    4. [gelöst] Objekte werden nicht mehr komplett angezeigt
    • 15. 05. Wartungsarbeiten am ioBroker Forum
    • Ro75
      Ro75 @hanss last edited by
      @hanss bitte mal
      iob diag
      Die Langfassung hier posten.
      Ro75.
      hanss 1 Reply Last reply Reply Quote 0
      • hanss
        hanss @Ro75 last edited by
        @ro75
        bitte sehr:
        Skript v.2024-08-12
        *** BASE SYSTEM ***
           Static hostname: raspi4
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 4.19.97-v7l+
              Architecture: arm
        OS is similar to: debian
        Model           : Raspberry Pi 4 Model B Rev 1.1
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : 32 bit
        Systemuptime and Load:
         17:42:58 up 108 days, 13:11,  3 users,  load average: 0.97, 0.89, 0.63
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Tue 2024-10-08 17:42:59 CEST
                   Universal time: Tue 2024-10-08 15:42:59 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        root
        HOME=/root
        GROUPS=root
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
        *** Display-Server-Setup ***
        Display-Server: true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           3.9G        1.6G        642M        220M        1.7G        2.0G
        Swap:            0B          0B          0B
        Total:         3.9G        1.6G        642M
        Active iob-Instances:   12
                 3906 M total memory
                 1552 M used memory
                 1890 M active memory
                 1114 M inactive memory
                  642 M free memory
                  225 M buffer memory
                 1485 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        top - 17:42:59 up 108 days, 13:11,  3 users,  load average: 0.97, 0.89, 0.63
        Tasks: 180 total,   1 running, 179 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  2.6 us,  3.8 sy,  0.0 ni, 93.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3906.0 total,    642.8 free,   1552.3 used,   1710.9 buff/cache
        MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1984.4 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** FILESYSTEM ***
        /dev/root      ext4       29G   15G   14G  51% /
        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
        tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
        tmpfs          tmpfs     2.0G  189M  1.8G  10% /run
        tmpfs          tmpfs     2.0G     0  2.0G   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   53M  200M  21% /boot
        /dev/sda1      fuseblk   932G   74G  858G   8% /media/exthd1
        tmpfs          tmpfs     391M  4.0K  391M   1% /run/user/1000
        tmpfs          tmpfs     391M     0  391M   0% /run/user/0
        [Sat Jun 22 04:31:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M cma=256M video=HDMI-A-1:1280x1024M@60,margin_left=0,margin_right=0,margin_top=0,margin_bottom=0 smsc95xx.macaddr=DC:A6:32:22:D6:DF vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=e98175b2-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Sat Jun 22 04:31:56 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
        [Sat Jun 22 04:31:56 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
        [Sat Jun 22 04:31:56 2024] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
        [Sat Jun 22 04:31:56 2024] EXT4-fs (mmcblk0p2): 8 orphan inodes deleted
        [Sat Jun 22 04:31:56 2024] EXT4-fs (mmcblk0p2): recovery complete
        [Sat Jun 22 04:31:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Sat Jun 22 04:31:56 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sat Jun 22 04:31:58 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        Show mounted filesystems:
        TARGET                SOURCE         FSTYPE          OPTIONS
        /                     /dev/mmcblk0p2 ext4            rw,noatime
        |-/sys/fs/bpf         bpf            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
        |-/run/user/1000/gvfs gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        |-/boot               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        `-/media/exthd1       /dev/sda1      fuseblk         rw,noatime,user_id=0,group_id=0,allow_other,blksize=4096
        /var:
        2.7G    /var/
        1.2G    /var/lib
        894M    /var/log
        801M    /var/lib/mongodb
        769M    /var/lib/mongodb/journal
        Archived and active journals take up 186.8M in the file system.
        /opt/iobroker/backups:
        280M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        946M    /opt/iobroker/iobroker-data/
        781M    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        24M     /opt/iobroker/iobroker-data/objects.jsonl
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
        8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_1e2c0fb9a112ec119d1720c7bd930c07-if00-port0
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        /dev/ttyUSB0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.20.4-1nodesource1
          Version table:
             18.20.4-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
             18.20.3-1nodesource1 1001
             18.20.2-1nodesource1 1001
             18.20.1-1nodesource1 1001
             18.20.0-1nodesource1 1001
             18.19.1-1nodesource1 1001
         *** 18.19.0-1nodesource1 1001
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             10.24.0~dfsg-1~deb10u3 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  6.0.11
        admin:          7.1.5
        javascript:     8.8.3
        nodejs modules from github:     0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspi4                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspi4                                   -  enabled
        + system.adapter.email.0                  : email                 : raspi4                                   -  enabled
          system.adapter.flot.0                   : flot                  : raspi4                                   -  enabled
          system.adapter.ical.0                   : ical                  : raspi4                                   -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspi4                                   -  enabled
        + system.adapter.iot.0                    : iot                   : raspi4                                   -  enabled
        + system.adapter.javascript.0             : javascript            : raspi4                                   -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : raspi4                                   -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.shelly.0                 : shelly                : raspi4                                   -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.sql.0                    : sql                   : raspi4                                   -  enabled, port: 3306
        + system.adapter.tr-064.0                 : tr-064                : raspi4                                   -  enabled
          system.adapter.vis-bars.0               : vis-bars              : raspi4                                   -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspi4                                   -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspi4                                   -  enabled
          system.adapter.vis-history.0            : vis-history           : raspi4                                   -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspi4                                   -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspi4                                   -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : raspi4                                   -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : raspi4                                   -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspi4                                   -  enabled
          system.adapter.vis.0                    : vis                   : raspi4                                   -  enabled
        + system.adapter.web.0                    : web                   : raspi4                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : raspi4                                   -  enabled, port: /dev/ttyUSB0
        + instance is alive
        ioBroker-Repositories
        │ (index) │   name   │                           url                           │ auto upgrade │
        │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
        │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.5    , installed 7.1.5
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "email"        : 1.3.1    , installed 1.3.1
        Adapter    "ical"         : 1.15.0   , installed 1.15.0
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 6.0.11   , installed 6.0.11
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "shelly"       : 8.2.1    , installed 8.2.1
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "sql"          : 3.0.1    , installed 3.0.1
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
        Objects and States
        Objects:        2521
        States:         2358
        E: Repository 'https://dl.ui.com/unifi/debian stable InRelease' changed its 'Codename' value from 'unifi-8.0' to 'unifi-8.4'
        Pending Updates: 87
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          16710      525/dnsmasq
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17596      523/sshd
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1002       550045522  28427/io.shelly.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1002       550048124  28402/io.mqtt.0
        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          20300      1044/smbd
        tcp        0      0 0.0.0.0:8800            0.0.0.0:*               LISTEN      0          188350090  12270/perl
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       550046775  28230/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       550046768  28230/iobroker.js-c
        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          20301      1044/smbd
        tcp6       0      0 :::53                   :::*                    LISTEN      0          16712      525/dnsmasq
        tcp6       0      0 :::22                   :::*                    LISTEN      0          17598      523/sshd
        tcp6       0      0 ::1:3350                :::*                    LISTEN      0          15764      489/xrdp-sesman
        tcp6       0      0 :::3389                 :::*                    LISTEN      112        16862      527/xrdp
        tcp6       0      0 :::445                  :::*                    LISTEN      0          20298      1044/smbd
        tcp6       0      0 :::3306                 :::*                    LISTEN      113        539078977  29231/mysqld
        tcp6       0      0 :::139                  :::*                    LISTEN      0          20299      1044/smbd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1002       550046261  28253/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1002       550051163  28545/io.web.0
        udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          16709      525/dnsmasq
        udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          16706      525/dnsmasq
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19573      412/dhcpcd
        udp        0      0 192.111.250.114:123     0.0.0.0:*                           105        21766      488/ntpd
        udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          17569      488/ntpd
        udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          17565      488/ntpd
        udp        0      0 192.111.250.255:137     0.0.0.0:*                           0          20655      443/nmbd
        udp        0      0 192.111.250.114:137     0.0.0.0:*                           0          20654      443/nmbd
        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          17686      443/nmbd
        udp        0      0 192.111.250.255:138     0.0.0.0:*                           0          20657      443/nmbd
        udp        0      0 192.111.250.114:138     0.0.0.0:*                           0          20656      443/nmbd
        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          17687      443/nmbd
        udp        0      0 192.111.250.114:5353    0.0.0.0:*                           1002       550049336  28478/io.tr-064.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           109        14551      386/avahi-daemon: r
        udp        0      0 0.0.0.0:53053           0.0.0.0:*                           109        14553      386/avahi-daemon: r
        udp6       0      0 :::53                   :::*                                0          16711      525/dnsmasq
        udp6       0      0 2003:f2:e74d:9600:d:123 :::*                                105        550464595  488/ntpd
        udp6       0      0 fe80::dea6:32ff:fe2:123 :::*                                105        21570      488/ntpd
        udp6       0      0 ::1:123                 :::*                                0          17573      488/ntpd
        udp6       0      0 :::123                  :::*                                0          17562      488/ntpd
        udp6       0      0 :::5353                 :::*                                109        14552      386/avahi-daemon: r
        udp6       0      0 :::48575                :::*                                109        14554      386/avahi-daemon: r
        2024-10-08 17:32:11.217  - info: host.raspi4 instance system.adapter.ical.0 having pid 26355 terminated with code 0 (NO_ERROR)
        2024-10-08 17:33:00.024  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 26440
        2024-10-08 17:33:11.192  - info: host.raspi4 instance system.adapter.ical.0 having pid 26440 terminated with code 0 (NO_ERROR)
        2024-10-08 17:34:00.043  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 26526
        2024-10-08 17:34:11.225  - info: host.raspi4 instance system.adapter.ical.0 having pid 26526 terminated with code 0 (NO_ERROR)
        2024-10-08 17:35:00.044  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 26625
        2024-10-08 17:35:11.464  - info: host.raspi4 instance system.adapter.ical.0 having pid 26625 terminated with code 0 (NO_ERROR)
        2024-10-08 17:36:00.039  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 26715
        2024-10-08 17:36:11.118  - info: host.raspi4 instance system.adapter.ical.0 having pid 26715 terminated with code 0 (NO_ERROR)
        2024-10-08 17:37:00.043  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 26793
        2024-10-08 17:37:11.459  - info: host.raspi4 instance system.adapter.ical.0 having pid 26793 terminated with code 0 (NO_ERROR)
        2024-10-08 17:38:00.046  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 26877
        2024-10-08 17:38:11.153  - info: host.raspi4 instance system.adapter.ical.0 having pid 26877 terminated with code 0 (NO_ERROR)
        2024-10-08 17:39:00.032  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 27064
        2024-10-08 17:39:11.987  - info: host.raspi4 instance system.adapter.ical.0 having pid 27064 terminated with code 0 (NO_ERROR)
        2024-10-08 17:40:00.021  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 27474
        2024-10-08 17:40:15.259  - info: host.raspi4 instance system.adapter.ical.0 having pid 27474 terminated with code 0 (NO_ERROR)
        2024-10-08 17:40:16.180  - debug: host.raspi4 Incoming Host message getRepository
        2024-10-08 17:40:18.971  - debug: host.raspi4 Incoming Host message getInstalled
        2024-10-08 17:41:00.031  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 27964
        2024-10-08 17:41:11.357  - info: host.raspi4 instance system.adapter.ical.0 having pid 27964 terminated with code 0 (NO_ERROR)
        2024-10-08 17:42:00.066  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 28273
        2024-10-08 17:42:11.306  - info: host.raspi4 instance system.adapter.ical.0 having pid 28273 terminated with code 0 (NO_ERROR)
        2024-10-08 17:43:00.026  - info: host.raspi4 instance system.adapter.ical.0 in version "1.15.0" started with pid 28631
        2024-10-08 17:43:12.092  - info: host.raspi4 instance system.adapter.ical.0 having pid 28631 terminated with code 0 (NO_ERROR)
        iob diag has finished.
        Ro75 1 Reply Last reply Reply Quote 0
        • Ro75
          Ro75 @hanss last edited by Ro75
          @hanss sagte in Objekte werden nicht mehr komplett angezeigt:
          Dafür gibt es keine OS-Update mehr. Neuinstallation mit Debian 12 (Bookworm) 64Bit lite ohne Desktop
          [Sat Jun 22 04:31:56 2024] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs [Sat Jun 22 04:31:56 2024] EXT4-fs (mmcblk0p2): 8 orphan inodes deleted [Sat Jun 22 04:31:56 2024] EXT4-fs (mmcblk0p2): recovery complete
          Dateisystem und / oder Datenträger defekt. Für Neuinstallation eine neuen Datenträger verwenden.
          Ro75
          EDIT: Backup hast du? Regelmäßig gesichert und extern aufbewahrt?
          • hanss
            @ro75
            Danke für den Tipp, aber das ist mir für den Bug zu viel Aufwand.
            • Ro75
              @hanss DAS IST KEIN BUG. Dein Datenträger ist schrott! Damit sind Daten verschwunden, aufgrund einer defekten Hardware.
              Ro75.
              • hanss
                @ro75
                Warum sehe ich dann die Objekt z.B. im IOT Adapter, die ich im Admin nicht sehe?
                Ro75 Samson71 Jey Cee 3 Replies Last reply Reply Quote 0
                • Ro75
                  @hanss Du hast um Hilfe gebeten. Ich habe dir gesagt, was nicht korrekt läuft und wo es Probleme gibt.
                  Ro75.
                  • Samson71
                    Samson71 Global Moderator @hanss last edited by Samson71
                    @hanss
                    Unabhängig von den Ausführungen von @Ro75 ist Debian 10 tot. Das kann auch nicht auf Nodejs 20 upgedatet werden. Um eine Neuinstallation mit Debian 12 kommst Du daher so oder so nicht herum.
                    • hanss
                      hanss @Samson71 last edited by
                      @samson71
                      in meinem ioBroker System stecken 4 Jahre Entwicklungsarbeit.
                      Da ist eine Neuinstallation schon eine Zumutung.
                      Samson71 Codierknecht 2 Replies Last reply Reply Quote 0
                      • Samson71
                        @hanss
                        Glaube ich, verstehe ich, kann ich aber nicht ändern und ist eigentlich auch nicht weiter schlimm. Das haben alle mit Debian 10 als Basis entweder durch oder aber noch zwingend vor sich. Punkt.
                        Bei mir stecken mittlerweile knapp 10 Jahre drin. Dafür gibt es ja das Backup. Alles unter "alt" soweit aktualisieren wie möglich und dann eine Neuinstallation unter Debian 12 und das Backup einspielen.
                        • Codierknecht
                          Codierknecht Developer Most Active @hanss last edited by
                          Eine Zumutung wäre, weiterhin ein totes Pferd zu reiten.
                          Du hast aktuelle Backups? Dann ist das Neuaufsetzen in max. 1-2 Stunden erledigt.
                          An Deiner Kiste ist so einiges im Argen:
                          1. Dein Datenträger ist Schrott
                          2. Dein OS ist tot
                          3. man fummelt nicht als root rum
                          4. auf einem Server betreibt man keinen Desktop
                          Und mit einem neuen OS hättest Du auch ein 64Bit-System.
                          • hanss
                            hanss @Codierknecht last edited by
                            @codierknecht
                            Wieso ist mein Datenträger "Schrott"?
                            • Codierknecht
                              Codierknecht Developer Most Active @hanss last edited by Codierknecht
                              @hanss
                              Entweder hat das Dateisystem 'nen Schuss abgekriegt oder der Datenträger.
                              Dem Raspi mal plötzlich den Strom abgeknipst?
                              Ich würde dem der SD-Karte nicht mehr trauen und für die Neuinstallation einen neuen eine neue Karte nehmen.
                              Dann kann man im allergrößten Notfall auch nochmal an den alten die alte Karte ran.
                              • Jey Cee
                                Jey Cee Developer @hanss last edited by
                                Spätestens hier hätte auch mal der Hinweis kommen können das womöglich ein Filter im Tab Objekte gesetzt sein könnte.
                                Check das mal.
                                Ansonsten haben die anderen schon recht, ein Update auf die Aktuelle Version des Betriebssystems solltest du machen.
                                hanss 1 Reply Last reply Reply Quote 1
                                • hanss
                                  hanss @Jey Cee last edited by
                                  @jey-cee
                                  Danke, kein Filter gesetzt.
                                  Inzwischen ist klar, die SD Karte ist defekt. Bei einem Neustart ist nicht einmal mehr
                                  das OS hochgelaufen.
                                  Dumm ist nur, dass bei einem 7 Tage altem Linux Backup ioBroker nicht mehr komplett hochfährt.
                                  z.B. ist "Admin" permanent deaktiviert. Admin manuell aktivieren hilft nicht.
                                  Ich bin jetzt 14Tage im Urlaub.
                                  Danach werde ich mit neuem Raspbi4 8GB, neuer microSD Karte, Debian 12 64Bit neu aufsetzen.
                                  Vielen Dank.
                                  • Codierknecht
                                    Es muss kein neuer Raspi sein. Neue SD-Karte reicht.
                                    Ich habe meinen Post mal dahingehend korrigiert.
                                    Aber 8 GB RAM sind auf jeden Fall besser als 4 und Du bist da für die Zukunft besser aufgestellt.
                                      ecki-noname @hanss last edited by
                                      Ich hatte ein Ähnliches Problem.
                                      Bei mir war in den Objekten ein Filter gesetzt.
                                      In den Spaltenüberschriften war ganz rechts ein X.
                                      Dieses habe ich betätigt und alles war wieder da.
                                      Mit freundlichen Grüßen
                                      Ro75 Samson71 2 Replies Last reply Reply Quote 0
                                      • Ro75
                                        Ro75 @ecki-noname last edited by Ro75
                                        @ecki-noname lies doch bitte mal alles. Bei dir war es so (ODER AUCH ÄHNLICH UND NICHT GLEICH). Hier liegt es etwas anders.
                                        Ro75.
                                        • Samson71
                                          Samson71 Global Moderator @ecki-noname last edited by
                                          @ecki-noname
                                          Mann, Mann, Mann. 2 Beiträge über Deinem ist das gerade geklärt.
                                          • hanss
                                            @samson71
                                            Problem gelöst:
                                            Nachdem auch noch der Admin nicht mehr aufzurufen war, neue MicroSD Karte besorgt
                                            und die Linux Datensicherung vom September aufgespielt.
                                            Objekte wurden noch immer nicht angezeigt:
                                            Cache vom Firefox gelöscht - Objekte werden wieder angezeigt!!!!
                                            Das war die Lösung.
                                            Ich habe mir damit wochenlange Arbeit erspart - funktioniert auch mit Debian 10!
                                            Thomas Braun Samson71 2 Replies Last reply Reply Quote 0
                                            31.6k
                                            79.5k
                                            983
