioniert das mit der History. Aber verzögert. Ich habe da aber nur ein Szenario wo ich es verwende: "Alexa, schalte Fernseher aus".
                                            In der App gibt es Routine welche dann nur "ok" zurückmeldet, über den Alexa2 Adapter bekomme ich raus das es gesagt wurde und welches Gerät es gehört hat.
                                            Das klappt, aber verzögert, es dauert 2 bis 5 Sekunden bis der Fernseher ausgeht.
                                            Für etwas wie du vorhast, ist das nichts.
                                            Da bräuchtest du ein Gerät welches dann dem Raum zugeordnet ist. Wobei ich noch nicht rausbekommen habe wie man im IoT auch eine Farbsteuerung einrichtet (entsprechendes Thema habe ich gerade eröffnet)
                                            302
                                            76315
