    4. [gelöst] Backitup bleibt bei Redis Backup hängen
    • simatec
      simatec Developer Most Active @Qlink last edited by
      @qlink Läuft Redis denn auch in deinem Docker Container? Wenn ja… passt der Pfad?
      • Q
        Qlink @simatec last edited by Qlink
        @simatec
        Ja Redis läuft in einem eigenen Container.
        Wie muss der Pfad lauten ? Den hab ich auf Standard gelassen...
        Hier die Volume Einstellungen von dem redis container:
        • simatec
          @qlink Dann geht natürlich kein lokales Redis Backup. Du musst auf dem iobroker Host redis-cli installiert haben und per remote auf den Redis Container zugreifen.
          Genaueres findest du in der Doku.
          https://github.com/simatec/ioBroker.backitup/wiki/ioBroker.backitup-Wiki-Deutsch#redis-backup
          • Q
            @simatec
            Danke das war der entscheidende Hinweis !
            Ich habe auf remote umgestellt und schon läuft das Backup durch 🙂
            11:26:18.350INFOguiBackup gestartet ...
            [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:00","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","redis":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"aof":false,"nameSuffix":"","slaveSuffix":"","hostType":"Single","path":"/data/dump.rdb","redisType":"remote","host":"redis","port":"6379","user":"","pass":"","ignoreErrors":false},"nodered":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"backup@multimediaberatung.at","emailSender":"iobroker@multimediaberatung.at","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1728725128009}
            11:26:22.877DEBUGiobrokerhost.iobroker 49861 states saved
            11:26:28.809DEBUGiobrokerhost.iobroker 60002 objects saved
            11:26:34.750DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_10_12-11_25_28_backupiobroker.tar.gz
            11:26:34.766DEBUGiobrokerThis backup can only be restored with js-controller version up from 4.1
            11:26:35.744DEBUGiobrokerdone
            11:26:36.511DEBUGredisStart Redis Backup ...
            11:26:36.532DEBUGredisCreated new redistmp directory
            11:26:56.560DEBUGredisPacked 15MB so far...
            11:27:06.827DEBUGredisPacked 91MB so far...
            11:27:16.528DEBUGredisPacked 193MB so far...
            11:27:26.560DEBUGredisPacked 302MB so far...
            11:27:36.598DEBUGredisPacked 406MB so far...
            11:27:46.532DEBUGredisPacked 516MB so far...
            11:27:54.569DEBUGredisBackup created: /opt/iobroker/backups/redis-remote_2024_10_12-11_25_45_backupiobroker.tar.gz
            11:27:54.578DEBUGredisTry deleting the redis tmp directory: "/opt/iobroker/backups/redistmp"
            11:27:54.583DEBUGredisdone
            11:27:55.925DEBUGnoderedCreated nodered tmp directory
            11:27:55.945DEBUGnoderedNode-Red tmp copy finish
            11:27:55.997DEBUGnoderedBackup created: /opt/iobroker/backups/nodered.0_2024_10_12-11_27_05_backupiobroker.tar.gz
            11:27:56.009DEBUGnoderedTry deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
            11:27:56.026DEBUGnodereddone
            11:27:57.238DEBUGcleandone
            11:27:57.368DEBUGhistoryHTMLnew history html values created
            11:27:57.381DEBUGhistoryHTMLdone
            11:27:57.528DEBUGhistoryJSONnew history json values created
            11:27:57.542DEBUGhistoryJSONdone
            [DEBUG] [historyHTML] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:00","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","redis":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"aof":false,"nameSuffix":"","slaveSuffix":"","hostType":"Single","path":"/data/dump.rdb","redisType":"remote","host":"redis","port":"6379","user":"","pass":"","ignoreErrors":false},"nodered":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"12. Oktober 2024 um 11:27 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"backup@multimediaberatung.at","emailSender":"iobroker@multimediaberatung.at","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1728725128009,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
            [DEBUG] [historyJSON] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:00","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","redis":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"aof":false,"nameSuffix":"","slaveSuffix":"","hostType":"Single","path":"/data/dump.rdb","redisType":"remote","host":"redis","port":"6379","user":"","pass":"","ignoreErrors":false},"nodered":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"12. Oktober 2024 um 11:27 Uhr"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"backup@multimediaberatung.at","emailSender":"iobroker@multimediaberatung.at","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1728725128009,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
            11:27:57.990DEBUGemail[iobroker] used E-Mail-Instance: email.0
            11:27:58.008DEBUGemaildone
            [DEBUG] [email] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:00","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","redis":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"aof":false,"nameSuffix":"","slaveSuffix":"","hostType":"Single","path":"/data/dump.rdb","redisType":"remote","host":"redis","port":"6379","user":"","pass":"","ignoreErrors":false},"nodered":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"backup@multimediaberatung.at","emailSender":"iobroker@multimediaberatung.at","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de","time":"12. Oktober 2024 um 11:27 Uhr"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1728725128009,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
            [DEBUG] [notification] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:00","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","redis":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"aof":false,"nameSuffix":"","slaveSuffix":"","hostType":"Single","path":"/data/dump.rdb","redisType":"remote","host":"redis","port":"6379","user":"","pass":"","ignoreErrors":false},"nodered":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"backup@multimediaberatung.at","emailSender":"iobroker@multimediaberatung.at","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de","time":"12. Oktober 2024 um 11:27 Uhr"},"backupDir":"/opt/iobroker/backups","timestamp":1728725128009,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
            11:28:00.043DEBUGnotificationdone
            11:28:00.197INFOguiDas Backup wurde erfolgreich erstellt!
            Danke für deine Hilfe !
            Beste Grüße
            • simatec
              @qlink kein Problem 😉
              • Q
                Qlink last edited by Qlink
                @simatec
                Jetzt bin ich leider doch noch auf ein Problem gestoßen:
                Nachdem das Backup wie oben eingestellt ist gibt es jetzt scheinbar ein Problem mit dem SQL Backup 😞
                Das iobroker Backup startet um 02:00 Uhr, wenn ich in der Früh auf den iobroker schaue, ist jetzt aber immer die SQL Instanz deaktiviert.
                Ich muss sie also jeden Tag manuell starten, was auch ohne Fehler funktioniert.
                Scheinbar findet er die SQL Instanz nicht mehr, dabei hat das Backup schon ohne Probleme funktioniert (siehe Beitrag weiter oben) ?
                Hier wäre ein Log von heute:
                2024-10-18 01:59:59.142  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (72, 1729209599141, 0, 0, 8, 0);
                2024-10-18 01:59:59.142  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 01:59:59.158  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:00.028  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 22995
                2024-10-18 02:00:00.034  - debug: sql.0 (17845) pushValueIntoDB called for 0_userdata.0.Uptime.DS1821+_Uptime (type: 1, ID: 255) and state: {"val":"172d 22h 18min","ack":true,"ts":1729209600024,"q":0,"c":"script.js.Umrechnungen.DS1821+_Uptime_Sekunden_in_Tage_Stunden_Minuten","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600024}
                2024-10-18 02:00:00.034  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for 0_userdata.0.Uptime.DS1821+_Uptime
                2024-10-18 02:00:00.034  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for 0_userdata.0.Uptime.DS1821+_Uptime (type: 1, ID: 255) and state: {"val":"172d 22h 18min","ack":true,"ts":1729209600024,"q":0,"c":"script.js.Umrechnungen.DS1821+_Uptime_Sekunden_in_Tage_Stunden_Minuten","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600024}: undefined
                2024-10-18 02:00:00.036  - debug: sql.0 (17845) pushValueIntoDB called for 0_userdata.0.Uptime.Fortigate_40F_Uptime (type: 1, ID: 254) and state: {"val":"8d 12h 29min","ack":true,"ts":1729209600030,"q":0,"c":"script.js.Umrechnungen.Fortigate_40F_Uptime_Sekunden_in_Tage_Stunden_Minuten","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600030}
                2024-10-18 02:00:00.037  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for 0_userdata.0.Uptime.Fortigate_40F_Uptime
                2024-10-18 02:00:00.037  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for 0_userdata.0.Uptime.Fortigate_40F_Uptime (type: 1, ID: 254) and state: {"val":"8d 12h 29min","ack":true,"ts":1729209600030,"q":0,"c":"script.js.Umrechnungen.Fortigate_40F_Uptime_Sekunden_in_Tage_Stunden_Minuten","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600030}: undefined
                2024-10-18 02:00:00.053  - debug: sql.0 (17845) pushValueIntoDB called for javascript.0.ccu.uptime (type: 0, ID: 145) and state: {"val":4499.29,"ack":true,"ts":1729209600048,"q":0,"c":"script.js.Systemstats.CCU_Monitoring","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600048}
                2024-10-18 02:00:00.053  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for javascript.0.ccu.uptime
                2024-10-18 02:00:00.053  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for javascript.0.ccu.uptime (type: 0, ID: 145) and state: {"val":4499.29,"ack":true,"ts":1729209600048,"q":0,"c":"script.js.Systemstats.CCU_Monitoring","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600048}: undefined
                2024-10-18 02:00:00.054  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (145, 1729209600048, 4499.29, 1, 4, 0);
                2024-10-18 02:00:00.054  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:00.078  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:00.131  - debug: sql.0 (17845) pushValueIntoDB called for javascript.0.ccu.systemTemperature (type: 0, ID: 146) and state: {"val":49.4,"ack":true,"ts":1729209480124,"q":0,"c":"script.js.Systemstats.CCU_Monitoring","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209360127}
                2024-10-18 02:00:00.131  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for javascript.0.ccu.systemTemperature
                2024-10-18 02:00:00.131  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for javascript.0.ccu.systemTemperature (type: 0, ID: 146) and state: {"val":49.4,"ack":true,"ts":1729209480124,"q":0,"c":"script.js.Systemstats.CCU_Monitoring","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209360127}: undefined
                2024-10-18 02:00:00.131  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (146, 1729209480124, 49.4, 1, 4, 0);
                2024-10-18 02:00:00.131  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:00.131  - debug: sql.0 (17845) pushValueIntoDB called for javascript.0.ccu.systemTemperature (type: 0, ID: 146) and state: {"val":51,"ack":true,"ts":1729209600128,"q":0,"c":"script.js.Systemstats.CCU_Monitoring","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600128}
                2024-10-18 02:00:00.132  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for javascript.0.ccu.systemTemperature (type: 0, ID: 146) and state: {"val":51,"ack":true,"ts":1729209600128,"q":0,"c":"script.js.Systemstats.CCU_Monitoring","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600128}: undefined
                2024-10-18 02:00:00.147  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:00.148  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (146, 1729209600128, 51, 1, 4, 0);
                2024-10-18 02:00:00.149  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:00.169  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:00.213  - debug: sql.0 (17845) pushValueIntoDB called for javascript.0.ccu.cpuFrequency (type: 0, ID: 147) and state: {"val":1200,"ack":true,"ts":1729209600211,"q":0,"c":"script.js.Systemstats.CCU_Monitoring","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600211}
                2024-10-18 02:00:00.213  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for javascript.0.ccu.cpuFrequency
                2024-10-18 02:00:00.213  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for javascript.0.ccu.cpuFrequency (type: 0, ID: 147) and state: {"val":1200,"ack":true,"ts":1729209600211,"q":0,"c":"script.js.Systemstats.CCU_Monitoring","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600211}: undefined
                2024-10-18 02:00:00.213  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (147, 1729209600211, 1200, 1, 4, 0);
                2024-10-18 02:00:00.213  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:00.231  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:01.440  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":56,"ack":true,"ts":1729209601439,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209601439}
                2024-10-18 02:00:01.440  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.temperature
                2024-10-18 02:00:01.440  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":56,"ack":true,"ts":1729209601439,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209601439}: undefined
                2024-10-18 02:00:01.440  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (241, 1729209601439, 56, 1, 27, 0);
                2024-10-18 02:00:01.440  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:01.459  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:01.673  - debug: sql.0 (17845) pushValueIntoDB called for modbus.0.inputRegisters.30537_Tagesertrag (type: 0, ID: 56) and state: {"val":0,"ack":true,"ts":1729209601673,"q":0,"from":"system.adapter.sql.0","user":"system.user.admin","lc":1729202401650}
                2024-10-18 02:00:01.673  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for modbus.0.inputRegisters.30537_Tagesertrag
                2024-10-18 02:00:01.673  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for modbus.0.inputRegisters.30537_Tagesertrag (type: 0, ID: 56) and state: {"val":0,"ack":true,"ts":1729209601673,"q":0,"from":"system.adapter.sql.0","user":"system.user.admin","lc":1729202401650}: undefined
                2024-10-18 02:00:01.673  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (56, 1729209601673, 0, 1, 8, 0);
                2024-10-18 02:00:01.673  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:01.687  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:04.043  - info: host.iobroker instance system.adapter.ical.2 started with pid 23013
                2024-10-18 02:00:05.503  - info: ical.2 (23013) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.1, js-controller: 5.0.19
                2024-10-18 02:00:05.625  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":58,"ack":true,"ts":1729209605623,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209605623}
                2024-10-18 02:00:05.626  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.temperature
                2024-10-18 02:00:05.626  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":58,"ack":true,"ts":1729209605623,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209605623}: undefined
                2024-10-18 02:00:05.626  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (241, 1729209605623, 58, 1, 27, 0);
                2024-10-18 02:00:05.626  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:05.644  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.memory_usage (type: 0, ID: 243) and state: {"val":50,"ack":true,"ts":1729209605640,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209605640}
                2024-10-18 02:00:05.644  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.memory_usage
                2024-10-18 02:00:05.644  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.memory_usage (type: 0, ID: 243) and state: {"val":50,"ack":true,"ts":1729209605640,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209605640}: undefined
                2024-10-18 02:00:05.652  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:05.652  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (243, 1729209605640, 50, 1, 27, 0);
                2024-10-18 02:00:05.653  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:05.672  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:06.142  - info: ical.2 (23013) processing URL: Abfallkalender-mfpmmb.gmail.com https://calendar.google.com/calendar/ical/mfpmmb%40gmail.com/private-19c13d45e459539e837664778cd79c79/basic.ics
                2024-10-18 02:00:07.237  - debug: sql.0 (17845) pushValueIntoDB called for nut.0.input.voltage (type: 1, ID: 248) and state: {"val":"234.0","ack":true,"ts":1729209607235,"q":0,"from":"system.adapter.nut.0","user":"system.user.admin","lc":1729209307228}
                2024-10-18 02:00:07.237  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for nut.0.input.voltage
                2024-10-18 02:00:07.237  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for nut.0.input.voltage (type: 1, ID: 248) and state: {"val":"234.0","ack":true,"ts":1729209607235,"q":0,"from":"system.adapter.nut.0","user":"system.user.admin","lc":1729209307228}: undefined
                2024-10-18 02:00:07.435  - debug: sql.0 (17845) pushValueIntoDB called for 0_userdata.0.Fortigate.WAN-Incoming-Mbit (type: 0, ID: 249) and state: {"val":0.1,"ack":true,"ts":1729209592430,"q":0,"c":"script.js.Umrechnungen.Fortigate-Traffic","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209577432}
                2024-10-18 02:00:07.436  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for 0_userdata.0.Fortigate.WAN-Incoming-Mbit
                2024-10-18 02:00:07.436  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for 0_userdata.0.Fortigate.WAN-Incoming-Mbit (type: 0, ID: 249) and state: {"val":0.1,"ack":true,"ts":1729209592430,"q":0,"c":"script.js.Umrechnungen.Fortigate-Traffic","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209577432}: undefined
                2024-10-18 02:00:07.436  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (249, 1729209592430, 0.1, 1, 4, 0);
                2024-10-18 02:00:07.436  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:07.436  - debug: sql.0 (17845) pushValueIntoDB called for 0_userdata.0.Fortigate.WAN-Incoming-Mbit (type: 0, ID: 249) and state: {"val":0.2,"ack":true,"ts":1729209607433,"q":0,"c":"script.js.Umrechnungen.Fortigate-Traffic","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209607433}
                2024-10-18 02:00:07.436  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for 0_userdata.0.Fortigate.WAN-Incoming-Mbit (type: 0, ID: 249) and state: {"val":0.2,"ack":true,"ts":1729209607433,"q":0,"c":"script.js.Umrechnungen.Fortigate-Traffic","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209607433}: undefined
                2024-10-18 02:00:07.436  - debug: sql.0 (17845) pushValueIntoDB called for 0_userdata.0.Fortigate.WAN-Outgoing-Mbit (type: 0, ID: 250) and state: {"val":4.2,"ack":true,"ts":1729209592430,"q":0,"c":"script.js.Umrechnungen.Fortigate-Traffic","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209577432}
                2024-10-18 02:00:07.436  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for 0_userdata.0.Fortigate.WAN-Outgoing-Mbit
                2024-10-18 02:00:07.436  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for 0_userdata.0.Fortigate.WAN-Outgoing-Mbit (type: 0, ID: 250) and state: {"val":4.2,"ack":true,"ts":1729209592430,"q":0,"c":"script.js.Umrechnungen.Fortigate-Traffic","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209577432}: undefined
                2024-10-18 02:00:07.437  - debug: sql.0 (17845) pushValueIntoDB called for 0_userdata.0.Fortigate.WAN-Outgoing-Mbit (type: 0, ID: 250) and state: {"val":8.5,"ack":true,"ts":1729209607433,"q":0,"c":"script.js.Umrechnungen.Fortigate-Traffic","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209607433}
                2024-10-18 02:00:07.437  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for 0_userdata.0.Fortigate.WAN-Outgoing-Mbit
                2024-10-18 02:00:07.437  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for 0_userdata.0.Fortigate.WAN-Outgoing-Mbit (type: 0, ID: 250) and state: {"val":8.5,"ack":true,"ts":1729209607433,"q":0,"c":"script.js.Umrechnungen.Fortigate-Traffic","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209607433}: undefined
                2024-10-18 02:00:07.454  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:07.454  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (249, 1729209607433, 0.2, 1, 4, 0);
                2024-10-18 02:00:07.455  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:07.469  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:07.471  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (250, 1729209592430, 4.2, 1, 4, 0),(250, 1729209607433, 8.5, 1, 4, 0);
                2024-10-18 02:00:07.471  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:07.484  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:07.633  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":57,"ack":true,"ts":1729209607632,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209607632}
                2024-10-18 02:00:07.633  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.temperature
                2024-10-18 02:00:07.633  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":57,"ack":true,"ts":1729209607632,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209607632}: undefined
                2024-10-18 02:00:07.633  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (241, 1729209607632, 57, 1, 27, 0);
                2024-10-18 02:00:07.633  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:07.646  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:07.686  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2024-10-18 02:00:08.052  - info: host.iobroker instance system.adapter.ical.1 started with pid 23042
                2024-10-18 02:00:09.072  - debug: sql.0 (17845) pushValueIntoDB called for system.host.iobroker.mem (type: 0, ID: 123) and state: {"val":51,"ack":true,"ts":1729209594067,"q":0,"from":"system.host.iobroker","lc":1729207824050}
                2024-10-18 02:00:09.072  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for system.host.iobroker.mem
                2024-10-18 02:00:09.072  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for system.host.iobroker.mem (type: 0, ID: 123) and state: {"val":51,"ack":true,"ts":1729209594067,"q":0,"from":"system.host.iobroker","lc":1729207824050}: undefined
                2024-10-18 02:00:09.073  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (123, 1729209594067, 51, 1, 12, 0);
                2024-10-18 02:00:09.073  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:09.073  - debug: sql.0 (17845) pushValueIntoDB called for system.host.iobroker.mem (type: 0, ID: 123) and state: {"val":52,"ack":true,"ts":1729209609067,"q":0,"from":"system.host.iobroker","lc":1729209609067}
                2024-10-18 02:00:09.073  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for system.host.iobroker.mem
                2024-10-18 02:00:09.073  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for system.host.iobroker.mem (type: 0, ID: 123) and state: {"val":52,"ack":true,"ts":1729209609067,"q":0,"from":"system.host.iobroker","lc":1729209609067}: undefined
                2024-10-18 02:00:09.074  - debug: sql.0 (17845) pushValueIntoDB called for system.host.iobroker.cpu (type: 0, ID: 122) and state: {"val":0.67,"ack":true,"ts":1729209609071,"q":0,"from":"system.host.iobroker","lc":1729209609071}
                2024-10-18 02:00:09.075  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for system.host.iobroker.cpu
                2024-10-18 02:00:09.075  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for system.host.iobroker.cpu (type: 0, ID: 122) and state: {"val":0.67,"ack":true,"ts":1729209609071,"q":0,"from":"system.host.iobroker","lc":1729209609071}: undefined
                2024-10-18 02:00:09.102  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:09.104  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (123, 1729209609067, 52, 1, 12, 0);
                2024-10-18 02:00:09.104  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:09.132  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:09.132  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (122, 1729209609071, 0.67, 1, 12, 0);
                2024-10-18 02:00:09.133  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:09.159  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:09.355  - info: ical.1 (23042) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.1, js-controller: 5.0.19
                2024-10-18 02:00:09.679  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":35,"ack":true,"ts":1729209609679,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209609679}
                2024-10-18 02:00:09.680  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.cpu_load
                2024-10-18 02:00:09.680  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":35,"ack":true,"ts":1729209609679,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209609679}: undefined
                2024-10-18 02:00:09.680  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (242, 1729209609679, 35, 1, 27, 0);
                2024-10-18 02:00:09.680  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:09.696  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:10.014  - debug: backitup.0 (568) Backup has started ...
                2024-10-18 02:00:11.295  - info: ical.2 (23013) Terminated (NO_ERROR): Without reason
                2024-10-18 02:00:11.814  - info: host.iobroker instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
                2024-10-18 02:00:11.825  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":58,"ack":true,"ts":1729209611824,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209611824}
                2024-10-18 02:00:11.825  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.temperature
                2024-10-18 02:00:11.825  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":58,"ack":true,"ts":1729209611824,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209611824}: undefined
                2024-10-18 02:00:11.825  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (241, 1729209611824, 58, 1, 27, 0);
                2024-10-18 02:00:11.826  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:11.848  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:12.063  - info: host.iobroker instance system.adapter.ical.0 started with pid 23070
                2024-10-18 02:00:13.887  - info: ical.0 (23070) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.1, js-controller: 5.0.19
                2024-10-18 02:00:14.224  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":59,"ack":true,"ts":1729209614223,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209614223}
                2024-10-18 02:00:14.225  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.temperature
                2024-10-18 02:00:14.225  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":59,"ack":true,"ts":1729209614223,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209614223}: undefined
                2024-10-18 02:00:14.225  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (241, 1729209614223, 59, 1, 27, 0);
                2024-10-18 02:00:14.225  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:14.237  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":39,"ack":true,"ts":1729209614235,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209614235}
                2024-10-18 02:00:14.237  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.cpu_load
                2024-10-18 02:00:14.237  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":39,"ack":true,"ts":1729209614235,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209614235}: undefined
                2024-10-18 02:00:14.259  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:14.261  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (242, 1729209614235, 39, 1, 27, 0);
                2024-10-18 02:00:14.261  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:14.282  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:15.123  - info: ical.1 (23042) processing URL: Magdalena https://outlook.office365.com/owa/calendar/1b4051cc812a43b38177057e14fe3d1d@langthaler.co/a5ae21dbe3f54bf8ad2462b30d51d06614501199648262372113/calendar.ics
                2024-10-18 02:00:15.263  - debug: backitup.0 (568) [iobroker/iobroker] host.iobroker 49916 states saved
                2024-10-18 02:00:17.264  - debug: sql.0 (17845) pushValueIntoDB called for nut.0.input.voltage (type: 1, ID: 248) and state: {"val":"234.0","ack":true,"ts":1729209617264,"q":0,"from":"system.adapter.nut.0","user":"system.user.admin","lc":1729209307228}
                2024-10-18 02:00:17.265  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for nut.0.input.voltage
                2024-10-18 02:00:17.265  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for nut.0.input.voltage (type: 1, ID: 248) and state: {"val":"234.0","ack":true,"ts":1729209617264,"q":0,"from":"system.adapter.nut.0","user":"system.user.admin","lc":1729209307228}: undefined
                2024-10-18 02:00:18.322  - info: ical.0 (23070) processing URL: Gerald https://outlook.office365.com/owa/calendar/83b88f98b9a842a087bc908a81726653@langthaler.co/66f51c2dcb55428da093bb0c45e7c5ac3783454353823405424/calendar.ics
                2024-10-18 02:00:18.439  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":50,"ack":true,"ts":1729209618437,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209618437}
                2024-10-18 02:00:18.439  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.cpu_load
                2024-10-18 02:00:18.439  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":50,"ack":true,"ts":1729209618437,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209618437}: undefined
                2024-10-18 02:00:18.440  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (242, 1729209618437, 50, 1, 27, 0);
                2024-10-18 02:00:18.440  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:18.476  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:20.693  - info: ical.1 (23042) Terminated (NO_ERROR): Without reason
                2024-10-18 02:00:21.207  - info: host.iobroker instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                2024-10-18 02:00:21.906  - debug: backitup.0 (568) [iobroker/iobroker] host.iobroker 60065 objects saved
                2024-10-18 02:00:22.377  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":58,"ack":true,"ts":1729209622376,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209622376}
                2024-10-18 02:00:22.377  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.temperature
                2024-10-18 02:00:22.377  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":58,"ack":true,"ts":1729209622376,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209622376}: undefined
                2024-10-18 02:00:22.377  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (241, 1729209622376, 58, 1, 27, 0);
                2024-10-18 02:00:22.377  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:22.381  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":52,"ack":true,"ts":1729209622381,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209622381}
                2024-10-18 02:00:22.382  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.cpu_load
                2024-10-18 02:00:22.382  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":52,"ack":true,"ts":1729209622381,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209622381}: undefined
                2024-10-18 02:00:22.385  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.memory_usage (type: 0, ID: 243) and state: {"val":52,"ack":true,"ts":1729209622383,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209622383}
                2024-10-18 02:00:22.385  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.memory_usage
                2024-10-18 02:00:22.385  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.memory_usage (type: 0, ID: 243) and state: {"val":52,"ack":true,"ts":1729209622383,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209622383}: undefined
                2024-10-18 02:00:22.395  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:22.397  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (242, 1729209622381, 52, 1, 27, 0);
                2024-10-18 02:00:22.397  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:22.410  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:22.410  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (243, 1729209622383, 52, 1, 27, 0);
                2024-10-18 02:00:22.410  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:22.422  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:23.612  - info: ical.0 (23070) Terminated (NO_ERROR): Without reason
                2024-10-18 02:00:24.071  - debug: sql.0 (17845) pushValueIntoDB called for system.host.iobroker.mem (type: 0, ID: 123) and state: {"val":55,"ack":true,"ts":1729209624068,"q":0,"from":"system.host.iobroker","lc":1729209624068}
                2024-10-18 02:00:24.071  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for system.host.iobroker.mem
                2024-10-18 02:00:24.071  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for system.host.iobroker.mem (type: 0, ID: 123) and state: {"val":55,"ack":true,"ts":1729209624068,"q":0,"from":"system.host.iobroker","lc":1729209624068}: undefined
                2024-10-18 02:00:24.071  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (123, 1729209624068, 55, 1, 12, 0);
                2024-10-18 02:00:24.071  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:24.078  - debug: sql.0 (17845) pushValueIntoDB called for system.host.iobroker.cpu (type: 0, ID: 122) and state: {"val":0.27,"ack":true,"ts":1729209624073,"q":0,"from":"system.host.iobroker","lc":1729209624073}
                2024-10-18 02:00:24.078  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for system.host.iobroker.cpu
                2024-10-18 02:00:24.078  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for system.host.iobroker.cpu (type: 0, ID: 122) and state: {"val":0.27,"ack":true,"ts":1729209624073,"q":0,"from":"system.host.iobroker","lc":1729209624073}: undefined
                2024-10-18 02:00:24.097  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:24.098  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (122, 1729209624073, 0.27, 1, 12, 0);
                2024-10-18 02:00:24.098  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:24.120  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:24.136  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                2024-10-18 02:00:24.333  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":57,"ack":true,"ts":1729209624332,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209624332}
                2024-10-18 02:00:24.333  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.temperature
                2024-10-18 02:00:24.333  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":57,"ack":true,"ts":1729209624332,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209624332}: undefined
                2024-10-18 02:00:24.333  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (241, 1729209624332, 57, 1, 27, 0);
                2024-10-18 02:00:24.333  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:24.349  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:26.374  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":58,"ack":true,"ts":1729209626373,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209626373}
                2024-10-18 02:00:26.374  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.temperature
                2024-10-18 02:00:26.374  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":58,"ack":true,"ts":1729209626373,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209626373}: undefined
                2024-10-18 02:00:26.374  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (241, 1729209626373, 58, 1, 27, 0);
                2024-10-18 02:00:26.374  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:26.378  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":30,"ack":true,"ts":1729209626378,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209626378}
                2024-10-18 02:00:26.378  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.cpu_load
                2024-10-18 02:00:26.378  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":30,"ack":true,"ts":1729209626378,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209626378}: undefined
                2024-10-18 02:00:26.389  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:26.389  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (242, 1729209626378, 30, 1, 27, 0);
                2024-10-18 02:00:26.390  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:26.400  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:27.237  - debug: sql.0 (17845) pushValueIntoDB called for nut.0.input.voltage (type: 1, ID: 248) and state: {"val":"232.0","ack":true,"ts":1729209627237,"q":0,"from":"system.adapter.nut.0","user":"system.user.admin","lc":1729209627237}
                2024-10-18 02:00:27.238  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for nut.0.input.voltage
                2024-10-18 02:00:27.238  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for nut.0.input.voltage (type: 1, ID: 248) and state: {"val":"232.0","ack":true,"ts":1729209627237,"q":0,"from":"system.adapter.nut.0","user":"system.user.admin","lc":1729209627237}: undefined
                2024-10-18 02:00:27.355  - debug: backitup.0 (568) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2024_10_18-02_00_10_backupiobroker.tar.gz
                2024-10-18 02:00:27.356  - debug: backitup.0 (568) [iobroker/iobroker] This backup can only be restored with js-controller version up from 4.1
                2024-10-18 02:00:28.316  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":57,"ack":true,"ts":1729209628316,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209628316}
                2024-10-18 02:00:28.316  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.temperature
                2024-10-18 02:00:28.317  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":57,"ack":true,"ts":1729209628316,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209628316}: undefined
                2024-10-18 02:00:28.317  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (241, 1729209628316, 57, 1, 27, 0);
                2024-10-18 02:00:28.317  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:28.329  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:28.404  - debug: backitup.0 (568) [iobroker/iobroker] done
                2024-10-18 02:00:28.676  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49611 (type: 1, ID: 86) and state: {"val":"O","ack":true,"ts":1729209628676,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209568690}
                2024-10-18 02:00:28.677  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for hm-rega.0.49611
                2024-10-18 02:00:28.677  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49611 (type: 1, ID: 86) and state: {"val":"O","ack":true,"ts":1729209628676,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209568690}: undefined
                2024-10-18 02:00:28.705  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.62800 (type: 0, ID: 155) and state: {"val":989.23,"ack":true,"ts":1729209628705,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209628705}
                2024-10-18 02:00:28.705  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for hm-rega.0.62800
                2024-10-18 02:00:28.705  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.62800 (type: 0, ID: 155) and state: {"val":989.23,"ack":true,"ts":1729209628705,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209628705}: undefined
                2024-10-18 02:00:28.706  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (155, 1729209628705, 989.23, 1, 2, 0);
                2024-10-18 02:00:28.706  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:28.720  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:29.006  - debug: backitup.0 (568) [iobroker/sqlite] Start SQLite3 Backup ...
                2024-10-18 02:00:29.011  - debug: backitup.0 (568) [iobroker/sqlite] sql.0 is stopped
                2024-10-18 02:00:29.013  - info: host.iobroker instance "system.adapter.sql.0" disabled via .alive
                2024-10-18 02:00:29.015  - error: backitup.0 (568) [iobroker/sqlite] Error: Command failed: sqlite3 /opt/iobroker/iobroker-data/sqlite/sqlite.db .dump > /opt/iobroker/backups/sqlite_2024_10_18-02_00_29_backupiobroker.sql
                2024-10-18 02:00:29.020  - info: host.iobroker "system.adapter.sql.0" disabled
                2024-10-18 02:00:29.021  - info: host.iobroker stopInstance system.adapter.sql.0 (force=false, process=true)
                2024-10-18 02:00:29.015  - error: backitup.0 (568) [iobroker/sqlite] /bin/sh: 1: sqlite3: not found
                2024-10-18 02:00:29.015  - error: backitup.0 (568) [iobroker] Error: Command failed: sqlite3 /opt/iobroker/iobroker-data/sqlite/sqlite.db .dump > /opt/iobroker/backups/sqlite_2024_10_18-02_00_29_backupiobroker.sql
                2024-10-18 02:00:29.028  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.30165 (type: 0, ID: 9) and state: {"val":18.65,"ack":true,"ts":1729209208664,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729208818656}
                2024-10-18 02:00:29.028  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for hm-rega.0.30165
                2024-10-18 02:00:29.028  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.30165 (type: 0, ID: 9) and state: {"val":18.65,"ack":true,"ts":1729209208664,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729208818656}: undefined
                2024-10-18 02:00:29.029  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.36508 (type: 0, ID: 14) and state: {"val":56.1,"ack":true,"ts":1729209628666,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209628666}
                2024-10-18 02:00:29.029  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for hm-rega.0.36508
                2024-10-18 02:00:29.029  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.36508 (type: 0, ID: 14) and state: {"val":56.1,"ack":true,"ts":1729209628666,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209628666}: undefined
                2024-10-18 02:00:29.029  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.36507 (type: 0, ID: 15) and state: {"val":21.45,"ack":true,"ts":1729208368653,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729208068655}
                2024-10-18 02:00:29.029  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for hm-rega.0.36507
                2024-10-18 02:00:29.029  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.36507 (type: 0, ID: 15) and state: {"val":21.45,"ack":true,"ts":1729208368653,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729208068655}: undefined
                2024-10-18 02:00:29.032  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (15, 1729208368653, 21.45, 1, 2, 0);
                2024-10-18 02:00:29.032  - debug: sql.0 (17845) Borrow connection from pool: 1 now
                2024-10-18 02:00:29.044  - debug: sql.0 (17845) Return connection to pool: 0 now
                2024-10-18 02:00:29.763  - info: sql.0 (17845) terminating
                2024-10-18 02:00:29.763  - debug: sql.0 (17845) Plugin sentry destroyed
                2024-10-18 02:00:29.764  - info: sql.0 (17845) Terminated (NO_ERROR): Without reason
                2024-10-18 02:00:30.027  - debug: sql.0 (17845) pushValueIntoDB called for javascript.0.Netzbezug.Gesamtverbrauch (type: 0, ID: 62) and state: {"val":355.23333333333335,"ack":false,"ts":1729209626645,"q":0,"c":"script.js.Umrechnungen.Berechnung_Gesamtverbrauch1_V2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209626645}
                2024-10-18 02:00:30.027  - warn: sql.0 (17845) No Connection to database
                2024-10-18 02:00:30.028  - debug: sql.0 (17845) pushValueIntoDB called for javascript.0.Netzbezug.kW (type: 0, ID: 65) and state: {"val":0,"ack":true,"ts":1729209626645,"q":0,"c":"script.js.Umrechnungen.Umrechnung_Netzbezug_W_in_kW_V2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1551003543474}
                2024-10-18 02:00:30.028  - warn: sql.0 (17845) No Connection to database
                2024-10-18 02:00:30.028  - debug: sql.0 (17845) pushValueIntoDB called for javascript.0.Netzbezug.PV_Leistung (type: 0, ID: 68) and state: {"val":0,"ack":true,"ts":1729181933598,"q":0,"c":"script.js.Umrechnungen.PVLeistung_auf_0_limitieren","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729181933598}
                2024-10-18 02:00:30.028  - debug: sql.0 (17845) pushValueIntoDB called for javascript.0.Netzbezug.Eingangsspannung (type: 0, ID: 69) and state: {"val":800,"ack":true,"ts":1729181933448,"q":0,"c":"script.js.Umrechnungen.PV_Eingangsspannung_auf_900_limitieren","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729181933448}
                2024-10-18 02:00:30.028  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.WAERMEPUMPE.LEISTUNGSAUFNAHME.P_WW_TAG (type: 0, ID: 76) and state: {"val":0.754,"ack":true,"ts":1729209582732,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729202451191}
                2024-10-18 02:00:30.028  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.WAERMEPUMPE.LEISTUNGSAUFNAHME.P_HEIZUNG_TAG (type: 0, ID: 77) and state: {"val":0.73,"ack":true,"ts":1729209582732,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729202451191}
                2024-10-18 02:00:30.028  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.VERDICHTER_HEIZEN (type: 0, ID: 78) and state: {"val":1013,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729170408861}
                2024-10-18 02:00:30.028  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.ELEKTR_NE_WW (type: 0, ID: 79) and state: {"val":0,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1728812217521}
                2024-10-18 02:00:30.028  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.VERDICHTER_WW (type: 0, ID: 80) and state: {"val":220,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729151862282}
                2024-10-18 02:00:30.029  - warn: sql.0 (17845) No Connection to database
                2024-10-18 02:00:30.029  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.VERDICHTER_KUEHLEN (type: 0, ID: 81) and state: {"val":53,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1728812217521}
                2024-10-18 02:00:30.029  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.ELEKTR_NE_HEIZEN (type: 0, ID: 82) and state: {"val":0,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1728812217521}
                2024-10-18 02:00:30.029  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.ANLAGE.RAUMTEMPERATUR.RAUMFEUCHTE_HK2 (type: 0, ID: 83) and state: {"val":52.7,"ack":true,"ts":1729209580854,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729206760840}
                2024-10-18 02:00:30.029  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.ANLAGE.HEIZEN.AUSSENTEMPERATUR (type: 0, ID: 84) and state: {"val":14.5,"ack":true,"ts":1729209580855,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729209220926}
                2024-10-18 02:00:30.029  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.ANLAGE.RAUMTEMPERATUR.RAUMISTTEMP_HK2 (type: 0, ID: 85) and state: {"val":24.1,"ack":true,"ts":1729209580854,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729207540840}
                2024-10-18 02:00:30.029  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49607 (type: 0, ID: 87) and state: {"val":0,"ack":true,"ts":1729209538665,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1728944545694}
                2024-10-18 02:00:30.029  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49615 (type: 0, ID: 88) and state: {"val":0,"ack":true,"ts":1729209628683,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729029656858}
                2024-10-18 02:00:30.030  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49610 (type: 0, ID: 89) and state: {"val":-10.3,"ack":true,"ts":1729209568688,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209568688}
                2024-10-18 02:00:30.030  - warn: sql.0 (17845) No Connection to database
                2024-10-18 02:00:30.030  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49602 (type: 0, ID: 90) and state: {"val":0,"ack":true,"ts":1729209628673,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209208693}
                2024-10-18 02:00:30.030  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49601 (type: 0, ID: 91) and state: {"val":0,"ack":true,"ts":1729209628672,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729208398662}
                2024-10-18 02:00:30.030  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49612 (type: 0, ID: 92) and state: {"val":0,"ack":true,"ts":1729209628677,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1725487252453}
                2024-10-18 02:00:30.030  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49609 (type: 0, ID: 93) and state: {"val":0,"ack":true,"ts":1729209628675,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1694728863383}
                2024-10-18 02:00:30.030  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.48846 (type: 0, ID: 94) and state: {"val":0,"ack":true,"ts":1729209628672,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209208688}
                2024-10-18 02:00:30.030  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49604 (type: 0, ID: 95) and state: {"val":0,"ack":true,"ts":1729209568685,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1710558066291}
                2024-10-18 02:00:30.030  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49608 (type: 0, ID: 96) and state: {"val":0,"ack":true,"ts":1729209568687,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1694682992674}
                2024-10-18 02:00:30.030  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.48832 (type: 0, ID: 97) and state: {"val":0,"ack":true,"ts":1729209568675,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1620435699829}
                2024-10-18 02:00:30.031  - warn: sql.0 (17845) No Connection to database
                2024-10-18 02:00:30.031  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49606 (type: 0, ID: 98) and state: {"val":13.9,"ack":true,"ts":1729209568686,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209568686}
                2024-10-18 02:00:30.031  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49600 (type: 0, ID: 99) and state: {"val":100,"ack":true,"ts":1729209568683,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729175248354}
                2024-10-18 02:00:30.031  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for javascript.0.Netzbezug.Gesamtverbrauch (type: 0, ID: 62) and state: {"val":355.23333333333335,"ack":false,"ts":1729209626645,"q":0,"c":"script.js.Umrechnungen.Berechnung_Gesamtverbrauch1_V2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209626645}: No Connection to database
                2024-10-18 02:00:30.031  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for javascript.0.Netzbezug.kW (type: 0, ID: 65) and state: {"val":0,"ack":true,"ts":1729209626645,"q":0,"c":"script.js.Umrechnungen.Umrechnung_Netzbezug_W_in_kW_V2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1551003543474}: No Connection to database
                2024-10-18 02:00:30.032  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for javascript.0.Netzbezug.PV_Leistung (type: 0, ID: 68) and state: {"val":0,"ack":true,"ts":1729181933598,"q":0,"c":"script.js.Umrechnungen.PVLeistung_auf_0_limitieren","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729181933598}: No Connection to database
                2024-10-18 02:00:30.032  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for javascript.0.Netzbezug.Eingangsspannung (type: 0, ID: 69) and state: {"val":800,"ack":true,"ts":1729181933448,"q":0,"c":"script.js.Umrechnungen.PV_Eingangsspannung_auf_900_limitieren","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729181933448}: No Connection to database
                2024-10-18 02:00:30.032  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.WAERMEPUMPE.LEISTUNGSAUFNAHME.P_WW_TAG (type: 0, ID: 76) and state: {"val":0.754,"ack":true,"ts":1729209582732,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729202451191}: No Connection to database
                2024-10-18 02:00:30.032  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.WAERMEPUMPE.LEISTUNGSAUFNAHME.P_HEIZUNG_TAG (type: 0, ID: 77) and state: {"val":0.73,"ack":true,"ts":1729209582732,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729202451191}: No Connection to database
                2024-10-18 02:00:30.033  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.VERDICHTER_HEIZEN (type: 0, ID: 78) and state: {"val":1013,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729170408861}: No Connection to database
                2024-10-18 02:00:30.033  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.ELEKTR_NE_WW (type: 0, ID: 79) and state: {"val":0,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1728812217521}: No Connection to database
                2024-10-18 02:00:30.033  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.VERDICHTER_WW (type: 0, ID: 80) and state: {"val":220,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729151862282}: No Connection to database
                2024-10-18 02:00:30.033  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.VERDICHTER_KUEHLEN (type: 0, ID: 81) and state: {"val":53,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1728812217521}: No Connection to database
                2024-10-18 02:00:30.034  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.ELEKTR_NE_HEIZEN (type: 0, ID: 82) and state: {"val":0,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1728812217521}: No Connection to database
                2024-10-18 02:00:30.034  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.ANLAGE.RAUMTEMPERATUR.RAUMFEUCHTE_HK2 (type: 0, ID: 83) and state: {"val":52.7,"ack":true,"ts":1729209580854,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729206760840}: No Connection to database
                2024-10-18 02:00:30.034  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.ANLAGE.HEIZEN.AUSSENTEMPERATUR (type: 0, ID: 84) and state: {"val":14.5,"ack":true,"ts":1729209580855,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729209220926}: No Connection to database
                2024-10-18 02:00:30.034  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.ANLAGE.RAUMTEMPERATUR.RAUMISTTEMP_HK2 (type: 0, ID: 85) and state: {"val":24.1,"ack":true,"ts":1729209580854,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729207540840}: No Connection to database
                2024-10-18 02:00:30.035  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49607 (type: 0, ID: 87) and state: {"val":0,"ack":true,"ts":1729209538665,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1728944545694}: No Connection to database
                2024-10-18 02:00:30.035  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49615 (type: 0, ID: 88) and state: {"val":0,"ack":true,"ts":1729209628683,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729029656858}: No Connection to database
                2024-10-18 02:00:30.035  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49610 (type: 0, ID: 89) and state: {"val":-10.3,"ack":true,"ts":1729209568688,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209568688}: No Connection to database
                2024-10-18 02:00:30.035  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49602 (type: 0, ID: 90) and state: {"val":0,"ack":true,"ts":1729209628673,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209208693}: No Connection to database
                2024-10-18 02:00:30.035  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49601 (type: 0, ID: 91) and state: {"val":0,"ack":true,"ts":1729209628672,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729208398662}: No Connection to database
                2024-10-18 02:00:30.036  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49612 (type: 0, ID: 92) and state: {"val":0,"ack":true,"ts":1729209628677,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1725487252453}: No Connection to database
                2024-10-18 02:00:30.036  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49609 (type: 0, ID: 93) and state: {"val":0,"ack":true,"ts":1729209628675,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1694728863383}: No Connection to database
                2024-10-18 02:00:30.036  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.48846 (type: 0, ID: 94) and state: {"val":0,"ack":true,"ts":1729209628672,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209208688}: No Connection to database
                2024-10-18 02:00:30.036  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49604 (type: 0, ID: 95) and state: {"val":0,"ack":true,"ts":1729209568685,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1710558066291}: No Connection to database
                2024-10-18 02:00:30.037  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49608 (type: 0, ID: 96) and state: {"val":0,"ack":true,"ts":1729209568687,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1694682992674}: No Connection to database
                2024-10-18 02:00:30.037  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.48832 (type: 0, ID: 97) and state: {"val":0,"ack":true,"ts":1729209568675,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1620435699829}: No Connection to database
                2024-10-18 02:00:30.037  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49606 (type: 0, ID: 98) and state: {"val":13.9,"ack":true,"ts":1729209568686,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209568686}: No Connection to database
                2024-10-18 02:00:30.037  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49600 (type: 0, ID: 99) and state: {"val":100,"ack":true,"ts":1729209568683,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729175248354}: No Connection to database
                2024-10-18 02:00:30.382  - info: host.iobroker instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
                2024-10-18 02:00:30.383  - info: host.iobroker Do not restart adapter system.adapter.sql.0 because disabled or deleted
                Hier noch das Backup Log:
                [DEBUG] [iobroker] host.iobroker 49898 states saved
                [DEBUG] [iobroker] host.iobroker 60040 objects saved
                [DEBUG] [iobroker] Backup created: /opt/iobroker/backups/iobroker_2024_10_17-02_00_10_backupiobroker.tar.gz
                [DEBUG] [iobroker] This backup can only be restored with js-controller version up from 4.1
                [DEBUG] [iobroker] done
                [DEBUG] [sqlite] Start SQLite3 Backup ...
                [DEBUG] [sqlite] sql.0 is stopped
                [ERROR] [sqlite] Error: Command failed: sqlite3 /opt/iobroker/iobroker-data/sqlite/sqlite.db .dump > /opt/iobroker/backups/sqlite_2024_10_17-02_00_27_backupiobroker.sql
                [DEBUG] [ccu] CCU-Backup started ...
                [DEBUG] [ccu] CCU Version: 3.75.6.20240316
                [DEBUG] [ccu] Requesting backup from CCU
                [DEBUG] [ccu] CCU Session logout successful
                [DEBUG] [ccu] CCU-Backup is finish
                [DEBUG] [ccu] done
                [DEBUG] [clean] delete /opt/iobroker/backups/homematic_2024_10_11-10_39_04_3.75.6.20240316_backupiobroker.tar.sbk
                [DEBUG] [clean] done
                [DEBUG] [historyHTML] new history html values created
                [DEBUG] [historyHTML] done
                [DEBUG] [historyJSON] new history json values created
                [DEBUG] [historyJSON] done
                [DEBUG] [email] [ccu] used E-Mail-Instance: email.0
                [DEBUG] [email] done
                [DEBUG] [notification] done
                Bei Konfigurations Ermittlung in SQL Backitup kommt:
                "Konfiguration in sql.0 gefunden, aber nichts geändert"
                  Thomas Braun Most Active @Qlink last edited by
                  @qlink
                  Da fehlt wohl!
                  Schau on der Dokumentation nach den Voraussetzungen für ein Backup.
                  Q 1 Reply Last reply Reply Quote 1
                  • Q
                    Qlink @Thomas Braun last edited by Qlink
                    Aaah jetzt machts klick!
                    Danke für den Hinweis.
                    Mit
                    sudo apt-get update && sudo apt-get upgrade
                    sudo apt install sqlite3
                    läuft jetzt auch das SQL Backup wieder !
                    Ich versuche nämlich gerade meinen iobroker Container auf Docker Compose bzw. Stacks (Portainer) umzustellen...
                    Gibt es eine Möglichkeit in dem Compose File die beiden Befehle oben beim neu deployen des Containers gleich mit zu geben ?
                    • simatec
                      simatec Developer Most Active @Qlink last edited by simatec
                      @qlink Du kannst alle Pakete, die installiert werden sollen, über die Environment Variable (ENV) PACKAGES mitgeben.
                      https://docs.buanet.de/iobroker-docker-image/docs/#environment-variables-env
                      • Q
                        Qlink @simatec last edited by
                        @simatec
                        Das hätte ich eigentlich gemacht.
                        Hier mein Stacks file
                        version: "3"
                        services:
                        ##### IOBROKER #####
                          iobroker:
                            container_name: iobroker-test
                            image: buanet/iobroker:v9.1.1
                            hostname: iobroker
                            restart: always
                            networks:
                              # MACVLAN
                              LAN_public:
                                ipv4_address: 192.168.30.90
                              # Bridge
                              iob_private:
                                ipv4_address: 172.18.0.1
                              iob_private2:
                                ipv4_address: 172.19.0.1
                            environment:
                              - IOB_STATESDB_HOST=redis
                              - IOB_STATESDB_PORT=6379
                              - IOB_STATESDB_TYPE=redis
                              - PACKAGES=sqlite redis-tools
                              - IOB_BACKITUP_EXTDB=true
                            volumes:
                              - /volume3/docker/iobroker_data:/opt/iobroker
                                ##### NETWORKS #####
                        networks:
                          iob_private:
                            external: true
                          iob_private2:
                            external: true
                          LAN_public:
                            external: true
                        sqlite musste ich aber dennoch manuell nach installieren ...
                        Hab ich einen Fehler im Stacks file ?
                          @qlink
                          Das Paket heißt auch sqlite3
                          • Q
                            @thomas-braun Danke für den Hinweis ! 🤦
                            3876
