    4. Backitup ENOSPC no space left on device
      Mr-M @mcm1957 last edited by
      @mcm1957
      hier noch einmal die Langfassung
      Skript v.2024-08-12
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      OS is similar to: debian
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 32 bit
      Systemuptime and Load:
       22:10:10 up  7:45,  2 users,  load average: 0.71, 0.57, 0.54
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Fri 2024-10-11 22:10:10 CEST
                 Universal time: Fri 2024-10-11 20:10:10 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pimk
      HOME=/home/pimk
      GROUPS=pimk adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            3.8G        1.4G        866M        1.0M        1.6G        2.4G
      Swap:            99M          0B         99M
      Total:          3.9G        1.4G        966M
      Active iob-Instances:   31
               3794 M total memory
               1353 M used memory
               1385 M active memory
               1214 M inactive memory
                865 M free memory
                154 M buffer memory
               1420 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      top - 22:10:11 up  7:45,  2 users,  load average: 0.71, 0.57, 0.54
      Tasks: 185 total,   2 running, 183 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 30.6 us,  2.8 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3794.3 total,    865.6 free,   1353.2 used,   1575.6 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2364.6 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       29G   11G   18G  38% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  1.2M  758M   1% /run
      /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Fri Oct 11 14:24:34 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:A9:B2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200console=tty1 root=PARTUUID=976d128e-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Fri Oct 11 14:24:37 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Oct 11 14:24:37 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Fri Oct 11 14:24:40 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.6G    /var/
      1.1G    /var/log/journal/64bfba8b2b044f0d8cca8b6961e09c03
      1.1G    /var/log
      389M    /var/cache
      Archived and active journals take up 1.0G in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      2.1G    /opt/iobroker/iobroker-data/
      1.4G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      594M    /opt/iobroker/iobroker-data/history
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      29M     /opt/iobroker/iobroker-data/objects.jsonl
      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2671885-if00
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyACM0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.17.0
      /usr/bin/node           v20.17.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.17.0-1nodesource1
        Candidate: 20.18.0-1nodesource1
        Version table:
           20.18.0-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
       *** 20.17.0-1nodesource1 600
              100 /var/lib/dpkg/status
           20.16.0-1nodesource1 600
           20.15.1-1nodesource1 600
           20.15.0-1nodesource1 600
           20.14.0-1nodesource1 600
           20.13.1-1nodesource1 600
           20.13.0-1nodesource1 600
           20.12.2-1nodesource1 600
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
           20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           12.22.12~dfsg-1~deb11u5 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.1.5
      javascript:     8.8.3
      nodejs modules from github:     1
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.ds18b20.0                : ds18b20               : slave                                    -  enabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
      + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
      + system.adapter.frontier_silicon.0       : frontier_silicon      : raspberrypi                              -  enabled
      + system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi                              -  enabled
      + system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.material.0               : material              : raspberrypi                              -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : slave                                    -  enabled
        system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
        system.adapter.solarmanpv.0             : solarmanpv            : raspberrypi                              -  enabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
      + system.adapter.statistics.1             : statistics            : raspberrypi                              -  enabled
      + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      + system.adapter.valuetrackerovertime.0   : valuetrackerovertime  : raspberrypi                              -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
        system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.22   , installed 3.0.22
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "frontier_silicon": 0.3.0 , installed 0.3.0
      Adapter    "fullcalendar" : 2.4.2    , installed 2.4.2
      Adapter    "heatingcontrol": 2.12.10 , installed 2.12.10
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "openligadb"   : 1.4.11   , installed 1.4.11
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "sayit"        : 5.0.0    , installed 5.0.0
      Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
      Adapter    "shuttercontrol": 1.7.3   , installed 1.7.3
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "solarmanpv"   : 0.6.1    , installed 0.6.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "valuetrackerovertime": 1.0.1, installed 1.0.1
      Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
      Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects:        10488
      States:         8236
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 http://phoscon.de/apt/deconz bullseye InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 15
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11880      556/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       432016     31407/iobroker.js-c
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       432011     31407/iobroker.js-c
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       434668     31740/io.sonoff.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          11882      556/sshd: /usr/sbin
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       434122     31833/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       433456     31426/io.admin.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       435926     31852/io.ws.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14789      763/dhcpcd
      udp        0      0 0.0.0.0:58088           0.0.0.0:*                           108        14617      381/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14615      381/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          14807      763/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        14616      381/avahi-daemon: r
      udp6       0      0 :::44520                :::*                                108        14618      381/avahi-daemon: r
      2024-10-11 22:10:31.369  - debug: zigbee.0 (31519) DeviceAvailability:Non-pingable device 0xa4c138fb1afe9099 TS0601 was last seen '1583.729' seconds ago.
      2024-10-11 22:10:31.371  - debug: zigbee.0 (31519) DeviceAvailability:Non-pingable device 0xa4c1383cee7c9d4c TS0601 was last seen '942.906' seconds ago.
      2024-10-11 22:10:31.372  - debug: zigbee.0 (31519) DeviceAvailability:Non-pingable device 0xa4c138fc13aab5df TS0601 was last seen '6146570.6' seconds ago.
      2024-10-11 22:10:31.376  - debug: zigbee.0 (31519) DeviceAvailability:Non-pingable device 0xa4c13851258a55bd TS0203 was last seen '9259.448' seconds ago.
      2024-10-11 22:10:31.388  - debug: zigbee.0 (31519) DeviceAvailability:Non-pingable device 0xa4c1380981e2173d TS0202 was last seen '3091.794' seconds ago.
      2024-10-11 22:10:31.395  - debug: zigbee.0 (31519) DeviceAvailability:Non-pingable device 0xa4c1380eb841c3c2 TS0203 was last seen '6091.478' seconds ago.
      2024-10-11 22:10:31.397  - debug: zigbee.0 (31519) DeviceAvailability:Non-pingable device 0xa4c138f0f6d4789c TS0203 was last seen '614.329' seconds ago.
      2024-10-11 22:10:31.400  - debug: zigbee.0 (31519) DeviceAvailability:Non-pingable device 0xa4c138438105a13d TS0203 was last seen '10732.94' seconds ago.
      2024-10-11 22:10:35.717  - debug: zigbee.0 (31519) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":46,"_applicationVersion":77,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":266,"inputClusters":[3,4,5,6,1794,2820,57344,57345,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"65503":"�5�-\u0012","65506":54,"65508":0,"65534":0,"modelId":"TS011F","manufacturerName":"_TZ3000_typdpbpg","powerSource":1,"zclVersion":3,"appVersion":77,"stackVersion":0,"hwVersion":1,"dateCode":""}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":2000,"acCurrentMultiplier":1,"rmsVoltage":235,"rmsCurrent":70,"activePower":13}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,436]}},"genOnOff":{"attributes":{"32768":0,"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":0,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":1,"53249":0,"53250":2896061,"53251":115,"53252":10522,"53253":1243,"powerOnBehavior":0,"switchType":0}}},"deviceIeeeAddress":"0xa4c138873c6b137e","deviceNetworkAddress":25002,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff098781","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00212effff098781","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00212effff098781","endpointID":1}],"_configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5,"manufacturerCode":null},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50,"manufacturerCode":null},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10,"manufacturerCode":null},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1],"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138873c6b137e"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138873c6b137e","deviceNetworkAddress":25002,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138873c6b137e"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138873c6b137e","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1728677435715,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_typdpbpg","_modelID":"TS011F","_networkAddress":25002,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":255,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":159,"_pendingRequestTimeout":0,"meta":{"configured":-1941818122}},"endpoint":"[Circular]","data":{"rmsVoltage":235},"linkquality":255,"groupID":null,"cluster":"haElectricalMeasurement","meta":{"zclTransactionSequenceNumber":160,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
      2024-10-11 22:10:35.718  - debug: zigbee.0 (31519) Received Zigbee message from '0xa4c138873c6b137e', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"rmsVoltage":235}' from endpoint 1 with groupID null
      2024-10-11 22:10:35.719  - debug: zigbee.0 (31519) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":46,"_applicationVersion":77,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":266,"inputClusters":[3,4,5,6,1794,2820,57344,57345,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"65503":"�5�-\u0012","65506":54,"65508":0,"65534":0,"modelId":"TS011F","manufacturerName":"_TZ3000_typdpbpg","powerSource":1,"zclVersion":3,"appVersion":77,"stackVersion":0,"hwVersion":1,"dateCode":""}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":2000,"acCurrentMultiplier":1,"rmsVoltage":235,"rmsCurrent":70,"activePower":13}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,436]}},"genOnOff":{"attributes":{"32768":0,"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":0,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":1,"53249":0,"53250":2896061,"53251":115,"53252":10522,"53253":1243,"powerOnBehavior":0,"switchType":0}}},"deviceIeeeAddress":"0xa4c138873c6b137e","deviceNetworkAddress":25002,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff098781","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00212effff098781","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00212effff098781","endpointID":1}],"_configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5,"manufacturerCode":null},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50,"manufacturerCode":null},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10,"manufacturerCode":null},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1],"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138873c6b137e"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138873c6b137e","deviceNetworkAddress":25002,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138873c6b137e"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138873c6b137e","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1728677435715,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_typdpbpg","_modelID":"TS011F","_networkAddress":25002,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":255,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":159,"_pendingRequestTimeout":0,"meta":{"configured":-1941818122}},"mapped":{"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior","power_outage_memory"]},{"key":["backlight_mode","indicator_mode"]},{"key":["child_lock"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"],"options":[{"name":"state_action","label":"State action","access":2,"type":"binary","property":"state_action","description":"State actions will also be published as 'action' when true (default false).","value_on":true,"value_off":false}]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"haElectricalMeasurement","type":["attributeReport","readResponse"]},{"cluster":"seMetering","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"exposes":[{"type":"switch","features":[{"name":"state","label":"State","access":7,"type":"binary","property":"state","description":"On/off state of the switch","value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"}]},{"name":"power_outage_memory","label":"Power outage memory","access":7,"type":"enum","property":"power_outage_memory","description":"Recover state after power outage","values":["on","off","restore"]},{"name":"indicator_mode","label":"Indicator mode","access":7,"type":"enum","property":"indicator_mode","description":"LED indicator mode","values":["off","off/on","on/off","on"]},{"name":"power","label":"Power","access":1,"type":"numeric","property":"power","description":"Instantaneous measured power","category":"diagnostic","unit":"W"},{"name":"current","label":"Current","access":1,"type":"numeric","property":"current","description":"Instantaneous measured electrical current","category":"diagnostic","unit":"A"},{"name":"voltage","label":"Voltage","access":1,"type":"numeric","property":"voltage","description":"Measured electrical potential value","category":"diagnostic","unit":"V"},{"name":"energy","label":"Energy","access":1,"type":"numeric","property":"energy","description":"Sum of consumed energy","unit":"kWh"},{"label":"Child lock","type":"lock","features":[{"name":"state","label":"State","access":3,"type":"binary","property":"child_lock","description":"Enables/disables physical input on the device","value_on":"LOCK","value_off":"UNLOCK"}]},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"ota":{},"zigbeeModel":["TS011F"],"model":"TS011F_plug_1","description":"Smart plug (with power monitoring)","vendor":"TuYa","whiteLabel":[{"vendor":"LELLKI","model":"TS011F_plug"},{"vendor":"Neo","model":"NAS-WR01B"},{"vendor":"BlitzWolf","model":"BW-SHP15"},{"vendor":"BlitzWolf","model":"BW-SHP13"},{"vendor":"MatSee Plus","model":"PJ-ZSW01"},{"vendor":"MODEMIX","model":"MOD037"},{"vendor":"MODEMIX","model":"MOD048"},{"vendor":"Coswall","model":"CS-AJ-DE2U-ZG-11"},{"vendor":"Aubess","model":"TS011F_plug_1"},{"vendor":"Nous","model":"A1Z","description":"Smart plug (with power monitoring)","fingerprint":[{"manufacturerName":"_TZ3000_2putqrmw"}]},{"vendor":"Moes","model":"MOES_plug","description":"Smart plug (with power monitoring)","fingerprint":[{"manufacturerName":"_TZ3000_yujkchbz"}]},{"vendor":"Moes","model":"ZK-EU","description":"Smart wallsocket (with power monitoring)","fingerprint":[{"manufacturerName":"_TZ3000_ss98ec5d"}]},{"vendor":"Nous","model":"A1Z","description":"Smart plug (with power monitoring)","fingerprint":[{"manufacturerName":"_TZ3000_ksw8qtmt"}]}],"options":[{"name":"power_calibration","label":"Power calibration","access":2,"type":"numeric","property":"power_calibration","description":"Calibrates the power value (percentual offset), takes into effect on next report of device."},{"name":"power_precision","label":"Power precision","access":2,"type":"numeric","property":"power_precision","description":"Number of digits after decimal point for power, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},{"name":"current_calibration","label":"Current calibration","access":2,"type":"numeric","property":"current_calibration","description":"Calibrates the current value (percentual offset), takes into effect on next report of device."},{"name":"current_precision","label":"Current precision","access":2,"type":"numeric","property":"current_precision","description":"Number of digits after decimal point for current, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},{"name":"voltage_calibration","label":"Voltage calibration","access":2,"type":"numeric","property":"voltage_calibration","description":"Calibrates the voltage value (percentual offset), takes into effect on next report of device."},{"name":"voltage_precision","label":"Voltage precision","access":2,"type":"numeric","property":"voltage_precision","description":"Number of digits after decimal point for voltage, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},{"name":"energy_calibration","label":"Energy calibration","access":2,"type":"numeric","property":"energy_calibration","description":"Calibrates the energy value (percentual offset), takes into effect on next report of device."},{"name":"energy_precision","label":"Energy precision","access":2,"type":"numeric","property":"energy_precision","description":"Number of digits after decimal point for energy, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},"[Circular]"]},"name":"0xa4c138873c6b137e"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":46,"_applicationVersion":77,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":266,"inputClusters":[3,4,5,6,1794,2820,57344,57345,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"65503":"�5�-\u0012","65506":54,"65508":0,"65534":0,"modelId":"TS011F","manufacturerName":"_TZ3000_typdpbpg","powerSource":1,"zclVersion":3,"appVersion":77,"stackVersion":0,"hwVersion":1,"dateCode":""}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":2000,"acCurrentMultiplier":1,"rmsVoltage":235,"rmsCurrent":70,"activePower":13}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,436]}},"genOnOff":{"attributes":{"32768":0,"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":0,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":1,"53249":0,"53250":2896061,"53251":115,"53252":10522,"53253":1243,"powerOnBehavior":0,"switchType":0}}},"deviceIeeeAddress":"0xa4c138873c6b137e","deviceNetworkAddress":25002,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff098781","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00212effff098781","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00212effff098781","endpointID":1}],"_configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5,"manufacturerCode":null},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50,"manufacturerCode":null},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10,"manufacturerCode":null},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1],"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138873c6b137e"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138873c6b137e","deviceNetworkAddress":25002,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138873c6b137e"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138873c6b137e","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1728677435715,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_typdpbpg","_modelID":"TS011F","_networkAddress":25002,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":255,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":159,"_pendingRequestTimeout":0,"meta":{"configured":-1941818122}},"endpoint":"[Circular]","data":{"rmsVoltage":235},"linkquality":255,"groupID":null,"cluster":"haElectricalMeasurement","meta":{"zclTransactionSequenceNumber":160,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
      2024-10-11 22:10:35.738  - debug: zigbee.0 (31519) Publish {"voltage":235} to "a4c138873c6b137e"
      2024-10-11 22:10:35.756  - silly: zigbee.0 (31519) States user redis pmessage zigbee.0.*/zigbee.0.a4c138873c6b137e.link_quality:{"val":255,"ack":true,"ts":1728677435753,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1728672170410}
      2024-10-11 22:10:35.801  - silly: zigbee.0 (31519) States user redis pmessage zigbee.0.*/zigbee.0.a4c138873c6b137e.msg_from_zigbee:{"val":"{\"type\":\"attributeReport\",\"data\":{\"rmsVoltage\":235},\"linkquality\":255,\"groupID\":null,\"cluster\":\"haElectricalMeasurement\",\"meta\":{\"zclTransactionSequenceNumber\":160,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}","ack":true,"ts":1728677435795,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1728677435795}
      2024-10-11 22:10:35.802  - silly: zigbee.0 (31519) States user redis pmessage zigbee.0.*/zigbee.0.a4c138873c6b137e.voltage:{"val":235,"ack":true,"ts":1728677435796,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1728677085057}
      2024-10-11 22:10:41.304  - debug: zigbee.0 (31519) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":43,"_applicationVersion":72,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":256,"inputClusters":[3,4,5,6,1794,2820,57344,57345,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"65503":"�g�+\u0013�g�+\u0012\b\u0001\u0000\u0000\u0012","65506":56,"65508":0,"65534":0,"modelId":"TS0001","manufacturerName":"_TZ3000_dzs254uq","powerSource":1,"zclVersion":3,"appVersion":72,"stackVersion":0,"hwVersion":1,"dateCode":""}},"manuSpecificBosch":{"attributes":{"53251":"AAAA"}},"genOnOff":{"attributes":{"onOff":0,"onTime":0,"offWaitTime":0,"moesStartUpOnOff":2}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"switchType":0}}},"deviceIeeeAddress":"0xa4c138809bc0f9bf","deviceNetworkAddress":59431,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff098781","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138809bc0f9bf"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138809bc0f9bf","deviceNetworkAddress":59431,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138809bc0f9bf"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138809bc0f9bf","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1728677441303,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_dzs254uq","_modelID":"TS0001","_networkAddress":59431,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":255,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":1,"_pendingRequestTimeout":0,"meta":{"configured":153093895}},"endpoint":"[Circular]","data":{"65506":56,"65508":0,"appVersion":72},"linkquality":255,"groupID":null,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":2,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
      2024-10-11 22:10:41.306  - debug: zigbee.0 (31519) Received Zigbee message from '0xa4c138809bc0f9bf', type 'attributeReport', cluster 'genBasic', data '{"65506":56,"65508":0,"appVersion":72}' from endpoint 1 with groupID null
      2024-10-11 22:10:41.307  - debug: zigbee.0 (31519) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":43,"_applicationVersion":72,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":256,"inputClusters":[3,4,5,6,1794,2820,57344,57345,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"65503":"�g�+\u0013�g�+\u0012\b\u0001\u0000\u0000\u0012","65506":56,"65508":0,"65534":0,"modelId":"TS0001","manufacturerName":"_TZ3000_dzs254uq","powerSource":1,"zclVersion":3,"appVersion":72,"stackVersion":0,"hwVersion":1,"dateCode":""}},"manuSpecificBosch":{"attributes":{"53251":"AAAA"}},"genOnOff":{"attributes":{"onOff":0,"onTime":0,"offWaitTime":0,"moesStartUpOnOff":2}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"switchType":0}}},"deviceIeeeAddress":"0xa4c138809bc0f9bf","deviceNetworkAddress":59431,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff098781","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138809bc0f9bf"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138809bc0f9bf","deviceNetworkAddress":59431,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138809bc0f9bf"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138809bc0f9bf","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1728677441303,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_dzs254uq","_modelID":"TS0001","_networkAddress":59431,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":255,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":2,"_pendingRequestTimeout":0,"meta":{"configured":153093895}},"mapped":{"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior","power_outage_memory"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"],"options":[{"name":"state_action","label":"State action","access":2,"type":"binary","property":"state_action","description":"State actions will also be published as 'action' when true (default false).","value_on":true,"value_off":false}]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"exposes":[{"type":"switch","features":[{"name":"state","label":"State","access":7,"type":"binary","property":"state","description":"On/off state of the switch","value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"}]},{"name":"power_on_behavior","label":"Power-on behavior","access":7,"type":"enum","property":"power_on_behavior","description":"Controls the behavior when the device is powered on after power loss. If you get an `UNSUPPORTED_ATTRIBUTE` error, the device does not support it.","category":"config","values":["off","previous","on"]},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"zigbeeModel":["TS0001"],"model":"TS0001","vendor":"TuYa","description":"1 gang switch","whiteLabel":[{"vendor":"CR Smart Home","model":"TS0001","description":"Valve control"},{"vendor":"Lonsonho","model":"X701"},{"vendor":"Bandi","model":"BDS03G1"}],"options":["[Circular]"]},"name":"0xa4c138809bc0f9bf"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":43,"_applicationVersion":72,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":256,"inputClusters":[3,4,5,6,1794,2820,57344,57345,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"65503":"�g�+\u0013�g�+\u0012\b\u0001\u0000\u0000\u0012","65506":56,"65508":0,"65534":0,"modelId":"TS0001","manufacturerName":"_TZ3000_dzs254uq","powerSource":1,"zclVersion":3,"appVersion":72,"stackVersion":0,"hwVersion":1,"dateCode":""}},"manuSpecificBosch":{"attributes":{"53251":"AAAA"}},"genOnOff":{"attributes":{"onOff":0,"onTime":0,"offWaitTime":0,"moesStartUpOnOff":2}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"switchType":0}}},"deviceIeeeAddress":"0xa4c138809bc0f9bf","deviceNetworkAddress":59431,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff098781","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138809bc0f9bf"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138809bc0f9bf","deviceNetworkAddress":59431,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138809bc0f9bf"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138809bc0f9bf","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1728677441303,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_dzs254uq","_modelID":"TS0001","_networkAddress":59431,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":255,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":2,"_pendingRequestTimeout":0,"meta":{"configured":153093895}},"endpoint":"[Circular]","data":{"65506":56,"65508":0,"appVersion":72},"linkquality":255,"groupID":null,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":2,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
      2024-10-11 22:10:41.338  - silly: zigbee.0 (31519) States user redis pmessage zigbee.0.*/zigbee.0.a4c138809bc0f9bf.link_quality:{"val":255,"ack":true,"ts":1728677441336,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1728673671164}
      2024-10-11 22:10:41.424  - silly: zigbee.0 (31519) States user redis pmessage zigbee.0.*/zigbee.0.a4c138809bc0f9bf.msg_from_zigbee:{"val":"{\"type\":\"attributeReport\",\"data\":{\"65506\":56,\"65508\":0,\"appVersion\":72},\"linkquality\":255,\"groupID\":null,\"cluster\":\"genBasic\",\"meta\":{\"zclTransactionSequenceNumber\":2,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}","ack":true,"ts":1728677441422,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1728677441422}
      2024-10-11 22:10:47.724  - info: sonoff.0 (31740) Client [StromClient] connected with secret 1728677447723_9136
      2024-10-11 22:10:56.036  - info: host.raspberrypi instance system.adapter.dwd.0 in version "2.8.5" started with pid 9314
      2024-10-11 22:10:59.838  - info: dwd.0 (9314) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.17.0, js-controller: 6.0.11
      2024-10-11 22:11:00.931  - info: dwd.0 (9314) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-10-11 22:11:01.476  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 9314 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        Thomas Braun Most Active @Mr-M last edited by
        @mr-m sagte in Backitup ENOSPC no space left on device:
        Userland : 32 bit
        Losgelöst von Problem mit dem Speicher: Installier das Betriebssystem in nächster Zeit komplett NEU, Debian 12 'Bookworm' als reines 64Bit-System.
        Das lokale Dateisystem hat allerdings in der Tat noch massig Platz.
        Pending Updates: 15
        Hau die rein. Inkl. des nodejs Updates.
        Aus dem iob diag ergibt sich aber keine Erklärung für die Meldung. Wie schaut es auf dem NAS aus?
          Mr-M @Thomas Braun last edited by
          Auf dem Nas sind 60% Speicher frei...
          Nun habe ich ja ein paar Aufgaben; vielleicht schaffe ich das noch an diesem Wochenende.
          Für heute bedanke ich mich recht herzlich.
          Einen schönen Abend noch
            Hallo Thomas,
            hatte heut etwas Zeit und habe mir auf einer neun SD Karte bookworm installiert, dann iobroker und dann backups eingespielt.... Leider das gleiche Fehlerbild.
            Diag Kurz
                                    v.2024-08-12
             Static hostname: Master
                   Icon name: computer
                      Kernel: Linux 6.6.51+rpt-rpi-v8
                Architecture: arm64
            Installation:           native
            Kernel:                 aarch64
            Userland:               64 bit
            Timezone:               Europe/Berlin (CEST, +0200)
            User-ID:                1000
            Pending OS-Updates:     0
            Pending iob updates:    0
            Nodejs-Installation:
            /usr/bin/nodejs         v20.18.0
            /usr/bin/node           v20.18.0
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            Recommended versions are nodejs 20.18.0 and npm 10.8.2
            MEMORY:
            Mem:            4.0G        2.1G        396M        1.2M        1.6G        1.9G
            Swap:           209M          0B        209M
            Total:          4.2G        2.1G        606M
            Active iob-Instances:   30
            ioBroker Core:          js-controller           6.0.11
                                    admin                   7.1.5
            Objects type: jsonl
            States  type: jsonl
            + system.adapter.admin.0                  : admin                 : Master                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.web.0                    : web                   : Master                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            Objects:                10089
            States:                 7915
            Size of iob-Database:
            37M     /opt/iobroker/iobroker-data/objects.jsonl
            26M     /opt/iobroker/iobroker-data/states.jsonl
              Diag Kurz
              Zu kurz, die Langfassung ist gefragt.
                hier die Langfassung
                ...und noch eine Erweiterung der Fehlerbeschreibung:
                Ich habe die Backitup Einstellungen gespeichert (2024_10_14-backitup.0.json und noch eine 2024_10_14-backitup.0.json)
                Bei der einen Variante bekomme ich das beschriebene Fehlerbild (Zusatzinfo : auf dem NAS werden 0byte Sicherungsdatein angelegt)
                Bei der anderen Variante bekomme ich einen Mount Fehler: mount error(111)....unable to find suitable adress.
                Und logischerweise tut sich dann auch nichts auf dem Nas.
                Interessanterweise läuft hier dann aber das backup durch und wird "erfolgreich" abgeschlossen. Wenn ich dann ins Protokoll der backuphistorie schaue steht dort "Für dieses backup ist kein Protokoll verfügbar"
                Ich hoffe das wird jetz nicht alles zu konfus.
                Vergleiche ich Inztanzeinstellung von backitup, kann ich in der Konfiguration keinen Unterschied erkennen. Ich habe testweise auch schon bei beiden Varianten das Passwort neu gesetzt..
                Skript v.2024-08-12
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                OS is similar to:
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                 17:58:07 up  1:21,  2 users,  load average: 0.46, 0.53, 0.55
                CPU threads: 4
                Current issues:
                               Local time: Wed 2024-10-16 17:58:07 CEST
                           Universal time: Wed 2024-10-16 15:58:07 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pimk
                HOME=/home/pimk
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            4.0G        2.1G        564M        978K        1.4G        1.9G
                Swap:           209M        262K        209M
                Total:          4.2G        2.1G        773M
                         3791 M total memory
                         1969 M used memory
                         1953 M active memory
                         1116 M inactive memory
                          537 M free memory
                           63 M buffer memory
                         1297 M swap cache
                          199 M total swap
                            0 M used swap
                          199 M free swap
                top - 17:58:07 up  1:21,  2 users,  load average: 0.46, 0.53, 0.55
                Tasks: 199 total,   1 running, 198 sleeping,   0 stopped,   0 zombie
                %Cpu(s): 20.0 us, 20.0 sy,  0.0 ni, 60.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :   3792.0 total,    537.2 free,   1970.3 used,   1360.7 buff/cache
                MiB Swap:    200.0 total,    199.7 free,      0.2 used.   1821.7 avail Mem
                *** FILESYSTEM ***
                udev           devtmpfs  1.6G     0  1.6G   0% /dev
                tmpfs          tmpfs     380M  1.2M  379M   1% /run
                /dev/mmcblk0p2 ext4       29G  7.3G   20G  28% /
                /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
                [Wed Oct 16 16:36:38 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:A9:B2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=27566863-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=GE
                [Wed Oct 16 16:36:41 2024] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                [Wed Oct 16 16:36:42 2024] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
                `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                633M    /var/
                206M    /var/cache
                200M    /var/cache/apt
                166M    /var/lib
                134M    /var/lib/apt/lists
                Archived and active journals take up 60.0M in the file system.
                438M    /opt/iobroker/backups/
                1.7G    /opt/iobroker/iobroker-data/
                1.1G    /opt/iobroker/iobroker-data/files
                30M     /opt/iobroker/iobroker-data/states.jsonl
                USB-Devices by-id:
                HINT:
                /dev/ttyACM0
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Installed: 20.18.0-1nodesource1
                  Version table:
                 *** 20.18.0-1nodesource1 1001
                        500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                     20.17.0-1nodesource1 1001
                     20.16.0-1nodesource1 1001
                     20.15.1-1nodesource1 1001
                     20.15.0-1nodesource1 1001
                     20.14.0-1nodesource1 1001
                     20.13.1-1nodesource1 1001
                     20.13.0-1nodesource1 1001
                     20.12.2-1nodesource1 1001
                     20.12.1-1nodesource1 1001
                     20.12.0-1nodesource1 1001
                     20.11.1-1nodesource1 1001
                     20.11.0-1nodesource1 1001
                     20.10.0-1nodesource1 1001
                     20.9.0-1nodesource1 1001
                     20.8.1-1nodesource1 1001
                     20.8.0-1nodesource1 1001
                     20.7.0-1nodesource1 1001
                     20.6.1-1nodesource1 1001
                     20.6.0-1nodesource1 1001
                     20.5.1-1nodesource1 1001
                     20.5.0-1nodesource1 1001
                     20.4.0-1nodesource1 1001
                     20.3.1-1nodesource1 1001
                     20.3.0-1nodesource1 1001
                     20.2.0-1nodesource1 1001
                     20.1.0-1nodesource1 1001
                     20.0.0-1nodesource1 1001
                     18.19.0+dfsg-6~deb12u2 500
                     18.19.0+dfsg-6~deb12u1 500
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          7.1.5
                javascript:     8.8.3
                nodejs modules from github:     0
                Adapter State
                + system.adapter.alexa2.0                 : alexa2                : Master                                   -  enabled
                + system.adapter.backitup.0               : backitup              : Master                                   -  enabled
                + system.adapter.cloud.0                  : cloud                 : Master                                   -  enabled
                + system.adapter.device-watcher.0         : device-watcher        : Master                                   -  enabled
                + system.adapter.discovery.0              : discovery             : Master                                   -  enabled
                  system.adapter.dwd.0                    : dwd                   : Master                                   -  enabled
                + system.adapter.echarts.0                : echarts               : Master                                   -  enabled
                + system.adapter.fritzbox.0               : fritzbox              : Master                                   -  enabled
                + system.adapter.frontier_silicon.0       : frontier_silicon      : Master                                   -  enabled
                + system.adapter.fullcalendar.0           : fullcalendar          : Master                                   -  enabled
                + system.adapter.heatingcontrol.0         : heatingcontrol        : Master                                   -  enabled
                + system.adapter.history.0                : history               : Master                                   -  enabled
                  system.adapter.ical.0                   : ical                  : Master                                   -  enabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Master                                   - disabled
                  system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : Master                                   - disabled
                + system.adapter.iot.0                    : iot                   : Master                                   -  enabled
                + system.adapter.javascript.0             : javascript            : Master                                   -  enabled
                  system.adapter.material.0               : material              : Master                                   - disabled
                + system.adapter.ping.0                   : ping                  : Master                                   -  enabled
                + system.adapter.pushover.0               : pushover              : Master                                   -  enabled
                  system.adapter.schoolfree.0             : schoolfree            : Master                                   -  enabled
                  system.adapter.solarmanpv.0             : solarmanpv            : Master                                   -  enabled
                + system.adapter.sonoff.0                 : sonoff                : Master                                   -  enabled, port: 1883, bind: 0.0.0.0
                + system.adapter.statistics.0             : statistics            : Master                                   -  enabled
                + system.adapter.statistics.1             : statistics            : Master                                   -  enabled
                + system.adapter.text2command.0           : text2command          : Master                                   -  enabled
                + system.adapter.tr-064.0                 : tr-064                : Master                                   -  enabled
                + system.adapter.trashschedule.0          : trashschedule         : Master                                   -  enabled
                + system.adapter.valuetrackerovertime.0   : valuetrackerovertime  : Master                                   -  enabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : Master                                   - disabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : Master                                   -  enabled
                  system.adapter.vis-material-advanced.0  : vis-material-advanced : Master                                   - disabled
                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : Master                                   - disabled
                  system.adapter.vis-players.0            : vis-players           : Master                                   - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : Master                                   - disabled
                  system.adapter.vis.0                    : vis                   : Master                                   -  enabled
                + system.adapter.ws.0                     : ws                    : Master                                   -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                + system.adapter.zigbee.0                 : zigbee                : Master                                   -  enabled, port: /dev/ttyACM0
                + instance is alive
                Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                Adapter    "schoolfree"   : 1.1.5    , installed 1.1.5
                Objects and States
                Objects:        10089
                States:         7915
                Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                Pending Updates: 0
                tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       14785      2486/sshd: pimk@pts
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       8576       1113/io.sonoff.0
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4548       697/sshd: /usr/sbin
                tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       5992       684/iobroker.js-con
                tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       5997       684/iobroker.js-con
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8877       1371/io.web.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7201       769/io.admin.0
                tcp6       0      0 :::8084                 :::*                    LISTEN      1001       8869       1378/io.ws.0
                tcp6       0      0 :::22                   :::*                    LISTEN      0          4550       697/sshd: /usr/sbin
                tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       14784      2486/sshd: pimk@pts
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4431       512/avahi-daemon: r
                udp        0      0 0.0.0.0:60965           0.0.0.0:*                           104        887        512/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                104        886        512/avahi-daemon: r
                udp6       0      0 fe80::935b:624a:7d7:546 :::*                                0          6289       636/NetworkManager
                udp6       0      0 fe80::deea:b64c:d8c:546 :::*                                0          6283       636/NetworkManager
                udp6       0      0 :::54032                :::*                                104        888        512/avahi-daemon: r
                2024-10-16 17:58:48.165  - debug: heatingcontrol.0 (808) Kinderzimmer ### ChangeStatus Thermostats_Current to {"val":17,"ack":true,"ts":1729094328161,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729094264054} in auto
                2024-10-16 17:58:48.165  - debug: heatingcontrol.0 (808) Change Status current temperature in Kinderzimmer to 17
                2024-10-16 17:58:48.165  - debug: heatingcontrol.0 (808) HandleActors for Kinderzimmer auto,  timers 0 PI false
                2024-10-16 17:58:48.166  - debug: heatingcontrol.0 (808) HandleActors: no actors and/or no thermostats in Kinderzimmer
                2024-10-16 17:58:48.166  - debug: heatingcontrol.0 (808) checking all actors
                2024-10-16 17:58:48.213  - debug: heatingcontrol.0 (808) UpdateDPs for Kinderzimmer auto
                2024-10-16 17:58:48.255  - debug: heatingcontrol.0 (808) AddStatusToLog skip Kinderzimmer auto 17°C
                2024-10-16 17:58:50.966  - debug: zigbee.0 (1149) handleMessage. {"type":"commandDataReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":30,"_applicationVersion":67,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":81,"inputClusters":[4,5,61184,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"65503":"�ѝ.i","65506":55,"65508":0,"65534":0,"modelId":"TS0601","manufacturerName":"_TZE200_6rdj8dzm","powerSource":3,"zclVersion":3,"appVersion":67,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"deviceIeeeAddress":"0xa4c138fb1afe9099","deviceNetworkAddress":31845,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138fb1afe9099"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138fb1afe9099","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1729094330966,"_manufacturerID":4417,"_manufacturerName":"_TZE200_6rdj8dzm","_modelID":"TS0601","_networkAddress":31845,"_powerSource":"Battery","_stackVersion":0,"_type":"EndDevice","_zclVersion":3,"_linkquality":255,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":133,"_pendingRequestTimeout":0,"meta":{"configured":-708457359}},"endpoint":"[Circular]","data":{"seq":21504,"dpValues":[{"dp":5,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,180]}}]},"linkquality":255,"groupID":null,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":134,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                2024-10-16 17:58:50.968  - debug: zigbee.0 (1149) Received Zigbee message from '0xa4c138fb1afe9099', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"seq":21504,"dpValues":[{"dp":5,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,180]}}]}' from endpoint 1 with groupID null
                2024-10-16 17:58:50.969  - debug: zigbee.0 (1149) Type commandDataReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":30,"_applicationVersion":67,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":81,"inputClusters":[4,5,61184,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"65503":"�ѝ.i","65506":55,"65508":0,"65534":0,"modelId":"TS0601","manufacturerName":"_TZE200_6rdj8dzm","powerSource":3,"zclVersion":3,"appVersion":67,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"deviceIeeeAddress":"0xa4c138fb1afe9099","deviceNetworkAddress":31845,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138fb1afe9099"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138fb1afe9099","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1729094330966,"_manufacturerID":4417,"_manufacturerName":"_TZE200_6rdj8dzm","_modelID":"TS0601","_networkAddress":31845,"_powerSource":"Battery","_stackVersion":0,"_type":"EndDevice","_zclVersion":3,"_linkquality":255,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":134,"_pendingRequestTimeout":0,"meta":{"configured":-708457359}},"mapped":{"fingerprint":[{"modelID":"TS0601","manufacturerName":"_TZE200_bvu2wnxz"},{"modelID":"TS0601","manufacturerName":"_TZE200_6rdj8dzm"},{"modelID":"TS0601","manufacturerName":"_TZE200_p3dbf6qs"},{"modelID":"TS0601","manufacturerName":"_TZE200_rxntag7i"}],"model":"ME167","vendor":"AVATTO","description":"Thermostatic radiator valve","fromZigbee":[{"cluster":"manuSpecificTuya","type":["commandDataResponse","commandDataReport","commandActiveStatusReport","commandActiveStatusReportAlt"]}],"toZigbee":[{"key":["temperature_unit","temperature_calibration","humidity_calibration","alarm_switch","tamper_alarm_switch","state","brightness","min_brightness","max_brightness","power_on_behavior","position","alarm_melody","alarm_mode","countdown","light_type","silence","self_test","child_lock","open_window","open_window_temperature","frost_protection","system_mode","heating_stop","current_heating_setpoint","local_temperature_calibration","preset","boost_timeset_countdown","holiday_start_stop","holiday_temperature","comfort_temperature","eco_temperature","working_day","week_schedule_programming","online","holiday_mode_date","schedule","schedule_monday","schedule_tuesday","schedule_wednesday","schedule_thursday","schedule_friday","schedule_saturday","schedule_sunday","clear_fault","scale_protection","error","radar_scene","radar_sensitivity","tumble_alarm_time","tumble_switch","fall_sensitivity","min_temperature","max_temperature","window_detection","boost_heating","alarm_ringtone","alarm_time","fan_speed","reverse_direction","border","click_control","motor_direction","opening_mode","factory_reset","set_upper_limit","set_bottom_limit","motor_speed","timer","reset_frost_lock","schedule_periodic","schedule_weekday","schedule_holiday","backlight_mode","calibration","motor_steering","mode","lower","upper","delay","reverse","touch","program","light_mode","switch_mode","schedule_slot_1","schedule_slot_2","schedule_slot_3","schedule_slot_4","schedule_slot_5","schedule_slot_6","minimum_range","maximum_range","detection_delay","fading_time","radar_sensitivity","entry_sensitivity","illuminance_threshold","detection_range","shield_range","entry_distance_indentation","entry_filter_time","departure_delay","block_time","status_indication","breaker_mode","breaker_status","alarm","alarm_time","alarm_volume","type","volume","ringtone","duration","medium_motion_detection_distance","large_motion_detection_distance","large_motion_detection_sensitivity","small_motion_detection_distance","small_motion_detection_sensitivity","static_detection_distance","static_detection_sensitivity","keep_time","indicator","motion_sensitivity","detection_distance_max","detection_distance_min","presence_sensitivity","sensitivity","illuminance_interval","medium_motion_detection_sensitivity","small_detection_distance","small_detection_sensitivity","fan_mode","deadzone_temperature","eco_mode","max_temperature_limit","min_temperature_limit","manual_mode","medium_motion_detection_sensitivity","small_detection_distance","small_detection_sensitivity","switch_type","ph_max","ph_min","ec_max","ec_min","orp_max","orp_min","free_chlorine_max","free_chlorine_min","target_distance","illuminance_treshold_max","illuminance_treshold_min","presence_illuminance_switch","light_switch","light_linkage","indicator_light","find_switch","detection_method","sensor","hysteresis","max_temperature_protection","display_brightness","screen_orientation","regulator_period","regulator_set_point","upper_stroke_limit","middle_stroke_limit","lower_stroke_limit","buzzer_feedback","rf_pairing","max_temperature_alarm","min_temperature_alarm","max_humidity_alarm","min_humidity_alarm","temperature_periodic_report","humidity_periodic_report","temperature_sensitivity","humidity_sensitivity","temperature_alarm","humidity_alarm","move_sensitivity","radar_range","presence_timeout"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"whiteLabel":[{"vendor":"AVATTO","model":"ME167","description":"Thermostatic radiator valve","fingerprint":[{"manufacturerName":"_TZE200_bvu2wnxz"},{"manufacturerName":"_TZE200_6rdj8dzm"}]},{"vendor":"AVATTO","model":"ME168","description":"Thermostatic radiator valve","fingerprint":[{"manufacturerName":"_TZE200_p3dbf6qs"},{"manufacturerName":"_TZE200_rxntag7i"}]}],"exposes":[{"label":"Child lock","type":"lock","features":[{"name":"state","label":"State","access":3,"type":"binary","property":"child_lock","description":"Enables/disables physical input on the device","value_on":"LOCK","value_off":"UNLOCK"}]},{"name":"battery_low","label":"Battery low","access":1,"type":"binary","property":"battery_low","description":"Indicates if the battery of this device is almost empty","category":"diagnostic","value_on":true,"value_off":false},{"type":"climate","features":[{"name":"current_heating_setpoint","label":"Current heating setpoint","access":3,"type":"numeric","property":"current_heating_setpoint","description":"Temperature setpoint","unit":"°C","value_max":35,"value_min":5,"value_step":1},{"name":"local_temperature","label":"Local temperature","access":1,"type":"numeric","property":"local_temperature","description":"Current temperature measured on the device","unit":"°C"},{"name":"system_mode","label":"System mode","access":3,"type":"enum","property":"system_mode","description":"Mode of this device","values":["auto","heat","off"]},{"name":"running_state","label":"Running state","access":1,"type":"enum","property":"running_state","description":"The current running state","values":["idle","heat"]},{"name":"local_temperature_calibration","label":"Local temperature calibration","access":3,"type":"numeric","property":"local_temperature_calibration","description":"Offset to add/subtract to the local temperature","unit":"°C","value_max":9,"value_min":-9,"value_step":1}]},{"name":"schedule_monday","label":"Schedule monday","access":3,"type":"text","property":"schedule_monday","description":"Schedule for monday, format: \"HH:MM/C HH:MM/C HH:MM/C HH:MM/C HH:MM/C HH:MM/C\""},{"name":"schedule_tuesday","label":"Schedule tuesday","access":3,"type":"text","property":"schedule_tuesday","description":"Schedule for tuesday, format: \"HH:MM/C HH:MM/C HH:MM/C HH:MM/C HH:MM/C HH:MM/C\""},{"name":"schedule_wednesday","label":"Schedule wednesday","access":3,"type":"text","property":"schedule_wednesday","description":"Schedule for wednesday, format: \"HH:MM/C HH:MM/C HH:MM/C HH:MM/C HH:MM/C HH:MM/C\""},{"name":"schedule_thursday","label":"Schedule thursday","access":3,"type":"text","property":"schedule_thursday","description":"Schedule for thursday, format: \"HH:MM/C HH:MM/C HH:MM/C HH:MM/C HH:MM/C HH:MM/C\""},{"name":"schedule_friday","label":"Schedule friday","access":3,"type":"text","property":"schedule_friday","description":"Schedule for friday, format: \"HH:MM/C HH:MM/C HH:MM/C HH:MM/C HH:MM/C HH:MM/C\""},{"name":"schedule_saturday","label":"Schedule saturday","access":3,"type":"text","property":"schedule_saturday","description":"Schedule for saturday, format: \"HH:MM/C HH:MM/C HH:MM/C HH:MM/C HH:MM/C HH:MM/C\""},{"name":"schedule_sunday","label":"Schedule sunday","access":3,"type":"text","property":"schedule_sunday","description":"Schedule for sunday, format: \"HH:MM/C HH:MM/C HH:MM/C HH:MM/C HH:MM/C HH:MM/C\""},{"name":"scale_protection","label":"Scale protection","access":3,"type":"binary","property":"scale_protection","description":"If the heat sink is not fully opened within two weeks or is not used for a long time, the valve will be blocked due to silting up and the heat sink will not be able to be used. To ensure normal use of the heat sink, the controller will automatically open the valve fully every two weeks. It will run for 30 seconds per time with the screen displaying \"Ad\", then return to its normal working state again.","value_on":"ON","value_off":"OFF"},{"name":"frost_protection","label":"Frost protection","access":3,"type":"binary","property":"frost_protection","description":"When the room temperature is lower than 5 °C, the valve opens; when the temperature rises to 8 °C, the valve closes.","value_on":"ON","value_off":"OFF"},{"name":"error","label":"Error","access":1,"type":"numeric","property":"error","description":"If NTC is damaged, \"Er\" will be on the TRV display."},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"meta":{"tuyaDatapoints":[[2,"system_mode",{}],[3,"running_state",{}],[4,"current_heating_setpoint",{}],[5,"local_temperature","[Circular]"],[7,"child_lock",{}],[28,"schedule_monday",{}],[29,"schedule_tuesday",{}],[30,"schedule_wednesday",{}],[31,"schedule_thursday",{}],[32,"schedule_friday",{}],[33,"schedule_saturday",{}],[34,"schedule_sunday",{}],[35,null,{}],[36,"frost_protection",{}],[39,"scale_protection","[Circular]"],[47,"local_temperature_calibration",{}]]},"options":[]},"name":"0xa4c138fb1afe9099"} incoming event: {"type":"commandDataReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":30,"_applicationVersion":67,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":81,"inputClusters":[4,5,61184,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"65503":"�ѝ.i","65506":55,"65508":0,"65534":0,"modelId":"TS0601","manufacturerName":"_TZE200_6rdj8dzm","powerSource":3,"zclVersion":3,"appVersion":67,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"deviceIeeeAddress":"0xa4c138fb1afe9099","deviceNetworkAddress":31845,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138fb1afe9099"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138fb1afe9099","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1729094330966,"_manufacturerID":4417,"_manufacturerName":"_TZE200_6rdj8dzm","_modelID":"TS0601","_networkAddress":31845,"_powerSource":"Battery","_stackVersion":0,"_type":"EndDevice","_zclVersion":3,"_linkquality":255,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":134,"_pendingRequestTimeout":0,"meta":{"configured":-708457359}},"endpoint":"[Circular]","data":{"seq":21504,"dpValues":[{"dp":5,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,180]}}]},"linkquality":255,"groupID":null,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":134,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                2024-10-16 17:58:50.984  - debug: zigbee.0 (1149) Publish {"local_temperature":18} to "a4c138fb1afe9099"
                2024-10-16 17:58:50.996  - silly: zigbee.0 (1149) States user redis pmessage zigbee.0.*/zigbee.0.a4c138fb1afe9099.link_quality:{"val":255,"ack":true,"ts":1729094330993,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729093466203}
                2024-10-16 17:58:50.999  - silly: zigbee.0 (1149) States user redis pmessage zigbee.0.*/zigbee.0.a4c138fb1afe9099.msg_from_zigbee:{"val":"{\"type\":\"commandDataReport\",\"data\":{\"seq\":21504,\"dpValues\":[{\"dp\":5,\"datatype\":2,\"data\":{\"type\":\"Buffer\",\"data\":[0,0,0,180]}}]},\"linkquality\":255,\"groupID\":null,\"cluster\":\"manuSpecificTuya\",\"meta\":{\"zclTransactionSequenceNumber\":134,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}","ack":true,"ts":1729094330993,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729094330993}
                2024-10-16 17:58:51.079  - silly: zigbee.0 (1149) States user redis pmessage zigbee.0.*/zigbee.0.a4c138fb1afe9099.local_temperature:{"val":18,"ack":true,"ts":1729094331077,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729094331077}
                2024-10-16 17:58:51.079  - silly: heatingcontrol.0 (808) States user redis pmessage zigbee.0.a4c138fb1afe9099.local_temperature/zigbee.0.a4c138fb1afe9099.local_temperature:{"val":18,"ack":true,"ts":1729094331077,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729094331077}
                2024-10-16 17:58:51.080  - debug: heatingcontrol.0 (808) ### handle state change acked zigbee.0.a4c138fb1afe9099.local_temperature {"val":18,"ack":true,"ts":1729094331077,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729094331077}
                2024-10-16 17:58:51.080  - debug: heatingcontrol.0 (808) HandleStateChangeDevices zigbee.0.a4c138fb1afe9099.local_temperature
                2024-10-16 17:58:51.081  - debug: heatingcontrol.0 (808) CheckStateChangeDevice zigbee.0.a4c138fb1afe9099.local_temperature
                2024-10-16 17:58:51.081  - debug: heatingcontrol.0 (808) Kinderzimmer ### ChangeStatus Thermostats_Current to {"val":18,"ack":true,"ts":1729094331077,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1729094331077} in auto
                2024-10-16 17:58:51.081  - debug: heatingcontrol.0 (808) Change Status current temperature in Kinderzimmer to 18
                2024-10-16 17:58:51.081  - debug: heatingcontrol.0 (808) HandleActors for Kinderzimmer auto,  timers 0 PI false
                2024-10-16 17:58:51.081  - debug: heatingcontrol.0 (808) HandleActors: no actors and/or no thermostats in Kinderzimmer
                2024-10-16 17:58:51.081  - debug: heatingcontrol.0 (808) checking all actors
                2024-10-16 17:58:51.090  - debug: heatingcontrol.0 (808) UpdateDPs for Kinderzimmer auto
                2024-10-16 17:58:51.124  - debug: heatingcontrol.0 (808) AddStatusToLog skip Kinderzimmer auto 17°C
                  Und wie sehen die aus?
                  Mit welchen Optionen wird auf das NAS geschrieben? CIFS? NFS? FTP? Irrgendwas anderes?
                    Hei dies sind die Einstellungen...
                    sehen bei beiden Varianten gleich aus....mit eben dem vorher beschriebenen Verhalten
                      @mr-m
                      Setz mal beim NAS die Optionen noserverino und Cache Loose.
                      Sollten zwar eigentlich nur in anderen Szenarien notwendig sein, aber einen Versuch ist es wert.
                        hab ich gemacht... variante1
                        Habe in den Ausgaben den BackupBenutzerNamen UserName genannt.
                        Da in der Variante 2 das Protokoll nicht erstellt wird, habe ich die Zeitstempel von Hand rausgenommen..
                        daher das etwas andere Format
                        [DEBUG] [mount] mount activ... umount is started before mount!!
                        [DEBUG] [mount] umount successfully completed
                        [DEBUG] [mount] cifs-mount command: "sudo mount -t cifs -o username=UserName,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.35/backup /opt/iobroker/backups"
                        [DEBUG] [mount] mount successfully completed
                        [DEBUG] [mount] done
                        [DEBUG] [iobroker] host.Master 7915 states saved
                        [DEBUG] [iobroker] host.Master 10094 objects saved
                        [DEBUG] [iobroker] Backup created: /opt/iobroker/backups/iobroker_2024_10_16-19_19_02_backupiobroker.tar.gz
                        [DEBUG] [iobroker] This backup can only be restored with js-controller version up from 4.1
                        ****[ERROR] [iobroker] host.Master Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: ENOSPC: no space left on device, close****
                        [DEBUG] [iobroker] done
                        [DEBUG] [historyDB] compress from historyDB started ...
                        [DEBUG] [historyDB] Packed 11MB so far...
                        [DEBUG] [historyDB] Packed 26MB so far...
                        [DEBUG] [historyDB] Backup created: /opt/iobroker/backups/historyDB_2024_10_16-19_19_23_backupiobroker.tar.gz
                        [DEBUG] [historyDB] done
                        [DEBUG] [zigbee] found zigbee database: zigbee.0
                        [DEBUG] [zigbee] done
                        [ERROR] [zigbee] Error: ENOSPC: no space left on device, close
                        [WARN] [javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" cannot created ... Error: ENOSPC: no space left on device, mkdir '/opt/iobroker/backups/tmpScripts'
                        [ERROR] [javascripts] script.json cannot be written: Error: ENOENT: no such file or directory, open '/opt/iobroker/backups/tmpScripts/script.json'
                        [DEBUG] [javascripts] found Script: Gasskript
                        [DEBUG] [javascripts] found Script: Zählerstände
                        [DEBUG] [javascripts] found Script: FensterAufHeizkörperAus
                        [DEBUG] [javascripts] found Script: NurWarmwasser
                        [DEBUG] [javascripts] found Script: 6circle
                        [DEBUG] [javascripts] found Script: 6lightinancircle
                        [DEBUG] [javascripts] found Script: Bewegungsmelder
                        [DEBUG] [javascripts] found Script: Fernsehlicht
                        [DEBUG] [javascripts] found Script: Inividuelle_Helligkeit
                        [DEBUG] [javascripts] found Script: Badfenster
                        [DEBUG] [javascripts] found Script: Battery_Low
                        [DEBUG] [javascripts] found Script: Boiler_unter_46_5
                        [DEBUG] [javascripts] found Script: Boiler_über_49_2
                        [DEBUG] [javascripts] found Script: Gästetoilette
                        [DEBUG] [javascripts] found Script: Klofenster
                        [DEBUG] [javascripts] found Script: RolloNachbarn
                        [DEBUG] [javascripts] found Script: Rollos_rauf
                        [DEBUG] [javascripts] found Script: Rollos_runter
                        [DEBUG] [javascripts] found Script: Strom
                        [DEBUG] [javascripts] found Script: ABabören
                        [DEBUG] [javascripts] found Script: ical_converter
                        [DEBUG] [javascripts] found Script: Fenster_Status
                        [DEBUG] [javascripts] found Script: VAR_Berechnungen
                        [DEBUG] [javascripts] found Script: VAR_Energie_Bezug
                        [DEBUG] [javascripts] found Script: VAR_Solar_Einspeisung
                        [DEBUG] [javascripts] found Script: VAR_Zaelerstände
                        [WARN] [javascripts] javascript Backup not created
                        [DEBUG] [javascripts] done
                        [DEBUG] [cifs] used copy path: /backup
                        [DEBUG] [cifs] done
                        [ERROR] [clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                        [DEBUG] [clean] done
                        [DEBUG] [historyHTML] new history html values created
                        [DEBUG] [historyHTML] done
                        [DEBUG] [historyJSON] new history json values created
                        [DEBUG] [historyJSON] done
                        [DEBUG] [umount] mount active, umount is started ...
                        [DEBUG] [umount] umount successfully completed
                        [DEBUG] [umount] done
                        [DEBUG] [pushover] done
                        [DEBUG] [notification] Admin notification will be sent
                        [DEBUG] [notification] done
                        und mit der anderen Variante
                        INFOguiBackup gestartet ...
                        DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=UserName,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.36/backup /opt/iobroker/backups"
                        **DEBUGmountfirst mount attempt with smb option failed**. try next mount attempt without smb option ...
                        DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=UserName,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.36/backup /opt/iobroker/backups"
                        DEBUGmountError: Command failed: sudo mount -t cifs -o username=UserName,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.36/backup /opt/iobroker/backups
                        **mount error(111): could not connect to 192.168.178.36Unable to find suitable address**.
                        DEBUGiobrokerhost.Master 7916 states saved
                        DEBUGiobrokerhost.Master 10094 objects saved
                        DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_10_16-19_35_57_backupiobroker.tar.gz
                        DEBUGiobrokerThis backup can only be restored with js-controller version up from 4.1
                        DEBUGiobrokerdone
                        DEBUGhistoryDBcompress from historyDB started ...
                        DEBUGhistoryDBPacked 12MB so far...
                        DEBUGhistoryDBPacked 26MB so far...
                        DEBUGhistoryDBBackup created: /opt/iobroker/backups/historyDB_2024_10_16-19_36_21_backupiobroker.tar.gz
                        DEBUGhistoryDBdone
                        DEBUGzigbeefound zigbee database: zigbee.0
                        DEBUGzigbeedone
                        DEBUGjavascriptsCreated javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                        DEBUGjavascriptsfound Script: Gasskript
                        DEBUGjavascriptsfound Script: Zählerstände
                        DEBUGjavascriptsfound Script: FensterAufHeizkörperAus
                        DEBUGjavascriptsfound Script: NurWarmwasser
                        DEBUGjavascriptsfound Script: 6circle
                        DEBUGjavascriptsfound Script: 6lightinancircle
                        DEBUGjavascriptsfound Script: Bewegungsmelder
                        DEBUGjavascriptsfound Script: Fernsehlicht
                        DEBUGjavascriptsfound Script: Inividuelle_Helligkeit
                        DEBUGjavascriptsfound Script: Badfenster
                        DEBUGjavascriptsfound Script: Battery_Low
                        DEBUGjavascriptsfound Script: Boiler_unter_46_5
                        DEBUGjavascriptsfound Script: Boiler_über_49_2
                        DEBUGjavascriptsfound Script: Gästetoilette
                        DEBUGjavascriptsfound Script: Klofenster
                        DEBUGjavascriptsfound Script: RolloNachbarn
                        DEBUGjavascriptsfound Script: Rollos_rauf
                        DEBUGjavascriptsfound Script: Rollos_runter
                        DEBUGjavascriptsfound Script: Strom
                        DEBUGjavascriptsfound Script: ABabören
                        DEBUGjavascriptsfound Script: ical_converter
                        DEBUGjavascriptsfound Script: Fenster_Status
                        DEBUGjavascriptsfound Script: VAR_Berechnungen
                        DEBUGjavascriptsfound Script: VAR_Energie_Bezug
                        DEBUGjavascriptsfound Script: VAR_Solar_Einspeisung
                        DEBUGjavascriptsfound Script: VAR_Zaelerstände
                        DEBUGjavascriptsTry deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                        DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                        DEBUGjavascriptsdone
                        DEBUGcifsused copy path: /backup
                        DEBUGcifsdone
                        ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
                        DEBUGcleandone
                        DEBUGhistoryHTMLnew history html values created
                        DEBUGhistoryHTMLdone
                        DEBUGhistoryJSONnew history json values created
                        DEBUGhistoryJSONdone
                          @mr-m
                          Und worin bestehen die Unterschiede zwischen Variante 1 und 2?
                            wenn ich das wüsst... ich habe ja die screenshots geschickt....und die sind identisch...
                              @mr-m
                              Ich verstehe nicht was du mit Var 1 und Var 2 meinst.
                                ich habe die 2024_10_14-backitup.0.json und eine weitere die ein paar tage älter ist... habe aber nichts an den Einstellungen der instance geändert .
                                Kleine Zusammenfassung
                                -habe nichts gemacht 🙂
                                -bekomme eine message "....ENOSPC"
                                -nach erfolgloser Suche setzte ich den Post ab
                                -update der pending OS updates
                                -Erstellen einer neuen SD Karte mit bookworm-image
                                -Update des Os
                                -Installation iobroker
                                -Einspielen der Backup files (iobroker, zigbee und java skripts, historische daten)
                                Weiter bin ich nun leider nicht gekommen. Fehlerbild bleibt gleich.
                                Weiterhin habe ich nun mit bookworm auch keinen Zugriff auf die echarts mehr...die daten selbst sind ja noch da in den historischen Daten...aber das ist natürlich eine andere Baustelle.
                                Bis hierher erst einmal vielen Dank, ich hoffe morgen weiter testen zu können...
                                  Hallo Thomas,
                                  ich habe noch eine ganze Menge rumgemurkst.
                                  Einspielen älterer Backups. Backitup instance gelöscht, neu angelegt etc...OHNE backitup-config file, sondern händisch alle Einstellungen vorgenommen etc....alle erfolglos und es kommt immer wieder zum Szenario :
                                  ENOSPC no space left on device (hier ist ja offensichtlich der Raspi gemeint)
                                  Ein neuer Ansatz musste her, daher habe ich versucht per ftp die Sicherung auf mein NAS zu schieben, leider auch erfolglos. Zunächst kam es zu einem permission denied, welches ich schnell abgeräumt habe.
                                  Ich habe dann als Gegenprobe über den explorer per ftp aufs NAS zugegriffen was normal funktionierte.
                                  Als ich dann den backupjob gestartet habe gab es eine lapidare Log-Ausgabe die besagte es habe nicht geklappt ...because of some errors... nicht sehr aussagekräftig. Nun hatte ich auch keinen nerv mehr dieser Sache nachzugehen.
                                  Letzter Ansatz (der auch tadellos funktioniert) : Ich schiebe alles auf mein ms-one-drive.
                                  Dies ist natürlich nur ein Workaround und ändert ja nichts an dem grundsätzlichen Problem. Daher lasse ich den thread offen.
                                    Damit dürfte das eingehängte Dateisystem gemeint sein.
                                    backitup lokale datei löschen
                                    1387
