    3. Off Topic
    4. Grafana
    5. "Unauthorized" Meldung beim Sign in in Grafana
      wibear @Ro75 last edited by wibear
      @ro75 sagte in "Unauthorized" Meldung beim Sign in in Grafana:
      mal aktivieren.
      Aktiviert, keine Funktion
      Ro75 1 Reply Last reply Reply Quote 0
      • Ro75
        Ro75 @wibear last edited by
        @wibear du musst aber Grafana danach neu starten.
        Ro75.
          Restart natürlich ausgeführt:
          • Ro75
            @wibear und was sagt der Status?
            Ro75.
              @ro75
               systemctl status grafana-server
              ● grafana-server.service - Grafana instance
                   Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendo>
                   Active: failed (Result: exit-code) since Sat 2024-10-19 16:17:44 CEST; 7mi>
                     Docs: http://docs.grafana.org
                  Process: 9362 ExecStart=/usr/share/grafana/bin/grafana server --config=${CO>
                 Main PID: 9362 (code=exited, status=1/FAILURE)
                      CPU: 412ms
              Oct 19 16:17:44 iobroker-pi systemd[1]: grafana-server.service: Scheduled resta>
              Oct 19 16:17:44 iobroker-pi systemd[1]: Stopped Grafana instance.
              Oct 19 16:17:44 iobroker-pi systemd[1]: grafana-server.service: Start request r>
              Oct 19 16:17:44 iobroker-pi systemd[1]: grafana-server.service: Failed with res>
              Oct 19 16:17:44 iobroker-pi systemd[1]: Failed to start Grafana instance.
              lines 1-13/13 (END)
                   Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
                   Active: failed (Result: exit-code) since Sat 2024-10-19 16:17:44 CEST; 7min ago
                  Process: 9362 ExecStart=/usr/share/grafana/bin/grafana server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packagi>
                      CPU: 412ms
              Oct 19 16:17:44 iobroker-pi systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
              Oct 19 16:17:44 iobroker-pi systemd[1]: grafana-server.service: Start request repeated too quickly.
              Oct 19 16:17:44 iobroker-pi systemd[1]: grafana-server.service: Failed with result 'exit-code'.
                Homoran Global Moderator Administrators @wibear last edited by
                @wibear warum ist da alles abgeschnitten?
                  wibear @Homoran last edited by
                  Ist es besser?
                  wibear@iobroker-pi:~ $ systemctl status grafana-server
                       Active: failed (Result: exit-code) since Sat 2024-10-19 16:17:44 CEST; 10min ago
                      Process: 9362 ExecStart=/usr/share/grafana/bin/grafana server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packaging=deb cfg:default.paths.logs=${LOG_DIR} cfg:default.paths.data=${DATA_DIR} cfg:default.paths.>
                          CPU: 412ms
                  • Ro75
                    Ro75 last edited by
                    @wibear sagte in "Unauthorized" Meldung beim Sign in in Grafana:
                    schaue mal hier. Da wurde das Problem schon einmal besprochen.
                    Ro75.
                      Ich habe die Datei /lib/systemd/system/grafana-server.service mit meiner verglichen: identisch.
                      Mehr konnte ich dem Beitrag nicht entnehmen.
                      • Ro75
                        @wibear dann hätte ich außer einem kompletten Neuanfang (Installation Debian12) - wäre auch die beste Option, nur noch eine Idee.
                        1. sichere die Datei "/var/lib/grafana/grafana.db"
                        2. Entferne Grafana von deinem System
                        3. Installiere Grafana komplett neu
                        4. Starte Grafana und schaue ob du wieder zur Anmeldung kommst
                        Wenn ja dann ab hier weiter
                        1. Stoppe Grafana
                        2. Kopiere die Datei unter Punkt 1 zurück und gib dieser Datei die Rechte von der existierenden
                        3. Starte Grafana neu.
                        Ro75.
                          @ro75
                          Es kommt ein Fehler beim Versuch runterzuladen:
                          • Ro75
                            @wibear was hast du denn immer mit dem "Berechtigungsfenster"? Mit welchen Account loggst du dich den via Filezilla ein?
                            Ro75.
                              Mit dem Account, mit dem ich mich über die Console anmelde.
                              • Ro75
                                Alles klar, damit kann ich nichts anfangen? Root? pi? iobroker? klaus?
                                Ro75.
                                  es ist der einzige User, den ich bei der Installation angelegt habe. Müsste eigentlich root sein.
                                  • Ro75
                                    @wibear genau. Die Rechte, Eigentümer, Gruppe stimmen nicht.
                                    Bei dir ist es root/grafana und 0640. Da passt was überhaupt nicht. Hast du von Grafana via Backitup eine Sicherung die OK ist? Wenn ja, setze neu auf.
                                    Und nix mir Root in Zukunft.
                                    Ro75.
                                      Die Sicherung wurde mit OK geladen, hat aber nichts gebracht.
                                      Ich versuche Grafana neu zu installieren, wie Du zuvor vorgeschlagen hast.
                                      • Ro75
                                        Das ist gut. Mir ging es nur darum, ob in gepackten Datei auch was drin ist.
                                        Ro75.
                                          wibear @Thomas Braun last edited by
                                          Hallo Thomas, ich benutze momentan eine SSD und versuche jetzt auf einer SD dieses Update auf 64-bit auf einem Raspi 4B mit einem Image für Bookworm Lite mittels Raspberry Pi Imager durchzuspielen. Dafür klemme ich die SSD ab und versuche es mit der SD zu booten. Der Raspi bootet aber nicht und die beiden LEDs vorne rot und grün leuchten permanent. Woran könnte es bitte liegen. Danke und Grüße
                                            Thomas Braun Most Active @wibear last edited by
                                            An der Boot-Reihenfolge. Kann man z. B. in
                                            sudo raspi-config
                                            einstellen.
                                            7906
