    3. Einsteigerfragen
    4. Installation
    5. IOBroker startet nicht mehr nach Updates
      Thomas Braun Most Active @thomke67 last edited by Thomas Braun
      @thomke67
      Kannst du mir mal aus dem jetzigen System die Ausgabe von
      cat /etc/debian_version
      mitteilen?
        thomke67 @Thomas Braun last edited by
        Ich habe node.js Version 18 installiert und das System ist wieder da. Vielen Dank!!!!!!
        Es war aber wohl auf Version 14, oder?
        ioBroker nodejs fixer 2024-06-20
        You requested to install latest version from nodejs v18 tree.
        Your current setup is:
        /usr/bin/nodejs         v14.21.3
        /usr/bin/node           v14.21.3
        /usr/bin/npm            6.14.18
        /usr/bin/npx            6.14.18
        /usr/bin/corepack       0.15.1
        We found these nodejs versions available for installation:
        nodejs:
          Installed: 14.21.3-deb-1nodesource1
          Candidate: 14.21.3-deb-1nodesource1
          Version table:
         *** 14.21.3-deb-1nodesource1 1001
                500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u3 500
        Nothing to do - Your installation is using the correct paths.
        You are running nodejs v14.21.3. Do you want to install latest version from nodejs v.18 tree?
        Press <y> to continue or any other key to quit
        Trying to fix your installation now. Please be patient.
        rm: cannot remove '/etc/apt/keyrings/nodesource.gpg'$'\n''/usr/share/keyrings/nodesource.gpg 2> /dev/null': No such file or directory
        Waiting for ioBroker to shut down - Give me a minute...
        Removing dfsg-nodejs
        *** These repos are active on your system:
        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:2 https://apt.pivccu.de/piVCCU stable InRelease
        Hit:3 http://archive.raspberrypi.org/debian buster InRelease
        Reading package lists... Done
        *** Installing ca-certificates, curl and gnupg, just in case they are missing.
        *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
        deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
        Package: nodejs
        Pin: origin deb.nodesource.com
        Pin-Priority: 1001
        *** These repos are active after the adjustments:
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 https://apt.pivccu.de/piVCCU stable InRelease
        Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
        Get:5 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [10.2 kB]
        Fetched 22.4 kB in 1s (21.2 kB/s)
        Installing nodejs now!
        Exact recommended version unknown, installing a fallback!
        (Reading database ... 129820 files and directories currently installed.)
        Preparing to unpack .../nodejs_18.0.0-1nodesource1_armhf.deb ...
        Detected old npm client, removing...
        Unpacking nodejs (18.0.0-1nodesource1) over (14.21.3-deb-1nodesource1) ...
        Setting up nodejs (18.0.0-1nodesource1) ...
        Processing triggers for man-db (2.8.5-2+deb10u1) ...
        Updating fallback to latest nodejs v18 release
        (Reading database ... 130626 files and directories currently installed.)
        Preparing to unpack .../nodejs_18.20.4-1nodesource1_armhf.deb ...
        Unpacking nodejs (18.20.4-1nodesource1) over (18.0.0-1nodesource1) ...
        Setting up nodejs (18.20.4-1nodesource1) ...
        v18.20.4 has been installed! You are using the latest version now!
        Installing the nodejs!
        We tried our best to fix your nodejs. Please run iob diag again to verify.
        *** RESTARTING ioBroker NOW! ***
         Please refresh or restart your browser in a few moments.
        pi@raspberrypi:~ $
          @thomas-braun Debian Version 10.13
            @thomke67
            Bitte vollständige Ein- wie Ausgaben in CodeTags zeigen. Also genauso wie es dann auch auf deinem Bildschirm ausgespuckt wird.
              @thomas-braun Hier die Ausgabe:
              pi@raspberrypi:~ $ cat /etc/debian_version
              10.13
              pi@raspberrypi:~ $
                @thomke67
                Jetzt siehst du auch warum ich da so genau nachfrage...
                Debian Version 10.13 ist nicht gleich 10.13
                Ich muss die Abfrage in nodejs-update dann entsprehend ergänzen.
                  @thomas-braun Ok!
                  Und wie komme ich jetzt für mich am Einfachsten von Debian Buster auf die aktuellste Version?
                  Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
                  • Codierknecht
                    Codierknecht Developer Most Active @thomke67 last edited by
                    @thomke67 sagte in IOBroker startet nicht mehr nach Updates:
                    wurde doch schon mehrfach geschrieben:
                    https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                      thomke67 @thomke67 last edited by
                      @codierknecht Es wurde genau einmal geschrieben und da waren meine Fragen:
                      @codierknecht Wird dabei die alte Version überschrieben, oder muss ich die manuell löschen?
                      Zudem ist bei mir die Installation auf einer SSD. Das habe ich vor langer Zeit mal gemacht und jetzt weiß ich nicht mehr, wie ich damals vorgegangen bin. War bestimmt eine Schritt für Schritt Anleitung.
                      Backitup hat bei mir die Backups auf einen NAS geschrieben. Die stehen mir also jetzt unabhängig von der SSD zur Verfügung.
                      Ich weiß aber echt nicht mehr, wie ich von der SD Karte auf die SSD umgezogen bin. Das System lief jetzt einige Jahre super stabil! Und wenn ich mich nicht ganz täusche, dann habe ich die Version des Debians schon mal von einer alten Version auf Buster hochgezogen. Ich habe nämlich irgendwo noch in einem Script einen String durch "buster" ersetzt und dann ging es.
                      Aber das ist alles schon sehr lange her.....
                      Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                        Der einfachste, weil auch einzige sinnvolle Weg zu einem Raspberry OS 12 'Bookworm' ist eine komplette Neuinstallation.
                          Das funktioniert im Fall von 'Raspberry OS 12' nicht.
                            @thomas-braun Ok, verstanden. Also wäre das die normale Vorgehensweise:
                            1. Ein neues Image auf die SSD schreiben
                            2. Nach deiner Vorgehensweise auf https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht Iobroker neu installieren
                            3. Backitup Adapter installieren
                            4. Backups zurückspielen
                            Allerdings läuft bei mir auch noch PIvCCU auf dem gleichen Raspi. Das wäre ja dann weg.
                            Also klappt das bei mir nicht ganz so....
                            Thomas Braun Samson71 2 Replies Last reply Reply Quote 0
                              Aber auch dafür wird es wohl Backups geben. Musst du halt mal bei pivCCU vorbeischauen, wie das gemacht wird.
                              • Samson71
                                Samson71 Global Moderator @thomke67 last edited by
                                Sofern nativ (ohne ein Containersystem wie Docker o. Proxmox), zeigt sich dass es sehr problematisch sein kann mehrere Systeme einfach gemeinsam ohne Trennung auf eine Kiste zu packen. Da bei mir Homematic immer noch mehr als 80% meiner Komponenten managed und die Grundfunktionen wie Licht und Verdunkelung auch ohne ioBroker in Grundzügen funktionieren sollen, habe ich Raspberrymatic auf einem eigenen TinkerS laufen. Ich würde daher hier und jetzt die Chance zur Trennung nutzen. Auch die (Linux-)Basis für ein CCU-Derivat will aktuell gehalten sein.
                                  Thomas Braun Most Active @Samson71 last edited by Thomas Braun
                                  @samson71
                                  Eigentlich kein Problem. pivCCU setzt ja auf der gleichen aktuellen OS-Basis auf, wenn ich das richtig beobachte. Und auch für pivCCU wird es in irgendeiner Form was zum backuppen geben. Und sei es nur das wegsichern einer /etc/pivccu.conf oder sowas.
                                  Eine backup-Strategie musst du eh in jedem Fall haben, sei es als Container oder nativ aufgesetzt. Kann ja beides auch unverhofft aus irgendwelchen Gründen die Grätsche machen.
                                    Passt schon, Homematic selber kann Backups machen. Habe ich auch schon gemacht. Aber auch der Backitup Adapter speichert Backups von Homemetic (bzw. pivCCU). Auch das habe ich immer gemacht. Ich wollte halt nur vermeiden die ganzen Backups (Iobroker, Javascript, History db, Homematic) einzuspielen. Bin eben faul.....
                                    Ich gebe mich morgen mal dran. Sollte etwas nicht klappen, melde ich mich. Bei Erfolg, aber auch!
                                    Schon jetzt vielen Dank an alle!
                                      crunchip Forum Testing Most Active @thomke67 last edited by
                                      Bevor du loslegst würde ich mir die backitup config sichern, die kannst du dann, nachdem iobroker neu installiert wurde, wieder reinladen und anschließend dein Backup einspielen, anstoßen
                                        thomke67 @crunchip last edited by
                                        @crunchip Wenn du die json-Datei meinst, dann ja. Auch die ist gespeichert.
                                          thomke67 @thomke67 last edited by thomke67
                                          An Alle,
                                          vielen Dank für eure Hilfe! Neuestes Image laut Anleitung geflasht und gestartet, Iobroker installiert und pivCCU manuell nach Anleitung von Alex installiert, alle Backups eingespielt und siehe da, pivCCU und Iobroker rennen wie vorher. Super!
                                          Einzig diese Fehlermeldung stört mich:
                                          rpi2.0	2024-10-11 12:05:57.396	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/sda2 114875828 7059872 101965036 7% .....
                                          Gibt es da noch einen Tipp?
                                            Das ist mit rpi2 Version 2.0.1 (Beta) behoben.
                                            Da gibt es allerdings u. U. mit GPIOs Probleme.
                                            2690
