    4. Test Adapter onvif camera v1.x.x
      ewc @tombox last edited by
      @tombox
      Fehlermeldungen nicht direkt, aber noch ziemlich viel traffic
      2024-07-29 18:40:13.220 - silly: onvif.0 (1100) States user redis pmessage onvif.0./onvif.0.192_168_178_150_80.events.VideoSource/MotionAlarm:{"val":"VINToken0","ack":true,"ts":1722271213218,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722271213218}
      2024-07-29 18:40:13.223 - silly: onvif.0 (1100) States user redis pmessage onvif.0.
      /onvif.0.192_168_178_153_80.events.RuleEngine/CellMotionDetector/Motion_Rule:{"val":"MDRule0","ack":true,"ts":1722271213222,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722270646262}
      2024-07-29 18:40:13.223 - silly: onvif.0 (1100) States user redis pmessage onvif.0./onvif.0.192_168_178_153_80.events.RuleEngine/CellMotionDetector/Motion_VideoSourceConfigurationToken:{"val":"VINToken0_0","ack":true,"ts":1722271213223,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722270646238}
      /onvif.0.192_168_178_153_80.events.VideoSource/MotionAlarm:{"val":"VINToken0","ack":true,"ts":1722271213223,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722271213223}
      2024-07-29 18:40:13.224 - silly: onvif.0 (1100) States user redis pmessage onvif.0./onvif.0.192_168_178_150_80.events.RuleEngine/CellMotionDetector/Motion:{"val":false,"ack":true,"ts":1722271213223,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722270646148}
      2024-07-29 18:40:13.226 - silly: onvif.0 (1100) States user redis pmessage onvif.0.
      /onvif.0.192_168_178_150_80.events.RuleEngine/CellMotionDetector/Motion_VideoAnalyticsConfigurationToken:{"val":"VANToken0","ack":true,"ts":1722271213225,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722270646111}
      2024-07-29 18:40:13.226 - silly: onvif.0 (1100) States user redis pmessage onvif.0./onvif.0.192_168_178_150_80.events.VideoSource/MotionAlarm:{"val":false,"ack":true,"ts":1722271213226,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722271213226}
      2024-07-29 18:40:13.227 - silly: onvif.0 (1100) States user redis pmessage onvif.0.
      /onvif.0.192_168_178_153_80.events.RuleEngine/CellMotionDetector/Motion:{"val":false,"ack":true,"ts":1722271213226,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722270646288}
      2024-07-29 18:40:13.229 - silly: onvif.0 (1100) States user redis pmessage onvif.0./onvif.0.192_168_178_153_80.events.RuleEngine/CellMotionDetector/Motion_VideoAnalyticsConfigurationToken:{"val":"VANToken0","ack":true,"ts":1722271213228,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722270646247}
      /onvif.0.192_168_178_153_80.events.VideoSource/MotionAlarm:{"val":false,"ack":true,"ts":1722271213228,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1722271213228}
      Ich glaube, ich schmeiße die beiden Kameras doch noch in die Tonne, bevor Du deinen Adapter vergewaltigen musst
        tombox @ewc last edited by
        @ewc Problem ist also behoben sehr gut
        Du solltest das log level auf info setzen und nicht auf silly
          @tombox said in Test Adapter onvif camera v1.x.x:
          @ewc
          ist schon erledigt... war ja nur für den Wunsch nach einem Log
          Hab Dank
            c3b last edited by
            Hi Leutz
            Ich hänge mich mal hier dran. Ich habe schon gesucht, aber nichts gefunden.
            Ich habe eine Reolink E1 Outdoor am Kabel hängen. Alle erkannten Alarme werden auf meinen FTP-Server geschickt. Jedes Mal ein Bild und ein Video.
            Im iobroker habe ich sie mit dem onfiv-Adapter eingefügt.
            Wenn ich jetzt von Hand einen snapshot auslöse, erstellt er keinen Datenpunkt mit der URL in dem Ordner Remote. Wenn ich die URL aus dem Info-Ordner eingebe, zeigt er mir den snapshot an. Will aber immer einen Benutzer und ein Kennwort.
            Mein Ziel ist es, das Bild, welches er zum FTP-Server schickt per Telegramm auf mein Handy zu schicken.
            Jetzt habe ich hier gelesen, dass es mit dem Reolink-Adapter gehen soll. So habe ich das zumindest verstanden.
            Also installiert und eingerichtet. V 1.1.1. Funktioniert auch. Adapter ist grün, objekte sind angelegt.
            Aber wie geht es jetzt weiter? Ich sehe keinen snapshot bzw. eine URL.
            Kann mir da jemand weiterhelfen? Ich lese schon die ganze Zeit auf github, werde aber nicht richtig schlau daraus.
            LG aus dem Sauerland
            Jörg
            • XBiT
              XBiT last edited by
              @c3b
              Kann dir leider nicht direkt helfen da ich selbst keine Reolink Kamera habe.
              Wollte dir nur den Tipp geben da es ja bei deiner Frage mehr um den Reolink-Adapter geht, diese eventuell besser hier zu stellen.
              Da kann dir sicher schneller jemand helfen.
                bommel_030 @c3b last edited by
                @c3b
                Der Reolink-Adapter erstellt meines Wissens keine Snapshots, aber das ist mit nem Blockly doch leicht erledigt.
                Trigger nebst Konditionen anpassen und ggf. Telegram verfeinern. Funktioniert mit hier ner E1 Outdoor PoE problemlos.
                 <block type="on_ext" id="I6{E8q1TwHTCti=gNWYU" x="-712" y="-62">
                   <value name="OID0">
                     <shadow type="field_oid" id="0[4DFJ{$Y#II4lwDBR-4">
                       <field name="oid">alias.0.Zimmer.EG.Flur.Fenster</field>
                     <block type="field_oid" id="r^#Z/B^0ok0t.GgT~gcg">
                       <field name="oid">ID auswählen</field>
                     <block type="exec" id="7y|0nSY]!//y,4P70]W)">
                       <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                       <field name="WITH_STATEMENT">TRUE</field>
                       <field name="LOG"></field>
                       <value name="COMMAND">
                         <shadow type="text" id="QL]`;3dY(Vl[w27L]E$h">
                           <field name="TEXT">wget -O /opt/iobroker/Eingang.jpg "http://192.168.10.95/cgi-bin/api.cgi?cmd=Snap&amp;channel=0&amp;rs=wuuPhkmUCeI9WG7C&amp;user=userename&amp;password=passwort"</field>
                         <block type="telegram" id="{(|fFOBclDO+P+3R:83*">
                           <field name="INSTANCE">.0</field>
                           <field name="ESCAPING">FALSE</field>
                           <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field>
                           <value name="MESSAGE">
                             <shadow type="text" id="ycSmBrHt+l+k=pv/Sn~k">
                               <field name="TEXT">/opt/iobroker/Eingang.jpg</field>
                  c3b last edited by
                  @ XBiT
                  Danke für die Info. Ich versuche mal da mein Glück.
                  @ bommel_030
                  Danke für das Blockly. So ganz schnalle ich das noch nicht. Mit exec habe ich noch gar nichts gemacht. Sollte die Objekt ID eine Bewegungserkennung sein? Der Pfad im Telegramm weist auf ein Unterverzeichnis im iobroker hin. Wie bekommst du da die Bilder hin? Ich tippe mal darauf, das der wget-Befehl das Bild dort hin kopiert.
                  Kannst du mir noch ein paar mehr Infos geben?
                  Jörg
                    lemmymania last edited by lemmymania
                    @tombox
                    Hallo, ich und zwar habe ich eine "SV3C - C13" und eine von "X-Serie" kamera welche auch über die IP erkannt wird im ONVIF Adapter.
                    Aber mit folgender meldung (zumindest bei der SV3C):
                    danach sieht man unter Objekte folgendes:
                    klicke ich auf "snapshot" wird auch ein neues Foto erzeugt. Aber unter dem Pfad "Event" kann ich leider keine einträge erkennen.
                    Mache ich etwas falsch weil unter Events nicht erscheint ? Oder werden diese kameras dann nicht vom Adapter unterstüzt ?
                    D matze55 2 Replies Last reply Reply Quote 0
                      denjo @lemmymania last edited by
                      Hallo, ich habe mir Kameras von IMOU geholt und bin eigentlich recht zufrieden damit. ich habe sie über go2rtc in meine vis eingebunden, nur leider wenn sich mein internet neu verbindet um ca 3 Uhr morgens läuft es auf meiner vis nicht. sobald ich die kameras in der app neu starte läuft es wieder. deswegen würde ich sie gerne über onvif neustarten lassen. leider klappt das nicht mit dem adapter, aber mit dem Windows Programm ODM-Onvif klappt das. könnte man die Funktion in den Adapter einbringen????
                      • matze55
                        matze55 @lemmymania last edited by matze55
                        @lemmymania möchtest du nur die Bilder angezeigt haben? Du musst in der Vis das widget ,,string img src,, auswählen. Dann unter den Objekten die ID ==>>onvif.0.192_168_178_**_****.snapshot auswählen da der Adapter onvif es verschlüsselt in base64.
                        Der Datenpunkt zeigt doch an. Es wird aber immer nur ein Bild gespeichert, danch wird es überschrieben bei einem neuen Bild.
                        lg
                          exitus last edited by exitus
                          @tombox Hallo
                          habe annke nc 800 kameras habe die onvif ports und username passwort richtig eingegeben aber er findet die kameras nicht kann jemand mir helfen ???
                          Data: null xml: undefined
                          onvif.0
                          2025-05-21 12:42:02.017	info	Error Error: connect EHOSTUNREACH 192.168.0.53:80
                          onvif.0
                          2025-05-21 12:42:02.015	error	Failed to login to 192.168.0.53:80 with admin:*********
                          onvif.0
                          2025-05-21 12:41:58.944	info	Data: null xml: undefined
                          onvif.0
                          2025-05-21 12:41:58.943	info	Error Error: socket hang up
                          onvif.0
                          2025-05-21 12:41:58.942	error	Failed to login to 192.168.0.52:443 with admin:*********
                          onvif.0
                          2025-05-21 12:41:58.935	info	Data: null xml: undefined
                          onvif.0
                          2025-05-21 12:41:58.934	info	Error Error: read ECONNRESET
                          onvif.0
                          2025-05-21 12:41:58.934	error	Failed to login to 192.168.0.52:8000 with admin:E*********1
                          onvif.0
                          2025-05-21 12:41:58.926	info	Data: null xml: <!DOCTYPE html> <html><head><title>Document Error: Not Found</title></head> <body><h2>Access Error: 404 -- Not Found</h2> <p>Request Refuse: ONVIF integrate function is disabled.</p> </body> </html>
                          onvif.0
                          2025-05-21 12:41:58.921	info	Error Error: Wrong ONVIF SOAP response
                          onvif.0
                          2025-05-21 12:41:58.921	error	Failed to login to 192.168.0.52:80 with admin:*****
                          wendy2702 T 2 Replies Last reply Reply Quote 0
                          • wendy2702
                            wendy2702 @exitus last edited by
                            @exitus sagte in Test Adapter onvif camera v1.x.x:
                            annke nc 800
                            Laut Google Onvif Port 8080, sehe ich in deinem Log nicht. Hast du den eingestellt?
                            Screenshot Adapter config
                              tombox @exitus last edited by
                              @exitus Port 8000 sagt: " ONVIF integrate function is disabled"
                                exitus @tombox last edited by
                                @tombox also die Onvif port ist aktiv der Recorder verbindet sich auch ich schaue mal genauer hin. Die port sind 8000
                                  @exitus Teste mal mit ODM
                                  https://sourceforge.net/projects/onvifdm/files/latest/download
                                  E 2 Replies Last reply Reply Quote 0
                                    @tombox danke erstmal ich habe ein neuen user angelegt und jetzt klappt es.
                                    Wie kann ich jetzt zu telegramm bilder schicken????
                                    • wendy2702
                                      @exitus in dem du die Forensuche benutzt.
                                      Es gibt gefühlt 1000 Beiträge dazu.
                                        @tombox so Verbindung habe ich die Datenpunkte sind auch da , habe eine Frage die NC800 sind sehr gut bei der Personen Erkennung , ich habe kein, Datenpunkt gesehen der bei dieser Event auslöst . Original bekommt Alarm aber es gibt kein Datenpunkt für diese Erkennung . Es gib nur Motiondection der bei alles Alarm gibt.
                                        Die Frage ist dieser Option mit programmiert oder muss ich an der Kamera was anderes einstellen einstellen ?? ich möchte gerne den Datenpunkt haben, der bei Personen ausgibt.
                                        • wendy2702
                                          @exitus Habe nur Reolink,
                                          da gibt es "events". Hast du die nicht?
                                            exitus @wendy2702 last edited by
                                            @wendy2702 doch habe ich , aber es aktualisiert sich bei jede bewegung welche ist nur auf person ?
                                            onvif.0.192_168_0_51_80.events.RuleEngine/FieldDetector/ObjectsInside
                                            hier passiert nichts
                                            31.7k
                                            79.8k
                                            339
                                            50755
