    4. Test Adapter flexcharts - Stapeldiagramme und mehr
    • mcm1957
      mcm1957 @legro last edited by
      Generell:
      Wenn der web Adapter nicht installiert ist, dann sollte der web Adapter implizit bei der Installation von flexcharts mit installiert werden. Eine explizite Installation vor der Installation von flexcharts sollte nicht notwendig sein. Siehe log:
      $ iobroker add flexcharts --host Envy
      NPM version: 10.7.0
      Installing iobroker.flexcharts@0.1.4... (System call)
      added 15 packages, and audited 986 packages in 18s
      108 packages are looking for funding run `npm fund` for details
      65 vulnerabilities (9 low, 30 moderate, 25 high, 1 critical)
      To address issues that do not require attention, run: npm audit fix To address all issues possible (including breaking changes), run: npm audit fix --force Some issues need review, and may require choosing a different dependency. Run `npm audit` for details.
      host.Envy install adapter flexcharts
      upload [2] flexcharts.admin C:/ioBroker/node_modules/iobroker.flexcharts/admin/flexcharts-icon-small.png flexcharts-icon-small.png image/png
      upload [1] flexcharts.admin C:/ioBroker/node_modules/iobroker.flexcharts/admin/flexcharts-icon.png flexcharts-icon.png image/png
      upload [0] flexcharts.admin C:/ioBroker/node_modules/iobroker.flexcharts/admin/flexcharts.png flexcharts.png image/png
      upload [5] flexcharts C:/ioBroker/node_modules/iobroker.flexcharts/www/404.css 404.css text/css
      upload [4] flexcharts C:/ioBroker/node_modules/iobroker.flexcharts/www/404.html 404.html text/html
      upload [3] flexcharts C:/ioBroker/node_modules/iobroker.flexcharts/www/echarts.html echarts.html text/html
      upload [2] flexcharts C:/ioBroker/node_modules/iobroker.flexcharts/www/echarts.js echarts.js application/javascript
      upload [1] flexcharts C:/ioBroker/node_modules/iobroker.flexcharts/www/echarts.js.map echarts.js.map application/json
      upload [0] flexcharts C:/ioBroker/node_modules/iobroker.flexcharts/www/favicon.ico favicon.ico image/vnd.microsoft.icon
      host.Envy Required dependency "web" not found on this host.
      host.Envy install adapter web
      NPM version: 10.7.0
      Installing iobroker.web@6.3.1... (System call)
      added 90 packages, and audited 1076 packages in 23s
      124 packages are looking for funding run `npm fund` for details
      68 vulnerabilities (12 low, 30 moderate, 25 high, 1 critical) To address issues that do not require attention, run: npm audit fix To address all issues possible (including breaking changes), run:
      upload [127] web.admin C:/ioBroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
      upload [100] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Coffee Makers.9fb4d82f957a06f30dae.svg static/media/Coffee Makers.9fb4d82f957a06f30dae.svg image/svg+xml
      upload [90] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Doors.d59bf859f582d3488a04.svg static/media/Doors.d59bf859f582d3488a04.svg image/svg+xml
      upload [80] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Gallery.4e7f9433fae8b24fdfca.svg static/media/Gallery.4e7f9433fae8b24fdfca.svg image/svg+xml
      upload [70] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Hall.9c2fa95419cb84ecda68.svg static/media/Hall.9c2fa95419cb84ecda68.svg image/svg+xml
      upload [60] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Kitchen.deb7f976c1f43f9039a2.svg static/media/Kitchen.deb7f976c1f43f9039a2.svg image/svg+xml
      upload [50] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Mowing Machine.9ead5b039f36cdc800e6.svg static/media/Mowing Machine.9ead5b039f36cdc800e6.svg image/svg+xml
      upload [40] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Printer.146d983be964b95745d2.svg static/media/Printer.146d983be964b95745d2.svg image/svg+xml
      upload [30] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Sleeping Area.828017602bfcc2dd7dce.svg static/media/Sleeping Area.828017602bfcc2dd7dce.svg image/svg+xml
      upload [20] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Table Lamps.bd92de33bf86b6cbaec9.svg static/media/Table Lamps.bd92de33bf86b6cbaec9.svg image/svg+xml
      upload [19] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Temperature Sensors.75d805988a6b77b231d8.svg static/media/Temperature Sensors.75d805988a6b77b231d8.svg image/svg+xml
      upload [18] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
      upload [17] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
      upload [16] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
      upload [15] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
      upload [14] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
      upload [13] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
      upload [12] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
      upload [11] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
      upload [10] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
      upload [9] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
      upload [8] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
      upload [7] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
      upload [6] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
      upload [5] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
      upload [4] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
      upload [3] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
      upload [2] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
      upload [1] web.admin C:/ioBroker/node_modules/iobroker.web/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
      upload [0] web.admin C:/ioBroker/node_modules/iobroker.web/admin/web.png web.png image/png
      upload [397] web C:/ioBroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
      upload [350] web C:/ioBroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
      upload [300] web C:/ioBroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
      upload [250] web C:/ioBroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
      upload [200] web C:/ioBroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
      upload [150] web C:/ioBroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
      upload [100] web C:/ioBroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
      upload [90] web C:/ioBroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
      upload [80] web C:/ioBroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
      upload [70] web C:/ioBroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
      upload [60] web C:/ioBroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
      upload [50] web C:/ioBroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
      upload [40] web C:/ioBroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
      upload [30] web C:/ioBroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
      upload [20] web C:/ioBroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
      upload [19] web C:/ioBroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
      upload [18] web C:/ioBroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
      upload [17] web C:/ioBroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
      upload [16] web C:/ioBroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
      upload [15] web C:/ioBroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
      upload [14] web C:/ioBroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
      upload [13] web C:/ioBroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
      upload [12] web C:/ioBroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
      upload [11] web C:/ioBroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
      upload [10] web C:/ioBroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
      upload [9] web C:/ioBroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
      upload [7] web C:/ioBroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
      upload [6] web C:/ioBroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
      upload [3] web C:/ioBroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
      upload [2] web C:/ioBroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
      upload [0] web C:/ioBroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
      host.Envy object system.adapter.web created/updated
      host.Envy create instance web
      host.Envy object system.adapter.web.0.connected created
      host.Envy object system.adapter.web.0.memHeapUsed created
      host.Envy object system.adapter.web.0.sigKill created
      host.Envy object web.0.info.connected created
      host.Envy object system.adapter.flexcharts created/updated
      host.Envy object system.adapter.flexcharts.0.memRss created
      host.Envy object system.adapter.flexcharts.0 created
      Process exited with code 0
      • mcm1957
        @legro said in Test Adapter flexcharts 0.0.1 - Stapeldiagramme und mehr:
        @mcm1957
        Meine Admin-Version ist die 7.1.5
        OK, sieht nach einem Problem mit Admin 7.1.5 aus. Mit Admin 7.2.2 kommt diese (wenig sinnvolle) Meldung schainbar nicht mehr. Hintergrund ist offensichtlich die fehlende Installation des web Adapters. Kannst du bestätigen, dass bei dir der Adapter web nicht installiert ist / war als die Fehlermeldung auftrat?
        • mcm1957
          mcm1957 @mcm1957 last edited by mcm1957
          @mcm1957
          OK - ist reproduzierbar bei mir. Nunmehr installiert er auch bei mir den web nicht automatisch !?!?. Ich mach dann mal ein Issue auf ...
          Damit HIER zurück zum flexcharts Adapter.
          EDIT: https://github.com/ioBroker/ioBroker.admin/issues/2744
          mcm1957 created this issue in ioBroker/ioBroker.admin
          closed [bug]: Latest available version of "%s" is required, but nothing installed. Please install first "%s" and then retry. #2744
            legro @mcm1957 last edited by
            @mcm1957
            Danke für deine Unterstützung.
            Selbstverständlich verfügt meine Hausautomation über den Web Adapter. Die vorangehenden Versionen von flexcharts konnte ich problemlos installieren. Die Probleme traten erst auf, als ich die letzte Version - wie von @jrbwh empfohlen - komplett deinstalliert habe.
            • mcm1957
              mcm1957 @legro last edited by mcm1957
              @legro
              Frühe Versionen von flexcharts erforderten NICHT den web Adapter da dieser damals nicht als Extension implementiert war.
              jrbwh 1 Reply Last reply Reply Quote 0
              • jrbwh
                jrbwh @mcm1957 last edited by
                @mcm1957 @legro Die Versionen 0.0.x von flexcharts haben ohne web-Adapter funktioniert, die Versionen 0.1.x benötigen ihn.
                Ich habe aber erst mit 0.1.4 die dependency ergänzt und info.connection entfernt. Deshalb der Hinweis, flexcharts nochmal neu zu installieren.
                  @mcm1957 sagte in Test Adapter flexcharts 0.0.1 - Stapeldiagramme und mehr:
                  @mcm1957
                  Das sollte bei mir nicht die Ursache sein. Der Web Adapter ist bei mir ja (schon immer) vorhanden.
                  • mcm1957
                    @legro
                    hast du ein master / slave system?
                    welche versuon v web ist installiert?
                      Delphinis @jrbwh last edited by Delphinis
                      @jrbwh
                      ich wollte eigentlich in typescript eine Generische Klasse erstellen, mit welcher ich den JSON-Baum in verschachtelten Objekten erstellen kann und diese dann mit obj.toString() ins JSON-Format überführen könnte.
                      Das hat sich aber als kompliziert herausgestellt, siehe details unten.
                      Aber vielleicht gibt es das in Typescript ja irgendwie schon so eine Funktion oder eine Klasse die sowas macht? Die eCharts optionen sind ja sehr umfangreich: https://echarts.apache.org/en/option.html#title
                      Ich denke du hast ja da irgendwie schon den umgekehrten Weg gemacht, indem du das JSON parsen musst, oder macht das eCharts selbst?
                      Details, fals es interessiert:
                      JSON besteht aus folgenden JSON-Datentypen, welche verschachtelt werden:
                      • string;
                      • number;
                      • boolean;
                      • object;
                      • Array;
                      • null;
                        Diese zu verschachteln ist nicht ganz einfach, da man nicht so einfach datentypen ineinander verschachteln kann, da diese sich selbst referenzieren (z.b. array of object of array).
                        Man müsste mit any arbeiten, womit man dann mit typabfragen die typen sicherstellen kann. Dies ist in Typescript aber nicht so einfach, da die typinformation nach der Kompilation verloren geht.
                        Da gibt es in Foren auch etliche beiträge darüber.
                        legro @mcm1957 last edited by legro
                        @mcm1957
                        • Version 6.2.5 ist installiert.
                        • kein Multihost
                        Irgendetwas dürfte beim Deinstallieren der alten flexcharts Version in meinem System kaputt gegangen sein. Die Vorgängerversionen konnte ich problemlos installieren.
                        • jrbwh
                          jrbwh @Delphinis last edited by
                          @delphinis Bei Typescript kann ich Dir leider nicht helfen, da habe ich noch kaum was gemacht.
                          Wenn Du mit Skript und callback(options) arbeitest, gibst Du ja direkt das json-Objekt zurück.
                          Wenn Du über einen State gehst, habe ich das bisher immer mit JSON.stringify(obj) gemacht. Das funktioniert zwar nicht mit verschachtelten Objekten, ich sehe aber grade auch nicht, wo man das in der der Datenstruktur der ECharts brauchen sollte.
                          Ein Beispiel für eine etwas komplexere Aufbereitung von Daten findest Du hier.
                            legro @jrbwh last edited by
                            @jrbwh
                            So gerne würde ich deinen Adapter flexcharts einmal ausprobieren. Leider bekomme ich den nach wie vor nicht installiert. Stets erhalte ich die hier zitierte Fehlermeldung.
                            Wie könnt ich ansonsten noch installieren? Würde folgendes auch bei den Versionen 0.1.x funktionieren? Nicht, dass ich am Ende noch mehr Schaden anrichte.
                            cd /opt/iobroker
                            npm i iobroker.flexcharts
                            jrbwh mcm1957 2 Replies Last reply Reply Quote 0
                            • jrbwh
                              jrbwh @legro last edited by
                              @legro Diese Befehle sollten die aktuelle auf npm verfügbare Version installieren, also 0.1.4. Ob das bei Dir funktioniert? Keine Ahnung. Aber probieren schadet nichts. Der normale Installationsvorgang macht meines Wissens auch nichts anderes.
                              Was Du auch probieren kannst:
                              iob stop
                              iob fix
                              iob start
                              Vielleicht behebt das Probleme Deiner ioBroker-Installation.
                              Würde aber vorher ein Backup machen.
                              • mcm1957
                                @jrbwh
                                Dann stimmt ledier etwas an deinem System nicht.
                                cd /opt/iobroker
                                Adapter sollten niemals mittesl 'npm irgendwas' installiert werden. Außerdem klärt das noch imemr nicht warum die normale Installation bei dir nicht funktioniert.
                                • mcm1957
                                  mcm1957 @jrbwh last edited by
                                  @jrbwh said in Test Adapter flexcharts 0.0.1 - Stapeldiagramme und mehr:
                                  Dann ist dein Wissen nicht aktuell 🙂
                                  Die normale Installation fürht noch weitere Schritte vor und nach dem npm Aufruf aus.
                                  Und probieren kann hier sehr wohl schaden. Insbesondere wenn der User nicht passt oder das Verzeichnisch falsch eingestellt ist kann die ganze ioBroker Installation abgeschossen werden.
                                  mcm1957 jrbwh 2 Replies Last reply Reply Quote 0
                                  • mcm1957
                                    Bevor hier mit npm experimentiert wird:
                                    Was sagt eine Installation auf der Commandline mit dem vorgesehenen iobroer command
                                    iobroker add ... bzw. iobroekr update ...?
                                      sigi234 Forum Testing Most Active @jrbwh last edited by sigi234
                                      @jrbwh
                                      bei mir kommt diese Meldung:
                                      Aha, gibt schon ein Issues
                                      • mcm1957
                                        mcm1957 @sigi234 last edited by mcm1957
                                        @sigi234 said in Test Adapter flexcharts 0.0.1 - Stapeldiagramme und mehr:
                                        @jrbwh
                                        Ja für den fehlerhaften Text gibts ein Issue.
                                        Unklar ist warum die Meldung bei @legro auch kommt obwohl der web Adapter installiert ist. Kannst du bitte sagen ob bei dir web installiert ist? Und wenn ja ob bzw. was bei einem Installationsversuch via Commandline passiert?
                                        Bei mir kommt die obige unvollständige Meldung nur wenn web nicht installiert ist.
                                          Erst einmal: Vielen Dank für deine Unterstützung!
                                          Da bin ich mir mittlerweile nicht mehr so sicher. Mittlerweile läuft das Ganze bei mir. Das Vorgehen ..
                                          • Über die "Katze" habe ich den reinen Adapter installiert,
                                          • anschließend habe ich via SSH mittels iob add flexcharts eine Instanz erzeugt.
                                          Der Fehler liegt bei meiner Installation wohl darin begründet, dass das zuvor gepflegte Vorgehen mittels des Admin-Adapters einfach keine Instanz erzeugt, sondern stattdessen diese ominöse Fehlermeldung ausgibt.
                                            sigi234 Forum Testing Most Active @mcm1957 last edited by sigi234
                                            @jrbwh
                                            Ja
                                            ***               Welcome to ioBroker.                 ***
                                            ***     Type 'iob help' for list of instructions.      ***
                                            ***                For more help see                   ***
                                            ***     https://github.com/ioBroker/ioBroker.docs      ***
                                            Your environment has been set up for using Node.js 20.18.0 (x64) and npm.
                                            C:\SmartHome>npm i iobroker.flexcharts
                                            up to date, audited 1954 packages in 12s
                                            404 packages are looking for funding
                                            87 vulnerabilities (17 low, 40 moderate, 28 high, 2 critical)
                                              npm audit fix
                                            C:\SmartHome>
                                            Bei mir ist V 0.1.4 ja schon installiert, Windows System
                                            1.0k
                                            chart charts diagramme echarts visualisierung visualization
                                            19
                                            266
                                            46776
