    4. Daten aus der Fritzbox visualisieren
      WernerS @fastfoot last edited by
      @fastfoot
      Danke für das Script 👍 wusste nicht dass das auch nachträglich geht
      Allerdings bringt das Script bei mir einen Fehler
      javascript.0
      	2024-10-04 10:20:12.837	error	at processImmediate (node:internal/timers:476:21)
      javascript.0
      	2024-10-04 10:20:12.836	error	at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:381:37)
      javascript.0
      	2024-10-04 10:20:12.835	error	at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:10886:45)
      javascript.0
      	2024-10-04 10:20:12.835	error	at Object.cb (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3097:38)
      javascript.0
      	2024-10-04 10:20:12.834	error	at Object.<anonymous> (script.js.common.FritzBox_Daten_nachträglich_neuberechnen:33:23)
      javascript.0
      	2024-10-04 10:20:12.833	error	Error in callback: TypeError: Cannot read properties of undefined (reading 'length')
      javascript.0
      	2024-10-04 10:20:12.829	error	at processImmediate (node:internal/timers:476:21)
      javascript.0
      	2024-10-04 10:20:12.829	error	at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:381:37)
      javascript.0
      	2024-10-04 10:20:12.829	error	at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:10886:45)
      javascript.0
      	2024-10-04 10:20:12.829	error	at Object.cb (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3097:38)
      javascript.0
      	2024-10-04 10:20:12.828	error	at Object.<anonymous> (script.js.common.FritzBox_Daten_nachträglich_neuberechnen:33:23)
      javascript.0
      	2024-10-04 10:20:12.827	error	Error in callback: TypeError: Cannot read properties of undefined (reading 'length')
        fastfoot @WernerS last edited by
        @werners Das kommt davon wenn man keine Fehlerbehandlung einbaut, my bad!
        Kopiere bitte nochmal das verbesserte Skript und achte darauf dass der Datenbankname in Zeile 1 richtig ist. Dass der Statename in Zeile 2 verkürzt scheint ist Absicht, nicht abändern!
        const db = 'iobrokerslave02'
        const stateID = '0_userdata.0.FritzBox.Traffic.Tag';
        //summe(8, 3); // Der 3. September
        summe(8); // Der gesamte September
        function summe(monat = null, tag = null) {
            const monatsStart = new Date();
            const monatsEnde = new Date();
            monatsStart.setDate(tag || 1);
            monatsStart.setHours(0, 0, 0, 0);
            monatsStart.setMonth(monat || new Date().getMonth());
            monatsEnde.setMonth(monatsStart.getMonth() + (tag ? 0 : 1));
            monatsEnde.setDate(tag || 0);
            monatsEnde.setHours(23, 59, 59, 999);
            log(monatsStart.toString());
            log(monatsEnde.toString());
            const query = `
                SELECT b.name, sum(a.val) AS summe
                  FROM ${db}.ts_number a
                  JOIN ${db}.datapoints b ON a.id = b.id AND b.name LIKE "${stateID}%"
                  WHERE a.ts BETWEEN ${monatsStart.getTime()} AND ${monatsEnde.getTime()}
                  GROUP BY b.name`
            sendTo('sql.0', 'query', query, (res) => {
                if (/*!res.error &&*/ res.result?.length) {
                    log(res.result[0].name.split('.')[4] + ' : ' + res.result[0].summe)
                    log(res.result[1].name.split('.')[4] + ' : ' + res.result[1].summe)
                } else {
                    log('Keine Daten!', 'warn');
                    res.error && log(res.error, 'error')
          danwir @Ro75 last edited by
          @ro75 entschuldige, kannst du mir sagen wo ich den Code reinkopieren muss ? Stehe da gerade ein wenig auf dem Schlauch. Hab iobroker drauf und den Adapter avm 64, welcher auch verbunden ist, aber nichts anzeigt.
          Daniel
            @fastfoot
            habe ich gemacht.
            Beim Script kommt das unten
            javascript.0	16:03:13.360	info	Start JavaScript script.js.common.FritzBox_Daten_nachträglich_neuberechnen (Javascript/js)
            javascript.0	16:03:13.411	info	script.js.common.FritzBox_Daten_nachträglich_neuberechnen: Sun Sep 01 2024 00:00:00 GMT+0200 (Central European Summer Time)
            javascript.0	16:03:13.412	info	script.js.common.FritzBox_Daten_nachträglich_neuberechnen: Mon Sep 30 2024 23:59:59 GMT+0200 (Central European Summer Time)
            javascript.0	16:03:13.412	info	script.js.common.FritzBox_Daten_nachträglich_neuberechnen: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            javascript.0	16:03:13.423	warn	script.js.common.FritzBox_Daten_nachträglich_neuberechnen: Keine Daten!
            javascript.0	16:03:13.424	error	script.js.common.FritzBox_Daten_nachträglich_neuberechnen: Error: SELECT command denied to user 'iobroker'@'Iobroker.fritz.box' for table `iobrokerslave02`.`ts_number`
            In den Protokollen steht das drin
            avascript.0
            	2024-10-07 16:05:50.482	info	Stopping script script.js.common.FritzBox_Daten_nachträglich_neuberechnen
            javascript.0
            	2024-10-07 16:05:45.756	error	script.js.common.FritzBox_Daten_nachträglich_neuberechnen: Error: SELECT command denied to user 'iobroker'@'Iobroker.fritz.box' for table `iobrokerslave02`.`ts_number`
            javascript.0
            	2024-10-07 16:05:45.755	warn	script.js.common.FritzBox_Daten_nachträglich_neuberechnen: Keine Daten!
            javascript.0
            	2024-10-07 16:05:45.746	info	script.js.common.FritzBox_Daten_nachträglich_neuberechnen: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            javascript.0
            	2024-10-07 16:05:45.745	info	script.js.common.FritzBox_Daten_nachträglich_neuberechnen: Mon Sep 30 2024 23:59:59 GMT+0200 (Central European Summer Time)
            javascript.0
            	2024-10-07 16:05:45.745	info	script.js.common.FritzBox_Daten_nachträglich_neuberechnen: Sun Sep 01 2024 00:00:00 GMT+0200 (Central European Summer Time)
            javascript.0
            	2024-10-07 16:05:45.689	info	Start JavaScript script.js.common.FritzBox_Daten_nachträglich_neuberechnen (Javascript/js)
              @werners demnach dürfte das 'Originalscript' auch nicht mehr funktionieren! Hast Du an den Settings im SQL-Adapter oder in der Datenbank rumgespielt?
              W 2 Replies Last reply Reply Quote 0
                @fastfoot
                nein da ist alles wie es war. Also das andere Script das läuft und berechnet die aktuelle und die Tagesrate.
                  @werners sagte in Daten aus der Fritzbox visualisieren:
                  @fastfoot
                  das Skript nutzt dieselbe Instanz von SQL wie das originale, somit auch die gleichen Berechtigungen! Läuft es denn auf einer anderen Instanz als das Original?
                  W 3 Replies Last reply Reply Quote 0
                    @fastfoot sagte in Daten aus der Fritzbox visualisieren:
                    @fastfoot
                    Nein ich habe nur eine Javascript Instanz auf meinem slave01
                      @fastfoot
                      ih glaube ich habe was gefunden. muss es nicht
                      0_userdata.0.FritzBox.Traffic.Tag_IN heißen?
                      Aber der Fehler kommt trotzdem
                        @fastfoot
                        Da ist mir nochwas aufgefallen. Bei dem Datenpunkt geht es ja um einen Tag, aber er 3.09. ist auskommentiert.
                        Ist das so gewollt?
                          @fastfoot
                          so und noch was. Im script steht sql.0. Das habe ich übersehen denn ich habe auf allen 3 Raspis mit iobroker eine SQL Datenbank. Die vom Slave 2 heißt dann sql.2
                          Aber das andere Script läuft und berechnet ja die Daten da steht auch sql.0 drin
                          Ich habe mal versuchhalber das auf sql.2 geändert und das so gemacht
                          //summe(8); // Der gesamte September
                          dann bekomme ich
                          javascript.0	17:51:52.131	info	Start JavaScript script.js.common.FritzBox_Daten_nachträglich_neuberechnen (Javascript/js)
                          javascript.0	17:51:52.162	info	script.js.common.FritzBox_Daten_nachträglich_neuberechnen: Tue Sep 03 2024 00:00:00 GMT+0200 (Central European Summer Time)
                          javascript.0	17:51:52.162	info	script.js.common.FritzBox_Daten_nachträglich_neuberechnen: Tue Sep 03 2024 23:59:59 GMT+0200 (Central European Summer Time)
                          javascript.0	17:51:52.163	info	script.js.common.FritzBox_Daten_nachträglich_neuberechnen: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          javascript.0	17:51:52.179	info	script.js.common.FritzBox_Daten_nachträglich_neuberechnen: Tag_IN : 32828971246
                          javascript.0	17:51:52.181	error	at Object.<anonymous> (script.js.common.FritzBox_Daten_nachträglich_neuberechnen:66:31)
                          Ich hoffe ich habe jetzt nicht alles durcheinander gemacht 🙂
                          Danke für deine Geduld
                            docsnyder7 @Ro75 last edited by
                            @ro75 erstmal herzlichen Dank für das zur Verfügung gestelltes Script...
                            ein Frage dazu... als command result steht hier code:500
                            ist das korrekt oder eher nicht... denn ich bekomme alle DP´s angelegt, aber keine Daten darin?
                            Ro75 1 Reply Last reply Reply Quote 0
                            • Ro75
                              Ro75 @docsnyder7 last edited by
                              @docsnyder7 500 ist nicht in Ordnung. Da stimmt was bei den Einstellungen im Adapter nicht. Eventuell Benutzer Kennwort. Ist in der FB selbst die Freigabe im Benutzer erteilt worden?
                              Ro75.
                                @ro75
                                Kacke.. genau das wars! Es fehlte die Berechtigung ! Danke für den schnellen Support!!!!
                                  fastfoot @WernerS last edited by fastfoot
                                  @fastfoot
                                  also das _IN weg
                                    @fastfoot
                                    Ist das so gewollt?
                                    Du kannst ja die einzelnen Tage summiert berechnen, dafür ist der Monatsmodus gedacht
                                      dann bekomme ich
                                      und die Fehlermeldung schneidest du ab!
                                      Also nochmal
                                      • Das Skript muss da laufen wo auch das Original läuft
                                      • wenn dort sql.0 steht muss das auch in diesem Skript so stehen.
                                      • Wenn im Original iobrokerslave02 steht, muss das auch in diesem Skript in Zeile 1 so stehen
                                      • Den Datenbanknamen findest du auch in den Settings der jeweiligen SQL Instanz und der muss in beiden Skripts genau so lauten wie dort angegeben
                                      ich fürchte dein Setup verwirrt dich etwas, ganz zu schweigen von den Helfern die dein System nicht kennen und auf deine korrekten Infos angewiesen sind
                                        @fastfoot
                                        Hallo
                                        also das Script hat super funktioniert. Nur seid Januar kommt eine Fehlermeldung "Keine Daten" obwohl sich nichts geändert hat.
                                        Werner
                                          srkonus last edited by
                                          Nabend zusammen,
                                          ich habe keine SQL laufen - zumindest nicht bewusst. Einen SQL Adpter habe ich nicht installiert. Geht das Script auch über den History Adapter?
                                          VG
                                          srkonus
                                          112
                                          11168
