    3. Off Topic
    4. Grafana
    5. "Unauthorized" Meldung beim Sign in in Grafana
    • Ro75
      Ro75 @wibear last edited by
      @wibear Das sind ja nur die "Diagramme" drin, aber doch nicht Grafana selbst. Keine Ahnung. Hattest du schon einmal
      iob diag
      gemacht und die Langfassung gepostet?
      Ro75.
      W 2 Replies Last reply Reply Quote 0
        wibear @Ro75 last edited by
        @ro75
        Summary:
        ```bash
                                v.2024-08-12
           Static hostname: iobroker-pi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v7l+
              Architecture: arm
        Installation:           native
        Kernel:                 armv7l
        Userland:               32 bit
        Timezone:               Europe/Berlin (CEST, +0200)
        User-ID:                1000
        Display-Server:         true
        Boot Target:            multi-user.target
        Pending OS-Updates:     1
        Pending iob updates:    0
        Nodejs-Installation:
        /usr/bin/nodejs         v20.18.0
        /usr/bin/node           v20.18.0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.3
        Recommended versions are nodejs 20.18.0 and npm 10.8.2
        MEMORY:
        Mem:            3.9G        1.3G        728M        0.0K        1.8G        2.5G
        Swap:            99M        5.0M         94M
        Total:          4.0G        1.3G        823M
        Active iob-Instances:   24
        Upgrade policy: patch
        ioBroker Core:          js-controller           6.0.11
                                admin                   7.1.5
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                7086
        States:                 5970
        Size of iob-Database:
        18M     /opt/iobroker/iobroker-data/objects.jsonl
        8.5M    /opt/iobroker/iobroker-data/states.jsonl
        ```bash
        Skript v.2024-08-12
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm
        OS is similar to: debian
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : 32 bit
        Systemuptime and Load:
         12:15:40 up 38 min,  1 user,  load average: 0.92, 0.85, 0.61
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Sat 2024-10-19 12:15:40 CEST
                   Universal time: Sat 2024-10-19 10:15:40 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        wibear
        HOME=/home/wibear
        GROUPS=wibear adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
        *** Display-Server-Setup ***
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            3.9G        1.3G        727M        0.0K        1.9G        2.5G
        Swap:            99M        5.0M         94M
        Total:          4.0G        1.3G        822M
                 3887 M total memory
                 1308 M used memory
                  302 M active memory
                 2729 M inactive memory
                  727 M free memory
                   86 M buffer memory
                 1764 M swap cache
                   99 M total swap
                    5 M used swap
                   94 M free swap
        top - 12:15:41 up 38 min,  1 user,  load average: 0.92, 0.85, 0.61
        Tasks: 205 total,   2 running, 203 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  6.1 us,  0.0 sy,  0.0 ni, 93.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3887.9 total,    727.9 free,   1308.5 used,   1851.5 buff/cache
        MiB Swap:    100.0 total,     95.0 free,      5.0 used.   2470.9 avail Mem
        *** FAILED SERVICES ***
          UNIT                   LOAD   ACTIVE SUB    DESCRIPTION
        * grafana-server.service loaded failed failed Grafana instance
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       55G   11G   42G  21% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     778M  1.1M  777M   1% /run
        /dev/sda1      vfat      255M   60M  196M  24% /boot
        tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
        [Sat Oct 19 11:37:16 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:E1:EF:16 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=tty1 root=PARTUUID=e605bf32-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Sat Oct 19 11:37:17 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
        [Sat Oct 19 11:37:17 2024] EXT4-fs (sda2): write access will be enabled during recovery
        [Sat Oct 19 11:37:17 2024] EXT4-fs (sda2): recovery complete
        [Sat Oct 19 11:37:17 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sat Oct 19 11:37:17 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Sat Oct 19 11:37:18 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
        3.8G    /var/
        2.0G    /var/log
        1.5G    /var/log/journal/6462312882a642219bbda7aff5f4f5b9
        943M    /var/cache
        Archived and active journals take up 1.4G in the file system.
        /opt/iobroker/backups:
        82M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        909M    /opt/iobroker/iobroker-data/
        754M    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
        8.8M    /opt/iobroker/iobroker-data/states.jsonl
        8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Installed: 20.18.0-1nodesource1
          Candidate: 20.18.0-1nodesource1
          Version table:
         *** 20.18.0-1nodesource1 600
                500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             20.17.0-1nodesource1 600
             20.16.0-1nodesource1 600
             20.15.1-1nodesource1 600
             20.15.0-1nodesource1 600
             20.14.0-1nodesource1 600
             20.13.1-1nodesource1 600
             20.13.0-1nodesource1 600
             20.12.2-1nodesource1 600
             20.12.1-1nodesource1 600
             20.12.0-1nodesource1 600
             20.11.1-1nodesource1 600
             20.11.0-1nodesource1 600
             20.10.0-1nodesource1 600
             20.9.0-1nodesource1 600
             20.8.1-1nodesource1 600
             20.8.0-1nodesource1 600
             20.7.0-1nodesource1 600
             20.6.1-1nodesource1 600
             20.6.0-1nodesource1 600
             20.5.1-1nodesource1 600
             20.5.0-1nodesource1 600
             20.4.0-1nodesource1 600
             20.3.1-1nodesource1 600
             20.3.0-1nodesource1 600
             20.2.0-1nodesource1 600
             20.1.0-1nodesource1 600
             20.0.0-1nodesource1 600
             12.22.12~dfsg-1~deb11u5 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  6.0.11
        admin:          7.1.5
        javascript:     8.8.3
        nodejs modules from github:     1
        +-- iobroker.vw-connect@0.5.3 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#b5fbfb41f65b8a1efb646e9efb68f1cbd1627d27)
        Adapter State
        + system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
        + system.adapter.ems-esp.0                : ems-esp               : iobroker-pi                              -  enabled
          system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-pi                              - disabled
          system.adapter.energiefluss.0           : energiefluss          : iobroker-pi                              - disabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-pi                              -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : iobroker-pi                              -  enabled
          system.adapter.habpanel.0               : habpanel              : iobroker-pi                              -  enabled
        + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12001
        + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12010
        + system.adapter.influxdb.0               : influxdb              : iobroker-pi                              -  enabled, port: 8086
        + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 192.168.178.10
          system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker-pi                              -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
          system.adapter.tuya.0                   : tuya                  : iobroker-pi                              - disabled
        + system.adapter.vw-connect.0             : vw-connect            : iobroker-pi                              -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : iobroker-pi                              - disabled
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-pi                              -  enabled
        + instance is alive
        ioBroker-Repositories
        │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.5    , installed 7.1.5
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "ems-esp"      : 4.8.0    , installed 4.8.0
        Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
        Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
        Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
        Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 6.0.11   , installed 6.0.11
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
        Adapter    "shelly"       : 8.2.1    , installed 8.2.1
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Objects and States
        Objects:        7086
        States:         5970
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:2 https://packages.grafana.com/oss/deb stable InRelease
        Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
        Hit:6 https://repos.influxdata.com/debian bullseye InRelease
        Reading package lists...
        Pending Updates: 1
        *** Listening Ports ***
        tcp        0      0 192.168.178.10:1883     0.0.0.0:*               LISTEN      1001       20835      2442/io.mqtt.0
        tcp        0      0 192.168.178.10:18701    0.0.0.0:*               LISTEN      1001       17102      2163/io.hm-rpc.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11850      831/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        11838      784/influxd
        tcp        0      0 192.168.178.10:12001    0.0.0.0:*               LISTEN      1001       19800      2386/io.hm-rpc.1
        tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       17232      2426/io.hm-rpc.2
        tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          11881      878/dnsmasq
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       21089      2543/io.shelly.0
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16138      1621/iobroker.js-co
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16726      1621/iobroker.js-co
        tcp6       0      0 :::22                   :::*                    LISTEN      0          11852      831/sshd: /usr/sbin
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21177      2638/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16824      1828/io.admin.0
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21153      2621/io.simple-api.
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        16087      784/influxd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12690      368/avahi-daemon: r
        udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          11880      878/dnsmasq
        udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          11877      878/dnsmasq
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14528      611/dhclient
        udp        0      0 0.0.0.0:40577           0.0.0.0:*                           108        12692      368/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        12691      368/avahi-daemon: r
        udp6       0      0 :::60456                :::*                                108        12693      368/avahi-daemon: r
        2024-10-19 12:00:07.986  - info: netatmo-crawler.0 (4265) Getting data for stationid:70:ee:50:33:0f:3e
        2024-10-19 12:00:11.082  - info: netatmo-crawler.0 (4265) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
        2024-10-19 12:00:11.615  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 4265 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-10-19 12:01:40.325  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.7
        2024-10-19 12:03:10.939  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.7
        2024-10-19 12:05:05.023  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 4608
        2024-10-19 12:05:07.958  - info: netatmo-crawler.0 (4608) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
        2024-10-19 12:05:08.027  - info: netatmo-crawler.0 (4608) Getting data for stationid:70:ee:50:33:0f:3e
        2024-10-19 12:05:09.323  - info: netatmo-crawler.0 (4608) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
        2024-10-19 12:05:09.856  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 4608 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-10-19 12:08:33.508  - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.178.33
        2024-10-19 12:10:05.025  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 4939
        2024-10-19 12:10:07.943  - info: netatmo-crawler.0 (4939) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
        2024-10-19 12:10:08.008  - info: netatmo-crawler.0 (4939) Getting data for stationid:70:ee:50:33:0f:3e
        2024-10-19 12:10:09.580  - info: netatmo-crawler.0 (4939) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
        2024-10-19 12:10:10.111  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 4939 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-10-19 12:10:25.733  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.7
        2024-10-19 12:11:10.407  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.8
        2024-10-19 12:14:10.520  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.7
        2024-10-19 12:14:55.567  - info: javascript.0 (1927) script.js.common.Pumpensteuerung: 12.6
        2024-10-19 12:15:05.024  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 6289
        2024-10-19 12:15:08.067  - info: netatmo-crawler.0 (6289) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
        2024-10-19 12:15:08.134  - info: netatmo-crawler.0 (6289) Getting data for stationid:70:ee:50:33:0f:3e
        2024-10-19 12:15:11.479  - info: netatmo-crawler.0 (6289) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
        2024-10-19 12:15:12.015  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 6289 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        Ro75 1 Reply Last reply Reply Quote 0
          @ro75 sagte in "Unauthorized" Meldung beim Sign in in Grafana:
          Ich habe auch diesen Backup vor ein paar Tagen gemacht:
          Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
          • Ro75
            @wibear tja, möglicherweise ist das die Folge von
            Das Dateisystem hat(te) einen Treffer. Da kann u.U. noch einiges "defekt" sein. Grafana könnte auch davon betroffen sein.
            Ro75.
            • Ro75
              @wibear sagte in "Unauthorized" Meldung beim Sign in in Grafana:
              nix anderes.
              Ro75.
                Thomas Braun Most Active @wibear last edited by
                @wibear
                Da über kurz oder lang ohnehin eine komplette Neuinstallation des Betriebssystems ins Haus steht kannst du es auch jetzt in Angriff nehmen.
                  wibear @Thomas Braun last edited by
                  Was meinst Du unter Neuinstallation??
                    Damit meine ich eine Neuinstallation.
                    Dein Raspberry 11 'Bullseye' (32Bit) kann ohnehin nicht auf das aktuelle Release 12 'Bookworm' (64Bit) gebracht werden. Musst du also neuinstallieren. Ganz unabhängig von Grafana.
                      Würdest Du das bitte etwas genauer erläutern? Heißt es, dass meine jetzige Installation, in die ich wie etliche andere Nutzer jede Menge Zeit investiert habe, unbrauchbar geworden ist und wir wieder von vorne anfangen müssen?
                        Das heißt, das du wie üblich Backups anlegst und mit diesen Backups auf ein neuinstalliertes System umziehst.
                        Wie etliche andere Nutzer auch schon. Da muss auch nix 'von vorne' angefangen werden, weil du ja die Daten im Backup hast.
                          @thomas-braun sagte in "Unauthorized" Meldung beim Sign in in Grafana:
                          Wird es dafür irgendeine Anleitung o.ä. geben, da diese Neuinstallation (Umstieg von 32- auf 64-bit ?) etwas komplexer ausfallen dürfte?
                          Gibt's eine Möglichkeit, grafana.ini runterzuladen und/oder durch eine andere zu ersetzen? Bei mir begann der Ärger mit deren Änderung.
                          • Ro75
                            Die ini nicht runterziehen. Nach der Neuinstalltion schauen ob es gleich geht. Wenn nicht, dann die Datei modifizieren. Im übrigen, begannen die Probleme wohl nicht damit. Wie ich schon geschrieben habe, das Dateisystem hat einen Treffer.
                            Ro75.
                              https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                Muss mein 32-bit System auf 64-bit ungestellt werden?
                                Kann ich es jetzt ohne Bedenken über arm_64bit=1 machen?
                                Muss meine SSD gelöscht werden und IOBroker danach neu istalliert werden?
                                Was geschieht dann mit Raspberrymatic?
                                  Thomas Braun Most Active @wibear last edited by Thomas Braun
                                  Irgendwann ganz sicher.
                                  Nein, das ist nur Schminke und kein richtiger Wechsel der Architektur.
                                  Ja, so funktioniert das mit dem Umzug.
                                  Backups einspielen. Muss es ja auch dort geben.
                                  Bei Raspberry OS Bookworm kommt noch dazu, das beim Bootvorgang etwas umgestellt wurde. Und auch das geht man am besten mit einer Neuinstallation an. Das ist im Übrigen auch die offizielle Vorgehensweise, in-line-Dist-Upgrades waren noch nie vorgesehen.
                                    Gibt's einen Grund, warum ich mit FileZilla grafana.ini nicht runterladen kann bzw. gibt's eine andere Möglichkeit zum Runterladen?
                                    Könnte mir bitte jemand für eine Analyse eine Beispiel grafana.ini zur Verfügung stellen?
                                    Danke.
                                    • Ro75
                                      @wibear Die eine Seite sollte der eigene und die andere Seite der "entfernte" Rechner sein. Normalerweise kann man die doch per Drag and Drop rüberziehen?
                                      Ro75.
                                        Bestimmt. Aber ohne die Rechte des Users zu kennen kann ich dazu nix sagen.
                                        Aber warum willst du die Datei überhaupt runter und wieder raufladen?
                                        Viel zu umständlich. Du kommst doch per nano dran.
                                          @ro75
                                          Es funktioniert bei anderen Dateien, nicht aber bei grafana.ini, obwohl sie gleiche Berechtigungen haben.
                                          Homoran Ro75 2 Replies Last reply Reply Quote 0
                                            Homoran Global Moderator Administrators @wibear last edited by
                                            und welche?
                                            7906
