    4. Aktuell Probleme , oder nur bei mir ?
      Wenn der Prozess doppelt liefe käme ein code 7 error.
      Ich tippe da eher auf Konfigurationsfehler der Instanz.
      Gruß Rainer
      • wendy2702
        wendy2702 last edited by
        @Rainer:
        kommt bzw. kam doch
        2018-01-07 17:26:15.115  - error: host.raspberrypi instance system.adapter.fhem.0 terminated with code 7 (Adapter already running)
          mameier1234 last edited by
          so… Wasserbett deaktiviert 🙂
          neustart: wieder hänger.... aber diesmal keine Fehler im Log...
          2018-01-07 17:44:54.250  - info: host.raspberrypi  inMem-states listening on port 9000
          2018-01-07 17:44:55.481  - info: host.raspberrypi  inMem-objects listening on port 9001
          2018-01-07 17:44:55.514  - info: host.raspberrypi InMemoryDB connected
          2018-01-07 17:44:55.617  - info: host.raspberrypi 10 instances found
          2018-01-07 17:44:55.650  - info: host.raspberrypi starting 10 instances
          2018-01-07 17:44:55.758  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 576
          2018-01-07 17:44:59.673  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 582
          2018-01-07 17:44:59.893  - info: admin.0 starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.admin, node: v6.12.3
          2018-01-07 17:44:59.977  - info: admin.0 requesting all states
          2018-01-07 17:44:59.983  - info: admin.0 requesting all objects
          2018-01-07 17:45:03.777  - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 593
          2018-01-07 17:45:03.838  - info: discovery.0 starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v6.12.3
          2018-01-07 17:45:04.744  - info: admin.0 received all states
          2018-01-07 17:45:07.226  - info: admin.0 received all objects
          2018-01-07 17:45:07.160  - info: cloud.0 starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.12.3
          2018-01-07 17:45:07.211  - info: cloud.0 Connecting with https://iobroker.net:10555 with "@pro_martin@familie-meier.de_eb9c9f70-ee3f-11e7-86ee-214f5496d63"
          2018-01-07 17:45:07.568  - info: admin.0 http server listening on port 8081
          2018-01-07 17:45:07.569  - info: admin.0 Use link "http://localhost:8081" to configure.
          2018-01-07 17:45:07.907  - info: admin.0 Request actual repository...
          2018-01-07 17:45:08.088  - info: cloud.0 Connection changed: CONNECTED1
          2018-01-07 17:45:08.310  - info: host.raspberrypi instance system.adapter.web.0 started with pid 607
          2018-01-07 17:45:08.374  - info: admin.0 Change log subscriber state: true
          2018-01-07 17:45:08.388  - info: discovery.0 system.adapter.admin.0: logging true
          2018-01-07 17:45:08.400  - info: cloud.0 system.adapter.admin.0: logging true
          2018-01-07 17:45:08.501  - info: admin.0 system.adapter.admin.0: logging true
          2018-01-07 17:45:08.635  - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
          2018-01-07 17:45:10.643  - info: admin.0 Repository received successfully.
          2018-01-07 17:45:10.948  - info: web.0 starting. Version 2.1.9 in /opt/iobroker/node_modules/iobroker.web, node: v6.12.3
          2018-01-07 17:45:11.756  - info: host.raspberrypi instance system.adapter.xs1.0 started with pid 619
          2018-01-07 17:45:12.009  - info: web.0 socket.io server listening on port 8082
          2018-01-07 17:45:12.015  - info: cloud.0 2018-01-07T16:45:12.014Z Connected system.user.admin
          2018-01-07 17:45:12.019  - info: web.0 http server listening on port 8082
          2018-01-07 17:45:20.932  - info: xs1.0 starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.xs1, node: v6.12.3
          2018-01-07 17:45:20.962  - info: xs1.0 config XS1 Addresse: http://192.168.160.250
          2018-01-07 17:45:20.970  - info: xs1.0 CopyList = {}
          2018-01-07 17:45:25.470  - info: vis.0 starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.vis, node: v6.12.3
          2018-01-07 17:45:25.745  - info: vis.0 vis license is OK.
          2018-01-07 17:45:25.863  - info: xs1.0 Finished state creation. Added totally 43 actuators or sensors
          2018-01-07 17:45:27.182  - info: host.raspberrypi instance system.adapter.hm-rpc.0 started with pid 643
          2018-01-07 17:45:27.689  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
          2018-01-07 17:45:29.037  - info: hm-rpc.0 starting. Version 1.4.14 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.12.3
          2018-01-07 17:45:29.540  - info: hm-rpc.0 binrpc server is trying to listen on 192.168.160.160:2001
          2018-01-07 17:45:29.543  - info: hm-rpc.0 binrpc client is trying to connect to 192.168.160.4:2001 with ["xmlrpc_bin://192.168.160.160:2001","hm-rpc.0"]
          2018-01-07 17:45:29.781  - info: hm-rpc.0 binrpc <- system.listMethods ["hm-rpc.0"]
          2018-01-07 17:45:29.799  - info: hm-rpc.0 binrpc <- listDevices ["hm-rpc.0"]
          2018-01-07 17:45:30.053  - info: hm-rpc.0 binrpc -> 278 devices
          2018-01-07 17:45:30.401  - info: hm-rpc.0 Connected
          2018-01-07 17:45:31.106  - info: host.raspberrypi instance system.adapter.fhem.0 started with pid 653
          2018-01-07 17:45:32.646  - info: fhem.0 starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.fhem, node: v6.12.3
          2018-01-07 17:45:35.067  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 663
          2018-01-07 17:45:39.072  - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 669
          2018-01-07 17:45:40.841  - info: javascript.0 starting. Version 3.5.1 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.12.3
          2018-01-07 17:45:40.877  - info: javascript.0 requesting all states
          2018-01-07 17:45:40.882  - info: javascript.0 requesting all objects
          2018-01-07 17:45:47.577  - info: javascript.0 received all states
          2018-01-07 17:45:46.549  - info: hm-rega.0 starting. Version 1.6.6 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v6.12.3
          2018-01-07 17:45:46.575  - info: hm-rega.0 subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
          2018-01-07 17:45:49.267  - info: hm-rega.0 ReGaHSS 192.168.160.4 up
          2018-01-07 17:45:49.316  - info: hm-rega.0 time difference local-ccu 0s
          2018-01-07 17:45:49.448  - info: hm-rega.0 added/updated 1 favorites to enum.favorites
          2018-01-07 17:45:49.534  - info: hm-rega.0 added/updated functions to enum.functions
          2018-01-07 17:45:49.590  - info: hm-rega.0 added/updated rooms to enum.rooms
          2018-01-07 17:45:50.309  - info: hm-rega.0 renamed hm-rpc.0.OEQ0261402.0.UNREACH_ALARM to "Leinwand:0.UNREACH_ALARM"
          2018-01-07 17:45:50.370  - info: hm-rega.0 got 0 programs
          2018-01-07 17:45:50.400  - info: hm-rega.0 added/updated 0 programs
          2018-01-07 17:45:50.410  - info: javascript.0 received all objects
          2018-01-07 17:45:50.403  - info: hm-rega.0 deleted 0 programs
          2018-01-07 17:45:50.535  - info: hm-rega.0 got 4 variables
          2018-01-07 17:45:50.556  - info: javascript.0 Start javascript script.js.common.Leinwand
          2018-01-07 17:45:50.600  - info: hm-rega.0 added/updated 4 variables
          2018-01-07 17:45:50.623  - info: javascript.0 script.js.common.Leinwand: registered 2 subscriptions and 0 schedules
          2018-01-07 17:45:50.603  - info: hm-rega.0 deleted 0 variables
          2018-01-07 17:45:50.608  - info: hm-rega.0 request state values
          2018-01-07 17:45:51.066  - info: hm-rega.0 got state values
          • wendy2702
            @mameier1234:
            ich habe in der Zwischenzeit versucht über Github den Fhem - Adapter zu erneuern…
            danach: gleiche Version.
            Dann habe ich die Instanz wieder gestartet.. sieht gut aus... Allerdings noch kein kompletter pi-neustart.
            2018-01-07 17:40:14.868  - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
            2018-01-07 17:40:33.191  - info: host.raspberrypi object change system.adapter.fhem.0
            2018-01-07 17:40:33.247  - info: host.raspberrypi instance system.adapter.fhem.0 started with pid 792
            2018-01-07 17:40:34.860  - info: fhem.0 starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.fhem, node: v6.12.3
            2018-01-07 17:41:44.547  - info: fhem.0 Synchronised!
            So wie ich das in Git sehe ist das auch die aktuellste Version
              http://download.iobroker.net/list.html# … ot-systems
              Überall die gleiche
              • wendy2702
                @mameier1234:
                neustart: wieder hänger.... aber diesmal keine Fehler im Log... `
                Wie lange hast du nach dem PI restart gewartet?
                Hast du mal eine andere SD Karte zum testen?
                Wie ist der PI denn mit Strom versorgt?
                Bleibt das logfile dann auch hängen?
                Was sagt denn das Linux System log –> Eventuell steht da noch etwas brauchbares drin?
                Wie sieht denn "TOP" jetzt aus oder geht keine Eingabe mehr?
                  @wendy2702:
                  @mameier1234:
                  Wie sieht denn "TOP" jetzt aus oder geht keine Eingabe mehr? `
                  Pi neustart: so ca 5 sek… (sollte reichen)
                  Strom: USB-Netzteil
                  Logfile und in 2.er ssh Session Top... alles bleibt hängen...
                  In /var/log/messages sieht alles smooth aus..
                  Ich habe jetzt nochmal die Fhem Instanz angehalten... dann den pi neugestartet: Alles ok !!!!
                  Wenn ich dann dien Fhem Adapter erst später starte, ist auch alles ok..
                  • wendy2702
                    Hm,
                    weiß nicht was der FHEM Adapter dann macht. Nutze ich nicht und würde dann eventuell auch auf ein Konfig Problem tippen.
                      gibt es die möglichkeit eine Instanz (in dem Fall Fhem) beim Neustart nicht automatisch zu starten ?
                      • wendy2702
                        Das kann Ich dir leider nicht beantworten.
                        Würde aber mal vermuten das dein Problem irgendwo anders liegt.
                        Mach doch wegen dem FHEM Adapter Problem besser ein neues Thema auf oder ändere hier die Überschrift. Dann schaut sich das eventuell ein anderer FHEM User auch an und hat eine Idee.
                          mach ich…. jetzt ist ja erstmal klar, was das Problem grundsätzlich ist...
                          • Dutchman
                            @mameier1234:
                            gibt es die möglichkeit eine Instanz (in dem Fall Fhem) beim Neustart nicht automatisch zu starten ? `
                            Ja, entweder du Schaltest manuell aus vier Neustart oder wird machen dafür ein Script das beim Ausschalten des Systems den Adapter ausschaltet
                            Send from mobile device
                              paul53 last edited by
                              @Dutchman:
                              oder wird machen dafür ein Script das beim Ausschalten des Systems den Adapter ausschaltet `
                              Das wird nur funktionieren, wenn die FHEM-Instanz nicht vor der JS-Instanz gekillt wird.
                              • Dutchman
                                @paul53:
                                @Dutchman:
                                oder wird machen dafür ein Script das beim Ausschalten des Systems den Adapter ausschaltet Das wird nur funktionieren, wenn die FHEM-Instanz nicht vor der JS-Instanz gekillt wird.
                                Wieso? Es geht ja darum den Wert "enabled" auf false zu setzen..
                                Wird der Adapter gestoppt ist er immer noch enabled aber nicht running 😉
                                  @Dutchman:
                                  Wird der Adapter gestoppt ist er immer noch enabled aber nicht running `
                                  Hast recht 😮
                                    aeh… Ja!!
                                    (vergesst bitte nicht, ich bin neu in der Materie...)
                                    • Dutchman
                                      @paul53 legst du den code noch ich müsste Forum stöbern 😛
                                        @Dutchman:
                                        ich müsste Forum stöbern `
                                        …und ich in der Doku des JS-Adapters, sollte aber so funktionieren.
                                        onStop(function() {
                                           var obj = getObject('system.adapter.fhem.0');
                                           obj.common.enabled = false;
                                           setObject('system.adapter.fhem.0', obj);
                                        }, 0);
                                        function startFHEM() {
                                           obj.common.enabled = true;
                                        // FHEM verzögert starten
                                        setTimeout(startFHEM, 20000);  // 20 s nach Skriptstart
                                          Wow… OK...
                                          wenn ich das richtig verstehe, mache ich ein neues Script und paste das da rein ?
                                            @mameier1234:
                                            wenn ich das richtig verstehe, mache ich ein neues Script und paste das da rein ? `
                                            Richtig. Die Funktion setObject() muss in der Konfiguration der JS-Instanz freigegeben sein.
                                            2225
