    4. [gelöst]PV-Forecast Probleme mit solcast!
    • icebear
      icebear @arteck last edited by
      @arteck said in PV-Forecast Probleme mit solcast!:
      ich weiss nicht...
      die scripte sind alle lauffähig und werden auch genutzt.. also kein plan
      Es läuft jetzt, die Daten kommen auch. Vielleicht war ich einfach zu ungeduldig und mußte das erstmal einen kompletten Tag laufen lassen.
      Ein Problem hab ich allerdings noch, im Protokoll meckert er an das 'toLog is not defined'
      javascript.0
      2024-10-15 09:01:01.502	error	at processTimers (node:internal/timers:519:7)
      javascript.0
      2024-10-15 09:01:01.502	error	at listOnTimeout (node:internal/timers:581:17)
      javascript.0
      2024-10-15 09:01:01.502	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3219:34)
      javascript.0
      2024-10-15 09:01:01.499	error	at Object.<anonymous> (script.js.get_solcast_data:189:17)
      javascript.0
      2024-10-15 09:01:01.499	error	at genGraphAnlegen (script.js.get_solcast_data:402:5)
      javascript.0
      2024-10-15 09:01:01.499	error	at genGraph (script.js.get_solcast_data:451:16)
      javascript.0
      2024-10-15 09:01:01.499	error	script.js.get_solcast_data: TypeError: Cannot read properties of undefined (reading 'setStateAsync')
      javascript.0
      2024-10-15 09:01:01.476	error	at processTimers (node:internal/timers:519:7)
      javascript.0
      2024-10-15 09:01:01.475	error	at listOnTimeout (node:internal/timers:581:17)
      javascript.0
      2024-10-15 09:01:01.473	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3219:34)
      javascript.0
      2024-10-15 09:01:01.473	error	at Object.<anonymous> (script.js.get_solcast_data:188:17)
      javascript.0
      2024-10-15 09:01:01.473	error	at genGraphAnlegen (script.js.get_solcast_data:402:5)
      javascript.0
      2024-10-15 09:01:01.473	error	at genGraph (script.js.get_solcast_data:451:16)
      javascript.0
      2024-10-15 09:01:01.473	error	script.js.get_solcast_data: TypeError: Cannot read properties of undefined (reading 'setStateAsync')
      javascript.0
      2024-10-15 09:01:01.468	error	at processTimers (node:internal/timers:519:7)
      javascript.0
      2024-10-15 09:01:01.466	error	at listOnTimeout (node:internal/timers:581:17)
      javascript.0
      2024-10-15 09:01:01.463	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3219:34)
      javascript.0
      2024-10-15 09:01:01.460	error	at Object.<anonymous> (script.js.get_solcast_data:192:17)
      javascript.0
      2024-10-15 09:01:01.452	error	Error in callback: ReferenceError: toLog is not defined
      bekomm ich das noch irgendwie weg?
      • haus-automatisierung
        haus-automatisierung Developer Most Active last edited by
        Ich bestelle das Thema mal ab, geht ja gar nicht mehr um den Adapter. Hatte auf Feedback vom TO gehofft.
        Danke an @SmartHomer-0 für die Rückmeldung.
        icebear D 2 Replies Last reply Reply Quote 1
        • icebear
          icebear @haus-automatisierung last edited by
          Danke für deinen Einsatz, habs grad auf die neue Version aktualisiert und jetzt funktioniert wieder alles.
          Nochmals vielen Dank für deinen Einsatz und die schnelle Behebung des Problems.
            arteck Developer Most Active @icebear last edited by
            @icebear sagte in PV-Forecast Probleme mit solcast!:
            toLog
            lösch die Zeile 1024
            toLog(' -----------------    Batterie NOTLADEN ' + _bydDirectSOC + ' %', true);
            icebear 1 Reply Last reply Reply Quote 0
            • icebear
              Hm, ich benutze ja nur das 'get_solcast_data' Script, da gibt es keine Zeile 1024, bzw eine Zeile die so aussieht wie in deinem Post.
              Ich hoffe ich gehe recht in der Annahme, das das beim 'get_solcast_Data' Script ähnlich ist und so hab ich zum Testen mal die Zeilen mit toLog auskommentiert (42, 46 und 191) :
              schedule({ astro: 'sunrise' }, () => {
                  initialPV();
                  let url = `${seite2}/forecasts?format=json&api_key=${key_id}`;
                  //toLog(`Hole PV ${name2}`, true);
                  requestData(url, name2);
                  url = `${seite1}/forecasts?format=json&api_key=${key_id}`;
                  //toLog(`Hole PV ${name1}`, true);
                  requestData(url, name1);
              sowie:
                             setState(`${mainObject}.lastUpdated`, { val: moment().valueOf(), ack: true });
                              //toLog(`Hole PV ${seite}`, true);
              • mcm1957
                mcm1957 @icebear last edited by
                @icebear said in PV-Forecast Probleme mit solcast!:
                Guten Morgen
                Kümmert sich eigentlich noch jemand um den PV-Forecast Adapter?
                Seit vorgestern funktioniert die Abfrage der Forecast-Daten bei Solcast nicht mehr.
                Fehlermeldung ist > AxiosError: Request failed with status code 403
                Github Issue sind erstellt!
                Um die URSPRÜNGLICHE Frage zu beantworten:
                JA
                Es gibt eine neue Version 4.0.0.
                Rückmeldungen zum Adapter - gerne auch positive im Sinne von es geht -sind gern gesehen.
                Zitat:
                https://forum.iobroker.net/topic/77375/pv-forecast-probleme-mit-solcast/20
                Version 4.0.0 testen, Plants neu anlegen (braucht ja nur noch die Resource ID), fertig.
                Sollte etwas nicht gehen: Issue auf GitHub öffnen und vernünftig beschreiben.
                Diskussionen zu Skripts weichen eigentlich vom Thema (siehe Eröffnungsposting) ab und sollten in einem Support / Diskussionstopicc für das jeweilige Scritp geführt werden da sie mitz dem Adapter eher wenig zu tun haben.
                icebear 1 Reply Last reply Reply Quote 1
                • icebear
                  icebear @mcm1957 last edited by
                  @mcm1957 said in PV-Forecast Probleme mit solcast!:
                  Leider ist das ganze mit den zusätzlichen Post's hier etwas aus dem Ruder gelaufen, und war so ja auch garnicht gedacht. Sorry dafür!
                  Noch einmal möchte ich mich bei @haus-automatisierung für seinen schnellen und unermüdlichen Einsatz beim beheben des Problems Danke sagen!
                  Zumindest bei mir funktioniert der Adapter mit 'solcast jetzt wieder zu 100% .
                  Ich glaube wir können das jetzt hiermit beschließen.
                    Taddy81 @icebear last edited by Taddy81
                    hat sich erledigt
                    • icebear
                      icebear @Taddy81 last edited by
                      @taddy81
                      Hallo, da es hier nur um die vorübergehend nicht zur Verfügung stehenden Vorhersagen vom PV-Forecast Adapter bei 'solcast' ging und das Problem ja mit der Version 4.0.0 behoben ist, mußt du am besten deine Frage im ursprünglichen Thread posten.
                      Test PV-Forecast Adapter
                        anbima @icebear last edited by
                        Bei mir wird die 4.0 nicht angezeigt.
                        Ich habe auch "Adapter auf Updates prüfen" gemacht, aber es bleibt beim 3.0.0
                        Muss ich da noch warten?
                          haus-automatisierung Developer Most Active @anbima last edited by
                          @anbima sagte in [gelöst]PV-Forecast Probleme mit solcast!:
                          Wie immer bei neuen Versionen: Ist nur im Beta-Repo bisher.
                          Alternativ über npm installieren (nie über GitHub-Urls bitte).
                            anbima @haus-automatisierung last edited by
                            @haus-automatisierung said in [gelöst]PV-Forecast Probleme mit solcast!:
                            Wie mache ich das über npm?
                            Welchen Befehl muss ich im Rasp eingeben?
                            Oder geht das direkt aus dem ioBroker?
                              Klar. Adapter-Tab. Experten-Modus. GitHub Octocat anklicken. Tab npm. pvforecast auswählen.
                              Generell mal die ioBroker-Grundlagen anschauen
                              A 2 Replies Last reply Reply Quote 0
                                Vielen Dank.
                                Ich hatte das schon mal gelesen, aber den GitHub-Button glatt übersehen.
                                Im Experten-Modus war ich schon...
                                  docsnyder7 @haus-automatisierung last edited by
                                  Auch hier mit dem Update wieder alles Bestens!
                                  Danke Matthias
                                    Funktioniert wieder bestens. Vielen Dank.
                                    Ich hätte da noch was anderes.
                                    Wir haben ja bei Solcast das Problem mit den Updates, dass die "alten" Daten vom Tag verloren gehen.
                                    Dafür hätte ich eine Lösung.
                                    Du machst um 5 Uhr in der früh eine Abfrage, wie es bisher ist.
                                    Bei der nächsten Abfrage (sagen wir mal alle 240 Minuten) kommt eine zusätzliche Abfrage beim Import der Daten rein:
                                    wenn timestamp == heute && uhrzeit > 5 uhr dann
                                    wenn import-wert != 0 wert importieren sonst nicht.
                                    Somit würden die Werte von früheren Stunden des Tages erhalten bleiben und die neuen werden aktualisiert.
                                    Was hältst du davon?
                                    arteck haus-automatisierung 2 Replies Last reply Reply Quote 0
                                      arteck Developer Most Active @anbima last edited by
                                      mal von abgesehen das bei solcast man NUR 10 freie abfragen hat und die Daten dir nix bringen vor dem Sonnenaufgang zu holen..
                                      schmeiss die Daten in influxDB oder mysql oder oder..
                                        anbima @arteck last edited by
                                        @arteck said in [gelöst]PV-Forecast Probleme mit solcast!:
                                        Derzeit werden die Daten bereits um 1 Uhr geholt.
                                        Und um 5 Uhr ist im Sommer kurz vor Sonnenaufgang.
                                        Die 10 freien Abfragen könnte man ja schön über den Tag verteilen. Der Abfrageintervall ist ja bei forecast.solar schon vorhanden und könnte da auch verwendet werden.
                                        Das mit der Datenbank könnte man machen, wäre dann aber nicht erforderlich. Nicht jeder möchte hierfür eine Datenbank anlegen.
                                          Schon klar wie das technisch umsetzbar wäre. Aber guck mal den Code an. Alles ist auf forecast solar ausgelegt und solcadt wurde nachträglich oben drauf gebaut.
                                          So wird zB auch das Format von Solcast in das von Forecast Solar konvertiert, damit man die ganze Logik beibehalten konnte.
                                          Es wäre also ein größerer Eingriff das komplett zu trennen. Aber ich freue mich immer über Mitarbeitende am Adapter.
                                          A A 2 Replies Last reply Reply Quote 1
                                            anbima @haus-automatisierung last edited by anbima
                                            An welcher Stelle in der main.js schreibst du die Daten in die Objekte?
                                            Ich bin zwar kein Programmierer, aber vielleicht bekomme ich das hin.
                                            Nur den ganzen Code zu durchsuchen ist sehr aufwendig.
                                            Nachtrag.
                                            Kannst du mir vielleicht folgendes beantworten:
                                            So wie ich das sehen kann, werden die Daten nur in die Objekte der einzelnen plants geschrieben, wenn diese vorhanden sind. Löscht du die Inhalte alle, bevor du diese neu in die Objekte schreibst? Wenn ja, wo wird dies gemacht?
                                            69
                                            6226
