    4. Nach Update Anmeldung nicht mehr möglich
      Knoddel @Thomas Braun last edited by
      @thomas-braun Hier ein Ausschnitt von meinem Log
      2024-10-06 15:30:06.304  - info: ical.0 (2303) Terminated (NO_ERROR): Without reason
      2024-10-06 15:30:06.817  - info: host.Iobroker instance system.adapter.ical.0 having pid 2                                   303 terminated with code 0 (NO_ERROR)
      2024-10-06 15:30:15.020  - info: host.Iobroker "system.adapter.admin.0" disabled
      2024-10-06 15:30:15.021  - info: host.Iobroker stopInstance system.adapter.admin.0 (force=                                   false, process=true)
      2024-10-06 15:30:15.022  - info: admin.0 (313) Got terminate signal TERMINATE_YOURSELF
      2024-10-06 15:30:15.023  - info: admin.0 (313) terminating http server on port 8081
      2024-10-06 15:30:15.024  - info: admin.0 (313) terminating
      2024-10-06 15:30:15.025  - info: admin.0 (313) Terminated (ADAPTER_REQUESTED_TERMINATION):                                    Without reason
      2024-10-06 15:30:15.059  - info: host.Iobroker stopInstance system.adapter.admin.0 send ki                                   ll signal
      2024-10-06 15:30:15.526  - info: admin.0 (313) terminating
      2024-10-06 15:30:15.613  - info: host.Iobroker instance system.adapter.admin.0 terminated                                    with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-10-06 15:30:18.027  - info: host.Iobroker [WEBSERVER_UPGRADE] (admin) Server is runni                                   ng on http://localhost:8081
      2024-10-06 15:30:20.014  - info: host.Iobroker instance system.adapter.daswetter.0 in vers                                   ion "3.1.16" started with pid 2357
      2024-10-06 15:30:20.493  - info: daswetter.0 (2357) starting. Version 3.1.16 in /opt/iobro                                   ker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
      2024-10-06 15:30:22.274  - info: daswetter.0 (2357) still wrong data structure from server                                    received! repaired...
      2024-10-06 15:30:22.947  - info: host.Iobroker [WEBSERVER_UPGRADE] (admin) Successfully up                                   graded admin to version 7.2.1
      2024-10-06 15:30:22.970  - info: daswetter.0 (2357) Terminated (ADAPTER_REQUESTED_TERMINAT                                   ION): All data handled, adapter stopped until next scheduled moment
      2024-10-06 15:30:22.997  - info: host.Iobroker [WEBSERVER_UPGRADE] (admin) Final informati                                   on delivered
      2024-10-06 15:30:23.007  - info: host.Iobroker "system.adapter.admin.0" enabled
      2024-10-06 15:30:23.007  - info: host.Iobroker [WEBSERVER_UPGRADE] (admin) Successfully st                                   arted adapter
      2024-10-06 15:30:23.309  - info: host.Iobroker instance system.adapter.admin.0 in version                                    "7.2.1" started with pid 2372
      2024-10-06 15:30:23.473  - info: daswetter.0 (2357) cleaned everything up...
      2024-10-06 15:30:23.479  - info: host.Iobroker instance system.adapter.daswetter.0 having                                    pid 2357 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-10-06 15:30:23.926  - info: admin.0 (2372) starting. Version 7.2.1 in /opt/iobroker/n                                   ode_modules/iobroker.admin, node: v20.18.0, js-controller: 6.0.11
      2024-10-06 15:30:23.938  - info: admin.0 (2372) requesting all objects
      2024-10-06 15:30:23.970  - error: admin.0 (2372) Cannot init i18n: Error: Cannot find i18n                                    directory
      2024-10-06 15:30:24.910  - info: admin.0 (2372) received all objects
      2024-10-06 15:30:25.174  - info: admin.0 (2372) socket.io server listening on port 8081
      2024-10-06 15:30:25.176  - info: admin.0 (2372) http server listening on port 8081
      2024-10-06 15:30:25.176  - info: admin.0 (2372) Use link "http://127.0.0.1:8081" to config                                   ure.
      2024-10-06 15:30:25.713  - error: admin.0 (2372) uncaught exception: Parameter "id" needs                                    to be of type "string" but type "number" has been passed
      2024-10-06 15:30:25.713  - error: admin.0 (2372) Error: Parameter "id" needs to be of type                                    "string" but type "number" has been passed
          at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/s                                   rc/lib/adapter/validator.ts:238:19)
          at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/li                                   b/adapter/adapter.ts:1373:19)
          at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_mod                                   ules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
          at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@io                                   broker/socket-classes/lib/socketCommon.js:162:22)
          at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib                                   /socketCommon.js:104:22
          at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/ind                                   ex.js:246:64
          at Array.forEach (<anonymous>)
          at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules                                   /@iobroker/ws-server/dist/index.js:246:50)
          at WebSocketServer.emit (node:events:519:28)
          at WebSocketServer.emit (node:domain:488:12)
      2024-10-06 15:30:25.713  - error: admin.0 (2372) Parameter "id" needs to be of type "strin                                   g" but type "number" has been passed
      2024-10-06 15:30:25.718  - info: admin.0 (2372) terminating http server on port 8081
      2024-10-06 15:30:25.719  - info: admin.0 (2372) terminating
      2024-10-06 15:30:25.719  - warn: admin.0 (2372) Terminated (UNCAUGHT_EXCEPTION): Without r                                   eason
      2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]: Error: Parameter                                    "id" needs to be of type "string" but type "number" has been passed
      2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at Function.a                                   ssertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/va                                   lidator.ts:238:19)
      2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at Admin.getS                                   ession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter                                   .ts:1373:19)
      2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at SocketAdmi                                   n.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/so                                   cket-classes/lib/socketAdmin.js:73:33)
      2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at SocketAdmi                                   n._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-cla                                   sses/lib/socketCommon.js:162:22)
      2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at /opt/iobro                                   ker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:                                   104:22
      2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at /opt/iobro                                   ker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
      2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at Array.forE                                   ach (<anonymous>)
      2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at WebSocketS                                   erver.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-ser                                   ver/dist/index.js:246:50)
      2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at WebSocketS                                   erver.emit (node:events:519:28)
      2024-10-06 15:30:26.070  - error: host.Iobroker Caught by controller[0]:     at WebSocketS                                   erver.emit (node:domain:488:12)
      2024-10-06 15:30:26.070  - error: host.Iobroker instance system.adapter.admin.0 terminated                                    with code 1 (JS_CONTROLLER_STOPPED)
      2024-10-06 15:30:26.070  - info: host.Iobroker Restart adapter system.adapter.admin.0 beca                                   use enabled
      2024-10-06 15:30:56.317  - info: host.Iobroker instance system.adapter.admin.0 in version "7.2.1" started with pid 2405
      2024-10-06 15:30:56.935  - info: admin.0 (2405) starting. Version 7.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 6.0.11
      2024-10-06 15:30:56.951  - info: admin.0 (2405) requesting all objects
      2024-10-06 15:30:56.993  - error: admin.0 (2405) Cannot init i18n: Error: Cannot find i18n directory
      2024-10-06 15:30:57.976  - info: admin.0 (2405) received all objects
      2024-10-06 15:30:58.231  - info: admin.0 (2405) socket.io server listening on port 8081
      2024-10-06 15:30:58.233  - info: admin.0 (2405) http server listening on port 8081
      2024-10-06 15:30:58.233  - info: admin.0 (2405) Use link "http://127.0.0.1:8081" to configure.
      2024-10-06 15:31:13.095  - error: admin.0 (2405) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
      2024-10-06 15:31:13.095  - error: admin.0 (2405) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
          at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
          at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1373:19)
          at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
          at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
          at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
          at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
          at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
      2024-10-06 15:31:13.096  - error: admin.0 (2405) Parameter "id" needs to be of type "string" but type "number" has been passed
      2024-10-06 15:31:13.101  - info: admin.0 (2405) terminating http server on port 8081
      2024-10-06 15:31:13.102  - info: admin.0 (2405) terminating
      2024-10-06 15:31:13.102  - warn: admin.0 (2405) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
      2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
      2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1373:19)
      2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
      2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
      2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
      2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
      2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at Array.forEach (<anonymous>)
      2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
      2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
      2024-10-06 15:31:13.685  - error: host.Iobroker Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
      2024-10-06 15:31:13.685  - error: host.Iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-10-06 15:31:13.685  - info: host.Iobroker Restart adapter system.adapter.admin.0 because enabled
      2024-10-06 15:31:14.210  - info: roborock.0 (394) Reconnecting mqtt client!
      2024-10-06 15:31:14.251  - info: roborock.0 (394) MQTT connection close.
      2024-10-06 15:31:14.252  - info: roborock.0 (394) MQTT connection reconnect.
      2024-10-06 15:31:43.937  - info: host.Iobroker instance system.adapter.admin.0 in version "7.2.1" started with pid 2448
      2024-10-06 15:31:44.563  - info: admin.0 (2448) starting. Version 7.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 6.0.11
      2024-10-06 15:31:44.573  - info: admin.0 (2448) requesting all objects
      2024-10-06 15:31:44.607  - error: admin.0 (2448) Cannot init i18n: Error: Cannot find i18n directory
      2024-10-06 15:31:45.537  - info: admin.0 (2448) received all objects
      2024-10-06 15:31:45.787  - info: admin.0 (2448) socket.io server listening on port 8081
      2024-10-06 15:31:45.788  - info: admin.0 (2448) http server listening on port 8081
      2024-10-06 15:31:45.788  - info: admin.0 (2448) Use link "http://127.0.0.1:8081" to configure.
      2024-10-06 15:31:45.937  - error: admin.0 (2448) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
      2024-10-06 15:31:45.938  - error: admin.0 (2448) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
      2024-10-06 15:31:45.938  - error: admin.0 (2448) Parameter "id" needs to be of type "string" but type "number" has been passed
      2024-10-06 15:31:45.943  - info: admin.0 (2448) terminating http server on port 8081
      2024-10-06 15:31:45.944  - warn: admin.0 (2448) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2024-10-06 15:31:46.465  - error: host.Iobroker Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
      2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
      2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1373:19)
      2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
      2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
      2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
      2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
      2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at Array.forEach (<anonymous>)
      2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
      2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
      2024-10-06 15:31:46.466  - error: host.Iobroker Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
      2024-10-06 15:31:46.466  - error: host.Iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-10-06 15:31:46.466  - info: host.Iobroker Restart adapter system.adapter.admin.0 because enabled
      2024-10-06 15:32:16.721  - info: host.Iobroker instance system.adapter.admin.0 in version "7.2.1" started with pid 2480
      2024-10-06 15:32:17.424  - info: admin.0 (2480) starting. Version 7.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 6.0.11
      2024-10-06 15:32:17.438  - info: admin.0 (2480) requesting all objects
      2024-10-06 15:32:17.480  - error: admin.0 (2480) Cannot init i18n: Error: Cannot find i18n directory
      2024-10-06 15:32:18.414  - info: admin.0 (2480) received all objects
      2024-10-06 15:32:18.662  - info: admin.0 (2480) socket.io server listening on port 8081
      2024-10-06 15:32:18.664  - info: admin.0 (2480) http server listening on port 8081
      2024-10-06 15:32:18.664  - info: admin.0 (2480) Use link "http://127.0.0.1:8081" to configure.
      2024-10-06 15:32:19.097  - error: admin.0 (2480) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
      2024-10-06 15:32:19.097  - error: admin.0 (2480) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
      2024-10-06 15:32:19.098  - error: admin.0 (2480) Parameter "id" needs to be of type "string" but type "number" has been passed
      2024-10-06 15:32:19.103  - info: admin.0 (2480) terminating http server on port 8081
      2024-10-06 15:32:19.104  - warn: admin.0 (2480) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
      2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
      2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1373:19)
      2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
      2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
      2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
      2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
      2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at Array.forEach (<anonymous>)
      2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
      2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
      2024-10-06 15:32:19.505  - error: host.Iobroker Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
      2024-10-06 15:32:19.505  - error: host.Iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-10-06 15:32:19.505  - info: host.Iobroker Restart adapter system.adapter.admin.0 because enabled
      2024-10-06 15:32:28.192  - info: host.Iobroker "system.adapter.admin.0" disabled
      2024-10-06 15:32:31.231  - info: host.Iobroker "system.adapter.admin.0" enabled
      2024-10-06 15:32:31.466  - info: host.Iobroker instance system.adapter.admin.0 in version "7.2.0" started with pid 2557
      2024-10-06 15:32:32.086  - info: admin.0 (2557) starting. Version 7.2.0 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 6.0.11
      2024-10-06 15:32:32.097  - info: admin.0 (2557) requesting all objects
      2024-10-06 15:32:32.128  - error: admin.0 (2557) Cannot init i18n: Error: Cannot find i18n directory
      2024-10-06 15:32:33.068  - info: admin.0 (2557) received all objects
      2024-10-06 15:32:33.275  - info: admin.0 (2557) socket.io server listening on port 8081
      • rweise
        rweise last edited by
        Bei mir 2 Installationen mit 7.2.1 kein Zugriff mehr. Der IOBroker hat aber im Hintergrund anstandslos gearbeitet. Die Lösung war ein Downgrade zu 7.2.0. hat auf beiden Geräten fuktioniert. Natürlich dann in der Konsole.
        cd /opt/iobroker
        iobroker stop
        npm install iobroker.admin@7.2.0 --production
        iobroker start
        und schon ging es wieder 🙂
        Ähm, hab es erst außerhalb von /opt/iobroker versucht. Dann macht er aber kein Downgrade...
          Thomas Braun Most Active @rweise last edited by Thomas Braun
          @rweise
          Joh, und in diesem Beitrag sind die Kommandos immer noch falsch...
          npm wird nicht direkt verwendet, insbesondere nicht, wenn man offensichtlich gar nicht damit umgehen kann.
          Sollte man als Beta-Tester allerdings, imho.
          Dein Log fehlt auch noch.
          Für die Gallerie und damit es nicht so falsch stehen bleibt:
          Bestimmte Adapterversionen werden mit
          iob upgrade adaptername@versionsnummer
          eingespielt. Dann ist es nämlich unter anderem auch egal, in welchem Verzeichnis man gerade steht.
          Nee, dann wird das Modul in dem Verzeichnis installiert, in dem du gerade herumstehst.
            Jan1 @Thomas Braun last edited by
            @thomas-braun sagte in Nach Update Anmeldung nicht mehr möglich:
            dann bitte mal in der Doku alles aktuell machen, denn da stehts über npm drin 😉
              Thomas Braun Most Active @Jan1 last edited by Thomas Braun
              @jan1
              Du schaust offenbar in altes Zeuch rein.
              Hier stimmt es:
              https://www.iobroker.net/#de/documentation/tutorial/adapter.md
              Edit: Wobei
              iobroker install AdapterName@ver.si.on
              auch falsch ist.
              Muss natürlich
              iobroker upgrade AdapterName@ver.si.on
              lauten.
              Aber PRs dazu kannst du auch machen, @jan1
              So wie der hier:
              https://github.com/ioBroker/ioBroker.docs/pull/553
              Grothesk242 created this issue in ioBroker/ioBroker.docs
              closed Update adapter.md #553
                ist eben doof, wenn ein und die selbe Doku zwei verschiedene Ansätze enthält, denn Dein Link ist die Doku in der ich auch nachschaue, allerdings unter IOBroker läuft nicht mehr.
                Da sollte mal einer aufräumen 😉
                  @jan1 sagte in Nach Update Anmeldung nicht mehr möglich:
                  Dann ran, lieber @jan1
                  Hast ja die Baustellen erkannt.
                    und immer noch keine Zeit 😉
                    Läuft ja wieder und somit ab an die "echten" Baustellen.
                      Die Pflege der Dokumentation kannst du dir auch für später vormerken.
                      • rweise
                        Da hab ich ja eine tolle Diskussion losgetreten. Egal, ob ich da falsch lag mit der alten Doku. es hat auf jeden Fall funktioniert. Übrigens habe ich nie behauptet das ich Linux Profi wäre. Aber es stand nirgends ein Weg wie ich die verflixte 7.2.1 wieder los werde.
                        Von daher wäre es nett gewesen wenn jemand mal eine Fehlerbehebung gepostet hätte. Auch wenn es Beta ist, würde wohl mancher gerne wissen wie er das ganze wieder zum laufen bekommt, der kein Profi ist. Ich habe das ganze übrigens auf zwei völlig unterschiedlichen Plattformen erleben dürfen. Eine "echte" RPI 4/4GB mit 32 Bit-Rasbian und einer Ménge Adaptern und Deconz Zigbee sowie einer Orange Pi 2 W Zero /4GB mit 64 Bit Debian und eigentlich blankem IOBroker.
                        Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
                        • Ro75
                          Ro75 @rweise last edited by
                          @rweise sagte in Nach Update Anmeldung nicht mehr möglich:
                          Dann arbeite bitte nur mit STABLE (egal welchen Adapter). Bei BETA musst du halt mit so etwas rechnen.
                          Ro75.
                            Musst du auch nicht, das hat nämlich mit 'Linux' gar nichts zu tun.
                            Es wäre nett gewesen, wenn du als Beta-Tester verwertbare LOGS bereitgestellt hättest, vielleicht hätte man damit den Fehler im Adapter dann auch beheben können.
                            Beta-Versionen werden ja nicht veröffentlicht, damit du da eine höhere Versionsnummer bestaunen darfst, sondern um Fehler zu finden und für ein stabiles Release auszumerzen.
                              alexanderbrix last edited by alexanderbrix
                              so, gerade eben Update auf die 7.2.2 gemacht, gleiches Problem, kein Zugriff mehr auf die Admin-Oberfläche...
                              Also heute Abend wieder auf die 7.2.0 downgraden... 🙄
                                das wurde 1:1 aus der alten Doku übernommen und bisher noch nicht überarbeitet worden
                                ich wollte mich drüber machen, leider fehlt mir aber die Zeit
                                  Thomas Braun Most Active @alexanderbrix last edited by
                                  @alexanderbrix
                                  Hier kein Problem, die 7.2.2 läuft wie auch die 7.2.1 schon
                                    ag @Eaglefire last edited by ag
                                    Hallo.
                                    Habe eben Admin Version 7.22 installiert. danach Anmeldung nicht mehr möglich
                                    Auszug aus dem Log:
                                    f
                                    admin.0
                                    	2024-10-07 08:34:59.290	info	received all objects
                                    admin.0
                                    	2024-10-07 08:34:58.682	error	Cannot init i18n: Error: Cannot find i18n directory
                                    admin.0
                                    	2024-10-07 08:34:58.619	info	requesting all objects
                                    admin.0
                                    	2024-10-07 08:34:58.599	info	starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0-alpha.0-20240926-91f9b082f
                                    host.RPI5Test
                                    	2024-10-07 08:34:57.785	info	instance system.adapter.admin.1 in version "7.2.2" started with pid 65770
                                    host.RPI5Test
                                    	2024-10-07 08:34:57.378	info	instance system.adapter.admin.0 in version "7.2.2" started with pid 65763
                                    host.RPI5Test
                                    	2024-10-07 08:34:27.020	info	Restart adapter system.adapter.admin.0 because enabled
                                    host.RPI5Test
                                    	2024-10-07 08:34:27.020	error	instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    host.RPI5Test
                                    	2024-10-07 08:34:27.020	error	Caught by controller[0]: at WebSocketServer.emit (node:domain:488:12)
                                    host.RPI5Test
                                    	2024-10-07 08:34:27.020	error	Caught by controller[0]: at WebSocketServer.emit (node:events:519:28)
                                    host.RPI5Test
                                    	2024-10-07 08:34:27.020	error	Caught by controller[0]: at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
                                    host.RPI5Test
                                    	2024-10-07 08:34:27.020	error	Caught by controller[0]: at Array.forEach (<anonymous>)
                                    host.RPI5Test
                                    	2024-10-07 08:34:27.020	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
                                    host.RPI5Test
                                    	2024-10-07 08:34:27.020	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
                                    host.RPI5Test
                                    	2024-10-07 08:34:27.020	error	Caught by controller[0]: at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
                                    host.RPI5Test
                                    	2024-10-07 08:34:27.020	error	Caught by controller[0]: at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
                                    host.RPI5Test
                                    	2024-10-07 08:34:27.020	error	Caught by controller[0]: at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1374:19)
                                    host.RPI5Test
                                    	2024-10-07 08:34:27.020	error	Caught by controller[0]: at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
                                    host.RPI5Test
                                    	2024-10-07 08:34:27.019	error	Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                                    admin.0
                                    	2024-10-07 08:34:26.704	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    admin.0
                                    	2024-10-07 08:34:26.703	info	terminating
                                    admin.0
                                    	2024-10-07 08:34:26.702	info	terminating http server on port 8081
                                    admin.0
                                    	2024-10-07 08:34:26.692	error	Parameter "id" needs to be of type "string" but type "number" has been passed
                                    admin.0
                                    	2024-10-07 08:34:26.691	error	Error: Parameter "id" needs to be of type "string" but type "number" has been passed at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19) at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1374:19) at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33) at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22) at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22 at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64 at Array.forEach (<anonymous>) at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50) at WebSocketServer.emit (node:events:519:28) at WebSocketServer.emit (node:domain:488:12)
                                    admin.0
                                    	2024-10-07 08:34:26.691	error	uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
                                    admin.0
                                    	2024-10-07 08:33:48.835	info	Use link "http://127.0.0.1:8081" to configure.
                                    admin.0
                                    	2024-10-07 08:33:48.835	info	http server listening on port 8081
                                    admin.0
                                    	2024-10-07 08:33:48.833	info	socket.io server listening on port 8081
                                    admin.0
                                    	2024-10-07 08:33:48.454	info	received all objects
                                    admin.0
                                    	2024-10-07 08:33:47.858	error	Cannot init i18n: Error: Cannot find i18n directory
                                    admin.0
                                    	2024-10-07 08:33:47.800	info	requesting all objects
                                    admin.0
                                    	2024-10-07 08:33:47.783	info	starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0-alpha.0-20240926-91f9b082f
                                    Edit:
                                    die Instanz admin.1 hab ich danach zu testzwecken installiert.
                                    Wenn ich diese dann starte und die instanz 0 stoppen komme ich auf die Admin-Oberfläche.
                                    ag
                                      el_rob @Thomas Braun last edited by
                                      @thomas-braun Sorry, komme erst jetzt dazu... Bei Adapterversion 7.2.2 besteht bei mir das Problem immer noch. Hier das Log (bereinigt um irrelevante Einträge):
                                      2024-10-07 09:54:40.206  - info: admin.0 (3048266) starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v18.20.4, js-controller: 6.0.11
                                      2024-10-07 09:54:40.225  - info: admin.0 (3048266) requesting all objects
                                      2024-10-07 09:54:40.260  - error: admin.0 (3048266) Cannot init i18n: Error: Cannot find i18n directory
                                      2024-10-07 09:54:41.457  - info: admin.0 (3048266) received all objects
                                      2024-10-07 09:54:41.707  - info: admin.0 (3048266) socket.io server listening on port 8081
                                      2024-10-07 09:54:41.708  - info: admin.0 (3048266) http server listening on port 8081
                                      2024-10-07 09:54:41.709  - info: admin.0 (3048266) Use link "http://127.0.0.1:8081" to configure.
                                      2024-10-07 09:54:46.557  - error: admin.0 (3048266) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
                                      2024-10-07 09:54:46.557  - error: admin.0 (3048266) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                                          at WebSocketServer.emit (node:events:517:28)
                                          at WebSocketServer.emit (node:domain:489:12)
                                      2024-10-07 09:54:46.557  - error: admin.0 (3048266) Parameter "id" needs to be of type "string" but type "number" has been passed
                                      2024-10-07 09:54:46.564  - info: admin.0 (3048266) terminating http server on port 8081
                                      2024-10-07 09:54:46.565  - info: admin.0 (3048266) terminating
                                      2024-10-07 09:54:46.566  - warn: admin.0 (3048266) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                                      2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
                                      2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1373:19)
                                      2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
                                      2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
                                      2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
                                      2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
                                      2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at Array.forEach (<anonymous>)
                                      2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
                                      2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at WebSocketServer.emit (node:events:517:28)
                                      2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at WebSocketServer.emit (node:domain:489:12)
                                      2024-10-07 09:54:46.799  - error: host.iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      2024-10-07 09:54:46.799  - info: host.iobroker Restart adapter system.adapter.admin.0 because enabled
                                      2024-10-07 09:55:17.142  - info: host.iobroker instance system.adapter.admin.0 in version "7.2.2" started with pid 3049825
                                      2024-10-07 09:55:18.356  - info: admin.0 (3049825) starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v18.20.4, js-controller: 6.0.11
                                      2024-10-07 09:55:18.375  - info: admin.0 (3049825) requesting all objects
                                      2024-10-07 09:55:18.410  - error: admin.0 (3049825) Cannot init i18n: Error: Cannot find i18n directory
                                      2024-10-07 09:55:19.642  - info: admin.0 (3049825) received all objects
                                      2024-10-07 09:55:19.748  - info: squeezeboxrpc.0 (1192) State value to set for "squeezeboxrpc.0.Server.LastScan" has to be type "number" but received type "string"
                                      2024-10-07 09:55:19.783  - info: admin.0 (3049825) socket.io server listening on port 8081
                                      2024-10-07 09:55:19.784  - info: admin.0 (3049825) http server listening on port 8081
                                      2024-10-07 09:55:19.784  - info: admin.0 (3049825) Use link "http://127.0.0.1:8081" to configure.
                                      2024-10-07 09:55:24.543  - error: admin.0 (3049825) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
                                      2024-10-07 09:55:24.543  - error: admin.0 (3049825) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                                      2024-10-07 09:55:24.543  - error: admin.0 (3049825) Parameter "id" needs to be of type "string" but type "number" has been passed
                                      2024-10-07 09:55:24.550  - info: admin.0 (3049825) terminating http server on port 8081
                                      2024-10-07 09:55:24.551  - info: admin.0 (3049825) terminating
                                      2024-10-07 09:55:24.552  - warn: admin.0 (3049825) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      2024-10-07 09:55:24.803  - error: host.iobroker Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                                      2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
                                      2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1373:19)
                                      2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
                                      2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
                                      2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
                                      2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
                                      2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at Array.forEach (<anonymous>)
                                      2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
                                      2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at WebSocketServer.emit (node:events:517:28)
                                      2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at WebSocketServer.emit (node:domain:489:12)
                                      2024-10-07 09:55:24.804  - error: host.iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      2024-10-07 09:55:24.804  - info: host.iobroker Restart adapter system.adapter.admin.0 because enabled
                                        TT-Tom last edited by TT-Tom
                                        habe den Test mit dem js-controller 7.0.0, Admin 7.2.1 und Nodejs 20.18.0 durchgeführt. Das Log sieht den andren gleich aus.
                                        2024-10-07 11:30:55.346  - info: host.iobtest Restart adapter system.adapter.admin.0 because enabled
                                        2024-10-07 11:31:25.572  - info: host.iobtest instance system.adapter.admin.0 in version "7.2.1" started with pid 9133
                                        2024-10-07 11:31:26.332  - info: admin.0 (9133) starting. Version 7.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0
                                        2024-10-07 11:31:26.347  - info: admin.0 (9133) requesting all objects
                                        2024-10-07 11:31:26.385  - error: admin.0 (9133) Cannot init i18n: Error: Cannot find i18n directory
                                        2024-10-07 11:31:26.753  - info: admin.0 (9133) received all objects
                                        2024-10-07 11:31:26.877  - info: admin.0 (9133) socket.io server listening on port 8081
                                        2024-10-07 11:31:26.878  - info: admin.0 (9133) http server listening on port 8081
                                        2024-10-07 11:31:26.878  - info: admin.0 (9133) Use link "http://127.0.0.1:8081" to configure.
                                        2024-10-07 11:31:31.081  - error: admin.0 (9133) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
                                        2024-10-07 11:31:31.081  - error: admin.0 (9133) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                                        2024-10-07 11:31:31.081  - error: admin.0 (9133) Parameter "id" needs to be of type "string" but type "number" has been passed
                                        2024-10-07 11:31:31.089  - info: admin.0 (9133) terminating http server on port 8081
                                        2024-10-07 11:31:31.090  - warn: admin.0 (9133) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                                        2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
                                        2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1374:19)
                                        2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
                                        2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
                                        2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
                                        2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
                                        2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at Array.forEach (<anonymous>)
                                        2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
                                        2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
                                        2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
                                        2024-10-07 11:31:31.442  - error: host.iobtest instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2024-10-07 11:31:31.442  - info: host.iobtest Restart adapter system.adapter.admin.0 because enabled
                                        gleiches Verhalten mit Version 7.2.2
                                        2024-10-07 11:38:26.917  - info: host.iobtest instance system.adapter.admin.0 in version "7.2.2" started with pid 9648
                                        2024-10-07 11:38:27.722  - info: admin.0 (9648) starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0
                                        2024-10-07 11:38:27.737  - info: admin.0 (9648) requesting all objects
                                        2024-10-07 11:38:27.776  - error: admin.0 (9648) Cannot init i18n: Error: Cannot find i18n directory
                                        2024-10-07 11:38:28.145  - info: admin.0 (9648) received all objects
                                        2024-10-07 11:38:28.348  - info: admin.0 (9648) socket.io server listening on port 8081
                                        2024-10-07 11:38:28.349  - info: admin.0 (9648) http server listening on port 8081
                                        2024-10-07 11:38:28.350  - info: admin.0 (9648) Use link "http://127.0.0.1:8081" to configure.
                                        2024-10-07 11:38:29.654  - error: admin.0 (9648) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
                                        2024-10-07 11:38:29.654  - error: admin.0 (9648) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                                        2024-10-07 11:38:29.654  - error: admin.0 (9648) Parameter "id" needs to be of type "string" but type "number" has been passed
                                        2024-10-07 11:38:29.662  - info: admin.0 (9648) terminating http server on port 8081
                                        2024-10-07 11:38:29.663  - warn: admin.0 (9648) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                                        2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
                                        2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1374:19)
                                        2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
                                        2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
                                        2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
                                        2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
                                        2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at Array.forEach (<anonymous>)
                                        2024-10-07 11:38:30.016  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
                                        2024-10-07 11:38:30.016  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
                                        2024-10-07 11:38:30.016  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
                                        2024-10-07 11:38:30.016  - error: host.iobtest instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2024-10-07 11:38:30.016  - info: host.iobtest Restart adapter system.adapter.admin.0 because enabled
                                          Thomas Braun Most Active @TT-Tom last edited by
                                          Scheint mir ein Fehler mit der Authentifzierung bei admins mit SSL/https zu sein.
                                          A T E 3 Replies Last reply Reply Quote 0
                                            ag @Thomas Braun last edited by
                                            Habe Authentifizierung ausgeschaltet und dann auf 7.2.2 upgedatet.
                                            Admin wird problemlos angezeigt
                                            ag
                                            39
                                            3424
