    4. Kein Zugriff auf Admin Oberfläche
    • N
      nousefor82 last edited by nousefor82
      ich komme auch nicht mehr auf die Admin Oberfläche.
      Ich habe gestern den Admin upgedatet.
      C:\Users\Jörg\ioBroker>node -v
      v10.19.0
      C:\Users\Jörg\ioBroker>npm -v
      6.4.1
      C:\Users\Jörg\ioBroker> npm install iobroker.js-controller
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
      > iobroker.js-controller@1.5.14 preinstall C:\Users\Jörg\ioBroker\node_modules\iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.4.1
      npm version >= 5: disabling package-lock
      > unix-dgram@0.2.3 install C:\Users\Jörg\ioBroker\node_modules\unix-dgram
      > node-gyp rebuild
      C:\Users\Jörg\ioBroker\node_modules\unix-dgram>if not defined npm_config_node_gyp (node "C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
      gyp ERR! configure error
      gyp ERR! stack Error: Can't find Python executable "python2.7", you can set the PYTHON env variable.
      gyp ERR! stack     at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:484:19)
      gyp ERR! stack     at PythonFinder.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:509:16)
      gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:284:29
      gyp ERR! stack     at FSReqWrap.oncomplete (fs.js:153:21)
      gyp ERR! System Windows_NT 10.0.17763
      gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
      gyp ERR! cwd C:\Users\Jörg\ioBroker\node_modules\unix-dgram
      gyp ERR! node -v v10.19.0
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      > iobroker.js-controller@1.5.14 install C:\Users\Jörg\ioBroker\node_modules\iobroker.js-controller
      > node iobroker.js setup first
      npm WARN enoent ENOENT: no such file or directory, open 'C:\Users\Jörg\ioBroker\node_modules\tmp\package.json'
      npm WARN enoent ENOENT: no such file or directory, open 'C:\Users\Jörg\ioBroker\node_modules\iobroker.zigbee\node_modules\cc-znp\package.json'
      npm WARN ws@7.2.1 requires a peer of bufferutil@^4.0.1 but none is installed. You must install peer dependencies yourself.
      npm WARN ws@7.2.1 requires a peer of utf-8-validate@^5.0.2 but none is installed. You must install peer dependencies yourself.
      npm WARN onvif-snapshot@1.0.2 requires a peer of onvif@^0.5.5 but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules\osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules\unix-dgram):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-gyp rebuild`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      + iobroker.js-controller@1.5.14
      added 35 packages from 20 contributors, removed 173 packages, updated 40 packages, moved 15 packages and audited 833 packages in 77.298s
      found 17 vulnerabilities (11 low, 6 high)
        run `npm audit fix` to fix them, or `npm audit` for details
      C:\Users\Jörg\ioBroker>node node_modules/iobroker.js-controller/controller.js --logs
      2020-02-12 21:47:34.750  - info: host.DESKTOP-P9BVQ1I iobroker.js-controller version 1.5.14 js-controller starting
      2020-02-12 21:47:34.756  - info: host.DESKTOP-P9BVQ1I Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
      2020-02-12 21:47:34.757  - info: host.DESKTOP-P9BVQ1I hostname: DESKTOP-P9BVQ1I, node: v10.19.0
      2020-02-12 21:47:34.772  - info: host.DESKTOP-P9BVQ1I ip addresses: 2002:bcc2:441c:0:65e2:1607:2b76:8b96 2002:bcc2:441c:0:9ce6:2d48:78e4:d66b fe80::65e2:1607:2b76:8b96 192.168.188.60
      2020-02-12 21:47:35.166  - info: host.DESKTOP-P9BVQ1I  inMem-states listening on port 9000
      2020-02-12 21:47:36.256  - info: host.DESKTOP-P9BVQ1I  inMem-objects listening on port 9001
      2020-02-12 21:47:36.272  - error: Another instance is running or some application uses port!
      2020-02-12 21:47:36.274  - error: uncaught exception: listen EADDRINUSE: address already in use 127.0.0.1:9000
      2020-02-12 21:47:36.286  - info: host.DESKTOP-P9BVQ1I terminated
      2020-02-12 21:47:36.331  - info: iobroker _restart
      2020-02-12 21:47:36.353  - info: host.DESKTOP-P9BVQ1I InMemoryDB connected
      2020-02-12 21:47:36.496  - info: host.DESKTOP-P9BVQ1I 66 instances found
      host.DESKTOP-P9BVQ1I check instance "system.adapter.admin.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.discovery.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.web.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.vis.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.hue.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-hqwidgets.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.lupusec.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.javascript.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.alexa2.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.cloud.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.daswetter.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.tr-064.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.yr.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.dwd.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-jqui-mfd.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-weather.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.sonos.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.sayit.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.feiertage.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.spotify-premium.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-timeandweather.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-colorpicker.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.ical.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.shelly.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.pushover.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.yamaha.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.telegram.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.text2command.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-players.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.mihome-vacuum.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.harmony.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-metro.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-fancyswitch.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-history.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-google-fonts.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.ical.1" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.javascript.1" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.synology.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.hm-rpc.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.hm-rega.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.hm-rpc.1" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.fullybrowser.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.vis-justgage.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.unifi.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.node-red.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.backitup.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.pollenflug.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.info.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.zigbee.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.mihome.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.iqontrol.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.iot.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.onvif.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.trashschedule.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.parser.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.ical.2" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.simple-api.0" for host "DESKTOP-P9BVQ1I"
      host.DESKTOP-P9BVQ1I check instance "system.adapter.yahka.0" for host "DESKTOP-P9BVQ1I"
      2020-02-12 21:47:36.829  - info: host.DESKTOP-P9BVQ1I starting 55 instances
      listen EADDRINUSE: address already in use 127.0.0.1:9001
      Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
          at Server.setupListenHandle [as _listen2] (net.js:1280:14)
          at listenInCluster (net.js:1328:12)
          at doListen (net.js:1461:7)
          at process._tickCallback (internal/process/next_tick.js:63:19)
          at Function.Module.runMain (internal/modules/cjs/loader.js:834:11)
          at startup (internal/bootstrap/node.js:283:19)
          at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
      System: Win10
      Mit der Bitte um Hilfe,
      Jörg!
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
      • AlCalzone
        AlCalzone Developer @nousefor82 last edited by
        @nousefor82 sagte in Kein Zugriff auf Admin Oberfläche:
        ==> https://www.npmjs.com/package/windows-build-tools installieren.
        • N
          nousefor82 @AlCalzone last edited by
          @AlCalzone
          Servus, danke.
          Leider hat "der" hingeschrieben, dass python bereits installiert ist.
          Auf 8081 lässt sich immer noch nicht zugreifen.
          VG
          • N
            Noch jemand eine Idee, woran es liegen könnte, dass ich plötzlich nicht mehr auf die Admin Oberfläche zugreifen kann?
              arteck Developer Most Active @nousefor82 last edited by
              @nousefor82 du hast eine manell installierte iobroker version.. da können wir lange suchen..
              nimm den installer und portiere deine jetzige in die neue rein.. fertig
              • N
                nousefor82 @arteck last edited by nousefor82
                @arteck
                hab ich probiert...wurde mit eine Fehlermeldung beendet:
                Fehler beim Ausführen eines Post - Installationsschrittes.
                Die Installation wird möglicherweise nicht korrekt abgeschlossen.
                Kritischer Installationsfehler. Keine aktive ioBroker Admin-Instanz auf Port 8091.
                Abbruch der Installation.
                Danke!
                • N
                  Oh Mann...das nervt grad.
                  Ich habe mal gelesen, dass man über die objects.json die scripte extrahieren kann.
                  Habe das mal probiert bin mir aber nicht sicher, von wo bis wo die im code aktuell gehen, bzw. was ich da kopieren muss.
                  Ein Neuinstallation läuft durch...hab dann probiert über backitup ein backup einzuspielen (Stand, bei dem noch alles funktioniert hatte), jetzt komm ich auch nicht mehr auf die neue Admin - Oberfläche.
                  Noch jemand eine Idee, wie ich auf die 8081 kommen könnte?
                  Vielen Dank!
                  • N
                    So, komme wieder drauf...weiß nur nicht warum.
                    Habe folgendes eingegeben mit nachfolgenden Fehlermeldungen...trotzdem kann ich wieder zugreifen...
                    C:\Users\Jörg\ioBroker>iobroker stop
                    C:\Users\Jörg\ioBroker>node node_modules/iobroker.js-controller/iobroker.js stop
                    iobroker controller daemon is not running
                    C:\Users\Jörg\ioBroker>ps auxww|grep io
                    Der Befehl "ps" ist entweder falsch geschrieben oder
                    konnte nicht gefunden werden.
                    C:\Users\Jörg\ioBroker>iobroker upgrade self
                    C:\Users\Jörg\ioBroker>node node_modules/iobroker.js-controller/iobroker.js upgrade self
                    Update js-controller from @1.5.14 to @2.2.8
                    NPM version: 6.4.1
                    npm install iobroker.js-controller@2.2.8 --unsafe-perm --production --save --prefix "C:/Users/Jörg/ioBroker" (System call)
                    npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
                    gyp ERR! cwd C:\Users\Jörg\ioBroker\node_modules\iobroker.js-controller\node_modules\unix-dgram
                    gyp ERR! not ok
                    gyp ERR! cwd C:\Users\Jörg\ioBroker\node_modules\iobroker.js-controller\node_modules\diskusage
                    gyp ERR! not ok
                    npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules\iobroker.js-controller\node_modules\fsevents):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.3 (node_modules\iobroker.js-controller\node_modules\unix-dgram):
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.3 install: `node-gyp rebuild`
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@1.1.3 (node_modules\iobroker.js-controller\node_modules\diskusage):
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@1.1.3 install: `node-gyp rebuild`
                    Host "DESKTOP-P9BVQ1I" (win32) updated
                    Starting node restart.js
                    C:\Users\Jörg\ioBroker>iobroker upgrade admin
                    C:\Users\Jörg\ioBroker>node node_modules/iobroker.js-controller/iobroker.js upgrade admin
                    Adapter "admin"          is not installed.
                    C:\Users\Jörg\ioBroker>iobroker install admin
                    C:\Users\Jörg\ioBroker>node node_modules/iobroker.js-controller/iobroker.js install admin
                    adapter "admin" already installed. Use "upgrade" to upgrade to a newer version.
                    • N
                      Das war wohl nix....kein Zugriff mehr möglich. Aber solang ich den Zugriff hatte, habe ich per Hand sämtliche Scripte etc. gesichert.
                      Habe nun komplett neu installiert. LEider noch die Version 1.5.14 .... trau mich nicht mehr mir
                      abzudaten...
                      • rweise
                        rweise last edited by rweise
                        Bei mir 2 Installationen mit 7.2.1 kein Zugriff mehr. Der IOBroker hat aber im Hintergrund anstandslos gearbeitet. Die Lösung war ein Downgrade zu 7.2.0. hat auf beiden Geräten fuktioniert. Natürlich dann in der Konsole.
                        1. cd /opt/iobroker
                        2. iobroker stop
                        3. npm install iobroker.admin@7.2.0 --production
                        4. iobroker start
                        und schon ging es wieder 🙂
                        Ähm, hab es erst außerhalb von /opt/iobroker versucht. Dann macht er aber kein Downgrade...
                          Thomas Braun Most Active @rweise last edited by
                          @rweise sagte in Kein Zugriff auf Admin Oberfläche:
                          Du sieht schon, dass der Thread 4 Jahre alt ist?
                          Und du verwendest die falschen Befehle im falschen Verzeichnis...
                          Mit
                          iob upgrade admin@7.20.0
                          hätte es funktioniert. Und wo ist das Log von deinem Beta-Testing?
                          rweise 1 Reply Last reply Reply Quote 0
                          • rweise
                            rweise @Thomas Braun last edited by
                            Sorry, hab den falschen Thread erwischt...
                            admin
                            2348
