    4. Nach Update Anmeldung nicht mehr möglich
      Thomas Braun Most Active @alexanderbrix last edited by
      @alexanderbrix
      Hier kein Problem, die 7.2.2 läuft wie auch die 7.2.1 schon
        ag @Eaglefire last edited by ag
        Hallo.
        Habe eben Admin Version 7.22 installiert. danach Anmeldung nicht mehr möglich
        Auszug aus dem Log:
        f
        admin.0
        	2024-10-07 08:34:59.290	info	received all objects
        admin.0
        	2024-10-07 08:34:58.682	error	Cannot init i18n: Error: Cannot find i18n directory
        admin.0
        	2024-10-07 08:34:58.619	info	requesting all objects
        admin.0
        	2024-10-07 08:34:58.599	info	starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0-alpha.0-20240926-91f9b082f
        host.RPI5Test
        	2024-10-07 08:34:57.785	info	instance system.adapter.admin.1 in version "7.2.2" started with pid 65770
        host.RPI5Test
        	2024-10-07 08:34:57.378	info	instance system.adapter.admin.0 in version "7.2.2" started with pid 65763
        host.RPI5Test
        	2024-10-07 08:34:27.020	info	Restart adapter system.adapter.admin.0 because enabled
        host.RPI5Test
        	2024-10-07 08:34:27.020	error	instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.RPI5Test
        	2024-10-07 08:34:27.020	error	Caught by controller[0]: at WebSocketServer.emit (node:domain:488:12)
        host.RPI5Test
        	2024-10-07 08:34:27.020	error	Caught by controller[0]: at WebSocketServer.emit (node:events:519:28)
        host.RPI5Test
        	2024-10-07 08:34:27.020	error	Caught by controller[0]: at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
        host.RPI5Test
        	2024-10-07 08:34:27.020	error	Caught by controller[0]: at Array.forEach (<anonymous>)
        host.RPI5Test
        	2024-10-07 08:34:27.020	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
        host.RPI5Test
        	2024-10-07 08:34:27.020	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
        host.RPI5Test
        	2024-10-07 08:34:27.020	error	Caught by controller[0]: at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
        host.RPI5Test
        	2024-10-07 08:34:27.020	error	Caught by controller[0]: at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
        host.RPI5Test
        	2024-10-07 08:34:27.020	error	Caught by controller[0]: at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1374:19)
        host.RPI5Test
        	2024-10-07 08:34:27.020	error	Caught by controller[0]: at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
        host.RPI5Test
        	2024-10-07 08:34:27.019	error	Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
        admin.0
        	2024-10-07 08:34:26.704	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        admin.0
        	2024-10-07 08:34:26.703	info	terminating
        admin.0
        	2024-10-07 08:34:26.702	info	terminating http server on port 8081
        admin.0
        	2024-10-07 08:34:26.692	error	Parameter "id" needs to be of type "string" but type "number" has been passed
        admin.0
        	2024-10-07 08:34:26.691	error	Error: Parameter "id" needs to be of type "string" but type "number" has been passed at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19) at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1374:19) at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33) at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22) at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22 at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64 at Array.forEach (<anonymous>) at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50) at WebSocketServer.emit (node:events:519:28) at WebSocketServer.emit (node:domain:488:12)
        admin.0
        	2024-10-07 08:34:26.691	error	uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
        admin.0
        	2024-10-07 08:33:48.835	info	Use link "http://127.0.0.1:8081" to configure.
        admin.0
        	2024-10-07 08:33:48.835	info	http server listening on port 8081
        admin.0
        	2024-10-07 08:33:48.833	info	socket.io server listening on port 8081
        admin.0
        	2024-10-07 08:33:48.454	info	received all objects
        admin.0
        	2024-10-07 08:33:47.858	error	Cannot init i18n: Error: Cannot find i18n directory
        admin.0
        	2024-10-07 08:33:47.800	info	requesting all objects
        admin.0
        	2024-10-07 08:33:47.783	info	starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0-alpha.0-20240926-91f9b082f
        Edit:
        die Instanz admin.1 hab ich danach zu testzwecken installiert.
        Wenn ich diese dann starte und die instanz 0 stoppen komme ich auf die Admin-Oberfläche.
        ag
          el_rob @Thomas Braun last edited by
          @thomas-braun Sorry, komme erst jetzt dazu... Bei Adapterversion 7.2.2 besteht bei mir das Problem immer noch. Hier das Log (bereinigt um irrelevante Einträge):
          2024-10-07 09:54:40.206  - info: admin.0 (3048266) starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v18.20.4, js-controller: 6.0.11
          2024-10-07 09:54:40.225  - info: admin.0 (3048266) requesting all objects
          2024-10-07 09:54:40.260  - error: admin.0 (3048266) Cannot init i18n: Error: Cannot find i18n directory
          2024-10-07 09:54:41.457  - info: admin.0 (3048266) received all objects
          2024-10-07 09:54:41.707  - info: admin.0 (3048266) socket.io server listening on port 8081
          2024-10-07 09:54:41.708  - info: admin.0 (3048266) http server listening on port 8081
          2024-10-07 09:54:41.709  - info: admin.0 (3048266) Use link "http://127.0.0.1:8081" to configure.
          2024-10-07 09:54:46.557  - error: admin.0 (3048266) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 09:54:46.557  - error: admin.0 (3048266) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
              at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1373:19)
              at WebSocketServer.emit (node:events:517:28)
              at WebSocketServer.emit (node:domain:489:12)
          2024-10-07 09:54:46.557  - error: admin.0 (3048266) Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 09:54:46.564  - info: admin.0 (3048266) terminating http server on port 8081
          2024-10-07 09:54:46.565  - info: admin.0 (3048266) terminating
          2024-10-07 09:54:46.566  - warn: admin.0 (3048266) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
          2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1373:19)
          2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
          2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
          2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
          2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
          2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at Array.forEach (<anonymous>)
          2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
          2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at WebSocketServer.emit (node:events:517:28)
          2024-10-07 09:54:46.799  - error: host.iobroker Caught by controller[0]:     at WebSocketServer.emit (node:domain:489:12)
          2024-10-07 09:54:46.799  - error: host.iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-10-07 09:54:46.799  - info: host.iobroker Restart adapter system.adapter.admin.0 because enabled
          2024-10-07 09:55:17.142  - info: host.iobroker instance system.adapter.admin.0 in version "7.2.2" started with pid 3049825
          2024-10-07 09:55:18.356  - info: admin.0 (3049825) starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v18.20.4, js-controller: 6.0.11
          2024-10-07 09:55:18.375  - info: admin.0 (3049825) requesting all objects
          2024-10-07 09:55:18.410  - error: admin.0 (3049825) Cannot init i18n: Error: Cannot find i18n directory
          2024-10-07 09:55:19.642  - info: admin.0 (3049825) received all objects
          2024-10-07 09:55:19.748  - info: squeezeboxrpc.0 (1192) State value to set for "squeezeboxrpc.0.Server.LastScan" has to be type "number" but received type "string"
          2024-10-07 09:55:19.783  - info: admin.0 (3049825) socket.io server listening on port 8081
          2024-10-07 09:55:19.784  - info: admin.0 (3049825) http server listening on port 8081
          2024-10-07 09:55:19.784  - info: admin.0 (3049825) Use link "http://127.0.0.1:8081" to configure.
          2024-10-07 09:55:24.543  - error: admin.0 (3049825) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 09:55:24.543  - error: admin.0 (3049825) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 09:55:24.543  - error: admin.0 (3049825) Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 09:55:24.550  - info: admin.0 (3049825) terminating http server on port 8081
          2024-10-07 09:55:24.551  - info: admin.0 (3049825) terminating
          2024-10-07 09:55:24.552  - warn: admin.0 (3049825) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2024-10-07 09:55:24.803  - error: host.iobroker Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
          2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
          2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1373:19)
          2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
          2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
          2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
          2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
          2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at Array.forEach (<anonymous>)
          2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
          2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at WebSocketServer.emit (node:events:517:28)
          2024-10-07 09:55:24.804  - error: host.iobroker Caught by controller[0]:     at WebSocketServer.emit (node:domain:489:12)
          2024-10-07 09:55:24.804  - error: host.iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-10-07 09:55:24.804  - info: host.iobroker Restart adapter system.adapter.admin.0 because enabled
            TT-Tom last edited by TT-Tom
            habe den Test mit dem js-controller 7.0.0, Admin 7.2.1 und Nodejs 20.18.0 durchgeführt. Das Log sieht den andren gleich aus.
            2024-10-07 11:30:55.346  - info: host.iobtest Restart adapter system.adapter.admin.0 because enabled
            2024-10-07 11:31:25.572  - info: host.iobtest instance system.adapter.admin.0 in version "7.2.1" started with pid 9133
            2024-10-07 11:31:26.332  - info: admin.0 (9133) starting. Version 7.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0
            2024-10-07 11:31:26.347  - info: admin.0 (9133) requesting all objects
            2024-10-07 11:31:26.385  - error: admin.0 (9133) Cannot init i18n: Error: Cannot find i18n directory
            2024-10-07 11:31:26.753  - info: admin.0 (9133) received all objects
            2024-10-07 11:31:26.877  - info: admin.0 (9133) socket.io server listening on port 8081
            2024-10-07 11:31:26.878  - info: admin.0 (9133) http server listening on port 8081
            2024-10-07 11:31:26.878  - info: admin.0 (9133) Use link "http://127.0.0.1:8081" to configure.
            2024-10-07 11:31:31.081  - error: admin.0 (9133) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
            2024-10-07 11:31:31.081  - error: admin.0 (9133) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
            2024-10-07 11:31:31.081  - error: admin.0 (9133) Parameter "id" needs to be of type "string" but type "number" has been passed
            2024-10-07 11:31:31.089  - info: admin.0 (9133) terminating http server on port 8081
            2024-10-07 11:31:31.090  - warn: admin.0 (9133) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
            2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
            2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1374:19)
            2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
            2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
            2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
            2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
            2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at Array.forEach (<anonymous>)
            2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
            2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
            2024-10-07 11:31:31.442  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
            2024-10-07 11:31:31.442  - error: host.iobtest instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2024-10-07 11:31:31.442  - info: host.iobtest Restart adapter system.adapter.admin.0 because enabled
            gleiches Verhalten mit Version 7.2.2
            2024-10-07 11:38:26.917  - info: host.iobtest instance system.adapter.admin.0 in version "7.2.2" started with pid 9648
            2024-10-07 11:38:27.722  - info: admin.0 (9648) starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0
            2024-10-07 11:38:27.737  - info: admin.0 (9648) requesting all objects
            2024-10-07 11:38:27.776  - error: admin.0 (9648) Cannot init i18n: Error: Cannot find i18n directory
            2024-10-07 11:38:28.145  - info: admin.0 (9648) received all objects
            2024-10-07 11:38:28.348  - info: admin.0 (9648) socket.io server listening on port 8081
            2024-10-07 11:38:28.349  - info: admin.0 (9648) http server listening on port 8081
            2024-10-07 11:38:28.350  - info: admin.0 (9648) Use link "http://127.0.0.1:8081" to configure.
            2024-10-07 11:38:29.654  - error: admin.0 (9648) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
            2024-10-07 11:38:29.654  - error: admin.0 (9648) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
            2024-10-07 11:38:29.654  - error: admin.0 (9648) Parameter "id" needs to be of type "string" but type "number" has been passed
            2024-10-07 11:38:29.662  - info: admin.0 (9648) terminating http server on port 8081
            2024-10-07 11:38:29.663  - warn: admin.0 (9648) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
            2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
            2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1374:19)
            2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
            2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
            2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
            2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
            2024-10-07 11:38:30.015  - error: host.iobtest Caught by controller[0]:     at Array.forEach (<anonymous>)
            2024-10-07 11:38:30.016  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
            2024-10-07 11:38:30.016  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
            2024-10-07 11:38:30.016  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
            2024-10-07 11:38:30.016  - error: host.iobtest instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2024-10-07 11:38:30.016  - info: host.iobtest Restart adapter system.adapter.admin.0 because enabled
              Thomas Braun Most Active @TT-Tom last edited by
              Scheint mir ein Fehler mit der Authentifzierung bei admins mit SSL/https zu sein.
              A T E 3 Replies Last reply Reply Quote 0
                ag @Thomas Braun last edited by
                @thomas-braun sagte in Nach Update Anmeldung nicht mehr möglich:
                Habe Authentifizierung ausgeschaltet und dann auf 7.2.2 upgedatet.
                Admin wird problemlos angezeigt
                ag
                  TT-Tom @Thomas Braun last edited by TT-Tom
                  ich nutze kein https, aber die Anmeldung als Admin. Werde es auch mal ohne versuchen.
                  ohne Authentifizierung funktioniert das Update auf 7.2.2.
                  habe danach die Authentifizierung wieder aktiviert und folgendes Log erhalten mit den Resultat, dass man sich nicht mehr einloggen kann und der Admin in einer Schleife wieder hängt.
                  2024-10-07 13:19:06.612  - info: admin.0 (10274) starting. Version 7.2.0 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0
                  2024-10-07 13:19:06.627  - info: admin.0 (10274) requesting all objects
                  2024-10-07 13:19:06.666  - error: admin.0 (10274) Cannot init i18n: Error: Cannot find i18n directory
                  2024-10-07 13:19:07.037  - info: admin.0 (10274) received all objects
                  2024-10-07 13:19:07.161  - info: admin.0 (10274) socket.io server listening on port 8081
                  2024-10-07 13:19:07.161  - info: admin.0 (10274) http server listening on port 8081
                  2024-10-07 13:19:07.162  - info: admin.0 (10274) Use link "http://127.0.0.1:8081" to configure.
                  2024-10-07 13:19:08.974  - info: admin.0 (10274) ==> Connected system.user.admin from ::ffff:192.168.178.11
                  2024-10-07 13:19:26.550  - info: fahrplan.0 (8780) Updated 2 routes, 2 enabled and 0 disabled
                  2024-10-07 13:19:26.792  - info: fahrplan.0 (8780) Updated 1 departure timetables, 1 enabled and 0 disabled
                  2024-10-07 13:19:29.572  - info: host.iobtest "system.adapter.admin.0" disabled
                  2024-10-07 13:19:29.573  - info: host.iobtest stopInstance system.adapter.admin.0 (force=false, process=true)
                  2024-10-07 13:19:29.575  - info: admin.0 (10274) Got terminate signal TERMINATE_YOURSELF
                  2024-10-07 13:19:29.575  - info: admin.0 (10274) terminating http server on port 8081
                  2024-10-07 13:19:29.577  - info: admin.0 (10274) terminating
                  2024-10-07 13:19:29.577  - info: admin.0 (10274) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2024-10-07 13:19:29.614  - info: host.iobtest stopInstance system.adapter.admin.0 send kill signal
                  2024-10-07 13:19:30.078  - info: admin.0 (10274) terminating
                  2024-10-07 13:19:30.100  - info: host.iobtest instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2024-10-07 13:19:32.575  - info: host.iobtest [WEBSERVER_UPGRADE] (admin) Server is running on http://localhost:8081
                  2024-10-07 13:19:35.917  - info: host.iobtest [WEBSERVER_UPGRADE] (admin) Successfully upgraded admin to version 7.2.2
                  2024-10-07 13:19:36.350  - info: host.iobtest [WEBSERVER_UPGRADE] (admin) Final information delivered
                  2024-10-07 13:19:36.355  - info: host.iobtest "system.adapter.admin.0" enabled
                  2024-10-07 13:19:36.355  - info: host.iobtest [WEBSERVER_UPGRADE] (admin) Successfully started adapter
                  2024-10-07 13:19:36.588  - info: host.iobtest instance system.adapter.admin.0 in version "7.2.2" started with pid 10336
                  2024-10-07 13:19:37.318  - info: admin.0 (10336) starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0
                  2024-10-07 13:19:37.333  - info: admin.0 (10336) requesting all objects
                  2024-10-07 13:19:37.371  - error: admin.0 (10336) Cannot init i18n: Error: Cannot find i18n directory
                  2024-10-07 13:19:37.744  - info: admin.0 (10336) received all objects
                  2024-10-07 13:19:37.858  - info: admin.0 (10336) socket.io server listening on port 8081
                  2024-10-07 13:19:37.858  - info: admin.0 (10336) http server listening on port 8081
                  2024-10-07 13:19:37.859  - info: admin.0 (10336) Use link "http://127.0.0.1:8081" to configure.
                  2024-10-07 13:19:40.480  - info: admin.0 (10336) ==> Connected system.user.admin from ::ffff:192.168.178.11
                  2024-10-07 13:19:41.606  - info: admin.0 (10336) <== Disconnect system.user.admin from ::ffff:192.168.178.11 admin
                  2024-10-07 13:19:42.118  - info: admin.0 (10336) ==> Connected system.user.admin from ::ffff:192.168.178.11
                  2024-10-07 13:20:15.922  - info: host.iobtest stopInstance system.adapter.admin.0 (force=false, process=true)
                  2024-10-07 13:20:15.925  - info: admin.0 (10336) Got terminate signal TERMINATE_YOURSELF
                  2024-10-07 13:20:15.926  - info: admin.0 (10336) terminating http server on port 8081
                  2024-10-07 13:20:15.929  - info: admin.0 (10336) terminating
                  2024-10-07 13:20:15.930  - info: admin.0 (10336) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2024-10-07 13:20:15.964  - info: host.iobtest stopInstance system.adapter.admin.0 send kill signal
                  2024-10-07 13:20:16.429  - info: admin.0 (10336) terminating
                  2024-10-07 13:20:16.453  - info: host.iobtest instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2024-10-07 13:20:19.656  - info: host.iobtest instance system.adapter.admin.0 in version "7.2.2" started with pid 10404
                  2024-10-07 13:20:20.390  - info: admin.0 (10404) starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0
                  2024-10-07 13:20:20.404  - info: admin.0 (10404) requesting all objects
                  2024-10-07 13:20:20.443  - error: admin.0 (10404) Cannot init i18n: Error: Cannot find i18n directory
                  2024-10-07 13:20:20.823  - info: admin.0 (10404) received all objects
                  2024-10-07 13:20:20.945  - info: admin.0 (10404) socket.io server listening on port 8081
                  2024-10-07 13:20:20.946  - info: admin.0 (10404) http server listening on port 8081
                  2024-10-07 13:20:20.946  - info: admin.0 (10404) Use link "http://127.0.0.1:8081" to configure.
                  2024-10-07 13:20:22.775  - error: admin.0 (10404) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
                  2024-10-07 13:20:22.775  - error: admin.0 (10404) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                  2024-10-07 13:20:22.775  - error: admin.0 (10404) Parameter "id" needs to be of type "string" but type "number" has been passed
                  2024-10-07 13:20:22.783  - info: admin.0 (10404) terminating http server on port 8081
                  2024-10-07 13:20:22.784  - warn: admin.0 (10404) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  2024-10-07 13:20:23.112  - error: host.iobtest Caught by controller[1]: strict mode: missing type "object" for keyword "properties" at "#/if" (strictTypes)
                  2024-10-07 13:20:23.112  - error: host.iobtest Caught by controller[2]: strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
                  2024-10-07 13:20:23.112  - error: host.iobtest Caught by controller[3]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.112  - error: host.iobtest Caught by controller[4]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.112  - error: host.iobtest Caught by controller[5]: strict mode: required property "items" is not defined at "#/properties/items/patternProperties/%5E.%2B/allOf/9/then/oneOf/0" (strictRequired)
                  2024-10-07 13:20:23.112  - error: host.iobtest Caught by controller[6]: strict mode: required property "#include" is not defined at "#/properties/items/patternProperties/%5E.%2B/allOf/9/then/oneOf/1" (strictRequired)
                  2024-10-07 13:20:23.112  - error: host.iobtest Caught by controller[7]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.112  - error: host.iobtest Caught by controller[8]: strict mode: required property "items" is not defined at "#/patternProperties/%5E.%2B/allOf/9/then/oneOf/0" (strictRequired)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[9]: strict mode: required property "#include" is not defined at "#/patternProperties/%5E.%2B/allOf/9/then/oneOf/1" (strictRequired)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[10]: strict mode: missing type "object" for keyword "required" at "#/definitions/sendToProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[10]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/sendToProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[11]: strict mode: missing type "object" for keyword "properties" at "#/definitions/sendToProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[12]: strict mode: missing type "object" for keyword "required" at "#/definitions/stateProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[12]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/stateProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[13]: strict mode: missing type "object" for keyword "properties" at "#/definitions/stateProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[14]: strict mode: missing type "object" for keyword "required" at "#/definitions/passwordProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[15]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/passwordProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[15]: strict mode: missing type "object" for keyword "properties" at "#/definitions/passwordProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[16]: strict mode: missing type "object" for keyword "required" at "#" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[16]: strict mode: missing type "object" for keyword "additionalProperties" at "#" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[17]: strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[18]: strict mode: missing type "object" for keyword "required" at "#/definitions/checkboxProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[18]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/checkboxProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[19]: strict mode: missing type "object" for keyword "properties" at "#/definitions/checkboxProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[20]: strict mode: missing type "object" for keyword "required" at "#/definitions/fileSelectorProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[21]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/fileSelectorProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[21]: strict mode: missing type "object" for keyword "properties" at "#/definitions/fileSelectorProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[22]: strict mode: missing type "object" for keyword "required" at "#/definitions/numberProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[23]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/numberProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[23]: strict mode: missing type "object" for keyword "properties" at "#/definitions/numberProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[24]: strict mode: missing type "object" for keyword "required" at "#/definitions/aliveProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[25]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/aliveProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[25]: strict mode: missing type "object" for keyword "properties" at "#/definitions/aliveProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[26]: strict mode: missing type "object" for keyword "required" at "#/definitions/qrCodeProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[26]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/qrCodeProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[27]: strict mode: missing type "object" for keyword "properties" at "#/definitions/qrCodeProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/cronProps" (strictTypes)
                  2024-10-07 13:20:23.113  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "properties" at "#/definitions/cronProps" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/0" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: required property "complex" is not defined at "#/definitions/cronProps/oneOf/0" (strictRequired)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/1" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: required property "simple" is not defined at "#/definitions/cronProps/oneOf/1" (strictRequired)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "required" at "#/definitions/deviceManagerProps" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/deviceManagerProps" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "properties" at "#/definitions/deviceManagerProps" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "required" at "#" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "additionalProperties" at "#" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[28]: strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[29]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[30]: strict mode: missing type "object" for keyword "additionalProperties" at "#" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[30]: strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[31]: strict mode: use allowUnionTypes to allow union type keyword at "#/properties/width" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[32]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[33]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[34]: strict mode: required property "items" is not defined at "#/items/allOf/10/then/allOf/1/oneOf/0" (strictRequired)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[35]: strict mode: required property "#include" is not defined at "#/items/allOf/10/then/allOf/1/oneOf/1" (strictRequired)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[36]: strict mode: missing type "object" for keyword "required" at "#/definitions/aliveProps" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[36]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/aliveProps" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[37]: strict mode: missing type "object" for keyword "properties" at "#/definitions/aliveProps" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[38]: strict mode: required property "complex" is not defined at "#/items/allOf/21/then/oneOf/0" (strictRequired)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[39]: strict mode: required property "simple" is not defined at "#/items/allOf/21/then/oneOf/1" (strictRequired)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[40]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[41]: strict mode: missing type "object" for keyword "required" at "#/definitions/certificatesProps" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[41]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/certificatesProps" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[42]: strict mode: missing type "object" for keyword "properties" at "#/definitions/certificatesProps" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[43]: strict mode: missing type "object" for keyword "required" at "#" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[43]: strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[44]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.114  - error: host.iobtest Caught by controller[45]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[46]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[47]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[48]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[49]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[50]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[51]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[52]: strict mode: missing type "object" for keyword "required" at "#/definitions/certificatesProps" (strictTypes)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[52]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/certificatesProps" (strictTypes)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[53]: strict mode: missing type "object" for keyword "properties" at "#/definitions/certificatesProps" (strictTypes)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[54]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[55]: strict mode: missing type "object" for keyword "required" at "#/definitions/instanceProps" (strictTypes)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[55]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/instanceProps" (strictTypes)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[56]: strict mode: missing type "object" for keyword "properties" at "#/definitions/instanceProps" (strictTypes)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[57]: strict mode: missing type "object" for keyword "required" at "#/definitions/objectIdProps" (strictTypes)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[58]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/objectIdProps" (strictTypes)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[58]: strict mode: missing type "object" for keyword "properties" at "#/definitions/objectIdProps" (strictTypes)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[59]: strict mode: missing type "object" for keyword "required" at "#/definitions/timePickerProps" (strictTypes)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[59]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/timePickerProps" (strictTypes)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[59]: strict mode: missing type "object" for keyword "properties" at "#/definitions/timePickerProps" (strictTypes)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[59]: strict mode: missing type "object" for keyword "required" at "#/definitions/coordinatesProps" (strictTypes)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[59]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/coordinatesProps" (strictTypes)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[59]: strict mode: missing type "object" for keyword "properties" at "#/definitions/coordinatesProps" (strictTypes)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[60]: strict mode: missing type "object" for keyword "required" at "#/definitions/interfaceProps" (strictTypes)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[61]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/interfaceProps" (strictTypes)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[61]: strict mode: missing type "object" for keyword "properties" at "#/definitions/interfaceProps" (strictTypes)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[62]: strict mode: missing type "object" for keyword "required" at "#/definitions/stateProps" (strictTypes)
                  2024-10-07 13:20:23.115  - error: host.iobtest Caught by controller[62]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/stateProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[63]: strict mode: missing type "object" for keyword "properties" at "#/definitions/stateProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[64]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[65]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[66]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[67]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[68]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[69]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[70]: strict mode: missing type "object" for keyword "required" at "#/definitions/sendToProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[70]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/sendToProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[71]: strict mode: missing type "object" for keyword "properties" at "#/definitions/sendToProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[72]: strict mode: missing type "object" for keyword "required" at "#/definitions/stateProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[72]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/stateProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[73]: strict mode: missing type "object" for keyword "properties" at "#/definitions/stateProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[74]: strict mode: missing type "object" for keyword "required" at "#/definitions/passwordProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[75]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/passwordProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[75]: strict mode: missing type "object" for keyword "properties" at "#/definitions/passwordProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[76]: strict mode: missing type "object" for keyword "required" at "#/definitions/checkboxProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[76]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/checkboxProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[77]: strict mode: missing type "object" for keyword "properties" at "#/definitions/checkboxProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[78]: strict mode: missing type "object" for keyword "required" at "#/definitions/fileSelectorProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[78]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/fileSelectorProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[79]: strict mode: missing type "object" for keyword "properties" at "#/definitions/fileSelectorProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[80]: strict mode: missing type "object" for keyword "required" at "#/definitions/numberProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[80]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/numberProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[81]: strict mode: missing type "object" for keyword "properties" at "#/definitions/numberProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[82]: strict mode: missing type "object" for keyword "required" at "#/definitions/aliveProps" (strictTypes)
                  2024-10-07 13:20:23.116  - error: host.iobtest Caught by controller[83]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/aliveProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[83]: strict mode: missing type "object" for keyword "properties" at "#/definitions/aliveProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[84]: strict mode: missing type "object" for keyword "required" at "#/definitions/qrCodeProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[85]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/qrCodeProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[85]: strict mode: missing type "object" for keyword "properties" at "#/definitions/qrCodeProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[86]: strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[87]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/cronProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[87]: strict mode: missing type "object" for keyword "properties" at "#/definitions/cronProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[88]: strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/0" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[89]: strict mode: required property "complex" is not defined at "#/definitions/cronProps/oneOf/0" (strictRequired)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[90]: strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/1" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[91]: strict mode: required property "simple" is not defined at "#/definitions/cronProps/oneOf/1" (strictRequired)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[92]: strict mode: missing type "object" for keyword "required" at "#/definitions/deviceManagerProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[93]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/deviceManagerProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[93]: strict mode: missing type "object" for keyword "properties" at "#/definitions/deviceManagerProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[94]: strict mode: missing type "object" for keyword "required" at "#/definitions/certificatesProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[94]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/certificatesProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[95]: strict mode: missing type "object" for keyword "properties" at "#/definitions/certificatesProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[96]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[97]: strict mode: missing type "object" for keyword "required" at "#/definitions/instanceProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[97]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/instanceProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[97]: strict mode: missing type "object" for keyword "properties" at "#/definitions/instanceProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[98]: strict mode: missing type "object" for keyword "required" at "#/definitions/objectIdProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[98]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/objectIdProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[98]: strict mode: missing type "object" for keyword "properties" at "#/definitions/objectIdProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[99]: strict mode: missing type "object" for keyword "required" at "#/definitions/timePickerProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[99]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/timePickerProps" (strictTypes)
                  2024-10-07 13:20:23.117  - error: host.iobtest Caught by controller[99]: strict mode: missing type "object" for keyword "properties" at "#/definitions/timePickerProps" (strictTypes)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[100]: strict mode: missing type "object" for keyword "required" at "#/definitions/coordinatesProps" (strictTypes)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[100]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/coordinatesProps" (strictTypes)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[101]: strict mode: missing type "object" for keyword "properties" at "#/definitions/coordinatesProps" (strictTypes)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[102]: strict mode: missing type "object" for keyword "required" at "#/definitions/interfaceProps" (strictTypes)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[102]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/interfaceProps" (strictTypes)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[103]: strict mode: missing type "object" for keyword "properties" at "#/definitions/interfaceProps" (strictTypes)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[104]: strict mode: missing type "object" for keyword "required" at "#/definitions/stateProps" (strictTypes)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[105]: strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/stateProps" (strictTypes)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[105]: strict mode: missing type "object" for keyword "properties" at "#/definitions/stateProps" (strictTypes)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[106]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[107]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[108]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[109]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[110]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[111]: strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1374:19)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at Array.forEach (<anonymous>)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at WebSocketServer.emit (node:events:519:28)
                  2024-10-07 13:20:23.118  - error: host.iobtest Caught by controller[112]:     at WebSocketServer.emit (node:domain:488:12)
                  2024-10-07 13:20:23.118  - error: host.iobtest instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2024-10-07 13:20:23.118  - info: host.iobtest Restart adapter system.adapter.admin.0 because enabled
                  2024-10-07 13:20:53.346  - info: host.iobtest instance system.adapter.admin.0 in version "7.2.2" started with pid 10437
                  2024-10-07 13:20:54.082  - info: admin.0 (10437) starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0
                  2024-10-07 13:20:54.096  - info: admin.0 (10437) requesting all objects
                  2024-10-07 13:20:54.135  - error: admin.0 (10437) Cannot init i18n: Error: Cannot find i18n directory
                  2024-10-07 13:20:54.510  - info: admin.0 (10437) received all objects
                  2024-10-07 13:20:54.637  - info: admin.0 (10437) socket.io server listening on port 8081
                  2024-10-07 13:20:54.638  - info: admin.0 (10437) http server listening on port 8081
                  2024-10-07 13:20:54.638  - info: admin.0 (10437) Use link "http://127.0.0.1:8081" to configure.
                  2024-10-07 13:21:29.058  - error: admin.0 (10437) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
                  2024-10-07 13:21:29.058  - error: admin.0 (10437) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                  2024-10-07 13:21:29.058  - error: admin.0 (10437) Parameter "id" needs to be of type "string" but type "number" has been passed
                  2024-10-07 13:21:29.066  - info: admin.0 (10437) terminating http server on port 8081
                  2024-10-07 13:21:29.067  - info: admin.0 (10437) terminating
                  2024-10-07 13:21:29.067  - warn: admin.0 (10437) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                  2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
                  2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1374:19)
                  2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
                  2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
                  2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
                  2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
                  2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at Array.forEach (<anonymous>)
                  2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
                  2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
                  2024-10-07 13:21:29.503  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
                  2024-10-07 13:21:29.503  - error: host.iobtest instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2024-10-07 13:21:29.504  - info: host.iobtest Restart adapter system.adapter.admin.0 because enabled
                  2024-10-07 13:21:59.721  - info: host.iobtest instance system.adapter.admin.0 in version "7.2.2" started with pid 10476
                  2024-10-07 13:22:00.471  - info: admin.0 (10476) starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0
                  2024-10-07 13:22:00.485  - info: admin.0 (10476) requesting all objects
                  2024-10-07 13:22:00.524  - error: admin.0 (10476) Cannot init i18n: Error: Cannot find i18n directory
                  2024-10-07 13:22:00.899  - info: admin.0 (10476) received all objects
                  2024-10-07 13:22:01.029  - info: admin.0 (10476) socket.io server listening on port 8081
                  2024-10-07 13:22:01.030  - info: admin.0 (10476) http server listening on port 8081
                  2024-10-07 13:22:01.031  - info: admin.0 (10476) Use link "http://127.0.0.1:8081" to configure.
                  2024-10-07 13:22:05.403  - error: admin.0 (10476) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
                  2024-10-07 13:22:05.403  - error: admin.0 (10476) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                  2024-10-07 13:22:05.404  - error: admin.0 (10476) Parameter "id" needs to be of type "string" but type "number" has been passed
                  2024-10-07 13:22:05.411  - info: admin.0 (10476) terminating http server on port 8081
                  2024-10-07 13:22:05.412  - info: admin.0 (10476) terminating
                  2024-10-07 13:22:05.412  - warn: admin.0 (10476) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  2024-10-07 13:22:05.730  - error: host.iobtest Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                  2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
                  2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1374:19)
                  2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
                  2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
                  2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
                  2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
                  2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at Array.forEach (<anonymous>)
                  2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
                  2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
                  2024-10-07 13:22:05.731  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
                  2024-10-07 13:22:05.731  - error: host.iobtest instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2024-10-07 13:22:05.731  - info: host.iobtest Restart adapter system.adapter.admin.0 because enabled
                  2024-10-07 13:22:35.960  - info: host.iobtest instance system.adapter.admin.0 in version "7.2.2" started with pid 10509
                  2024-10-07 13:22:36.702  - info: admin.0 (10509) starting. Version 7.2.2 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 7.0.0
                  2024-10-07 13:22:36.717  - info: admin.0 (10509) requesting all objects
                  2024-10-07 13:22:36.755  - error: admin.0 (10509) Cannot init i18n: Error: Cannot find i18n directory
                  2024-10-07 13:22:37.139  - info: admin.0 (10509) received all objects
                  2024-10-07 13:22:37.255  - info: admin.0 (10509) socket.io server listening on port 8081
                  2024-10-07 13:22:37.256  - info: admin.0 (10509) http server listening on port 8081
                  2024-10-07 13:22:37.256  - info: admin.0 (10509) Use link "http://127.0.0.1:8081" to configure.
                  2024-10-07 13:22:41.460  - error: admin.0 (10509) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
                  2024-10-07 13:22:41.460  - error: admin.0 (10509) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                  2024-10-07 13:22:41.461  - error: admin.0 (10509) Parameter "id" needs to be of type "string" but type "number" has been passed
                  2024-10-07 13:22:41.468  - info: admin.0 (10509) terminating http server on port 8081
                  2024-10-07 13:22:41.469  - info: admin.0 (10509) terminating
                  2024-10-07 13:22:41.469  - warn: admin.0 (10509) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                  2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
                  2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1374:19)
                  2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
                  2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
                  2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
                  2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
                  2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at Array.forEach (<anonymous>)
                  2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
                  2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:events:519:28)
                  2024-10-07 13:22:41.866  - error: host.iobtest Caught by controller[0]:     at WebSocketServer.emit (node:domain:488:12)
                  2024-10-07 13:22:41.867  - error: host.iobtest instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2024-10-07 13:22:41.867  - info: host.iobtest Restart adapter system.adapter.admin.0 because enabled
                  mit https und ohne Authentifizierung funktioniert der Admin in Version 7.2.2
                  jetzt könnte es am Password liegen, das bestimmte Zeichen oder länge nicht mehr passt.
                    el_rob @Thomas Braun last edited by
                    Bei meiner Installation ist HTTPS nicht aktiviert.
                      tomatenforever @el_rob last edited by
                      @el_rob Guten Abend, Ich habe das gleiche Problem. Mein ioBroker läuft an sich im Hintergrund, jedoch ist die Webseite nicht mehr erreichbar... Lediglich der Ladebalken dreht die ganze Zeit.
                      Oct  7 20:24:05 raspberrypi bash[3479769]: Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                      Oct  7 20:24:05 raspberrypi bash[3479769]:     at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:238:19)
                      Oct  7 20:24:05 raspberrypi bash[3479769]:     at Admin.getSession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1373:19)
                      Oct  7 20:24:05 raspberrypi bash[3479769]:     at SocketAdmin.__getUserFromSocket (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:73:33)
                      Oct  7 20:24:05 raspberrypi bash[3479769]:     at SocketAdmin._initSocket (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommon.js:162:22)
                      Oct  7 20:24:05 raspberrypi bash[3479769]:     at /opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommon.js:104:22
                      Oct  7 20:24:05 raspberrypi bash[3479769]:     at /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:64
                      Oct  7 20:24:05 raspberrypi bash[3479769]:     at Array.forEach (<anonymous>)
                      Oct  7 20:24:05 raspberrypi bash[3479769]:     at WebSocketServer.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/ws-server/dist/index.js:246:50)
                      Oct  7 20:24:05 raspberrypi bash[3479769]:     at WebSocketServer.emit (node:events:519:28)
                      Oct  7 20:24:05 raspberrypi bash[3479769]:     at WebSocketServer.emit (node:domain:488:12)
                      Oct  7 20:24:06 raspberrypi systemd[1]: Stopping ioBroker Server...
                        Shadowhunter23 @tomatenforever last edited by Shadowhunter23
                        @tomatenforever
                        Zeig mal iob diag
                        Und mit iobroker upgrade admin@7.2.0 kommst du zurück zur 7.2.0
                        D T 2 Replies Last reply Reply Quote 0
                          DLaurenz @Shadowhunter23 last edited by DLaurenz
                          @shadowhunter23 Same here:
                          2024-10-08 13:23:54.342  - error: admin.0 (121735) uncaught exception: Parameter "id" needs to be of type "string" but type "number" has been passed
                          2024-10-08 13:23:54.343  - error: admin.0 (121735) Error: Parameter "id" needs to be of type "string" but type "number" has been passed
                          2024-10-08 13:23:54.344  - error: admin.0 (121735) Parameter "id" needs to be of type "string" but type "number" has been passed
                          2024-10-08 13:23:54.785  - info: admin.0 (121735) terminating https server on port 8081
                          2024-10-08 13:23:54.788  - info: admin.0 (121735) terminating
                                                  v.2024-08-12
                             Static hostname: iob-master
                                   Icon name: computer
                            Operating System: Debian GNU/Linux 11 (bullseye)
                                      Kernel: Linux 6.1.21-v8+
                                Architecture: arm64
                          Installation:           native
                          Kernel:                 aarch64
                          Userland:               64 bit
                          Timezone:               Europe/Berlin (CEST, +0200)
                          User-ID:                0
                          Display-Server:         false
                          Boot Target:            multi-user.target
                          Pending OS-Updates:     0
                          Pending iob updates:    0
                          Nodejs-Installation:
                          /usr/bin/nodejs         v20.18.0
                          /usr/bin/node           v20.18.0
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          /usr/bin/corepack       0.29.3
                          Recommended versions are nodejs 20.18.0 and npm 10.8.2
                          MEMORY:
                          Mem:            7.9G        2.1G        2.8G        192M        2.9G        5.4G
                          Swap:            99M          0B         99M
                          Total:          8.0G        2.1G        2.9G
                          Active iob-Instances:   20
                          Upgrade policy: none
                          ioBroker Core:          js-controller           7.0.0
                                                  admin                   7.2.2
                          Objects type: jsonl
                          States  type: jsonl
                          + system.adapter.admin.0                  : admin                 : iob-master                               -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                          + system.adapter.web.0                    : web                   : iob-master                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          Objects:                47963
                          States:                 43200
                          Size of iob-Database:
                          53M     /opt/iobroker/iobroker-data/objects.jsonl
                          110M    /opt/iobroker/iobroker-data/states.jsonl
                          iob diag:
                          Skript v.2024-08-12
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                          OS is similar to:
                          Model           : Raspberry Pi 4 Model B Rev 1.5
                          Docker          : false
                          Virtualization  : none
                          Kernel          : aarch64
                          Userland        : 64 bit
                          Systemuptime and Load:
                           13:29:20 up  2:14,  1 user,  load average: 0.52, 0.74, 0.96
                          CPU threads: 4
                          *** RASPBERRY THROTTLING ***
                          Current issues:
                          Previously detected issues:
                          *** Time and Time Zones ***
                                         Local time: Tue 2024-10-08 13:29:20 CEST
                                     Universal time: Tue 2024-10-08 11:29:20 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          *** Users and Groups ***
                          User that called 'iob diag':
                          root
                          HOME=/root
                          GROUPS=root
                          iobroker
                          HOME=/home/iobroker
                          GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
                          *** Display-Server-Setup ***
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:            99M          0B         99M
                                   7862 M total memory
                                   2132 M used memory
                                   2829 M active memory
                                   1983 M inactive memory
                                   2818 M free memory
                                    149 M buffer memory
                                   2761 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          top - 13:29:20 up  2:14,  1 user,  load average: 0.52, 0.74, 0.96
                          Tasks: 185 total,   1 running, 184 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  0.0 us,  4.3 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   7862.2 total,   2818.8 free,   2132.9 used,   2910.5 buff/cache
                          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   5375.3 avail Mem
                          *** FAILED SERVICES ***
                            UNIT            LOAD   ACTIVE SUB    DESCRIPTION
                          * hciuart.service loaded failed failed Configure Bluetooth Modems connected by UART
                          LOAD   = Reflects whether the unit definition was properly loaded.
                          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                          SUB    = The low-level unit activation state, values depend on unit type.
                          1 loaded units listed.
                          *** FILESYSTEM ***
                          /dev/root      ext4      469G   14G  431G   4% /
                          devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                          tmpfs          tmpfs     3.9G   20K  3.9G   1% /dev/shm
                          tmpfs          tmpfs     1.6G  3.0M  1.6G   1% /run
                          /dev/sda1      vfat      255M   31M  225M  13% /boot
                          folder2ram     tmpfs     3.9G  190M  3.7G   5% /opt/powershell
                          tmpfs          tmpfs     787M     0  787M   0% /run/user/0
                          [Tue Oct  8 11:14:36 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:46:C6:A8 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=7f03ccbc-02 rootfstype=ext4 fsck.repair=yes rootwait
                          [Tue Oct  8 11:14:38 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                          [Tue Oct  8 11:14:38 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                          [Tue Oct  8 11:14:40 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                          Show mounted filesystems:
                          TARGET                           SOURCE                     FSTYPE OPTIONS
                          /                                /dev/sda2                  ext4   rw,noatime
                          |-/boot                          /dev/sda1                  vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                          `-/var/folder2ram/opt/powershell /dev/sda2[/opt/powershell] ext4   rw,noatime
                          /var:
                          5.6G    /var/
                          4.1G    /var/log/journal/913411ec2113471e8a5a95f370c5ddcb
                          4.1G    /var/log
                          653M    /var/lib
                          Archived and active journals take up 4.0G in the file system.
                          /opt/iobroker/backups:
                          16K     /opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          1.3G    /opt/iobroker/iobroker-data/
                          885M    /opt/iobroker/iobroker-data/files
                          617M    /opt/iobroker/iobroker-data/files/javascript.admin
                          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                          109M    /opt/iobroker/iobroker-data/states.jsonl
                          24M     /opt/iobroker/iobroker-data/files/eventlist/static/js/main.bf7d9efc.js.map
                          24M     /opt/iobroker/iobroker-data/files/eventlist.admin/static/js/main.bf7d9efc.js.map
                          19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map
                          USB-Devices by-id:
                          No Devices found 'by-id'
                          HINT:
                          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                          /dev/ttyACM0
                          *** NodeJS-Installation ***
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Installed: 20.18.0-1nodesource1
                            Candidate: 20.18.0-1nodesource1
                            Version table:
                           *** 20.18.0-1nodesource1 1001
                                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                  100 /var/lib/dpkg/status
                               20.17.0-1nodesource1 1001
                               20.16.0-1nodesource1 1001
                               20.15.1-1nodesource1 1001
                               20.15.0-1nodesource1 1001
                               20.14.0-1nodesource1 1001
                               20.13.1-1nodesource1 1001
                               20.13.0-1nodesource1 1001
                               20.12.2-1nodesource1 1001
                               20.12.1-1nodesource1 1001
                               20.12.0-1nodesource1 1001
                               20.11.1-1nodesource1 1001
                               20.11.0-1nodesource1 1001
                               20.10.0-1nodesource1 1001
                               20.9.0-1nodesource1 1001
                               20.8.1-1nodesource1 1001
                               20.8.0-1nodesource1 1001
                               20.7.0-1nodesource1 1001
                               20.6.1-1nodesource1 1001
                               20.6.0-1nodesource1 1001
                               20.5.1-1nodesource1 1001
                               20.5.0-1nodesource1 1001
                               20.4.0-1nodesource1 1001
                               20.3.1-1nodesource1 1001
                               20.3.0-1nodesource1 1001
                               20.2.0-1nodesource1 1001
                               20.1.0-1nodesource1 1001
                               20.0.0-1nodesource1 1001
                               12.22.12~dfsg-1~deb11u5 500
                                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                               12.22.12~dfsg-1~deb11u4 500
                                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                          No problems detected
                          Errors in npm tree:
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Core adapters versions
                          admin:          7.2.2
                          javascript:     8.8.3
                          nodejs modules from github:     0
                          Adapter State
                          + system.adapter.accuweather.0            : accuweather           : iob-master                               -  enabled
                          + system.adapter.backitup.0               : backitup              : iob-master                               -  enabled
                            system.adapter.ble.0                    : ble                   : io-blegw02                               -  enabled
                          + system.adapter.discovery.0              : discovery             : iob-master                               -  enabled
                            system.adapter.dwd.0                    : dwd                   : iob-master                               -  enabled
                          + system.adapter.eventlist.0              : eventlist             : iob-master                               -  enabled
                            system.adapter.fb-checkpresence.0       : fb-checkpresence      : iob-master                               - disabled
                          + system.adapter.fritzdect.0              : fritzdect             : iob-master                               -  enabled
                          + system.adapter.hmip.0                   : hmip                  : iob-master                               -  enabled
                          + system.adapter.hmip.1                   : hmip                  : iob-master                               -  enabled
                            system.adapter.homeconnect.0            : homeconnect           : iob-master                               -  enabled
                            system.adapter.icons-icons8.0           : icons-icons8          : iob-master                               -  enabled
                            system.adapter.icons-material-png.0     : icons-material-png    : iob-master                               -  enabled
                            system.adapter.icons-material-svg.0     : icons-material-svg    : iob-master                               -  enabled
                            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iob-master                               -  enabled
                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iob-master                               -  enabled
                            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iob-master                               -  enabled
                          + system.adapter.influxdb.0               : influxdb              : iob-master                               -  enabled, port: 8086
                          + system.adapter.javascript.0             : javascript            : iob-master                               -  enabled
                          + system.adapter.linux-control.0          : linux-control         : iob-master                               -  enabled
                          + system.adapter.mercedesme.0             : mercedesme            : iob-master                               -  enabled
                          + system.adapter.meross.0                 : meross                : iob-master                               -  enabled
                          + system.adapter.ping.0                   : ping                  : iob-master                               -  enabled
                          + system.adapter.roborock.0               : roborock              : iob-master                               -  enabled
                          + system.adapter.selverf.0                : selverf               : io-fhem                                  -  enabled
                          + system.adapter.tr-064.0                 : tr-064                : iob-master                               -  enabled
                            system.adapter.vis-bars.0               : vis-bars              : iob-master                               -  enabled
                            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iob-master                               -  enabled
                            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iob-master                               -  enabled
                            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iob-master                               -  enabled
                            system.adapter.vis-history.0            : vis-history           : iob-master                               -  enabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iob-master                               -  enabled
                            system.adapter.vis-icontwo.0            : vis-icontwo           : iob-master                               -  enabled
                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iob-master                               -  enabled
                            system.adapter.vis-justgage.0           : vis-justgage          : iob-master                               -  enabled
                            system.adapter.vis-map.0                : vis-map               : iob-master                               -  enabled
                            system.adapter.vis-material-advanced.0  : vis-material-advanced : iob-master                               -  enabled
                            system.adapter.vis-material.0           : vis-material          : iob-master                               -  enabled
                            system.adapter.vis-metro.0              : vis-metro             : iob-master                               -  enabled
                            system.adapter.vis-players.0            : vis-players           : iob-master                               -  enabled
                            system.adapter.vis-plumb.0              : vis-plumb             : iob-master                               -  enabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iob-master                               -  enabled
                            system.adapter.vis-weather.0            : vis-weather           : iob-master                               -  enabled
                            system.adapter.vis.0                    : vis                   : iob-master                               -  enabled
                          + system.adapter.zigbee.0                 : zigbee                : io-fhem                                  -  enabled, port: /dev/ttyACM0
                          + instance is alive
                          ioBroker-Repositories
                          Active repo(s): beta
                          Installed ioBroker-Instances
                          Used repository: beta
                          Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
                          Adapter    "admin"        : 7.2.0    , installed 7.2.2
                          Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                          Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
                          Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
                          Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                          Adapter    "hmip"         : 1.24.3   , installed 1.24.3
                          Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
                          Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                          Controller "js-controller": 7.0.0    , installed 7.0.0
                          Adapter    "linux-control": 1.1.5    , installed 1.1.5
                          Adapter    "mercedesme"   : 0.2.3    , installed 0.2.3
                          Adapter    "meross"       : 1.17.0   , installed 1.17.0
                          Adapter    "ping"         : 1.7.9    , installed 1.7.9
                          Adapter    "roborock"     : 0.6.16   , installed 0.6.16
                          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                          Adapter    "vis-icontwo"  : 1.6.3    , installed 1.6.3
                          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                          Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                          Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                          Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                          Adapter    "web"          : 6.3.1    , installed 6.3.1
                          Adapter    "ws"           : 2.6.2    , installed 2.6.2
                          Objects and States
                          Objects:        47963
                          States:         43200
                          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:2 https://deb.nodesource.com/node_20.x nodistro InRelease
                          Hit:3 http://deb.debian.org/debian bullseye InRelease
                          Hit:4 https://repo.saltproject.io/salt/py3/debian/11/amd64/latest bullseye InRelease
                          Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
                          Hit:6 http://deb.debian.org/debian bullseye-backports InRelease
                          Hit:7 http://security.debian.org/debian-security bullseye-security InRelease
                          Hit:8 https://repos.influxdata.com/debian stable InRelease
                          Hit:9 https://packages.microsoft.com/debian/11/prod bullseye InRelease
                          Ign:10 https://download.webmin.com/download/repository sarge InRelease
                          Hit:11 https://download.webmin.com/download/repository sarge Release
                          Reading package lists...
                          Pending Updates: 0
                          *** Listening Ports ***
                          tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          15221      1256/perl
                          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       191961     106721/iobroker.js-
                          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       191353     106721/iobroker.js-
                          tcp        0      0 0.0.0.0:33733           0.0.0.0:*               LISTEN      107        181783     102314/rpc.statd
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          181170     102324/sshd: /usr/s
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          21351      1/init
                          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          19120      1172/smbd
                          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          19119      1172/smbd
                          tcp        0      0 0.0.0.0:44701           0.0.0.0:*               LISTEN      0          222860     -
                          tcp6       0      0 :::10000                :::*                    LISTEN      0          15222      1256/perl
                          tcp6       0      0 :::36915                :::*                    LISTEN      107        181787     102314/rpc.statd
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          181181     102324/sshd: /usr/s
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          20266      1/init
                          tcp6       0      0 :::80                   :::*                    LISTEN      0          181236     102347/node
                          tcp6       0      0 :::139                  :::*                    LISTEN      0          19118      1172/smbd
                          tcp6       0      0 :::443                  :::*                    LISTEN      0          186523     102347/node
                          tcp6       0      0 :::445                  :::*                    LISTEN      0          19117      1172/smbd
                          tcp6       0      0 :::7906                 :::*                    LISTEN      1001       197205     107257/io.roborock.
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       196923     107818/io.web.0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       214951     123102/io.admin.0
                          tcp6       0      0 :::8086                 :::*                    LISTEN      999        19147      1008/influxd
                          tcp6       0      0 :::6824                 :::*                    LISTEN      1001       197204     107257/io.roborock.
                          tcp6       0      0 :::39729                :::*                    LISTEN      0          222863     -
                          tcp6       0      0 :::6556                 :::*                    LISTEN      0          12079      1/init
                          udp        0      0 0.0.0.0:56293           0.0.0.0:*                           107        181781     102314/rpc.statd
                          udp        0      0 0.0.0.0:48461           0.0.0.0:*                           0          222859     -
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          20262      1/init
                          udp        0      0 192.168.2.255:137       0.0.0.0:*                           0          18981      1104/nmbd
                          udp        0      0 192.168.2.117:137       0.0.0.0:*                           0          18980      1104/nmbd
                          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          18959      1104/nmbd
                          udp        0      0 192.168.2.255:138       0.0.0.0:*                           0          18983      1104/nmbd
                          udp        0      0 192.168.2.117:138       0.0.0.0:*                           0          18982      1104/nmbd
                          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          18960      1104/nmbd
                          udp        0      0 0.0.0.0:57850           0.0.0.0:*                           108        12108      444/avahi-daemon: r
                          udp        0      0 192.168.2.117:16989     0.0.0.0:*                           0          186507     102347/node
                          udp        0      0 0.0.0.0:16989           0.0.0.0:*                           0          186506     102347/node
                          udp        0      0 127.0.0.1:730           0.0.0.0:*                           0          181779     102314/rpc.statd
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12106      444/avahi-daemon: r
                          udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          15223      1256/perl
                          udp6       0      0 :::36688                :::*                                0          222861     -
                          udp6       0      0 :::111                  :::*                                0          21355      1/init
                          udp6       0      0 fe80::95a2:3a:dd49::546 :::*                                0          14809      465/NetworkManager
                          udp6       0      0 fe80::95a2:3a:dd4:16989 :::*                                0          186520     102347/node
                          udp6       0      0 2003:d7:b736:fa00:16989 :::*                                0          186517     102347/node
                          udp6       0      0 fd00::8c2e:fc9f:e:16989 :::*                                0          186514     102347/node
                          udp6       0      0 2003:d7:b736:fa00:16989 :::*                                0          186511     102347/node
                          udp6       0      0 :::16989                :::*                                0          186508     102347/node
                          udp6       0      0 :::53915                :::*                                108        12109      444/avahi-daemon: r
                          udp6       0      0 :::5353                 :::*                                108        12107      444/avahi-daemon: r
                          udp6       0      0 :::54757                :::*                                107        181785     102314/rpc.statd
                          2024-10-08 13:25:37.055  - info: host.iob-master instance system.adapter.dwd.0 in version "2.8.5" started with pid 123923
                          2024-10-08 13:25:40.918  - info: dwd.0 (123923) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.0, js-controller: 7.0.0
                          2024-10-08 13:25:42.331  - info: dwd.0 (123923) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2024-10-08 13:25:42.868  - info: host.iob-master instance system.adapter.dwd.0 having pid 123923 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2024-10-08 13:28:39.181  - warn: homeconnect.0 (107315) Restart initiated
                          2024-10-08 13:28:39.189  - info: homeconnect.0 (107315) terminating
                          2024-10-08 13:28:39.192  - info: homeconnect.0 (107315) Terminated (NO_ERROR): Without reason
                          2024-10-08 13:28:39.688  - info: homeconnect.0 (107315) terminating
                          2024-10-08 13:28:40.055  - info: host.iob-master instance system.adapter.homeconnect.0 terminated with code 0 (NO_ERROR)
                          2024-10-08 13:28:40.056  - info: host.iob-master Restart adapter system.adapter.homeconnect.0 because enabled
                          2024-10-08 13:29:11.333  - info: host.iob-master instance system.adapter.homeconnect.0 in version "1.4.1" started with pid 127185
                          2024-10-08 13:29:15.065  - info: homeconnect.0 (127185) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v20.18.0, js-controller: 7.0.0
                          2024-10-08 13:29:15.925  - error: homeconnect.0 (127185) refresh token failed
                          2024-10-08 13:29:15.927  - error: homeconnect.0 (127185) AxiosError: Request failed with status code 400
                          2024-10-08 13:29:15.928  - error: homeconnect.0 (127185) {"error":"invalid_grant","error_description":"invalid refresh_token"}
                          2024-10-08 13:29:15.929  - error: homeconnect.0 (127185) Restart adapter in 20min
                          2024-10-08 13:29:16.030  - error: homeconnect.0 (127185) AxiosError: Request failed with status code 401
                          2024-10-08 13:29:16.031  - error: homeconnect.0 (127185) {"error":{"key":"invalid_token","description":"The access token expired"}}
                          2024-10-08 13:29:16.118  - error: homeconnect.0 (127185) 401 Unauthorized
                          2024-10-08 13:29:16.120  - error: homeconnect.0 (127185) Start Event Stream Error: {"type":"error","status":401,"message":"Unauthorized"}
                          2024-10-08 13:29:16.121  - info: homeconnect.0 (127185) Token abgelaufen
                          2024-10-08 13:29:16.228  - error: homeconnect.0 (127185) refresh token failed
                          2024-10-08 13:29:16.229  - error: homeconnect.0 (127185) AxiosError: Request failed with status code 400
                          2024-10-08 13:29:16.230  - error: homeconnect.0 (127185) {"error":"invalid_grant","error_description":"invalid refresh_token"}
                          2024-10-08 13:29:16.231  - error: homeconnect.0 (127185) Restart adapter in 20min
                          Admin 7.2.0 works
                            Derda @DLaurenz last edited by
                            Bei mir das gleiche Problem. Der Log ist bei mir mit >100 MB ala
                            AoBQCgFAKAUAoBQCgFAKAUAoBQCgFAKAUAoBQCgFAKAUAoBQCgFAKAUAoBQCgFAKAUAoBQCgFAKAUAoBQCgFAKAUAoBQCgFAWBjP2ab8Mb94KhlSJDUAUAoBQCgFAKAUAoBQCgFAKAUAoBQCgFAKAUAoBQCgFAKAUAoBQCgMZN/Y0v9ScfRmoGIT7GiPqTf6MtAjyc/aOf0928/MC/5UatL5j+Ij9Feln053DfA5X6yP1TznrAHeRQHO1/GW/4Un3wVTLczzu+w+xn0TV1c/OwUAoCnt2EFplTC8bKwlHDB1kDR9PvGDZ4YEGbMFFuLhqQRTMZUhAASmAwdIW4DUoGNzzEI+FgWEXjuPSD9PJsmjD5Wq2BxIPnDdsoLowuHK51FBKIogmBlVAIXXxEAEaIEHyHE5rMc1yprkzZ
                            zu gesumpft.
                            Ich kann daher nichts inhaltliches zur Lösung beitragen.
                            Danke für den Tipp mit der 7.2.0.
                            Die Version läuft bei mir auch erstmal stabile !
                              tomatenforever @Shadowhunter23 last edited by
                              @shadowhunter23 Das Downgrade auf 7.2.0 funktioniert. Habe mit der 7.2.0 soeben sogar den js-controller auf 7.0.0 aktualisiert. Keine weiteren Probleme. Danke 🙂
                              39
                              3424
