    4. Updateschwierigkeiten js-controller 4.0.23
      Thomas Braun Most Active @Flowski last edited by
      @flowski
      Das komplette System. Offenbar war da ein Kernel-Update dabei, weswegen da jetzt per dkms z.B. der pivccu neugebaut werden muss.
        Flowski @Thomas Braun last edited by
        @thomas-braun heißt jetzt für Dummies? Sorry aber bin mit den Befehlen noch nicht ganz fit
          @flowski
          iob stop
          sudo reboot
          Wenn die Kiste wieder erreichbar ist
          iob update
          iob upgrade all -y
            @thomas-braun danke für deinen support, jetzt erscheint folgendes im Terminal:
            fabio@IoBroker:/home/pi $ iob stop
            fabio@IoBroker:/home/pi $ sudo reboot
            [sudo] password for fabio:
            Connection to 192.168.178.46 closed by remote host.
            Connection to 192.168.178.46 closed.
            PS C:\Users\mulla> ssh pi@192.168.178.46
            pi@192.168.178.46's password:
            Linux IoBroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
            The programs included with the Debian GNU/Linux system are free software;
            the exact distribution terms for each program are described in the
            individual files in /usr/share/doc/*/copyright.
            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
            permitted by applicable law.
            Last login: Tue Oct  8 20:04:34 2024 from 192.168.178.131
            Wi-Fi is currently blocked by rfkill.
            Use raspi-config to set the country before use.
            pi@IoBroker:~ $ iob update
            Used repository: stable
            Adapter    "admin"        : 7.1.5    , installed 7.0.22 [Updatable]
            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
            Adapter    "backitup"     : 3.0.22   , installed 2.10.11 [Updatable]
            Adapter    "daikin-cloud" : 0.4.8    , installed 0.3.0  [Updatable]
            Adapter    "device-reminder": 3.1.2  , installed 3.1.2
            Adapter    "discovery"    : 5.0.0    , installed 4.5.0  [Updatable]
            Adapter    "ham"          : 5.3.1    , installed 5.3.1
            Adapter    "hm-rega"      : 5.0.0    , installed 4.0.0  [Updatable]
            Adapter    "hm-rpc"       : 2.0.2    , installed 1.16.0 [Updatable]
            Adapter    "homeconnect"  : 1.4.1    , installed 1.3.0  [Updatable]
            Adapter    "ical"         : 1.15.0   , installed 1.14.3 [Updatable]
            Adapter    "iot"          : 3.3.0    , installed 3.3.0
            Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
            Adapter    "javascript"   : 8.8.3    , installed 7.8.0  [Updatable]
            Controller "js-controller": 6.0.11   , installed 4.0.23 [Updatable]
            Adapter    "linux-control": 1.1.5    , installed 1.1.5
            Adapter    "meross"       : 1.17.0   , installed 1.17.0
            Adapter    "mihome"       : 1.4.0    , installed 1.4.0
            Adapter    "mihome-vacuum": 4.2.0    , installed 3.8.6  [Updatable]
            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
            Adapter    "mqtt-client"  : 2.0.0    , installed 1.6.3  [Updatable]
            Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "sonoff"       : 3.1.2    , installed 3.0.3  [Updatable]
            Adapter    "tankerkoenig" : 3.4.0    , installed 3.1.0  [Updatable]
            Adapter    "terminal"     : 1.0.0    , installed 1.0.0
            Adapter    "trashschedule": 3.3.0    , installed 3.2.0  [Updatable]
            Adapter    "tuya"         : 3.16.0   , installed 3.15.0 [Updatable]
            Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.2.3  [Updatable]
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Adapter    "yeelight-2"   : 1.4.0    , installed 1.2.1  [Updatable]
            Adapter    "zigbee"       : 1.10.3   , installed 1.8.10 [Updatable]
            pi@IoBroker:~ $ cu fabio
            -bash: cu: command not found
            pi@IoBroker:~ $ ssh fabio@192.168.178.46
            The authenticity of host '192.168.178.46 (192.168.178.46)' can't be established.
            ECDSA key fingerprint is SHA256:FIhsIFzSsCA3qcV8rP3HPxSWGbgQ71sBXmHraXwu1t0.
            Are you sure you want to continue connecting (yes/no/[fingerprint])? n
            Please type 'yes', 'no' or the fingerprint: no
            Host key verification failed.
            pi@IoBroker:~ $ su fabio
            Password:
            fabio@IoBroker:/home/pi $ iob update
            fabio@IoBroker:/home/pi $ iob upgrade all -y
            Cannot check dependencies: Invalid version of "js-controller". Installed "4.0.23", required ">=5.0.19
            Update hm-rega from @4.0.0 to @5.0.0
            NPM version: 10.8.2
            Installing iobroker.hm-rega@5.0.0... (System call)
            added 2 packages, removed 399 packages, and changed 2 packages in 16s
            131 packages are looking for funding
              run `npm fund` for details
            Update "system.adapter.hm-rega.0"
            upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
            upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
            upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
            upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
            Update discovery from @4.5.0 to @5.0.0
            NPM version: 10.8.2
            Installing iobroker.discovery@5.0.0... (System call)
            changed 1 package in 11s
            Update "system.adapter.discovery.0"
            upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
            upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
            upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
            upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
            upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
            upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
            upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
            Update admin from @7.0.22 to @7.1.5
            host.IoBroker Adapter "system.adapter.admin.0" is stopped.
            NPM version: 10.8.2
            Installing iobroker.admin@7.1.5... (System call)
            added 11 packages, removed 3 packages, and changed 11 packages in 21s
            Update "system.adapter.admin.0"
            upload [68] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
            upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
            upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js application/javascript
            upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js application/javascript
            upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js application/javascript
            upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js application/javascript
            upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map application/json
            upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js application/javascript
            upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map application/json
            upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js application/javascript
            upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map application/json
            upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js application/javascript
            upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map application/json
            upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
            upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
            upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
            host.IoBroker Adapter "system.adapter.admin.0" is started
            Update zigbee from @1.8.10 to @1.10.3
            host.IoBroker Adapter "system.adapter.zigbee.0" is stopped.
            NPM version: 10.8.2
            Installing iobroker.zigbee@1.10.3... (System call)
            added 18 packages, removed 19 packages, and changed 24 packages in 33s
            120 packages are looking for funding
            Update "system.adapter.zigbee.0"
            upload [331] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
            upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/E2213.png img/E2213.png image/png
            upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/cc2538_router_v1.png img/cc2538_router_v1.png image/png
            upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hue-smart-button.png img/hue-smart-button.png image/png
            upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_lamp.png img/lifecontrol_lamp.png image/png
            upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_fuzo_outdoor_wall_light.png img/philips_fuzo_outdoor_wall_light.png image/png
            upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_argenta_4.png img/philips_hue_argenta_4.png image/png
            upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_gu10_ambiance.png img/philips_hue_gu10_ambiance.png image/png
            upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lwv001.png img/philips_hue_lwv001.png image/png
            upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/previous_track.png img/previous_track.png image/png
            upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_philipshue.png img/sensor_philipshue.png image/png
            upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smartthings_motion.png img/smartthings_motion.png image/png
            upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ts0203.png img/ts0203.png image/png
            upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_tyzs1l.png img/tuya_tyzs1l.png image/png
            upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
            upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
            upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
            upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
            upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
            upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
            upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
            upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
            upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
            upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
            upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
            upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
            upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
            upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
            upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
            upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
            upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
            upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
            upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
            upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
            host.IoBroker Adapter "system.adapter.zigbee.0" is started
            Cannot check dependencies: Invalid version of "js-controller". Installed "4.0.23", required ">=5.0.0
              @flowski sagte in Updateschwierigkeiten js-controller 4.0.23:
              Warum? Stell dich als fabio auch in dessen home und nicht in das home eines anderen users.
              Den Fingerpring für den fabio musst du schon akzeptieren, damit das funktioniert.
              Und warum hast du nicht gleich den 'pi' verwendet, wenn es denn doch schon gab?
              iob stop
              iob ugrade self
              iob upgrade all -y
                Flowski last edited by Flowski
                puh ok 🤕 🙂
                heisst ssh fabio@192.168.178.46
                dann ecdsa key ... mit yes
                Zitat:
                Warum? Stell dich als fabio auch in dessen home und nicht in das home eines anderen users. sorry stehe auf dem Schlauch 😞 muss da sicherlich noch was umstellen bevor ich die drei Befehle eingebe aber begreife es grad nicht
                  @flowski
                  Jeder user hat auf einem Linux-System ein eigenes home-Verzeichnis, indem die eigenen Dateien abgelegt werden.
                    @thomas-braun so: fabio@IoBroker:~ $?
                      @flowski
                      Ja. Die Tilde repräsentiert das home des users.
                        @thomas-braun anbei der log, iobroker ist jetzt aktuell nicht erreichbar im Browser.. brauchts jetzt nochmal ein iob reboot?
                        fabio@IoBroker:/home/pi $  ssh fabio@192.168.178.46
                        Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
                        Warning: Permanently added '192.168.178.46' (ECDSA) to the list of known hosts.
                        fabio@192.168.178.46's password:
                        fabio@IoBroker:~ $ iob stop
                        fabio@IoBroker:~ $ iob upgrade self
                        Update js-controller from @4.0.23 to @6.0.11
                        Stopped Objects DB
                        Stopped States DB
                        NPM version: 10.8.2
                        Installing iobroker.js-controller@6.0.11... (System call)
                        added 10 packages, removed 67 packages, and changed 44 packages in 52s
                        121 packages are looking for funding
                        fabio@IoBroker:~ $ iob upgrade all -y
                        Update yeelight-2 from @1.2.1 to @1.4.0
                        NPM version: 10.8.2
                        Installing iobroker.yeelight-2@1.4.0... (System call)
                        added 2 packages, removed 32 packages, and changed 5 packages in 12s
                        Update "system.adapter.yeelight-2.0"
                        upload [20] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/1.png icons/1.png image/png
                        upload [19] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/2.png icons/2.png image/png
                        upload [18] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/3.png icons/3.png image/png
                        upload [17] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/4.png icons/4.png image/png
                        upload [16] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/5.png icons/5.png image/png
                        upload [15] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/6.png icons/6.png image/png
                        upload [14] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/7.png icons/7.png image/png
                        upload [13] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/bslamp1.png icons/bslamp1.png image/png
                        upload [12] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling1.png icons/ceiling1.png image/png
                        upload [11] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling10.png icons/ceiling10.png image/png
                        upload [10] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling3.png icons/ceiling3.png image/png
                        upload [9] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling4.png icons/ceiling4.png image/png
                        upload [8] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/color.png icons/color.png image/png
                        upload [7] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/desklamp.png icons/desklamp.png image/png
                        upload [6] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/mono.png icons/mono.png image/png
                        upload [5] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/stripe.png icons/stripe.png image/png
                        upload [4] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/index.html index.html text/html
                        upload [3] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/index_m.html index_m.html text/html
                        upload [2] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/lan.jpg lan.jpg image/jpeg
                        upload [1] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/words.js words.js application/javascript
                        upload [0] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/yeelight.png yeelight.png image/png
                        Update whatsapp-cmb from @0.2.3 to @0.3.0
                        NPM version: 10.8.2
                        Installing iobroker.whatsapp-cmb@0.3.0... (System call)
                        changed 1 package in 8s
                        Update "system.adapter.whatsapp-cmb.0"
                        Update "system.adapter.whatsapp-cmb.1"
                        upload [17] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/admin.d.ts admin.d.ts video/mp2t
                        upload [16] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/blockly.js blockly.js application/javascript
                        upload [15] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [14] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [13] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [12] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [11] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [10] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [9] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [8] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [7] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [6] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                        upload [5] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [4] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/index_m.html index_m.html text/html
                        upload [3] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/style.css style.css text/css
                        upload [2] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/tsconfig.json tsconfig.json application/json
                        upload [1] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/whatsapp-cmb.png whatsapp-cmb.png image/png
                        upload [0] whatsapp-cmb.admin /opt/iobroker/node_modules/iobroker.whatsapp-cmb/admin/words.js words.js application/javascript
                        Update tuya from @3.15.0 to @3.16.0
                        NPM version: 10.8.2
                        Installing iobroker.tuya@3.16.0... (System call)
                        added 73 packages, removed 1 package, and changed 3 packages in 24s
                        124 packages are looking for funding
                        Update "system.adapter.tuya.0"
                        upload [3] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/index_m.html index_m.html text/html
                        upload [2] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/tuya.png tuya.png image/png
                        upload [1] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/warning.png warning.png image/png
                        upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
                        Update trashschedule from @3.2.0 to @3.3.0
                        NPM version: 10.8.2
                        Installing iobroker.trashschedule@3.3.0... (System call)
                        added 1 package, and changed 1 package in 9s
                        Update "system.adapter.trashschedule.0"
                        upload [12] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [11] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [10] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [9] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [8] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [7] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [6] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [5] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [4] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [3] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                        upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json
                        upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png
                        Update tankerkoenig from @3.1.0 to @3.4.0
                        host.IoBroker Adapter "system.adapter.tankerkoenig.0" is stopped.
                        NPM version: 10.8.2
                        Installing iobroker.tankerkoenig@3.4.0... (System call)
                        removed 1 package, and changed 1 package in 10s
                        Update "system.adapter.tankerkoenig.0"
                        upload [4] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js build/index.js application/javascript
                        upload [3] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js.map build/index.js.map application/json
                        upload [2] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/index_m.html index_m.html text/html
                        upload [1] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/style.css style.css text/css
                        upload [0] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/tankerkoenig.png tankerkoenig.png image/png
                        host.IoBroker Adapter "system.adapter.tankerkoenig.0" is started
                        Update sonoff from @3.0.3 to @3.1.2
                        NPM version: 10.8.2
                        Installing iobroker.sonoff@3.1.2... (System call)
                        Update "system.adapter.sonoff.0"
                        upload [15] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [14] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [13] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [12] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [11] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [10] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [9] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [8] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [7] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [6] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                        upload [5] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [4] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
                        upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
                        upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/jsonConfig.json jsonConfig.json application/json
                        upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
                        upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
                        Update mqtt-client from @1.6.3 to @2.0.0
                        NPM version: 10.8.2
                        Installing iobroker.mqtt-client@2.0.0... (System call)
                        added 15 packages, and changed 1 package in 10s
                        upload [13] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [12] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [11] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [10] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [9] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [8] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [7] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [6] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [5] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [4] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                        upload [3] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [2] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/jsonConfig.json jsonConfig.json application/json
                        upload [1] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/jsonCustom.json jsonCustom.json application/json
                        upload [0] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/mqtt-client.png mqtt-client.png image/png
                        Update mihome-vacuum from @3.8.6 to @4.2.0
                        NPM version: 10.8.2
                        Installing iobroker.mihome-vacuum@4.2.0... (System call)
                        added 3 packages, removed 4 packages, and changed 9 packages in 2m
                        Update "system.adapter.mihome-vacuum.0"
                        upload [20] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                        upload [19] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [18] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [17] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [16] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [15] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [14] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [13] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [12] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                        upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                        upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                        upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
                        upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
                        upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
                        upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
                        upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
                        upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
                        upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                        Update javascript from @7.8.0 to @8.8.3
                        NPM version: 10.8.2
                        Installing iobroker.javascript@8.8.3... (System call)
                        added 1 package, removed 1 package, and changed 6 packages in 1m
                        Update "system.adapter.javascript.0"
                        upload [1177] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                        upload [1150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map application/json
                        upload [1100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly-9.3.3.tgz google-blockly/blockly-9.3.3.tgz false
                        upload [1050] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/field_oid.js google-blockly/own/field_oid.js application/javascript
                        upload [1000] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/102.23e64034.chunk.js.map static/js/102.23e64034.chunk.js.map application/json
                        upload [950] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/149.2197f5fc.chunk.js.LICENSE.txt static/js/149.2197f5fc.chunk.js.LICENSE.txt text/plain
                        upload [900] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/228.6096b27c.chunk.js.map static/js/228.6096b27c.chunk.js.map application/json
                        upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/274.47c324f3.chunk.js static/js/274.47c324f3.chunk.js application/javascript
                        upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/327.0f7eca59.chunk.js static/js/327.0f7eca59.chunk.js application/javascript
                        upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.2e64fd76.chunk.js static/js/409.2e64fd76.chunk.js application/javascript
                        upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/432.fb14e4f2.chunk.js.map static/js/432.fb14e4f2.chunk.js.map application/json
                        upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/568.f1b6e961.chunk.js static/js/568.f1b6e961.chunk.js application/javascript
                        upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/675.279d2690.chunk.js static/js/675.279d2690.chunk.js application/javascript
                        upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/772.a8a30056.chunk.js.LICENSE.txt static/js/772.a8a30056.chunk.js.LICENSE.txt text/plain
                        upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/838.92dfa026.chunk.js static/js/838.92dfa026.chunk.js application/javascript
                        upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/894.e378a23c.chunk.js.map static/js/894.e378a23c.chunk.js.map application/json
                        upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/982.2ba0e8b8.chunk.js.LICENSE.txt static/js/982.2ba0e8b8.chunk.js.LICENSE.txt text/plain
                        upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.567b63d3.js static/js/main.567b63d3.js application/javascript
                        upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.d79356b6.js static/js/main.d79356b6.js application/javascript
                        upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Chandelier.0f30083487437c7e9414.svg static/media/Chandelier.0f30083487437c7e9414.svg image/svg+xml
                        upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
                        upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Locker Room.09bd68885c505ed50641.svg static/media/Locker Room.09bd68885c505ed50641.svg image/svg+xml
                        upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.1b2e0a89e9b117740d6e.svg static/media/Speaker.1b2e0a89e9b117740d6e.svg image/svg+xml
                        upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Summer House.541a9fec69f01105e244.svg static/media/Summer House.541a9fec69f01105e244.svg image/svg+xml
                        upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                        upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg image/svg+xml
                        upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.07a51f1a9a8384bbc5ae.svg static/media/Water.07a51f1a9a8384bbc5ae.svg image/svg+xml
                        upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                        upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                        upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                        upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                        upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                        upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                        upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                        upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                        upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                        upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                        upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                        upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                        upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                        upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                        upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                        upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                        upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                        upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                        upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                        upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                        upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                        upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                        upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                        upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                        Update ical from @1.14.3 to @1.15.0
                        NPM version: 10.8.2
                        Installing iobroker.ical@1.15.0... (System call)
                        added 1 package, and changed 1 package in 11s
                        Update "system.adapter.ical.0"
                        upload [14] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [13] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [12] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [11] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [10] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [9] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [8] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [7] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [6] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [5] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                        upload [4] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [3] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
                        upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/img/info-big.png img/info-big.png image/png
                        upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/jsonConfig.json jsonConfig.json application/json
                        upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
                        Update homeconnect from @1.3.0 to @1.4.1
                        NPM version: 10.8.2
                        Installing iobroker.homeconnect@1.4.1... (System call)
                        added 1 package, and changed 2 packages in 16s
                        Update "system.adapter.homeconnect.0"
                        upload [15] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/homeconnect-880x800.png homeconnect-880x800.png image/png
                        upload [14] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/homeconnect.png homeconnect.png image/png
                        upload [13] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [12] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [11] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [10] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [9] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [8] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [7] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [6] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [5] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [4] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                        upload [3] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [2] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/index_m.html index_m.html text/html
                        upload [1] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/style.css style.css text/css
                        upload [0] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/words.js words.js application/javascript
                        Update hm-rpc from @1.16.0 to @2.0.2
                        NPM version: 10.8.2
                        Installing iobroker.hm-rpc@2.0.2... (System call)
                        added 1 package, and changed 2 packages in 10s
                        Update "system.adapter.hm-rpc.0"
                        Update "system.adapter.hm-rpc.1"
                        upload [279] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
                        upload [250] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-pe_thumb.png icons/113_hmip-psm-pe_thumb.png image/png
                        upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/157_hmip-broll_hmip-bbl_thumb.png icons/157_hmip-broll_hmip-bbl_thumb.png image/png
                        upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/202_hmip-wrcr_thumb_right.png icons/202_hmip-wrcr_thumb_right.png image/png
                        upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/3_hm-lc-sw4-sm_thumb.png icons/3_hm-lc-sw4-sm_thumb.png image/png
                        upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/50_hm-sec-mdir_thumb.png icons/50_hm-sec-mdir_thumb.png image/png
                        upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/58_hmw-sen-sc-12-fm_thumb.png icons/58_hmw-sen-sc-12-fm_thumb.png image/png
                        upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/68_hm-lc-sw4-dr_thumb.png icons/68_hm-lc-sw4-dr_thumb.png image/png
                        upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/78_hm-ou-led16_thumb.png icons/78_hm-ou-led16_thumb.png image/png
                        upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/86_hm-rc-sec4-2_thumb.png icons/86_hm-rc-sec4-2_thumb.png image/png
                        upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/98_hm-sec-sco_thumb.png icons/98_hm-sec-sco_thumb.png image/png
                        upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/HmIPW-FALMOT-C12.png icons/HmIPW-FALMOT-C12.png image/png
                        upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/group_hm-cc-vg-1.png icons/group_hm-cc-vg-1.png image/png
                        upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hb-uni-sen-cap-moist.png icons/hb-uni-sen-cap-moist.png image/png
                        upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hb-uni-sen-temp-ds18b20_thumb.png icons/hb-uni-sen-temp-ds18b20_thumb.png image/png
                        upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-dim.png icons/hm-coupling-dim.png image/png
                        upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-group.png icons/hm-coupling-group.png image/png
                        upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-onoff.png icons/hm-coupling-onoff.png image/png
                        upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb-dim.png icons/hm-coupling-rgb-dim.png image/png
                        upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb.png icons/hm-coupling-rgb.png image/png
                        upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw-dim.png icons/hm-coupling-rgbw-dim.png image/png
                        upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw.png icons/hm-coupling-rgbw.png image/png
                        upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white-dim.png icons/hm-coupling-white-dim.png image/png
                        upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white.png icons/hm-coupling-white.png image/png
                        upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-hue_gateway.png icons/hm-hue_gateway.png image/png
                        upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-lightify_gateway.png icons/hm-lightify_gateway.png image/png
                        upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm_resc-win-pcb-sc_thumb.png icons/hm_resc-win-pcb-sc_thumb.png image/png
                        upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hmip_brc2.png icons/hmip_brc2.png image/png
                        upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/pc.png icons/pc.png image/png
                        upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/sonos.png icons/sonos.png image/png
                        upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/unknown_device_thumb.png icons/unknown_device_thumb.png image/png
                        upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/jsonConfig.json jsonConfig.json application/json
                        upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/words.js words.js application/javascript
                        Update daikin-cloud from @0.3.0 to @0.4.8
                        NPM version: 10.8.2
                        Installing iobroker.daikin-cloud@0.4.8... (System call)
                        added 2 packages, removed 14 packages, and changed 4 packages in 11s
                        113 packages are looking for funding
                        Update "system.adapter.daikin-cloud.0"
                        upload [16] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/admin.d.ts admin.d.ts video/mp2t
                        upload [15] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin-cloud.jpg daikin-cloud.jpg image/jpeg
                        upload [14] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin_logo.jpg daikin_logo.jpg image/jpeg
                        upload [13] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [12] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [11] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [10] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [9] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [8] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [7] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [6] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [5] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [4] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                        upload [3] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [2] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/jsonConfig.json jsonConfig.json application/json
                        upload [1] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/warning.png warning.png image/png
                        upload [0] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/words.js words.js application/javascript
                        Update backitup from @2.10.11 to @3.0.22
                        host.IoBroker Adapter "system.adapter.backitup.0" is stopped.
                        NPM version: 10.8.2
                        Installing iobroker.backitup@3.0.22... (System call)
                        added 5 packages, and changed 20 packages in 17s
                        Update "system.adapter.backitup.0"
                        upload [90] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                        upload [80] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/i18n/fr.json custom/i18n/fr.json application/json
                        upload [70] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/static/js/main.0fac7bdb.js custom/static/js/main.0fac7bdb.js application/javascript
                        upload [60] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_index_js-node_modules_mui_styled-engine_Global-8c01ec.f3ac9a38.chunk.js custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_index_js-node_modules_mui_styled-engine_Global-8c01ec.f3ac9a38.chunk.js application/javascript
                        upload [50] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/static/js/vendors-node_modules_react-color_es_index_js.3c56e9e1.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js.3c56e9e1.chunk.js application/javascript
                        upload [40] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/googledrive.jsonConfig.json5 googledrive.jsonConfig.json5 application/json5
                        upload [30] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/main.jsonConfig.json5 main.jsonConfig.json5 application/json5
                        upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/manifest.json manifest.json application/json
                        upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/mysql.jsonConfig.json5 mysql.jsonConfig.json5 application/json5
                        upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/notifications.jsonConfig.json5 notifications.jsonConfig.json5 application/json5
                        upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/onedrive.jsonConfig.json5 onedrive.jsonConfig.json5 application/json5
                        upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/pgsql.jsonConfig.json5 pgsql.jsonConfig.json5 application/json5
                        upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/redis.jsonConfig.json5 redis.jsonConfig.json5 application/json5
                        upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/restore.jsonConfig.json5 restore.jsonConfig.json5 application/json5
                        upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/sqlite.jsonConfig.json5 sqlite.jsonConfig.json5 application/json5
                        upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/css/main.bd1167d4.css static/css/main.bd1167d4.css text/css
                        upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/js/245.7caf1dae.chunk.js static/js/245.7caf1dae.chunk.js application/javascript
                        upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/js/main.2cca4954.js static/js/main.2cca4954.js application/javascript
                        upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/js/main.2cca4954.js.LICENSE.txt static/js/main.2cca4954.js.LICENSE.txt text/plain
                        upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/static/media/history.d21dcfa508bd8a624c85.png static/media/history.d21dcfa508bd8a624c85.png image/png
                        upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                        upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                        upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                        upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                        upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/webdav.jsonConfig.json5 webdav.jsonConfig.json5 application/json5
                        upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                        upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/zigbee2mqtt.jsonConfig.json5 zigbee2mqtt.jsonConfig.json5 application/json5
                        host.IoBroker Adapter "system.adapter.backitup.0" is started
                        fabio@IoBroker:~ $
                          Thomas Braun Most Active @Flowski last edited by
                          @flowski
                          Was kommt bei einem
                          iob update
                          um's Eck?
                            Flowski @Thomas Braun last edited by Negalein
                            fabio@IoBroker:~ $ iob update
                            Used repository: stable
                            Adapter    "admin"        : 7.1.5    , installed 7.1.5
                            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                            Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                            Adapter    "daikin-cloud" : 0.4.8    , installed 0.4.8
                            Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                            Adapter    "ham"          : 5.3.1    , installed 5.3.1
                            Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
                            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                            Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
                            Adapter    "ical"         : 1.15.0   , installed 1.15.0
                            Adapter    "iot"          : 3.3.0    , installed 3.3.0
                            Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                            Controller "js-controller": 6.0.11   , installed 6.0.11
                            Adapter    "linux-control": 1.1.5    , installed 1.1.5
                            Adapter    "meross"       : 1.17.0   , installed 1.17.0
                            Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                            Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                            Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
                            Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                            Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                            Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                            Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                            Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                            Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                            Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                            Adapter    "ws"           : 2.6.2    , installed 2.6.2
                            Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
                            Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                            fabio@IoBroker:~ $
                              @flowski
                              Gut.
                              iob start admin
                              und die Kiste sollte wieder an den Start kommen.
                                @thomas-braun bislang tut sich nix
                                fabio@IoBroker:~ $ iob start admin
                                fabio@IoBroker:~ $
                                  @flowski
                                  iob diag
                                    bash
                                    Skript v.2024-08-12
                                    *** BASE SYSTEM ***
                                       Static hostname: IoBroker
                                             Icon name: computer
                                      Operating System: Debian GNU/Linux 11 (bullseye)
                                                Kernel: Linux 6.1.21-v8+
                                          Architecture: arm64
                                    OS is similar to:
                                    Model           : Raspberry Pi 4 Model B Rev 1.2
                                    Docker          : false
                                    Virtualization  : none
                                    Kernel          : aarch64
                                    Userland        : 64 bit
                                    Systemuptime and Load:
                                     21:35:42 up 48 min,  2 users,  load average: 0.35, 0.21, 0.53
                                    CPU threads: 4
                                    *** RASPBERRY THROTTLING ***
                                    Current issues:
                                    Previously detected issues:
                                    ~ Under-voltage has occurred
                                    ~ Arm frequency capping has occurred
                                    ~ Throttling has occurred
                                    ~ Soft temperature limit has occurred
                                    *** Time and Time Zones ***
                                                   Local time: Tue 2024-10-08 21:35:42 CEST
                                               Universal time: Tue 2024-10-08 19:35:42 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    *** Users and Groups ***
                                    User that called 'iob diag':
                                    fabio
                                    HOME=/home/fabio
                                    GROUPS=fabio sudo iobroker
                                    js-controller is not running
                                    *** Display-Server-Setup ***
                                    Display-Server: false
                                    Desktop:
                                    Terminal:       tty
                                    Boot Target:    multi-user.target
                                    *** MEMORY ***
                                    Mem:            3.8G        107M        920M        1.0M        2.8G        3.6G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        107M        1.0G
                                    Active iob-Instances:   1
                                             3794 M total memory
                                              107 M used memory
                                              213 M active memory
                                             2439 M inactive memory
                                              920 M free memory
                                               68 M buffer memory
                                             2698 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    top - 21:35:43 up 48 min,  2 users,  load average: 0.35, 0.21, 0.53
                                    Tasks: 162 total,   1 running, 161 sleeping,   0 stopped,   0 zombie
                                    %Cpu(s):  1.4 us,  2.9 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                    MiB Mem :   3794.3 total,    919.3 free,    107.8 used,   2767.3 buff/cache
                                    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3610.0 avail Mem
                                    *** FAILED SERVICES ***
                                      UNIT                LOAD   ACTIVE SUB    DESCRIPTION
                                    * iobroker.service    loaded failed failed ioBroker Server
                                    * pivccu-dkms.service loaded failed failed piVCCU DKMS Modules
                                    LOAD   = Reflects whether the unit definition was properly loaded.
                                    ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                                    SUB    = The low-level unit activation state, values depend on unit type.
                                    2 loaded units listed.
                                    *** FILESYSTEM ***
                                    /dev/root      ext4       59G  8.7G   48G  16% /
                                    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                    tmpfs          tmpfs     759M  1.2M  758M   1% /run
                                    /dev/mmcblk0p1 vfat      255M   32M  224M  13% /boot
                                    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                    tmpfs          tmpfs     380M     0  380M   0% /run/user/1002
                                    [Tue Oct  8 20:46:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:83:48 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=2a0531f8-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Tue Oct  8 20:46:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                    [Tue Oct  8 20:46:56 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                    [Tue Oct  8 20:46:58 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                    Show mounted filesystems:
                                    TARGET  SOURCE         FSTYPE OPTIONS
                                    /       /dev/mmcblk0p2 ext4   rw,noatime
                                    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                    /var:
                                    du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
                                    3.7G    /var/
                                    2.1G    /var/log/journal/664a8e581ec84405863df59a10cf9293
                                    2.1G    /var/log
                                    817M    /var/lib
                                    Archived and active journals take up 8.0M in the file system.
                                    /opt/iobroker/backups:
                                    58M     /opt/iobroker/backups/
                                    /opt/iobroker/iobroker-data:
                                    913M    /opt/iobroker/iobroker-data/
                                    840M    /opt/iobroker/iobroker-data/files
                                    617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                                    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                    16M     /opt/iobroker/iobroker-data/objects.jsonl
                                    14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
                                    USB-Devices by-id:
                                    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AI03D64S-if00-port0
                                    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                                    *** NodeJS-Installation ***
                                    /usr/bin/nodejs         v20.18.0
                                    /usr/bin/node           v20.18.0
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    /usr/bin/corepack       0.29.3
                                    nodejs:
                                      Installed: 20.18.0-1nodesource1
                                      Candidate: 20.18.0-1nodesource1
                                      Version table:
                                     *** 20.18.0-1nodesource1 1001
                                            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                            100 /var/lib/dpkg/status
                                         20.17.0-1nodesource1 1001
                                         20.16.0-1nodesource1 1001
                                         20.15.1-1nodesource1 1001
                                         20.15.0-1nodesource1 1001
                                         20.14.0-1nodesource1 1001
                                         20.13.1-1nodesource1 1001
                                         20.13.0-1nodesource1 1001
                                         20.12.2-1nodesource1 1001
                                         20.12.1-1nodesource1 1001
                                         20.12.0-1nodesource1 1001
                                         20.11.1-1nodesource1 1001
                                         20.11.0-1nodesource1 1001
                                         20.10.0-1nodesource1 1001
                                         20.9.0-1nodesource1 1001
                                         20.8.1-1nodesource1 1001
                                         20.8.0-1nodesource1 1001
                                         20.7.0-1nodesource1 1001
                                         20.6.1-1nodesource1 1001
                                         20.6.0-1nodesource1 1001
                                         20.5.1-1nodesource1 1001
                                         20.5.0-1nodesource1 1001
                                         20.4.0-1nodesource1 1001
                                         20.3.1-1nodesource1 1001
                                         20.3.0-1nodesource1 1001
                                         20.2.0-1nodesource1 1001
                                         20.1.0-1nodesource1 1001
                                         20.0.0-1nodesource1 1001
                                         12.22.12~dfsg-1~deb11u5 500
                                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                         12.22.12~dfsg-1~deb11u4 500
                                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                    No problems detected
                                    Errors in npm tree:
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    iobroker is not running on this host.
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Core adapters versions
                                    js-controller:  6.0.11
                                    admin:          7.1.5
                                    javascript:     8.8.3
                                    nodejs modules from github:     0
                                    Adapter State
                                      system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      system.adapter.alexa2.0                 : alexa2                : IoBroker                                 -  enabled
                                      system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
                                      system.adapter.daikin-cloud.0           : daikin-cloud          : IoBroker                                 - disabled
                                      system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
                                      system.adapter.ham.0                    : ham                   : IoBroker                                 -  enabled
                                      system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
                                      system.adapter.hm-rpc.0                 : hm-rpc                : IoBroker                                 -  enabled
                                      system.adapter.hm-rpc.1                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
                                      system.adapter.homeconnect.0            : homeconnect           : IoBroker                                 -  enabled
                                      system.adapter.ical.0                   : ical                  : IoBroker                                 -  enabled
                                      system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
                                      system.adapter.jarvis.0                 : jarvis                : IoBroker                                 -  enabled
                                      system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
                                      system.adapter.linux-control.0          : linux-control         : IoBroker                                 -  enabled
                                      system.adapter.meross.0                 : meross                : IoBroker                                 -  enabled
                                      system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
                                      system.adapter.mihome.0                 : mihome                : IoBroker                                 - disabled, port: 9898, bind: 0.0.0.0
                                      system.adapter.mqtt.0                   : mqtt                  : IoBroker                                 - disabled, port: 1883, bind: 0.0.0.0
                                      system.adapter.netatmo-crawler.0        : netatmo-crawler       : IoBroker                                 -  enabled
                                      system.adapter.rpi2.0                   : rpi2                  : IoBroker                                 -  enabled
                                      system.adapter.sonoff.0                 : sonoff                : IoBroker                                 -  enabled, port: 1883, bind: 192.168.178.46
                                      system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
                                      system.adapter.terminal.0               : terminal              : IoBroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                      system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
                                      system.adapter.tuya.0                   : tuya                  : IoBroker                                 -  enabled
                                      system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IoBroker                                 -  enabled
                                      system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : IoBroker                                 -  enabled
                                      system.adapter.yeelight-2.0             : yeelight-2            : IoBroker                                 -  enabled
                                      system.adapter.zigbee.0                 : zigbee                : IoBroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                    + instance is alive
                                    ioBroker-Repositories
                                    Active repo(s): stable
                                    Upgrade policy: none
                                    Installed ioBroker-Instances
                                    Objects and States
                                    Objects:        7521
                                    States:         5852
                                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                                    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                    Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
                                    Reading package lists...
                                    Pending Updates: 0
                                    *** Listening Ports ***
                                    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14606      1044/dnsmasq
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13147      1036/sshd: /usr/sbi
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          13149      1036/sshd: /usr/sbi
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12941      433/avahi-daemon: r
                                    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14605      1044/dnsmasq
                                    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14602      1044/dnsmasq
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13052      849/dhclient
                                    udp        0      0 0.0.0.0:33135           0.0.0.0:*                           108        12943      433/avahi-daemon: r
                                    udp6       0      0 :::5353                 :::*                                108        12942      433/avahi-daemon: r
                                    udp6       0      0 :::58117                :::*                                108        12944      433/avahi-daemon: r
                                    2024-10-08 21:11:10.669  - info: host.IoBroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    2024-10-08 21:11:10.732  - info: host.IoBroker instance system.adapter.alexa2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    2024-10-08 21:11:10.733  - info: host.IoBroker instance system.adapter.ham.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    2024-10-08 21:11:10.734  - info: host.IoBroker instance system.adapter.iot.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    2024-10-08 21:11:10.747  - info: host.IoBroker instance system.adapter.whatsapp-cmb.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    2024-10-08 21:11:11.096  - info: host.IoBroker instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    2024-10-08 21:11:11.097  - info: host.IoBroker instance system.adapter.whatsapp-cmb.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    2024-10-08 21:11:11.097  - info: host.IoBroker instance system.adapter.tankerkoenig.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    2024-10-08 21:11:11.098  - info: host.IoBroker instance system.adapter.hm-rega.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    2024-10-08 21:11:11.098  - warn: host.IoBroker instance system.adapter.hm-rpc.0 terminated due to SIGTERM
                                    2024-10-08 21:11:11.098  - info: host.IoBroker instance system.adapter.hm-rpc.0 terminated with code null ()
                                    2024-10-08 21:11:11.099  - warn: host.IoBroker instance system.adapter.sonoff.0 terminated due to SIGTERM
                                    2024-10-08 21:11:11.099  - info: host.IoBroker instance system.adapter.sonoff.0 terminated with code null ()
                                    2024-10-08 21:11:11.099  - warn: host.IoBroker instance system.adapter.web.0 terminated due to SIGTERM
                                    2024-10-08 21:11:11.100  - info: host.IoBroker instance system.adapter.web.0 terminated with code null ()
                                    2024-10-08 21:11:11.100  - warn: host.IoBroker instance system.adapter.zigbee.0 terminated due to SIGTERM
                                    2024-10-08 21:11:11.100  - info: host.IoBroker instance system.adapter.zigbee.0 terminated with code null ()
                                    2024-10-08 21:11:11.101  - warn: host.IoBroker instance system.adapter.hm-rpc.1 terminated due to SIGTERM
                                    2024-10-08 21:11:11.101  - info: host.IoBroker instance system.adapter.hm-rpc.1 terminated with code null ()
                                    2024-10-08 21:11:11.859  - info: tuya.0 (1498) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2024-10-08 21:11:12.433  - info: host.IoBroker instance system.adapter.tuya.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    2024-10-08 21:11:13.061  - info: meross.0 (1382) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2024-10-08 21:11:13.634  - info: host.IoBroker instance system.adapter.meross.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-10-08 21:11:13.635  - info: host.IoBroker All instances are stopped.
                                    2024-10-08 21:11:13.863  - info: host.IoBroker terminated
                                                            v.2024-08-12
                                             Icon name: computer
                                          Architecture: arm64
                                    Installation:           native
                                    Kernel:                 aarch64
                                    Userland:               64 bit
                                    Timezone:               Europe/Berlin (CEST, +0200)
                                    User-ID:                1002
                                    Pending OS-Updates:     0
                                    Pending iob updates:    0
                                    Nodejs-Installation:
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    Recommended versions are nodejs 20.18.0 and npm 10.8.2
                                    MEMORY:
                                    Mem:            3.8G        111M        920M        1.0M        2.8G        3.6G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        111M        1.0G
                                    ioBroker Core:          js-controller           6.0.11
                                                            admin                   7.1.5
                                    ioBroker Status:        iobroker is not running on this host.
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects:                7521
                                    States:                 5852
                                    Size of iob-Database:
                                    7.2M    /opt/iobroker/iobroker-data/states.jsonl
                                      • iobroker.service loaded failed failed ioBroker Server
                                      iobroker start
                                        @thomas-braun jetzt ist iobroker, jarvis usw. wieder erreichbar. lediglich homematic steht in den Adaptern auf rot, ne idee?
                                        bash
                                        Skript v.2024-08-12
                                        *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                        OS is similar to:
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : 64 bit
                                         21:47:18 up  1:00,  2 users,  load average: 1.69, 1.67, 1.09
                                        CPU threads: 4
                                        Current issues:
                                                       Local time: Tue 2024-10-08 21:47:18 CEST
                                                   Universal time: Tue 2024-10-08 19:47:18 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        fabio
                                        HOME=/home/fabio
                                        iobroker
                                        HOME=/home/iobroker
                                        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:            3.8G        1.5G        597M        1.0M        1.7G        2.2G
                                        Swap:            99M          0B         99M
                                        Total:          3.9G        1.5G        697M
                                        Active iob-Instances:   25
                                                 3794 M total memory
                                                 1542 M used memory
                                                 1624 M active memory
                                                 1292 M inactive memory
                                                  597 M free memory
                                                  127 M buffer memory
                                                 1526 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        top - 21:47:19 up  1:00,  2 users,  load average: 1.69, 1.67, 1.09
                                        Tasks: 191 total,   1 running, 190 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s):  1.4 us,  2.8 sy,  0.0 ni, 95.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :   3794.3 total,    597.5 free,   1542.4 used,   1654.4 buff/cache
                                        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2175.3 avail Mem
                                        1 loaded units listed.
                                        *** FILESYSTEM ***
                                        /dev/root      ext4       59G  8.8G   48G  16% /
                                        /var:
                                        3.7G    /var/
                                        2.1G    /var/log
                                        817M    /var/lib
                                        909M    /opt/iobroker/iobroker-data/
                                        10M     /opt/iobroker/iobroker-data/objects.jsonl
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        nodejs:
                                          Version table:
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          7.1.5
                                        javascript:     8.8.3
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        + system.adapter.alexa2.0                 : alexa2                : IoBroker                                 -  enabled
                                        + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
                                        + system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
                                        + system.adapter.ham.0                    : ham                   : IoBroker                                 -  enabled
                                        + system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
                                        + system.adapter.homeconnect.0            : homeconnect           : IoBroker                                 -  enabled
                                        + system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
                                        + system.adapter.jarvis.0                 : jarvis                : IoBroker                                 -  enabled
                                        + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
                                        + system.adapter.linux-control.0          : linux-control         : IoBroker                                 -  enabled
                                        + system.adapter.meross.0                 : meross                : IoBroker                                 -  enabled
                                        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
                                        + system.adapter.rpi2.0                   : rpi2                  : IoBroker                                 -  enabled
                                        + system.adapter.sonoff.0                 : sonoff                : IoBroker                                 -  enabled, port: 1883, bind: 192.168.178.46
                                        + system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
                                        + system.adapter.terminal.0               : terminal              : IoBroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                        + system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
                                        + system.adapter.tuya.0                   : tuya                  : IoBroker                                 -  enabled
                                        + system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IoBroker                                 -  enabled
                                        + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : IoBroker                                 -  enabled
                                        + system.adapter.yeelight-2.0             : yeelight-2            : IoBroker                                 -  enabled
                                        + system.adapter.zigbee.0                 : zigbee                : IoBroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                        + instance is alive
                                        Objects and States
                                        Objects:        7600
                                        States:         5939
                                        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                        Hit:2 http://deb.debian.org/debian bullseye InRelease
                                        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                        Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
                                        Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
                                        Pending Updates: 0
                                        tcp        0      0 192.168.178.46:1883     0.0.0.0:*               LISTEN      1001       38656      11108/io.sonoff.0
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       35395      10803/iobroker.js-c
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       36274      10803/iobroker.js-c
                                        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       39945      11336/io.jarvis.0
                                        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       37795      11464/io.terminal.0
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35443      10826/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       38884      11317/io.web.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       41098      11184/io.ham.0
                                        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       35719      11093/io.mihome-vac
                                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       37615      11234/io.tuya.0
                                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       37616      11234/io.tuya.0
                                        2024-10-08 21:47:30.711  - error: hm-rega.0 (10994) CCU 192.168.178.47 unreachable
                                        2024-10-08 21:47:33.801  - info: netatmo-crawler.0 (12424) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                        2024-10-08 21:47:33.907  - info: netatmo-crawler.0 (12424) Getting data for stationid:70:ee:50:22:e4:6e
                                        2024-10-08 21:47:34.887  - info: netatmo-crawler.0 (12424) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                        2024-10-08 21:47:35.441  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 having pid 12424 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2024-10-08 21:47:50.799  - info: hm-rpc.1 (12180) xmlrpc -> 192.168.178.47:2010/ init ["http://192.168.178.46:2010",""]
                                        2024-10-08 21:47:50.799  - info: hm-rpc.0 (12186) xmlrpc -> 192.168.178.47:2001/ init ["http://192.168.178.46:2001",""]
                                        2024-10-08 21:47:50.807  - error: hm-rpc.1 (12180) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.47:2010
                                        2024-10-08 21:47:50.809  - error: hm-rpc.0 (12186) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.47:2001
                                        2024-10-08 21:47:50.808  - warn: hm-rpc.1 (12180) setTimeout called, but adapter is shutting down
                                        2024-10-08 21:47:50.810  - warn: hm-rpc.0 (12186) setTimeout called, but adapter is shutting down
                                        2024-10-08 21:47:51.812  - info: hm-rpc.1 (12180) terminating
                                        2024-10-08 21:47:51.814  - info: hm-rpc.1 (12180) Terminated (NO_ERROR): Without reason
                                        2024-10-08 21:47:51.821  - info: hm-rpc.0 (12186) terminating
                                        2024-10-08 21:47:51.823  - info: hm-rpc.0 (12186) Terminated (NO_ERROR): Without reason
                                        2024-10-08 21:47:52.477  - info: host.IoBroker instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
                                        2024-10-08 21:47:52.479  - info: host.IoBroker Restart adapter system.adapter.hm-rpc.1 because enabled
                                        2024-10-08 21:47:52.538  - info: host.IoBroker instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                                        2024-10-08 21:47:52.538  - info: host.IoBroker Restart adapter system.adapter.hm-rpc.0 because enabled
                                        2024-10-08 21:48:00.110  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 12970
                                        2024-10-08 21:48:03.799  - error: hm-rega.0 (10994) CCU 192.168.178.47 unreachable
                                        2024-10-08 21:48:04.085  - info: netatmo-crawler.0 (12970) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                        2024-10-08 21:48:04.178  - info: netatmo-crawler.0 (12970) Getting data for stationid:70:ee:50:22:e4:6e
                                        2024-10-08 21:48:05.463  - info: netatmo-crawler.0 (12970) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                        2024-10-08 21:48:06.020  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 having pid 12970 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          @flowski sagte in Updateschwierigkeiten js-controller 4.0.23:
                                          • pivccu-dkms.service loaded failed failed piVCCU DKMS Modules
                                          Hat das mit homematic zu tun? Kenn mich in dem Bereich aber auch Null aus.
                                            @thomas-braun mir wurde damals eine virtuelle ccu aufgespielt? das sollte es sein
                                            3040
