    4. Motion eye startet nicht
      crunchip Forum Testing Most Active @crunchip last edited by crunchip
      @line sagte in Motion eye startet nicht:
      Kamara konnte ich nun einbinden
      welche und wie?
      • haselchen
        haselchen Most Active @line last edited by
        @line
        Connection refused deutet auf ein Problem mit der Verbindung zur Kamera hin.
        Wie lautet deine RTSP URL?
        Und wo haste die her ?
        Hersteller oder aus dem Netz ?
          line @haselchen last edited by
          @haselchen
          Vom Gerät hab ich die rtsp. Sie lautet rtsp://ip:554/live/ch1
          Ich bekomm auch ein Bild, jedoch wundert mich die Fehlermeldung
          wendy2702 haselchen 2 Replies Last reply Reply Quote 0
          • wendy2702
            wendy2702 @line last edited by
            @line welche Fehlermeldung?
            Sehe im log fitzel keinen Error
              line @wendy2702 last edited by
              @wendy2702
              Oct 13 16:53:47 iobroker-pi motion[11715]: [0:motion] [NTC] [ALL] motion_startup: Using log type (ALL) log level (WRN)
              Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [NTC] [ALL] conf_load: Processing thread 0 - config file /etc/motioneye/motion.conf
              Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [NTC] [ALL] config_camera: Processing camera config file camera-1.conf
              Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [ALR] [ALL] conf_cmdparse: "netcam_keepalive" replaced with "netcam_params" after version >
              Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [ALR] [ALL] conf_cmdparse: "netcam_tolerant_check" replaced with "netcam_params" after ver>
              Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [NTC] [ALL] motion_startup: Logging to syslog
              Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [NTC] [ALL] motion_startup: Motion 4.7.0 Started
              Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [NTC] [ALL] motion_startup: Using default log type (ALL)
              Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [NTC] [ALL] motion_startup: Using log type (ALL) log level (WRN)
              Oct 13 17:25:38 iobroker-pi motion[11792]: [2:nc2:Hausgang] [ERR] [NET] netcam_rtsp_handler_reconnect: norm: Reconnecting with camera....
              • haselchen
                @line
                Also, korrigiert mich , aber meine Streams haben entweder einen Token oder ich muss Benutzername und Passwort mit in die URL packen.
                Hast Du mal den ONVIF Manager ausprobiert (Windows). Der liefert dir die genaue Stream URL.
                  @haselchen der obere RTSP habe ich im Motion Eye eingegeben. Dieser ist ja dann mit User und PW.
                  Laut der Einstellung in meiner Kamara ist die RTSP wie folgt:
                  rtsp://User:PW@IP_Nummer:544/live/ch1
                  Aber wie gesagt, den User/PW gebe ich ja in der Motion Eye Setup ein
                  bahnuhr haselchen 2 Replies Last reply Reply Quote 0
                  • bahnuhr
                    bahnuhr Forum Testing Most Active @line last edited by
                    Dann musst du auch die von ME zur Verfügung gestellte url eingeben; und nicht die rtsp
                    • haselchen
                      @line
                      Vermutlich ein Kommunikationsfehler.
                      Also beim Anlegen der Kamera gibst Du ja Network Kamera an.
                      Da kommt dann die RTSP URL rein OHNE Benutzername und Passwort.
                      Und in den Feldern darunter, da gibst Du dann Benutzername und Passwort ein.
                      Vorausgesetzt, so ist das bei Deiner Kamera vorgesehen.
                      Bei meiner Wansview muss ich nen Token mit angeben (herausgefunden über ONVIF Manager).
                      Bei meiner Tapo muss ich das so eingeben, wie oben beschrieben.
                      • bahnuhr
                        In ME hier den rtsp:
                        Und hier erhälts du die Streaming url:
                        Bei mir:
                        Und diesen dann in vis.
                          @haselchen ich musste den motion eye nochmals deinstallieren und neu aufsetzten, weil er zu viele Fehler hatte.
                          Nun konnte ich meinen Iobroker nicht mehr wie gewohnt auf dem Port 8081 erreichen, sondern auf dem 8082.
                          in der Iobroker list instance zeigt er mir jedoch den 8081 an:
                          system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
                          Die Ports von motion und motion eye sind in der config auf 8765 gesetzt. Das passt.
                          Jedoch hab ich unternetstart -n -a -p TCP so viele Dienste drin - teilweise auch doppelt. Kann das zusammenhängen mit dem neuen Iobroker Port 8082?
                            crunchip Forum Testing Most Active @line last edited by crunchip
                            weil du dadurch den Port belegt hast
                            hat damit nichts zu tun, sondern jede Cam bekommt einen Port zugeteilt, cam1 Port 8081, cam2 8082, cam3 8083...usw
                            zu sehen, hier
                            du kannst die Ports der cams in motioneye ändern
                              line @crunchip last edited by line
                              Trotzdem wird die 8081 von irgendetwas anderes blockiert
                              Wenn ich auf den stream url klicke, passiert nichts. Gebe ich die ip mit dem Port ein, sehe ich das Kamara. Aber er zeigt mir keine snapshot url, stream url, eingebettete url - aber das ist ein anderes Thema 🙂
                                auch neu durchgestartet?
                                dann seh nach was für Ports belegt sind
                                sudo netstat -tulpn
                                  @crunchip der zeigt an, dass ich 4 Kamaras habe - aber es sind nur 2 mit Port 8898 und 8899
                                  Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
                                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      494/mosquitto
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      7379/iobroker.js-co
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      7379/iobroker.js-co
                                  tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      483/python3
                                  tcp        0      0 0.0.0.0:8899            0.0.0.0:*               LISTEN      10788/motion
                                  tcp        0      0 0.0.0.0:8898            0.0.0.0:*               LISTEN      10788/motion
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      525/sshd: /usr/sbin
                                  tcp        0      0 127.0.0.1:8081          0.0.0.0:*               LISTEN      492/motion
                                  tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      492/motion
                                  tcp        0      0 127.0.0.1:6999          0.0.0.0:*               LISTEN      10788/motion
                                  tcp        0      0 192.168.178.69:1882     0.0.0.0:*               LISTEN      7700/io.shelly.0
                                  tcp6       0      0 :::1883                 :::*                    LISTEN      494/mosquitto
                                  tcp6       0      0 :::4712                 :::*                    LISTEN      859/evcc
                                  tcp6       0      0 :::22                   :::*                    LISTEN      525/sshd: /usr/sbin
                                  tcp6       0      0 :::8095                 :::*                    LISTEN      10200/io.onvif.0
                                  tcp6       0      0 :::8084                 :::*                    LISTEN      7926/io.socketio.0
                                  tcp6       0      0 :::8083                 :::*                    LISTEN      7995/io.web.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      7428/io.admin.0
                                  tcp6       0      0 :::3389                 :::*                    LISTEN      530/xrdp
                                  tcp6       0      0 :::7070                 :::*                    LISTEN      859/evcc
                                  tcp6       0      0 ::1:3350                :::*                    LISTEN      498/xrdp-sesman
                                  udp        0      0 0.0.0.0:1902            0.0.0.0:*                           7892/io.mediola-gat
                                  udp        0      0 0.0.0.0:60841           0.0.0.0:*                           370/avahi-daemon: r
                                  udp        0      0 0.0.0.0:67              0.0.0.0:*                           7685/io.radar2.0
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           853/dhcpcd
                                  udp        0      0 0.0.0.0:53460           0.0.0.0:*                           7892/io.mediola-gat
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           859/evcc
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           370/avahi-daemon: r
                                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           7735/io.shelly.1
                                  udp6       0      0 :::51464                :::*                                370/avahi-daemon: r
                                  udp6       0      0 :::546                  :::*                                853/dhcpcd
                                  udp6       0      0 :::5353                 :::*                                859/evcc
                                  udp6       0      0 :::5353                 :::*                                370/avahi-daemon: r
                                  Evt. Noch von der 1. Installation? Kann ich die 8080 und 8081 dann rauskicken?
                                    Thomas Braun Most Active @line last edited by
                                    @line
                                    kill 492
                                      line @Thomas Braun last edited by
                                      @thomas-braun dass war’s! Hoffentlich bleibt es so. Danke
                                      • haselchen
                                        @line
                                        Keine Ahnung wieviel RAM Du hast bei Deinem Raspi , aber mit Iobroker und vielleicht anderer Software zusammen , hast Du keinen Spaß mit MotionEye. Wenn dann noch 1-2 Cams dazukommen haste nur noch Daumenkino.
                                        Ich rate Dir zu separater Hardware und dem MotionEye Image.
                                        Hab nen Raspi 4 mit dem Image laufen und läuft ohne Neustart seit Monaten .
                                        Durch das Image brauchste auch nichts installieren und verwurschtelst vielleicht was dadurch , sondern haste sogar noch zusätzliche Einstellmöglichkeiten in der Software/ in der GUI.
                                        1139
