    4. [gelöst] Backitup bleibt bei Redis Backup hängen
    • Q
      Qlink @simatec last edited by Qlink
      @simatec
      Ja Redis läuft in einem eigenen Container.
      Wie muss der Pfad lauten ? Den hab ich auf Standard gelassen...
      Hier die Volume Einstellungen von dem redis container:
      • simatec
        simatec Developer Most Active @Qlink last edited by
        @qlink Dann geht natürlich kein lokales Redis Backup. Du musst auf dem iobroker Host redis-cli installiert haben und per remote auf den Redis Container zugreifen.
        Genaueres findest du in der Doku.
        https://github.com/simatec/ioBroker.backitup/wiki/ioBroker.backitup-Wiki-Deutsch#redis-backup
        • Q
          @simatec
          Danke das war der entscheidende Hinweis !
          Ich habe auf remote umgestellt und schon läuft das Backup durch 🙂
          11:26:18.350INFOguiBackup gestartet ...
          [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:00","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","redis":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"aof":false,"nameSuffix":"","slaveSuffix":"","hostType":"Single","path":"/data/dump.rdb","redisType":"remote","host":"redis","port":"6379","user":"","pass":"","ignoreErrors":false},"nodered":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"backup@multimediaberatung.at","emailSender":"iobroker@multimediaberatung.at","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1728725128009}
          11:26:22.877DEBUGiobrokerhost.iobroker 49861 states saved
          11:26:28.809DEBUGiobrokerhost.iobroker 60002 objects saved
          11:26:34.750DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_10_12-11_25_28_backupiobroker.tar.gz
          11:26:34.766DEBUGiobrokerThis backup can only be restored with js-controller version up from 4.1
          11:26:35.744DEBUGiobrokerdone
          11:26:36.511DEBUGredisStart Redis Backup ...
          11:26:36.532DEBUGredisCreated new redistmp directory
          11:26:56.560DEBUGredisPacked 15MB so far...
          11:27:06.827DEBUGredisPacked 91MB so far...
          11:27:16.528DEBUGredisPacked 193MB so far...
          11:27:26.560DEBUGredisPacked 302MB so far...
          11:27:36.598DEBUGredisPacked 406MB so far...
          11:27:46.532DEBUGredisPacked 516MB so far...
          11:27:54.569DEBUGredisBackup created: /opt/iobroker/backups/redis-remote_2024_10_12-11_25_45_backupiobroker.tar.gz
          11:27:54.578DEBUGredisTry deleting the redis tmp directory: "/opt/iobroker/backups/redistmp"
          11:27:54.583DEBUGredisdone
          11:27:55.925DEBUGnoderedCreated nodered tmp directory
          11:27:55.945DEBUGnoderedNode-Red tmp copy finish
          11:27:55.997DEBUGnoderedBackup created: /opt/iobroker/backups/nodered.0_2024_10_12-11_27_05_backupiobroker.tar.gz
          11:27:56.009DEBUGnoderedTry deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
          11:27:56.026DEBUGnodereddone
          11:27:57.238DEBUGcleandone
          11:27:57.368DEBUGhistoryHTMLnew history html values created
          11:27:57.381DEBUGhistoryHTMLdone
          11:27:57.528DEBUGhistoryJSONnew history json values created
          11:27:57.542DEBUGhistoryJSONdone
          [DEBUG] [historyHTML] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:00","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","redis":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"aof":false,"nameSuffix":"","slaveSuffix":"","hostType":"Single","path":"/data/dump.rdb","redisType":"remote","host":"redis","port":"6379","user":"","pass":"","ignoreErrors":false},"nodered":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"12. Oktober 2024 um 11:27 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"backup@multimediaberatung.at","emailSender":"iobroker@multimediaberatung.at","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1728725128009,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
          [DEBUG] [historyJSON] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:00","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","redis":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"aof":false,"nameSuffix":"","slaveSuffix":"","hostType":"Single","path":"/data/dump.rdb","redisType":"remote","host":"redis","port":"6379","user":"","pass":"","ignoreErrors":false},"nodered":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"12. Oktober 2024 um 11:27 Uhr"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"backup@multimediaberatung.at","emailSender":"iobroker@multimediaberatung.at","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1728725128009,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
          11:27:57.990DEBUGemail[iobroker] used E-Mail-Instance: email.0
          11:27:58.008DEBUGemaildone
          [DEBUG] [email] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:00","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","redis":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"aof":false,"nameSuffix":"","slaveSuffix":"","hostType":"Single","path":"/data/dump.rdb","redisType":"remote","host":"redis","port":"6379","user":"","pass":"","ignoreErrors":false},"nodered":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"backup@multimediaberatung.at","emailSender":"iobroker@multimediaberatung.at","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de","time":"12. Oktober 2024 um 11:27 Uhr"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1728725128009,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
          [DEBUG] [notification] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:00","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","redis":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"aof":false,"nameSuffix":"","slaveSuffix":"","hostType":"Single","path":"/data/dump.rdb","redisType":"remote","host":"redis","port":"6379","user":"","pass":"","ignoreErrors":false},"nodered":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"backup@multimediaberatung.at","emailSender":"iobroker@multimediaberatung.at","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de","time":"12. Oktober 2024 um 11:27 Uhr"},"backupDir":"/opt/iobroker/backups","timestamp":1728725128009,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
          11:28:00.043DEBUGnotificationdone
          11:28:00.197INFOguiDas Backup wurde erfolgreich erstellt!
          Danke für deine Hilfe !
          Beste Grüße
          • simatec
            @qlink kein Problem 😉
            • Q
              Qlink last edited by Qlink
              @simatec
              Jetzt bin ich leider doch noch auf ein Problem gestoßen:
              Nachdem das Backup wie oben eingestellt ist gibt es jetzt scheinbar ein Problem mit dem SQL Backup 😞
              Das iobroker Backup startet um 02:00 Uhr, wenn ich in der Früh auf den iobroker schaue, ist jetzt aber immer die SQL Instanz deaktiviert.
              Ich muss sie also jeden Tag manuell starten, was auch ohne Fehler funktioniert.
              Scheinbar findet er die SQL Instanz nicht mehr, dabei hat das Backup schon ohne Probleme funktioniert (siehe Beitrag weiter oben) ?
              Hier wäre ein Log von heute:
              2024-10-18 01:59:59.142  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (72, 1729209599141, 0, 0, 8, 0);
              2024-10-18 01:59:59.142  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 01:59:59.158  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:00.028  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 22995
              2024-10-18 02:00:00.034  - debug: sql.0 (17845) pushValueIntoDB called for 0_userdata.0.Uptime.DS1821+_Uptime (type: 1, ID: 255) and state: {"val":"172d 22h 18min","ack":true,"ts":1729209600024,"q":0,"c":"script.js.Umrechnungen.DS1821+_Uptime_Sekunden_in_Tage_Stunden_Minuten","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600024}
              2024-10-18 02:00:00.034  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for 0_userdata.0.Uptime.DS1821+_Uptime
              2024-10-18 02:00:00.034  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for 0_userdata.0.Uptime.DS1821+_Uptime (type: 1, ID: 255) and state: {"val":"172d 22h 18min","ack":true,"ts":1729209600024,"q":0,"c":"script.js.Umrechnungen.DS1821+_Uptime_Sekunden_in_Tage_Stunden_Minuten","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600024}: undefined
              2024-10-18 02:00:00.036  - debug: sql.0 (17845) pushValueIntoDB called for 0_userdata.0.Uptime.Fortigate_40F_Uptime (type: 1, ID: 254) and state: {"val":"8d 12h 29min","ack":true,"ts":1729209600030,"q":0,"c":"script.js.Umrechnungen.Fortigate_40F_Uptime_Sekunden_in_Tage_Stunden_Minuten","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600030}
              2024-10-18 02:00:00.037  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for 0_userdata.0.Uptime.Fortigate_40F_Uptime
              2024-10-18 02:00:00.037  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for 0_userdata.0.Uptime.Fortigate_40F_Uptime (type: 1, ID: 254) and state: {"val":"8d 12h 29min","ack":true,"ts":1729209600030,"q":0,"c":"script.js.Umrechnungen.Fortigate_40F_Uptime_Sekunden_in_Tage_Stunden_Minuten","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600030}: undefined
              2024-10-18 02:00:00.053  - debug: sql.0 (17845) pushValueIntoDB called for javascript.0.ccu.uptime (type: 0, ID: 145) and state: {"val":4499.29,"ack":true,"ts":1729209600048,"q":0,"c":"script.js.Systemstats.CCU_Monitoring","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600048}
              2024-10-18 02:00:00.053  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for javascript.0.ccu.uptime
              2024-10-18 02:00:00.053  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for javascript.0.ccu.uptime (type: 0, ID: 145) and state: {"val":4499.29,"ack":true,"ts":1729209600048,"q":0,"c":"script.js.Systemstats.CCU_Monitoring","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600048}: undefined
              2024-10-18 02:00:00.054  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (145, 1729209600048, 4499.29, 1, 4, 0);
              2024-10-18 02:00:00.054  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:00.078  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:00.131  - debug: sql.0 (17845) pushValueIntoDB called for javascript.0.ccu.systemTemperature (type: 0, ID: 146) and state: {"val":49.4,"ack":true,"ts":1729209480124,"q":0,"c":"script.js.Systemstats.CCU_Monitoring","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209360127}
              2024-10-18 02:00:00.131  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for javascript.0.ccu.systemTemperature
              2024-10-18 02:00:00.131  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for javascript.0.ccu.systemTemperature (type: 0, ID: 146) and state: {"val":49.4,"ack":true,"ts":1729209480124,"q":0,"c":"script.js.Systemstats.CCU_Monitoring","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209360127}: undefined
              2024-10-18 02:00:00.131  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (146, 1729209480124, 49.4, 1, 4, 0);
              2024-10-18 02:00:00.131  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:00.131  - debug: sql.0 (17845) pushValueIntoDB called for javascript.0.ccu.systemTemperature (type: 0, ID: 146) and state: {"val":51,"ack":true,"ts":1729209600128,"q":0,"c":"script.js.Systemstats.CCU_Monitoring","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600128}
              2024-10-18 02:00:00.132  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for javascript.0.ccu.systemTemperature (type: 0, ID: 146) and state: {"val":51,"ack":true,"ts":1729209600128,"q":0,"c":"script.js.Systemstats.CCU_Monitoring","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600128}: undefined
              2024-10-18 02:00:00.147  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:00.148  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (146, 1729209600128, 51, 1, 4, 0);
              2024-10-18 02:00:00.149  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:00.169  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:00.213  - debug: sql.0 (17845) pushValueIntoDB called for javascript.0.ccu.cpuFrequency (type: 0, ID: 147) and state: {"val":1200,"ack":true,"ts":1729209600211,"q":0,"c":"script.js.Systemstats.CCU_Monitoring","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600211}
              2024-10-18 02:00:00.213  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for javascript.0.ccu.cpuFrequency
              2024-10-18 02:00:00.213  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for javascript.0.ccu.cpuFrequency (type: 0, ID: 147) and state: {"val":1200,"ack":true,"ts":1729209600211,"q":0,"c":"script.js.Systemstats.CCU_Monitoring","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209600211}: undefined
              2024-10-18 02:00:00.213  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (147, 1729209600211, 1200, 1, 4, 0);
              2024-10-18 02:00:00.213  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:00.231  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:01.440  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":56,"ack":true,"ts":1729209601439,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209601439}
              2024-10-18 02:00:01.440  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.temperature
              2024-10-18 02:00:01.440  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":56,"ack":true,"ts":1729209601439,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209601439}: undefined
              2024-10-18 02:00:01.440  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (241, 1729209601439, 56, 1, 27, 0);
              2024-10-18 02:00:01.440  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:01.459  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:01.673  - debug: sql.0 (17845) pushValueIntoDB called for modbus.0.inputRegisters.30537_Tagesertrag (type: 0, ID: 56) and state: {"val":0,"ack":true,"ts":1729209601673,"q":0,"from":"system.adapter.sql.0","user":"system.user.admin","lc":1729202401650}
              2024-10-18 02:00:01.673  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for modbus.0.inputRegisters.30537_Tagesertrag
              2024-10-18 02:00:01.673  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for modbus.0.inputRegisters.30537_Tagesertrag (type: 0, ID: 56) and state: {"val":0,"ack":true,"ts":1729209601673,"q":0,"from":"system.adapter.sql.0","user":"system.user.admin","lc":1729202401650}: undefined
              2024-10-18 02:00:01.673  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (56, 1729209601673, 0, 1, 8, 0);
              2024-10-18 02:00:01.673  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:01.687  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:04.043  - info: host.iobroker instance system.adapter.ical.2 started with pid 23013
              2024-10-18 02:00:05.503  - info: ical.2 (23013) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.1, js-controller: 5.0.19
              2024-10-18 02:00:05.625  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":58,"ack":true,"ts":1729209605623,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209605623}
              2024-10-18 02:00:05.626  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.temperature
              2024-10-18 02:00:05.626  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":58,"ack":true,"ts":1729209605623,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209605623}: undefined
              2024-10-18 02:00:05.626  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (241, 1729209605623, 58, 1, 27, 0);
              2024-10-18 02:00:05.626  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:05.644  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.memory_usage (type: 0, ID: 243) and state: {"val":50,"ack":true,"ts":1729209605640,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209605640}
              2024-10-18 02:00:05.644  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.memory_usage
              2024-10-18 02:00:05.644  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.memory_usage (type: 0, ID: 243) and state: {"val":50,"ack":true,"ts":1729209605640,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209605640}: undefined
              2024-10-18 02:00:05.652  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:05.652  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (243, 1729209605640, 50, 1, 27, 0);
              2024-10-18 02:00:05.653  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:05.672  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:06.142  - info: ical.2 (23013) processing URL: Abfallkalender-mfpmmb.gmail.com https://calendar.google.com/calendar/ical/mfpmmb%40gmail.com/private-19c13d45e459539e837664778cd79c79/basic.ics
              2024-10-18 02:00:07.237  - debug: sql.0 (17845) pushValueIntoDB called for nut.0.input.voltage (type: 1, ID: 248) and state: {"val":"234.0","ack":true,"ts":1729209607235,"q":0,"from":"system.adapter.nut.0","user":"system.user.admin","lc":1729209307228}
              2024-10-18 02:00:07.237  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for nut.0.input.voltage
              2024-10-18 02:00:07.237  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for nut.0.input.voltage (type: 1, ID: 248) and state: {"val":"234.0","ack":true,"ts":1729209607235,"q":0,"from":"system.adapter.nut.0","user":"system.user.admin","lc":1729209307228}: undefined
              2024-10-18 02:00:07.435  - debug: sql.0 (17845) pushValueIntoDB called for 0_userdata.0.Fortigate.WAN-Incoming-Mbit (type: 0, ID: 249) and state: {"val":0.1,"ack":true,"ts":1729209592430,"q":0,"c":"script.js.Umrechnungen.Fortigate-Traffic","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209577432}
              2024-10-18 02:00:07.436  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for 0_userdata.0.Fortigate.WAN-Incoming-Mbit
              2024-10-18 02:00:07.436  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for 0_userdata.0.Fortigate.WAN-Incoming-Mbit (type: 0, ID: 249) and state: {"val":0.1,"ack":true,"ts":1729209592430,"q":0,"c":"script.js.Umrechnungen.Fortigate-Traffic","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209577432}: undefined
              2024-10-18 02:00:07.436  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (249, 1729209592430, 0.1, 1, 4, 0);
              2024-10-18 02:00:07.436  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:07.436  - debug: sql.0 (17845) pushValueIntoDB called for 0_userdata.0.Fortigate.WAN-Incoming-Mbit (type: 0, ID: 249) and state: {"val":0.2,"ack":true,"ts":1729209607433,"q":0,"c":"script.js.Umrechnungen.Fortigate-Traffic","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209607433}
              2024-10-18 02:00:07.436  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for 0_userdata.0.Fortigate.WAN-Incoming-Mbit (type: 0, ID: 249) and state: {"val":0.2,"ack":true,"ts":1729209607433,"q":0,"c":"script.js.Umrechnungen.Fortigate-Traffic","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209607433}: undefined
              2024-10-18 02:00:07.436  - debug: sql.0 (17845) pushValueIntoDB called for 0_userdata.0.Fortigate.WAN-Outgoing-Mbit (type: 0, ID: 250) and state: {"val":4.2,"ack":true,"ts":1729209592430,"q":0,"c":"script.js.Umrechnungen.Fortigate-Traffic","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209577432}
              2024-10-18 02:00:07.436  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for 0_userdata.0.Fortigate.WAN-Outgoing-Mbit
              2024-10-18 02:00:07.436  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for 0_userdata.0.Fortigate.WAN-Outgoing-Mbit (type: 0, ID: 250) and state: {"val":4.2,"ack":true,"ts":1729209592430,"q":0,"c":"script.js.Umrechnungen.Fortigate-Traffic","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209577432}: undefined
              2024-10-18 02:00:07.437  - debug: sql.0 (17845) pushValueIntoDB called for 0_userdata.0.Fortigate.WAN-Outgoing-Mbit (type: 0, ID: 250) and state: {"val":8.5,"ack":true,"ts":1729209607433,"q":0,"c":"script.js.Umrechnungen.Fortigate-Traffic","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209607433}
              2024-10-18 02:00:07.437  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for 0_userdata.0.Fortigate.WAN-Outgoing-Mbit
              2024-10-18 02:00:07.437  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for 0_userdata.0.Fortigate.WAN-Outgoing-Mbit (type: 0, ID: 250) and state: {"val":8.5,"ack":true,"ts":1729209607433,"q":0,"c":"script.js.Umrechnungen.Fortigate-Traffic","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209607433}: undefined
              2024-10-18 02:00:07.454  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:07.454  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (249, 1729209607433, 0.2, 1, 4, 0);
              2024-10-18 02:00:07.455  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:07.469  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:07.471  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (250, 1729209592430, 4.2, 1, 4, 0),(250, 1729209607433, 8.5, 1, 4, 0);
              2024-10-18 02:00:07.471  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:07.484  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:07.633  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":57,"ack":true,"ts":1729209607632,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209607632}
              2024-10-18 02:00:07.633  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.temperature
              2024-10-18 02:00:07.633  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":57,"ack":true,"ts":1729209607632,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209607632}: undefined
              2024-10-18 02:00:07.633  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (241, 1729209607632, 57, 1, 27, 0);
              2024-10-18 02:00:07.633  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:07.646  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:07.686  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2024-10-18 02:00:08.052  - info: host.iobroker instance system.adapter.ical.1 started with pid 23042
              2024-10-18 02:00:09.072  - debug: sql.0 (17845) pushValueIntoDB called for system.host.iobroker.mem (type: 0, ID: 123) and state: {"val":51,"ack":true,"ts":1729209594067,"q":0,"from":"system.host.iobroker","lc":1729207824050}
              2024-10-18 02:00:09.072  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for system.host.iobroker.mem
              2024-10-18 02:00:09.072  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for system.host.iobroker.mem (type: 0, ID: 123) and state: {"val":51,"ack":true,"ts":1729209594067,"q":0,"from":"system.host.iobroker","lc":1729207824050}: undefined
              2024-10-18 02:00:09.073  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (123, 1729209594067, 51, 1, 12, 0);
              2024-10-18 02:00:09.073  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:09.073  - debug: sql.0 (17845) pushValueIntoDB called for system.host.iobroker.mem (type: 0, ID: 123) and state: {"val":52,"ack":true,"ts":1729209609067,"q":0,"from":"system.host.iobroker","lc":1729209609067}
              2024-10-18 02:00:09.073  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for system.host.iobroker.mem
              2024-10-18 02:00:09.073  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for system.host.iobroker.mem (type: 0, ID: 123) and state: {"val":52,"ack":true,"ts":1729209609067,"q":0,"from":"system.host.iobroker","lc":1729209609067}: undefined
              2024-10-18 02:00:09.074  - debug: sql.0 (17845) pushValueIntoDB called for system.host.iobroker.cpu (type: 0, ID: 122) and state: {"val":0.67,"ack":true,"ts":1729209609071,"q":0,"from":"system.host.iobroker","lc":1729209609071}
              2024-10-18 02:00:09.075  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for system.host.iobroker.cpu
              2024-10-18 02:00:09.075  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for system.host.iobroker.cpu (type: 0, ID: 122) and state: {"val":0.67,"ack":true,"ts":1729209609071,"q":0,"from":"system.host.iobroker","lc":1729209609071}: undefined
              2024-10-18 02:00:09.102  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:09.104  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (123, 1729209609067, 52, 1, 12, 0);
              2024-10-18 02:00:09.104  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:09.132  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:09.132  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (122, 1729209609071, 0.67, 1, 12, 0);
              2024-10-18 02:00:09.133  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:09.159  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:09.355  - info: ical.1 (23042) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.1, js-controller: 5.0.19
              2024-10-18 02:00:09.679  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":35,"ack":true,"ts":1729209609679,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209609679}
              2024-10-18 02:00:09.680  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.cpu_load
              2024-10-18 02:00:09.680  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":35,"ack":true,"ts":1729209609679,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209609679}: undefined
              2024-10-18 02:00:09.680  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (242, 1729209609679, 35, 1, 27, 0);
              2024-10-18 02:00:09.680  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:09.696  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:10.014  - debug: backitup.0 (568) Backup has started ...
              2024-10-18 02:00:11.295  - info: ical.2 (23013) Terminated (NO_ERROR): Without reason
              2024-10-18 02:00:11.814  - info: host.iobroker instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
              2024-10-18 02:00:11.825  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":58,"ack":true,"ts":1729209611824,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209611824}
              2024-10-18 02:00:11.825  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.temperature
              2024-10-18 02:00:11.825  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":58,"ack":true,"ts":1729209611824,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209611824}: undefined
              2024-10-18 02:00:11.825  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (241, 1729209611824, 58, 1, 27, 0);
              2024-10-18 02:00:11.826  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:11.848  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:12.063  - info: host.iobroker instance system.adapter.ical.0 started with pid 23070
              2024-10-18 02:00:13.887  - info: ical.0 (23070) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.1, js-controller: 5.0.19
              2024-10-18 02:00:14.224  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":59,"ack":true,"ts":1729209614223,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209614223}
              2024-10-18 02:00:14.225  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.temperature
              2024-10-18 02:00:14.225  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":59,"ack":true,"ts":1729209614223,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209614223}: undefined
              2024-10-18 02:00:14.225  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (241, 1729209614223, 59, 1, 27, 0);
              2024-10-18 02:00:14.225  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:14.237  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":39,"ack":true,"ts":1729209614235,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209614235}
              2024-10-18 02:00:14.237  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.cpu_load
              2024-10-18 02:00:14.237  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":39,"ack":true,"ts":1729209614235,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209614235}: undefined
              2024-10-18 02:00:14.259  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:14.261  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (242, 1729209614235, 39, 1, 27, 0);
              2024-10-18 02:00:14.261  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:14.282  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:15.123  - info: ical.1 (23042) processing URL: Magdalena https://outlook.office365.com/owa/calendar/1b4051cc812a43b38177057e14fe3d1d@langthaler.co/a5ae21dbe3f54bf8ad2462b30d51d06614501199648262372113/calendar.ics
              2024-10-18 02:00:15.263  - debug: backitup.0 (568) [iobroker/iobroker] host.iobroker 49916 states saved
              2024-10-18 02:00:17.264  - debug: sql.0 (17845) pushValueIntoDB called for nut.0.input.voltage (type: 1, ID: 248) and state: {"val":"234.0","ack":true,"ts":1729209617264,"q":0,"from":"system.adapter.nut.0","user":"system.user.admin","lc":1729209307228}
              2024-10-18 02:00:17.265  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for nut.0.input.voltage
              2024-10-18 02:00:17.265  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for nut.0.input.voltage (type: 1, ID: 248) and state: {"val":"234.0","ack":true,"ts":1729209617264,"q":0,"from":"system.adapter.nut.0","user":"system.user.admin","lc":1729209307228}: undefined
              2024-10-18 02:00:18.322  - info: ical.0 (23070) processing URL: Gerald https://outlook.office365.com/owa/calendar/83b88f98b9a842a087bc908a81726653@langthaler.co/66f51c2dcb55428da093bb0c45e7c5ac3783454353823405424/calendar.ics
              2024-10-18 02:00:18.439  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":50,"ack":true,"ts":1729209618437,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209618437}
              2024-10-18 02:00:18.439  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.cpu_load
              2024-10-18 02:00:18.439  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":50,"ack":true,"ts":1729209618437,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209618437}: undefined
              2024-10-18 02:00:18.440  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (242, 1729209618437, 50, 1, 27, 0);
              2024-10-18 02:00:18.440  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:18.476  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:20.693  - info: ical.1 (23042) Terminated (NO_ERROR): Without reason
              2024-10-18 02:00:21.207  - info: host.iobroker instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
              2024-10-18 02:00:21.906  - debug: backitup.0 (568) [iobroker/iobroker] host.iobroker 60065 objects saved
              2024-10-18 02:00:22.377  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":58,"ack":true,"ts":1729209622376,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209622376}
              2024-10-18 02:00:22.377  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.temperature
              2024-10-18 02:00:22.377  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":58,"ack":true,"ts":1729209622376,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209622376}: undefined
              2024-10-18 02:00:22.377  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (241, 1729209622376, 58, 1, 27, 0);
              2024-10-18 02:00:22.377  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:22.381  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":52,"ack":true,"ts":1729209622381,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209622381}
              2024-10-18 02:00:22.382  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.cpu_load
              2024-10-18 02:00:22.382  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":52,"ack":true,"ts":1729209622381,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209622381}: undefined
              2024-10-18 02:00:22.385  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.memory_usage (type: 0, ID: 243) and state: {"val":52,"ack":true,"ts":1729209622383,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209622383}
              2024-10-18 02:00:22.385  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.memory_usage
              2024-10-18 02:00:22.385  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.memory_usage (type: 0, ID: 243) and state: {"val":52,"ack":true,"ts":1729209622383,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209622383}: undefined
              2024-10-18 02:00:22.395  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:22.397  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (242, 1729209622381, 52, 1, 27, 0);
              2024-10-18 02:00:22.397  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:22.410  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:22.410  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (243, 1729209622383, 52, 1, 27, 0);
              2024-10-18 02:00:22.410  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:22.422  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:23.612  - info: ical.0 (23070) Terminated (NO_ERROR): Without reason
              2024-10-18 02:00:24.071  - debug: sql.0 (17845) pushValueIntoDB called for system.host.iobroker.mem (type: 0, ID: 123) and state: {"val":55,"ack":true,"ts":1729209624068,"q":0,"from":"system.host.iobroker","lc":1729209624068}
              2024-10-18 02:00:24.071  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for system.host.iobroker.mem
              2024-10-18 02:00:24.071  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for system.host.iobroker.mem (type: 0, ID: 123) and state: {"val":55,"ack":true,"ts":1729209624068,"q":0,"from":"system.host.iobroker","lc":1729209624068}: undefined
              2024-10-18 02:00:24.071  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (123, 1729209624068, 55, 1, 12, 0);
              2024-10-18 02:00:24.071  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:24.078  - debug: sql.0 (17845) pushValueIntoDB called for system.host.iobroker.cpu (type: 0, ID: 122) and state: {"val":0.27,"ack":true,"ts":1729209624073,"q":0,"from":"system.host.iobroker","lc":1729209624073}
              2024-10-18 02:00:24.078  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for system.host.iobroker.cpu
              2024-10-18 02:00:24.078  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for system.host.iobroker.cpu (type: 0, ID: 122) and state: {"val":0.27,"ack":true,"ts":1729209624073,"q":0,"from":"system.host.iobroker","lc":1729209624073}: undefined
              2024-10-18 02:00:24.097  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:24.098  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (122, 1729209624073, 0.27, 1, 12, 0);
              2024-10-18 02:00:24.098  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:24.120  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:24.136  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
              2024-10-18 02:00:24.333  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":57,"ack":true,"ts":1729209624332,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209624332}
              2024-10-18 02:00:24.333  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.temperature
              2024-10-18 02:00:24.333  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":57,"ack":true,"ts":1729209624332,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209624332}: undefined
              2024-10-18 02:00:24.333  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (241, 1729209624332, 57, 1, 27, 0);
              2024-10-18 02:00:24.333  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:24.349  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:26.374  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":58,"ack":true,"ts":1729209626373,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209626373}
              2024-10-18 02:00:26.374  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.temperature
              2024-10-18 02:00:26.374  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":58,"ack":true,"ts":1729209626373,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209626373}: undefined
              2024-10-18 02:00:26.374  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (241, 1729209626373, 58, 1, 27, 0);
              2024-10-18 02:00:26.374  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:26.378  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":30,"ack":true,"ts":1729209626378,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209626378}
              2024-10-18 02:00:26.378  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.cpu_load
              2024-10-18 02:00:26.378  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.cpu_load (type: 0, ID: 242) and state: {"val":30,"ack":true,"ts":1729209626378,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209626378}: undefined
              2024-10-18 02:00:26.389  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:26.389  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (242, 1729209626378, 30, 1, 27, 0);
              2024-10-18 02:00:26.390  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:26.400  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:27.237  - debug: sql.0 (17845) pushValueIntoDB called for nut.0.input.voltage (type: 1, ID: 248) and state: {"val":"232.0","ack":true,"ts":1729209627237,"q":0,"from":"system.adapter.nut.0","user":"system.user.admin","lc":1729209627237}
              2024-10-18 02:00:27.238  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for nut.0.input.voltage
              2024-10-18 02:00:27.238  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for nut.0.input.voltage (type: 1, ID: 248) and state: {"val":"232.0","ack":true,"ts":1729209627237,"q":0,"from":"system.adapter.nut.0","user":"system.user.admin","lc":1729209627237}: undefined
              2024-10-18 02:00:27.355  - debug: backitup.0 (568) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2024_10_18-02_00_10_backupiobroker.tar.gz
              2024-10-18 02:00:27.356  - debug: backitup.0 (568) [iobroker/iobroker] This backup can only be restored with js-controller version up from 4.1
              2024-10-18 02:00:28.316  - debug: sql.0 (17845) pushValueIntoDB called for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":57,"ack":true,"ts":1729209628316,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209628316}
              2024-10-18 02:00:28.316  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for synology.0.DiskStationManager.info.temperature
              2024-10-18 02:00:28.317  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for synology.0.DiskStationManager.info.temperature (type: 0, ID: 241) and state: {"val":57,"ack":true,"ts":1729209628316,"q":0,"from":"system.adapter.synology.0","user":"system.user.admin","lc":1729209628316}: undefined
              2024-10-18 02:00:28.317  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (241, 1729209628316, 57, 1, 27, 0);
              2024-10-18 02:00:28.317  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:28.329  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:28.404  - debug: backitup.0 (568) [iobroker/iobroker] done
              2024-10-18 02:00:28.676  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49611 (type: 1, ID: 86) and state: {"val":"O","ack":true,"ts":1729209628676,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209568690}
              2024-10-18 02:00:28.677  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for hm-rega.0.49611
              2024-10-18 02:00:28.677  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49611 (type: 1, ID: 86) and state: {"val":"O","ack":true,"ts":1729209628676,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209568690}: undefined
              2024-10-18 02:00:28.705  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.62800 (type: 0, ID: 155) and state: {"val":989.23,"ack":true,"ts":1729209628705,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209628705}
              2024-10-18 02:00:28.705  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for hm-rega.0.62800
              2024-10-18 02:00:28.705  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.62800 (type: 0, ID: 155) and state: {"val":989.23,"ack":true,"ts":1729209628705,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209628705}: undefined
              2024-10-18 02:00:28.706  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (155, 1729209628705, 989.23, 1, 2, 0);
              2024-10-18 02:00:28.706  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:28.720  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:29.006  - debug: backitup.0 (568) [iobroker/sqlite] Start SQLite3 Backup ...
              2024-10-18 02:00:29.011  - debug: backitup.0 (568) [iobroker/sqlite] sql.0 is stopped
              2024-10-18 02:00:29.013  - info: host.iobroker instance "system.adapter.sql.0" disabled via .alive
              2024-10-18 02:00:29.015  - error: backitup.0 (568) [iobroker/sqlite] Error: Command failed: sqlite3 /opt/iobroker/iobroker-data/sqlite/sqlite.db .dump > /opt/iobroker/backups/sqlite_2024_10_18-02_00_29_backupiobroker.sql
              2024-10-18 02:00:29.020  - info: host.iobroker "system.adapter.sql.0" disabled
              2024-10-18 02:00:29.021  - info: host.iobroker stopInstance system.adapter.sql.0 (force=false, process=true)
              2024-10-18 02:00:29.015  - error: backitup.0 (568) [iobroker/sqlite] /bin/sh: 1: sqlite3: not found
              2024-10-18 02:00:29.015  - error: backitup.0 (568) [iobroker] Error: Command failed: sqlite3 /opt/iobroker/iobroker-data/sqlite/sqlite.db .dump > /opt/iobroker/backups/sqlite_2024_10_18-02_00_29_backupiobroker.sql
              2024-10-18 02:00:29.028  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.30165 (type: 0, ID: 9) and state: {"val":18.65,"ack":true,"ts":1729209208664,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729208818656}
              2024-10-18 02:00:29.028  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for hm-rega.0.30165
              2024-10-18 02:00:29.028  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.30165 (type: 0, ID: 9) and state: {"val":18.65,"ack":true,"ts":1729209208664,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729208818656}: undefined
              2024-10-18 02:00:29.029  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.36508 (type: 0, ID: 14) and state: {"val":56.1,"ack":true,"ts":1729209628666,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209628666}
              2024-10-18 02:00:29.029  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for hm-rega.0.36508
              2024-10-18 02:00:29.029  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.36508 (type: 0, ID: 14) and state: {"val":56.1,"ack":true,"ts":1729209628666,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209628666}: undefined
              2024-10-18 02:00:29.029  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.36507 (type: 0, ID: 15) and state: {"val":21.45,"ack":true,"ts":1729208368653,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729208068655}
              2024-10-18 02:00:29.029  - debug: sql.0 (17845) prepareTaskCheckTypeAndDbId CALLED for hm-rega.0.36507
              2024-10-18 02:00:29.029  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.36507 (type: 0, ID: 15) and state: {"val":21.45,"ack":true,"ts":1729208368653,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729208068655}: undefined
              2024-10-18 02:00:29.032  - debug: sql.0 (17845) INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES (15, 1729208368653, 21.45, 1, 2, 0);
              2024-10-18 02:00:29.032  - debug: sql.0 (17845) Borrow connection from pool: 1 now
              2024-10-18 02:00:29.044  - debug: sql.0 (17845) Return connection to pool: 0 now
              2024-10-18 02:00:29.763  - info: sql.0 (17845) terminating
              2024-10-18 02:00:29.763  - debug: sql.0 (17845) Plugin sentry destroyed
              2024-10-18 02:00:29.764  - info: sql.0 (17845) Terminated (NO_ERROR): Without reason
              2024-10-18 02:00:30.027  - debug: sql.0 (17845) pushValueIntoDB called for javascript.0.Netzbezug.Gesamtverbrauch (type: 0, ID: 62) and state: {"val":355.23333333333335,"ack":false,"ts":1729209626645,"q":0,"c":"script.js.Umrechnungen.Berechnung_Gesamtverbrauch1_V2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209626645}
              2024-10-18 02:00:30.027  - warn: sql.0 (17845) No Connection to database
              2024-10-18 02:00:30.028  - debug: sql.0 (17845) pushValueIntoDB called for javascript.0.Netzbezug.kW (type: 0, ID: 65) and state: {"val":0,"ack":true,"ts":1729209626645,"q":0,"c":"script.js.Umrechnungen.Umrechnung_Netzbezug_W_in_kW_V2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1551003543474}
              2024-10-18 02:00:30.028  - warn: sql.0 (17845) No Connection to database
              2024-10-18 02:00:30.028  - debug: sql.0 (17845) pushValueIntoDB called for javascript.0.Netzbezug.PV_Leistung (type: 0, ID: 68) and state: {"val":0,"ack":true,"ts":1729181933598,"q":0,"c":"script.js.Umrechnungen.PVLeistung_auf_0_limitieren","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729181933598}
              2024-10-18 02:00:30.028  - debug: sql.0 (17845) pushValueIntoDB called for javascript.0.Netzbezug.Eingangsspannung (type: 0, ID: 69) and state: {"val":800,"ack":true,"ts":1729181933448,"q":0,"c":"script.js.Umrechnungen.PV_Eingangsspannung_auf_900_limitieren","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729181933448}
              2024-10-18 02:00:30.028  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.WAERMEPUMPE.LEISTUNGSAUFNAHME.P_WW_TAG (type: 0, ID: 76) and state: {"val":0.754,"ack":true,"ts":1729209582732,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729202451191}
              2024-10-18 02:00:30.028  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.WAERMEPUMPE.LEISTUNGSAUFNAHME.P_HEIZUNG_TAG (type: 0, ID: 77) and state: {"val":0.73,"ack":true,"ts":1729209582732,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729202451191}
              2024-10-18 02:00:30.028  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.VERDICHTER_HEIZEN (type: 0, ID: 78) and state: {"val":1013,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729170408861}
              2024-10-18 02:00:30.028  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.ELEKTR_NE_WW (type: 0, ID: 79) and state: {"val":0,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1728812217521}
              2024-10-18 02:00:30.028  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.VERDICHTER_WW (type: 0, ID: 80) and state: {"val":220,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729151862282}
              2024-10-18 02:00:30.029  - warn: sql.0 (17845) No Connection to database
              2024-10-18 02:00:30.029  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.VERDICHTER_KUEHLEN (type: 0, ID: 81) and state: {"val":53,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1728812217521}
              2024-10-18 02:00:30.029  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.ELEKTR_NE_HEIZEN (type: 0, ID: 82) and state: {"val":0,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1728812217521}
              2024-10-18 02:00:30.029  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.ANLAGE.RAUMTEMPERATUR.RAUMFEUCHTE_HK2 (type: 0, ID: 83) and state: {"val":52.7,"ack":true,"ts":1729209580854,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729206760840}
              2024-10-18 02:00:30.029  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.ANLAGE.HEIZEN.AUSSENTEMPERATUR (type: 0, ID: 84) and state: {"val":14.5,"ack":true,"ts":1729209580855,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729209220926}
              2024-10-18 02:00:30.029  - debug: sql.0 (17845) pushValueIntoDB called for stiebel-isg.0.Info.ANLAGE.RAUMTEMPERATUR.RAUMISTTEMP_HK2 (type: 0, ID: 85) and state: {"val":24.1,"ack":true,"ts":1729209580854,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729207540840}
              2024-10-18 02:00:30.029  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49607 (type: 0, ID: 87) and state: {"val":0,"ack":true,"ts":1729209538665,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1728944545694}
              2024-10-18 02:00:30.029  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49615 (type: 0, ID: 88) and state: {"val":0,"ack":true,"ts":1729209628683,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729029656858}
              2024-10-18 02:00:30.030  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49610 (type: 0, ID: 89) and state: {"val":-10.3,"ack":true,"ts":1729209568688,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209568688}
              2024-10-18 02:00:30.030  - warn: sql.0 (17845) No Connection to database
              2024-10-18 02:00:30.030  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49602 (type: 0, ID: 90) and state: {"val":0,"ack":true,"ts":1729209628673,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209208693}
              2024-10-18 02:00:30.030  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49601 (type: 0, ID: 91) and state: {"val":0,"ack":true,"ts":1729209628672,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729208398662}
              2024-10-18 02:00:30.030  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49612 (type: 0, ID: 92) and state: {"val":0,"ack":true,"ts":1729209628677,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1725487252453}
              2024-10-18 02:00:30.030  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49609 (type: 0, ID: 93) and state: {"val":0,"ack":true,"ts":1729209628675,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1694728863383}
              2024-10-18 02:00:30.030  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.48846 (type: 0, ID: 94) and state: {"val":0,"ack":true,"ts":1729209628672,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209208688}
              2024-10-18 02:00:30.030  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49604 (type: 0, ID: 95) and state: {"val":0,"ack":true,"ts":1729209568685,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1710558066291}
              2024-10-18 02:00:30.030  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49608 (type: 0, ID: 96) and state: {"val":0,"ack":true,"ts":1729209568687,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1694682992674}
              2024-10-18 02:00:30.030  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.48832 (type: 0, ID: 97) and state: {"val":0,"ack":true,"ts":1729209568675,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1620435699829}
              2024-10-18 02:00:30.031  - warn: sql.0 (17845) No Connection to database
              2024-10-18 02:00:30.031  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49606 (type: 0, ID: 98) and state: {"val":13.9,"ack":true,"ts":1729209568686,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209568686}
              2024-10-18 02:00:30.031  - debug: sql.0 (17845) pushValueIntoDB called for hm-rega.0.49600 (type: 0, ID: 99) and state: {"val":100,"ack":true,"ts":1729209568683,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729175248354}
              2024-10-18 02:00:30.031  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for javascript.0.Netzbezug.Gesamtverbrauch (type: 0, ID: 62) and state: {"val":355.23333333333335,"ack":false,"ts":1729209626645,"q":0,"c":"script.js.Umrechnungen.Berechnung_Gesamtverbrauch1_V2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729209626645}: No Connection to database
              2024-10-18 02:00:30.031  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for javascript.0.Netzbezug.kW (type: 0, ID: 65) and state: {"val":0,"ack":true,"ts":1729209626645,"q":0,"c":"script.js.Umrechnungen.Umrechnung_Netzbezug_W_in_kW_V2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1551003543474}: No Connection to database
              2024-10-18 02:00:30.032  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for javascript.0.Netzbezug.PV_Leistung (type: 0, ID: 68) and state: {"val":0,"ack":true,"ts":1729181933598,"q":0,"c":"script.js.Umrechnungen.PVLeistung_auf_0_limitieren","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729181933598}: No Connection to database
              2024-10-18 02:00:30.032  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for javascript.0.Netzbezug.Eingangsspannung (type: 0, ID: 69) and state: {"val":800,"ack":true,"ts":1729181933448,"q":0,"c":"script.js.Umrechnungen.PV_Eingangsspannung_auf_900_limitieren","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1729181933448}: No Connection to database
              2024-10-18 02:00:30.032  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.WAERMEPUMPE.LEISTUNGSAUFNAHME.P_WW_TAG (type: 0, ID: 76) and state: {"val":0.754,"ack":true,"ts":1729209582732,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729202451191}: No Connection to database
              2024-10-18 02:00:30.032  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.WAERMEPUMPE.LEISTUNGSAUFNAHME.P_HEIZUNG_TAG (type: 0, ID: 77) and state: {"val":0.73,"ack":true,"ts":1729209582732,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729202451191}: No Connection to database
              2024-10-18 02:00:30.033  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.VERDICHTER_HEIZEN (type: 0, ID: 78) and state: {"val":1013,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729170408861}: No Connection to database
              2024-10-18 02:00:30.033  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.ELEKTR_NE_WW (type: 0, ID: 79) and state: {"val":0,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1728812217521}: No Connection to database
              2024-10-18 02:00:30.033  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.VERDICHTER_WW (type: 0, ID: 80) and state: {"val":220,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729151862282}: No Connection to database
              2024-10-18 02:00:30.033  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.VERDICHTER_KUEHLEN (type: 0, ID: 81) and state: {"val":53,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1728812217521}: No Connection to database
              2024-10-18 02:00:30.034  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.WAERMEPUMPE.LAUFZEITEN.ELEKTR_NE_HEIZEN (type: 0, ID: 82) and state: {"val":0,"ack":true,"ts":1729209582733,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1728812217521}: No Connection to database
              2024-10-18 02:00:30.034  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.ANLAGE.RAUMTEMPERATUR.RAUMFEUCHTE_HK2 (type: 0, ID: 83) and state: {"val":52.7,"ack":true,"ts":1729209580854,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729206760840}: No Connection to database
              2024-10-18 02:00:30.034  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.ANLAGE.HEIZEN.AUSSENTEMPERATUR (type: 0, ID: 84) and state: {"val":14.5,"ack":true,"ts":1729209580855,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729209220926}: No Connection to database
              2024-10-18 02:00:30.034  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for stiebel-isg.0.Info.ANLAGE.RAUMTEMPERATUR.RAUMISTTEMP_HK2 (type: 0, ID: 85) and state: {"val":24.1,"ack":true,"ts":1729209580854,"q":0,"from":"system.adapter.stiebel-isg.0","user":"system.user.admin","lc":1729207540840}: No Connection to database
              2024-10-18 02:00:30.035  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49607 (type: 0, ID: 87) and state: {"val":0,"ack":true,"ts":1729209538665,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1728944545694}: No Connection to database
              2024-10-18 02:00:30.035  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49615 (type: 0, ID: 88) and state: {"val":0,"ack":true,"ts":1729209628683,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729029656858}: No Connection to database
              2024-10-18 02:00:30.035  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49610 (type: 0, ID: 89) and state: {"val":-10.3,"ack":true,"ts":1729209568688,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209568688}: No Connection to database
              2024-10-18 02:00:30.035  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49602 (type: 0, ID: 90) and state: {"val":0,"ack":true,"ts":1729209628673,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209208693}: No Connection to database
              2024-10-18 02:00:30.035  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49601 (type: 0, ID: 91) and state: {"val":0,"ack":true,"ts":1729209628672,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729208398662}: No Connection to database
              2024-10-18 02:00:30.036  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49612 (type: 0, ID: 92) and state: {"val":0,"ack":true,"ts":1729209628677,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1725487252453}: No Connection to database
              2024-10-18 02:00:30.036  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49609 (type: 0, ID: 93) and state: {"val":0,"ack":true,"ts":1729209628675,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1694728863383}: No Connection to database
              2024-10-18 02:00:30.036  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.48846 (type: 0, ID: 94) and state: {"val":0,"ack":true,"ts":1729209628672,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209208688}: No Connection to database
              2024-10-18 02:00:30.036  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49604 (type: 0, ID: 95) and state: {"val":0,"ack":true,"ts":1729209568685,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1710558066291}: No Connection to database
              2024-10-18 02:00:30.037  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49608 (type: 0, ID: 96) and state: {"val":0,"ack":true,"ts":1729209568687,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1694682992674}: No Connection to database
              2024-10-18 02:00:30.037  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.48832 (type: 0, ID: 97) and state: {"val":0,"ack":true,"ts":1729209568675,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1620435699829}: No Connection to database
              2024-10-18 02:00:30.037  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49606 (type: 0, ID: 98) and state: {"val":13.9,"ack":true,"ts":1729209568686,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729209568686}: No Connection to database
              2024-10-18 02:00:30.037  - debug: sql.0 (17845) pushValueIntoDB-prepareTaskCheckTypeAndDbId RESULT for hm-rega.0.49600 (type: 0, ID: 99) and state: {"val":100,"ack":true,"ts":1729209568683,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1729175248354}: No Connection to database
              2024-10-18 02:00:30.382  - info: host.iobroker instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
              2024-10-18 02:00:30.383  - info: host.iobroker Do not restart adapter system.adapter.sql.0 because disabled or deleted
              Hier noch das Backup Log:
              [DEBUG] [iobroker] host.iobroker 49898 states saved
              [DEBUG] [iobroker] host.iobroker 60040 objects saved
              [DEBUG] [iobroker] Backup created: /opt/iobroker/backups/iobroker_2024_10_17-02_00_10_backupiobroker.tar.gz
              [DEBUG] [iobroker] This backup can only be restored with js-controller version up from 4.1
              [DEBUG] [iobroker] done
              [DEBUG] [sqlite] Start SQLite3 Backup ...
              [DEBUG] [sqlite] sql.0 is stopped
              [ERROR] [sqlite] Error: Command failed: sqlite3 /opt/iobroker/iobroker-data/sqlite/sqlite.db .dump > /opt/iobroker/backups/sqlite_2024_10_17-02_00_27_backupiobroker.sql
              [DEBUG] [ccu] CCU-Backup started ...
              [DEBUG] [ccu] CCU Version: 3.75.6.20240316
              [DEBUG] [ccu] Requesting backup from CCU
              [DEBUG] [ccu] CCU Session logout successful
              [DEBUG] [ccu] CCU-Backup is finish
              [DEBUG] [ccu] done
              [DEBUG] [clean] delete /opt/iobroker/backups/homematic_2024_10_11-10_39_04_3.75.6.20240316_backupiobroker.tar.sbk
              [DEBUG] [clean] done
              [DEBUG] [historyHTML] new history html values created
              [DEBUG] [historyHTML] done
              [DEBUG] [historyJSON] new history json values created
              [DEBUG] [historyJSON] done
              [DEBUG] [email] [ccu] used E-Mail-Instance: email.0
              [DEBUG] [email] done
              [DEBUG] [notification] done
              Bei Konfigurations Ermittlung in SQL Backitup kommt:
              "Konfiguration in sql.0 gefunden, aber nichts geändert"
                Thomas Braun Most Active @Qlink last edited by
                @qlink
                Da fehlt wohl!
                Schau on der Dokumentation nach den Voraussetzungen für ein Backup.
                Q 1 Reply Last reply Reply Quote 1
                • Q
                  Qlink @Thomas Braun last edited by Qlink
                  Aaah jetzt machts klick!
                  Danke für den Hinweis.
                  Mit
                  sudo apt-get update && sudo apt-get upgrade
                  sudo apt install sqlite3
                  läuft jetzt auch das SQL Backup wieder !
                  Ich versuche nämlich gerade meinen iobroker Container auf Docker Compose bzw. Stacks (Portainer) umzustellen...
                  Gibt es eine Möglichkeit in dem Compose File die beiden Befehle oben beim neu deployen des Containers gleich mit zu geben ?
                  • simatec
                    simatec Developer Most Active @Qlink last edited by simatec
                    @qlink Du kannst alle Pakete, die installiert werden sollen, über die Environment Variable (ENV) PACKAGES mitgeben.
                    https://docs.buanet.de/iobroker-docker-image/docs/#environment-variables-env
                    • Q
                      Qlink @simatec last edited by
                      @simatec
                      Das hätte ich eigentlich gemacht.
                      Hier mein Stacks file
                      version: "3"
                      services:
                      ##### IOBROKER #####
                        iobroker:
                          container_name: iobroker-test
                          image: buanet/iobroker:v9.1.1
                          hostname: iobroker
                          restart: always
                          networks:
                            # MACVLAN
                            LAN_public:
                              ipv4_address: 192.168.30.90
                            # Bridge
                            iob_private:
                              ipv4_address: 172.18.0.1
                            iob_private2:
                              ipv4_address: 172.19.0.1
                          environment:
                            - IOB_STATESDB_HOST=redis
                            - IOB_STATESDB_PORT=6379
                            - IOB_STATESDB_TYPE=redis
                            - PACKAGES=sqlite redis-tools
                            - IOB_BACKITUP_EXTDB=true
                          volumes:
                            - /volume3/docker/iobroker_data:/opt/iobroker
                              ##### NETWORKS #####
                      networks:
                        iob_private:
                          external: true
                        iob_private2:
                          external: true
                        LAN_public:
                          external: true
                      sqlite musste ich aber dennoch manuell nach installieren ...
                      Hab ich einen Fehler im Stacks file ?
                        @qlink
                        Das Paket heißt auch sqlite3
                        • Q
                          @thomas-braun Danke für den Hinweis ! 🤦
                          3883
