    4. Nach Update Anmeldung nicht mehr möglich
      Eaglefire last edited by
      Hab ich gemacht, komme aber immer noch nicht auf das WebIF.
      ```bash
      Skript v.2024-08-12
      *** BASE SYSTEM ***
       Static hostname: IoBroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.8.4-3-pve
          Architecture: x86-64
      OS is similar to:
      model name      : Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       09:58:14 up 1 min,  2 users,  load average: 4.16, 3.63, 3.51
      CPU threads: 2
      *** Time and Time Zones ***
                     Local time: Sun 2024-10-06 09:58:14 CEST
                 Universal time: Sun 2024-10-06 07:58:14 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      eagle
      HOME=/home/eagle
      GROUPS=eagle sudo users iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            5.4G        1.2G        3.9G        114K        269M        4.2G
      Swap:           536M          0B        536M
      Total:          5.9G        1.2G        4.4G
      Active iob-Instances:   10
               5120 M total memory
               1132 M used memory
               1221 M active memory
                101 M inactive memory
               3731 M free memory
                  0 M buffer memory
                256 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      top - 09:58:15 up 1 min,  2 users,  load average: 4.16, 3.63, 3.51
      Tasks:  42 total,   1 running,  41 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   5120.0 total,   3729.4 free,   1133.8 used,    256.9 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3986.2 avail Mem
      *** FAILED SERVICES ***
        UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--101--disk--0 ext4       30G  5.6G   23G  21% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs   16G     0   16G   0% /dev/tty
      tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
      tmpfs                            tmpfs     6.3G  108K  6.3G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      dmesg: read kernel buffer failed: Operation not permitted
      Show mounted filesystems:
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
      /var:
      755M    /var/
      498M    /var/cache
      494M    /var/cache/apt
      419M    /var/cache/apt/archives
      146M    /var/lib
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      39M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      845M    /opt/iobroker/iobroker-data/
      740M    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
      19M     /opt/iobroker/iobroker-data/objects.jsonl
      12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
      11M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.c9e0f545.js
      9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.0
      /usr/bin/node           v20.18.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.18.0-1nodesource1
        Candidate: 20.18.0-1nodesource1
        Version table:
       *** 20.18.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.2.1
      javascript:     8.8.3
      nodejs modules from github:     0
      Adapter State
        system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : IoBroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
        system.adapter.bydhvs.0                 : bydhvs                : IoBroker                                 -  enabled
        system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
        system.adapter.fronius-solarweb.0       : fronius-solarweb      : IoBroker                                 -  enabled
        system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : IoBroker                                 -  enabled
      + system.adapter.fronius.0                : fronius               : IoBroker                                 -  enabled
      + system.adapter.harmony.0                : harmony               : IoBroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
        system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
        system.adapter.modbus.0                 : modbus                : IoBroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : IoBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.tibberlink.0             : tibberlink            : IoBroker                                 -  enabled
        system.adapter.yahka.0                  : yahka                 : IoBroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 7.2.1    , installed 7.2.1
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
      Adapter    "fronius"      : 2.1.1    , installed 2.1.1
      Adapter    "fronius-solarweb": 0.1.0 , installed 0.1.0
      Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.3
      Adapter    "harmony"      : 1.5.0    , installed 1.5.0
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "iot"          : 3.4.2    , installed 3.4.2
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
      Adapter    "tibberlink"   : 3.5.1    , installed 3.5.1
      Adapter    "yahka"        : 1.0.9    , installed 1.0.9
      Objects and States
      Objects:        9954
      States:         8247
      Hit:1 http://security.debian.org bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.2.92:2001       0.0.0.0:*               LISTEN      1000       79731465   388/io.hm-rpc.0
      tcp        0      0 192.168.2.92:2010       0.0.0.0:*               LISTEN      1000       79730577   418/io.hm-rpc.1
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       79730991   132/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       79730006   132/iobroker.js-con
      tcp        0      0 0.0.0.0:40353           0.0.0.0:*               LISTEN      1000       79732933   556/io.yahka.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          79727486   1/init
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       79732806   492/io.shelly.0
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          79730047   296/master
      tcp6       0      0 :::61991                :::*                    LISTEN      1000       79732768   470/io.harmony.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          79727488   1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          79729833   1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          79730048   296/master
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          79727487   1/init
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       79732938   556/io.yahka.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       79732937   556/io.yahka.0
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       79732769   470/io.harmony.0
      udp6       0      0 :::111                  :::*                                0          79727489   1/init
          at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
          at SocketAdmin._initSocket (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
          at /opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
          at /opt/iobroker/node_modules/@iobroker/ws-server/dist/index.js:246:64
          at Array.forEach (<anonymous>)
          at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/@iobroker/ws-server/dist/index.js:246:50)
          at WebSocketServer.emit (node:events:519:28)
          at WebSocketServer.emit (node:domain:488:12)
      2024-10-06 09:58:11.056  - error: admin.0 (584) Parameter "id" needs to be of type "string" but type "number" has been passed
      2024-10-06 09:58:11.067  - info: admin.0 (584) terminating http server on port 8081
      2024-10-06 09:58:11.068  - warn: admin.0 (584) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2024-10-06 09:58:11.123  - error: host.IoBroker Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
      2024-10-06 09:58:11.123  - error: host.IoBroker Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
      2024-10-06 09:58:11.123  - error: host.IoBroker Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1373:19)
      2024-10-06 09:58:11.123  - error: host.IoBroker Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
      2024-10-06 09:58:11.123  - error: host.IoBroker Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
      2024-10-06 09:58:11.124  - error: host.IoBroker Caught by controller[0]:     at /opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
      2024-10-06 09:58:11.124  - error: host.IoBroker Caught by controller[0]:     at /opt/iobroker/node_modules/@iobroker/ws-server/dist/index.js:246:64
      2024-10-06 09:58:11.124  - error: host.IoBroker Caught by controller[0]:     at Array.forEach (<anonymous>)
      2024-10-06 09:58:11.124  - error: host.IoBroker Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/@iobroker/ws-server/dist/index.js:246:50)
      2024-10-06 09:58:11.124  - error: host.IoBroker Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
      2024-10-06 09:58:11.124  - error: host.IoBroker Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
      2024-10-06 09:58:11.124  - error: host.IoBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-10-06 09:58:11.124  - info: host.IoBroker Restart adapter system.adapter.admin.0 because enabled
        el_rob last edited by
        Bei mir dasselbe Problem mit Version 7.2.1... Nach Downgrade auf 7.2.0 funktioniert das Login wieder.
        Thomas Braun E 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @Eaglefire last edited by
          @eaglefire
          iob start admin
          Und den Start im Log beobachten.
          iob logs --watch
            Thomas Braun Most Active @el_rob last edited by
            @el_rob
            Meldungen?
            Hier bei mir habe ich gerade das Update auf 7.2.1 ohne Auffälligkeiten durchgeführt.
              Eaglefire @el_rob last edited by
              @el_rob danke für den Tipp, jetzt läuft es wieder
                @eaglefire sagte in Nach Update Anmeldung nicht mehr möglich:
                Und die Ursache ist nicht behoben. So kannst du aber kein (Beta)-Testing betreiben. Stell das Repo auf 'Stable' um, wenn du keine Betas testen willst und kannst.
                Samson71 E 2 Replies Last reply Reply Quote 1
                • Samson71
                  Samson71 Global Moderator @Thomas Braun last edited by
                  Hatte mich auch schon gewundert. Stable ist doch aktuell noch 7.1.5 ?
                    Eaglefire @Thomas Braun last edited by
                    @thomas-braun nur die Ruhe. Ich helfe gerne. Und Beta ist mir schon bewusst. Habe nochmal ein Upgrade auf die 7.2.1 gemacht und das LOG eingefangen. Steht eigentlich das gleiche wie im Diag Bericht drin.
                    2024-10-06 10:25:09.439  - error: admin.0 (7940) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
                    2024-10-06 10:25:09.440  - error: admin.0 (7940) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                    2024-10-06 10:25:09.440  - error: admin.0 (7940) Parameter "id" needs to be of type "string" but type "number" has been passed
                    2024-10-06 10:25:09.480  - info: admin.0 (7940) terminating http server on port 8081
                    2024-10-06 10:25:09.527  - error: host.IoBroker Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                    2024-10-06 10:25:09.527  - error: host.IoBroker Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
                    2024-10-06 10:25:09.527  - error: host.IoBroker Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1373:19)
                    2024-10-06 10:25:09.527  - error: host.IoBroker Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
                    2024-10-06 10:25:09.527  - error: host.IoBroker Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
                    2024-10-06 10:25:09.527  - error: host.IoBroker Caught by controller[0]:     at /opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
                    2024-10-06 10:25:09.528  - error: host.IoBroker Caught by controller[0]:     at /opt/iobroker/node_modules/@iobroker/ws-server/dist/index.js:246:64
                    2024-10-06 10:25:09.528  - error: host.IoBroker Caught by controller[0]:     at Array.forEach (<anonymous>)
                    2024-10-06 10:25:09.528  - error: host.IoBroker Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/@iobroker/ws-server/dist/index.js:246:50)
                    2024-10-06 10:25:09.528  - error: host.IoBroker Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
                    2024-10-06 10:25:09.528  - error: host.IoBroker Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
                    2024-10-06 10:25:09.528  - error: host.IoBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2024-10-06 10:25:09.528  - info: host.IoBroker Restart adapter system.adapter.admin.0 because enabled
                    2024-10-06 10:25:13.405  - info: shelly.0 (7752) [MQTT] Device with client id "shellyplus1pm-80646fe265a4" connected!
                    2024-10-06 10:25:39.777  - info: host.IoBroker instance system.adapter.admin.0 in version "7.2.1" started with pid 7988
                    2024-10-06 10:25:40.648  - info: admin.0 (7988) starting. Version 7.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 6.0.11
                    2024-10-06 10:25:40.665  - info: admin.0 (7988) requesting all objects
                    2024-10-06 10:25:40.716  - error: admin.0 (7988) Cannot init i18n: Error: Cannot find i18n directory
                    2024-10-06 10:25:41.273  - info: admin.0 (7988) received all objects
                    2024-10-06 10:25:41.411  - info: admin.0 (7988) socket.io server listening on port 8081
                    2024-10-06 10:25:41.413  - info: admin.0 (7988) http server listening on port 8081
                    2024-10-06 10:25:41.413  - info: admin.0 (7988) Use link "http://127.0.0.1:8081" to configure.
                    2024-10-06 10:25:47.316  - error: admin.0 (7988) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
                    2024-10-06 10:25:47.316  - error: admin.0 (7988) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                    2024-10-06 10:25:47.316  - error: admin.0 (7988) Parameter "id" needs to be of type "string" but type "number" has been passed
                    2024-10-06 10:25:47.323  - info: admin.0 (7988) terminating http server on port 8081
                    2024-10-06 10:25:47.324  - info: admin.0 (7988) terminating
                    2024-10-06 10:25:47.324  - warn: admin.0 (7988) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2024-10-06 10:25:47.384  - error: host.IoBroker Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                    2024-10-06 10:25:47.384  - error: host.IoBroker Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
                    2024-10-06 10:25:47.384  - error: host.IoBroker Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1373:19)
                    2024-10-06 10:25:47.384  - error: host.IoBroker Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
                    2024-10-06 10:25:47.384  - error: host.IoBroker Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
                    2024-10-06 10:25:47.384  - error: host.IoBroker Caught by controller[0]:     at /opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
                    2024-10-06 10:25:47.384  - error: host.IoBroker Caught by controller[0]:     at /opt/iobroker/node_modules/@iobroker/ws-server/dist/index.js:246:64
                    2024-10-06 10:25:47.385  - error: host.IoBroker Caught by controller[0]:     at Array.forEach (<anonymous>)
                    2024-10-06 10:25:47.385  - error: host.IoBroker Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/@iobroker/ws-server/dist/index.js:246:50)
                    2024-10-06 10:25:47.385  - error: host.IoBroker Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
                    2024-10-06 10:25:47.385  - error: host.IoBroker Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
                    2024-10-06 10:25:47.385  - error: host.IoBroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2024-10-06 10:25:47.385  - info: host.IoBroker Restart adapter system.adapter.admin.0 because enabled
                      Thomas Braun Most Active @Knoddel last edited by
                      @knoddel @el_rob
                      Meldungen im Log?
                      K E 2 Replies Last reply Reply Quote 0
                        Knoddel @Thomas Braun last edited by
                        @thomas-braun Hier ein Ausschnitt von meinem Log
                        2024-10-06 15:30:06.304  - info: ical.0 (2303) Terminated (NO_ERROR): Without reason
                        2024-10-06 15:30:06.817  - info: host.Iobroker instance system.adapter.ical.0 having pid 2                                   303 terminated with code 0 (NO_ERROR)
                        2024-10-06 15:30:15.020  - info: host.Iobroker "system.adapter.admin.0" disabled
                        2024-10-06 15:30:15.021  - info: host.Iobroker stopInstance system.adapter.admin.0 (force=                                   false, process=true)
                        2024-10-06 15:30:15.022  - info: admin.0 (313) Got terminate signal TERMINATE_YOURSELF
                        2024-10-06 15:30:15.023  - info: admin.0 (313) terminating http server on port 8081
                        2024-10-06 15:30:15.024  - info: admin.0 (313) terminating
                        2024-10-06 15:30:15.025  - info: admin.0 (313) Terminated (ADAPTER_REQUESTED_TERMINATION):                                    Without reason
                        2024-10-06 15:30:15.059  - info: host.Iobroker stopInstance system.adapter.admin.0 send ki                                   ll signal
                        2024-10-06 15:30:15.526  - info: admin.0 (313) terminating
                        2024-10-06 15:30:15.613  - info: host.Iobroker instance system.adapter.admin.0 terminated                                    with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2024-10-06 15:30:18.027  - info: host.Iobroker [WEBSERVER_UPGRADE] (admin) Server is runni                                   ng on http://localhost:8081
                        2024-10-06 15:30:20.014  - info: host.Iobroker instance system.adapter.daswetter.0 in vers                                   ion "3.1.16" started with pid 2357
                        2024-10-06 15:30:20.493  - info: daswetter.0 (2357) starting. Version 3.1.16 in /opt/iobro                                   ker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
                        2024-10-06 15:30:22.274  - info: daswetter.0 (2357) still wrong data structure from server                                    received! repaired...
                        2024-10-06 15:30:22.947  - info: host.Iobroker [WEBSERVER_UPGRADE] (admin) Successfully up                                   graded admin to version 7.2.1
                        2024-10-06 15:30:22.970  - info: daswetter.0 (2357) Terminated (ADAPTER_REQUESTED_TERMINAT                                   ION): All data handled, adapter stopped until next scheduled moment
                        2024-10-06 15:30:22.997  - info: host.Iobroker [WEBSERVER_UPGRADE] (admin) Final informati                                   on delivered
                        2024-10-06 15:30:23.007  - info: host.Iobroker "system.adapter.admin.0" enabled
                        2024-10-06 15:30:23.007  - info: host.Iobroker [WEBSERVER_UPGRADE] (admin) Successfully st                                   arted adapter
                        2024-10-06 15:30:23.309  - info: host.Iobroker instance system.adapter.admin.0 in version                                    "7.2.1" started with pid 2372
                        2024-10-06 15:30:23.473  - info: daswetter.0 (2357) cleaned everything up...
                        2024-10-06 15:30:23.479  - info: host.Iobroker instance system.adapter.daswetter.0 having                                    pid 2357 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2024-10-06 15:30:23.926  - info: admin.0 (2372) starting. Version 7.2.1 in /opt/iobroker/n                                   ode_modules/iobroker.admin, node: v20.18.0, js-controller: 6.0.11
                        2024-10-06 15:30:23.938  - info: admin.0 (2372) requesting all objects
                        2024-10-06 15:30:23.970  - error: admin.0 (2372) Cannot init i18n: Error: Cannot find i18n                                    directory
                        2024-10-06 15:30:24.910  - info: admin.0 (2372) received all objects
                        2024-10-06 15:30:25.174  - info: admin.0 (2372) socket.io server listening on port 8081
                        2024-10-06 15:30:25.176  - info: admin.0 (2372) http server listening on port 8081
                        2024-10-06 15:30:25.176  - info: admin.0 (2372) Use link "http://127.0.0.1:8081" to config                                   ure.
                        2024-10-06 15:30:25.713  - error: admin.0 (2372) uncaught exception: Parameter "id" needs                                    to be of type "string" but type "number" has been passed
                        2024-10-06 15:30:25.713  - error: admin.0 (2372) Error: Parameter "id" needs to be of type                                    "string" but type "number" has been passed
                            at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/s                                   rc/lib/adapter/validator.ts:238:19)
                            at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/li                                   b/adapter/adapter.ts:1373:19)
                            at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_mod                                   ules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
                            at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@io                                   broker/socket-classes/lib/socketCommon.js:162:22)
                            at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib                                   /socketCommon.js:104:22
                            at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/ind                                   ex.js:246:64
                            at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules                                   /@iobroker/ws-server/dist/index.js:246:50)
                        2024-10-06 15:30:25.713  - error: admin.0 (2372) Parameter "id" needs to be of type "strin                                   g" but type "number" has been passed
                        2024-10-06 15:30:25.718  - info: admin.0 (2372) terminating http server on port 8081
                        2024-10-06 15:30:25.719  - info: admin.0 (2372) terminating
                        2024-10-06 15:30:25.719  - warn: admin.0 (2372) Terminated (UNCAUGHT_EXCEPTION): Without r                                   eason
                        2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]: Error: Parameter                                    "id" needs to be of type "string" but type "number" has been passed
                        2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at Function.a                                   ssertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/va                                   lidator.ts:238:19)
                        2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at Admin.getS                                   ession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter                                   .ts:1373:19)
                        2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at SocketAdmi                                   n.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/so                                   cket-classes/lib/socketAdmin.js:73:33)
                        2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at SocketAdmi                                   n._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-cla                                   sses/lib/socketCommon.js:162:22)
                        2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at /opt/iobro                                   ker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:                                   104:22
                        2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at /opt/iobro                                   ker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
                        2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at Array.forE                                   ach (<anonymous>)
                        2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at WebSocketS                                   erver.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-ser                                   ver/dist/index.js:246:50)
                        2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at WebSocketS                                   erver.emit (node:events:519:28)
                        2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at WebSocketS                                   erver.emit (node:domain:488:12)
                        2024-10-06 15:30:26.070  - error: host.Iobroker instance system.adapter.admin.0 terminated                                    with code 1 (JS_CONTROLLER_STOPPED)
                        2024-10-06 15:30:26.070  - info: host.Iobroker Restart adapter system.adapter.admin.0 beca                                   use enabled
                        2024-10-06 15:30:56.317  - info: host.Iobroker instance system.adapter.admin.0 in version "7.2.1" started with pid 2405
                        2024-10-06 15:30:56.935  - info: admin.0 (2405) starting. Version 7.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 6.0.11
                        2024-10-06 15:30:56.951  - info: admin.0 (2405) requesting all objects
                        2024-10-06 15:30:56.993  - error: admin.0 (2405) Cannot init i18n: Error: Cannot find i18n directory
                        2024-10-06 15:30:57.976  - info: admin.0 (2405) received all objects
                        2024-10-06 15:30:58.231  - info: admin.0 (2405) socket.io server listening on port 8081
                        2024-10-06 15:30:58.233  - info: admin.0 (2405) http server listening on port 8081
                        2024-10-06 15:30:58.233  - info: admin.0 (2405) Use link "http://127.0.0.1:8081" to configure.
                        2024-10-06 15:31:13.095  - error: admin.0 (2405) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
                        2024-10-06 15:31:13.095  - error: admin.0 (2405) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                            at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
                            at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
                            at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
                            at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
                            at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
                        2024-10-06 15:31:13.096  - error: admin.0 (2405) Parameter "id" needs to be of type "string" but type "number" has been passed
                        2024-10-06 15:31:13.101  - info: admin.0 (2405) terminating http server on port 8081
                        2024-10-06 15:31:13.102  - info: admin.0 (2405) terminating
                        2024-10-06 15:31:13.102  - warn: admin.0 (2405) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                        2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
                        2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1373:19)
                        2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
                        2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
                        2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
                        2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
                        2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at Array.forEach (<anonymous>)
                        2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
                        2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
                        2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
                        2024-10-06 15:31:13.685  - error: host.Iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2024-10-06 15:31:13.685  - info: host.Iobroker Restart adapter system.adapter.admin.0 because enabled
                        2024-10-06 15:31:14.210  - info: roborock.0 (394) Reconnecting mqtt client!
                        2024-10-06 15:31:14.251  - info: roborock.0 (394) MQTT connection close.
                        2024-10-06 15:31:14.252  - info: roborock.0 (394) MQTT connection reconnect.
                        2024-10-06 15:31:43.937  - info: host.Iobroker instance system.adapter.admin.0 in version "7.2.1" started with pid 2448
                        2024-10-06 15:31:44.563  - info: admin.0 (2448) starting. Version 7.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 6.0.11
                        2024-10-06 15:31:44.573  - info: admin.0 (2448) requesting all objects
                        2024-10-06 15:31:44.607  - error: admin.0 (2448) Cannot init i18n: Error: Cannot find i18n directory
                        2024-10-06 15:31:45.537  - info: admin.0 (2448) received all objects
                        2024-10-06 15:31:45.787  - info: admin.0 (2448) socket.io server listening on port 8081
                        2024-10-06 15:31:45.788  - info: admin.0 (2448) http server listening on port 8081
                        2024-10-06 15:31:45.788  - info: admin.0 (2448) Use link "http://127.0.0.1:8081" to configure.
                        2024-10-06 15:31:45.937  - error: admin.0 (2448) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
                        2024-10-06 15:31:45.938  - error: admin.0 (2448) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                        2024-10-06 15:31:45.938  - error: admin.0 (2448) Parameter "id" needs to be of type "string" but type "number" has been passed
                        2024-10-06 15:31:45.943  - info: admin.0 (2448) terminating http server on port 8081
                        2024-10-06 15:31:45.944  - warn: admin.0 (2448) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2024-10-06 15:31:46.465  - error: host.Iobroker Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                        2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
                        2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1373:19)
                        2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
                        2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
                        2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
                        2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
                        2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at Array.forEach (<anonymous>)
                        2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
                        2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
                        2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
                        2024-10-06 15:31:46.466  - error: host.Iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2024-10-06 15:31:46.466  - info: host.Iobroker Restart adapter system.adapter.admin.0 because enabled
                        2024-10-06 15:32:16.721  - info: host.Iobroker instance system.adapter.admin.0 in version "7.2.1" started with pid 2480
                        2024-10-06 15:32:17.424  - info: admin.0 (2480) starting. Version 7.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 6.0.11
                        2024-10-06 15:32:17.438  - info: admin.0 (2480) requesting all objects
                        2024-10-06 15:32:17.480  - error: admin.0 (2480) Cannot init i18n: Error: Cannot find i18n directory
                        2024-10-06 15:32:18.414  - info: admin.0 (2480) received all objects
                        2024-10-06 15:32:18.662  - info: admin.0 (2480) socket.io server listening on port 8081
                        2024-10-06 15:32:18.664  - info: admin.0 (2480) http server listening on port 8081
                        2024-10-06 15:32:18.664  - info: admin.0 (2480) Use link "http://127.0.0.1:8081" to configure.
                        2024-10-06 15:32:19.097  - error: admin.0 (2480) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
                        2024-10-06 15:32:19.097  - error: admin.0 (2480) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                        2024-10-06 15:32:19.098  - error: admin.0 (2480) Parameter "id" needs to be of type "string" but type "number" has been passed
                        2024-10-06 15:32:19.103  - info: admin.0 (2480) terminating http server on port 8081
                        2024-10-06 15:32:19.104  - warn: admin.0 (2480) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                        2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
                        2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1373:19)
                        2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
                        2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
                        2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
                        2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
                        2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at Array.forEach (<anonymous>)
                        2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
                        2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
                        2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
                        2024-10-06 15:32:19.505  - error: host.Iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2024-10-06 15:32:19.505  - info: host.Iobroker Restart adapter system.adapter.admin.0 because enabled
                        2024-10-06 15:32:28.192  - info: host.Iobroker "system.adapter.admin.0" disabled
                        2024-10-06 15:32:31.231  - info: host.Iobroker "system.adapter.admin.0" enabled
                        2024-10-06 15:32:31.466  - info: host.Iobroker instance system.adapter.admin.0 in version "7.2.0" started with pid 2557
                        2024-10-06 15:32:32.086  - info: admin.0 (2557) starting. Version 7.2.0 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 6.0.11
                        2024-10-06 15:32:32.097  - info: admin.0 (2557) requesting all objects
                        2024-10-06 15:32:32.128  - error: admin.0 (2557) Cannot init i18n: Error: Cannot find i18n directory
                        2024-10-06 15:32:33.068  - info: admin.0 (2557) received all objects
                        2024-10-06 15:32:33.275  - info: admin.0 (2557) socket.io server listening on port 8081
                        • rweise
                          rweise last edited by
                          Bei mir 2 Installationen mit 7.2.1 kein Zugriff mehr. Der IOBroker hat aber im Hintergrund anstandslos gearbeitet. Die Lösung war ein Downgrade zu 7.2.0. hat auf beiden Geräten fuktioniert. Natürlich dann in der Konsole.
                          cd /opt/iobroker
                          iobroker stop
                          npm install iobroker.admin@7.2.0 --production
                          iobroker start
                          und schon ging es wieder 🙂
                          Ähm, hab es erst außerhalb von /opt/iobroker versucht. Dann macht er aber kein Downgrade...
                            Thomas Braun Most Active @rweise last edited by Thomas Braun
                            @rweise
                            Joh, und in diesem Beitrag sind die Kommandos immer noch falsch...
                            npm wird nicht direkt verwendet, insbesondere nicht, wenn man offensichtlich gar nicht damit umgehen kann.
                            Sollte man als Beta-Tester allerdings, imho.
                            Dein Log fehlt auch noch.
                            Für die Gallerie und damit es nicht so falsch stehen bleibt:
                            Bestimmte Adapterversionen werden mit
                            iob upgrade adaptername@versionsnummer
                            eingespielt. Dann ist es nämlich unter anderem auch egal, in welchem Verzeichnis man gerade steht.
                            Nee, dann wird das Modul in dem Verzeichnis installiert, in dem du gerade herumstehst.
                              Jan1 @Thomas Braun last edited by
                              @thomas-braun sagte in Nach Update Anmeldung nicht mehr möglich:
                              dann bitte mal in der Doku alles aktuell machen, denn da stehts über npm drin 😉
                                Thomas Braun Most Active @Jan1 last edited by Thomas Braun
                                @jan1
                                Du schaust offenbar in altes Zeuch rein.
                                Hier stimmt es:
                                https://www.iobroker.net/#de/documentation/tutorial/adapter.md
                                Edit: Wobei
                                iobroker install AdapterName@ver.si.on
                                auch falsch ist.
                                Muss natürlich
                                iobroker upgrade AdapterName@ver.si.on
                                lauten.
                                Aber PRs dazu kannst du auch machen, @jan1
                                So wie der hier:
                                https://github.com/ioBroker/ioBroker.docs/pull/553
                                Grothesk242 created this issue in ioBroker/ioBroker.docs
                                closed Update adapter.md #553
                                  ist eben doof, wenn ein und die selbe Doku zwei verschiedene Ansätze enthält, denn Dein Link ist die Doku in der ich auch nachschaue, allerdings unter IOBroker läuft nicht mehr.
                                  Da sollte mal einer aufräumen 😉
                                    @jan1 sagte in Nach Update Anmeldung nicht mehr möglich:
                                    Dann ran, lieber @jan1
                                    Hast ja die Baustellen erkannt.
                                      und immer noch keine Zeit 😉
                                      Läuft ja wieder und somit ab an die "echten" Baustellen.
                                        Die Pflege der Dokumentation kannst du dir auch für später vormerken.
                                        • rweise
                                          Da hab ich ja eine tolle Diskussion losgetreten. Egal, ob ich da falsch lag mit der alten Doku. es hat auf jeden Fall funktioniert. Übrigens habe ich nie behauptet das ich Linux Profi wäre. Aber es stand nirgends ein Weg wie ich die verflixte 7.2.1 wieder los werde.
                                          Von daher wäre es nett gewesen wenn jemand mal eine Fehlerbehebung gepostet hätte. Auch wenn es Beta ist, würde wohl mancher gerne wissen wie er das ganze wieder zum laufen bekommt, der kein Profi ist. Ich habe das ganze übrigens auf zwei völlig unterschiedlichen Plattformen erleben dürfen. Eine "echte" RPI 4/4GB mit 32 Bit-Rasbian und einer Ménge Adaptern und Deconz Zigbee sowie einer Orange Pi 2 W Zero /4GB mit 64 Bit Debian und eigentlich blankem IOBroker.
                                          Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
                                          • Ro75
                                            Ro75 @rweise last edited by
                                            @rweise sagte in Nach Update Anmeldung nicht mehr möglich:
                                            Dann arbeite bitte nur mit STABLE (egal welchen Adapter). Bei BETA musst du halt mit so etwas rechnen.
                                            Ro75.
                                            39
                                            3424
