    4. Test Adapter rpi2 2.x
    • I
      IOSD @Garfonso last edited by
      @garfonso
      meinst du das. Bei mir geht GPIO auch nicht mehr. Fehler analog:
      Cannot initialize/setMode GPIO: TypeError: Cannot read properties of undefined (reading 'watch')
      "_id": "system.adapter.rpi2.0",
      "common": {
      "name": "rpi2",
      "version": "2.0.0",
      "title": "RPI-Monitor",
      "authors": [
      "Christian Baumgartner",
      "husky-koglhof husky.koglhof@icloud.com",
      "Garfonso garfonso@mobo.info"
      "os": [
      "linux"
      "keywords": [
      "ioBroker",
      "monitoring",
      "raspberry",
      "orangepi",
      "odroid",
      "bananapi",
      "gpio"
      "licenseInformation": {
      "type": "free",
      "license": "MIT"
      "platform": "Javascript/Node.js",
      "main": "main.js",
      "icon": "rpi2.png",
      "enabled": true,
      "extIcon": "https://raw.githubusercontent.com/iobroker-community-adapters/ioBroker.rpi2/master/admin/rpi2.png",
      "readme": "https://github.com/iobroker-community-adapters/ioBroker.rpi2/blob/master/README.md",
      "loglevel": "info",
      "tier": 2,
      "mode": "daemon",
      "type": "hardware",
      "compact": true,
      "connectionType": "local",
      "dataSource": "poll",
      "adminUI": {
      "config": "materialize"
      "osDependencies": {
      "linux": [
      "build-essential",
      "python",
      "libgpiod-dev"
      "dependencies": [
      "js-controller": ">=3.3.22"
      "globalDependencies": [
      "admin": ">=5.0.0"
      "singletonHost": true,
      "messages": [
      "condition": {
      "operand": "and",
      "rules": [
      "oldVersion<2.0.0",
      "newVersion>=2.0.0"
      "title": {
      "en": "GPIO Breaking Change",
      "de": "GPIO Veränderung",
      "ru": "GPIO Перерывы",
      "pt": "GPIO Mudança de ruptura",
      "nl": "GPIO Verandering doorbreken",
      "fr": "GPIO Briser le changement",
      "it": "GPIO Cambiamento di rottura",
      "es": "GPIO Cambio de ruptura",
      "pl": "GPIO Łamanie zmian",
      "uk": "ГРУП Зміна несправностей",
      "zh-cn": "科普罗 中断更改"
      "text": {
      "en": "GPIO needed massive changes for support of newer Raspian versions (Bookworm and following). Please check your GPIO configuration and if everything still works. GPIO Button support is removed. If you need it, please discuss in Github, see link.",
      "de": "GPIO brauchte massive Änderungen für die Unterstützung neuerer Raspian Versionen (Bookworm und nachfolgend). Bitte überprüfen Sie Ihre GPIO-Konfiguration und wenn alles noch funktioniert. GPIO Button-Unterstützung wird entfernt. Wenn Sie es brauchen, diskutieren Sie bitte in Github, siehe Link.",
      "ru": "GPIO нуждались в массовых изменениях для поддержки более новых версий Raspian (Bookworm и следующий). Пожалуйста, проверьте конфигурацию GPIO и все ли еще работает. Поддержка GPIO Button удалена. Если вам это нужно, пожалуйста, обсудите в Гитубе, см. ссылку.",
      "pt": "O GPIO precisava de mudanças massivas para o suporte de versões mais recentes do Raspian (Bookworm e seguintes). Por favor, verifique sua configuração GPIO e se tudo ainda funciona. O suporte do botão GPIO é removido. Se precisar, por favor, discuta no Github, veja link.",
      "nl": "GPIO had massale veranderingen nodig voor ondersteuning van nieuwere Raspian versies (Bookworm en volgende). Controleer uw GPIO configuratie en of alles nog werkt. GPIO-knop ondersteuning is verwijderd. Als je het nodig hebt, bespreek het dan in Github, zie link.",
      "fr": "GPIO a besoin de changements massifs pour soutenir les nouvelles versions Raspiennes (Bookworm et suivants). Veuillez vérifier votre configuration GPIO et si tout fonctionne encore. Le support du bouton GPIO est enlevé. Si vous en avez besoin, veuillez discuter à Github, voir le lien.",
      "it": "GPIO aveva bisogno di enormi cambiamenti per il supporto delle nuove versioni Raspian (Bookworm e seguenti). Controllare la configurazione GPIO e se tutto funziona ancora. Il supporto del pulsante GPIO viene rimosso. Se avete bisogno, si prega di discutere a Github, vedere il link.",
      "es": "GPIO necesitaba cambios masivos para apoyar las nuevas versiones de Raspian (worm y siguientes). Por favor, compruebe su configuración de GPIO y si todo sigue funcionando. GPIO Button support is removed. Si lo necesita, por favor discuta en Github, vea el enlace.",
      "pl": "GPIO potrzebowało ogromnych zmian dla wsparcia nowszych wersji Raspian (Bookworm i następnie). Proszę sprawdzić konfigurację GPIO i czy wszystko nadal działa. Wsparcie GPIO Button jest usuwane. W razie potrzeby proszę omówić to w Github, zobacz link.",
      "uk": "GPIO вимагає масивних змін для підтримки нових версій Raspian (Bookworm і наступні). Будь ласка, перевірте налаштування GPIO і якщо все ще працює. При видаленні кнопки GPIO. Якщо вам потрібно, будь ласка, покажіть в Github, див. посилання.",
      "zh-cn": "GPIO需要大规模修改来支持较新的Raspian版本(Bookdorm and follows). 请检查您的 GPIO 配置, 如果一切都还在工作。 GPIO按钮支持被删除. 如果你需要,请在Github讨论,参见链接."
      "link": "https://github.com/iobroker-community-adapters/ioBroker.rpi2/issues/192",
      "level": "warn",
      "linkText": {
      "en": "GPIO Button discussion.",
      "de": "GPIO Button Diskussion.",
      "ru": "GPIO Button discussion.",
      "pt": "Discussão do botão GPIO.",
      "nl": "GPIO Button discussie.",
      "fr": "Discussion sur le bouton GPIO.",
      "it": "GPIO Button discussione.",
      "es": "GPIO Button discussion.",
      "pl": "Dyskusja GPIO Button.",
      "uk": "Обговорення кнопки GPIO.",
      "zh-cn": "GPIO按钮讨论."
      "buttons": [
      "agree",
      "cancel"
      "installedFrom": "iobroker.rpi2@2.0.0",
      "installedVersion": "2.0.0",
      "host": "raspberrypi"
      "native": {
      "c_cpu": true,
      "c_raspberry": true,
      "c_memory": true,
      "c_network": true,
      "c_sdcard": true,
      "c_swap": true,
      "c_temperature": true,
      "c_uptime": true,
      "c_wlan": false,
      "inputPullUp": false,
      "inputDebounceMs": "0",
      "buttonPullUp": false,
      "buttonDebounceMs": "",
      "buttonPressMs": "200",
      "buttonDoubleMs": "500",
      "dhtPollInterval": "15000",
      "gpios": [
      null,
      null,
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": true,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      "enabled": false,
      "input": "in",
      "label": ""
      Garfonso created this issue in iobroker-community-adapters/ioBroker.rpi2
      open Keep button support -Discussion #192
        searcher57 @Garfonso last edited by searcher57
        @garfonso said in Test Adapter rpi2 2.x:
        @searcher57
        Nein, beides nicht. Also das JSON ist schon richttig erstellt, aber es ist das falsche Objekt. Ich meine das Objekt system.adapter.rpi2.0.
        //Edit: Aber gerade ist mir noch was einfacheres eingefallen -> einfach die Settings exportieren, das führt auch zu dem richtigen Ergebnis. Also bei den Einstellungen vom RPI Adapter oben rechts den Knopf mit dem Pfeil runter drücken, dann sollte das JSON als Download kommen.
        Ich hoffe, dass es dieses ist:
          "common": {
            "name": "rpi2",
            "version": "2.0.0",
            "mode": "daemon",
            "os": [
              "linux"
            "loglevel": "info",
            "keywords": [
              "ioBroker",
              "monitoring",
              "raspberry",
              "orangepi",
              "odroid",
              "bananapi",
              "gpio"
            "main": "main.js",
            "authors": [
              "husky-koglhof <husky.koglhof@icloud.com>",
              "Garfonso <garfonso@mobo.info>"
            "osDependencies": {
              "linux": [
                "build-essential",
                "python",
                "libgpiod-dev"
            "dependencies": [
                "admin": ">=5.0.0"
            "license": "MIT",
            "icon": "rpi2.png",
            "type": "hardware",
            "enabled": true,
            "materialize": true,
            "tier": 2,
            "host": "Raspi58GB",
              "type": "free",
              "license": "MIT"
            "compact": true,
            "adminUI": {
            "messages": [
                "condition": {
                  "operand": "and",
                  "rules": [
                    "oldVersion<2.0.0",
                    "newVersion>=2.0.0"
                "title": {
                  "zh-cn": "科普罗 中断更改"
                "text": {
                "level": "warn",
                "linkText": {
                "buttons": [
                  "agree",
                  "cancel"
          "native": {
            "c_cpu": false,
            "c_memory": true,
            "c_network": true,
            "c_sdcard": true,
            "c_swap": false,
            "c_uptime": false,
            "c_wlan": false,
            "inputDebounceMs": "20",
            "buttonPressMs": "",
            "buttonDoubleMs": "",
            "dhtPollInterval": "",
            "gpios": [
              null,
              null,
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": true,
                "input": "in",
                "label": "Wasserwächter"
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": true,
                "input": "in",
                "label": "Gas"
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
                "enabled": false,
                "input": "in",
                "label": ""
          jrgsch @Garfonso last edited by
          @garfonso
          Leider war ich eine zeitlang außer Gefecht gesetzt 😥
          Gestern habe ich nochmal das System komplett neu aufgesetzt --> leider immer noch kein Erfolg, beim Aktivieren eines Ausgangs kommt immer eine Error-Meldung
          rpi2.0   2024-10-02 09:53:38.827	error	Cannot initialize/setMode GPIO: TypeError: Cannot read properties of undefined (reading 'output')
          beim Input kommt
          rpi2.0 2024-10-02 10:21:50.279	error	Cannot initialize/setMode GPIO: TypeError: Cannot read properties of undefined (reading 'watch')
          Auszug "iob diag"
          *** BASE SYSTEM ***
           Static hostname: iobroker-24d-test
                 Icon name: computer
                    Kernel: Linux 6.6.51+rpt-rpi-v8
              Architecture: arm64
          OS is similar to:
          Model           : Raspberry Pi 4 Model B Rev 1.1
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.17.0
          /usr/bin/node           v20.17.0
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.3
          Alle Hinweise hier im Forum habe ich nach bestem Wissen und Gewissen überprüft, etwa
          pi@iobroker-24d-test:/opt/iobroker $ npm list opengpio
          iobroker.inst@3.0.0 /opt/iobroker
          └─┬ iobroker.rpi2@2.0.0
            └── opengpio@1.0.16
          Hier mal ein Auszug der beim Setzen eines Ausgangs generierten Debug-Meldungen
          2024-10-02 09:52:56.880 - debug: rpi2.0 (18615) Creating gpio.5.isInput
          2024-10-02 09:52:56.906 - debug: rpi2.0 (18615) Creating gpio.6.isInput
          2024-10-02 09:52:56.989 - debug: rpi2.0 (18615) Creating gpio.12.isInput
          2024-10-02 09:52:57.049 - debug: rpi2.0 (18615) Creating gpio.16.isInput
          2024-10-02 09:52:57.112 - debug: rpi2.0 (18615) Creating gpio.20.isInput
          2024-10-02 09:52:57.150 - debug: rpi2.0 (18615) Creating gpio.21.isInput
          2024-10-02 09:52:57.270 - debug: rpi2.0 (18615) undefined
          2024-10-02 09:52:57.279 - debug: rpi2.0 (18615) CPU Info: Raspberry Pi 4 Model B Rev 1.1
          2024-10-02 09:52:57.279 - debug: rpi2.0 (18615) STDERR:
          2024-10-02 09:52:57.280 - debug: rpi2.0 (18615) Got 4 from Raspberry Pi 4 Model B Rev 1.1.
          2024-10-02 09:52:57.281 - debug: rpi2.0 (18615) Inputs are pull down.
          2024-10-02 09:52:57.281 - debug: rpi2.0 (18615) Buttons are pull down.
          2024-10-02 09:52:57.281 - debug: rpi2.0 (18615) Got chip: undefined
          2024-10-02 09:52:57.281 - debug: rpi2.0 (18615) GPIO chip undefined initialized
          2024-10-02 09:52:57.281 - debug: rpi2.0 (18615) Port 5 direction: out
          2024-10-02 09:52:57.282 - error: rpi2.0 (18615) Cannot initialize/setMode GPIO: TypeError: Cannot read properties of undefined (reading 'output')
          Got chip: undefined, GPIO chip undefined initialized ????
          Das komplette Log ist recht groß, kann es bei Bedarf natürlich zur Verfügung stellen, z.B. per Mail
          Ich würde mir ebenfalls wünschen, dass der rpi2-Adapter in seiner bisherigen Funktionalität weiter lebt und kann sicher in der nächsten Zeit auch wieder mehr testen.
          Danke für die Arbeit am / mit dem Adapter!
          smartboart 1 Reply Last reply Reply Quote 0
          • smartboart
            smartboart @jrgsch last edited by smartboart
            ich schliesse mich da an. hier mein log... Meine Poolsteuerung ist seit dem System Update ebnefalls tod. Auch nach update auf Version 2.0.0. Aber die Saison ist auch rum also noch bissi zeit...
            Outputs werden garnicht angezeigt im Log.
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v20.17.0
            v20.17.0
            10.8.2
            rpi2.0
            	2024-10-04 02:41:06.492	error	Cannot initialize/setMode GPIO: TypeError: Cannot read properties of undefined (reading 'output')
            rpi2.0
            	2024-10-04 02:41:06.491	debug	Port 5 direction: outhigh
            rpi2.0
            	2024-10-04 02:41:06.491	debug	GPIO chip undefined initialized
            rpi2.0
            	2024-10-04 02:41:06.490	debug	Got chip: undefined
            rpi2.0
            	2024-10-04 02:41:06.490	debug	Buttons are pull down.
            rpi2.0
            	2024-10-04 02:41:06.490	debug	Inputs are pull down.
            rpi2.0
            	2024-10-04 02:41:06.489	debug	Got 4 from Raspberry Pi 4 Model B Rev 1.2
            pi2.0
            	2024-10-04 02:49:35.908	debug	STDERR:
            rpi2.0
            	2024-10-04 02:49:35.907	debug	CPU Info: Raspberry Pi 4 Model B Rev 1.2
            rpi2.0
            	2024-10-04 02:49:35.653	debug	Creating gpio.26.isInput
            rpi2.0
            	2024-10-04 02:49:35.633	debug	Creating gpio.25.isInput
            rpi2.0
            	2024-10-04 02:49:35.612	debug	Creating gpio.24.isInput
            rpi2.0
            	2024-10-04 02:49:35.592	debug	Creating gpio.23.isInput
            rpi2.0
            	2024-10-04 02:49:35.368	debug	Creating gpio.21.isInput
            rpi2.0
            	2024-10-04 02:49:35.345	debug	Creating gpio.20.isInput
            rpi2.0
            	2024-10-04 02:49:35.326	debug	Creating gpio.19.isInput
            rpi2.0
            	2024-10-04 02:49:35.306	debug	Creating gpio.18.isInput
            rpi2.0
            	2024-10-04 02:49:35.078	debug	Creating gpio.16.isInput
            rpi2.0
            	2024-10-04 02:49:35.059	debug	Creating gpio.15.isInput
            rpi2.0
            	2024-10-04 02:49:35.037	debug	Creating gpio.14.isInput
            rpi2.0
            	2024-10-04 02:49:35.016	debug	Creating gpio.13.isInput
            rpi2.0
            	2024-10-04 02:49:34.994	debug	Creating gpio.12.isInput
            rpi2.0
            	2024-10-04 02:49:34.971	debug	Creating gpio.11.isInput
            rpi2.0
            	2024-10-04 02:49:34.950	debug	Creating gpio.10.isInput
            rpi2.0
            	2024-10-04 02:49:34.919	debug	Creating gpio.9.isInput
            rpi2.0
            	2024-10-04 02:49:34.609	debug	Creating gpio.7.isInput
            rpi2.0
            	2024-10-04 02:49:34.581	debug	Creating gpio.6.isInput
            rpi2.0
            	2024-10-04 02:49:34.547	debug	Creating gpio.5.isInput
            • smartboart
              smartboart @smartboart last edited by smartboart
              vlt. als Hinweis...
              An meinem Wallmount Raspi verarbeite ich die GPIO mittels Pythonm Script und übertrage / empfange Befehle mittels MQTT.
              Hierbei verwende ich gpiozero welches mit dem neuen OS funktioniert.
              Import wie gehabt als BCM Nummer..
              Wenn der Adapter nicht mehr ans laufen kommt, bleibt mir wohl nix anderes übrig als die Poolsteuerung ebenfalls so umzustricken.
              Der Adapter wäre mir aber lieber weil ich sonst auch meine Logic Scripte und die Vis umbauen müsste.
              Hier ein kleiner Auszug..
              # -*- coding: utf-8 -*-
              import sys
              import logging
              import time
              import threading
              import subprocess
              from gpiozero import Button, LED
              import paho.mqtt.client as mqtt
              import psutil
              import json
              import os
              # Konfiguration
              SHUTOFF_DELAY = 180  # Sekunden
              long_press_threshold = 0.5  # Schwellenwert für langen Tastendruck in Sekunden
              long_press_active = False   # Variable, um den Status des langen Tastendrucks zu verfolgen
              press_start_time = 0        # Zeitstempel, um die Startzeit des Tastendrucks zu speichern
              turned_off = False
              last_motion_time = time.time()
              mqtt_broker_host = "192.168.xx.xx"  # MQTT-Broker-Host eintragen
              mqtt_port = 1883  # MQTT-Port eintragen
              mqtt_username = "adi"  # MQTT-Benutzername eintragen (falls erforderlich)
              mqtt_password = "gti"  # MQTT-Passwort eintragen (falls erforderlich)
              mqtt_topic_status = "Raspi-Wall.Wohnzimmer_Kamin.GPIO.Licht"  # MQTT-Topic fuer den Status eintragen
              mqtt_topic_status2 = "Raspi-Wall.Wohnzimmer_Kamin.GPIO.Netzteil"  # MQTT-Topic fuer den Status Netzteil eintragen
              mqtt_topic_motion = "Raspi-Wall.Wohnzimmer_Kamin.GPIO.Pir"  # MQTT-Topic fuer Bewegungserkennung
              mqtt_topic_taster = "Raspi-Wall.Wohnzimmer_Kamin.GPIO.Taster"  # MQTT-Topic fuer den Taster
              mqtt_topic_CPUTEMP = "Raspi-Wall.Wohnzimmer_Kamin.CPU.Temperatur"  # MQTT-Topic fuer den CPU Temp
              mqtt_topic_CPULAST = "Raspi-Wall.Wohnzimmer_Kamin.CPU.Auslastung"  # MQTT-Topic fuer den CPU Last
              # GPIO-Pin-Konfiguration
              TASTER_PIN = 18  # GPIO-Pin BCM 18 fuer den Taster - Licht
              RELAIS_PIN = 17  # GPIO-Pin BCM 17 fuer das Relais - Licht
              RELAIS_PIN2 = 26  # GPIO-Pin BCM 26 fuer das Relais - Netzteil Touchscreen
              PIR_PIN = 6  # GPIO-Pin BCM 6 fuer den Bewegungsmelder
              # GPIO-Initialisierung
              taster = Button(TASTER_PIN, pull_up=False)
              relais = LED(RELAIS_PIN)
              Display = LED(RELAIS_PIN2)
              pir = Button(PIR_PIN, pull_up=False)
              # Pfad zur Logdatei
              log_file_path = '/home/pi/Scripte/MQTT_Motion.log'
              • Garfonso
                Garfonso Developer @Garfonso last edited by Garfonso
                @garfonso
                Es gibt eine neue Version, 2.1.1. Die sollte im beta feed auftauchen, oder halt mit dem Befehl im ersten Post direkt installieren (das geht ab jetzt).
                Ich hoffe, dass damit die undefined Fehler gelöst sind und GPIO grundsätzlich Funktioniert. Bitte testen.
                Falls es Fehler bei der Installation gibt, bitte auch hier melden. Aber auch das Problem hab ich jetzt hoffentlich in den Griff bekommen (das machen wir dann wieder auf, sobald wir auf die opengio-Version umstellen, die auch Pullup/Pulldown usw. kann flöt)
                L S R J 5 Replies Last reply Reply Quote 2
                  Laser @Garfonso last edited by Laser
                  @garfonso Heute habe ich den Adapter auf dem Testsystem installiert. Klappt ohne Fehlermeldungen. (Raspi4). Ein und Ausgänge funktionieren. Jetzt habe ich auf dem Hauptsystem alle Betriebsystem- Updates gemacht, die ich bis dahin ausgesetzt habe. (Vorsichtshalber einen Clone der SD erzeugt). Auch hier klappt Alles.
                  Super Arbeit! Die GPIO's sind doch für Einige wichtig. Danke, daß Du dich so ins Zeug gelegt hast! Wenn jeder seine Wurstel- Lösung gesucht und gefunden hätte. wäre das nicht so toll.
                    @garfonso
                    Herzlichen Glückwunsch und vielen Dank für Eure Mühe. Ich habe die Version 2.1.1 ohne Probleme auf einem Raspi 4 und auf einem Raspi 5 installiert. Es funktioniert alles wie früher!👍 😁
                      ralfheitz @Garfonso last edited by
                      @garfonso Vielen vielen Dank für die tolle Arbeit! Ich schätze dies wirklich sehr, zumal ich gerade erst unsere Haussteuerung mit dem Raspi 5 und einer Relais-Karte verbinden wollte und dann gemerkt hatte, dass die GPIOs mit dem alten Adapter nicht mehr funktionieren. Ich habe es jetzt mit der neusten Version 2.1.2 getestet und es funktioniert einwandfrei. Daher nochmals tausend Dank!
                        @garfonso
                        @garfonso
                        Eine Frage habe ich doch noch. Ich benutze die GPIO 17 und 22 als Eingänge, das funktioniert wieder. Aber seit ich das Update vorgenommen habe, funktionieren die GPIO 14 und 15, die ich als seriellen Eingang zum Auslesen des Stromzählers nutze, nicht mehr. Es wird nämlich die Schnittstelle /dev/ttyS0 beim SMARTMETER- Adapter nicht mehr angezeigt. Kann das mit Deinen Änderungen zu tun haben? Ansonsten müsste ich einen 2. Raspi ohne Deine Änderungen daneben betreiben.
                        J Garfonso 2 Replies Last reply Reply Quote 0
                          JanGa @searcher57 last edited by
                          @searcher57 ansonsten könntest du auch einen USB auf seriell Adapter verwenden. Wäre einfacher als ein zweites Gerät.
                          • Garfonso
                            Garfonso Developer @searcher57 last edited by
                            @searcher57
                            Wenn die GPIOs im Adapter nicht konfiguriert sind "sollte" der Adapter sich da auch nicht einmischen. Oder geht das über den Adapter irgendwie?
                            Ging das denn vorher auf Bookworm?
                            Es gibt system-tools um mit den gpios zu reden. Vielleicht kommst du damit irgendwie weiter... ehrlich gesagt hab ich da nicht wirklich viel Ahnung. 😉
                              searcher57 @JanGa last edited by
                              @janga said in Test Adapter rpi2 2.x:
                              Ja, das ist mir schon vorher gesagt worden. Das würde aber wieder einen neuen Lesekopf mit USB Anschluss bestellen (den 3.). Ein Raspi 4 habe noch!
                                @searcher57
                                Ja, bis heute Mittag ging das. Ich komme wahrscheinlich nicht umhin den Vorschlag von @janga anzunehmen.
                                  @searcher57
                                  Was bedeuten denn eigentlich die unteren beiden Auswahlmöglichkeiten?
                                    @searcher57 das sind Temperatur/ Luftfeuchtigkeitssensoren.
                                    Du brauchst keinen neuen Lesekopf, nur den Adapter. Kann da bei Bedarf mal einen raussuchen.
                                    • Garfonso
                                      Garfonso Developer @searcher57 last edited by Garfonso
                                      @searcher57 said in Test Adapter rpi2 2.x:
                                      @searcher57
                                      Ok, dann musst du mir erklären, das du genau tust und was nun nicht mehr geht. Also, z.B.
                                      1. Welche Adapter Version war "heute Mittag" noch im Einsatz?
                                      2. Welches Betriebssystem (z.B. Raspain Bookworm)? (z.B. rausfinden über die Kommandozeile mit cat /etc/os-release)
                                      3. Was sind die Einstellungen für die GPIOs? Eingang? Spielt entprellen da eine Rolle?
                                      4. Was heißt "funktioniert nicht mehr"?
                                      Wenn es vorher ging und jetzt nicht mehr, wird da bestimmt was mit zu tun haben. Da stellt sich dann die frage, ob es wieder funktionieren kann, oder nicht. 😉 Insbesondere, wenn das vorher mit der 1.x war und du nicht auf Bookworm bist, kann das damit zusammenhängen.
                                      @searcher57
                                      DHT11 bzw. DHT22 kenne ich als Temperatur- und Feuchtigkeitssensoren. Im Grunde werden die GPIOs an diese Library weiter gereicht und die Werte regelmäßig ausgelesen (vermute ich). Ob das noch funktioniert, oder nicht, weiß ich nicht. Da geht es mir etwas wie mit dem Support für "Button" (gab es früher als Einstellung), da wäre für mich erstmal interessant, wie viele das wirklich nutzen und was damit gemacht wird, um zu sehen, wie viel Energie ich da rein stecken soll oder ob es nicht anders einfacher geht.
                                        @garfonso
                                        Ich habe heute ebenfalls den Adapter upgedatet und bin begeistert. Ein- und Ausgänge funktionieren.
                                        Danke, dass du nicht aufgegeben hast, dich um die GPIO's zu kümmern. Für mich und wohl einige andere auch, ist der RasPi vor allem wegen der GPIO's interessant. Ich betreibe z.B. ein komplexes Bewässerungssystem mit 10 Magnetventilen, Pumpen etc., die vom RasPi gesteuert werden, der wiederum als Slave in den ioBroker eingebunden ist.
                                        • Garfonso
                                          @garfonso
                                          Gute Neuigkeiten für alle mutigen Tester, gibt was neues zu tun... hust Ich hatte gestern und heute was Zeit und hab die Konfigurationsseite auf das neue jsonConfig System umgearbeitet. Dafür musste ich auch relativ tief in den Adapter eingreifen und die alte Konfiguration bei bedarf übersetzen.
                                          Der Adapter startet nach dem Update noch einmal mit der neuen Konfig neu. Bei meinen Tests hier ging das alles sauber. Es gibt jetzt auf der GPIO Seite keine lange Liste mehr, sondern eine Tabelle, die nur anzeigt, was auch konfiguriert ist. Auch das wurde bei mir korrekt übernommen.
                                          Bitte mal die 2.2.0 testen. 🙂 (wer sicher gehen will, dass nichts kaputt geht, vorher die Konfiguration mit dem Admin exportieren, das sind die zwei Knöpfe rechts oben)
                                            @garfonso Installieren kann ich (Version 2.2.0 manuell eingegeben), Ansicht wird die Neue, aber der Adapter startet nicht (linkes eigentlich grün werdendes Feld bleibt rotes Rad).
                                            Werde den Adapter löschen und nochmal neu installieren.
                                            EDIT: geht nicht? Bzw. bleibt in der Instanzübersicht rot (Rad).
                                            RAM Nutzung wird auch mit 0 MB angezeigt.
                                            2.1.2 hat funktioniert.
                                            otto@neuheizung:~ $ cat /etc/os-release
                                            PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
                                            NAME="Debian GNU/Linux"
                                            VERSION_ID="12"
                                            VERSION="12 (bookworm)"
                                            VERSION_CODENAME=bookworm
                                            ID=debian
                                            HOME_URL="https://www.debian.org/"
                                            SUPPORT_URL="https://www.debian.org/support"
                                            BU
                                            GPIO's Entprellen: 100mSec
                                            519
                                            145400
