    4. ioBroker/Adapter Update
      Leon111 last edited by Homoran
      @thomas-braun said in ioBroker/Adapter Update:
      iob diag
      Danke Thomas für die schnelle Antwort.
      Der fix ist durchgelaufen, und die Diagnostik:
      Copy text starting here:
                              v.2024-05-22
         Static hostname: raspberrypi4-iob
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Installation:           native
      Kernel:                 armv7l
      Userland:               32 bit
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      Display-Server:         false
      Boot Target:            graphical.target
      Pending OS-Updates:     0
      Pending iob updates:    10
      Nodejs-Installation:
      /usr/bin/nodejs         v18.20.4
      /usr/local/bin/node             v18.12.1
      /usr/local/bin/npm              8.19.2
      /usr/local/bin/npx              8.19.2
      /usr/local/bin/corepack         0.14.2
      Recommended versions are nodejs 18.20.4 and npm 10.7.0
      *** nodejs is NOT correctly installed ***
      Wrong installation path detected. This needs to be fixed.
      Please execute
      iobroker nodejs-update
      to fix these errors.
      MEMORY:
      Mem:           3.8G        912M        2.1G        8.0M        792M        2.8G
      Swap:           99M          0B         99M
      Total:         3.9G        912M        2.2G
      Active iob-Instances:   21
      Active repo(s): stable
      ioBroker Core:          js-controller           5.0.19
                              admin                   6.17.14
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : raspberrypi4-iob                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : raspberrypi4-iob                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                4287
      States:                 4031
      Size of iob-Database:
      12M     /opt/iobroker/iobroker-data/objects.jsonl
      6.2M    /opt/iobroker/iobroker-data/objects.json.migrated
      6.2M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      1.8M    /opt/iobroker/iobroker-data/states.jsonl
      932K    /opt/iobroker/iobroker-data/states.json.migrated
      932K    /opt/iobroker/iobroker-data/states.json.bak.migrated
      0       /opt/iobroker/iobroker-data/states.json.broken
      === Mark text until here for copying ===
      pi@raspberrypi4-iob:~ $ Copy text starting here:
                              v.2024-05-22
               Icon name: computer
            Architecture: arm
      Kernel:                 armv7l
      Userland:               32 bit
      User-ID:                1000
      *** nodejs is NOT c-bash: Copy: Kommando nicht gefunden.
      Please execute
      MEMORY:
      Swap:           99M          0B         99M
                              admin                   6.17.14
      Objects type: jsonl
      States  type: jsonl
      Objects:                4287
      States:                 4031
      > ======================= SUMMARY =======================
      >                         v.2024-05-22
      >          Icon name: computer
      >       Architecture: arm
      > Kernel:                 armv7l
      > Userland:               32 bit
      > User-ID:                1000
      > Please execute
      > MEMORY:
      >               total        used        free      shared  buff/cache   available
      > Swap:           99M          0B         99M
      >                         admin                   6.17.14
      > ioBroker Status:        iobroker is running on this host.
      > Objects type: jsonl
      > States  type: jsonl
      > Status admin and web instance:
      > Objects:                4287
      > States:                 4031
      > =================== END OF SUMMARY ====================
      -bash: =======================: Kommando nicht gefunden.
      -bash: v.2024-05-22: Kommando nicht gefunden.
      -bash: Static: Kommando nicht gefunden.
      -bash: Icon: Kommando nicht gefunden.
      -bash: command substitution: Zeile 8: Syntaxfehler beim unerwarteten Wort `('
      -bash: command substitution: Zeile 8: `  Operating System: Raspbian GNU/Linux 10 (buster)'
      pi@raspberrypi4-iob:~ $ === Mark text until here for copying ===
      -bash: ===: Kommando nicht gefunden.
      pi@raspberrypi4-iob:~ $ pi@raspberrypi4-iob:~ $
      -bash: pi@raspberrypi4-iob:~: Kommando nicht gefunden.
      das ist das was am Ende kamm. Das frühere war dann schon weg. Soll ich es nochmal machen und auch hier posten?
      Vielen Dank erstmal für die Mühe.
      Leon
        Skript v.2024-05-22
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm
        Model           : Raspberry Pi 4 Model B Rev 1.1
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : 32 bit
        Systemuptime and Load:
         16:26:26 up 20 min,  1 user,  load average: 0.44, 0.76, 0.91
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Sat 2024-09-21 16:26:27 CEST
                   Universal time: Sat 2024-09-21 14:26:27 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
        *** Display-Server-Setup ***
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           3.8G        898M        2.1G        8.0M        793M        2.8G
        Swap:           99M          0B         99M
        Total:         3.9G        898M        2.2G
                 3838 M total memory
                  898 M used memory
                  498 M active memory
                  972 M inactive memory
                 2146 M free memory
                  249 M buffer memory
                  543 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        top - 16:26:27 up 20 min,  1 user,  load average: 0.44, 0.76, 0.91
        Tasks: 148 total,   1 running, 147 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  2.7 us,  4.1 sy,  0.0 ni, 93.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3838.7 total,   2146.4 free,    898.7 used,    793.6 buff/cache
        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2775.0 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** FILESYSTEM ***
        /dev/root      ext4       59G   13G   44G  23% /
        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     1.9G  8.5M  1.9G   1% /run
        tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
        [Sat Sep 21 16:06:07 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:36:29:4C vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Sat Sep 21 16:06:08 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Sat Sep 21 16:06:08 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sat Sep 21 16:06:10 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        Show mounted filesystems:
        TARGET                                SOURCE         FSTYPE     OPTIONS
        /                                     /dev/mmcblk0p2 ext4       rw,noatime
        |-/dev                                devtmpfs       devtmpfs   rw,relatime,size=1800568k,nr_inodes=84157,mode=755
        | |-/dev/shm                          tmpfs          tmpfs      rw,nosuid,nodev
        | |-/dev/pts                          devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | `-/dev/mqueue                       mqueue         mqueue     rw,relatime
        |-/sys                                sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security              securityfs     securityfs rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup                    tmpfs          tmpfs      ro,nosuid,nodev,noexec,mode=755
        | | |-/sys/fs/cgroup/unified          cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
        | | |-/sys/fs/cgroup/systemd          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
        | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
        | | |-/sys/fs/cgroup/cpuset           cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
        | | |-/sys/fs/cgroup/net_cls,net_prio cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
        | | |-/sys/fs/cgroup/blkio            cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,blkio
        | | |-/sys/fs/cgroup/devices          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,devices
        | | |-/sys/fs/cgroup/perf_event       cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
        | | |-/sys/fs/cgroup/freezer          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,freezer
        | | `-/sys/fs/cgroup/pids             cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,pids
        | |-/sys/fs/bpf                       none           bpf        rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug                 debugfs        debugfs    rw,relatime
        | `-/sys/kernel/config                configfs       configfs   rw,relatime
        |-/proc                               proc           proc       rw,relatime
        | `-/proc/sys/fs/binfmt_misc          systemd-1      autofs     rw,relatime,fd=32,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
        |-/run                                tmpfs          tmpfs      rw,nosuid,nodev,mode=755
        | |-/run/lock                         tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/rpc_pipefs                   sunrpc         rpc_pipefs rw,relatime
        | `-/run/user/1000                    tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=393084k,mode=700,uid=1000,gid=1000
        `-/boot                               /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.4G    /var/
        1.2G    /var/cache/apt/archives
        1.2G    /var/cache/apt
        1.2G    /var/cache
        93M     /var/lib
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        134M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        516M    /opt/iobroker/iobroker-data/
        369M    /opt/iobroker/iobroker-data/files
        139M    /opt/iobroker/iobroker-data/files/javascript.admin
        119M    /opt/iobroker/iobroker-data/backup-objects
        118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
        7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
        7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/61.54b23816.chunk.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        /dev/ttyACM0
        *** NodeJS-Installation ***
        nodejs:
          Installed: 18.20.4-1nodesource1
          Candidate: 18.20.4-1nodesource1
          Version table:
         *** 18.20.4-1nodesource1 600
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.20.3-1nodesource1 600
             18.20.2-1nodesource1 600
             18.20.1-1nodesource1 600
             18.20.0-1nodesource1 600
             18.19.1-1nodesource1 600
             18.19.0-1nodesource1 600
             18.18.2-1nodesource1 600
             18.18.1-1nodesource1 600
             18.18.0-1nodesource1 600
             18.17.1-1nodesource1 600
             18.17.0-1nodesource1 600
             18.16.1-1nodesource1 600
             18.16.0-1nodesource1 600
             18.15.0-1nodesource1 600
             18.14.2-1nodesource1 600
             18.14.1-1nodesource1 600
             18.14.0-1nodesource1 600
             18.13.0-1nodesource1 600
             18.12.0-1nodesource1 600
             18.11.0-1nodesource1 600
             18.10.0-1nodesource1 600
             18.9.1-1nodesource1 600
             18.9.0-1nodesource1 600
             18.8.0-1nodesource1 600
             18.7.0-1nodesource1 600
             18.6.0-1nodesource1 600
             18.5.0-1nodesource1 600
             18.4.0-1nodesource1 600
             18.3.0-1nodesource1 600
             18.2.0-1nodesource1 600
             18.1.0-1nodesource1 600
             18.0.0-1nodesource1 600
             10.24.0~dfsg-1~deb10u3 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.17.14
        javascript:     8.3.1
        nodejs modules from github:     3
        |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
        +-- iobroker.icons-open-icon-library-png@0.1.3 invalid: "https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master" from the root project
        | `-- philips-tv-api@0.0.1 invalid: "https://github.com/foxriver76/philipsandroidtv/tarball/d90e61de1ebf5cf07ab3b90c87d11afe02231025" from node_modules/iobroker.philips-tv
        Adapter State
          system.adapter.backitup.0               : backitup              : raspberrypi4-iob                         - disabled
        + system.adapter.ble.0                    : ble                   : raspberrypi4-iob                         -  enabled
          system.adapter.cloud.0                  : cloud                 : raspberrypi4-iob                         - disabled
        + system.adapter.discovery.0              : discovery             : raspberrypi4-iob                         -  enabled
        + system.adapter.email.0                  : email                 : raspberrypi4-iob                         -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : raspberrypi4-iob                         -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi4-iob                         -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi4-iob                         -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi4-iob                         -  enabled, port: 0
        + system.adapter.hue.0                    : hue                   : raspberrypi4-iob                         -  enabled, port: 443
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi4-iob                         -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi4-iob                         -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi4-iob                         -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi4-iob                         -  enabled
        + system.adapter.info.0                   : info                  : raspberrypi4-iob                         -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi4-iob                         -  enabled
          system.adapter.mihome.0                 : mihome                : raspberrypi4-iob                         - disabled, port: 9898, bind: 0.0.0.0
          system.adapter.mobile.0                 : mobile                : raspberrypi4-iob                         -  enabled
          system.adapter.mqtt.0                   : mqtt                  : raspberrypi4-iob                         - disabled, port: 1500, bind: 0.0.0.0
        + system.adapter.philips-tv.0             : philips-tv            : raspberrypi4-iob                         -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4-iob                         -  enabled
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi4-iob                         -  enabled, port: 1883, bind: 192.168.178.54
          system.adapter.squeezebox.0             : squeezebox            : raspberrypi4-iob                         - disabled, port: 9090
        + system.adapter.terminal.0               : terminal              : raspberrypi4-iob                         -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        + system.adapter.tr-064.0                 : tr-064                : raspberrypi4-iob                         -  enabled
          system.adapter.vis-bars.0               : vis-bars              : raspberrypi4-iob                         -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi4-iob                         -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi4-iob                         -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi4-iob                         -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4-iob                         -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi4-iob                         -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi4-iob                         -  enabled
          system.adapter.vis-material.0           : vis-material          : raspberrypi4-iob                         -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi4-iob                         -  enabled
          system.adapter.vis-metro.0              : vis-metro             : raspberrypi4-iob                         -  enabled
          system.adapter.vis-players.0            : vis-players           : raspberrypi4-iob                         -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi4-iob                         -  enabled
          system.adapter.vis-weather.0            : vis-weather           : raspberrypi4-iob                         -  enabled
          system.adapter.vis.0                    : vis                   : raspberrypi4-iob                         -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi4-iob                         -  enabled
        + system.adapter.yeelight-2.0             : yeelight-2            : raspberrypi4-iob                         -  enabled
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi4-iob                         -  enabled, port: /dev/ttyACM0
        + instance is alive
        ioBroker-Repositories
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.2    , installed 6.17.14 [Updatable]
        Adapter    "backitup"     : 3.0.22   , installed 2.11.0 [Updatable]
        Adapter    "ble"          : 0.14.0   , installed 0.14.0
        Adapter    "discovery"    : 5.0.0    , installed 4.5.0  [Updatable]
        Adapter    "email"        : 1.3.1    , installed 1.3.1
        Adapter    "hm-rega"      : 5.0.0    , installed 4.0.0  [Updatable]
        Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
        Adapter    "hue"          : 3.12.0   , installed 3.11.0 [Updatable]
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
        Adapter    "javascript"   : 8.7.6    , installed 8.3.1  [Updatable]
        Controller "js-controller": 6.0.11   , installed 5.0.19 [Updatable]
        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "philips-tv"   : 0.5.4    , installed 0.5.3  [Updatable]
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.0  [Updatable]
        Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "ws"           : 2.6.2    , installed 2.6.1  [Updatable]
        Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
        Objects and States
        Objects:        4287
        States:         4031
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.178.54:2001     0.0.0.0:*               LISTEN      1001       36675      5612/io.hm-rpc.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14317      619/sshd
        tcp        0      0 192.168.178.54:2010     0.0.0.0:*               LISTEN      1001       37144      5627/io.hm-rpc.1
        tcp        0      0 192.168.178.54:1883     0.0.0.0:*               LISTEN      1001       37901      5712/io.sonoff.0
        tcp        0      0 192.168.178.54:8701     0.0.0.0:*               LISTEN      1001       34500      5646/io.hm-rpc.2
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       36984      5526/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       36977      5526/iobroker.js-co
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       37029      5544/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       40405      6281/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14319      619/sshd
        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       34736      5841/io.terminal.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14089      611/dhcpcd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11205      371/avahi-daemon: r
        udp        0      0 0.0.0.0:60251           0.0.0.0:*                           108        11207      371/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          14100      611/dhcpcd
        udp6       0      0 :::44640                :::*                                108        11208      371/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        11206      371/avahi-daemon: r
        2024-09-21 16:25:26.672  - info: weatherunderground.0 (22296) State value to set for "weatherunderground.0.forecastHourly.24h.precipitation" has to be type "value.precipitation" but received type "number"
        2024-09-21 16:25:26.769  - info: weatherunderground.0 (22296) State value to set for "weatherunderground.0.forecastHourly.25h.precipitation" has to be type "value.precipitation" but received type "number"
        2024-09-21 16:25:26.817  - info: weatherunderground.0 (22296) State value to set for "weatherunderground.0.forecastHourly.26h.precipitation" has to be type "value.precipitation" but received type "number"
        2024-09-21 16:25:26.908  - info: weatherunderground.0 (22296) State value to set for "weatherunderground.0.forecastHourly.27h.precipitation" has to be type "value.precipitation" but received type "number"
        2024-09-21 16:25:26.968  - info: weatherunderground.0 (22296) State value to set for "weatherunderground.0.forecastHourly.28h.precipitation" has to be type "value.precipitation" but received type "number"
        2024-09-21 16:25:27.071  - info: weatherunderground.0 (22296) State value to set for "weatherunderground.0.forecastHourly.29h.precipitation" has to be type "value.precipitation" but received type "number"
        2024-09-21 16:25:27.142  - info: weatherunderground.0 (22296) State value to set for "weatherunderground.0.forecastHourly.30h.precipitation" has to be type "value.precipitation" but received type "number"
        2024-09-21 16:25:27.240  - info: weatherunderground.0 (22296) State value to set for "weatherunderground.0.forecastHourly.31h.precipitation" has to be type "value.precipitation" but received type "number"
        2024-09-21 16:25:27.327  - info: weatherunderground.0 (22296) State value to set for "weatherunderground.0.forecastHourly.32h.precipitation" has to be type "value.precipitation" but received type "number"
        2024-09-21 16:25:27.374  - info: weatherunderground.0 (22296) State value to set for "weatherunderground.0.forecastHourly.33h.precipitation" has to be type "value.precipitation" but received type "number"
        2024-09-21 16:25:27.421  - info: weatherunderground.0 (22296) State value to set for "weatherunderground.0.forecastHourly.34h.precipitation" has to be type "value.precipitation" but received type "number"
        2024-09-21 16:25:27.515  - info: weatherunderground.0 (22296) State value to set for "weatherunderground.0.forecastHourly.35h.precipitation" has to be type "value.precipitation" but received type "number"
        2024-09-21 16:25:29.585  - info: weatherunderground.0 (22296) Terminated (NO_ERROR): Without reason
        2024-09-21 16:25:30.150  - info: host.raspberrypi4-iob instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
        2024-09-21 16:25:30.674  - info: tr-064.0 (5773) forEachConfiguredDevice: in GetSpecificHostEntry 3(Marcel/AA:33:01:1A:D5:B1) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2024-09-21 16:25:41.605  - info: tr-064.0 (5773) forEachConfiguredDevice: in GetSpecificHostEntry 3(Marcel/AA:33:01:1A:D5:B1) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2024-09-21 16:25:52.641  - info: tr-064.0 (5773) forEachConfiguredDevice: in GetSpecificHostEntry 3(Marcel/AA:33:01:1A:D5:B1) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2024-09-21 16:26:03.835  - info: tr-064.0 (5773) forEachConfiguredDevice: in GetSpecificHostEntry 3(Marcel/AA:33:01:1A:D5:B1) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2024-09-21 16:26:15.024  - info: tr-064.0 (5773) forEachConfiguredDevice: in GetSpecificHostEntry 3(Marcel/AA:33:01:1A:D5:B1) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2024-09-21 16:26:26.041  - info: tr-064.0 (5773) forEachConfiguredDevice: in GetSpecificHostEntry 3(Marcel/AA:33:01:1A:D5:B1) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2024-09-21 16:26:37.369  - info: tr-064.0 (5773) forEachConfiguredDevice: in GetSpecificHostEntry 3(Marcel/AA:33:01:1A:D5:B1) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2024-09-21 16:26:48.554  - info: tr-064.0 (5773) forEachConfiguredDevice: in GetSpecificHostEntry 3(Marcel/AA:33:01:1A:D5:B1) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2024-09-21 16:26:59.694  - info: tr-064.0 (5773) forEachConfiguredDevice: in GetSpecificHostEntry 3(Marcel/AA:33:01:1A:D5:B1) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2024-09-21 16:27:11.100  - info: tr-064.0 (5773) forEachConfiguredDevice: in GetSpecificHostEntry 3(Marcel/AA:33:01:1A:D5:B1) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2024-09-21 16:27:22.172  - info: tr-064.0 (5773) forEachConfiguredDevice: in GetSpecificHostEntry 3(Marcel/AA:33:01:1A:D5:B1) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        iob diag has finished.
        Press any key for a summary
        Das hier ist der Anfang von der Diagnose
          Thomas Braun Most Active @Leon111 last edited by
          @leon111 sagte in ioBroker/Adapter Update:
          buster
          Einmal komplett neu aufsetzen.
          Buster ist abgekündigt.
          https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
          Diesmal dann in den er 64Bit-Version ohne Desktop.
          Nein, nicht notwendig, du wirst das eh neumachen müssen.
          iob nodejs-update 18
          iob update
          iob upgrade all
          iob stop
          iob upgrade self
          iob start
          Dann davon ein Backup ziehen und damit auf die Neuinstallation umziehen.
            Backup
            Danke dafür. Wenn ich ein Backup erstelle ( mit dem Backitup-Adapter ?)bleiben dann alle Adapter ( instalierte Instanzen) mit den Einstellungen erhalten?
            Soll ich die SD-Karte vorher rausnehmen und formatieren? Wie gehe ich am besten vor.:
            • Raspberry updaten:
            iob update
            iob upgrade all
            iob stop
            iob upgrade self
            iob start
            • Backup erstellen
            • ioBroker neuausetzen ( was heist "ohne Desktop"?)
            • Backup wieder einspielen
            Leon
              Thomas Braun Most Active @Leon111 last edited by Thomas Braun
              Das ist Sinn und Zweck eines Backups. Verwende den Backitup-Adapter dafür.
              Das heißt, du installierst ein 64Bit-Raspberry OS 'Lite' mittels Raspberry Imager.
              • OliverIO
                OliverIO last edited by
                nimm eine neue sd karte.
                dann hast du die alte noch zum spickeln falls was nicht richtig funktioniert beim übertragen,
                  OK, keine schlechte Idee
                  Ich werde mir es erstmal alles angucken und durchlesen, SD-Karte vorbereiten, Backup erstellen und dann losfahren mit dem Neuafsetzen. Dafür brauche ich allerdings ruhige Minute bzw. Stunden.
                  Erstmal vielen Dank für die Antworten und ich melde mich bestimmt wieder.
                  Schönes Wochenende noch
                  Leon
                    @leon111
                    Zumindest die Fixes und Updates solltest du zeitnah ausführen.
                    Aber auch die Neuinstallation nicht auf die lange Bank schieben.
                      Hallo an alle,
                      ich habe die Neuinstalation durchgeführt und das Backup wieder draugespielt.
                      Es funktioniert alles. Auch die Updates werden erfolgreich.
                      PlatformBetriebssystem:linux
                      Architektur:arm64
                      CPUs:4
                      Geschwindigkeit:1500 MHz
                      Modell:Cortex-A72
                      RAM:3.7 GB
                      System-Betriebszeit:4 T. 07:03:03
                      Node.js:v20.18.0
                      time:1728486040780
                      timeOffset:-120
                      NPM:10.8.2
                      Adapter-Anzahl:543
                      Datenträgergröße:58.0 GB
                      Freier Festplattenspeicher:51.6 GB
                      Aktive Instanzen:20
                      Pfad:/opt/iobroker/
                      Betriebszeit:4 T. 07:03:06
                      aktiv:true
                      _nodeCurrent:20.18.0
                      _nodeNewest:20.18.0
                      _nodeNewestNext:20.18.0
                      _npmCurrent:10.8.2
                      _npmNewest:10.8.2
                      _npmNewestNext:10.8.2
                      Vielen Dank noch eimal an die Profis
                      • mcm1957
                        mcm1957 @Leon111 last edited by
                        @leon111
                        Danke fürd Feedback
                        1032
