    4. Test Adapter rpi2 2.x
      searcher57 @searcher57 last edited by
      @searcher57 said in Test Adapter rpi2 2.x:
      @garfonso said in Test Adapter rpi2 2.x:
      gpioinfo
      Ich habe die neueste Version RPI2 soeben aktualisiert. Außerdem habe ich die Eingänge GPIO14 und 15 deaktiviert. Und hier die Ausgabe :
      pi@Raspi58GB:~ $ gpioinfo
      gpiochip0 - 54 lines:
              line   0:     "ID_SDA"       unused   input  active-high
              line   1:     "ID_SCL"       unused   input  active-high
              line   2:      "GPIO2"       unused   input  active-high
              line   3:      "GPIO3"       unused   input  active-high
              line   4:      "GPIO4"       unused   input  active-high
              line   5:      "GPIO5"       unused   input  active-high
              line   6:      "GPIO6"       unused   input  active-high
              line   7:      "GPIO7"       unused   input  active-high
              line   8:      "GPIO8"       unused   input  active-high
              line   9:      "GPIO9"       unused   input  active-high
              line  10:     "GPIO10"       unused   input  active-high
              line  11:     "GPIO11"       unused   input  active-high
              line  12:     "GPIO12"       unused   input  active-high
              line  13:     "GPIO13"       unused   input  active-high
              line  14:     "GPIO14"       unused   input  active-high
              line  15:     "GPIO15"       unused   input  active-high
              line  16:     "GPIO16"       unused   input  active-high
              line  17:     "GPIO17" "opengpio_4_17_watch" input active-high [used]
              line  18:     "GPIO18"       unused   input  active-high
              line  19:     "GPIO19"       unused   input  active-high
              line  20:     "GPIO20"       unused   input  active-high
              line  21:     "GPIO21"       unused   input  active-high
              line  22:     "GPIO22" "opengpio_4_22_watch" input active-high [used]
              line  23:     "GPIO23"       unused   input  active-high
              line  24:     "GPIO24"       unused   input  active-high
              line  25:     "GPIO25"       unused   input  active-high
              line  26:     "GPIO26"       unused   input  active-high
              line  27:     "GPIO27"       unused   input  active-high
              line  28: "PCIE_RP1_WAKE" unused input active-high
              line  29:   "FAN_TACH"       unused   input  active-high
              line  30:   "HOST_SDA"       unused   input  active-high
              line  31:   "HOST_SCL"       unused   input  active-high
              line  32:  "ETH_RST_N"  "phy-reset"  output   active-low [used]
              line  33:          "-"       unused   input  active-high
              line  34: "CD0_IO0_MICCLK" "cam0_reg" output active-high [used]
              line  35: "CD0_IO0_MICDAT0" unused input active-high
              line  36: "RP1_PCIE_CLKREQ_N" unused input active-high
              line  37:          "-"       unused   input  active-high
              line  38:    "CD0_SDA"       unused   input  active-high
              line  39:    "CD0_SCL"       unused   input  active-high
              line  40:    "CD1_SDA"       unused   input  active-high
              line  41:    "CD1_SCL"       unused   input  active-high
              line  42: "USB_VBUS_EN" unused output active-high
              line  43:   "USB_OC_N"       unused   input  active-high
              line  44: "RP1_STAT_LED" "PWR" output active-low [used]
              line  45:    "FAN_PWM"       unused   input  active-high
              line  46: "CD1_IO0_MICCLK" "cam1_reg" output active-high [used]
              line  47:  "2712_WAKE"       unused   input  active-high
              line  48: "CD1_IO1_MICDAT1" unused input active-high
              line  49: "EN_MAX_USB_CUR" unused output active-high
              line  50:          "-"       unused   input  active-high
              line  51:          "-"       unused   input  active-high
              line  52:          "-"       unused   input  active-high
              line  53:          "-"       unused   input  active-high
      gpiochip10 - 32 lines:
              line   0:          "-"       unused   input  active-high
              line   1: "2712_BOOT_CS_N" "spi10 CS0" output active-low [used]
              line   2: "2712_BOOT_MISO" unused input active-high
              line   3: "2712_BOOT_MOSI" unused input active-high
              line   4: "2712_BOOT_SCLK" unused input active-high
              line   5:          "-"       unused   input  active-high
              line   6:          "-"       unused   input  active-high
              line   7:          "-"       unused   input  active-high
              line   8:          "-"       unused   input  active-high
              line   9:          "-"       unused   input  active-high
              line  10:          "-"       unused   input  active-high
              line  11:          "-"       unused   input  active-high
              line  12:          "-"       unused   input  active-high
              line  13:          "-"       unused   input  active-high
              line  14:   "PCIE_SDA"       unused   input  active-high
              line  15:   "PCIE_SCL"       unused   input  active-high
              line  16:          "-"       unused   input  active-high
              line  17:          "-"       unused   input  active-high
              line  18:          "-"       unused   input  active-high
              line  19:          "-"       unused   input  active-high
              line  20:   "PWR_GPIO" "pwr_button"   input   active-low [used]
              line  21: "2712_G21_FS" unused input active-high
              line  22:          "-"       unused   input  active-high
              line  23:          "-"       unused   input  active-high
              line  24:     "BT_RTS"       unused   input  active-high
              line  25:     "BT_CTS"       unused   input  active-high
              line  26:     "BT_TXD"       unused   input  active-high
              line  27:     "BT_RXD"       unused   input  active-high
              line  28:      "WL_ON"  "wl_on_reg"  output  active-high [used]
              line  29:      "BT_ON"   "shutdown"  output  active-high [used]
              line  30: "WIFI_SDIO_CLK" unused input active-high
              line  31: "WIFI_SDIO_CMD" unused input active-high
      gpiochip11 - 4 lines:
              line   0: "WIFI_SDIO_D0" unused input active-high
              line   1: "WIFI_SDIO_D1" unused input active-high
              line   2: "WIFI_SDIO_D2" unused input active-high
              line   3: "WIFI_SDIO_D3" unused input active-high
      gpiochip12 - 17 lines:
              line   0:    "RP1_SDA"       unused   input  active-high
              line   1:    "RP1_SCL"       unused   input  active-high
              line   2:    "RP1_RUN" "RP1 RUN pin" output active-high [used]
              line   3: "SD_IOVDD_SEL" "vdd-sd-io" output active-high [used]
              line   4:  "SD_PWR_ON" "sd_vcc_reg"  output  active-high [used]
              line   5:  "SD_CDET_N"         "cd"   input   active-low [used]
              line   6:   "SD_FLG_N"       unused   input  active-high
              line   8:  "2712_WAKE"       unused   input  active-high
              line   9: "2712_STAT_LED" "ACT" output active-low [used]
              line  12:   "PMIC_INT"       unused   input  active-high
              line  13: "UART_TX_FS"       unused   input  active-high
              line  14: "UART_RX_FS"       unused   input  active-high
              line  15:          "-"       unused   input  active-high
      gpiochip13 - 6 lines:
              line   0:  "HDMI0_SCL"       unused   input  active-high
              line   1:  "HDMI0_SDA"       unused   input  active-high
              line   2:  "HDMI1_SCL"       unused   input  active-high
              line   3:  "HDMI1_SDA"       unused   input  active-high
              line   4:   "PMIC_SCL"       unused   input  active-high
              line   5:   "PMIC_SDA"       unused   input  active-high
      gpiochip14 - 7 lines:
              line   0:      unnamed       unused   input  active-high
              line   1:      unnamed       unused   input  active-high
              line   2:      unnamed       unused   input  active-high
              line   3:      unnamed       unused   input  active-high
              line   4:      unnamed       unused   input  active-high
              line   5:      unnamed       unused   input  active-high
              line   6:      unnamed       unused   input  active-high
      Wenn ich Dich richtig verstehe, dann müsste doch auch gpiochip15 aufgeführt sein, oder...?
        Laser @searcher57 last edited by
        @searcher57 ich möchte jetzt mein halbwegs funktionierendes System nicht zerschießen. Was benötige ich , um die GPIO- Kommandos auszuführen? ZB. gpioinfo?
        Homoran S 2 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @Laser last edited by
          @laser sagte in Test Adapter rpi2 2.x:
          einen Raspi und ein Terminal 😁
            Laser @Homoran last edited by
            @homoran toller Tip!
            gpioinfo
            -bash: gpioinfo: command not found
              Thomas Braun Most Active @Laser last edited by
              @laser
              Das Paket nennt sich
              gpiod
              • Garfonso
                Garfonso Developer @Laser last edited by
                @laser
                kannst du da ein debug log geben?
                  @thomas-braun sagte in Test Adapter rpi2 2.x:
                  @laser
                  gpiod
                  dann hat @laser noch nicht den bookworm "patch"?
                  dann würde ich an seiner Stelle das Paket nicht installieren.
                    @homoran einen bookworm "patch" habe ich nicht wissentlich installiert.
                      searcher57 @Laser last edited by
                      @laser said in Test Adapter rpi2 2.x:
                      Aber das war das doch, oder...)
                        @searcher57 die Antworten sind immer sehr kurz formuliert. Kann ich so nicht verstehen.
                        S Thomas Braun 2 Replies Last reply Reply Quote 0
                          Ich habe doch oben die Ausgabe von gpioinfo gegeben.
                            Laser last edited by Laser
                            @searcher57 ja, aber ich kann den Befehl "gpioinfo" nicht ausführen. Den gibt es bei mir nicht.
                              @laser
                              sudo apt update && apt policy gpiod
                                Ja und was brauchst Du dann?
                                  Laser @searcher57 last edited by Laser
                                  und das ist der bookworm- patch?
                                  @searcher57 Das weiß ich eben nicht, was ich installieren muß, um den Befehl zu bekommen.
                                    @laser
                                    Das ist das Paket, welche das Kommando gpioinfo beinhaltet.
                                      Laser @Thomas Braun last edited by
                                      @thomas-braun habe ich ausgeführt, aber:
                                      gpioinfo
                                      Thomas Braun S 2 Replies Last reply Reply Quote 0
                                        Zeigen.
                                          gpioinfo
                                          Na dann merke ic endlich, daß auch bei Euch Uneinigkeit besteht!😁
                                            Laser @Thomas Braun last edited by Laser
                                            Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                            Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                                            Hit:5 https://packages.grafana.com/enterprise/deb stable InRelease
                                            Hit:6 https://repos.influxdata.com/debian stable InRelease
                                            Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                                            Reading package lists... Done
                                            Building dependency tree... Done
                                            1 package can be upgraded. Run 'apt list --upgradable' to see it.
                                            W: https://packages.grafana.com/enterprise/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                                            gpiod:
                                              Installed: (none)
                                              Candidate: 1.6.3-1+b3
                                              Version table:
                                                 1.6.3-1+b3 500
                                            otto@neuheizung:/dev $ gpioinfo
                                            519
                                            145646
