    3. Einsteigerfragen
    4. Installation
    5. [gelöst] ioBroker Web nach Backitup nicht erreichbar
      crunchip Forum Testing Most Active @Codierknecht last edited by
      @codierknecht laut log ist er noch am arbeiten mit einigen error Meldungen
      Codierknecht 1 Reply Last reply Reply Quote 1
        Bene241 @crunchip last edited by
        er muss ja jetzt erstmal die eigentliche Installation bewerkstelligen und dies dauert eine Weile, du kannst in log sehen, was er gerade macht
        iob logs --watch
        Das schemißt er raus:
        pi@raspberrypi:~ $ iob logs --watch
        2024-10-06 14:33:19.831  - info: host.raspberrypi iobroker npm-install: upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
        2024-10-06 14:33:19.842  - info: host.raspberrypi iobroker npm-install: upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
        2024-10-06 14:33:19.850  - info: host.raspberrypi iobroker npm-install: upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
        2024-10-06 14:33:20.046  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.web created/updated
        2024-10-06 14:33:21.137  - info: host.raspberrypi iobroker npm-install: exit 0
        2024-10-06 14:33:22.137  - warn: host.raspberrypi startInstance cannot find adapter "ws@1.3.0". Try to install it... 1 attempt
        2024-10-06 14:33:22.138  - info: host.raspberrypi iobroker install ws@1.3.0 using installedVersion
        2024-10-06 14:33:24.455  - info: host.raspberrypi iobroker npm-install: adapter "ws" already installed. Use "upgrade" to upgrade to a newer version.
        2024-10-06 14:33:25.498  - info: host.raspberrypi iobroker npm-install: exit 51
        2024-10-06 14:33:26.499  - warn: host.raspberrypi startInstance cannot find adapter "yahka@0.13.1". Try to install it... 1 attempt
        2024-10-06 14:33:26.501  - info: host.raspberrypi iobroker install yahka@0.13.1 using installedFrom
        2024-10-06 14:33:29.596  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
        2024-10-06 14:33:29.598  - info: host.raspberrypi iobroker npm-install: Installing iobroker.yahka@0.13.1... (System call)
        2024-10-06 14:33:41.908  - info: host.raspberrypi iobroker npm-install:
        2024-10-06 14:33:41.909  - info: host.raspberrypi iobroker npm-install: added 38 packages in 12s
        2024-10-06 14:33:41.910  - info: host.raspberrypi iobroker npm-install:
        2024-10-06 14:33:41.911  - info: host.raspberrypi iobroker npm-install: 193 packages are looking for funding
        2024-10-06 14:33:41.913  - info: host.raspberrypi iobroker npm-install:   run `npm fund` for details
        2024-10-06 14:33:41.950  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter yahka@0.13.1
        2024-10-06 14:33:48.322  - error: host.raspberrypi iobroker npm-install: Cannot install "pam-devel": WARNING: apt does not have a stable CLI interface. Use with caution in scripts.E: Unable to locate package pam-develThe following apt packages could not be installed: pam-devel. Please install them manually.
        2024-10-06 14:33:48.323  - info: host.raspberrypi iobroker npm-install: Installed the following apt packages: pam-develThese apt packages were already installed: libavahi-compat-libdnssd-dev
        2024-10-06 14:33:48.398  - info: host.raspberrypi iobroker npm-install: upload [19] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/css/yahka.admin.css css/yahka.admin.css text/css
        2024-10-06 14:33:48.409  - info: host.raspberrypi iobroker npm-install: upload [18] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-colors.min.css ext/metroui/css/metro-colors.min.css text/css
        2024-10-06 14:33:48.417  - info: host.raspberrypi iobroker npm-install: upload [17] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-icons.min.css ext/metroui/css/metro-icons.min.css text/css
        2024-10-06 14:33:48.424  - info: host.raspberrypi iobroker npm-install: upload [16] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-responsive.min.css ext/metroui/css/metro-responsive.min.css text/css
        2024-10-06 14:33:48.431  - info: host.raspberrypi iobroker npm-install: upload [15] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-rtl.min.css ext/metroui/css/metro-rtl.min.css text/css
        2024-10-06 14:33:48.437  - info: host.raspberrypi iobroker npm-install: upload [14] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-schemes.min.css ext/metroui/css/metro-schemes.min.css text/css
        2024-10-06 14:33:48.444  - info: host.raspberrypi iobroker npm-install: upload [13] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro.min.css ext/metroui/css/metro.min.css text/css
        2024-10-06 14:33:48.453  - info: host.raspberrypi iobroker npm-install: upload [12] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.eot ext/metroui/fonts/metro.eot application/vnd.ms-fontobject
        2024-10-06 14:33:48.460  - info: host.raspberrypi iobroker npm-install: upload [11] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.svg ext/metroui/fonts/metro.svg image/svg+xml
        2024-10-06 14:33:48.472  - info: host.raspberrypi iobroker npm-install: upload [10] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.ttf ext/metroui/fonts/metro.ttf font/ttf
        2024-10-06 14:33:48.479  - info: host.raspberrypi iobroker npm-install: upload [9] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.woff ext/metroui/fonts/metro.woff font/woff
        2024-10-06 14:33:48.487  - info: host.raspberrypi iobroker npm-install: upload [8] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/selection.json ext/metroui/fonts/selection.json application/json
        2024-10-06 14:33:48.501  - info: host.raspberrypi iobroker npm-install: upload [7] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/js/metro.min.js ext/metroui/js/metro.min.js application/javascript
        2024-10-06 14:33:48.509  - info: host.raspberrypi iobroker npm-install: upload [6] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/home_icon_large.png home_icon_large.png image/png
        2024-10-06 14:33:48.515  - info: host.raspberrypi iobroker npm-install: upload [5] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index.html index.html text/html
        2024-10-06 14:33:48.522  - info: host.raspberrypi iobroker npm-install: upload [4] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index_m.html index_m.html text/html
        2024-10-06 14:33:48.528  - info: host.raspberrypi iobroker npm-install: upload [3] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/words.js words.js application/javascript
        2024-10-06 14:33:48.534  - info: host.raspberrypi iobroker npm-install: upload [2] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js yahka.admin.js application/javascript
        2024-10-06 14:33:48.695  - info: host.raspberrypi iobroker npm-install: upload [1] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js.map yahka.admin.js.map application/json
        2024-10-06 14:33:48.862  - info: host.raspberrypi iobroker npm-install: upload [0] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.png yahka.png image/png
        2024-10-06 14:33:48.882  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object yahka.meta._accessoryCategories created/updated
        2024-10-06 14:33:48.891  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.yahka created/updated
        2024-10-06 14:33:48.974  - info: host.raspberrypi iobroker npm-install: Update "system.adapter.yahka.0"
        2024-10-06 14:33:50.014  - info: host.raspberrypi iobroker npm-install: exit 0
        2024-10-06 14:33:51.015  - warn: host.raspberrypi startInstance cannot find adapter "mihome-vacuum@3.8.8". Try to install it... 2 attempt
        2024-10-06 14:33:51.016  - info: host.raspberrypi iobroker install mihome-vacuum@3.8.8 using installedFrom
        2024-10-06 14:33:54.092  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
        2024-10-06 14:33:54.094  - info: host.raspberrypi iobroker npm-install: Installing iobroker.mihome-vacuum@3.8.8... (System call)
        2024-10-06 14:34:03.558  - error: host.raspberrypi iobroker npm-install: npm error code 127npm error path /opt/iobroker/node_modules/zlibnpm error command failednpm error command sh -c node-waf clean || true; node-waf configure buildnpm error sh: 1: node-waf: not foundnpm error sh: 1: node-waf: not foundnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T12_33_54_373Z-debug-0.log
        2024-10-06 14:34:03.560  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.mihome-vacuum@3.8.8: 127
        2024-10-06 14:34:04.589  - info: host.raspberrypi iobroker npm-install: exit 25
        2024-10-06 14:34:05.590  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 2 attempt
        2024-10-06 14:34:05.591  - info: host.raspberrypi iobroker install vis@1.4.15 using installedFrom
        2024-10-06 14:34:08.677  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
        2024-10-06 14:34:08.679  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
        2024-10-06 14:34:17.590  - info: vis.0 (11909) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
        2024-10-06 14:34:17.887  - info: vis.0 (11909) vis license is OK.
        2024-10-06 14:34:18.097  - error: vis.0 (11909) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-10-06 14:34:18.098  - error: vis.0 (11909) unhandled promise rejection: Not exists
        2024-10-06 14:34:18.100  - error: vis.0 (11909) Error: Not exists
            at ObjectsInRedisClient._readFile (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:850:19)
            at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:887:59)
            at process.processImmediate (node:internal/timers:485:21)
        2024-10-06 14:34:18.101  - error: vis.0 (11909) Not exists
        2024-10-06 14:34:18.607  - info: vis.0 (11909) terminating
        2024-10-06 14:34:18.609  - warn: vis.0 (11909) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2024-10-06 14:34:19.275  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T12_34_08_958Z-debug-0.log
        2024-10-06 14:34:19.276  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
        2024-10-06 14:34:20.305  - info: host.raspberrypi iobroker npm-install: exit 25
        2024-10-06 14:34:21.305  - warn: host.raspberrypi startInstance cannot find adapter "mihome-vacuum@3.8.8". Try to install it... 3 attempt
        2024-10-06 14:34:21.308  - info: host.raspberrypi iobroker install mihome-vacuum@3.8.8 using installedVersion
        2024-10-06 14:34:24.355  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
        2024-10-06 14:34:24.357  - info: host.raspberrypi iobroker npm-install: Installing iobroker.mihome-vacuum@3.8.8... (System call)
        2024-10-06 14:34:31.625  - error: host.raspberrypi iobroker npm-install: npm error code 127npm error path /opt/iobroker/node_modules/zlibnpm error command failednpm error command sh -c node-waf clean || true; node-waf configure buildnpm error sh: 1: node-waf: not foundnpm error sh: 1: node-waf: not foundnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T12_34_24_639Z-debug-0.log
        2024-10-06 14:34:31.626  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.mihome-vacuum@3.8.8: 127
        2024-10-06 14:34:32.653  - info: host.raspberrypi iobroker npm-install: exit 25
        2024-10-06 14:34:33.655  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 3 attempt
        2024-10-06 14:34:33.655  - info: host.raspberrypi iobroker install vis@1.4.15 using installedVersion
        2024-10-06 14:34:36.662  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
        2024-10-06 14:34:36.663  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
        2024-10-06 14:34:45.598  - info: vis.0 (11991) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
        2024-10-06 14:34:45.893  - info: vis.0 (11991) vis license is OK.
        2024-10-06 14:34:46.101  - error: vis.0 (11991) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-10-06 14:34:46.103  - error: vis.0 (11991) unhandled promise rejection: Not exists
        2024-10-06 14:34:46.105  - error: vis.0 (11991) Error: Not exists
        2024-10-06 14:34:46.106  - error: vis.0 (11991) Not exists
        2024-10-06 14:34:46.612  - info: vis.0 (11991) terminating
        2024-10-06 14:34:46.613  - warn: vis.0 (11991) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2024-10-06 14:34:47.281  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T12_34_36_958Z-debug-0.log
        2024-10-06 14:34:47.282  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
        2024-10-06 14:34:48.311  - info: host.raspberrypi iobroker npm-install: exit 25
        2024-10-06 14:34:49.312  - warn: host.raspberrypi startInstance cannot find adapter "mihome-vacuum@3.8.8". Try to install it... 4 attempt
        2024-10-06 14:34:49.313  - info: host.raspberrypi iobroker install mihome-vacuum@3.8.8 using installedVersion
        2024-10-06 14:34:52.305  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
        2024-10-06 14:34:52.307  - info: host.raspberrypi iobroker npm-install: Installing iobroker.mihome-vacuum@3.8.8... (System call)
        2024-10-06 14:34:59.572  - error: host.raspberrypi iobroker npm-install: npm error code 127npm error path /opt/iobroker/node_modules/zlibnpm error command failednpm error command sh -c node-waf clean || true; node-waf configure buildnpm error sh: 1: node-waf: not foundnpm error sh: 1: node-waf: not foundnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T12_34_52_586Z-debug-0.loghost.raspberrypi Cannot install iobroker.mihome-vacuum@3.8.8: 127
        2024-10-06 14:35:00.601  - info: host.raspberrypi iobroker npm-install: exit 25
        2024-10-06 14:35:01.602  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 4 attempt
        2024-10-06 14:35:01.603  - info: host.raspberrypi iobroker install vis@1.4.15 using installedVersion
        2024-10-06 14:35:04.576  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
        2024-10-06 14:35:04.579  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
        2024-10-06 14:35:13.586  - info: vis.0 (12072) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
        2024-10-06 14:35:13.888  - info: vis.0 (12072) vis license is OK.
        2024-10-06 14:35:14.074  - error: vis.0 (12072) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-10-06 14:35:14.076  - error: vis.0 (12072) unhandled promise rejection: Not exists
        2024-10-06 14:35:14.077  - error: vis.0 (12072) Error: Not exists
        2024-10-06 14:35:14.079  - error: vis.0 (12072) Not exists
        2024-10-06 14:35:14.584  - info: vis.0 (12072) terminating
        2024-10-06 14:35:14.586  - warn: vis.0 (12072) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2024-10-06 14:35:15.260  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T12_35_04_857Z-debug-0.log
        2024-10-06 14:35:15.261  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
        2024-10-06 14:35:16.289  - info: host.raspberrypi iobroker npm-install: exit 25
        2024-10-06 14:35:17.290  - error: host.raspberrypi Cannot download and install adapter "mihome-vacuum@3.8.8". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
        2024-10-06 14:35:17.791  - error: host.raspberrypi Cannot download and install adapter "vis@1.4.15". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
        2024-10-06 15:19:34.015  - info: host.raspberrypi received SIGTERM
        2024-10-06 15:19:34.018  - info: backitup.0 (9416) cleaned everything up...
        2024-10-06 15:19:34.021  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=false)
        2024-10-06 15:19:34.021  - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=false)
        2024-10-06 15:19:34.022  - info: host.raspberrypi stopInstance system.adapter.telegram.0 (force=false, process=false)
        2024-10-06 15:19:34.022  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 (force=false, process=false)
        2024-10-06 15:19:34.023  - info: host.raspberrypi stopInstance system.adapter.hm-rega.0 (force=false, process=false)
        2024-10-06 15:19:34.023  - info: host.raspberrypi stopInstance system.adapter.hm-rpc.0 (force=false, process=false)
        2024-10-06 15:19:34.023  - info: host.raspberrypi stopInstance system.adapter.hm-rpc.1 (force=false, process=false)
        2024-10-06 15:19:34.023  - info: host.raspberrypi stopInstance system.adapter.hm-rpc.2 (force=false, process=false)
        2024-10-06 15:19:34.024  - info: host.raspberrypi stopInstance system.adapter.hue.0 (force=false, process=false)
        2024-10-06 15:19:34.024  - info: host.raspberrypi stopInstance system.adapter.ical.0 (force=false, process=false)
        2024-10-06 15:19:34.024  - info: host.raspberrypi stopInstance system.adapter.mihome-vacuum.0 (force=false, process=false)
        2024-10-06 15:19:34.025  - info: host.raspberrypi stopInstance system.adapter.mihome.0 (force=false, process=false)
        2024-10-06 15:19:34.025  - info: host.raspberrypi stopInstance system.adapter.ping.0 (force=false, process=false)
        2024-10-06 15:19:34.025  - info: host.raspberrypi stopInstance system.adapter.rpi2.0 (force=false, process=false)
        2024-10-06 15:19:34.025  - info: host.raspberrypi stopInstance system.adapter.sonos.0 (force=false, process=false)
        2024-10-06 15:19:34.026  - info: host.raspberrypi stopInstance system.adapter.tr-064.0 (force=false, process=false)
        2024-10-06 15:19:34.030  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=false)
        2024-10-06 15:19:34.030  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
        2024-10-06 15:19:34.031  - info: host.raspberrypi stopInstance system.adapter.bring.0 (force=false, process=false)
        2024-10-06 15:19:34.031  - info: host.raspberrypi stopInstance system.adapter.denon.0 (force=false, process=false)
        2024-10-06 15:19:34.031  - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 (force=false, process=false)
        2024-10-06 15:19:34.032  - info: host.raspberrypi stopInstance system.adapter.fullybrowser.0 (force=false, process=false)
        2024-10-06 15:19:34.032  - info: host.raspberrypi stopInstance system.adapter.hue-extended.0 (force=false, process=false)
        2024-10-06 15:19:34.032  - info: host.raspberrypi stopInstance system.adapter.icons-mfd-png.0 (force=false, process=false)
        2024-10-06 15:19:34.032  - info: host.raspberrypi stopInstance system.adapter.icons-ultimate-png.0 (force=false, process=false)
        2024-10-06 15:19:34.032  - info: host.raspberrypi stopInstance system.adapter.info.0 (force=false, process=false)
        2024-10-06 15:19:34.033  - info: host.raspberrypi stopInstance system.adapter.lgtv.0 (force=false, process=false)
        2024-10-06 15:19:34.033  - info: host.raspberrypi stopInstance system.adapter.trashschedule.0 (force=false, process=false)
        2024-10-06 15:19:34.033  - info: host.raspberrypi stopInstance system.adapter.vis-bars.0 (force=false, process=false)
        2024-10-06 15:19:34.033  - info: host.raspberrypi stopInstance system.adapter.vis-fancyswitch.0 (force=false, process=false)
        2024-10-06 15:19:34.033  - info: host.raspberrypi stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
        2024-10-06 15:19:34.034  - info: host.raspberrypi stopInstance system.adapter.vis-inventwo.0 (force=false, process=false)
        2024-10-06 15:19:34.034  - info: host.raspberrypi stopInstance system.adapter.vis-players.0 (force=false, process=false)
        2024-10-06 15:19:34.034  - info: host.raspberrypi stopInstance system.adapter.vis-timeandweather.0 (force=false, process=false)
        2024-10-06 15:19:34.034  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=false)
        2024-10-06 15:19:34.034  - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=false)
        2024-10-06 15:19:34.035  - info: host.raspberrypi stopInstance system.adapter.ws.0 (force=false, process=false)
        2024-10-06 15:19:34.035  - info: host.raspberrypi stopInstance system.adapter.yahka.0 (force=false, process=false)
        2024-10-06 15:19:34.043  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
        2024-10-06 15:19:34.042  - info: backitup.0 (9416) Got terminate signal TERMINATE_YOURSELF
        2024-10-06 15:19:34.047  - info: backitup.0 (9416) terminating
        2024-10-06 15:19:34.049  - info: backitup.0 (9416) Terminated (NO_ERROR): Without reason
        2024-10-06 15:19:34.526  - info: backitup.0 (9416) terminating
        2024-10-06 15:19:34.763  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
        2024-10-06 15:19:34.763  - info: host.raspberrypi All instances are stopped.
        2024-10-06 15:19:34.946  - info: host.raspberrypi terminated
        2024-10-06 15:20:28.227  - info: host.raspberrypi iobroker.js-controller version 6.0.11 js-controller starting
        2024-10-06 15:20:28.233  - info: host.raspberrypi Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
        2024-10-06 15:20:28.234  - info: host.raspberrypi hostname: raspberrypi, node: v20.18.0
        2024-10-06 15:20:28.235  - info: host.raspberrypi ip addresses: 192.168.178.65 2a02:908:1c40:1f80:892:a253:c9a7:6444 fe80::dad5:b9d2:3d51:2e39
        2024-10-06 15:20:29.891  - info: host.raspberrypi connected to Objects and States
        2024-10-06 15:20:29.931  - info: host.raspberrypi added notifications configuration of host
        2024-10-06 15:20:30.589  - info: host.raspberrypi 38 instances found
        2024-10-06 15:20:30.646  - info: host.raspberrypi starting 2 instances
        2024-10-06 15:20:30.656  - warn: host.raspberrypi startInstance cannot find adapter "mihome-vacuum@3.8.8". Try to install it... 1 attempt
        2024-10-06 15:20:30.658  - info: host.raspberrypi iobroker install mihome-vacuum@3.8.8 using installedFrom
        2024-10-06 15:20:31.125  - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
        2024-10-06 15:20:31.153  - info: host.raspberrypi Some obsolete host states deleted.
        2024-10-06 15:20:31.174  - info: host.raspberrypi instance system.adapter.admin.0 in version "6.3.5" started with pid 12369
        2024-10-06 15:20:34.162  - info: admin.0 (12369) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 6.0.11
        2024-10-06 15:20:34.182  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
        2024-10-06 15:20:34.184  - info: host.raspberrypi iobroker npm-install: Installing iobroker.mihome-vacuum@3.8.8... (System call)
        2024-10-06 15:20:34.239  - info: admin.0 (12369) requesting all states
        2024-10-06 15:20:34.241  - info: admin.0 (12369) requesting all objects
        2024-10-06 15:20:36.023  - info: host.raspberrypi instance system.adapter.backitup.0 in version "2.6.23" started with pid 12419
        2024-10-06 15:20:36.266  - info: admin.0 (12369) received all objects
        2024-10-06 15:20:36.349  - error: admin.0 (12369) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
        2024-10-06 15:20:36.351  - info: admin.0 (12369) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-10-06 15:20:36.965  - warn: admin.0 (12369) redis get admin.0.info.newsLastId, error - Connection is closed.
        2024-10-06 15:20:36.985  - error: admin.0 (12369) Cannot update news: Error: DB closed
        2024-10-06 15:20:36.987  - warn: admin.0 (12369) Cannot check node.js/npm version
        2024-10-06 15:20:37.001  - info: admin.0 (12369) terminating http server on port 8081
        2024-10-06 15:20:37.165  - info: host.raspberrypi instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        2024-10-06 15:20:37.167  - info: host.raspberrypi Do not restart adapter system.adapter.admin.0 because desired by instance
        2024-10-06 15:20:39.761  - info: backitup.0 (12419) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.18.0, js-controller: 6.0.11
        2024-10-06 15:20:40.009  - info: backitup.0 (12419) [iobroker] backup will be activated at 02:40 every 1 day(s)
        2024-10-06 15:20:40.125  - info: backitup.0 (12419) [ccu] backup will be activated at 01:30 every 3 day(s)
        2024-10-06 15:20:44.994  - error: host.raspberrypi iobroker npm-install: npm error code 127npm error path /opt/iobroker/node_modules/zlibnpm error command failednpm error command sh -c node-waf clean || true; node-waf configure buildnpm error sh: 1: node-waf: not foundnpm error sh: 1: node-waf: not foundnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_20_34_497Z-debug-0.log
        2024-10-06 15:20:44.995  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.mihome-vacuum@3.8.8: 127
        2024-10-06 15:20:46.031  - info: host.raspberrypi iobroker npm-install: exit 25
        2024-10-06 15:20:47.032  - warn: host.raspberrypi startInstance cannot find adapter "hue-extended@2.0.0". Try to install it... 1 attempt
        2024-10-06 15:20:47.034  - info: host.raspberrypi iobroker install hue-extended@2.0.0 using installedFrom
        2024-10-06 15:20:49.848  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Unknown packet name hue-extended. Please install packages from outside the repository using "iobroker url <url-or-package>"!
        2024-10-06 15:20:49.849  - error: host.raspberrypi iobroker npm-install: adapter "hue-extended" cannot be installed: Unknown packetName hue-extended. Please install packages from outside the repository using npm!
        2024-10-06 15:20:50.904  - info: host.raspberrypi iobroker npm-install: exit 12
        2024-10-06 15:20:51.904  - warn: host.raspberrypi startInstance cannot find adapter "info@1.9.19". Try to install it... 1 attempt
        2024-10-06 15:20:51.906  - info: host.raspberrypi iobroker install info@1.9.19 using installedFrom
        2024-10-06 15:20:54.570  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Unknown packet name info. Please install packages from outside the repository using "iobroker url <url-or-package>"!
        2024-10-06 15:20:54.571  - error: host.raspberrypi iobroker npm-install: adapter "info" cannot be installed: Unknown packetName info. Please install packages from outside the repository using npm!
        2024-10-06 15:20:55.631  - info: host.raspberrypi iobroker npm-install: exit 12
        2024-10-06 15:20:56.632  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 1 attempt
        2024-10-06 15:20:56.633  - info: host.raspberrypi iobroker install vis@1.4.15 using installedFrom
        2024-10-06 15:20:59.610  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
        2024-10-06 15:20:59.612  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
        2024-10-06 15:21:08.952  - info: vis.0 (12506) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
        2024-10-06 15:21:09.253  - info: vis.0 (12506) vis license is OK.
        2024-10-06 15:21:09.477  - error: vis.0 (12506) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-10-06 15:21:09.479  - error: vis.0 (12506) unhandled promise rejection: Not exists
        2024-10-06 15:21:09.481  - error: vis.0 (12506) Error: Not exists
        2024-10-06 15:21:09.482  - error: vis.0 (12506) Not exists
        2024-10-06 15:21:09.988  - info: vis.0 (12506) terminating
        2024-10-06 15:21:09.989  - warn: vis.0 (12506) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2024-10-06 15:21:10.660  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_20_59_899Z-debug-0.log
        2024-10-06 15:21:10.662  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
        2024-10-06 15:21:11.690  - info: host.raspberrypi iobroker npm-install: exit 25
        2024-10-06 15:21:12.690  - warn: host.raspberrypi startInstance cannot find adapter "mihome-vacuum@3.8.8". Try to install it... 2 attempt
        2024-10-06 15:21:12.693  - info: host.raspberrypi iobroker install mihome-vacuum@3.8.8 using installedFrom
        2024-10-06 15:21:15.763  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
        2024-10-06 15:21:15.765  - info: host.raspberrypi iobroker npm-install: Installing iobroker.mihome-vacuum@3.8.8... (System call)
        2024-10-06 15:21:23.145  - error: host.raspberrypi iobroker npm-install: npm error code 127npm error path /opt/iobroker/node_modules/zlibnpm error command failednpm error command sh -c node-waf clean || true; node-waf configure buildnpm error sh: 1: node-waf: not foundnpm error sh: 1: node-waf: not foundnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_21_16_046Z-debug-0.log
        2024-10-06 15:21:23.147  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.mihome-vacuum@3.8.8: 127
        2024-10-06 15:21:24.177  - info: host.raspberrypi iobroker npm-install: exit 25
        2024-10-06 15:21:25.178  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 2 attempt
        2024-10-06 15:21:25.179  - info: host.raspberrypi iobroker install vis@1.4.15 using installedFrom
        2024-10-06 15:21:28.146  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
        2024-10-06 15:21:28.148  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
        2024-10-06 15:21:37.017  - info: vis.0 (12587) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
        2024-10-06 15:21:37.305  - info: vis.0 (12587) vis license is OK.
        2024-10-06 15:21:37.516  - error: vis.0 (12587) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-10-06 15:21:37.518  - error: vis.0 (12587) unhandled promise rejection: Not exists
        2024-10-06 15:21:37.520  - error: vis.0 (12587) Error: Not exists
        2024-10-06 15:21:37.521  - error: vis.0 (12587) Not exists
        2024-10-06 15:21:38.027  - info: vis.0 (12587) terminating
        2024-10-06 15:21:38.028  - warn: vis.0 (12587) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2024-10-06 15:21:38.699  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_21_28_427Z-debug-0.log
        2024-10-06 15:21:38.700  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
        2024-10-06 15:21:39.728  - info: host.raspberrypi iobroker npm-install: exit 25
        2024-10-06 15:21:40.729  - warn: host.raspberrypi startInstance cannot find adapter "mihome-vacuum@3.8.8". Try to install it... 3 attempt
        2024-10-06 15:21:40.730  - info: host.raspberrypi iobroker install mihome-vacuum@3.8.8 using installedVersion
        2024-10-06 15:21:43.701  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
        2024-10-06 15:21:43.703  - info: host.raspberrypi iobroker npm-install: Installing iobroker.mihome-vacuum@3.8.8... (System call)
        2024-10-06 15:21:51.009  - error: host.raspberrypi iobroker npm-install: npm error code 127npm error path /opt/iobroker/node_modules/zlibnpm error command failednpm error command sh -c node-waf clean || true; node-waf configure buildnpm error sh: 1: node-waf: not foundnpm error sh: 1: node-waf: not foundnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_21_43_982Z-debug-0.loghost.raspberrypi Cannot install iobroker.mihome-vacuum@3.8.8: 127
        2024-10-06 15:21:52.040  - info: host.raspberrypi iobroker npm-install: exit 25
        2024-10-06 15:21:53.040  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 3 attempt
        2024-10-06 15:21:53.042  - info: host.raspberrypi iobroker install vis@1.4.15 using installedVersion
        2024-10-06 15:21:56.057  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
        2024-10-06 15:21:56.059  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
        2024-10-06 15:22:04.895  - info: vis.0 (12669) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
        2024-10-06 15:22:05.271  - info: vis.0 (12669) vis license is OK.
        2024-10-06 15:22:05.479  - error: vis.0 (12669) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-10-06 15:22:05.481  - error: vis.0 (12669) unhandled promise rejection: Not exists
        2024-10-06 15:22:05.483  - error: vis.0 (12669) Error: Not exists
        2024-10-06 15:22:05.484  - error: vis.0 (12669) Not exists
        2024-10-06 15:22:05.990  - info: vis.0 (12669) terminating
        2024-10-06 15:22:05.992  - warn: vis.0 (12669) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2024-10-06 15:22:06.662  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_21_56_340Z-debug-0.loghost.raspberrypi Cannot install iobroker.vis@1.4.15: 6
        2024-10-06 15:22:07.691  - info: host.raspberrypi iobroker npm-install: exit 25
        2024-10-06 15:22:08.692  - warn: host.raspberrypi startInstance cannot find adapter "mihome-vacuum@3.8.8". Try to install it... 4 attempt
        2024-10-06 15:22:08.694  - info: host.raspberrypi iobroker install mihome-vacuum@3.8.8 using installedVersion
        2024-10-06 15:22:11.709  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
        2024-10-06 15:22:11.711  - info: host.raspberrypi iobroker npm-install: Installing iobroker.mihome-vacuum@3.8.8... (System call)
        2024-10-06 15:22:19.063  - error: host.raspberrypi iobroker npm-install: npm error code 127npm error path /opt/iobroker/node_modules/zlibnpm error command failednpm error command sh -c node-waf clean || true; node-waf configure buildnpm error sh: 1: node-waf: not foundnpm error sh: 1: node-waf: not foundnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_22_11_989Z-debug-0.log
        2024-10-06 15:22:19.064  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.mihome-vacuum@3.8.8: 127
        2024-10-06 15:22:20.093  - info: host.raspberrypi iobroker npm-install: exit 25
        2024-10-06 15:22:21.093  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 4 attempt
        2024-10-06 15:22:21.095  - info: host.raspberrypi iobroker install vis@1.4.15 using installedVersion
        2024-10-06 15:22:24.068  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
        2024-10-06 15:22:24.070  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
        2024-10-06 15:22:33.026  - info: vis.0 (12750) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
        2024-10-06 15:22:33.307  - info: vis.0 (12750) vis license is OK.
        2024-10-06 15:22:33.512  - error: vis.0 (12750) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-10-06 15:22:33.514  - error: vis.0 (12750) unhandled promise rejection: Not exists
        2024-10-06 15:22:33.516  - error: vis.0 (12750) Error: Not exists
        2024-10-06 15:22:33.517  - error: vis.0 (12750) Not exists
        2024-10-06 15:22:34.023  - info: vis.0 (12750) terminating
        2024-10-06 15:22:34.024  - warn: vis.0 (12750) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2024-10-06 15:22:34.694  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_22_24_350Z-debug-0.log
        2024-10-06 15:22:34.695  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
        2024-10-06 15:22:35.722  - info: host.raspberrypi iobroker npm-install: exit 25
        2024-10-06 15:22:36.724  - error: host.raspberrypi Cannot download and install adapter "mihome-vacuum@3.8.8". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
        2024-10-06 15:22:37.225  - error: host.raspberrypi Cannot download and install adapter "vis@1.4.15". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
        2024-10-06 15:44:22.936  - info: host.raspberrypi "system.adapter.vis.0" enabled
        2024-10-06 15:44:23.415  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 1 attempt
        2024-10-06 15:44:23.416  - info: host.raspberrypi iobroker install vis@1.4.15 using installedFrom
        2024-10-06 15:44:26.380  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
        2024-10-06 15:44:26.382  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
        2024-10-06 15:44:35.746  - info: vis.0 (15614) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
        2024-10-06 15:44:36.028  - info: vis.0 (15614) vis license is OK.
        2024-10-06 15:44:36.232  - error: vis.0 (15614) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-10-06 15:44:36.234  - error: vis.0 (15614) unhandled promise rejection: Not exists
        2024-10-06 15:44:36.236  - error: vis.0 (15614) Error: Not exists
        2024-10-06 15:44:36.237  - error: vis.0 (15614) Not exists
        2024-10-06 15:44:36.741  - info: vis.0 (15614) terminating
        2024-10-06 15:44:36.743  - warn: vis.0 (15614) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2024-10-06 15:44:37.418  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_44_26_661Z-debug-0.log
        2024-10-06 15:44:37.420  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
        2024-10-06 15:44:38.448  - info: host.raspberrypi iobroker npm-install: exit 25
        2024-10-06 15:44:39.449  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 2 attempt
        2024-10-06 15:44:39.450  - info: host.raspberrypi iobroker install vis@1.4.15 using installedFrom
        2024-10-06 15:44:41.571  - info: host.raspberrypi "system.adapter.web.0" enabled
        2024-10-06 15:44:42.202  - info: host.raspberrypi instance system.adapter.web.0 in version "4.3.0" started with pid 15650
        2024-10-06 15:44:43.430  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2Installing iobroker.vis@1.4.15... (System call)
        2024-10-06 15:44:43.814  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1228
        2024-10-06 15:44:43.814  - error: host.raspberrypi Caught by controller[0]:   throw err;
        2024-10-06 15:44:43.814  - error: host.raspberrypi Caught by controller[0]:   ^
        2024-10-06 15:44:43.815  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
        2024-10-06 15:44:43.815  - error: host.raspberrypi Caught by controller[0]: Require stack:
        2024-10-06 15:44:43.815  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
        2024-10-06 15:44:43.815  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
        2024-10-06 15:44:43.815  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1051:27)
        2024-10-06 15:44:43.816  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
        2024-10-06 15:44:43.816  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
        2024-10-06 15:44:43.816  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
        2024-10-06 15:44:43.816  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
        2024-10-06 15:44:43.816  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
        2024-10-06 15:44:43.817  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
        2024-10-06 15:44:43.817  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
        2024-10-06 15:44:43.817  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
        2024-10-06 15:44:43.817  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
        2024-10-06 15:44:43.817  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
        2024-10-06 15:44:43.817  - error: host.raspberrypi Caught by controller[0]: }
        2024-10-06 15:44:43.818  - error: host.raspberrypi Caught by controller[0]: Node.js v20.18.0
        2024-10-06 15:44:43.818  - error: host.raspberrypi instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-10-06 15:44:43.818  - info: host.raspberrypi Adapter system.adapter.web.0 needs rebuild and will be restarted afterwards.
        2024-10-06 15:44:43.819  - info: host.raspberrypi system.adapter.web.0 will be rebuilt
        2024-10-06 15:44:52.410  - info: vis.0 (15681) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
        2024-10-06 15:44:52.701  - info: vis.0 (15681) vis license is OK.
        2024-10-06 15:44:52.909  - error: vis.0 (15681) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-10-06 15:44:52.911  - error: vis.0 (15681) unhandled promise rejection: Not exists
        2024-10-06 15:44:52.913  - error: vis.0 (15681) Error: Not exists
        2024-10-06 15:44:52.914  - error: vis.0 (15681) Not exists
        2024-10-06 15:44:53.420  - info: vis.0 (15681) terminating
        2024-10-06 15:44:53.421  - warn: vis.0 (15681) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2024-10-06 15:44:54.099  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_44_43_778Z-debug-0.log
        2024-10-06 15:44:54.100  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
        2024-10-06 15:44:55.127  - info: host.raspberrypi iobroker npm-install: exit 25
        2024-10-06 15:44:56.128  - warn: host.raspberrypi adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
        2024-10-06 15:44:56.129  - info: host.raspberrypi iobroker rebuild
        2024-10-06 15:44:57.896  - info: host.raspberrypi iobroker npm-rebuild: Rebuilding native modules ...
        2024-10-06 15:45:42.200  - info: host.raspberrypi iobroker npm-rebuild: rebuilt dependencies successfully
        2024-10-06 15:45:42.233  - info: host.raspberrypi iobroker npm-rebuild:
        2024-10-06 15:45:42.234  - info: host.raspberrypi iobroker npm-rebuild: Rebuilding native modules done
        2024-10-06 15:45:43.246  - info: host.raspberrypi iobroker npm-rebuild: exit 0
        2024-10-06 15:45:43.792  - info: host.raspberrypi instance system.adapter.web.0 in version "4.3.0" started with pid 16132
        2024-10-06 15:45:44.248  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 3 attempt
        2024-10-06 15:45:44.250  - info: host.raspberrypi iobroker install vis@1.4.15 using installedVersion
        2024-10-06 15:45:45.313  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1228
        2024-10-06 15:45:45.313  - error: host.raspberrypi Caught by controller[0]:   throw err;
        2024-10-06 15:45:45.314  - error: host.raspberrypi Caught by controller[0]:   ^
        2024-10-06 15:45:45.314  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
        2024-10-06 15:45:45.314  - error: host.raspberrypi Caught by controller[0]: Require stack:
        2024-10-06 15:45:45.314  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
        2024-10-06 15:45:45.315  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
        2024-10-06 15:45:45.315  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1051:27)
        2024-10-06 15:45:45.315  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
        2024-10-06 15:45:45.315  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
        2024-10-06 15:45:45.315  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
        2024-10-06 15:45:45.316  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
        2024-10-06 15:45:45.316  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
        2024-10-06 15:45:45.316  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
        2024-10-06 15:45:45.316  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
        2024-10-06 15:45:45.316  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
        2024-10-06 15:45:45.317  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
        2024-10-06 15:45:45.317  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
        2024-10-06 15:45:45.317  - error: host.raspberrypi Caught by controller[0]: }
        2024-10-06 15:45:45.317  - error: host.raspberrypi Caught by controller[0]: Node.js v20.18.0
        2024-10-06 15:45:45.317  - error: host.raspberrypi instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-10-06 15:45:45.318  - info: host.raspberrypi Adapter system.adapter.web.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
        2024-10-06 15:45:45.318  - info: host.raspberrypi system.adapter.web.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"6.0.11"})
        2024-10-06 15:45:47.453  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
        2024-10-06 15:45:47.456  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
        2024-10-06 15:45:57.836  - info: vis.0 (16176) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
        2024-10-06 15:45:58.174  - info: vis.0 (16176) vis license is OK.
        2024-10-06 15:45:58.373  - error: vis.0 (16176) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-10-06 15:45:58.375  - error: vis.0 (16176) unhandled promise rejection: Not exists
        2024-10-06 15:45:58.377  - error: vis.0 (16176) Error: Not exists
        2024-10-06 15:45:58.378  - error: vis.0 (16176) Not exists
        2024-10-06 15:45:58.884  - info: vis.0 (16176) terminating
        2024-10-06 15:45:58.885  - warn: vis.0 (16176) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2024-10-06 15:45:59.767  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_45_47_734Z-debug-0.log
        2024-10-06 15:45:59.768  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
        2024-10-06 15:46:00.797  - info: host.raspberrypi iobroker npm-install: exit 25
        2024-10-06 15:46:01.797  - warn: host.raspberrypi adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
        2024-10-06 15:46:01.799  - info: host.raspberrypi iobroker rebuild iobroker.js-controller@6.0.11 --path /opt/iobroker/node_modules
        2024-10-06 15:46:03.292  - info: host.raspberrypi iobroker npm-rebuild: Rebuilding native module "iobroker.js-controller@6.0.11" in /opt/iobroker/node_modules ...
        2024-10-06 15:46:20.538  - info: host.raspberrypi iobroker npm-rebuild: rebuilt dependencies successfully
        2024-10-06 15:46:20.571  - info: host.raspberrypi iobroker npm-rebuild:
        2024-10-06 15:46:20.571  - info: host.raspberrypi iobroker npm-rebuild: Rebuilding native modules done
        2024-10-06 15:46:21.584  - info: host.raspberrypi iobroker npm-rebuild: exit 0
        2024-10-06 15:46:21.994  - info: host.raspberrypi instance system.adapter.web.0 in version "4.3.0" started with pid 16246
        2024-10-06 15:46:22.584  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 4 attempt
        2024-10-06 15:46:22.585  - info: host.raspberrypi iobroker install vis@1.4.15 using installedVersion
        2024-10-06 15:46:23.506  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1228
        2024-10-06 15:46:23.506  - error: host.raspberrypi Caught by controller[0]:   throw err;
        2024-10-06 15:46:23.507  - error: host.raspberrypi Caught by controller[0]:   ^
        2024-10-06 15:46:23.507  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
        2024-10-06 15:46:23.507  - error: host.raspberrypi Caught by controller[0]: Require stack:
        2024-10-06 15:46:23.507  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
        2024-10-06 15:46:23.507  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
        2024-10-06 15:46:23.507  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1051:27)
        2024-10-06 15:46:23.507  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
        2024-10-06 15:46:23.508  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
        2024-10-06 15:46:23.508  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
        2024-10-06 15:46:23.508  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
        2024-10-06 15:46:23.508  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
        2024-10-06 15:46:23.508  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
        2024-10-06 15:46:23.509  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
        2024-10-06 15:46:23.509  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
        2024-10-06 15:46:23.510  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
        2024-10-06 15:46:23.510  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
        2024-10-06 15:46:23.510  - error: host.raspberrypi Caught by controller[0]: }
        2024-10-06 15:46:23.510  - error: host.raspberrypi Caught by controller[0]: Node.js v20.18.0
        2024-10-06 15:46:23.510  - error: host.raspberrypi instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-10-06 15:46:23.511  - info: host.raspberrypi Adapter system.adapter.web.0 needs rebuild and will be restarted afterwards.
        2024-10-06 15:46:23.511  - info: host.raspberrypi system.adapter.web.0 will be rebuilt
        2024-10-06 15:46:25.762  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
        2024-10-06 15:46:25.764  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
        2024-10-06 15:46:36.200  - info: vis.0 (16288) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
        2024-10-06 15:46:36.531  - info: vis.0 (16288) vis license is OK.
        2024-10-06 15:46:36.727  - error: vis.0 (16288) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-10-06 15:46:36.729  - error: vis.0 (16288) unhandled promise rejection: Not exists
        2024-10-06 15:46:36.731  - error: vis.0 (16288) Error: Not exists
        2024-10-06 15:46:36.732  - error: vis.0 (16288) Not exists
        2024-10-06 15:46:37.238  - info: vis.0 (16288) terminating
        2024-10-06 15:46:37.240  - warn: vis.0 (16288) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2024-10-06 15:46:38.120  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_46_26_043Z-debug-0.log
        2024-10-06 15:46:38.121  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
        2024-10-06 15:46:39.149  - info: host.raspberrypi iobroker npm-install: exit 25
        2024-10-06 15:46:40.150  - warn: host.raspberrypi adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
        2024-10-06 15:46:40.151  - info: host.raspberrypi iobroker rebuild
        2024-10-06 15:46:41.843  - info: host.raspberrypi iobroker npm-rebuild: Rebuilding native modules ...
        2024-10-06 15:47:25.422  - info: host.raspberrypi iobroker npm-rebuild: rebuilt dependencies successfully
        2024-10-06 15:47:25.464  - info: host.raspberrypi iobroker npm-rebuild:
        2024-10-06 15:47:25.465  - info: host.raspberrypi iobroker npm-rebuild: Rebuilding native modules done
        2024-10-06 15:47:26.479  - info: host.raspberrypi iobroker npm-rebuild: exit 0
        2024-10-06 15:47:26.985  - info: host.raspberrypi instance system.adapter.web.0 in version "4.3.0" started with pid 16999
        2024-10-06 15:47:27.481  - error: host.raspberrypi Cannot download and install adapter "vis@1.4.15". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
        2024-10-06 15:47:28.552  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1228
        2024-10-06 15:47:28.553  - error: host.raspberrypi Caught by controller[0]:   throw err;
        2024-10-06 15:47:28.553  - error: host.raspberrypi Caught by controller[0]:   ^
        2024-10-06 15:47:28.553  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
        2024-10-06 15:47:28.554  - error: host.raspberrypi Caught by controller[0]: Require stack:
        2024-10-06 15:47:28.554  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
        2024-10-06 15:47:28.554  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
        2024-10-06 15:47:28.554  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1051:27)
        2024-10-06 15:47:28.555  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
        2024-10-06 15:47:28.555  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
        2024-10-06 15:47:28.555  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
        2024-10-06 15:47:28.555  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
        2024-10-06 15:47:28.556  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
        2024-10-06 15:47:28.556  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
        2024-10-06 15:47:28.556  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
        2024-10-06 15:47:28.557  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
        2024-10-06 15:47:28.557  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
        2024-10-06 15:47:28.557  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
        2024-10-06 15:47:28.558  - error: host.raspberrypi Caught by controller[0]: }
        2024-10-06 15:47:28.558  - error: host.raspberrypi Caught by controller[0]: Node.js v20.18.0
        2024-10-06 15:47:28.559  - error: host.raspberrypi instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-10-06 15:47:28.559  - info: host.raspberrypi Rebuild for adapter system.adapter.web.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
        • Codierknecht
          Codierknecht Developer Most Active @crunchip last edited by
          @crunchip sagte in ioBroker Web nach Backitup nicht erreichbar:
          Jo - nicht drauf geachtet 😞
            Bene241 @Codierknecht last edited by
            @codierknecht @crunchip
            werdet ihr denn aus den Fehlermeldungen schlau?
              Thomas Braun Most Active @Bene241 last edited by
              @bene241
              Backup sollte ja jetzt durch sein bzw. in timeout gelaufen sein.
              Sauberen reboot und dann eine frische Ausgabe von
              iob diag
                Bene241 @Thomas Braun last edited by
                @thomas-braun said in ioBroker Web nach Backitup nicht erreichbar:
                @bene241
                iob diag
                Vielen Dank nochmals 🙂
                ```bash
                Skript v.2024-08-12
                *** BASE SYSTEM ***
                 Static hostname: raspberrypi
                       Icon name: computer
                          Kernel: Linux 6.6.51+rpt-rpi-v8
                    Architecture: arm64
                OS is similar to:
                Model           : Raspberry Pi 4 Model B Rev 1.2
                Docker          : false
                Virtualization  : none
                Kernel          : aarch64
                Userland        : 64 bit
                Systemuptime and Load:
                 16:58:10 up 1 min,  2 users,  load average: 1.41, 0.42, 0.15
                CPU threads: 4
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** Time and Time Zones ***
                               Local time: Sun 2024-10-06 16:58:10 CEST
                           Universal time: Sun 2024-10-06 14:58:10 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** Users and Groups ***
                User that called 'iob diag':
                pi
                HOME=/home/pi
                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                iobroker
                HOME=/home/iobroker
                GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                *** Display-Server-Setup ***
                Display-Server: false
                Desktop:
                Terminal:       tty
                Boot Target:    multi-user.target
                *** MEMORY ***
                Mem:            4.0G        370M        3.4G        1.2M        304M        3.6G
                Swap:           209M          0B        209M
                Total:          4.2G        370M        3.6G
                Active iob-Instances:   2
                         3791 M total memory
                          353 M used memory
                          360 M active memory
                          123 M inactive memory
                         3217 M free memory
                           44 M buffer memory
                          246 M swap cache
                          199 M total swap
                            0 M used swap
                          199 M free swap
                top - 16:58:10 up 1 min,  2 users,  load average: 1.41, 0.42, 0.15
                Tasks: 182 total,   2 running, 180 sleeping,   0 stopped,   0 zombie
                %Cpu(s): 33.3 us, 16.7 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :   3792.0 total,   3216.7 free,    354.9 used,    291.1 buff/cache
                MiB Swap:    200.0 total,    200.0 free,      0.0 used.   3437.1 avail Mem
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** FILESYSTEM ***
                udev           devtmpfs  1.6G     0  1.6G   0% /dev
                tmpfs          tmpfs     380M  1.2M  379M   1% /run
                /dev/mmcblk0p2 ext4       29G  4.3G   24G  16% /
                tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
                tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                [Sun Oct  6 16:57:02 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:F4:D7:06 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d3f39d23-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                [Sun Oct  6 16:57:04 2024] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                [Sun Oct  6 16:57:06 2024] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
                Show mounted filesystems:
                TARGET           SOURCE         FSTYPE OPTIONS
                /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                628M    /var/
                206M    /var/cache
                200M    /var/cache/apt
                166M    /var/lib
                134M    /var/lib/apt/lists
                Archived and active journals take up 55.6M in the file system.
                /opt/iobroker/backups:
                6.6M    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                235M    /opt/iobroker/iobroker-data/
                210M    /opt/iobroker/iobroker-data/files
                51M     /opt/iobroker/iobroker-data/files/javascript.admin
                48M     /opt/iobroker/iobroker-data/files/telegram.admin
                32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                21M     /opt/iobroker/iobroker-data/objects.jsonl
                15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
                7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
                7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
                USB-Devices by-id:
                No Devices found 'by-id'
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v20.18.0
                /usr/bin/node           v20.18.0
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                /usr/bin/corepack       0.29.3
                nodejs:
                  Installed: 20.18.0-1nodesource1
                  Candidate: 20.18.0-1nodesource1
                  Version table:
                 *** 20.18.0-1nodesource1 1001
                        500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                        100 /var/lib/dpkg/status
                     20.17.0-1nodesource1 1001
                     20.16.0-1nodesource1 1001
                     20.15.1-1nodesource1 1001
                     20.15.0-1nodesource1 1001
                     20.14.0-1nodesource1 1001
                     20.13.1-1nodesource1 1001
                     20.13.0-1nodesource1 1001
                     20.12.2-1nodesource1 1001
                     20.12.1-1nodesource1 1001
                     20.12.0-1nodesource1 1001
                     20.11.1-1nodesource1 1001
                     20.11.0-1nodesource1 1001
                     20.10.0-1nodesource1 1001
                     20.9.0-1nodesource1 1001
                     20.8.1-1nodesource1 1001
                     20.8.0-1nodesource1 1001
                     20.7.0-1nodesource1 1001
                     20.6.1-1nodesource1 1001
                     20.6.0-1nodesource1 1001
                     20.5.1-1nodesource1 1001
                     20.5.0-1nodesource1 1001
                     20.4.0-1nodesource1 1001
                     20.3.1-1nodesource1 1001
                     20.3.0-1nodesource1 1001
                     20.2.0-1nodesource1 1001
                     20.1.0-1nodesource1 1001
                     20.0.0-1nodesource1 1001
                     18.19.0+dfsg-6~deb12u2 500
                     18.19.0+dfsg-6~deb12u1 500
                No problems detected
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                admin:          6.3.5
                javascript:     6.1.4
                nodejs modules from github:     0
                Adapter State
                  system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
                + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                  system.adapter.bring.0                  : bring                 : raspberrypi                              - disabled
                  system.adapter.denon.0                  : denon                 : raspberrypi                              - disabled
                  system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                  system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              - disabled
                  system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
                  system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              - disabled
                  system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              - disabled, port: 18701
                  system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              - disabled, port: 12001
                  system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              - disabled, port: 12010
                  system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              - disabled
                  system.adapter.hue.0                    : hue                   : raspberrypi                              - disabled, port: 443
                  system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                  system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
                  system.adapter.info.0                   : info                  : raspberrypi                              - disabled
                  system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
                  system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              - disabled
                  system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
                  system.adapter.mihome.0                 : mihome                : raspberrypi                              - disabled, port: 9898, bind: 0.0.0.0
                  system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
                  system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
                  system.adapter.sonos.0                  : sonos                 : raspberrypi                              - disabled
                  system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
                  system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
                  system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
                  system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                  system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
                  system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                  system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                  system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  system.adapter.ws.0                     : ws                    : raspberrypi                              - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                  system.adapter.yahka.0                  : yahka                 : raspberrypi                              - disabled
                + instance is alive
                ioBroker-Repositories
                │ (index) │ name      │ url                                                     │ auto upgrade │
                │ 0       │ 'stable'  │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                │ 1       │ 'beta'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                │ 2       │ 'default' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                Active repo(s): stable
                Upgrade policy: none
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "admin"        : 7.1.5    , installed 6.3.5  [Updatable]
                Adapter    "alexa2"       : 3.26.5   , installed 3.23.2 [Updatable]
                Adapter    "backitup"     : 3.0.22   , installed 2.6.23 [Updatable]
                Adapter    "bring"        : 1.8.4    , installed 1.8.1  [Updatable]
                Adapter    "denon"        : 1.15.12  , installed 1.13.4 [Updatable]
                Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
                Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
                Adapter    "fullybrowser" : 3.0.12   , installed 2.1.2  [Updatable]
                Adapter    "hm-rega"      : 5.0.0    , installed 3.0.40 [Updatable]
                Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
                Adapter    "hue"          : 3.12.0   , installed 3.7.1  [Updatable]
                Adapter    "ical"         : 1.15.0   , installed 1.13.2 [Updatable]
                Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
                Adapter    "javascript"   : 8.8.3    , installed 6.1.4  [Updatable]
                Controller "js-controller": 6.0.11   , installed 6.0.11
                Adapter    "lgtv"         : 2.2.0    , installed 1.1.10 [Updatable]
                Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
                Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                Adapter    "socketio"     : 6.7.1    , installed 4.2.0  [Updatable]
                Adapter    "sonos"        : 3.0.0    , installed 2.3.1  [Updatable]
                Adapter    "telegram"     : 3.9.0    , installed 1.15.2 [Updatable]
                Adapter    "tr-064"       : 4.3.0    , installed 4.2.17 [Updatable]
                Adapter    "trashschedule": 3.3.0    , installed 2.2.0  [Updatable]
                Adapter    "vis-hqwidgets": 1.5.1    , installed 1.3.0  [Updatable]
                Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.1  [Updatable]
                Adapter    "web"          : 6.2.5    , installed 4.3.0  [Updatable]
                Adapter    "ws"           : 2.6.2    , installed 1.3.0  [Updatable]
                Adapter    "yahka"        : 1.0.3    , installed 0.13.1 [Updatable]
                Objects and States
                Objects:        9203
                States:         7435
                Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6493       673/iobroker.js-con
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6488       673/iobroker.js-con
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1777       681/sshd: /usr/sbin
                tcp6       0      0 :::22                   :::*                    LISTEN      0          1779       681/sshd: /usr/sbin
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5546       535/avahi-daemon: r
                udp        0      0 0.0.0.0:56761           0.0.0.0:*                           104        5548       535/avahi-daemon: r
                udp6       0      0 :::42211                :::*                                104        5549       535/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                104        5547       535/avahi-daemon: r
                udp6       0      0 fe80::dad5:b9d2:3d5:546 :::*                                0          1822       603/NetworkManager
                2024-10-06 16:59:03.703  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1228
                2024-10-06 16:59:03.703  - error: host.raspberrypi Caught by controller[0]:   throw err;
                2024-10-06 16:59:03.704  - error: host.raspberrypi Caught by controller[0]:   ^
                2024-10-06 16:59:03.704  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
                2024-10-06 16:59:03.704  - error: host.raspberrypi Caught by controller[0]: Require stack:
                2024-10-06 16:59:03.705  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                2024-10-06 16:59:03.705  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                2024-10-06 16:59:03.705  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1051:27)
                2024-10-06 16:59:03.706  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
                2024-10-06 16:59:03.706  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                2024-10-06 16:59:03.706  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                2024-10-06 16:59:03.706  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                2024-10-06 16:59:03.707  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                2024-10-06 16:59:03.707  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
                2024-10-06 16:59:03.707  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
                2024-10-06 16:59:03.707  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
                2024-10-06 16:59:03.707  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                2024-10-06 16:59:03.708  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                2024-10-06 16:59:03.708  - error: host.raspberrypi Caught by controller[0]: }
                2024-10-06 16:59:03.708  - error: host.raspberrypi Caught by controller[0]: Node.js v20.18.0
                2024-10-06 16:59:03.708  - error: host.raspberrypi instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2024-10-06 16:59:03.709  - info: host.raspberrypi Adapter system.adapter.web.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
                2024-10-06 16:59:03.710  - info: host.raspberrypi system.adapter.web.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"6.0.11"})
                2024-10-06 16:59:06.094  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
                2024-10-06 16:59:06.096  - info: host.raspberrypi iobroker npm-install: Installing iobroker.mihome-vacuum@3.8.8... (System call)
                  @bene241
                  iob update
                  iob upgrade all -y
                    Bene241 @Thomas Braun last edited by Bene241
                    @bene241
                    iob update
                    iob upgrade all -y
                    Super, ich komme wieder auf die Web-Oberfläche.
                    Vielen vielen Dank.
                    Woran hat das denn jetzt gelegen?
                    Zwei Fragen bleiben bei mir nun noch offen:
                    1. Das aktuell aufgespielte war nun "leider" das ältere Backup, kann ich das gleiche Prozedere nun mit dem 10/2024 Backup durchspielen?
                    2. Aktuell komme ich nicht auf die Vis-Oberfläche.
                      Bei "http://192.168.178.65:8082/vis/edit.html" sagt der "File edit.html not found: {}"
                      Instanz vis.0 zeigt wenn man auf Einstellungen klickt:
                    Nochmal Danke!
                    Thomas Braun B 2 Replies Last reply Reply Quote 0
                      @bene241 sagte in ioBroker Web nach Backitup nicht erreichbar:
                      An deinem steinalten System. Halt die Kiste R E G E L M Ä S S I G auf Stand.
                        Bene241 @Bene241 last edited by
                        Nochmal Danke!
                        Zu 1:
                        Hat funktioniert, mit dem gleichen Weg wie oben mit dem älteren Update.
                        Zu 2:
                        Funktioniert nun auch wieder nach dem aufspielen des neueren Backups.
                        Danke an Alle!
                        Meister Mopper Thomas Braun 2 Replies Last reply Reply Quote 0
                        • Meister Mopper
                          Meister Mopper @Bene241 last edited by
                          Danke an Alle!
                          Na dann setze bitte den thread im Titel auf [gelöst], dann können andere ebenfalls profitieren.
                            @bene241
                            Dann zeig jetzt nochmal abschließend
                            iob diag
                            Die Zusammenfassung reicht.
                              @bene241
                              iob diag
                              Copy text starting here:
                              ```bash
                                                      v.2024-08-12
                                     Icon name: computer
                                  Architecture: arm64
                              Installation:           native
                              Kernel:                 aarch64
                              Userland:               64 bit
                              Timezone:               Europe/Berlin (CEST, +0200)
                              User-ID:                1000
                              Pending OS-Updates:     0
                              Pending iob updates:    0
                              Nodejs-Installation:
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              Recommended versions are nodejs 20.18.0 and npm 10.8.2
                              MEMORY:
                              Mem:            4.0G        2.0G        484M        282K        1.5G        2.0G
                              Swap:           209M        1.0M        208M
                              Total:          4.2G        2.0G        692M
                              Active iob-Instances:   28
                              ioBroker Core:          js-controller           6.0.11
                                                      admin                   7.1.5
                              Objects type: jsonl
                              States  type: jsonl
                              + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              Objects:                9307
                              States:                 7580
                              Size of iob-Database:
                              25M     /opt/iobroker/iobroker-data/objects.jsonl
                              13M     /opt/iobroker/iobroker-data/states.jsonl
                                @bene241
                                Passt. Ab jetzt regelmäßig aktuell halten und auch regelmäßig Backups machen.
                                Mit dem Backitup-Adapter kann man das automatisch vornehmen lassen.
                                81.1k
                                admin backitup backup restore
                                1323
