    4. Updateschwierigkeiten js-controller 4.0.23
      Thomas Braun Most Active @Flowski last edited by
      @flowski
      Gut.
      iob start admin
      und die Kiste sollte wieder an den Start kommen.
        Flowski @Thomas Braun last edited by
        @thomas-braun bislang tut sich nix
        fabio@IoBroker:~ $ iob start admin
        fabio@IoBroker:~ $
          @flowski
          iob diag
            Flowski @Thomas Braun last edited by Negalein
            bash
            Skript v.2024-08-12
            *** BASE SYSTEM ***
               Static hostname: IoBroker
                     Icon name: computer
              Operating System: Debian GNU/Linux 11 (bullseye)
                        Kernel: Linux 6.1.21-v8+
                  Architecture: arm64
            OS is similar to:
            Model           : Raspberry Pi 4 Model B Rev 1.2
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : 64 bit
            Systemuptime and Load:
             21:35:42 up 48 min,  2 users,  load average: 0.35, 0.21, 0.53
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            ~ Under-voltage has occurred
            ~ Arm frequency capping has occurred
            ~ Throttling has occurred
            ~ Soft temperature limit has occurred
            *** Time and Time Zones ***
                           Local time: Tue 2024-10-08 21:35:42 CEST
                       Universal time: Tue 2024-10-08 19:35:42 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            fabio
            HOME=/home/fabio
            GROUPS=fabio sudo iobroker
            js-controller is not running
            *** Display-Server-Setup ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            Boot Target:    multi-user.target
            *** MEMORY ***
            Mem:            3.8G        107M        920M        1.0M        2.8G        3.6G
            Swap:            99M          0B         99M
            Total:          3.9G        107M        1.0G
            Active iob-Instances:   1
                     3794 M total memory
                      107 M used memory
                      213 M active memory
                     2439 M inactive memory
                      920 M free memory
                       68 M buffer memory
                     2698 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            top - 21:35:43 up 48 min,  2 users,  load average: 0.35, 0.21, 0.53
            Tasks: 162 total,   1 running, 161 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  1.4 us,  2.9 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   3794.3 total,    919.3 free,    107.8 used,   2767.3 buff/cache
            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3610.0 avail Mem
            *** FAILED SERVICES ***
              UNIT                LOAD   ACTIVE SUB    DESCRIPTION
            * iobroker.service    loaded failed failed ioBroker Server
            * pivccu-dkms.service loaded failed failed piVCCU DKMS Modules
            LOAD   = Reflects whether the unit definition was properly loaded.
            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
            SUB    = The low-level unit activation state, values depend on unit type.
            2 loaded units listed.
            *** FILESYSTEM ***
            /dev/root      ext4       59G  8.7G   48G  16% /
            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
            tmpfs          tmpfs     759M  1.2M  758M   1% /run
            /dev/mmcblk0p1 vfat      255M   32M  224M  13% /boot
            tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
            tmpfs          tmpfs     380M     0  380M   0% /run/user/1002
            [Tue Oct  8 20:46:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:83:48 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=2a0531f8-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Tue Oct  8 20:46:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Tue Oct  8 20:46:56 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Tue Oct  8 20:46:58 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            Show mounted filesystems:
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
            3.7G    /var/
            2.1G    /var/log/journal/664a8e581ec84405863df59a10cf9293
            2.1G    /var/log
            817M    /var/lib
            Archived and active journals take up 8.0M in the file system.
            /opt/iobroker/backups:
            58M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            913M    /opt/iobroker/iobroker-data/
            840M    /opt/iobroker/iobroker-data/files
            617M    /opt/iobroker/iobroker-data/files/javascript.admin
            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
            27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
            16M     /opt/iobroker/iobroker-data/objects.jsonl
            14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
            USB-Devices by-id:
            /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
            /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AI03D64S-if00-port0
            Your zigbee.0 COM-Port is matching 'by-id'. Very good!
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.18.0
            /usr/bin/node           v20.18.0
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            /usr/bin/corepack       0.29.3
            nodejs:
              Installed: 20.18.0-1nodesource1
              Candidate: 20.18.0-1nodesource1
              Version table:
             *** 20.18.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                    100 /var/lib/dpkg/status
                 20.17.0-1nodesource1 1001
                 20.16.0-1nodesource1 1001
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
                 12.22.12~dfsg-1~deb11u5 500
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            iobroker is not running on this host.
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  6.0.11
            admin:          7.1.5
            javascript:     8.8.3
            nodejs modules from github:     0
            Adapter State
              system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.alexa2.0                 : alexa2                : IoBroker                                 -  enabled
              system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
              system.adapter.daikin-cloud.0           : daikin-cloud          : IoBroker                                 - disabled
              system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
              system.adapter.ham.0                    : ham                   : IoBroker                                 -  enabled
              system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
              system.adapter.hm-rpc.0                 : hm-rpc                : IoBroker                                 -  enabled
              system.adapter.hm-rpc.1                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
              system.adapter.homeconnect.0            : homeconnect           : IoBroker                                 -  enabled
              system.adapter.ical.0                   : ical                  : IoBroker                                 -  enabled
              system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
              system.adapter.jarvis.0                 : jarvis                : IoBroker                                 -  enabled
              system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
              system.adapter.linux-control.0          : linux-control         : IoBroker                                 -  enabled
              system.adapter.meross.0                 : meross                : IoBroker                                 -  enabled
              system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
              system.adapter.mihome.0                 : mihome                : IoBroker                                 - disabled, port: 9898, bind: 0.0.0.0
              system.adapter.mqtt.0                   : mqtt                  : IoBroker                                 - disabled, port: 1883, bind: 0.0.0.0
              system.adapter.netatmo-crawler.0        : netatmo-crawler       : IoBroker                                 -  enabled
              system.adapter.rpi2.0                   : rpi2                  : IoBroker                                 -  enabled
              system.adapter.sonoff.0                 : sonoff                : IoBroker                                 -  enabled, port: 1883, bind: 192.168.178.46
              system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
              system.adapter.terminal.0               : terminal              : IoBroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
              system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
              system.adapter.tuya.0                   : tuya                  : IoBroker                                 -  enabled
              system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IoBroker                                 -  enabled
              system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : IoBroker                                 -  enabled
              system.adapter.yeelight-2.0             : yeelight-2            : IoBroker                                 -  enabled
              system.adapter.zigbee.0                 : zigbee                : IoBroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Upgrade policy: none
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 7.1.5    , installed 7.1.5
            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
            Adapter    "backitup"     : 3.0.22   , installed 3.0.22
            Adapter    "daikin-cloud" : 0.4.8    , installed 0.4.8
            Adapter    "device-reminder": 3.1.2  , installed 3.1.2
            Adapter    "ham"          : 5.3.1    , installed 5.3.1
            Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
            Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
            Adapter    "ical"         : 1.15.0   , installed 1.15.0
            Adapter    "iot"          : 3.3.0    , installed 3.3.0
            Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
            Controller "js-controller": 6.0.11   , installed 6.0.11
            Adapter    "linux-control": 1.1.5    , installed 1.1.5
            Adapter    "meross"       : 1.17.0   , installed 1.17.0
            Adapter    "mihome"       : 1.4.0    , installed 1.4.0
            Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
            Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
            Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
            Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
            Adapter    "terminal"     : 1.0.0    , installed 1.0.0
            Adapter    "trashschedule": 3.3.0    , installed 3.3.0
            Adapter    "tuya"         : 3.16.0   , installed 3.16.0
            Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
            Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
            Objects and States
            Objects:        7521
            States:         5852
            Hit:1 http://deb.debian.org/debian bullseye InRelease
            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
            Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14606      1044/dnsmasq
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13147      1036/sshd: /usr/sbi
            tcp6       0      0 :::22                   :::*                    LISTEN      0          13149      1036/sshd: /usr/sbi
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12941      433/avahi-daemon: r
            udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14605      1044/dnsmasq
            udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14602      1044/dnsmasq
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13052      849/dhclient
            udp        0      0 0.0.0.0:33135           0.0.0.0:*                           108        12943      433/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        12942      433/avahi-daemon: r
            udp6       0      0 :::58117                :::*                                108        12944      433/avahi-daemon: r
            2024-10-08 21:11:10.669  - info: host.IoBroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2024-10-08 21:11:10.732  - info: host.IoBroker instance system.adapter.alexa2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2024-10-08 21:11:10.733  - info: host.IoBroker instance system.adapter.ham.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2024-10-08 21:11:10.734  - info: host.IoBroker instance system.adapter.iot.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2024-10-08 21:11:10.747  - info: host.IoBroker instance system.adapter.whatsapp-cmb.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2024-10-08 21:11:11.096  - info: host.IoBroker instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2024-10-08 21:11:11.097  - info: host.IoBroker instance system.adapter.whatsapp-cmb.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2024-10-08 21:11:11.097  - info: host.IoBroker instance system.adapter.tankerkoenig.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2024-10-08 21:11:11.098  - info: host.IoBroker instance system.adapter.hm-rega.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2024-10-08 21:11:11.098  - warn: host.IoBroker instance system.adapter.hm-rpc.0 terminated due to SIGTERM
            2024-10-08 21:11:11.098  - info: host.IoBroker instance system.adapter.hm-rpc.0 terminated with code null ()
            2024-10-08 21:11:11.099  - warn: host.IoBroker instance system.adapter.sonoff.0 terminated due to SIGTERM
            2024-10-08 21:11:11.099  - info: host.IoBroker instance system.adapter.sonoff.0 terminated with code null ()
            2024-10-08 21:11:11.099  - warn: host.IoBroker instance system.adapter.web.0 terminated due to SIGTERM
            2024-10-08 21:11:11.100  - info: host.IoBroker instance system.adapter.web.0 terminated with code null ()
            2024-10-08 21:11:11.100  - warn: host.IoBroker instance system.adapter.zigbee.0 terminated due to SIGTERM
            2024-10-08 21:11:11.100  - info: host.IoBroker instance system.adapter.zigbee.0 terminated with code null ()
            2024-10-08 21:11:11.101  - warn: host.IoBroker instance system.adapter.hm-rpc.1 terminated due to SIGTERM
            2024-10-08 21:11:11.101  - info: host.IoBroker instance system.adapter.hm-rpc.1 terminated with code null ()
            2024-10-08 21:11:11.859  - info: tuya.0 (1498) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2024-10-08 21:11:12.433  - info: host.IoBroker instance system.adapter.tuya.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2024-10-08 21:11:13.061  - info: meross.0 (1382) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2024-10-08 21:11:13.634  - info: host.IoBroker instance system.adapter.meross.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-10-08 21:11:13.635  - info: host.IoBroker All instances are stopped.
            2024-10-08 21:11:13.863  - info: host.IoBroker terminated
                                    v.2024-08-12
                     Icon name: computer
                  Architecture: arm64
            Installation:           native
            Kernel:                 aarch64
            Userland:               64 bit
            Timezone:               Europe/Berlin (CEST, +0200)
            User-ID:                1002
            Pending OS-Updates:     0
            Pending iob updates:    0
            Nodejs-Installation:
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            Recommended versions are nodejs 20.18.0 and npm 10.8.2
            MEMORY:
            Mem:            3.8G        111M        920M        1.0M        2.8G        3.6G
            Swap:            99M          0B         99M
            Total:          3.9G        111M        1.0G
            ioBroker Core:          js-controller           6.0.11
                                    admin                   7.1.5
            ioBroker Status:        iobroker is not running on this host.
            Objects type: jsonl
            States  type: jsonl
            Objects:                7521
            States:                 5852
            Size of iob-Database:
            7.2M    /opt/iobroker/iobroker-data/states.jsonl
              @flowski sagte in Updateschwierigkeiten js-controller 4.0.23:
              • iobroker.service loaded failed failed ioBroker Server
              iobroker start
                @thomas-braun jetzt ist iobroker, jarvis usw. wieder erreichbar. lediglich homematic steht in den Adaptern auf rot, ne idee?
                bash
                Skript v.2024-08-12
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                OS is similar to:
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                 21:47:18 up  1:00,  2 users,  load average: 1.69, 1.67, 1.09
                CPU threads: 4
                Current issues:
                               Local time: Tue 2024-10-08 21:47:18 CEST
                           Universal time: Tue 2024-10-08 19:47:18 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                fabio
                HOME=/home/fabio
                iobroker
                HOME=/home/iobroker
                GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            3.8G        1.5G        597M        1.0M        1.7G        2.2G
                Swap:            99M          0B         99M
                Total:          3.9G        1.5G        697M
                Active iob-Instances:   25
                         3794 M total memory
                         1542 M used memory
                         1624 M active memory
                         1292 M inactive memory
                          597 M free memory
                          127 M buffer memory
                         1526 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                top - 21:47:19 up  1:00,  2 users,  load average: 1.69, 1.67, 1.09
                Tasks: 191 total,   1 running, 190 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  1.4 us,  2.8 sy,  0.0 ni, 95.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :   3794.3 total,    597.5 free,   1542.4 used,   1654.4 buff/cache
                MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2175.3 avail Mem
                1 loaded units listed.
                *** FILESYSTEM ***
                /dev/root      ext4       59G  8.8G   48G  16% /
                /var:
                3.7G    /var/
                2.1G    /var/log
                817M    /var/lib
                909M    /opt/iobroker/iobroker-data/
                10M     /opt/iobroker/iobroker-data/objects.jsonl
                USB-Devices by-id:
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          7.1.5
                javascript:     8.8.3
                Adapter State
                + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.alexa2.0                 : alexa2                : IoBroker                                 -  enabled
                + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
                + system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
                + system.adapter.ham.0                    : ham                   : IoBroker                                 -  enabled
                + system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
                + system.adapter.homeconnect.0            : homeconnect           : IoBroker                                 -  enabled
                + system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
                + system.adapter.jarvis.0                 : jarvis                : IoBroker                                 -  enabled
                + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
                + system.adapter.linux-control.0          : linux-control         : IoBroker                                 -  enabled
                + system.adapter.meross.0                 : meross                : IoBroker                                 -  enabled
                + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
                + system.adapter.rpi2.0                   : rpi2                  : IoBroker                                 -  enabled
                + system.adapter.sonoff.0                 : sonoff                : IoBroker                                 -  enabled, port: 1883, bind: 192.168.178.46
                + system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
                + system.adapter.terminal.0               : terminal              : IoBroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                + system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
                + system.adapter.tuya.0                   : tuya                  : IoBroker                                 -  enabled
                + system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IoBroker                                 -  enabled
                + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : IoBroker                                 -  enabled
                + system.adapter.yeelight-2.0             : yeelight-2            : IoBroker                                 -  enabled
                + system.adapter.zigbee.0                 : zigbee                : IoBroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                + instance is alive
                Objects and States
                Objects:        7600
                States:         5939
                Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:2 http://deb.debian.org/debian bullseye InRelease
                Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
                Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
                Pending Updates: 0
                tcp        0      0 192.168.178.46:1883     0.0.0.0:*               LISTEN      1001       38656      11108/io.sonoff.0
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       35395      10803/iobroker.js-c
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       36274      10803/iobroker.js-c
                tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       39945      11336/io.jarvis.0
                tcp6       0      0 :::8088                 :::*                    LISTEN      1001       37795      11464/io.terminal.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35443      10826/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       38884      11317/io.web.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       41098      11184/io.ham.0
                udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       35719      11093/io.mihome-vac
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       37615      11234/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       37616      11234/io.tuya.0
                2024-10-08 21:47:30.711  - error: hm-rega.0 (10994) CCU 192.168.178.47 unreachable
                2024-10-08 21:47:33.801  - info: netatmo-crawler.0 (12424) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                2024-10-08 21:47:33.907  - info: netatmo-crawler.0 (12424) Getting data for stationid:70:ee:50:22:e4:6e
                2024-10-08 21:47:34.887  - info: netatmo-crawler.0 (12424) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                2024-10-08 21:47:35.441  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 having pid 12424 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2024-10-08 21:47:50.799  - info: hm-rpc.1 (12180) xmlrpc -> 192.168.178.47:2010/ init ["http://192.168.178.46:2010",""]
                2024-10-08 21:47:50.799  - info: hm-rpc.0 (12186) xmlrpc -> 192.168.178.47:2001/ init ["http://192.168.178.46:2001",""]
                2024-10-08 21:47:50.807  - error: hm-rpc.1 (12180) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.47:2010
                2024-10-08 21:47:50.809  - error: hm-rpc.0 (12186) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.47:2001
                2024-10-08 21:47:50.808  - warn: hm-rpc.1 (12180) setTimeout called, but adapter is shutting down
                2024-10-08 21:47:50.810  - warn: hm-rpc.0 (12186) setTimeout called, but adapter is shutting down
                2024-10-08 21:47:51.812  - info: hm-rpc.1 (12180) terminating
                2024-10-08 21:47:51.814  - info: hm-rpc.1 (12180) Terminated (NO_ERROR): Without reason
                2024-10-08 21:47:51.821  - info: hm-rpc.0 (12186) terminating
                2024-10-08 21:47:51.823  - info: hm-rpc.0 (12186) Terminated (NO_ERROR): Without reason
                2024-10-08 21:47:52.477  - info: host.IoBroker instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
                2024-10-08 21:47:52.479  - info: host.IoBroker Restart adapter system.adapter.hm-rpc.1 because enabled
                2024-10-08 21:47:52.538  - info: host.IoBroker instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                2024-10-08 21:47:52.538  - info: host.IoBroker Restart adapter system.adapter.hm-rpc.0 because enabled
                2024-10-08 21:48:00.110  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 12970
                2024-10-08 21:48:03.799  - error: hm-rega.0 (10994) CCU 192.168.178.47 unreachable
                2024-10-08 21:48:04.085  - info: netatmo-crawler.0 (12970) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                2024-10-08 21:48:04.178  - info: netatmo-crawler.0 (12970) Getting data for stationid:70:ee:50:22:e4:6e
                2024-10-08 21:48:05.463  - info: netatmo-crawler.0 (12970) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                2024-10-08 21:48:06.020  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 having pid 12970 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  • pivccu-dkms.service loaded failed failed piVCCU DKMS Modules
                  Hat das mit homematic zu tun? Kenn mich in dem Bereich aber auch Null aus.
                    @thomas-braun mir wurde damals eine virtuelle ccu aufgespielt? das sollte es sein
                      @flowski
                      Wie gesagt, mit pivCCU und Co. kenn ich mich nicht aus.
                      Muss sich wohl wer anders anschauen.
                      Mach am besten einen neuen Thread mit eigener Beschreibung dazu auf.
                      Da kannst du auch die Ausgabe von
                      systemctl status pivccu-dkms
                      posten.
                        Flowski last edited by Flowski
                        @thomas-braun said in Updateschwierigkeiten js-controller 4.0.23:
                        Ok werde ich machen. Nochmal tausend Dank für deinen Support, hast mir sehr geholfen.. dann mache ich mal einen neuen Beitrag auf.
                        Schönen Abend
                        EDIT: Neuer Beitrag zur CCU-Problematik
                        3039
