    4. bekomme den Sonoff 3 USB Dongle auch nicht auf grün.
    • haselchen
      haselchen Most Active @werner2000x last edited by haselchen
      @werner2000x
      Ok gerade quergelesen .
      Nimm bei Coordinator den EZSP.
      Und wichtig , es darf nix anderes laufen wo auf den Stick zugegriffen wird , als Beispiel Homeassistant.
      Edit: und die URL vom Stick, die du vorher hattest … dev/…..
      Mit dem Tool kannste resetten oder die nötige Firmware aufspielen.
      https://zig-star.com/radio-docs/zigstar-multi-tool/
      werner2000x 1 Reply Last reply Reply Quote 0
      • werner2000x
        werner2000x @haselchen last edited by werner2000x
        @haselchen Den EZSP gibt es in zwei versionen.
        Wieder Fehler:
        zigbee.0
        2024-10-14 18:27:58.032	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"3a137e30f6e6ed11a179cf770b2af5ab","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3a137e30f6e6ed11a179cf770b2af5ab-if00-port0","vendorId":"10c4","productId":"ea60"}]
        zigbee.0
        2024-10-14 18:27:57.884	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
        zigbee.0
        2024-10-14 18:27:08.051	info	Installed Version: ioBroker/ioBroker.zigbee
        zigbee.0
        2024-10-14 18:27:07.719	info	Starting Zigbee npm ...
        zigbee.0
        2024-10-14 18:27:07.717	info	delete old Backup files. keep only last 10
        zigbee.0
        2024-10-14 18:27:07.618	info	starting. Version 1.10.9 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.0, js-controller: 6.0.11
        zigbee.0
        2024-10-14 18:26:52.141	info	terminating
        zigbee.0
        2024-10-14 18:26:51.658	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        zigbee.0
        2024-10-14 18:26:51.655	info	terminating
        zigbee.0
        2024-10-14 18:26:51.642	info	Zigbee: disabling joining new devices.
        zigbee.0
        2024-10-14 18:26:51.637	info	cleaned everything up...
        zigbee.0
        2024-10-14 18:26:51.634	info	Got terminate signal TERMINATE_YOURSELF
        Thomas Braun haselchen 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @werner2000x last edited by
          @werner2000x
          Nix /dev/USB...
          Der Link 'by-id' war doch schon richtig:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3a137e30f6e6ed11a179cf770b2af5ab-if00-port0
          Your zigbee.0 COM-Port is matching 'by-id'. Very good!
          • haselchen
            @werner2000x
            Da ist kein Fehler . Das sind Infos .
            Zeig mal jetzt bitte deine komplette Einstellungsseite vom Adapter
            Edit : in deinem Screenshot gibt es nur einen EZSP zur Auswahl
            • haselchen
              haselchen Most Active @Thomas Braun last edited by
              Niemand hat dev/USB geraten.
              Ansonsten wäre es auch tty/USB0
                Thomas Braun Most Active @haselchen last edited by
                @haselchen
                Es wäre /dev/ttyUSB0.
                Und nicht die beste Lösung, wenn es mit dem 'by-id' doch schon lief.
                Mit der EZSP-Version läuft es ja nun wohl.
                • haselchen
                  Da ich nicht weiß welche FW auf dem Stick läuft , würde ich mit dem Multitool die geforderte 7.2.xx
                  aufspielen und bei 0 beginnen.
                  • werner2000x
                    @haselchen Ja, stimmt nur einen, aber zwei EFR32:
                    • haselchen
                      @werner2000x
                      Nimm den EZSP bitte .
                      Die baudrate spielt glaube ich nur beim Conbee ne Rolle .
                      Schreib da trotzdem 115200 rein .
                      Ansonsten müsste alles passen.
                      Ich hatte auch solche Probleme.
                      Hab mit dem Multitool den Stick resettet und neu angefangen .
                      Vielleicht solltest du das genauso machen .
                      Aber auf jeden Fall solltest du deine FW herausbekommen .
                      Wenn die nicht zur EZSP Einstellung passt , musste die dann noch flashen .
                      • Meister Mopper
                        Meister Mopper @bjoernb last edited by
                        @bjoernb sagte in [gelöst] Sonoff Zigbee 3.0 Dongle E startet nicht (mehr):
                        @thomas-braun Manachmal verstehe ich Computer ja schon nicht. Jetzt hab ich den Adapter deinstalliert und einfach nochmal die Version 1.9.5. installiert, dann konnte er den Stick verbinden. Upgrade auf die aktuelle Version, immernoch grün.
                        Sozusagen "solved"...
                        @Homoran (lieber Hausmeister 😉 )
                        Kannst Du das bitte separieren? Der erste Teil hat meiner Ansicht nach nichts mehr mit dem zweiten zu tun.
                          Homoran Global Moderator Administrators @Meister Mopper last edited by
                          @meister-mopper sagte in bekomme den Sonoff 3 USB Dongle auch nicht auf grün.:
                          Kann ich!
                          Hab ich sogar gemacht 😁
                          @werner2000x bitte provisorischen Threadtitel anpassen
                          • werner2000x
                            @homoran Habe heute neu geflashed mit NabuCasa_SkyConnect_EZSP_v7.2.3.0_ncp-uart-hw_115200.hex
                            Kein Erfolg 😞
                            zigbee.0
                            2024-10-15 13:33:42.243	info	Installed Version: ioBroker/ioBroker.zigbee
                            zigbee.0
                            2024-10-15 13:33:42.183	info	Starting Zigbee npm ...
                            zigbee.0
                            2024-10-15 13:33:42.182	info	Try to reconnect. 1 attempts left
                            zigbee.0
                            2024-10-15 13:33:32.176	error	Error herdsman start
                            zigbee.0
                            2024-10-15 13:33:32.175	error	Failed to start Zigbee
                            zigbee.0
                            2024-10-15 13:33:32.174	error	Starting zigbee-herdsman problem : "Failure to connect"
                            zigbee.0
                            2024-10-15 13:32:21.468	info	Installed Version: ioBroker/ioBroker.zigbee
                            zigbee.0
                            2024-10-15 13:32:21.120	info	Starting Zigbee npm ...
                            zigbee.0
                            2024-10-15 13:32:21.118	info	delete old Backup files. keep only last 10
                            zigbee.0
                            2024-10-15 13:32:21.015	info	starting. Version 1.10.9 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.0, js-controller: 6.0.11
                            • haselchen
                              @werner2000x
                              Warum nicht ne für den Stick vorgesehene Firmware ?
                              https://github.com/itead/Sonoff_Zigbee_Dongle_Firmware/tree/master/Dongle-E
                              Oder von hier:
                              • werner2000x
                                @hase Ich habe den Sonoff Model: ZBDongle-P
                                • haselchen
                                  @werner2000x
                                  Guck dir dann den 2.Link an .
                                  Edit : dann haben wir eigentlich den gleichen Stick
                                  Dann musste im Adapter als Coordinator anscheinend doch CC…. nehmen
                                  • werner2000x
                                    @haselchen Dort finde ich nur den Dongle- E
                                    haselchen C 3 Replies Last reply Reply Quote 0
                                    • haselchen
                                      @werner2000x
                                      Und dann kann ich dir auch den Link für die richtige Software gleich geben.
                                      Das flasht du mit dem Multitool
                                        chris299 @werner2000x last edited by
                                        @werner2000x ich verwende den P mit dieser Firmware: https://github.com/Koenkk/Z-Stack-firmware/tree/master/coordinator (das ist dann der TI stack )
                                        • haselchen
                                          @werner2000x
                                          https://github.com/Koenkk/Z-Stack-firmware/tree/master/coordinator/Z-Stack_3.x.0/bin
                                          Erster Eintrag mit Launchpad
                                          • werner2000x
                                            @haselchen Der Adapter ist jetzt grün. D a n k e !!!
                                            Jetzt muss ich noch herausfinden wie man Geräte findet. Ich habe jede Menge Geräte aus dem innogy Umfeld und einen Aquara TVCO Air Quality Monitor der schon gefunden wurde.
                                            1215
