    3. Off Topic
    4. Grafana
    5. "Unauthorized" Meldung beim Sign in in Grafana
      wibear @Ro75 last edited by
      @ro75 sagte in "Unauthorized" Meldung beim Sign in in Grafana:
      dann hast du ggfs. die einen Fehler in die ini eingebaut.
      Ich hab nur das geändert:
      Ro75 1 Reply Last reply Reply Quote 0
      • Ro75
        Ro75 @wibear last edited by
        @wibear was sagt
        systemctl status grafana-server
        Ro75.
          @ro75
          ist es gut lesbar?
          • Ro75
            @wibear nein. immer in code-tags (</>). Starte mal das Gerät mal neu.
            Ro75.
            W 2 Replies Last reply Reply Quote 0
              @ro75
              ...skipping...
              ● grafana-server.service - Grafana instance
                   Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
                   Active: failed (Result: exit-code) since Sat 2024-10-19 11:18:20 CEST; 15min ago
                     Docs: http://docs.grafana.org
                  Process: 3157 ExecStart=/usr/share/grafana/bin/grafana server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana>
                 Main PID: 3157 (code=exited, status=1/FAILURE)
                      CPU: 394ms
              Oct 19 11:18:20 iobroker-pi systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
              Oct 19 11:18:20 iobroker-pi systemd[1]: Stopped Grafana instance.
              Oct 19 11:18:20 iobroker-pi systemd[1]: grafana-server.service: Start request repeated too quickly.
              Oct 19 11:18:20 iobroker-pi systemd[1]: grafana-server.service: Failed with result 'exit-code'.
              Oct 19 11:18:20 iobroker-pi systemd[1]: Failed to start Grafana instance.
                @ro75
                wibear@iobroker-pi:~ $ systemctl status grafana-server
                     Active: failed (Result: exit-code) since Sat 2024-10-19 11:18:20 CEST; 16min ago
                        CPU: 394ms
                • Ro75
                  @wibear das ist ja von 11:18. Die Kiste mal neu starten.
                  Ro75.
                    zum 2. Mal neu gestartet ohne Erfolg.
                           Active: failed (Result: exit-code) since Sat 2024-10-19 11:37:43 CEST; 4min 36s ago
                          Process: 1675 ExecStart=/usr/share/grafana/bin/grafana server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana>
                         Main PID: 1675 (code=exited, status=1/FAILURE)
                              CPU: 475ms
                      Oct 19 11:37:43 iobroker-pi systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
                      Oct 19 11:37:43 iobroker-pi systemd[1]: Stopped Grafana instance.
                      Oct 19 11:37:43 iobroker-pi systemd[1]: grafana-server.service: Start request repeated too quickly.
                      Oct 19 11:37:43 iobroker-pi systemd[1]: grafana-server.service: Failed with result 'exit-code'.
                      Oct 19 11:37:43 iobroker-pi systemd[1]: Failed to start Grafana instance.
                      • Ro75
                        Ro75 @wibear last edited by Ro75
                        @wibear mach die Änderung in der ini rückgängig. Was passiert dann? Ist Grafana im Docker?
                        Ro75.
                          noch einmal
                          bitte siehe oben (vor einer minute)
                            Habe rückgängig gemacht:
                                 Active: failed (Result: exit-code) since Sat 2024-10-19 11:48:35 CEST; 38s ago
                                Process: 3461 ExecStart=/usr/share/grafana/bin/grafana server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafan>
                               Main PID: 3461 (code=exited, status=1/FAILURE)
                                    CPU: 391ms
                            Oct 19 11:48:35 iobroker-pi systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
                            Oct 19 11:48:35 iobroker-pi systemd[1]: Stopped Grafana instance.
                            Oct 19 11:48:35 iobroker-pi systemd[1]: grafana-server.service: Start request repeated too quickly.
                            Oct 19 11:48:35 iobroker-pi systemd[1]: grafana-server.service: Failed with result 'exit-code'.
                            Oct 19 11:48:35 iobroker-pi systemd[1]: Failed to start Grafana instance.
                            lines 1-13/13 (END)
                            Auf Raspberry läuft IOBroker und Raspberrymatic, kein Docker.
                            • Ro75
                              @wibear wie bzw. mit was hast du die ini geändert. Ggfs. mal die ini hier posten.
                              Ro75.
                                @ro75
                                Geändert mit nano: sudo nano /etc/grafana/grafana.ini
                                Beim Versuch sie mit FileZilla runterzuladen kommt eine Fehlermeldung konnte nicht gestartet werden.
                                Womit kann ich sie noch runterladen?
                                  funkydoc @wibear last edited by
                                  @wibear genauso habe ich es auch gemacht, mit sudo nano ….
                                  Dann nach dem String gesucht, geändert, abgespeichert und Grafana neu gestartet. Fertig und läuft.
                                    @ro75
                                    Ich habe ein Grafana-Backup. Vielleicht damit versuchen?
                                    • Ro75
                                      @wibear was bedeutet Backup genau?
                                      Ro75.
                                        @ro75
                                        • Ro75
                                          @wibear Das sind ja nur die "Diagramme" drin, aber doch nicht Grafana selbst. Keine Ahnung. Hattest du schon einmal
                                          iob diag
                                          gemacht und die Langfassung gepostet?
                                          Ro75.
                                            @ro75
                                            Summary:
                                            ```bash
        v.2024-08-12
                                               Static hostname: iobroker-pi
                                                     Icon name: computer
                                              Operating System: Raspbian GNU/Linux 11 (bullseye)
                                                        Kernel: Linux 6.1.21-v7l+
                                                  Architecture: arm
                                            Installation:           native
                                            Kernel:                 armv7l
                                            Userland:               32 bit
                                            Timezone:               Europe/Berlin (CEST, +0200)
                                            User-ID:                1000
                                            Display-Server:         true
                                            Boot Target:            multi-user.target
                                            Pending OS-Updates:     1
                                            Pending iob updates:    0
                                            Nodejs-Installation:
                                            /usr/bin/nodejs         v20.18.0
                                            /usr/bin/node           v20.18.0
                                            /usr/bin/npm            10.8.2
                                            /usr/bin/npx            10.8.2
                                            /usr/bin/corepack       0.29.3
                                            Recommended versions are nodejs 20.18.0 and npm 10.8.2
                                            MEMORY:
                                            Mem:            3.9G        1.3G        728M        0.0K        1.8G        2.5G
                                            Swap:            99M        5.0M         94M
                                            Total:          4.0G        1.3G        823M
                                            Active iob-Instances:   24
                                            Upgrade policy: patch
                                            ioBroker Core:          js-controller           6.0.11
        admin                   7.1.5
                                            Objects type: jsonl
                                            States  type: jsonl
                                            + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                            + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                            Objects:                7086
                                            States:                 5970
                                            Size of iob-Database:
                                            18M     /opt/iobroker/iobroker-data/objects.jsonl
                                            8.5M    /opt/iobroker/iobroker-data/states.jsonl
                                            ```bash
                                            Skript v.2024-08-12
                                            *** BASE SYSTEM ***
                                                     Icon name: computer
                                                  Architecture: arm
                                            OS is similar to: debian
                                            Model           : Raspberry Pi 4 Model B Rev 1.5
                                            Docker          : false
                                            Virtualization  : none
                                            Kernel          : armv7l
                                            Userland        : 32 bit
                                            Systemuptime and Load:
                                             12:15:40 up 38 min,  1 user,  load average: 0.92, 0.85, 0.61
                                            CPU threads: 4
                                            *** RASPBERRY THROTTLING ***
                                            Current issues:
                                            Previously detected issues:
                                            *** Time and Time Zones ***
                                                           Local time: Sat 2024-10-19 12:15:40 CEST
                                                       Universal time: Sat 2024-10-19 10:15:40 UTC
                                                             RTC time: n/a
                                                          NTP service: active
                                                      RTC in local TZ: no
                                            *** Users and Groups ***
                                            User that called 'iob diag':
                                            wibear
                                            HOME=/home/wibear
                                            GROUPS=wibear adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                            iobroker
                                            HOME=/home/iobroker
                                            GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                            *** Display-Server-Setup ***
                                            Desktop:
                                            Terminal:       tty
                                            *** MEMORY ***
                                            Mem:            3.9G        1.3G        727M        0.0K        1.9G        2.5G
                                            Swap:            99M        5.0M         94M
                                            Total:          4.0G        1.3G        822M
                                                     3887 M total memory
                                                     1308 M used memory
                                                      302 M active memory
                                                     2729 M inactive memory
                                                      727 M free memory
                                                       86 M buffer memory
                                                     1764 M swap cache
                                                       99 M total swap
                                                        5 M used swap
                                                       94 M free swap
                                            top - 12:15:41 up 38 min,  1 user,  load average: 0.92, 0.85, 0.61
                                            Tasks: 205 total,   2 running, 203 sleeping,   0 stopped,   0 zombie
                                            %Cpu(s):  6.1 us,  0.0 sy,  0.0 ni, 93.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                            MiB Mem :   3887.9 total,    727.9 free,   1308.5 used,   1851.5 buff/cache
                                            MiB Swap:    100.0 total,     95.0 free,      5.0 used.   2470.9 avail Mem
                                            *** FAILED SERVICES ***
                                              UNIT                   LOAD   ACTIVE SUB    DESCRIPTION
                                            * grafana-server.service loaded failed failed Grafana instance
                                            LOAD   = Reflects whether the unit definition was properly loaded.
                                            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                                            SUB    = The low-level unit activation state, values depend on unit type.
                                            1 loaded units listed.
                                            *** FILESYSTEM ***
                                            /dev/root      ext4       55G   11G   42G  21% /
                                            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                            tmpfs          tmpfs     778M  1.1M  777M   1% /run
                                            /dev/sda1      vfat      255M   60M  196M  24% /boot
                                            tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
                                            [Sat Oct 19 11:37:16 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:E1:EF:16 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=tty1 root=PARTUUID=e605bf32-02 rootfstype=ext4 fsck.repair=yes rootwait
                                            [Sat Oct 19 11:37:17 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                                            [Sat Oct 19 11:37:17 2024] EXT4-fs (sda2): write access will be enabled during recovery
                                            [Sat Oct 19 11:37:17 2024] EXT4-fs (sda2): recovery complete
                                            [Sat Oct 19 11:37:17 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                            [Sat Oct 19 11:37:17 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                            [Sat Oct 19 11:37:18 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                            Show mounted filesystems:
                                            TARGET  SOURCE    FSTYPE OPTIONS
                                            /       /dev/sda2 ext4   rw,noatime
                                            `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                            /var:
                                            du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
                                            3.8G    /var/
                                            2.0G    /var/log
                                            1.5G    /var/log/journal/6462312882a642219bbda7aff5f4f5b9
                                            943M    /var/cache
                                            Archived and active journals take up 1.4G in the file system.
                                            /opt/iobroker/backups:
                                            82M     /opt/iobroker/backups/
                                            /opt/iobroker/iobroker-data:
                                            909M    /opt/iobroker/iobroker-data/
                                            754M    /opt/iobroker/iobroker-data/files
                                            617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                            12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                                            8.8M    /opt/iobroker/iobroker-data/states.jsonl
                                            8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                                            USB-Devices by-id:
                                            No Devices found 'by-id'
                                            *** NodeJS-Installation ***
                                            /usr/bin/npm            10.8.2
                                            /usr/bin/npx            10.8.2
                                            nodejs:
                                              Installed: 20.18.0-1nodesource1
                                              Candidate: 20.18.0-1nodesource1
                                              Version table:
                                             *** 20.18.0-1nodesource1 600
                                                    500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                                                    100 /var/lib/dpkg/status
                                                 20.17.0-1nodesource1 600
                                                 20.16.0-1nodesource1 600
                                                 20.15.1-1nodesource1 600
                                                 20.15.0-1nodesource1 600
                                                 20.14.0-1nodesource1 600
                                                 20.13.1-1nodesource1 600
                                                 20.13.0-1nodesource1 600
                                                 20.12.2-1nodesource1 600
                                                 20.12.1-1nodesource1 600
                                                 20.12.0-1nodesource1 600
                                                 20.11.1-1nodesource1 600
                                                 20.11.0-1nodesource1 600
                                                 20.10.0-1nodesource1 600
                                                 20.9.0-1nodesource1 600
                                                 20.8.1-1nodesource1 600
                                                 20.8.0-1nodesource1 600
                                                 20.7.0-1nodesource1 600
                                                 20.6.1-1nodesource1 600
                                                 20.6.0-1nodesource1 600
                                                 20.5.1-1nodesource1 600
                                                 20.5.0-1nodesource1 600
                                                 20.4.0-1nodesource1 600
                                                 20.3.1-1nodesource1 600
                                                 20.3.0-1nodesource1 600
                                                 20.2.0-1nodesource1 600
                                                 20.1.0-1nodesource1 600
                                                 20.0.0-1nodesource1 600
                                                 12.22.12~dfsg-1~deb11u5 500
                                                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                            No problems detected
                                            Errors in npm tree:
                                            *** ioBroker-Installation ***
                                            ioBroker Status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            Core adapters versions
                                            js-controller:  6.0.11
                                            admin:          7.1.5
                                            javascript:     8.8.3
                                            nodejs modules from github:     1
                                            +-- iobroker.vw-connect@0.5.3 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#b5fbfb41f65b8a1efb646e9efb68f1cbd1627d27)
                                            Adapter State
                                            + system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              -  enabled
                                            + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
                                            + system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              -  enabled
                                            + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
                                            + system.adapter.ems-esp.0                : ems-esp               : iobroker-pi                              -  enabled
                                              system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-pi                              - disabled
                                              system.adapter.energiefluss.0           : energiefluss          : iobroker-pi                              - disabled
                                            + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-pi                              -  enabled
                                            + system.adapter.fritzdect.0              : fritzdect             : iobroker-pi                              -  enabled
                                              system.adapter.habpanel.0               : habpanel              : iobroker-pi                              -  enabled
                                            + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
                                            + system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              -  enabled
                                            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
                                            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12001
                                            + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12010
                                            + system.adapter.influxdb.0               : influxdb              : iobroker-pi                              -  enabled, port: 8086
                                            + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
                                            + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 192.168.178.10
                                              system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker-pi                              -  enabled
                                            + system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
                                            + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
                                            + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                            + system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
                                              system.adapter.tuya.0                   : tuya                  : iobroker-pi                              - disabled
                                            + system.adapter.vw-connect.0             : vw-connect            : iobroker-pi                              -  enabled
                                              system.adapter.weatherunderground.0     : weatherunderground    : iobroker-pi                              - disabled
                                            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-pi                              -  enabled
                                            + instance is alive
                                            ioBroker-Repositories
                                            │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
                                            Active repo(s): stable
                                            Installed ioBroker-Instances
                                            Used repository: stable
                                            Adapter    "admin"        : 7.1.5    , installed 7.1.5
                                            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                            Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                                            Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                            Adapter    "ems-esp"      : 4.8.0    , installed 4.8.0
                                            Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
                                            Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
                                            Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
                                            Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                                            Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                            Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                                            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                            Controller "js-controller": 6.0.11   , installed 6.0.11
                                            Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                            Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                            Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                                            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                            Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                            Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                                            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                            Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                            Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                            Objects and States
                                            Objects:        7086
                                            States:         5970
                                            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                            Hit:2 https://packages.grafana.com/oss/deb stable InRelease
                                            Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
                                            Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                            Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
                                            Hit:6 https://repos.influxdata.com/debian bullseye InRelease
                                            Reading package lists...
                                            Pending Updates: 1
                                            *** Listening Ports ***
                                            tcp        0      0 192.168.178.10:1883     0.0.0.0:*               LISTEN      1001       20835      2442/io.mqtt.0
                                            tcp        0      0 192.168.178.10:18701    0.0.0.0:*               LISTEN      1001       17102      2163/io.hm-rpc.0
                                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11850      831/sshd: /usr/sbin
                                            tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        11838      784/influxd
                                            tcp        0      0 192.168.178.10:12001    0.0.0.0:*               LISTEN      1001       19800      2386/io.hm-rpc.1
                                            tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       17232      2426/io.hm-rpc.2
                                            tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          11881      878/dnsmasq
                                            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       21089      2543/io.shelly.0
                                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16138      1621/iobroker.js-co
                                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16726      1621/iobroker.js-co
                                            tcp6       0      0 :::22                   :::*                    LISTEN      0          11852      831/sshd: /usr/sbin
                                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21177      2638/io.web.0
                                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16824      1828/io.admin.0
                                            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21153      2621/io.simple-api.
                                            tcp6       0      0 :::8086                 :::*                    LISTEN      999        16087      784/influxd
                                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12690      368/avahi-daemon: r
                                            udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          11880      878/dnsmasq
                                            udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          11877      878/dnsmasq
                                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14528      611/dhclient
                                            udp        0      0 0.0.0.0:40577           0.0.0.0:*                           108        12692      368/avahi-daemon: r
                                            udp6       0      0 :::5353                 :::*                                108        12691      368/avahi-daemon: r
                                            udp6       0      0 :::60456                :::*                                108        12693      368/avahi-daemon: r
                                            2024-10-19 12:00:07.986  - info: netatmo-crawler.0 (4265) Getting data for stationid:70:ee:50:33:0f:3e
                                            2024-10-19 12:00:11.082  - info: netatmo-crawler.0 (4265) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                            2024-10-19 12:00:11.615  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 4265 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2024-10-19 12:01:40.325  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.7
                                            2024-10-19 12:03:10.939  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.7
                                            2024-10-19 12:05:05.023  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 4608
                                            2024-10-19 12:05:07.958  - info: netatmo-crawler.0 (4608) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                            2024-10-19 12:05:08.027  - info: netatmo-crawler.0 (4608) Getting data for stationid:70:ee:50:33:0f:3e
                                            2024-10-19 12:05:09.323  - info: netatmo-crawler.0 (4608) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                            2024-10-19 12:05:09.856  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 4608 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2024-10-19 12:08:33.508  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.178.33
                                            2024-10-19 12:10:05.025  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 4939
                                            2024-10-19 12:10:07.943  - info: netatmo-crawler.0 (4939) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                            2024-10-19 12:10:08.008  - info: netatmo-crawler.0 (4939) Getting data for stationid:70:ee:50:33:0f:3e
                                            2024-10-19 12:10:09.580  - info: netatmo-crawler.0 (4939) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                            2024-10-19 12:10:10.111  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 4939 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2024-10-19 12:10:25.733  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.7
                                            2024-10-19 12:11:10.407  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.8
                                            2024-10-19 12:14:10.520  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.7
                                            2024-10-19 12:14:55.567  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.6
                                            2024-10-19 12:15:05.024  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 6289
                                            2024-10-19 12:15:08.067  - info: netatmo-crawler.0 (6289) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                            2024-10-19 12:15:08.134  - info: netatmo-crawler.0 (6289) Getting data for stationid:70:ee:50:33:0f:3e
                                            2024-10-19 12:15:11.479  - info: netatmo-crawler.0 (6289) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                            2024-10-19 12:15:12.015  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 6289 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            7912
