    4. Updateschwierigkeiten js-controller 4.0.23
      Flowski @Thomas Braun last edited by
      @thomas-braun iobroker restart?
        Flowski @Flowski last edited by
        @flowski oder sudo reboot?
          Thomas Braun Most Active @Flowski last edited by
          @flowski
          Das komplette System. Offenbar war da ein Kernel-Update dabei, weswegen da jetzt per dkms z.B. der pivccu neugebaut werden muss.
            @thomas-braun heißt jetzt für Dummies? Sorry aber bin mit den Befehlen noch nicht ganz fit
              @flowski
              iob stop
              sudo reboot
              Wenn die Kiste wieder erreichbar ist
              iob update
              iob upgrade all -y
                @thomas-braun danke für deinen support, jetzt erscheint folgendes im Terminal:
                fabio@IoBroker:/home/pi $ iob stop
                fabio@IoBroker:/home/pi $ sudo reboot
                [sudo] password for fabio:
                Connection to 192.168.178.46 closed by remote host.
                Connection to 192.168.178.46 closed.
                PS C:\Users\mulla> ssh pi@192.168.178.46
                pi@192.168.178.46's password:
                Linux IoBroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                The programs included with the Debian GNU/Linux system are free software;
                the exact distribution terms for each program are described in the
                individual files in /usr/share/doc/*/copyright.
                Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                permitted by applicable law.
                Last login: Tue Oct  8 20:04:34 2024 from 192.168.178.131
                Wi-Fi is currently blocked by rfkill.
                Use raspi-config to set the country before use.
                pi@IoBroker:~ $ iob update
                Used repository: stable
                Adapter    "admin"        : 7.1.5    , installed 7.0.22 [Updatable]
                Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                Adapter    "backitup"     : 3.0.22   , installed 2.10.11 [Updatable]
                Adapter    "daikin-cloud" : 0.4.8    , installed 0.3.0  [Updatable]
                Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                Adapter    "discovery"    : 5.0.0    , installed 4.5.0  [Updatable]
                Adapter    "ham"          : 5.3.1    , installed 5.3.1
                Adapter    "hm-rega"      : 5.0.0    , installed 4.0.0  [Updatable]
                Adapter    "hm-rpc"       : 2.0.2    , installed 1.16.0 [Updatable]
                Adapter    "homeconnect"  : 1.4.1    , installed 1.3.0  [Updatable]
                Adapter    "ical"         : 1.15.0   , installed 1.14.3 [Updatable]
                Adapter    "iot"          : 3.3.0    , installed 3.3.0
                Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                Adapter    "javascript"   : 8.8.3    , installed 7.8.0  [Updatable]
                Controller "js-controller": 6.0.11   , installed 4.0.23 [Updatable]
                Adapter    "linux-control": 1.1.5    , installed 1.1.5
                Adapter    "meross"       : 1.17.0   , installed 1.17.0
                Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                Adapter    "mihome-vacuum": 4.2.0    , installed 3.8.6  [Updatable]
                Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                Adapter    "mqtt-client"  : 2.0.0    , installed 1.6.3  [Updatable]
                Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                Adapter    "sonoff"       : 3.1.2    , installed 3.0.3  [Updatable]
                Adapter    "tankerkoenig" : 3.4.0    , installed 3.1.0  [Updatable]
                Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                Adapter    "trashschedule": 3.3.0    , installed 3.2.0  [Updatable]
                Adapter    "tuya"         : 3.16.0   , installed 3.15.0 [Updatable]
                Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.2.3  [Updatable]
                Adapter    "ws"           : 2.6.2    , installed 2.6.2
                Adapter    "yeelight-2"   : 1.4.0    , installed 1.2.1  [Updatable]
                Adapter    "zigbee"       : 1.10.3   , installed 1.8.10 [Updatable]
                pi@IoBroker:~ $ cu fabio
                -bash: cu: command not found
                pi@IoBroker:~ $ ssh fabio@192.168.178.46
                The authenticity of host '192.168.178.46 (192.168.178.46)' can't be established.
                ECDSA key fingerprint is SHA256:FIhsIFzSsCA3qcV8rP3HPxSWGbgQ71sBXmHraXwu1t0.
                Are you sure you want to continue connecting (yes/no/[fingerprint])? n
                Please type 'yes', 'no' or the fingerprint: no
                Host key verification failed.
                pi@IoBroker:~ $ su fabio
                Password:
                fabio@IoBroker:/home/pi $ iob update
                fabio@IoBroker:/home/pi $ iob upgrade all -y
                Cannot check dependencies: Invalid version of "js-controller". Installed "4.0.23", required ">=5.0.19
                Update hm-rega from @4.0.0 to @5.0.0
                NPM version: 10.8.2
                Installing iobroker.hm-rega@5.0.0... (System call)
                added 2 packages, removed 399 packages, and changed 2 packages in 16s
                131 packages are looking for funding
                  run `npm fund` for details
                Update "system.adapter.hm-rega.0"
                upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
                upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
                upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
                upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
                upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
                upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                Update discovery from @4.5.0 to @5.0.0
                NPM version: 10.8.2
                Installing iobroker.discovery@5.0.0... (System call)
                changed 1 package in 11s
                Update "system.adapter.discovery.0"
                upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                Update admin from @7.0.22 to @7.1.5
                host.IoBroker Adapter "system.adapter.admin.0" is stopped.
                NPM version: 10.8.2
                Installing iobroker.admin@7.1.5... (System call)
                added 11 packages, removed 3 packages, and changed 11 packages in 21s
                Update "system.adapter.admin.0"
                upload [68] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
                upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js application/javascript
                upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js application/javascript
                upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js application/javascript
                upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js application/javascript
                upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map application/json
                upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js application/javascript
                upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map application/json
                upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js application/javascript
                upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map application/json
                upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js application/javascript
                upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map application/json
                upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                host.IoBroker Adapter "system.adapter.admin.0" is started
                Update zigbee from @1.8.10 to @1.10.3
                host.IoBroker Adapter "system.adapter.zigbee.0" is stopped.
                NPM version: 10.8.2
                Installing iobroker.zigbee@1.10.3... (System call)
                added 18 packages, removed 19 packages, and changed 24 packages in 33s
                120 packages are looking for funding
                Update "system.adapter.zigbee.0"
                upload [331] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/E2213.png img/E2213.png image/png
                upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/cc2538_router_v1.png img/cc2538_router_v1.png image/png
                upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hue-smart-button.png img/hue-smart-button.png image/png
                upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_lamp.png img/lifecontrol_lamp.png image/png
                upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_fuzo_outdoor_wall_light.png img/philips_fuzo_outdoor_wall_light.png image/png
                upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_argenta_4.png img/philips_hue_argenta_4.png image/png
                upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_gu10_ambiance.png img/philips_hue_gu10_ambiance.png image/png
                upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lwv001.png img/philips_hue_lwv001.png image/png
                upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/previous_track.png img/previous_track.png image/png
                upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_philipshue.png img/sensor_philipshue.png image/png
                upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smartthings_motion.png img/smartthings_motion.png image/png
                upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ts0203.png img/ts0203.png image/png
                upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_tyzs1l.png img/tuya_tyzs1l.png image/png
                upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
                upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
                upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
                upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
                upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
                upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
                upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
                upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
                upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
                upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
                upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
                upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
                upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
                upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
                upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
                upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
                upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
                upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
                upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
                upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
                host.IoBroker Adapter "system.adapter.zigbee.0" is started
                Cannot check dependencies: Invalid version of "js-controller". Installed "4.0.23", required ">=5.0.0
                  @flowski sagte in Updateschwierigkeiten js-controller 4.0.23:
                  Warum? Stell dich als fabio auch in dessen home und nicht in das home eines anderen users.
                  Den Fingerpring für den fabio musst du schon akzeptieren, damit das funktioniert.
                  Und warum hast du nicht gleich den 'pi' verwendet, wenn es denn doch schon gab?
                  iob stop
                  iob ugrade self
                  iob upgrade all -y
                    Flowski last edited by Flowski
                    puh ok 🤕 🙂
                    heisst ssh fabio@192.168.178.46
                    dann ecdsa key ... mit yes
                    Zitat:
                    Warum? Stell dich als fabio auch in dessen home und nicht in das home eines anderen users. sorry stehe auf dem Schlauch 😞 muss da sicherlich noch was umstellen bevor ich die drei Befehle eingebe aber begreife es grad nicht
                      @flowski
                      Jeder user hat auf einem Linux-System ein eigenes home-Verzeichnis, indem die eigenen Dateien abgelegt werden.
                        @thomas-braun so: fabio@IoBroker:~ $?
                          @flowski
                          Ja. Die Tilde repräsentiert das home des users.
                            @thomas-braun anbei der log, iobroker ist jetzt aktuell nicht erreichbar im Browser.. brauchts jetzt nochmal ein iob reboot?
                            fabio@IoBroker:/home/pi $  ssh fabio@192.168.178.46
                            Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
                            Warning: Permanently added '192.168.178.46' (ECDSA) to the list of known hosts.
                            fabio@192.168.178.46's password:
                            fabio@IoBroker:~ $ iob stop
                            fabio@IoBroker:~ $ iob upgrade self
                            Update js-controller from @4.0.23 to @6.0.11
                            Stopped Objects DB
                            Stopped States DB
                            NPM version: 10.8.2
                            Installing iobroker.js-controller@6.0.11... (System call)
                            added 10 packages, removed 67 packages, and changed 44 packages in 52s
                            121 packages are looking for funding
                            fabio@IoBroker:~ $ iob upgrade all -y
                            Update yeelight-2 from @1.2.1 to @1.4.0
                            NPM version: 10.8.2
                            Installing iobroker.yeelight-2@1.4.0... (System call)
                            added 2 packages, removed 32 packages, and changed 5 packages in 12s
                            Update "system.adapter.yeelight-2.0"
                            upload [20] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/1.png icons/1.png image/png
                            upload [19] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/2.png icons/2.png image/png
                            upload [18] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/3.png icons/3.png image/png
                            upload [17] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/4.png icons/4.png image/png
                            upload [16] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/5.png icons/5.png image/png
                            upload [15] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/6.png icons/6.png image/png
                            upload [14] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/7.png icons/7.png image/png
                            upload [13] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/bslamp1.png icons/bslamp1.png image/png
                            upload [12] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling1.png icons/ceiling1.png image/png
                            upload [11] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling10.png icons/ceiling10.png image/png
                            upload [10] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling3.png icons/ceiling3.png image/png
                            upload [9] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling4.png icons/ceiling4.png image/png
                            upload [8] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/color.png icons/color.png image/png
                            upload [7] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/desklamp.png icons/desklamp.png image/png
                            upload [6] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/mono.png icons/mono.png image/png
                            upload [5] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/stripe.png icons/stripe.png image/png
                            upload [4] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/index.html index.html text/html
                            upload [3] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/index_m.html index_m.html text/html
                            upload [2] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/lan.jpg lan.jpg image/jpeg
                            upload [1] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/words.js words.js application/javascript
                            upload [0] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/yeelight.png yeelight.png image/png
                            Update whatsapp-cmb from @0.2.3 to @0.3.0
                            NPM version: 10.8.2
                            Installing iobroker.whatsapp-cmb@0.3.0... (System call)
                            changed 1 package in 8s
                            Update "system.adapter.whatsapp-cmb.0"
                            Update "system.adapter.whatsapp-cmb.1"
                            upload [17] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/admin.d.ts admin.d.ts video/mp2t
                            upload [16] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/blockly.js blockly.js application/javascript
                            upload [15] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/de/translations.json i18n/de/translations.json application/json
                            upload [14] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/en/translations.json i18n/en/translations.json application/json
                            upload [13] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/es/translations.json i18n/es/translations.json application/json
                            upload [12] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                            upload [11] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/it/translations.json i18n/it/translations.json application/json
                            upload [10] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                            upload [9] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                            upload [8] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                            upload [7] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                            upload [6] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                            upload [5] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                            upload [4] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/index_m.html index_m.html text/html
                            upload [3] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/style.css style.css text/css
                            upload [2] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/tsconfig.json tsconfig.json application/json
                            upload [1] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/whatsapp-cmb.png whatsapp-cmb.png image/png
                            upload [0] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/words.js words.js application/javascript
                            Update tuya from @3.15.0 to @3.16.0
                            NPM version: 10.8.2
                            Installing iobroker.tuya@3.16.0... (System call)
                            added 73 packages, removed 1 package, and changed 3 packages in 24s
                            124 packages are looking for funding
                            Update "system.adapter.tuya.0"
                            upload [3] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/index_m.html index_m.html text/html
                            upload [2] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/tuya.png tuya.png image/png
                            upload [1] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/warning.png warning.png image/png
                            upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
                            Update trashschedule from @3.2.0 to @3.3.0
                            NPM version: 10.8.2
                            Installing iobroker.trashschedule@3.3.0... (System call)
                            added 1 package, and changed 1 package in 9s
                            Update "system.adapter.trashschedule.0"
                            upload [12] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json
                            upload [11] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/en/translations.json i18n/en/translations.json application/json
                            upload [10] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/es/translations.json i18n/es/translations.json application/json
                            upload [9] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                            upload [8] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/it/translations.json i18n/it/translations.json application/json
                            upload [7] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                            upload [6] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                            upload [5] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                            upload [4] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                            upload [3] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                            upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                            upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json
                            upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png
                            Update tankerkoenig from @3.1.0 to @3.4.0
                            host.IoBroker Adapter "system.adapter.tankerkoenig.0" is stopped.
                            NPM version: 10.8.2
                            Installing iobroker.tankerkoenig@3.4.0... (System call)
                            removed 1 package, and changed 1 package in 10s
                            Update "system.adapter.tankerkoenig.0"
                            upload [4] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js build/index.js application/javascript
                            upload [3] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js.map build/index.js.map application/json
                            upload [2] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/index_m.html index_m.html text/html
                            upload [1] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/style.css style.css text/css
                            upload [0] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/tankerkoenig.png tankerkoenig.png image/png
                            host.IoBroker Adapter "system.adapter.tankerkoenig.0" is started
                            Update sonoff from @3.0.3 to @3.1.2
                            NPM version: 10.8.2
                            Installing iobroker.sonoff@3.1.2... (System call)
                            Update "system.adapter.sonoff.0"
                            upload [15] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/de/translations.json i18n/de/translations.json application/json
                            upload [14] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/en/translations.json i18n/en/translations.json application/json
                            upload [13] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/es/translations.json i18n/es/translations.json application/json
                            upload [12] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                            upload [11] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/it/translations.json i18n/it/translations.json application/json
                            upload [10] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                            upload [9] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                            upload [8] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                            upload [7] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                            upload [6] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                            upload [5] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                            upload [4] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
                            upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
                            upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/jsonConfig.json jsonConfig.json application/json
                            upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
                            upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
                            Update mqtt-client from @1.6.3 to @2.0.0
                            NPM version: 10.8.2
                            Installing iobroker.mqtt-client@2.0.0... (System call)
                            added 15 packages, and changed 1 package in 10s
                            upload [13] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/de/translations.json i18n/de/translations.json application/json
                            upload [12] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/en/translations.json i18n/en/translations.json application/json
                            upload [11] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/es/translations.json i18n/es/translations.json application/json
                            upload [10] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                            upload [9] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/it/translations.json i18n/it/translations.json application/json
                            upload [8] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                            upload [7] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                            upload [6] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                            upload [5] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                            upload [4] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                            upload [3] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                            upload [2] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/jsonConfig.json jsonConfig.json application/json
                            upload [1] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/jsonCustom.json jsonCustom.json application/json
                            upload [0] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/mqtt-client.png mqtt-client.png image/png
                            Update mihome-vacuum from @3.8.6 to @4.2.0
                            NPM version: 10.8.2
                            Installing iobroker.mihome-vacuum@4.2.0... (System call)
                            added 3 packages, removed 4 packages, and changed 9 packages in 2m
                            Update "system.adapter.mihome-vacuum.0"
                            upload [20] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                            upload [19] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/de/translations.json i18n/de/translations.json application/json
                            upload [18] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/en/translations.json i18n/en/translations.json application/json
                            upload [17] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/es/translations.json i18n/es/translations.json application/json
                            upload [16] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                            upload [15] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/it/translations.json i18n/it/translations.json application/json
                            upload [14] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                            upload [13] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                            upload [12] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                            upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                            upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                            upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                            upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                            upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                            upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
                            upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
                            upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
                            upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
                            upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
                            upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
                            upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                            Update javascript from @7.8.0 to @8.8.3
                            NPM version: 10.8.2
                            Installing iobroker.javascript@8.8.3... (System call)
                            added 1 package, removed 1 package, and changed 6 packages in 1m
                            Update "system.adapter.javascript.0"
                            upload [1177] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                            upload [1150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map application/json
                            upload [1100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly-9.3.3.tgz google-blockly/blockly-9.3.3.tgz false
                            upload [1050] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/field_oid.js google-blockly/own/field_oid.js application/javascript
                            upload [1000] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/102.23e64034.chunk.js.map static/js/102.23e64034.chunk.js.map application/json
                            upload [950] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/149.2197f5fc.chunk.js.LICENSE.txt static/js/149.2197f5fc.chunk.js.LICENSE.txt text/plain
                            upload [900] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/228.6096b27c.chunk.js.map static/js/228.6096b27c.chunk.js.map application/json
                            upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/274.47c324f3.chunk.js static/js/274.47c324f3.chunk.js application/javascript
                            upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/327.0f7eca59.chunk.js static/js/327.0f7eca59.chunk.js application/javascript
                            upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.2e64fd76.chunk.js static/js/409.2e64fd76.chunk.js application/javascript
                            upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/432.fb14e4f2.chunk.js.map static/js/432.fb14e4f2.chunk.js.map application/json
                            upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/568.f1b6e961.chunk.js static/js/568.f1b6e961.chunk.js application/javascript
                            upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/675.279d2690.chunk.js static/js/675.279d2690.chunk.js application/javascript
                            upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/772.a8a30056.chunk.js.LICENSE.txt static/js/772.a8a30056.chunk.js.LICENSE.txt text/plain
                            upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/838.92dfa026.chunk.js static/js/838.92dfa026.chunk.js application/javascript
                            upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/894.e378a23c.chunk.js.map static/js/894.e378a23c.chunk.js.map application/json
                            upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/982.2ba0e8b8.chunk.js.LICENSE.txt static/js/982.2ba0e8b8.chunk.js.LICENSE.txt text/plain
                            upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.567b63d3.js static/js/main.567b63d3.js application/javascript
                            upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.d79356b6.js static/js/main.d79356b6.js application/javascript
                            upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Chandelier.0f30083487437c7e9414.svg static/media/Chandelier.0f30083487437c7e9414.svg image/svg+xml
                            upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
                            upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Locker Room.09bd68885c505ed50641.svg static/media/Locker Room.09bd68885c505ed50641.svg image/svg+xml
                            upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.1b2e0a89e9b117740d6e.svg static/media/Speaker.1b2e0a89e9b117740d6e.svg image/svg+xml
                            upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Summer House.541a9fec69f01105e244.svg static/media/Summer House.541a9fec69f01105e244.svg image/svg+xml
                            upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                            upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg image/svg+xml
                            upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.07a51f1a9a8384bbc5ae.svg static/media/Water.07a51f1a9a8384bbc5ae.svg image/svg+xml
                            upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                            upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                            upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                            upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                            upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                            upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                            upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                            upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                            upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                            upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                            upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                            upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                            upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                            upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                            upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                            upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                            upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                            upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                            upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                            upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                            upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                            upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                            upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                            upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                            Update ical from @1.14.3 to @1.15.0
                            NPM version: 10.8.2
                            Installing iobroker.ical@1.15.0... (System call)
                            added 1 package, and changed 1 package in 11s
                            Update "system.adapter.ical.0"
                            upload [14] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/de/translations.json i18n/de/translations.json application/json
                            upload [13] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/en/translations.json i18n/en/translations.json application/json
                            upload [12] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/es/translations.json i18n/es/translations.json application/json
                            upload [11] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                            upload [10] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/it/translations.json i18n/it/translations.json application/json
                            upload [9] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                            upload [8] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                            upload [7] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                            upload [6] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                            upload [5] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                            upload [4] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                            upload [3] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
                            upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/img/info-big.png img/info-big.png image/png
                            upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/jsonConfig.json jsonConfig.json application/json
                            upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
                            Update homeconnect from @1.3.0 to @1.4.1
                            NPM version: 10.8.2
                            Installing iobroker.homeconnect@1.4.1... (System call)
                            added 1 package, and changed 2 packages in 16s
                            Update "system.adapter.homeconnect.0"
                            upload [15] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/homeconnect-880x800.png homeconnect-880x800.png image/png
                            upload [14] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/homeconnect.png homeconnect.png image/png
                            upload [13] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/de/translations.json i18n/de/translations.json application/json
                            upload [12] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/en/translations.json i18n/en/translations.json application/json
                            upload [11] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/es/translations.json i18n/es/translations.json application/json
                            upload [10] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                            upload [9] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/it/translations.json i18n/it/translations.json application/json
                            upload [8] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                            upload [7] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                            upload [6] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                            upload [5] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                            upload [4] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                            upload [3] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                            upload [2] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/index_m.html index_m.html text/html
                            upload [1] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/style.css style.css text/css
                            upload [0] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/words.js words.js application/javascript
                            Update hm-rpc from @1.16.0 to @2.0.2
                            NPM version: 10.8.2
                            Installing iobroker.hm-rpc@2.0.2... (System call)
                            added 1 package, and changed 2 packages in 10s
                            Update "system.adapter.hm-rpc.0"
                            Update "system.adapter.hm-rpc.1"
                            upload [279] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
                            upload [250] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-pe_thumb.png icons/113_hmip-psm-pe_thumb.png image/png
                            upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/157_hmip-broll_hmip-bbl_thumb.png icons/157_hmip-broll_hmip-bbl_thumb.png image/png
                            upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/202_hmip-wrcr_thumb_right.png icons/202_hmip-wrcr_thumb_right.png image/png
                            upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/3_hm-lc-sw4-sm_thumb.png icons/3_hm-lc-sw4-sm_thumb.png image/png
                            upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/50_hm-sec-mdir_thumb.png icons/50_hm-sec-mdir_thumb.png image/png
                            upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/58_hmw-sen-sc-12-fm_thumb.png icons/58_hmw-sen-sc-12-fm_thumb.png image/png
                            upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/68_hm-lc-sw4-dr_thumb.png icons/68_hm-lc-sw4-dr_thumb.png image/png
                            upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/78_hm-ou-led16_thumb.png icons/78_hm-ou-led16_thumb.png image/png
                            upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/86_hm-rc-sec4-2_thumb.png icons/86_hm-rc-sec4-2_thumb.png image/png
                            upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/98_hm-sec-sco_thumb.png icons/98_hm-sec-sco_thumb.png image/png
                            upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/HmIPW-FALMOT-C12.png icons/HmIPW-FALMOT-C12.png image/png
                            upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/group_hm-cc-vg-1.png icons/group_hm-cc-vg-1.png image/png
                            upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hb-uni-sen-cap-moist.png icons/hb-uni-sen-cap-moist.png image/png
                            upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hb-uni-sen-temp-ds18b20_thumb.png icons/hb-uni-sen-temp-ds18b20_thumb.png image/png
                            upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-dim.png icons/hm-coupling-dim.png image/png
                            upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-group.png icons/hm-coupling-group.png image/png
                            upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-onoff.png icons/hm-coupling-onoff.png image/png
                            upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb-dim.png icons/hm-coupling-rgb-dim.png image/png
                            upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb.png icons/hm-coupling-rgb.png image/png
                            upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw-dim.png icons/hm-coupling-rgbw-dim.png image/png
                            upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw.png icons/hm-coupling-rgbw.png image/png
                            upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white-dim.png icons/hm-coupling-white-dim.png image/png
                            upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white.png icons/hm-coupling-white.png image/png
                            upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-hue_gateway.png icons/hm-hue_gateway.png image/png
                            upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-lightify_gateway.png icons/hm-lightify_gateway.png image/png
                            upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm_resc-win-pcb-sc_thumb.png icons/hm_resc-win-pcb-sc_thumb.png image/png
                            upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hmip_brc2.png icons/hmip_brc2.png image/png
                            upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/pc.png icons/pc.png image/png
                            upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/sonos.png icons/sonos.png image/png
                            upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/unknown_device_thumb.png icons/unknown_device_thumb.png image/png
                            upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/jsonConfig.json jsonConfig.json application/json
                            upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/words.js words.js application/javascript
                            Update daikin-cloud from @0.3.0 to @0.4.8
                            NPM version: 10.8.2
                            Installing iobroker.daikin-cloud@0.4.8... (System call)
                            added 2 packages, removed 14 packages, and changed 4 packages in 11s
                            113 packages are looking for funding
                            Update "system.adapter.daikin-cloud.0"
                            upload [16] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/admin.d.ts admin.d.ts video/mp2t
                            upload [15] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin-cloud.jpg daikin-cloud.jpg image/jpeg
                            upload [14] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin_logo.jpg daikin_logo.jpg image/jpeg
                            upload [13] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/de/translations.json i18n/de/translations.json application/json
                            upload [12] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/en/translations.json i18n/en/translations.json application/json
                            upload [11] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/es/translations.json i18n/es/translations.json application/json
                            upload [10] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                            upload [9] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/it/translations.json i18n/it/translations.json application/json
                            upload [8] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                            upload [7] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                            upload [6] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                            upload [5] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                            upload [4] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                            upload [3] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                            upload [2] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/jsonConfig.json jsonConfig.json application/json
                            upload [1] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/warning.png warning.png image/png
                            upload [0] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/words.js words.js application/javascript
                            Update backitup from @2.10.11 to @3.0.22
                            host.IoBroker Adapter "system.adapter.backitup.0" is stopped.
                            NPM version: 10.8.2
                            Installing iobroker.backitup@3.0.22... (System call)
                            added 5 packages, and changed 20 packages in 17s
                            Update "system.adapter.backitup.0"
                            upload [90] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                            upload [80] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/i18n/fr.json custom/i18n/fr.json application/json
                            upload [70] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/static/js/main.0fac7bdb.js custom/static/js/main.0fac7bdb.js application/javascript
                            upload [60] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_index_js-node_modules_mui_styled-engine_Global-8c01ec.f3ac9a38.chunk.js custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_index_js-node_modules_mui_styled-engine_Global-8c01ec.f3ac9a38.chunk.js application/javascript
                            upload [50] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/static/js/vendors-node_modules_react-color_es_index_js.3c56e9e1.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js.3c56e9e1.chunk.js application/javascript
                            upload [40] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/googledrive.jsonConfig.json5 googledrive.jsonConfig.json5 application/json5
                            upload [30] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                            upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/main.jsonConfig.json5 main.jsonConfig.json5 application/json5
                            upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/manifest.json manifest.json application/json
                            upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/mysql.jsonConfig.json5 mysql.jsonConfig.json5 application/json5
                            upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/notifications.jsonConfig.json5 notifications.jsonConfig.json5 application/json5
                            upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/onedrive.jsonConfig.json5 onedrive.jsonConfig.json5 application/json5
                            upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/pgsql.jsonConfig.json5 pgsql.jsonConfig.json5 application/json5
                            upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/redis.jsonConfig.json5 redis.jsonConfig.json5 application/json5
                            upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/restore.jsonConfig.json5 restore.jsonConfig.json5 application/json5
                            upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/sqlite.jsonConfig.json5 sqlite.jsonConfig.json5 application/json5
                            upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/css/main.bd1167d4.css static/css/main.bd1167d4.css text/css
                            upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/js/245.7caf1dae.chunk.js static/js/245.7caf1dae.chunk.js application/javascript
                            upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/js/main.2cca4954.js static/js/main.2cca4954.js application/javascript
                            upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/js/main.2cca4954.js.LICENSE.txt static/js/main.2cca4954.js.LICENSE.txt text/plain
                            upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/media/history.d21dcfa508bd8a624c85.png static/media/history.d21dcfa508bd8a624c85.png image/png
                            upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                            upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                            upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                            upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                            upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/webdav.jsonConfig.json5 webdav.jsonConfig.json5 application/json5
                            upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                            upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/zigbee2mqtt.jsonConfig.json5 zigbee2mqtt.jsonConfig.json5 application/json5
                            host.IoBroker Adapter "system.adapter.backitup.0" is started
                            fabio@IoBroker:~ $
                              Thomas Braun Most Active @Flowski last edited by
                              @flowski
                              Was kommt bei einem
                              iob update
                              um's Eck?
                                Flowski @Thomas Braun last edited by Negalein
                                fabio@IoBroker:~ $ iob update
                                Used repository: stable
                                Adapter    "admin"        : 7.1.5    , installed 7.1.5
                                Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                                Adapter    "daikin-cloud" : 0.4.8    , installed 0.4.8
                                Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                Adapter    "ham"          : 5.3.1    , installed 5.3.1
                                Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
                                Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
                                Adapter    "ical"         : 1.15.0   , installed 1.15.0
                                Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                                Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                Controller "js-controller": 6.0.11   , installed 6.0.11
                                Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                Adapter    "meross"       : 1.17.0   , installed 1.17.0
                                Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                                Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                                Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
                                Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                                Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                                Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                                Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                                Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
                                Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                fabio@IoBroker:~ $
                                  @flowski
                                  Gut.
                                  iob start admin
                                  und die Kiste sollte wieder an den Start kommen.
                                    @thomas-braun bislang tut sich nix
                                    fabio@IoBroker:~ $ iob start admin
                                    fabio@IoBroker:~ $
                                      @flowski
                                      iob diag
                                        bash
                                        Skript v.2024-08-12
                                        *** BASE SYSTEM ***
                                           Static hostname: IoBroker
                                                 Icon name: computer
                                          Operating System: Debian GNU/Linux 11 (bullseye)
                                                    Kernel: Linux 6.1.21-v8+
                                              Architecture: arm64
                                        OS is similar to:
                                        Model           : Raspberry Pi 4 Model B Rev 1.2
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : aarch64
                                        Userland        : 64 bit
                                        Systemuptime and Load:
                                         21:35:42 up 48 min,  2 users,  load average: 0.35, 0.21, 0.53
                                        CPU threads: 4
                                        *** RASPBERRY THROTTLING ***
                                        Current issues:
                                        Previously detected issues:
                                        ~ Under-voltage has occurred
                                        ~ Arm frequency capping has occurred
                                        ~ Throttling has occurred
                                        ~ Soft temperature limit has occurred
                                        *** Time and Time Zones ***
                                                       Local time: Tue 2024-10-08 21:35:42 CEST
                                                   Universal time: Tue 2024-10-08 19:35:42 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** Users and Groups ***
                                        User that called 'iob diag':
                                        fabio
                                        HOME=/home/fabio
                                        GROUPS=fabio sudo iobroker
                                        js-controller is not running
                                        *** Display-Server-Setup ***
                                        Display-Server: false
                                        Desktop:
                                        Terminal:       tty
                                        Boot Target:    multi-user.target
                                        *** MEMORY ***
                                        Mem:            3.8G        107M        920M        1.0M        2.8G        3.6G
                                        Swap:            99M          0B         99M
                                        Total:          3.9G        107M        1.0G
                                        Active iob-Instances:   1
                                                 3794 M total memory
                                                  107 M used memory
                                                  213 M active memory
                                                 2439 M inactive memory
                                                  920 M free memory
                                                   68 M buffer memory
                                                 2698 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        top - 21:35:43 up 48 min,  2 users,  load average: 0.35, 0.21, 0.53
                                        Tasks: 162 total,   1 running, 161 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s):  1.4 us,  2.9 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :   3794.3 total,    919.3 free,    107.8 used,   2767.3 buff/cache
                                        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3610.0 avail Mem
                                        *** FAILED SERVICES ***
                                          UNIT                LOAD   ACTIVE SUB    DESCRIPTION
                                        * iobroker.service    loaded failed failed ioBroker Server
                                        * pivccu-dkms.service loaded failed failed piVCCU DKMS Modules
                                        LOAD   = Reflects whether the unit definition was properly loaded.
                                        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                                        SUB    = The low-level unit activation state, values depend on unit type.
                                        2 loaded units listed.
                                        *** FILESYSTEM ***
                                        /dev/root      ext4       59G  8.7G   48G  16% /
                                        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                        tmpfs          tmpfs     759M  1.2M  758M   1% /run
                                        /dev/mmcblk0p1 vfat      255M   32M  224M  13% /boot
                                        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                        tmpfs          tmpfs     380M     0  380M   0% /run/user/1002
                                        [Tue Oct  8 20:46:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:83:48 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=2a0531f8-02 rootfstype=ext4 fsck.repair=yes rootwait
                                        [Tue Oct  8 20:46:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Tue Oct  8 20:46:56 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                        [Tue Oct  8 20:46:58 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                        Show mounted filesystems:
                                        TARGET  SOURCE         FSTYPE OPTIONS
                                        /       /dev/mmcblk0p2 ext4   rw,noatime
                                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                        /var:
                                        du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
                                        3.7G    /var/
                                        2.1G    /var/log/journal/664a8e581ec84405863df59a10cf9293
                                        2.1G    /var/log
                                        817M    /var/lib
                                        Archived and active journals take up 8.0M in the file system.
                                        /opt/iobroker/backups:
                                        58M     /opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        913M    /opt/iobroker/iobroker-data/
                                        840M    /opt/iobroker/iobroker-data/files
                                        617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                                        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                        16M     /opt/iobroker/iobroker-data/objects.jsonl
                                        14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
                                        USB-Devices by-id:
                                        /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                        /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AI03D64S-if00-port0
                                        Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                                        *** NodeJS-Installation ***
                                        /usr/bin/nodejs         v20.18.0
                                        /usr/bin/node           v20.18.0
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        /usr/bin/corepack       0.29.3
                                        nodejs:
                                          Installed: 20.18.0-1nodesource1
                                          Candidate: 20.18.0-1nodesource1
                                          Version table:
                                         *** 20.18.0-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                                100 /var/lib/dpkg/status
                                             20.17.0-1nodesource1 1001
                                             20.16.0-1nodesource1 1001
                                             20.15.1-1nodesource1 1001
                                             20.15.0-1nodesource1 1001
                                             20.14.0-1nodesource1 1001
                                             20.13.1-1nodesource1 1001
                                             20.13.0-1nodesource1 1001
                                             20.12.2-1nodesource1 1001
                                             20.12.1-1nodesource1 1001
                                             20.12.0-1nodesource1 1001
                                             20.11.1-1nodesource1 1001
                                             20.11.0-1nodesource1 1001
                                             20.10.0-1nodesource1 1001
                                             20.9.0-1nodesource1 1001
                                             20.8.1-1nodesource1 1001
                                             20.8.0-1nodesource1 1001
                                             20.7.0-1nodesource1 1001
                                             20.6.1-1nodesource1 1001
                                             20.6.0-1nodesource1 1001
                                             20.5.1-1nodesource1 1001
                                             20.5.0-1nodesource1 1001
                                             20.4.0-1nodesource1 1001
                                             20.3.1-1nodesource1 1001
                                             20.3.0-1nodesource1 1001
                                             20.2.0-1nodesource1 1001
                                             20.1.0-1nodesource1 1001
                                             20.0.0-1nodesource1 1001
                                             12.22.12~dfsg-1~deb11u5 500
                                                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                             12.22.12~dfsg-1~deb11u4 500
                                                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                        No problems detected
                                        Errors in npm tree:
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        iobroker is not running on this host.
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Core adapters versions
                                        js-controller:  6.0.11
                                        admin:          7.1.5
                                        javascript:     8.8.3
                                        nodejs modules from github:     0
                                        Adapter State
                                          system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          system.adapter.alexa2.0                 : alexa2                : IoBroker                                 -  enabled
                                          system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
                                          system.adapter.daikin-cloud.0           : daikin-cloud          : IoBroker                                 - disabled
                                          system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
                                          system.adapter.ham.0                    : ham                   : IoBroker                                 -  enabled
                                          system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
                                          system.adapter.hm-rpc.0                 : hm-rpc                : IoBroker                                 -  enabled
                                          system.adapter.hm-rpc.1                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
                                          system.adapter.homeconnect.0            : homeconnect           : IoBroker                                 -  enabled
                                          system.adapter.ical.0                   : ical                  : IoBroker                                 -  enabled
                                          system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
                                          system.adapter.jarvis.0                 : jarvis                : IoBroker                                 -  enabled
                                          system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
                                          system.adapter.linux-control.0          : linux-control         : IoBroker                                 -  enabled
                                          system.adapter.meross.0                 : meross                : IoBroker                                 -  enabled
                                          system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
                                          system.adapter.mihome.0                 : mihome                : IoBroker                                 - disabled, port: 9898, bind: 0.0.0.0
                                          system.adapter.mqtt.0                   : mqtt                  : IoBroker                                 - disabled, port: 1883, bind: 0.0.0.0
                                          system.adapter.netatmo-crawler.0        : netatmo-crawler       : IoBroker                                 -  enabled
                                          system.adapter.rpi2.0                   : rpi2                  : IoBroker                                 -  enabled
                                          system.adapter.sonoff.0                 : sonoff                : IoBroker                                 -  enabled, port: 1883, bind: 192.168.178.46
                                          system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
                                          system.adapter.terminal.0               : terminal              : IoBroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                          system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
                                          system.adapter.tuya.0                   : tuya                  : IoBroker                                 -  enabled
                                          system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IoBroker                                 -  enabled
                                          system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : IoBroker                                 -  enabled
                                          system.adapter.yeelight-2.0             : yeelight-2            : IoBroker                                 -  enabled
                                          system.adapter.zigbee.0                 : zigbee                : IoBroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                        + instance is alive
                                        ioBroker-Repositories
                                        Active repo(s): stable
                                        Upgrade policy: none
                                        Installed ioBroker-Instances
                                        Objects and States
                                        Objects:        7521
                                        States:         5852
                                        Hit:1 http://deb.debian.org/debian bullseye InRelease
                                        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                        Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
                                        Reading package lists...
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14606      1044/dnsmasq
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13147      1036/sshd: /usr/sbi
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          13149      1036/sshd: /usr/sbi
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12941      433/avahi-daemon: r
                                        udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14605      1044/dnsmasq
                                        udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14602      1044/dnsmasq
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13052      849/dhclient
                                        udp        0      0 0.0.0.0:33135           0.0.0.0:*                           108        12943      433/avahi-daemon: r
                                        udp6       0      0 :::5353                 :::*                                108        12942      433/avahi-daemon: r
                                        udp6       0      0 :::58117                :::*                                108        12944      433/avahi-daemon: r
                                        2024-10-08 21:11:10.669  - info: host.IoBroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                        2024-10-08 21:11:10.732  - info: host.IoBroker instance system.adapter.alexa2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                        2024-10-08 21:11:10.733  - info: host.IoBroker instance system.adapter.ham.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                        2024-10-08 21:11:10.734  - info: host.IoBroker instance system.adapter.iot.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                        2024-10-08 21:11:10.747  - info: host.IoBroker instance system.adapter.whatsapp-cmb.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                        2024-10-08 21:11:11.096  - info: host.IoBroker instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                        2024-10-08 21:11:11.097  - info: host.IoBroker instance system.adapter.whatsapp-cmb.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                        2024-10-08 21:11:11.097  - info: host.IoBroker instance system.adapter.tankerkoenig.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                        2024-10-08 21:11:11.098  - info: host.IoBroker instance system.adapter.hm-rega.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                        2024-10-08 21:11:11.098  - warn: host.IoBroker instance system.adapter.hm-rpc.0 terminated due to SIGTERM
                                        2024-10-08 21:11:11.098  - info: host.IoBroker instance system.adapter.hm-rpc.0 terminated with code null ()
                                        2024-10-08 21:11:11.099  - warn: host.IoBroker instance system.adapter.sonoff.0 terminated due to SIGTERM
                                        2024-10-08 21:11:11.099  - info: host.IoBroker instance system.adapter.sonoff.0 terminated with code null ()
                                        2024-10-08 21:11:11.099  - warn: host.IoBroker instance system.adapter.web.0 terminated due to SIGTERM
                                        2024-10-08 21:11:11.100  - info: host.IoBroker instance system.adapter.web.0 terminated with code null ()
                                        2024-10-08 21:11:11.100  - warn: host.IoBroker instance system.adapter.zigbee.0 terminated due to SIGTERM
                                        2024-10-08 21:11:11.100  - info: host.IoBroker instance system.adapter.zigbee.0 terminated with code null ()
                                        2024-10-08 21:11:11.101  - warn: host.IoBroker instance system.adapter.hm-rpc.1 terminated due to SIGTERM
                                        2024-10-08 21:11:11.101  - info: host.IoBroker instance system.adapter.hm-rpc.1 terminated with code null ()
                                        2024-10-08 21:11:11.859  - info: tuya.0 (1498) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2024-10-08 21:11:12.433  - info: host.IoBroker instance system.adapter.tuya.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                        2024-10-08 21:11:13.061  - info: meross.0 (1382) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2024-10-08 21:11:13.634  - info: host.IoBroker instance system.adapter.meross.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2024-10-08 21:11:13.635  - info: host.IoBroker All instances are stopped.
                                        2024-10-08 21:11:13.863  - info: host.IoBroker terminated
        v.2024-08-12
                                                 Icon name: computer
                                              Architecture: arm64
                                        Installation:           native
                                        Kernel:                 aarch64
                                        Userland:               64 bit
                                        Timezone:               Europe/Berlin (CEST, +0200)
                                        User-ID:                1002
                                        Pending OS-Updates:     0
                                        Pending iob updates:    0
                                        Nodejs-Installation:
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        Recommended versions are nodejs 20.18.0 and npm 10.8.2
                                        MEMORY:
                                        Mem:            3.8G        111M        920M        1.0M        2.8G        3.6G
                                        Swap:            99M          0B         99M
                                        Total:          3.9G        111M        1.0G
                                        ioBroker Core:          js-controller           6.0.11
        admin                   7.1.5
                                        ioBroker Status:        iobroker is not running on this host.
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects:                7521
                                        States:                 5852
                                        Size of iob-Database:
                                        7.2M    /opt/iobroker/iobroker-data/states.jsonl
                                          • iobroker.service loaded failed failed ioBroker Server
                                          iobroker start
                                            @thomas-braun jetzt ist iobroker, jarvis usw. wieder erreichbar. lediglich homematic steht in den Adaptern auf rot, ne idee?
                                            bash
                                            Skript v.2024-08-12
                                            *** BASE SYSTEM ***
                                                     Icon name: computer
                                                  Architecture: arm64
                                            OS is similar to:
                                            Docker          : false
                                            Kernel          : aarch64
                                            Userland        : 64 bit
                                             21:47:18 up  1:00,  2 users,  load average: 1.69, 1.67, 1.09
                                            CPU threads: 4
                                            Current issues:
                                                           Local time: Tue 2024-10-08 21:47:18 CEST
                                                       Universal time: Tue 2024-10-08 19:47:18 UTC
                                                             RTC time: n/a
                                                          NTP service: active
                                                      RTC in local TZ: no
                                            fabio
                                            HOME=/home/fabio
                                            iobroker
                                            HOME=/home/iobroker
                                            GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                            Desktop:
                                            Terminal:       tty
                                            *** MEMORY ***
                                            Mem:            3.8G        1.5G        597M        1.0M        1.7G        2.2G
                                            Swap:            99M          0B         99M
                                            Total:          3.9G        1.5G        697M
                                            Active iob-Instances:   25
                                                     3794 M total memory
                                                     1542 M used memory
                                                     1624 M active memory
                                                     1292 M inactive memory
                                                      597 M free memory
                                                      127 M buffer memory
                                                     1526 M swap cache
                                                       99 M total swap
                                                        0 M used swap
                                                       99 M free swap
                                            top - 21:47:19 up  1:00,  2 users,  load average: 1.69, 1.67, 1.09
                                            Tasks: 191 total,   1 running, 190 sleeping,   0 stopped,   0 zombie
                                            %Cpu(s):  1.4 us,  2.8 sy,  0.0 ni, 95.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                            MiB Mem :   3794.3 total,    597.5 free,   1542.4 used,   1654.4 buff/cache
                                            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2175.3 avail Mem
                                            1 loaded units listed.
                                            *** FILESYSTEM ***
                                            /dev/root      ext4       59G  8.8G   48G  16% /
                                            /var:
                                            3.7G    /var/
                                            2.1G    /var/log
                                            817M    /var/lib
                                            909M    /opt/iobroker/iobroker-data/
                                            10M     /opt/iobroker/iobroker-data/objects.jsonl
                                            USB-Devices by-id:
                                            /usr/bin/npm            10.8.2
                                            /usr/bin/npx            10.8.2
                                            nodejs:
                                              Version table:
                                            Errors in npm tree:
                                            ioBroker Status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            admin:          7.1.5
                                            javascript:     8.8.3
                                            Adapter State
                                            + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                            + system.adapter.alexa2.0                 : alexa2                : IoBroker                                 -  enabled
                                            + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
                                            + system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
                                            + system.adapter.ham.0                    : ham                   : IoBroker                                 -  enabled
                                            + system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
                                            + system.adapter.homeconnect.0            : homeconnect           : IoBroker                                 -  enabled
                                            + system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
                                            + system.adapter.jarvis.0                 : jarvis                : IoBroker                                 -  enabled
                                            + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
                                            + system.adapter.linux-control.0          : linux-control         : IoBroker                                 -  enabled
                                            + system.adapter.meross.0                 : meross                : IoBroker                                 -  enabled
                                            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
                                            + system.adapter.rpi2.0                   : rpi2                  : IoBroker                                 -  enabled
                                            + system.adapter.sonoff.0                 : sonoff                : IoBroker                                 -  enabled, port: 1883, bind: 192.168.178.46
                                            + system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
                                            + system.adapter.terminal.0               : terminal              : IoBroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                            + system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
                                            + system.adapter.tuya.0                   : tuya                  : IoBroker                                 -  enabled
                                            + system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IoBroker                                 -  enabled
                                            + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : IoBroker                                 -  enabled
                                            + system.adapter.yeelight-2.0             : yeelight-2            : IoBroker                                 -  enabled
                                            + system.adapter.zigbee.0                 : zigbee                : IoBroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                            + instance is alive
                                            Objects and States
                                            Objects:        7600
                                            States:         5939
                                            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                            Hit:2 http://deb.debian.org/debian bullseye InRelease
                                            Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                            Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
                                            Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
                                            Pending Updates: 0
                                            tcp        0      0 192.168.178.46:1883     0.0.0.0:*               LISTEN      1001       38656      11108/io.sonoff.0
                                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       35395      10803/iobroker.js-c
                                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       36274      10803/iobroker.js-c
                                            tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       39945      11336/io.jarvis.0
                                            tcp6       0      0 :::8088                 :::*                    LISTEN      1001       37795      11464/io.terminal.0
                                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35443      10826/io.admin.0
                                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       38884      11317/io.web.0
                                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       41098      11184/io.ham.0
                                            udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       35719      11093/io.mihome-vac
                                            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       37615      11234/io.tuya.0
                                            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       37616      11234/io.tuya.0
                                            2024-10-08 21:47:30.711  - error: hm-rega.0 (10994) CCU 192.168.178.47 unreachable
                                            2024-10-08 21:47:33.801  - info: netatmo-crawler.0 (12424) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                            2024-10-08 21:47:33.907  - info: netatmo-crawler.0 (12424) Getting data for stationid:70:ee:50:22:e4:6e
                                            2024-10-08 21:47:34.887  - info: netatmo-crawler.0 (12424) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                            2024-10-08 21:47:35.441  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 having pid 12424 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2024-10-08 21:47:50.799  - info: hm-rpc.1 (12180) xmlrpc -> 192.168.178.47:2010/ init ["http://192.168.178.46:2010",""]
                                            2024-10-08 21:47:50.799  - info: hm-rpc.0 (12186) xmlrpc -> 192.168.178.47:2001/ init ["http://192.168.178.46:2001",""]
                                            2024-10-08 21:47:50.807  - error: hm-rpc.1 (12180) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.47:2010
                                            2024-10-08 21:47:50.809  - error: hm-rpc.0 (12186) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.47:2001
                                            2024-10-08 21:47:50.808  - warn: hm-rpc.1 (12180) setTimeout called, but adapter is shutting down
                                            2024-10-08 21:47:50.810  - warn: hm-rpc.0 (12186) setTimeout called, but adapter is shutting down
                                            2024-10-08 21:47:51.812  - info: hm-rpc.1 (12180) terminating
                                            2024-10-08 21:47:51.814  - info: hm-rpc.1 (12180) Terminated (NO_ERROR): Without reason
                                            2024-10-08 21:47:51.821  - info: hm-rpc.0 (12186) terminating
                                            2024-10-08 21:47:51.823  - info: hm-rpc.0 (12186) Terminated (NO_ERROR): Without reason
                                            2024-10-08 21:47:52.477  - info: host.IoBroker instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
                                            2024-10-08 21:47:52.479  - info: host.IoBroker Restart adapter system.adapter.hm-rpc.1 because enabled
                                            2024-10-08 21:47:52.538  - info: host.IoBroker instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                                            2024-10-08 21:47:52.538  - info: host.IoBroker Restart adapter system.adapter.hm-rpc.0 because enabled
                                            2024-10-08 21:48:00.110  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 12970
                                            2024-10-08 21:48:03.799  - error: hm-rega.0 (10994) CCU 192.168.178.47 unreachable
                                            2024-10-08 21:48:04.085  - info: netatmo-crawler.0 (12970) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                            2024-10-08 21:48:04.178  - info: netatmo-crawler.0 (12970) Getting data for stationid:70:ee:50:22:e4:6e
                                            2024-10-08 21:48:05.463  - info: netatmo-crawler.0 (12970) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                            2024-10-08 21:48:06.020  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 having pid 12970 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            3039
