    4. Motion eye startet nicht
      crunchip Forum Testing Most Active @line last edited by
      @line https://github.com/motioneye-project/motioneye/releases
      • haselchen
        haselchen Most Active @line last edited by haselchen
        @line
        Hast Du Dich verschrieben bei dem Port?
        Er ist 8765 und nicht , wie Du geschrieben hast 8756.
        "Öffnen Sie die MotionEye-Benutzeroberfläche mit Ihren Webbrowsern, indem Sie die IP-Adresse Ihres Raspberry Pi gefolgt von Port 8765 eingeben"
          line @haselchen last edited by
          @haselchen
          Sowas doofes. Du hast recht! Ich dachte es wäre 8756. Danke dir, jetzt gehts
            line @line last edited by line
            @line ok Kamara konnte ich nun einbinden.
            Der Status zeigt folgenden Fehler
            Oct 13 16:49:12 iobroker-pi meyectl[385]:    ERROR: rtsp client error: Connection refused
            Oct 13 16:49:23 iobroker-pi meyectl[385]:     INFO: adding new netcam camera with id 1...
            Oct 13 16:49:23 iobroker-pi motion[11559]: [0:motion] [NTC] [ALL] conf_load: Processing thread 0 - config file /etc/motioneye/motion.conf
            Oct 13 16:49:23 iobroker-pi motion[11559]: [0:motion] [NTC] [ALL] config_camera: Processing camera config file camera-1.conf
            Oct 13 16:49:23 iobroker-pi motion[11559]: [0:motion] [ALR] [ALL] conf_cmdparse: "netcam_keepalive" replaced with "netcam_params" after version >
            Oct 13 16:49:23 iobroker-pi motion[11559]: [0:motion] [ALR] [ALL] conf_cmdparse: "netcam_tolerant_check" replaced with "netcam_params" after ver>
            Oct 13 16:49:23 iobroker-pi motion[11559]: [0:motion] [NTC] [ALL] motion_startup: Logging to syslog
            Oct 13 16:49:23 iobroker-pi motion[11559]: [0:motion] [NTC] [ALL] motion_startup: Motion 4.7.0 Started
            Oct 13 16:49:23 iobroker-pi motion[11559]: [0:motion] [NTC] [ALL] motion_startup: Using default log type (ALL)
            Oct 13 16:49:23 iobroker-pi motion[11559]: [0:motion] [NTC] [ALL] motion_startup: Using log type (ALL) log level (WRN)
              crunchip Forum Testing Most Active @crunchip last edited by crunchip
              @line sagte in Motion eye startet nicht:
              welche und wie?
              • haselchen
                @line
                Connection refused deutet auf ein Problem mit der Verbindung zur Kamera hin.
                Wie lautet deine RTSP URL?
                Und wo haste die her ?
                Hersteller oder aus dem Netz ?
                  @haselchen
                  Vom Gerät hab ich die rtsp. Sie lautet rtsp://ip:554/live/ch1
                  Ich bekomm auch ein Bild, jedoch wundert mich die Fehlermeldung
                  wendy2702 haselchen 2 Replies Last reply Reply Quote 0
                  • wendy2702
                    wendy2702 @line last edited by
                    @line welche Fehlermeldung?
                    Sehe im log fitzel keinen Error
                      line @wendy2702 last edited by
                      @wendy2702
                      Oct 13 16:53:47 iobroker-pi motion[11715]: [0:motion] [NTC] [ALL] motion_startup: Using log type (ALL) log level (WRN)
                      Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [NTC] [ALL] conf_load: Processing thread 0 - config file /etc/motioneye/motion.conf
                      Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [NTC] [ALL] config_camera: Processing camera config file camera-1.conf
                      Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [ALR] [ALL] conf_cmdparse: "netcam_keepalive" replaced with "netcam_params" after version >
                      Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [ALR] [ALL] conf_cmdparse: "netcam_tolerant_check" replaced with "netcam_params" after ver>
                      Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [NTC] [ALL] motion_startup: Logging to syslog
                      Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [NTC] [ALL] motion_startup: Motion 4.7.0 Started
                      Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [NTC] [ALL] motion_startup: Using default log type (ALL)
                      Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [NTC] [ALL] motion_startup: Using log type (ALL) log level (WRN)
                      Oct 13 17:25:38 iobroker-pi motion[11792]: [2:nc2:Hausgang] [ERR] [NET] netcam_rtsp_handler_reconnect: norm: Reconnecting with camera....
                      • haselchen
                        @line
                        Also, korrigiert mich , aber meine Streams haben entweder einen Token oder ich muss Benutzername und Passwort mit in die URL packen.
                        Hast Du mal den ONVIF Manager ausprobiert (Windows). Der liefert dir die genaue Stream URL.
                          @haselchen der obere RTSP habe ich im Motion Eye eingegeben. Dieser ist ja dann mit User und PW.
                          Laut der Einstellung in meiner Kamara ist die RTSP wie folgt:
                          rtsp://User:PW@IP_Nummer:544/live/ch1
                          Aber wie gesagt, den User/PW gebe ich ja in der Motion Eye Setup ein
                          bahnuhr haselchen 2 Replies Last reply Reply Quote 0
                          • bahnuhr
                            bahnuhr Forum Testing Most Active @line last edited by
                            Dann musst du auch die von ME zur Verfügung gestellte url eingeben; und nicht die rtsp
                            • haselchen
                              @line
                              Vermutlich ein Kommunikationsfehler.
                              Also beim Anlegen der Kamera gibst Du ja Network Kamera an.
                              Da kommt dann die RTSP URL rein OHNE Benutzername und Passwort.
                              Und in den Feldern darunter, da gibst Du dann Benutzername und Passwort ein.
                              Vorausgesetzt, so ist das bei Deiner Kamera vorgesehen.
                              Bei meiner Wansview muss ich nen Token mit angeben (herausgefunden über ONVIF Manager).
                              Bei meiner Tapo muss ich das so eingeben, wie oben beschrieben.
                              • bahnuhr
                                In ME hier den rtsp:
                                Und hier erhälts du die Streaming url:
                                Bei mir:
                                Und diesen dann in vis.
                                  @haselchen ich musste den motion eye nochmals deinstallieren und neu aufsetzten, weil er zu viele Fehler hatte.
                                  Nun konnte ich meinen Iobroker nicht mehr wie gewohnt auf dem Port 8081 erreichen, sondern auf dem 8082.
                                  in der Iobroker list instance zeigt er mir jedoch den 8081 an:
                                  system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  Die Ports von motion und motion eye sind in der config auf 8765 gesetzt. Das passt.
                                  Jedoch hab ich unternetstart -n -a -p TCP so viele Dienste drin - teilweise auch doppelt. Kann das zusammenhängen mit dem neuen Iobroker Port 8082?
                                    crunchip Forum Testing Most Active @line last edited by crunchip
                                    weil du dadurch den Port belegt hast
                                    hat damit nichts zu tun, sondern jede Cam bekommt einen Port zugeteilt, cam1 Port 8081, cam2 8082, cam3 8083...usw
                                    zu sehen, hier
                                    du kannst die Ports der cams in motioneye ändern
                                      line @crunchip last edited by line
                                      Trotzdem wird die 8081 von irgendetwas anderes blockiert
                                      Wenn ich auf den stream url klicke, passiert nichts. Gebe ich die ip mit dem Port ein, sehe ich das Kamara. Aber er zeigt mir keine snapshot url, stream url, eingebettete url - aber das ist ein anderes Thema 🙂
                                        auch neu durchgestartet?
                                        dann seh nach was für Ports belegt sind
                                        sudo netstat -tulpn
                                          @crunchip der zeigt an, dass ich 4 Kamaras habe - aber es sind nur 2 mit Port 8898 und 8899
                                          Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
                                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      494/mosquitto
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      7379/iobroker.js-co
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      7379/iobroker.js-co
                                          tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      483/python3
                                          tcp        0      0 0.0.0.0:8899            0.0.0.0:*               LISTEN      10788/motion
                                          tcp        0      0 0.0.0.0:8898            0.0.0.0:*               LISTEN      10788/motion
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      525/sshd: /usr/sbin
                                          tcp        0      0 127.0.0.1:8081          0.0.0.0:*               LISTEN      492/motion
                                          tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      492/motion
                                          tcp        0      0 127.0.0.1:6999          0.0.0.0:*               LISTEN      10788/motion
                                          tcp        0      0 192.168.178.69:1882     0.0.0.0:*               LISTEN      7700/io.shelly.0
                                          tcp6       0      0 :::1883                 :::*                    LISTEN      494/mosquitto
                                          tcp6       0      0 :::4712                 :::*                    LISTEN      859/evcc
                                          tcp6       0      0 :::22                   :::*                    LISTEN      525/sshd: /usr/sbin
                                          tcp6       0      0 :::8095                 :::*                    LISTEN      10200/io.onvif.0
                                          tcp6       0      0 :::8084                 :::*                    LISTEN      7926/io.socketio.0
                                          tcp6       0      0 :::8083                 :::*                    LISTEN      7995/io.web.0
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      7428/io.admin.0
                                          tcp6       0      0 :::3389                 :::*                    LISTEN      530/xrdp
                                          tcp6       0      0 :::7070                 :::*                    LISTEN      859/evcc
                                          tcp6       0      0 ::1:3350                :::*                    LISTEN      498/xrdp-sesman
                                          udp        0      0 0.0.0.0:1902            0.0.0.0:*                           7892/io.mediola-gat
                                          udp        0      0 0.0.0.0:60841           0.0.0.0:*                           370/avahi-daemon: r
                                          udp        0      0 0.0.0.0:67              0.0.0.0:*                           7685/io.radar2.0
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           853/dhcpcd
                                          udp        0      0 0.0.0.0:53460           0.0.0.0:*                           7892/io.mediola-gat
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           859/evcc
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           370/avahi-daemon: r
                                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           7735/io.shelly.1
                                          udp6       0      0 :::51464                :::*                                370/avahi-daemon: r
                                          udp6       0      0 :::546                  :::*                                853/dhcpcd
                                          udp6       0      0 :::5353                 :::*                                859/evcc
                                          udp6       0      0 :::5353                 :::*                                370/avahi-daemon: r
                                          Evt. Noch von der 1. Installation? Kann ich die 8080 und 8081 dann rauskicken?
                                            Thomas Braun Most Active @line last edited by
                                            @line
                                            kill 492
                                            1139
