    4. Vis2 ab 09.01.2024 im stable
      Sandy @OliverIO last edited by
      @oliverio said in Vis2 ab morgen im stable:
      iobroker upload all
      Guten Morgen.
      Habe "iobroker upload all" gemacht aber es besteht immer noch der selbe Fehler 😞
       iobroker.vis-2@2.9.64 using theme "dark"
       Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters
       Help us to create open source project with reactJS!
       See you :)
       Sentry initialized
       Skip script "canvas-gauges" widgets/canvas-gauges/js/gauge.min.js
      5 Skip script "canvas-gauges" inline
      10 Skip script "colorpicker" inline
       Skip script "fancyswitch" widgets/fancyswitch/js/jquery-ui.toggleSwitch.js
       Skip script "fancyswitch" widgets/fancyswitch/js/jquery.ibutton.min.js
      8 Skip script "fancyswitch" inline
       Skip script "google-fonts" inline
       Skip script "info" ../adapter/info/lib/js/commons.js
       Skip script "info" ../adapter/info/lib/js/popupnews.js
       Skip script "info" widgets/info/js/info.js
      2 Skip script "info" inline
       Skip script "jqplot" widgets/jqplot/js/jquery.jqplot.min.js
      2 Skip script "jqplot" inline
       Version vis-jqui-mfd: 1.0.12
       Skip script "justgage" widgets/justgage/js/justgage.js
      4 Skip script "justgage" inline
      3 Skip script "map" inline
       Metro version: "1.2.0"
       Version vis-plumb: 1.0.0
      3 Skip script "swipe" inline
       Skip script "weather" widgets/weather/lib/js/lib/jquery.event.drag.js
       Skip script "weather" widgets/weather/lib/js/lib/jquery.mousewheel.js
       Skip script "weather" widgets/weather/lib/js/flot/jquery.canvaswrapper.js
       Skip script "weather" widgets/weather/lib/js/flot/jquery.colorhelpers.js
       Skip script "weather" widgets/weather/lib/js/flot/jquery.flot.js
       Skip script "weather" widgets/weather/lib/js/flot/jquery.flot.saturated.js
       Skip script "weather" widgets/weather/lib/js/flot/jquery.flot.browser.js
       Skip script "weather" widgets/weather/lib/js/flot/jquery.flot.drawSeries.js
       Skip script "weather" widgets/weather/lib/js/flot/jquery.flot.uiConstants.js
       Skip script "weather" widgets/weather/lib/js/flot/jquery.flot.time.js
       Skip script "weather" widgets/weather/lib/js/flot/jquery.flot.legend.js
       Skip script "weather" widgets/weather/lib/js/flot/jquery.flot.navigate.js
       Skip script "weather" widgets/weather/lib/js/flot/jquery.flot.touchNavigate.js
       Skip script "weather" widgets/weather/lib/js/flot/jquery.flot.hover.js
       Skip script "weather" widgets/weather/lib/js/flot/jquery.flot.touch.js
       Skip script "weather" widgets/weather/lib/js/flot/jquery.flot.selection.js
       Skip script "weather" widgets/weather/lib/js/flot/jquery.flot.axislabels.js
      2 Skip script "weather" inline
       Version material: 0.1.5
       Version trashschedule: 3.3.0
       Download the Vue Devtools extension for a better development experience:
      https://github.com/vuejs/vue-devtools
       You are running Vue in development mode.
      Make sure to turn on production mode when deploying for production.
      See more tips at https://vuejs.org/guide/deployment.html
       Version vis-materialdesign: 0.5.76
       vis-materialdesign: vibration supported by device: 'true'
       vis-materialdesign: sentry datapoint 'vis-materialdesign.0.sentry' not exist! Go to the adapter settings to activate it.
      (anonymous) @ main.8e80ccb0.js:2Understand this warning
       vis-materialdesign: click audio file '/vis.0/materialdesign-widgets-click-sound.mp3' not exists!
      :8082/vis-2/widgets/vis-2-widgets-jaeger-design/static/js/node_modules_iobroker_vis-2-widgets-react-dev_index_js-_081e0.187a47ed.chunk.js:1  Failed to load resource: the server responded with a status of 404 (Not Found)Understand this error
       Cannot load widget system.adapter.vis-2-widgets-jaeger-design.0: ChunkLoadError: Loading chunk node_modules_iobroker_vis-2-widgets-react-dev_index_js-_081e0 failed.
      (error: http://192.168.178.43:8082/vis-2/widgets/vis-2-widgets-jaeger-design/static/js/node_modules_iobroker_vis-2-widgets-react-dev_index_js-_081e0.187a47ed.chunk.js)
      (anonymous) @ main.8e80ccb0.js:2Understand this error
       Cannot load widget system.adapter.vis-2-widgets-jaeger-design.0: {"message":"Loading chunk node_modules_iobroker_vis-2-widgets-react-dev_index_js-_081e0 failed.\n(error: http://192.168.178.43:8082/vis-2/widgets/vis-2-widgets-jaeger-design/static/js/node_modules_iobroker_vis-2-widgets-react-dev_index_js-_081e0.187a47ed.chunk.js)","name":"ChunkLoadError","type":"error","request":"http://192.168.178.43:8082/vis-2/widgets/vis-2-widgets-jaeger-design/static/js/node_modules_iobroker_vis-2-widgets-react-dev_index_js-_081e0.187a47ed.chunk.js"}
       Cannot load widget system.adapter.vis-2-widgets-jaeger-design.0: ReferenceError: Cannot access 'x' before initialization
       Cannot load widget system.adapter.vis-2-widgets-jaeger-design.0: {}
       Translate: Write state
       Translate: jqui_Close
       Translate: jqui_input
       Translate: jqui_off
       Translate: jqui_on
       Translate: Value
       Ignored canvas-gauges/tplCGlinearGauge because not used in project
       Ignored canvas-gauges/tplCGradialGauge because not used in project
       Ignored canvas-gauges/tplCGCompas because not used in project
       Ignored canvas-gauges/tplCGflatGauge because not used in project
       Ignored colorpicker/tplRGBSpectrum because not used in project
       Ignored colorpicker/tplSpectrumHomematic because not used in project
       Ignored colorpicker/tplRGBFarbtastic because not used in project
       Ignored colorpicker/tplHUEjscolor because not used in project
       Ignored colorpicker/tplHUEPickerXY because not used in project
       Ignored colorpicker/tplHUEIndicatorXY because not used in project
       Ignored colorpicker/tplHUEPickerCT because not used in project
       Ignored colorpicker/tplHUEIndicatorCT because not used in project
       Ignored colorpicker/tplJscolor because not used in project
       Ignored fancyswitch/tplFancySwitch1 because not used in project
       Ignored fancyswitch/tplFancySwitch2 because not used in project
       Ignored fancyswitch/tplFancyDarkAnAus because not used in project
       Ignored fancyswitch/tplFancyDarkAnAusRev because not used in project
       Ignored fancyswitch/tplFancyDarkAnAusWippe because not used in project
       Ignored fancyswitch/tplFancyGivaIButton because not used in project
       Ignored fancyswitch/tplFancyToggleswitch because not used in project
       Ignored info/tplInfoMessages because not used in project
       Ignored info/tplInfoCalendar because not used in project
       Ignored jqplot/tplJqplotGauge because not used in project
       Ignored justgage/tplJustgageJustGage because not used in project
       Ignored justgage/tplJustgageValueColored because not used in project
       Ignored justgage/tplJustgageIndicatorColored because not used in project
       Ignored justgage/tplJustgageValueIndicatorColored because not used in project
       Ignored map/tplOsm because not used in project
       Ignored map/tplGoogleMap because not used in project
       Ignored swipe/tplSwipe because not used in project
       Ignored swipe/tplCarousel because not used in project
       Ignored weather/tplWeatherShowInstance because not used in project
       [2024-10-15T06:16:18.555Z] +SUBSCRIBE: ical.0.data.html
       [2024-10-15T06:16:18.562Z] +SUBSCRIBE: hm-rpc.0.OEQ0923598.1.STATE
       [2024-10-15T06:16:18.565Z] +SUBSCRIBE: hm-rpc.0.OEQ0923572.1.STATE
       [2024-10-15T06:16:18.567Z] +SUBSCRIBE: hm-rpc.0.NEQ1158750.1.STATE
      console.ts:40 [2024-10-15T06:16:18.567Z] +SUBSCRIBE: hm-rpc.0.NEQ1158750.1.LOWBAT
      console.ts:40 Version vis-hqwidgets: 1.5.1
      console.ts:40 [2024-10-15T06:16:18.569Z] +SUBSCRIBE: hm-rpc.0.OEQ1980740.1.STATE
      console.ts:40 [2024-10-15T06:16:18.571Z] +SUBSCRIBE: hm-rpc.0.OEQ2138145.1.STATE
      console.ts:40 [2024-10-15T06:16:18.571Z] +SUBSCRIBE: hm-rpc.0.OEQ2138145.1.LOWBAT
      console.ts:40 [2024-10-15T06:16:18.586Z] +SUBSCRIBE: hm-rpc.0.OEQ0923620.1.STATE
      console.ts:40 [2024-10-15T06:16:18.588Z] +SUBSCRIBE: hm-rpc.0.OEQ0923542.1.STATE
      console.ts:40 [2024-10-15T06:16:18.590Z] +SUBSCRIBE: hm-rpc.0.OEQ0924873.1.STATE
      console.ts:40 [2024-10-15T06:16:18.591Z] +SUBSCRIBE: hm-rpc.0.OEQ0923538.1.STATE
      console.ts:40 [2024-10-15T06:16:18.592Z] +SUBSCRIBE: tr-064.0.devices.nicogalaxys23plus.active
      console.ts:40 [2024-10-15T06:16:18.595Z] +SUBSCRIBE: hm-rega.0.22483
      console.ts:40 [2024-10-15T06:16:18.596Z] +SUBSCRIBE: ems-esp.0.heatingCircuits.hc1.roomtemperature
      console.ts:40 [2024-10-15T06:16:18.597Z] +SUBSCRIBE: hm-rpc.0.OEQ0662018.4.ACTUAL_TEMPERATURE
      console.ts:40 [2024-10-15T06:16:18.598Z] +SUBSCRIBE: hm-rpc.0.OEQ0662021.4.ACTUAL_TEMPERATURE
      console.ts:40 [2024-10-15T06:16:18.599Z] +SUBSCRIBE: hm-rpc.0.OEQ1251536.4.ACTUAL_TEMPERATURE
      console.ts:40 [2024-10-15T06:16:18.600Z] +SUBSCRIBE: hm-rpc.0.OEQ1251558.4.ACTUAL_TEMPERATURE
      console.ts:40 [2024-10-15T06:16:18.601Z] +SUBSCRIBE: ems-esp.0.system.sensors.temperatures.outdoor_t1
      console.ts:40 [2024-10-15T06:16:18.603Z] +SUBSCRIBE: midea.0.20890720963876.status.outdoorTemperature
      console.ts:40 [2024-10-15T06:16:18.605Z] +SUBSCRIBE: scene.0.Alarm.Einbrecher_Scheinwerfer
      console.ts:40 [2024-10-15T06:16:18.606Z] +SUBSCRIBE: hm-rpc.1.HmIP-RCV-1.28.PRESS_SHORT
      console.ts:40 [2024-10-15T06:16:18.609Z] +SUBSCRIBE: iot.0.services.custom_owntracks
      console.ts:40 [2024-10-15T06:16:18.610Z] +SUBSCRIBE: hm-rpc.0.OEQ0924753.1.STATE
      console.ts:40 [2024-10-15T06:16:18.612Z] +SUBSCRIBE: hm-rpc.0.OEQ0923521.1.STATE
      console.ts:40 [2024-10-15T06:16:18.637Z] +SUBSCRIBE: hm-rpc.0.BidCoS-RF.8.PRESS_SHORT
      console.ts:40 [2024-10-15T06:16:18.675Z] +SUBSCRIBE: tr-064.0.devices.Nico-Galaxy-S22.active
      console.ts:40 Version vis-timeandweather: 1.2.1
      query.yahooapis.com/v1/public/yql?q=select%20*%20from%20weather.forecast%20where%20woeid%20in%20(%27664942%27)%20and%20u%3D%27c%27&rnd=2024928&format=json&callback=jQuery111201235079405990629_1728972974104&_=1728972974105:1
             Failed to load resource: net::ERR_NAME_NOT_RESOLVEDUnderstand this error
      console.ts:40 vis-materialdesign: theme default 'colors' (light) successfully bound to css variables
      console.ts:40 vis-materialdesign: theme 'colors' (light) successfully bound to css variables
      console.ts:40 vis-materialdesign: theme default 'fonts' successfully bound to css variables
      console.ts:40 vis-materialdesign: theme 'fonts' successfully bound to css variables
      console.ts:40 vis-materialdesign: theme default 'font-sizes' successfully bound to css variables
      console.ts:40 vis-materialdesign: theme 'font-sizes' successfully bound to css variables
      console.ts:40 Translate: Please define states
      console.ts:40 Translate: Select object ID
      console.ts:40 [2024-10-15T06:16:24.043Z] +SUBSCRIBE: hm-rpc.0.OEQ0662018.4.SET_TEMPERATURE
      console.ts:40 [2024-10-15T06:16:24.044Z] +SUBSCRIBE: hm-rpc.0.OEQ0662018.4.VALVE_STATE
      console.ts:40 [2024-10-15T06:16:24.050Z] +SUBSCRIBE: hm-rpc.0.OEQ0662021.4.SET_TEMPERATURE
      console.ts:40 [2024-10-15T06:16:24.052Z] +SUBSCRIBE: hm-rpc.0.OEQ0662021.4.VALVE_STATE
      console.ts:40 [2024-10-15T06:16:24.055Z] +SUBSCRIBE: hm-rpc.0.OEQ0656186.4.SET_TEMPERATURE
      console.ts:40 [2024-10-15T06:16:24.057Z] +SUBSCRIBE: hm-rpc.0.OEQ0656186.4.VALVE_STATE
      console.ts:40 [2024-10-15T06:16:24.060Z] +SUBSCRIBE: hm-rpc.0.OEQ0656186.4.ACTUAL_TEMPERATURE
      console.ts:40 [2024-10-15T06:16:24.062Z] +SUBSCRIBE: hm-rpc.0.OEQ1251536.4.SET_TEMPERATURE
      console.ts:40 [2024-10-15T06:16:24.090Z] +SUBSCRIBE: hm-rpc.0.OEQ1251558.4.SET_TEMPERATURE
      console.ts:40 [2024-10-15T06:16:24.148Z] +SUBSCRIBE: hm-rpc.0.OEQ0655923.4.VALVE_STATE
      console.ts:40 [2024-10-15T06:16:24.150Z] +SUBSCRIBE: hm-rpc.0.OEQ0655923.4.SET_TEMPERATURE
      console.ts:40 [2024-10-15T06:16:24.152Z] +SUBSCRIBE: hm-rpc.0.OEQ0655923.4.ACTUAL_TEMPERATURE
      console.ts:40 [2024-10-15T06:16:24.155Z] +SUBSCRIBE: hm-rpc.0.OEQ0655923.4.CONTROL_MODE
      console.ts:40 [2024-10-15T06:16:24.158Z] +SUBSCRIBE: hm-rpc.0.OEQ0662018.4.CONTROL_MODE
      console.ts:40 [2024-10-15T06:16:24.159Z] +SUBSCRIBE: hm-rpc.0.OEQ0656186.4.CONTROL_MODE
      console.ts:40 [2024-10-15T06:16:24.161Z] +SUBSCRIBE: hm-rpc.0.OEQ0662021.4.CONTROL_MODE
      console.ts:40 [2024-10-15T06:16:24.167Z] +SUBSCRIBE: hm-rpc.0.OEQ1251536.4.VALVE_STATE
      console.ts:40 [2024-10-15T06:16:24.173Z] +SUBSCRIBE: hm-rpc.0.OEQ1251558.4.VALVE_STATE
      console.ts:40 [2024-10-15T06:16:24.176Z] +SUBSCRIBE: hm-rpc.0.OEQ1251550.4.SET_TEMPERATURE
      console.ts:40 [2024-10-15T06:16:24.178Z] +SUBSCRIBE: hm-rpc.0.OEQ1251550.4.VALVE_STATE
      console.ts:40 [2024-10-15T06:16:24.180Z] +SUBSCRIBE: hm-rpc.0.OEQ1251550.4.ACTUAL_TEMPERATURE
      console.ts:40 [2024-10-15T06:16:24.185Z] +SUBSCRIBE: hm-rpc.0.OEQ0656324.4.VALVE_STATE
      console.ts:40 [2024-10-15T06:16:24.188Z] +SUBSCRIBE: hm-rpc.0.OEQ0656324.4.SET_TEMPERATURE
      console.ts:40 [2024-10-15T06:16:24.190Z] +SUBSCRIBE: hm-rpc.0.OEQ0656324.4.ACTUAL_TEMPERATURE
      console.ts:40 [2024-10-15T06:16:24.192Z] +SUBSCRIBE: hm-rpc.0.OEQ0656324.4.CONTROL_MODE
      console.ts:40 [2024-10-15T06:16:24.194Z] +SUBSCRIBE: hm-rpc.0.OEQ1251536.4.CONTROL_MODE
      console.ts:40 [2024-10-15T06:16:24.196Z] +SUBSCRIBE: hm-rpc.0.OEQ1251550.4.CONTROL_MODE
      console.ts:40 [2024-10-15T06:16:24.199Z] +SUBSCRIBE: hm-rpc.0.OEQ1251558.4.CONTROL_MODE
      console.ts:40 [2024-10-15T06:16:24.202Z] +SUBSCRIBE: ems-esp.0.heatingCircuits.hc1.manualRoomSetpoint
      console.ts:40 [2024-10-15T06:16:24.203Z] +SUBSCRIBE: ems-esp.0.heatingCircuits.hc1.pumpModulation
      console.ts:40 [2024-10-15T06:16:24.206Z] +SUBSCRIBE: ems-esp.0.heatingCircuits.hc1.operationMode
      console.ts:40 [2024-10-15T06:16:24.261Z] +SUBSCRIBE: sonoff.0.Gosund_Heizung_Bett.POWER
      console.ts:40 [2024-10-15T06:16:24.262Z] +SUBSCRIBE: sonoff.0.Gosund_Heizung_Flur.POWER
      console.ts:40 [2024-10-15T06:16:24.264Z] +SUBSCRIBE: sonoff.0.Gosund_Heizung_Esszimmer.POWER
      console.ts:40 [2024-10-15T06:16:24.308Z] +SUBSCRIBE: sonoff.0.Tosmota_Heizlüfter_unten.POWER
      console.ts:40 [2024-10-15T06:16:24.309Z] +SUBSCRIBE: shelly.0.shellyplus1pm#fcb467a687c0#1.Relay0.Switch
      :8082/vis-2/?Nico#Heizung:1 Uncaught (in promise) Error: A listener indicated an asynchronous response by returning true, but the message channel closed before a response was receivedUnderstand this error
      • OliverIO
        @sandy dann diesen Adapter neu inst
          @oliverio habe jetzt den Adapter gelöscht und neu installiert aber das Problem ist immer noch das selbe 😞
          Weiß schon gar nicht mehr was ich noch machen soll 😞
          LG Sandy
          sigi234 S 2 Replies Last reply Reply Quote 0
            sigi234 Forum Testing Most Active @Sandy last edited by
            @sandy
            Browser Cache mal komplett geleert und System neu gestartet?
              Sandy @sigi234 last edited by Sandy
              @sigi234
              habe ich gerade gemacht, leider ohne Erfolg.
              Das ich die Lizenz nicht gekauft habe hat damit ja nichts zu tun oder ? Sie lief ja auch ohne das ich sie gekauft habe seit Monaten.
              OliverIO F 2 Replies Last reply Reply Quote 0
              • OliverIO
                OliverIO @Sandy last edited by OliverIO
                @sandy
                für privat ist die vis-2 lizenz kostenlos
                du musst dich nur auf der iobroker seite einloggen oder registrieren und dann bekommst du die lizenz über den lizenz reiter
                https://iobroker.net
                das jaeger-design kostet allerdings was. ob nur für kommerziell oder auch für privat weiß ich allerdings nicht. ist aber closed source, daher kann da wirklich nur der author helfen.
                  SilentM1978 @Sandy last edited by
                  @sandy "iobroker upload all" hat bei mir zum Erfolg geführt. Der Adapter funktioniert jetzt wieder.
                  • Negalein
                    Hallo
                    Wollte gerade am Zweitsystem (Test) die Lizenz für Vis-2 aktivieren.
                    Aber auf iobroker.net kann ich keine neue Lizenz kaufen.
                    Unter "Lizenzen" seh ich nur die vom Hauptsystem.
                    Ist für ein Zweitsystem ein eigener User auf iobroker.net nötig?
                    • OliverIO
                      OliverIO @SilentM1978 last edited by
                      @silentm1978 sagte in Vis2 ab morgen im stable:
                      iobroker upload all
                      hat sie wohl gemacht, aber ohne erfolg.
                      wenn ich mir die fehlermeldungen aus der browser console so anschaue, dann sind da noch andere sachen seltsam, die man sich mal anschauen muss
                      oder
                      wer da der verursacher ist, weiß ich nicht.
                      x sieht aber nicht nach iobroker aus.
                        Filo @Sandy last edited by Filo
                        @sandy,
                        ich habe ein ähnliches Problem mit Jaeger-widgets 1.3.1. Einige Widgets zeigen Fehler an und werden nicht angezeigt. Wenn ich den Jaeger-Widgets Adapter wieder auf 1.2.7 downgeade funktioniert wieder alles ganz normal..
                        Groß Filo
                        Edit: Nach erneutem "upload all" und Neutart jetzt keine Probleme mehr mit 1.3.1
                          Sandy @Filo last edited by
                          @filo
                          habe es jetzt ein paar mal probiert. Mit der 1.3.1 kommen immer diese Fehler. Aber der Tipp auf die alte Version 1.2.7 zurück zu gehen hat geklappt. Warum das mit der 1.3.1 nicht klappt weiß ich auch nicht aber ich überspringe dann erstmal diese Version 🙂
                          Danke für eure Hilfe
                          LG Sandy
                          • Feuersturm
                            Feuersturm @Sandy last edited by
                            @sandy bitte liegt ein entsprechendes issue an, ansonsten kann es vom Entwickler nicht analysiert werden. Ein Downgrade löst nicht das Problem in der Software 🙂
                              Sandy @Feuersturm last edited by
                              @feuersturm said in Vis2 ab morgen im stable:
                              habe ich erledigt 🙂
                                juergi last edited by
                                zuerst einmal möchte ich ein dickes Lob für die VIS 2 loswerden, ein tolles Tool, ich habe auch bereits gute Teile meiner alten VIS umgestellt. Für mich eines der ganz fetten Pluspunkte für den ioBroker.
                                Aber genau da liegt auch mein Problem:
                                Seit Monaten scheint sich da nichts mehr zu tun, die Issues werden wöchentlich mehr - auch meine eigenen liegen seit Mai schon da herum.
                                So macht die weitere Umstellung aber weder Sinn noch Spaß, da habe ich am Ende mehr Krücken und Workarounds drin als gut ist.
                                Ich will mich nicht beschweren, ich weiß wieviel Arbeit dahinter steckt, aber mir wäre mal eine Perspektive wichtig. Geht es da irgendwann weiter?
                                Und geht es nur mir so, dass ich auf Bugfixing und Verbesserungen warte?
                                sigi234 1 Reply Last reply Reply Quote 7
                                  sigi234 Forum Testing Most Active @juergi last edited by
                                  @juergi sagte in Vis2 ab morgen im stable:
                                  Nein, da bist du nicht alleine
                                  • icebear
                                    icebear last edited by icebear
                                    Ich hab grad meine VIS-2 von v2.9.64 auf die v.2.10.8 aktualisiert.
                                    Leider funktioniert jetzt das ausblenden der Navigationsleiste nicht mehr komplett.
                                    Die Option 'Nach Auswahl ausblenden' ist unter >Seite >Attribute aktiviert, die Navigationsleiste wird aber nur noch bis auf die Symbole zusammengeschoben. Vorher konnte ich nochmal auf die Show-Schaltfläche klicken und dann war die Leiste komplett weg, bis auf die Show-Schaltfläche.
                                    Issue: Issue 491
                                    P Bernd1967 2 Replies Last reply Reply Quote 0
                                      pdmetze @icebear last edited by
                                      @icebear ich hab ein anderes problem mit der vis-2 version und der vertikalen Navigation. Wenn ich sie zusammenklappen möchte, bleibt sie genau so wie sie ist, aber der content wird extrem schmal. Hab auch gerade ein issue in github aufgemacht #492
                                      • SMS
                                        SMS @icebear last edited by
                                        @icebear sagte in Vis2 ab morgen im stable:
                                        "contains_view_0": "Startseite",
                                        Hi! Sorry, greif das Thema kurz noch mal auf, da ich es nicht hinbekomme. Möchte von Grafana zwei Tabellen angezeigt bekommen.
                                        Wo muss ich jetzt noch mal was eintragen?
                                            "tpl": "tplStatefulIFrame8",
                                            "data": {
                                              "bindings": [],
                                              "oid": "0_userdata.0.Filter.14_Stromkosten",
                                              "refreshInterval": "0",
                                              "g_common": true,
                                              "count": "2",
                                              "src_1": "http://localhost:3000/d-solo/ae53e2c87evwge/stromkosten?orgId=1&from=now-24h&to=now&panelId=1\" width=\"450\" height=\"200\" frameborder=\"0\"",
                                              "noSandbox": null,
                                              "g_frames": true,
                                              "src_2": "http://localhost:3000/d-solo/ae53e2c87evwge/stromkosten?orgId=1&from=now-1M&to=now&panelId=3\" width=\"450\" height=\"200\" frameborder=\"0\""
                                            "style": {
                                              "bindings": [],
                                              "left": "30",
                                              "top": "720",
                                              "width": "1000",
                                              "height": "400"
                                            "widgetSet": "basic",
                                            "_id": "i000001"
                                        Umgeschaltet soll das mit dem "widget: Zustände steuern" funktionieren.
                                        Das "widget: Filtern! aus Vis 1 finde ich leider nicht mehr.
                                          daOlli @bahnuhr last edited by
                                          @bahnuhr hast du hierzu eventuell eine alternative gefunden? ich bin auch auf der suche nach den jqui buttons
                                          • bahnuhr
                                            bahnuhr Forum Testing Most Active @daOlli last edited by
                                            @daolli sagte in Vis2 ab morgen im stable:
                                            Na klar, nimm VIS 1
                                            422
                                            114235
