    3. Off Topic
    4. Grafana
    5. "Unauthorized" Meldung beim Sign in in Grafana
    • Ro75
      Ro75 @wibear last edited by
      @wibear das ist ja von 11:18. Die Kiste mal neu starten.
      Ro75.
      W 2 Replies Last reply Reply Quote 0
        wibear @Ro75 last edited by
        @ro75 sagte in "Unauthorized" Meldung beim Sign in in Grafana:
        zum 2. Mal neu gestartet ohne Erfolg.
        Ro75 1 Reply Last reply Reply Quote 0
          wibear@iobroker-pi:~ $ systemctl status grafana-server
          ● grafana-server.service - Grafana instance
               Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
               Active: failed (Result: exit-code) since Sat 2024-10-19 11:37:43 CEST; 4min 36s ago
                 Docs: http://docs.grafana.org
              Process: 1675 ExecStart=/usr/share/grafana/bin/grafana server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana>
             Main PID: 1675 (code=exited, status=1/FAILURE)
                  CPU: 475ms
          Oct 19 11:37:43 iobroker-pi systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
          Oct 19 11:37:43 iobroker-pi systemd[1]: Stopped Grafana instance.
          Oct 19 11:37:43 iobroker-pi systemd[1]: grafana-server.service: Start request repeated too quickly.
          Oct 19 11:37:43 iobroker-pi systemd[1]: grafana-server.service: Failed with result 'exit-code'.
          Oct 19 11:37:43 iobroker-pi systemd[1]: Failed to start Grafana instance.
          • Ro75
            Ro75 @wibear last edited by Ro75
            @wibear mach die Änderung in der ini rückgängig. Was passiert dann? Ist Grafana im Docker?
            Ro75.
              noch einmal
              bitte siehe oben (vor einer minute)
                Habe rückgängig gemacht:
                     Active: failed (Result: exit-code) since Sat 2024-10-19 11:48:35 CEST; 38s ago
                    Process: 3461 ExecStart=/usr/share/grafana/bin/grafana server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafan>
                   Main PID: 3461 (code=exited, status=1/FAILURE)
                        CPU: 391ms
                Oct 19 11:48:35 iobroker-pi systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
                Oct 19 11:48:35 iobroker-pi systemd[1]: Stopped Grafana instance.
                Oct 19 11:48:35 iobroker-pi systemd[1]: grafana-server.service: Start request repeated too quickly.
                Oct 19 11:48:35 iobroker-pi systemd[1]: grafana-server.service: Failed with result 'exit-code'.
                Oct 19 11:48:35 iobroker-pi systemd[1]: Failed to start Grafana instance.
                lines 1-13/13 (END)
                Auf Raspberry läuft IOBroker und Raspberrymatic, kein Docker.
                • Ro75
                  @wibear wie bzw. mit was hast du die ini geändert. Ggfs. mal die ini hier posten.
                  Ro75.
                    @ro75
                    Geändert mit nano: sudo nano /etc/grafana/grafana.ini
                    Beim Versuch sie mit FileZilla runterzuladen kommt eine Fehlermeldung konnte nicht gestartet werden.
                    Womit kann ich sie noch runterladen?
                      funkydoc @wibear last edited by
                      @wibear genauso habe ich es auch gemacht, mit sudo nano ….
                      Dann nach dem String gesucht, geändert, abgespeichert und Grafana neu gestartet. Fertig und läuft.
                        @ro75
                        Ich habe ein Grafana-Backup. Vielleicht damit versuchen?
                        • Ro75
                          @wibear was bedeutet Backup genau?
                          Ro75.
                            @ro75
                            • Ro75
                              @wibear Das sind ja nur die "Diagramme" drin, aber doch nicht Grafana selbst. Keine Ahnung. Hattest du schon einmal
                              iob diag
                              gemacht und die Langfassung gepostet?
                              Ro75.
                                @ro75
                                Summary:
                                ```bash
                                                        v.2024-08-12
                                   Static hostname: iobroker-pi
                                         Icon name: computer
                                  Operating System: Raspbian GNU/Linux 11 (bullseye)
                                            Kernel: Linux 6.1.21-v7l+
                                      Architecture: arm
                                Installation:           native
                                Kernel:                 armv7l
                                Userland:               32 bit
                                Timezone:               Europe/Berlin (CEST, +0200)
                                User-ID:                1000
                                Display-Server:         true
                                Boot Target:            multi-user.target
                                Pending OS-Updates:     1
                                Pending iob updates:    0
                                Nodejs-Installation:
                                /usr/bin/nodejs         v20.18.0
                                /usr/bin/node           v20.18.0
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                /usr/bin/corepack       0.29.3
                                Recommended versions are nodejs 20.18.0 and npm 10.8.2
                                MEMORY:
                                Mem:            3.9G        1.3G        728M        0.0K        1.8G        2.5G
                                Swap:            99M        5.0M         94M
                                Total:          4.0G        1.3G        823M
                                Active iob-Instances:   24
                                Upgrade policy: patch
                                ioBroker Core:          js-controller           6.0.11
                                                        admin                   7.1.5
                                Objects type: jsonl
                                States  type: jsonl
                                + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                Objects:                7086
                                States:                 5970
                                Size of iob-Database:
                                18M     /opt/iobroker/iobroker-data/objects.jsonl
                                8.5M    /opt/iobroker/iobroker-data/states.jsonl
                                ```bash
                                Skript v.2024-08-12
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm
                                OS is similar to: debian
                                Model           : Raspberry Pi 4 Model B Rev 1.5
                                Docker          : false
                                Virtualization  : none
                                Kernel          : armv7l
                                Userland        : 32 bit
                                Systemuptime and Load:
                                 12:15:40 up 38 min,  1 user,  load average: 0.92, 0.85, 0.61
                                CPU threads: 4
                                *** RASPBERRY THROTTLING ***
                                Current issues:
                                Previously detected issues:
                                *** Time and Time Zones ***
                                               Local time: Sat 2024-10-19 12:15:40 CEST
                                           Universal time: Sat 2024-10-19 10:15:40 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                *** Users and Groups ***
                                User that called 'iob diag':
                                wibear
                                HOME=/home/wibear
                                GROUPS=wibear adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                iobroker
                                HOME=/home/iobroker
                                GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                *** Display-Server-Setup ***
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            3.9G        1.3G        727M        0.0K        1.9G        2.5G
                                Swap:            99M        5.0M         94M
                                Total:          4.0G        1.3G        822M
                                         3887 M total memory
                                         1308 M used memory
                                          302 M active memory
                                         2729 M inactive memory
                                          727 M free memory
                                           86 M buffer memory
                                         1764 M swap cache
                                           99 M total swap
                                            5 M used swap
                                           94 M free swap
                                top - 12:15:41 up 38 min,  1 user,  load average: 0.92, 0.85, 0.61
                                Tasks: 205 total,   2 running, 203 sleeping,   0 stopped,   0 zombie
                                %Cpu(s):  6.1 us,  0.0 sy,  0.0 ni, 93.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :   3887.9 total,    727.9 free,   1308.5 used,   1851.5 buff/cache
                                MiB Swap:    100.0 total,     95.0 free,      5.0 used.   2470.9 avail Mem
                                *** FAILED SERVICES ***
                                  UNIT                   LOAD   ACTIVE SUB    DESCRIPTION
                                * grafana-server.service loaded failed failed Grafana instance
                                LOAD   = Reflects whether the unit definition was properly loaded.
                                ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                                SUB    = The low-level unit activation state, values depend on unit type.
                                1 loaded units listed.
                                *** FILESYSTEM ***
                                /dev/root      ext4       55G   11G   42G  21% /
                                devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                tmpfs          tmpfs     778M  1.1M  777M   1% /run
                                /dev/sda1      vfat      255M   60M  196M  24% /boot
                                tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
                                [Sat Oct 19 11:37:16 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:E1:EF:16 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=tty1 root=PARTUUID=e605bf32-02 rootfstype=ext4 fsck.repair=yes rootwait
                                [Sat Oct 19 11:37:17 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                                [Sat Oct 19 11:37:17 2024] EXT4-fs (sda2): write access will be enabled during recovery
                                [Sat Oct 19 11:37:17 2024] EXT4-fs (sda2): recovery complete
                                [Sat Oct 19 11:37:17 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                [Sat Oct 19 11:37:17 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                [Sat Oct 19 11:37:18 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                Show mounted filesystems:
                                TARGET  SOURCE    FSTYPE OPTIONS
                                /       /dev/sda2 ext4   rw,noatime
                                `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                /var:
                                du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
                                3.8G    /var/
                                2.0G    /var/log
                                1.5G    /var/log/journal/6462312882a642219bbda7aff5f4f5b9
                                943M    /var/cache
                                Archived and active journals take up 1.4G in the file system.
                                /opt/iobroker/backups:
                                82M     /opt/iobroker/backups/
                                /opt/iobroker/iobroker-data:
                                909M    /opt/iobroker/iobroker-data/
                                754M    /opt/iobroker/iobroker-data/files
                                617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                                8.8M    /opt/iobroker/iobroker-data/states.jsonl
                                8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                                USB-Devices by-id:
                                No Devices found 'by-id'
                                *** NodeJS-Installation ***
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                  Installed: 20.18.0-1nodesource1
                                  Candidate: 20.18.0-1nodesource1
                                  Version table:
                                 *** 20.18.0-1nodesource1 600
                                        500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                                        100 /var/lib/dpkg/status
                                     20.17.0-1nodesource1 600
                                     20.16.0-1nodesource1 600
                                     20.15.1-1nodesource1 600
                                     20.15.0-1nodesource1 600
                                     20.14.0-1nodesource1 600
                                     20.13.1-1nodesource1 600
                                     20.13.0-1nodesource1 600
                                     20.12.2-1nodesource1 600
                                     20.12.1-1nodesource1 600
                                     20.12.0-1nodesource1 600
                                     20.11.1-1nodesource1 600
                                     20.11.0-1nodesource1 600
                                     20.10.0-1nodesource1 600
                                     20.9.0-1nodesource1 600
                                     20.8.1-1nodesource1 600
                                     20.8.0-1nodesource1 600
                                     20.7.0-1nodesource1 600
                                     20.6.1-1nodesource1 600
                                     20.6.0-1nodesource1 600
                                     20.5.1-1nodesource1 600
                                     20.5.0-1nodesource1 600
                                     20.4.0-1nodesource1 600
                                     20.3.1-1nodesource1 600
                                     20.3.0-1nodesource1 600
                                     20.2.0-1nodesource1 600
                                     20.1.0-1nodesource1 600
                                     20.0.0-1nodesource1 600
                                     12.22.12~dfsg-1~deb11u5 500
                                        500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                No problems detected
                                Errors in npm tree:
                                *** ioBroker-Installation ***
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Core adapters versions
                                js-controller:  6.0.11
                                admin:          7.1.5
                                javascript:     8.8.3
                                nodejs modules from github:     1
                                +-- iobroker.vw-connect@0.5.3 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#b5fbfb41f65b8a1efb646e9efb68f1cbd1627d27)
                                Adapter State
                                + system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              -  enabled
                                + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
                                + system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              -  enabled
                                + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
                                + system.adapter.ems-esp.0                : ems-esp               : iobroker-pi                              -  enabled
                                  system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-pi                              - disabled
                                  system.adapter.energiefluss.0           : energiefluss          : iobroker-pi                              - disabled
                                + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-pi                              -  enabled
                                + system.adapter.fritzdect.0              : fritzdect             : iobroker-pi                              -  enabled
                                  system.adapter.habpanel.0               : habpanel              : iobroker-pi                              -  enabled
                                + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
                                + system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              -  enabled
                                + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
                                + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12001
                                + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12010
                                + system.adapter.influxdb.0               : influxdb              : iobroker-pi                              -  enabled, port: 8086
                                + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
                                + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 192.168.178.10
                                  system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker-pi                              -  enabled
                                + system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
                                + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
                                + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                + system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
                                  system.adapter.tuya.0                   : tuya                  : iobroker-pi                              - disabled
                                + system.adapter.vw-connect.0             : vw-connect            : iobroker-pi                              -  enabled
                                  system.adapter.weatherunderground.0     : weatherunderground    : iobroker-pi                              - disabled
                                + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-pi                              -  enabled
                                + instance is alive
                                ioBroker-Repositories
                                │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
                                Active repo(s): stable
                                Installed ioBroker-Instances
                                Used repository: stable
                                Adapter    "admin"        : 7.1.5    , installed 7.1.5
                                Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                                Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                Adapter    "ems-esp"      : 4.8.0    , installed 4.8.0
                                Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
                                Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
                                Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
                                Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                                Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                                Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                Controller "js-controller": 6.0.11   , installed 6.0.11
                                Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                                Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                                Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                Objects and States
                                Objects:        7086
                                States:         5970
                                Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                Hit:2 https://packages.grafana.com/oss/deb stable InRelease
                                Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
                                Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
                                Hit:6 https://repos.influxdata.com/debian bullseye InRelease
                                Reading package lists...
                                Pending Updates: 1
                                *** Listening Ports ***
                                tcp        0      0 192.168.178.10:1883     0.0.0.0:*               LISTEN      1001       20835      2442/io.mqtt.0
                                tcp        0      0 192.168.178.10:18701    0.0.0.0:*               LISTEN      1001       17102      2163/io.hm-rpc.0
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11850      831/sshd: /usr/sbin
                                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        11838      784/influxd
                                tcp        0      0 192.168.178.10:12001    0.0.0.0:*               LISTEN      1001       19800      2386/io.hm-rpc.1
                                tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       17232      2426/io.hm-rpc.2
                                tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          11881      878/dnsmasq
                                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       21089      2543/io.shelly.0
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16138      1621/iobroker.js-co
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16726      1621/iobroker.js-co
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          11852      831/sshd: /usr/sbin
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21177      2638/io.web.0
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16824      1828/io.admin.0
                                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21153      2621/io.simple-api.
                                tcp6       0      0 :::8086                 :::*                    LISTEN      999        16087      784/influxd
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12690      368/avahi-daemon: r
                                udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          11880      878/dnsmasq
                                udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          11877      878/dnsmasq
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14528      611/dhclient
                                udp        0      0 0.0.0.0:40577           0.0.0.0:*                           108        12692      368/avahi-daemon: r
                                udp6       0      0 :::5353                 :::*                                108        12691      368/avahi-daemon: r
                                udp6       0      0 :::60456                :::*                                108        12693      368/avahi-daemon: r
                                2024-10-19 12:00:07.986  - info: netatmo-crawler.0 (4265) Getting data for stationid:70:ee:50:33:0f:3e
                                2024-10-19 12:00:11.082  - info: netatmo-crawler.0 (4265) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                2024-10-19 12:00:11.615  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 4265 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-10-19 12:01:40.325  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.7
                                2024-10-19 12:03:10.939  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.7
                                2024-10-19 12:05:05.023  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 4608
                                2024-10-19 12:05:07.958  - info: netatmo-crawler.0 (4608) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                2024-10-19 12:05:08.027  - info: netatmo-crawler.0 (4608) Getting data for stationid:70:ee:50:33:0f:3e
                                2024-10-19 12:05:09.323  - info: netatmo-crawler.0 (4608) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                2024-10-19 12:05:09.856  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 4608 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-10-19 12:08:33.508  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.178.33
                                2024-10-19 12:10:05.025  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 4939
                                2024-10-19 12:10:07.943  - info: netatmo-crawler.0 (4939) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                2024-10-19 12:10:08.008  - info: netatmo-crawler.0 (4939) Getting data for stationid:70:ee:50:33:0f:3e
                                2024-10-19 12:10:09.580  - info: netatmo-crawler.0 (4939) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                2024-10-19 12:10:10.111  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 4939 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-10-19 12:10:25.733  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.7
                                2024-10-19 12:11:10.407  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.8
                                2024-10-19 12:14:10.520  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.7
                                2024-10-19 12:14:55.567  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.6
                                2024-10-19 12:15:05.024  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 6289
                                2024-10-19 12:15:08.067  - info: netatmo-crawler.0 (6289) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                2024-10-19 12:15:08.134  - info: netatmo-crawler.0 (6289) Getting data for stationid:70:ee:50:33:0f:3e
                                2024-10-19 12:15:11.479  - info: netatmo-crawler.0 (6289) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                2024-10-19 12:15:12.015  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 6289 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  Ich habe auch diesen Backup vor ein paar Tagen gemacht:
                                  Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
                                  • Ro75
                                    @wibear tja, möglicherweise ist das die Folge von
                                    Das Dateisystem hat(te) einen Treffer. Da kann u.U. noch einiges "defekt" sein. Grafana könnte auch davon betroffen sein.
                                    Ro75.
                                    • Ro75
                                      @wibear sagte in "Unauthorized" Meldung beim Sign in in Grafana:
                                      nix anderes.
                                      Ro75.
                                        Thomas Braun Most Active @wibear last edited by
                                        @wibear
                                        Da über kurz oder lang ohnehin eine komplette Neuinstallation des Betriebssystems ins Haus steht kannst du es auch jetzt in Angriff nehmen.
                                          wibear @Thomas Braun last edited by
                                          Was meinst Du unter Neuinstallation??
                                            Damit meine ich eine Neuinstallation.
                                            Dein Raspberry 11 'Bullseye' (32Bit) kann ohnehin nicht auf das aktuelle Release 12 'Bookworm' (64Bit) gebracht werden. Musst du also neuinstallieren. Ganz unabhängig von Grafana.
                                            7912
