    4. Adapterliste leer
    Adapterliste leer
      MartyBr last edited by
      Ich habe das gleiche Problem.
      Hier die Screenshots:
      Ansicht Alle
      Ansicht Allgemein
      Hier die die Repos:
      martin@iobroker:/opt/iobroker$ iob repo show
      │ (index) │ name          │ url                                                     │ auto upgrade │
      │ 0       │ 'stable'      │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'beta'        │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      │ 2       │ 'live-stable' │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
      │ 3       │ 'live-beta'   │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
      Active repo(s): stable
      Upgrade policy: none
      Lob update:
      martin@iobroker:/opt/iobroker$ iob update
      Used repository: stable
      Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "alarm"        : 3.6.2    , installed 3.6.2
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "birthdays"    : 3.0.1    , installed 3.0.1
      Adapter    "bring"        : 1.8.4    , installed 1.8.4
      Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "doorbird"     : 1.7.0    , installed 2.0.0
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "email"        : 1.3.1    , installed 1.3.1
      Adapter    "energiefluss-erweitert": 0.4.1, installed 0.5.1-alpha.0
      Adapter    "epson_ecotank_et_2750": 0.0.12, installed 0.0.12
      Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
      Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "fullcalendar" : 2.4.2    , installed 2.4.5
      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
      Adapter    "geofency"     : 1.2.4    , installed 1.2.4
      Adapter    "harmony"      : 1.5.0    , installed 1.5.0
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
      Adapter    "homekit-controller": 0.5.10, installed 0.5.10
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "kostal-piko-ba": 4.2.0   , installed 4.2.0
      Adapter    "lightcontrol" : 0.8.0    , installed 1.0.1
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "logparser"    : 2.2.2    , installed 2.2.2
      Adapter    "lorawan"      : 1.4.2    , installed 1.4.2
      Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
      Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
      Adapter    "meteoalarm"   : 3.0.3    , installed 3.0.3
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "nina"         : 0.0.25   , installed 0.0.26
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "nuki"         : 2.0.0    , installed 2.0.0
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "odl"          : 3.0.1    , installed 3.0.1
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
      Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
      Adapter    "shuttercontrol": 1.8.2   , installed 1.8.2
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "smoothed"     : 1.1.0    , installed 1.1.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
      Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
      Adapter    "viessmannapi" : 2.3.0    , installed 2.4.0
      Adapter    "vis-2"        : 2.9.32   , installed 2.9.64
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
      Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "weather-warnings": 0.6.7 , installed 0.6.7
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "worx"         : 3.1.0    , installed 3.1.0
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
      Adapter    "zigbee2mqtt"  : 2.13.10  , installed 2.13.10
      Jörg Giencke 1 Reply Last reply Reply Quote 0
      • Jörg Giencke
        Jörg Giencke @MartyBr last edited by
        Da wir jetzt schon zu Dritt sind, würde ich vorschlagen, meine Fehlermeldung bei github zumindest mit einem 'Bei mir auch' zu untermauern, um den Druck ein wenig zu erhöhen.
        https://github.com/arteck/ioBroker.zigbee2mqtt/issues/386
        JoergGiencke created this issue in arteck/ioBroker.zigbee2mqtt
        closed Adapter interferes with iobroker's adapter list #386
          MartyBr @Jörg Giencke last edited by
          @jörg-giencke
          Hast du den Adapter in einer bestimmten Version neu installiert? Ich kann ihn über die Oberfläche nicht mehr anzeigen. Die Rubrik Hardware ist bei mir total leer.
          • Jörg Giencke
            Jörg Giencke @MartyBr last edited by Jörg Giencke
            @martybr Ich habe ihn in der neusten (2.13.6) und einer etwa zehn Monate alten Version (2.13.4) jeweils über die URL zum Source (tar.gz) installiert (über das Katzenicon). Beide Versionen zeigten dasselbe Verhalten. Merkwürdig, dass das niemandem in diesem Zeitraum aufgefallen ist.
            • Hunduster
              Hunduster last edited by
              Ich hab zigbee2mqtt letztes Wochenende ganz normal über die Adapterliste installiert. v2.13.6
              • Jörg Giencke
                Jörg Giencke @Hunduster last edited by Jörg Giencke
                Irgendetwas scheint mit der Adapterliste so oder so schief zu sein. Man beachte 'MQTT':
                  Ich habe die 2.13.10 installiert, welche ohne Probleme läuft.
                  Ich kann sie nicht downgraden. Auch über
                  npm install iobroker.zigbee2mqtt@2.13.8
                  funktioniert es nicht. Fehlermeldung: Keine entsprechende Version vorhanden.
                  Wenn ich das Repo auf "beta" schalte, dann funktioniert die Adapter Ansicht normal.
                  Ich vermute, dass Zigbee2mqtt nicht ordentlich in Stabile eingelockt ist. Das ist aber nur eine Vermutung, belegen können es nur die Fachleute.
                  Jörg Giencke 2 Replies Last reply Reply Quote 0
                  • Jörg Giencke
                    @martybr sagte in Adapterliste leer:
                    Wo hast Du die denn her? Auf github hört es bei 2.13.6 auf.
                    Jörg Giencke M 2 Replies Last reply Reply Quote 0
                    • Jörg Giencke
                      Jörg Giencke @Jörg Giencke last edited by
                      @jörg-giencke sagte in Adapterliste leer:
                      Ahh! Alles klar. Beta-Repository. Damit läuft bei mir auch wieder alles 'normal'.
                        @jörg-giencke
                        Die wurde ins Stabile veröffentlicht. Scheinbar ist sie zurückgezogen worden. Daher haben wir die Probleme.
                        Hunduster 1 Reply Last reply Reply Quote 0
                        • Hunduster
                          Hunduster @MartyBr last edited by
                          @martybr Welche wurde zurückgezogen und welche ist nun die letzte Stabel? Ich habe 2.13.6 und habe das Problem ja auch?!
                          • Jörg Giencke
                            Vielleicht mal 2.13.6 (die aktuellste 'offizielle') probieren?
                              @jörg-giencke
                              Ich habe gerade gesehen, dass du den Hinweis auf das Beta-Repository auf Github gepostet hast. Vielen Dank für die Kommunikation dazu.
                              Dann hoffen wir mal, dass das schnell gelesen und der Fehler behoben wird. 👍
                              • Jörg Giencke
                                @hunduster sagte in Adapterliste leer:
                                Die letzte ist 2.13.6.
                                  @jörg-giencke
                                  Habe ich mal installiert. Die Adapter Ansicht in Stable ist weiterhin leer. Da scheint irgendetwas vermurkst sein.
                                  Die letzte Idee ist, den Adapter inkl. Instant komplett entfernen und neu installieren.
                                  Ich hoffe, dass alle Geräte erhalten bleiben. Die müssten ja vom Zigbee2mqtt-Server neu gezogen werden.
                                  Was meinst du?
                                  • Jörg Giencke
                                    @jörg-giencke
                                    Was meinst du?
                                    A) Da wäre ich mir nicht so sicher.
                                    B) Welcher Zigbee2mqtt-Server?
                                      @jörg-giencke
                                      Die Zigbeegeräte sind an einem Server angemeldet/gepaired. In meinem Fall ist das ein eigener Server, auf dem die Anwendung Zigbee2mqtt läuft.
                                      • Jörg Giencke
                                        @martybr Außerdem bin ich mittlerweile recht sicher, dass das Chaos nicht vom Adapter selbst sondern vom fehlerhaften Repository verursacht wird. Mit dem Beta-Repository funktionier ja alles wie erwartet.
                                          Das ist ja auch meine Meinung.
                                            @mcm1957 @Homoran
                                            Könnt ihr die Probleme mit dem Stable Repository und Zigbee2MQTT bestätigen?
                                            Im Beta-Repository lädt die Adapter Ansicht ohne Probleme.
                                            79
                                            4343
