    3. Off Topic
    4. Grafana
    5. Grafana - Stromzähler nachbauen
    • Humidor
      Humidor @Meister Mopper last edited by
      @meister-mopper kannst mir bitte den code einstellen, sonst müsste ich ihne mühsam abtipseln 🙂
      • Meister Mopper
        Meister Mopper @Humidor last edited by Meister Mopper
        @humidor
        Hier das json zum importieren, da sind dann auch alle Formatierungen und overrides mit drin:
         "datasource": {
           "type": "influxdb",
           "uid": "000000001"
         "description": "",
         "fieldConfig": {
           "defaults": {
             "custom": {
               "lineWidth": 1,
               "fillOpacity": 80,
               "gradientMode": "none",
               "axisPlacement": "auto",
               "axisLabel": "",
               "axisColorMode": "text",
               "axisBorderShow": false,
               "scaleDistribution": {
                 "type": "linear"
               "axisCenteredZero": false,
               "hideFrom": {
                 "tooltip": false,
                 "viz": false,
                 "legend": false
               "thresholdsStyle": {
                 "mode": "off"
             "color": {
               "mode": "fixed",
               "fixedColor": "red"
             "mappings": [],
             "thresholds": {
               "mode": "absolute",
               "steps": [
                   "color": "green",
                   "value": null
                   "color": "red",
                   "value": 80
             "links": [],
             "min": 0,
             "unit": "kwatth"
           "overrides": [
               "matcher": {
                 "id": "byName",
                 "options": "Time"
               "properties": [
                   "id": "unit",
                   "value": "time: D dd"
         "gridPos": {
           "h": 7,
           "w": 12,
           "x": 12,
           "y": 27
         "hideTimeOverride": true,
         "id": 98,
         "interval": "1d",
         "options": {
           "orientation": "auto",
           "xTickLabelRotation": -90,
           "xTickLabelSpacing": 0,
           "showValue": "always",
           "stacking": "none",
           "groupWidth": 0.7,
           "barWidth": 0.7,
           "barRadius": 0,
           "fullHighlight": false,
           "tooltip": {
             "mode": "single",
             "sort": "none"
           "legend": {
             "showLegend": false,
             "displayMode": "list",
             "placement": "bottom",
             "calcs": []
         "pluginVersion": "8.5.1",
         "targets": [
             "datasource": {
               "type": "influxdb",
               "uid": "000000001"
             "groupBy": [
                 "params": [
                   "$__interval"
                 "type": "time"
                 "params": [
                   "null"
                 "type": "fill"
             "measurement": "0_userdata.0.Energie.PV.Netzbezug",
             "orderByTime": "ASC",
             "policy": "default",
             "query": "import \"timezone\"\r\noption location = timezone.location(name: \"Europe/Berlin\")\r\n\r\nfrom(bucket: \"iobroker\")\r\n  |> range(start: -1mo, stop: v.timeRangeStop)\r\n  |> filter(fn: (r) => r[\"_measurement\"] == \"smartmeter.0.1-0:1_8_0__255.value\" and r[\"_field\"] == \"value\")\r\n  |> difference()\r\n  |> aggregateWindow(every: 1d, fn: sum, timeSrc: \"_start\")",
             "refId": "A",
             "resultFormat": "time_series",
             "select": [
                   "params": [
                     "value"
                   "type": "field"
                   "params": [],
                   "type": "max"
             "tags": []
             "alias": "Direct self-use",
             "datasource": {
               "type": "influxdb",
               "uid": "000000001"
             "groupBy": [
                 "params": [
                   "$__interval"
                 "type": "time"
                 "params": [
                   "null"
                 "type": "fill"
             "hide": false,
             "measurement": "kWh",
             "refId": "B",
             "select": [
                   "params": [
                     "value"
                   "type": "field"
                   "params": [],
                   "type": "max"
             "tags": [
                 "key": "entity_id",
                 "operator": "=",
                 "value": "selfuse_energy_daily"
         "timeFrom": "1h",
         "title": "Tagesbezug (Monat)",
         "type": "barchart"
        Hier influx
        import "timezone"
        option location = timezone.location(name: "Europe/Berlin")
        from(bucket: "iobroker")
          |> filter(fn: (r) => r["_measurement"] == "smartmeter.0.1-0:1_8_0__255.value" and r["_field"] == "value")
          |> difference()
          |> aggregateWindow(every: 1d, fn: sum, timeSrc: "_start")
        Humidor 1 Reply Last reply Reply Quote 1
        • Humidor
          @meister-mopper sagte in Grafana - Stromzähler nachbauen:
          |> difference() |> aggregateWindow(every: 1d, fn: sum, timeSrc: "_start")
          OK, das kapier ich noch nicht
          woher stammt der "Spoiler"? iobroker oder grafana?
          wenn ich deine Influx Text (geändert auf meine Werte) eingebe, kommt mal nix
          • Meister Mopper
            @humidor sagte in Grafana - Stromzähler nachbauen:
            Das ist das json des dashboard von Grafana und kann in Grafana eingelesen werden.
            Humidor 1 Reply Last reply Reply Quote 0
            • Humidor
              Humidor @Meister Mopper last edited by Humidor
              @meister-mopper etwas weiter bin ich gekommen, habe dein dashboard eingelesen, darin ein panel geöffnet mit das query eingetragen
              (ist das richtig ein Panel zu öffnen, das ist auf std. Einstellungen)
              nun sehe ich diese Information
              • Meister Mopper
                Schau mal hier.
                Damit habe ich es hinbekommen.
                • Humidor
                  @meister-mopper super, danke, habs soweit kapiert
                  jetzt habe ich ein Problem mit den Daten
                  Alias - aus einem Mqtt Wert wird der aktuelle Wert (Leistung) entnommen
                  Alias - aus einem Mqtt Wert nur der Neg. Wert
                  Alias - aus einem Mqtt Wert nur der Pos. Wert
                  alle werden in die Influx eingetragen
                  wenn ich mir im ioBroker den Verlauf ansehe, sehe ich die jeweiligen Werte zBsp. bezogen auf 1 Tag
                  im Grafana mit der Summen Funktion, kommt dann irgendwas raus, auch Minuswerte??
                  • Meister Mopper
                    Tatsächlich kann ich nicht nachvollziehen, was du hier sagen möchtest. Meinst mit negativen Werten die Einspeisung?
                    Ich rechne alle Negativdaten in positive Werte um. Mit diesen Daten arbeite ich in Grafana,
                    • Humidor
                      @meister-mopper mache ich genauso, dh die neg. Werte werden in pos. Werte umgerechnet, es geht mir um die Summen wieviel Bezug bzw. Lieferung stattgefunden hat.
                      Aus pos. Werte wird im Grafana ein Minuswert erzeugt, völliger quatsch. Aber wo liegt der Fehler?
                      du siehst am Graph vom ioBroker die pos. Werte, da müsste im Grafana dann die Summe berechnet werden. Soweit klar, raus kommt aber unsinnige Werte und auch Minus.
                      • Meister Mopper
                        Okay, das sind zwei verschiedene Ausgangslagen und ein Missverständnis.
                        Ich visualisiere bei dem täglichen Verbrauch im letzten Monat sowohl für den Tagesbezug als auch den Tagesverbrauch anwachsende Datenpunkte (Stromzähler und selbst berechneter Verbrauchszähler).
                        • Humidor
                          @meister-mopper hmm
                          das ist dann das -1mo, wie sage ich ihm von 0:00 - 23:59? also 1 Tag?
                          und das summiert wird, ist aber
                          difference()
                          fn: sum oder nicht?
                          welche Rolle spielt das difference?
                          • Humidor
                            Humidor @Humidor last edited by
                            hätte ev. jemand die richtigen Settings um die den Wert im Grafana zu summieren?
                            mickemup 1 Reply Last reply Reply Quote 0
                            • mickemup
                              mickemup @Humidor last edited by
                              @humidor
                              Habe da einiges bei mir gemacht um solche Sachen darzustellen.
                              Um dir helfen zu können, muss man aber wissen wie (und wie oft du dir Rohdaten loggst.)
                              Sind es Leistungen oder Zählerstände?
                              Wenn du Leistungen aufsummieren willst, kommt es darauf an, wie oft du die loggst
                              difference()
                              Das hier macht nur Sinn, wenn du "Zählerstände loggst....
                              • Humidor
                                Humidor @mickemup last edited by Humidor
                                @mickemup danke dir!
                                das sind Werte die per Mqtt einlese
                                mW ist Mqtt Event gesteuert, dh keine fixe Abfragezeit, der Timestamp könnte da eine Auskunft geben
                                • mickemup
                                  mickemup @Humidor last edited by mickemup
                                  @humidor
                                  OK das heisst es sind Leistungswerte?
                                  Um Energie zu erhalten, muss man das Integrieren.
                                  Das kann man "grob" im Grafana machen.
                                  Die saubere Lösung wurde aber schon hier beschrieben.
                                  @lesiflo hat das im Post von 13.Okt als Blockly aufgezeigt...
                                  Kannst du sagen wie oft die Werte in Influx geloggt werden und loggst du nur Veränderungen oder jeden mqtt Wert?
                                  evtl Printscrren?
                                  • Humidor
                                    @mickemup Ja, momentane Leistungswerte
                                    das ist was ich aus dem System per Mqtt raus bekomme:
                                    die Werte kommen jede Sekunde
                                    gibt zwar auch die Möglichkeit per Modbus direkt auf den Zähler zu gehen, aber die Register scheinen nicht zu stimmen, da kommen oft utopische Werte rüber.
                                    mickemup 2 Replies Last reply Reply Quote 0
                                    • mickemup
                                      @humidor
                                      Ok probier mal das:
                                      import "date"
                                      import "timezone"
                                      option location = timezone.location(name: "Europe/Madrid")
                                      from(bucket: "iobroker_YOURBUCKET")
                                        |> range(start: v.timeRangeStart, stop: v.timeRangeStop)
                                        |> filter(fn: (r) => r["_measurement"] == "YOURdatapoint")
                                        |> filter(fn: (r) => r["_field"] == "value")
                                          |> aggregateWindow(every: 1m, fn: mean, timeSrc: "_start")
                                      |> aggregateWindow(every: 1h, fn: mean, timeSrc: "_start")
                                      aja und kommen die Daten immer oder nur bei Veränderung
                                      und loggst du immer oder nur bei Veränderung?
                                      • Humidor
                                        @mickemup standard Einstellung von influxdb
                                        Humidor mickemup 2 Replies Last reply Reply Quote 0
                                        • Humidor
                                          Humidor @Humidor last edited by Humidor
                                          hab mal diesen Wert genommen: Power (ist ein Plus/Minus Wert)
                                          das wird aber wenig Sinn machen, verm. muss ich getrennt für Plus und Minus Werte hier loggen.
                                          Bildschirmfoto 2024-11-29 um 07.21.26.png Bildschirmfoto 2024-11-29 um 07.23.46.png
                                          • mickemup
                                            @humidor
                                            Du hast ja gesagt, dass du Dps für Einspeisung und Bezug separat hast.
                                            Diese müsstest du natürlich auch so loggen.
                                            Falls du denn generellen loggst, hast du Einfach eine Netto Bilanz...hast du überhaupt ein PV Anlage?
                                            Aber die die 12 KW (Ich nehme an Bezug) machen wohl schon Sinn, wenn man mit deinem INFLUX Plot vergleicht 🙂
                                            Hast du erst Daten von heute gesammelt?
                                            Falls nicht, musst du mal die Tiemrange in deinem Panel erhöhen
                                            Schreib mal beim zweiten "Printscreen" unter Query Options:
                                            Relative time now/M
                                            Time shift 0M/M
                                            Und nimm mal Barchart
                                            Sobald du mit dem ersten Plot zufrieden bist, kann man anschliessend noch die Wochen/Jahressummaries erstellen.
                                            Dies ist dann nur noch ein kleiner Schritt
                                            2953
