    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Shellys per mqtt keine Verbindung
      Accuface @Homoran last edited by Accuface
      @homoran said in Shellys per mqtt keine Verbindung:
      @accuface sagte in Shellys per mqtt keine Verbindung:
      keine Shellys per MQTT
      zusätzlich zum shelly Adapter?
      bitte iob diag in der Langfassung posten
      Skript v.2024-08-12
      *** BASE SYSTEM ***
      ```bash
      Skript v.2024-08-12
      *** BASE SYSTEM ***
       Static hostname: raspberrypi5
             Icon name: computer
                Kernel: Linux 6.6.47+rpt-rpi-2712
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 5 Model B Rev 1.0
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       20:25:12 up  1:04,  2 users,  load average: 0.88, 0.43, 0.28
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Tue 2024-10-15 20:25:12 CEST
                 Universal time: Tue 2024-10-15 18:25:12 UTC
                       RTC time: Tue 2024-10-15 18:25:12
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      Bernd
      HOME=/home/Bernd
      GROUPS=Bernd adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            8.4G        1.7G        5.9G        5.4M        993M        6.7G
      Swap:           209M          0B        209M
      Total:          8.7G        1.7G        6.1G
      Active iob-Instances:   22
               8052 M total memory
               1621 M used memory
               1479 M active memory
                726 M inactive memory
               5585 M free memory
                101 M buffer memory
                845 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      top - 20:25:12 up  1:04,  2 users,  load average: 0.88, 0.43, 0.28
      Tasks: 180 total,   1 running, 179 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8052.3 total,   5585.5 free,   1621.4 used,    947.4 buff/cache
      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6430.9 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  3.8G     0  3.8G   0% /dev
      tmpfs          tmpfs     806M  5.2M  801M   1% /run
      /dev/mmcblk0p2 ext4       29G  7.1G   21G  26% /
      tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
      tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
      [Tue Oct 15 19:20:45 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:56:18:0A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=8959849a-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
      [Tue Oct 15 19:20:48 2024] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
      [Tue Oct 15 19:20:49 2024] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      884M    /var/
      265M    /var/log/journal/9ba9919aad384e6eaaa1e9cb2eaa4832
      265M    /var/log
      252M    /var/cache
      Archived and active journals take up 264.6M in the file system.
      /opt/iobroker/backups:
      41M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.4G    /opt/iobroker/iobroker-data/
      1.3G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.0
      /usr/bin/node           v20.18.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.18.0-1nodesource1
        Candidate: 20.18.0-1nodesource1
        Version table:
       *** 20.18.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.1.5
      javascript:     8.8.3
      nodejs modules from github:     1
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi5                             -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi5                             -  enabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi5                             - disabled
      + system.adapter.echarts.0                : echarts               : raspberrypi5                             -  enabled
        system.adapter.feiertage.0              : feiertage             : raspberrypi5                             - disabled
      + system.adapter.fronius-solarweb.0       : fronius-solarweb      : raspberrypi5                             -  enabled
      + system.adapter.fronius.0                : fronius               : raspberrypi5                             -  enabled
      + system.adapter.fronius.1                : fronius               : raspberrypi5                             -  enabled
      + system.adapter.history.0                : history               : raspberrypi5                             -  enabled
        system.adapter.ical.0                   : ical                  : raspberrypi5                             -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi5                             -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypi5                             -  enabled
        system.adapter.iqontrol.0               : iqontrol              : raspberrypi5                             - disabled
      + system.adapter.jarvis.0                 : jarvis                : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.javascript.0             : javascript            : raspberrypi5                             -  enabled
        system.adapter.ping.0                   : ping                  : raspberrypi5                             - disabled
      + system.adapter.scenes.0                 : scenes                : raspberrypi5                             -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sql.0                    : sql                   : raspberrypi5                             -  enabled
      + system.adapter.synology.0               : synology              : raspberrypi5                             -  enabled, port: 5000
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi5                             -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi5                             -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi5                             -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi5                             -  enabled
        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: raspberrypi5                             -  enabled
        system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: raspberrypi5                             -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi5                             -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : raspberrypi5                             -  enabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi5                             -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi5                             -  enabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi5                             -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi5                             -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi5                             - disabled
      + system.adapter.web.0                    : web                   : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi5                             -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.22 [Updatable]
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "fronius"      : 2.1.1    , installed 2.1.1
      Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
      Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
      Adapter    "vis-2-widgets-jaeger-design": 1.2.7, installed 1.2.7
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        5608
      States:         4481
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5626       777/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       7833       1181/io.jarvis.0
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6380       766/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7383       766/iobroker.js-con
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       43171      1414/io.shelly.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       7749       1136/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7422       812/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          5628       777/sshd: /usr/sbin
      udp        0      0 0.0.0.0:48252           0.0.0.0:*                           104        6279       655/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6277       655/avahi-daemon: r
      udp6       0      0 :::60397                :::*                                104        6280       655/avahi-daemon: r
      udp6       0      0 fe80::dc25:f03d:c31:546 :::*                                0          6638       738/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        6278       655/avahi-daemon: r
      2024-10-15 20:25:25.325  - debug: shelly.0 (1414) [MQTT] Publish: 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1) - topic: shellyplus1pm-b0b21c1b4e14/events/rpc, qos: 1, payload: {"src":"shellyplus1pm-b0b21c1b4e14","dst":"shellyplus1pm-b0b21c1b4e14/events","method":"NotifyStatus","params":{"ts":1729016724.29,"switch:0":{"id":0,"apower":3.9}}}
      2024-10-15 20:25:25.340  - debug: shelly.0 (1414) [MQTT] Publish: 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1) - topic: shellyplus1pm-b0b21c1b4e14/status/switch:0, qos: 1, payload: {"id":0, "source":"SHC", "output":true, "apower":4.5, "voltage":228.5, "current":0.047, "aenergy":{"total":550.191,"by_minute":[71.439,80.471,65.280],"minute_ts":1729016700},"temperature":{"tC":54.1, "tF":129.4}}
      2024-10-15 20:25:25.340  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.Power, value: 4.5
      2024-10-15 20:25:25.341  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.Voltage, value: 228.5
      2024-10-15 20:25:25.341  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.Current, value: 0.047
      2024-10-15 20:25:25.341  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.Energy, value: 550.191
      2024-10-15 20:25:26.819  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.31 (shellyplus1 / shellyplus1-e465b8f46ac4 / shellyplus1#e465b8f46ac4#1): state: shellyplus1#e465b8f46ac4#1.uptime, value: 1238126
      2024-10-15 20:25:26.844  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.63 (shellyplus1pm / shellyplus1pm-10061ccb9fc0 / shellyplus1pm#10061ccb9fc0#1): state: shellyplus1pm#10061ccb9fc0#1.uptime, value: 775665
      2024-10-15 20:25:27.125  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.26 (shellyplus1pm / shellyplus1pm-fcb46727891c / shellyplus1pm#fcb46727891c#1): state: shellyplus1pm#fcb46727891c#1.uptime, value: 1238125
      2024-10-15 20:25:27.179  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.39 (shellyplus1pm / shellyplus1pm-10061ccb0c48 / shellyplus1pm#10061ccb0c48#1): state: shellyplus1pm#10061ccb0c48#1.uptime, value: 1238125
      2024-10-15 20:25:27.179  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.39 (shellyplus1pm / shellyplus1pm-10061ccb0c48 / shellyplus1pm#10061ccb0c48#1): state: shellyplus1pm#10061ccb0c48#1.rssi, value: -58
      2024-10-15 20:25:27.241  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.29 (shellyplus1 / shellyplus1-cc7b5c85af80 / shellyplus1#cc7b5c85af80#1): state: shellyplus1#cc7b5c85af80#1.uptime, value: 994761
      2024-10-15 20:25:27.261  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): state: shellyplus1pm#b0b21c1b4e14#1.uptime, value: 1238121
      2024-10-15 20:25:27.261  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): state: shellyplus1pm#b0b21c1b4e14#1.rssi, value: -73
      2024-10-15 20:25:31.322  - debug: shelly.0 (1414) [MQTT] Publish: 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1) - topic: shellyplus1pm-b0b21c1b4e14/events/rpc, qos: 1, payload: {"src":"shellyplus1pm-b0b21c1b4e14","dst":"shellyplus1pm-b0b21c1b4e14/events","method":"NotifyStatus","params":{"ts":1729016726.29,"switch:0":{"id":0,"apower":4.7}}}
      2024-10-15 20:25:31.332  - debug: shelly.0 (1414) [MQTT] Publish: 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1) - topic: shellyplus1pm-b0b21c1b4e14/status/switch:0, qos: 1, payload: {"id":0, "source":"SHC", "output":true, "apower":5.6, "voltage":228.4, "current":0.061, "aenergy":{"total":550.200,"by_minute":[71.439,80.471,65.280],"minute_ts":1729016700},"temperature":{"tC":54.0, "tF":129.3}}
      2024-10-15 20:25:31.332  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.temperatureC, value: 54
      2024-10-15 20:25:31.332  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.temperatureF, value: 129.3
      2024-10-15 20:25:31.332  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.Power, value: 5.6
      2024-10-15 20:25:31.332  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.Voltage, value: 228.4
      2024-10-15 20:25:31.332  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.Current, value: 0.061
      2024-10-15 20:25:31.332  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.Energy, value: 550.2
      2024-10-15 20:25:31.786  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.35 (shellyplus1pm / shellyplus1pm-d4d4daeb2ddc / shellyplus1pm#d4d4daeb2ddc#1): state: shellyplus1pm#d4d4daeb2ddc#1.uptime, value: 1238120
      2024-10-15 20:25:32.606  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.33 (shellyplus1pm / shellyplus1pm-cc7b5c0dd95c / shellyplus1pm#cc7b5c0dd95c#1): state: shellyplus1pm#cc7b5c0dd95c#1.uptime, value: 1238132
      2024-10-15 20:25:33.444  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.38 (shellyplus1pm / shellyplus1pm-d4d4da35853c / shellyplus1pm#d4d4da35853c#1): state: shellyplus1pm#d4d4da35853c#1.uptime, value: 1238128
      • Samson71
        Samson71 Global Moderator @Accuface last edited by
        @accuface
        Mal den 4. Haken im Shelly aktiviert? Soll angeblich egal sein, aber ich habe sie drin.
          Accuface @Samson71 last edited by
          @samson71 said in Shellys per mqtt keine Verbindung:
          @accuface
          hab ich vorhin getestet (Enable MQTT Control) haken gestzt oder nicht, ist egal. Klappt nicht
          A crunchip 2 Replies Last reply Reply Quote 0
            Accuface @Accuface last edited by
            Ich mache jetzt mal eins, ich werd den Pi3 nochmal in Betrieb nehmen, das OS neu Installieren, iob drauf und schauen ob es da funktioniert.
            Andere Frage: Kann ich meine erstellte VIS-2 irgendwie sichern, falls es auf dem 3er funktioniert und Ich auf dem PI5 alles neu machen muss?
            Samson71 crunchip 2 Replies Last reply Reply Quote 0
              crunchip Forum Testing Most Active @Accuface last edited by
              Klappt nicht
              Was genau klappt jetzt nicht?
              Shelly Gerät neu gestartet?
              Datenpunkte unter Objekte für den jeweiligen shelly mal löschen, Instanz vorher aber stoppen und debug modus kannst du auch wieder umstellen
              • Samson71
                @accuface
                Poste bitte nochmal die Einstellungen EINES Shelly, der aktuell tatsächlich funktioniert!
                  @accuface vis ist z. B. mit im Backup via backitup enthalten, die kann man sich dort herauholen
                    Accuface @crunchip last edited by
                    @crunchip said in Shellys per mqtt keine Verbindung:
                    Klappt nicht
                    das verbinden der Shellys per MQTT mit dem Shelly Adapter im iob.
                    nicht nur einmal, selbst wenn ich den eine Stunde vom Strom nehme, keine Chance
                    wie denn, wenn nur die "alten" Shellys drin sind, die neuen aber nicht auftauchen
                    mit alt meine ich die, was ich zuerst verbaut hatte und eingebunden hab in iob.
                    mit neu meine ich die Shellys, die ich erst letzte Woche verbaut habe und am Wochenende einbinden wollte.
                      Als guter Rat, erst verbinden und prüfen, anschließend verbauen
                      Ich dachte, die alten lassen sich nicht schalten
                      Und neu sich nicht einbinden
                      Aus deinem anderen Thread war dein Passwort falsch wegen groß /klein Schreibung
                        @accuface
                        so....jetzt bin ich komplett irritiert.
                        Im folgenden Bild ist der Kühlschrank zu sehen.
                        IP endet auf .56, wenn ich nun über die ios App in die einstellungen gehe, zeigt er mir die .35 an.
                        Client ID ist identisch.
                        Bild aus der App kommt gleich nach
                        • Samson71
                          Samson71 Global Moderator @Accuface last edited by Samson71
                          @accuface
                          Ich ahnte sowas irgendwie. Die Screenshots vom Brunnen im Eingang enden auf .27!
                          EDIT
                          Dein ioBroker müsste also die .56 haben
                            @accuface das ist die iobroker IP, die musst du logischerweise an deinen Geräten anpassen wenn du nun nen anderen Pi(mit anderer IP) im Betrieb hast
                              Es läuft hier aus dem Ruder. die alten funktionieren so wie sie sollen.
                              genau dass ist das Problem worum es geht.
                              Richtig, und danach liessen sich die alten einbinden. am wochenende wollte ich die neuen (sind mehrere) Verbinden und das geht nun nicht mehr.
                              Der Trinkbrunnen Felix war ja ein alter und vorher schon drin. Nachdem ich den am Sonntag rausgenommen (gelöscht aus den Objekten) liess auch er sich nicht mehr einbinden.
                              • Samson71
                                @accuface
                                Die die aktuell funktionieren müssen die IP Deines ioBroker haben. Die gehört in JEDEN Shelly damit er funktioniert.
                                  Ich glaub ich bin durch für heute, ich blick nicht mehr durch, ehrlich.
                                  Ich mach schluss für heute, das bringt nix
                                  • Samson71
                                    @accuface
                                    Ist doch ganz einfach. Es müssen alle Shellys die IP eingetragen bekommen die auch die haben, die aktuell funktionieren.
                                      @accuface
                                      ja ich weiss...dass ist auch so.
                                      Ich hab da gerade Äpfel mit Birnen verglichen. in der Weboberfläche muss natürlich die IP der iob stehen, gleichzeitig hab ich in der App nach der IP vom Kühlschrank gesehen, die natürlich die .35 ist.
                                      Sorry war mein Fehler.
                                      Ich mach jetzt Feierabend für heute
                                        @accuface dein laufender iobroker hat welche IP?
                                        Diese setzt du bei allen shelly bei mqtt setting bei server
                                        A 2 Replies Last reply Reply Quote 0
                                          192.168.178.56 ist die vom iob. Mir ist klar dass die beim MQTT rein muss.
                                            @accuface https://forum.iobroker.net/post/1209659
                                            Da scheint es dir aber nicht klar zu sein
                                            1.2k
                                            5292
