    4. INSTANZEN werden nicht angezeigt - "Cannot read instances"
      BlackTigga @Thomas Braun last edited by
      @Thomas-Braun
      Habe jetzt meinen neunen Raspi Pi5 gemäß der Installationsanleitung https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht neu aufgesetzt.
      Erhalte jetzt aber beim ausführen von
      curl -sLf https://iobroker.net/install.sh | bash -
      einen Abbruch mit folgender Meldung:
      library: loaded
      Library version=2024-08-11
          Welcome to the ioBroker installer!
          Installer version: 2024-08-11
          You might need to enter your password a couple of times.
          Installing prerequisites (1/4)
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Get:5 https://armbian.github.io/configng stable InRelease [3,264 B]
      Err:5 https://armbian.github.io/configng stable InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 93D6889F9F0E78D5
      Reading package lists... Done
      W: GPG error: https://armbian.github.io/configng stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 93D6889F9F0E78D5
      E: The repository 'https://armbian.github.io/configng stable InRelease' is not signed.
      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
          Node.js not found. Installing...
      rm: cannot remove '/etc/apt/keyrings/nodesource.gpg': No such file or directory
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
      Package: nodejs
      Pin: origin deb.nodesource.com
      Pin-Priority: 1001
      Installed nodejs
      Cannot install Node.js! Please install it manually.
      Ich lese da etwas raus von einem fehlendem public key. Wo/Wie muss ich das bei der Installation beachten?
        @blacktigga sagte in INSTANZEN werden nicht angezeigt - "Cannot read instances":
        warum armbian für einen Raspberry?
          BlackTigga @Homoran last edited by
          @homoran sagte in INSTANZEN werden nicht angezeigt - "Cannot read instances":
          Ich muss bei meinem Rock64 immer noch in die armbian-config um ein paar Einstellungen vorzunehmen und dazu musste ich das durchführen:
          https://github.com/armbian/configng?tab=readme-ov-file#add--install-from-development-repository
          Da ich den Befehl armbian-config auf dem Rasp nicht ausführen konnte (Befehl nicht bekannt), habe ich es hier auch genauso versucht.
          Ich flashe die SD Karte jetzt nochmal mach das nicht.
            Installation läuft jetzt durch....
              Thomas Braun Most Active @BlackTigga last edited by Thomas Braun
              Natürlich nicht... Das heißt ja auch raspi-config bei RaspberryOS. Mit armbian hat das alles nix zu tun. Andere Baustelle.
              Was zur Hölle veranstaltest du da?
                BlackTigga @Thomas Braun last edited by BlackTigga
                @thomas-braun sagte in INSTANZEN werden nicht angezeigt - "Cannot read instances":
                Ich versuche meine absoluten rudimentären Linux Kenntnisse so einzusetzen, dass es einfach funktioniert.... mehr eigentlich nicht.
                Und deswegen auch einen großen Dank an Eure Geduld und Bemühungen!
                  @blacktigga
                  Du hast also einen reinrassigen Raspberry 5?
                  Und warum klatschst du dann da Pakete aus einer anderen Distribution als 'RaspberryOS' rein?
                  Du verfummelst das Ding gerade gnadenlos.
                  Installier das nochmal komplett neu und lass die Finger von armbian-Quellen.
                    Und warum klastschst du dann da Pakete aus einer anderen Distribution als 'RaspberryOS' rein?
                    Das habe ich jetzt auch genauso nochmal gemacht.
                    1:1 das hier umgesetzt https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                    Jetzt noch redis installieren.
                    Reihenfolge erst
                    sudo apt install redis-server
                    und dann Meta-Paket 'redis'
                      @blacktigga
                      Nein, das Meta-Paket ist dazu da alles benötigte gesammelt zu installieren.
                      Also nur
                      Das Paket redis-server kommt dann automatisch mit.
                        Das hier notwendig?:
                        https://forum.iobroker.net/topic/68035/iob-node-fix-skript
                          @blacktigga
                          Ist denn dein nodejs kaputt?
                          Schau dir
                          iob diag
                          an.
                            Schau dir
                            diob diag
                            an.
                            Ich sehe dort zumindest keine Fehlermeldung:
                            Skript v.2024-08-12
                            *** BASE SYSTEM ***
                             Static hostname: All-In-One-RasPi
                                   Icon name: computer
                                      Kernel: Linux 6.6.31+rpt-rpi-2712
                                Architecture: arm64
                            OS is similar to:
                            Model           : Raspberry Pi 5 Model B Rev 1.0
                            Docker          : false
                            Virtualization  : none
                            Kernel          : aarch64
                            Userland        : 64 bit
                            Systemuptime and Load:
                             17:41:45 up  1:43,  3 users,  load average: 0.28, 0.48, 0.63
                            CPU threads: 4
                            *** RASPBERRY THROTTLING ***
                            Current issues:
                            Previously detected issues:
                            *** Time and Time Zones ***
                                           Local time: Sat 2024-10-19 17:41:45 CEST
                                       Universal time: Sat 2024-10-19 15:41:45 UTC
                                             RTC time: Sat 2024-10-19 15:41:45
                                          NTP service: active
                                      RTC in local TZ: no
                            *** Users and Groups ***
                            User that called 'iob diag':
                            blacktigga
                            HOME=/home/blacktigga
                            GROUPS=blacktigga adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                            iobroker
                            HOME=/home/iobroker
                            GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
                            *** Display-Server-Setup ***
                            Display-Server: false
                            Desktop:
                            Terminal:       tty
                            Boot Target:    multi-user.target
                            *** MEMORY ***
                            Mem:            8.4G        1.1G        482M        5.8M        6.9G        7.3G
                            Swap:           209M          0B        209M
                            Total:          8.6G        1.1G        691M
                            Active iob-Instances:   29
                                     8048 M total memory
                                     1092 M used memory
                                     1019 M active memory
                                     6061 M inactive memory
                                      459 M free memory
                                      180 M buffer memory
                                     6418 M swap cache
                                      199 M total swap
                                        0 M used swap
                                      199 M free swap
                            top - 17:41:46 up  1:43,  3 users,  load average: 0.28, 0.48, 0.63
                            Tasks: 156 total,   1 running, 155 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   8048.4 total,    459.2 free,   1093.3 used,   6598.3 buff/cache
                            MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6955.1 avail Mem
                            *** FAILED SERVICES ***
                            0 loaded units listed.
                            *** FILESYSTEM ***
                            udev           devtmpfs  3.8G     0  3.8G   0% /dev
                            tmpfs          tmpfs     805M  5.5M  800M   1% /run
                            /dev/mmcblk0p2 ext4       59G  5.9G   50G  11% /
                            tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                            tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                            /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
                            tmpfs          tmpfs     805M     0  805M   0% /run/user/1000
                            [Sat Oct 19 15:58:08 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:7F:28:9C vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=4f036408-02 rootfstype=ext4 fsck.repair=yes rootwait
                            [Sat Oct 19 15:58:11 2024] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                            [Sat Oct 19 15:58:12 2024] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
                            Show mounted filesystems:
                            TARGET           SOURCE         FSTYPE OPTIONS
                            /                /dev/mmcblk0p2 ext4   rw,noatime
                            `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            /var:
                            808M    /var/
                            404M    /var/cache
                            398M    /var/cache/apt
                            285M    /var/cache/apt/archives
                            168M    /var/lib
                            Archived and active journals take up 36.0M in the file system.
                            /opt/iobroker/backups:
                            7.6M    /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            968M    /opt/iobroker/iobroker-data/
                            924M    /opt/iobroker/iobroker-data/files
                            617M    /opt/iobroker/iobroker-data/files/javascript.admin
                            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                            44M     /opt/iobroker/iobroker-data/objects.jsonl
                            38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                            24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                            24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                            USB-Devices by-id:
                            No Devices found 'by-id'
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs         v20.18.0
                            /usr/bin/node           v20.18.0
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            /usr/bin/corepack       0.29.3
                            nodejs:
                              Installed: 20.18.0-1nodesource1
                              Candidate: 20.18.0-1nodesource1
                              Version table:
                             *** 20.18.0-1nodesource1 1001
                                    500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                    100 /var/lib/dpkg/status
                                 20.17.0-1nodesource1 1001
                                 20.16.0-1nodesource1 1001
                                 20.15.1-1nodesource1 1001
                                 20.15.0-1nodesource1 1001
                                 20.14.0-1nodesource1 1001
                                 20.13.1-1nodesource1 1001
                                 20.13.0-1nodesource1 1001
                                 20.12.2-1nodesource1 1001
                                 20.12.1-1nodesource1 1001
                                 20.12.0-1nodesource1 1001
                                 20.11.1-1nodesource1 1001
                                 20.11.0-1nodesource1 1001
                                 20.10.0-1nodesource1 1001
                                 20.9.0-1nodesource1 1001
                                 20.8.1-1nodesource1 1001
                                 20.8.0-1nodesource1 1001
                                 20.7.0-1nodesource1 1001
                                 20.6.1-1nodesource1 1001
                                 20.6.0-1nodesource1 1001
                                 20.5.1-1nodesource1 1001
                                 20.5.0-1nodesource1 1001
                                 20.4.0-1nodesource1 1001
                                 20.3.1-1nodesource1 1001
                                 20.3.0-1nodesource1 1001
                                 20.2.0-1nodesource1 1001
                                 20.1.0-1nodesource1 1001
                                 20.0.0-1nodesource1 1001
                                 18.19.0+dfsg-6~deb12u2 500
                                 18.19.0+dfsg-6~deb12u1 500
                            No problems detected
                            Errors in npm tree:
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: redis
                            Core adapters versions
                            js-controller:  6.0.11
                            admin:          7.1.5
                            javascript:     8.8.3
                            nodejs modules from github:     3
                            +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                            +-- iobroker.vw-connect@0.5.4 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#85f79d2a7282c7dacb8899fe2d0822971e549018)
                            `-- iobroker.wmswebcontrol@0.1.2 (git+ssh://git@github.com/TA2k/ioBroker.wmswebcontrol.git#b298042f51db69c5f49eb675adbc4f1147767ac5)
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : All-In-One-RasPi                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.backitup.0               : backitup              : All-In-One-RasPi                         -  enabled
                            + system.adapter.bluelink.0               : bluelink              : All-In-One-RasPi                         - disabled
                            + system.adapter.cloud.0                  : cloud                 : All-In-One-RasPi                         - disabled
                            + system.adapter.daikin.0                 : daikin                : All-In-One-RasPi                         - disabled
                            + system.adapter.daikin.1                 : daikin                : All-In-One-RasPi                         - disabled
                              system.adapter.daikin.2                 : daikin                : All-In-One-RasPi                         - disabled
                            + system.adapter.daikin.3                 : daikin                : All-In-One-RasPi                         - disabled
                              system.adapter.daswetter.0              : daswetter             : All-In-One-RasPi                         - disabled
                              system.adapter.discovery.0              : discovery             : All-In-One-RasPi                         - disabled
                            + system.adapter.email.0                  : email                 : All-In-One-RasPi                         - disabled
                              system.adapter.flot.0                   : flot                  : All-In-One-RasPi                         - disabled
                            + system.adapter.history.0                : history               : All-In-One-RasPi                         - disabled
                            + system.adapter.hm-rega.0                : hm-rega               : All-In-One-RasPi                         - disabled
                            + system.adapter.hm-rega.1                : hm-rega               : All-In-One-RasPi                         - disabled
                            + system.adapter.hm-rpc.0                 : hm-rpc                : All-In-One-RasPi                         - disabled, port: 0
                            + system.adapter.hm-rpc.1                 : hm-rpc                : All-In-One-RasPi                         - disabled, port: 0
                              system.adapter.icons-material-png.0     : icons-material-png    : All-In-One-RasPi                         - disabled
                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : All-In-One-RasPi                         - disabled
                              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : All-In-One-RasPi                         - disabled
                            + system.adapter.iot.0                    : iot                   : All-In-One-RasPi                         - disabled
                              system.adapter.javascript.0             : javascript            : All-In-One-RasPi                         - disabled
                            + system.adapter.logparser.0              : logparser             : All-In-One-RasPi                         - disabled
                              system.adapter.mobile.0                 : mobile                : All-In-One-RasPi                         - disabled
                            + system.adapter.modbus.0                 : modbus                : All-In-One-RasPi                         - disabled
                            + system.adapter.ping.0                   : ping                  : All-In-One-RasPi                         - disabled
                            + system.adapter.pushover.0               : pushover              : All-In-One-RasPi                         - disabled
                              system.adapter.scenes.0                 : scenes                : All-In-One-RasPi                         - disabled
                            + system.adapter.shelly.0                 : shelly                : All-In-One-RasPi                         - disabled, port: 1882, bind: 0.0.0.0
                            + system.adapter.smartgarden.0            : smartgarden           : All-In-One-RasPi                         - disabled
                            + system.adapter.socketio.0               : socketio              : All-In-One-RasPi                         - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                            + system.adapter.sonoff.0                 : sonoff                : All-In-One-RasPi                         - disabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.sonos.0                  : sonos                 : All-In-One-RasPi                         - disabled
                            + system.adapter.viessmannapi.0           : viessmannapi          : All-In-One-RasPi                         - disabled
                              system.adapter.vis-bars.0               : vis-bars              : All-In-One-RasPi                         - disabled
                              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : All-In-One-RasPi                         - disabled
                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : All-In-One-RasPi                         - disabled
                              system.adapter.vis-icontwo.0            : vis-icontwo           : All-In-One-RasPi                         - disabled
                            + system.adapter.vis-inventwo.0           : vis-inventwo          : All-In-One-RasPi                         - disabled
                              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : All-In-One-RasPi                         - disabled
                              system.adapter.vis-justgage.0           : vis-justgage          : All-In-One-RasPi                         - disabled
                              system.adapter.vis-map.0                : vis-map               : All-In-One-RasPi                         - disabled
                              system.adapter.vis-materialdesign.0     : vis-materialdesign    : All-In-One-RasPi                         - disabled
                              system.adapter.vis-metro.0              : vis-metro             : All-In-One-RasPi                         - disabled
                              system.adapter.vis-plumb.0              : vis-plumb             : All-In-One-RasPi                         - disabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : All-In-One-RasPi                         - disabled
                              system.adapter.vis-weather.0            : vis-weather           : All-In-One-RasPi                         - disabled
                              system.adapter.vis.0                    : vis                   : All-In-One-RasPi                         - disabled
                            + system.adapter.vw-connect.0             : vw-connect            : All-In-One-RasPi                         - disabled
                            + system.adapter.web.0                    : web                   : All-In-One-RasPi                         - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + system.adapter.wmswebcontrol.0          : wmswebcontrol         : All-In-One-RasPi                         - disabled
                            + instance is alive
                            ioBroker-Repositories
                            │ (index) │ name               │ url                                                     │ auto upgrade │
                            │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                            │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                            Active repo(s): Stable (default)
                            Upgrade policy: none
                            Installed ioBroker-Instances
                            Used repository: Stable (default)
                            Adapter    "admin"        : 7.1.5    , installed 7.1.5
                            Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                            Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
                            Adapter    "daikin"       : 1.4.2    , installed 1.4.2
                            Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
                            Adapter    "email"        : 1.3.1    , installed 1.3.1
                            Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                            Adapter    "iot"          : 3.3.0    , installed 3.3.0
                            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                            Controller "js-controller": 6.0.11   , installed 6.0.11
                            Adapter    "logparser"    : 2.2.2    , installed 2.2.2
                            Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                            Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                            Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                            Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                            Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                            Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
                            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                            Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                            Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                            Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
                            Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                            Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                            Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                            Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                            Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                            Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                            Adapter    "wmswebcontrol": 0.1.0    , installed 0.1.2
                            Adapter    "ws"           : 2.6.2    , installed 2.5.11 [Updatable]
                            Objects and States
                            Objects:        32920
                            States:         22727
                            Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                            Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                            Pending Updates: 0
                            *** Listening Ports ***
                            tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      106        41768      15562/redis-server
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       61743      29096/iobroker.js-c
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3897       847/sshd: /usr/sbin
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       61839      29244/io.admin.0
                            tcp6       0      0 ::1:6379                :::*                    LISTEN      106        41769      15562/redis-server
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          3899       847/sshd: /usr/sbin
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5058       667/avahi-daemon: r
                            udp        0      0 0.0.0.0:47116           0.0.0.0:*                           104        5060       667/avahi-daemon: r
                            udp6       0      0 fe80::6a25:96ae:1c5:546 :::*                                0          5720       773/NetworkManager
                            udp6       0      0 :::5353                 :::*                                104        5059       667/avahi-daemon: r
                            udp6       0      0 :::42527                :::*                                104        5061       667/avahi-daemon: r
                            2024-10-19 17:34:58.122  - info: host.All-In-One-RasPi iobroker npm-install: upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
                            2024-10-19 17:34:58.124  - info: host.All-In-One-RasPi iobroker npm-install: upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
                            2024-10-19 17:34:58.128  - info: host.All-In-One-RasPi iobroker npm-install: upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
                            2024-10-19 17:34:58.132  - info: host.All-In-One-RasPi iobroker npm-install: upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript2024-10-19 17:34:58.136  - info: host.All-In-One-RasPi iobroker npm-install: upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                            2024-10-19 17:34:58.139  - info: host.All-In-One-RasPi iobroker npm-install: upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
                            2024-10-19 17:34:58.141  - info: host.All-In-One-RasPi iobroker npm-install: upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
                            2024-10-19 17:34:58.147  - info: host.All-In-One-RasPi iobroker npm-install: upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon2024-10-19 17:34:58.151  - info: host.All-In-One-RasPi iobroker npm-install: upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
                            2024-10-19 17:34:58.328  - info: host.All-In-One-RasPi iobroker npm-install: host.All-In-One-RasPi object system.adapter.web created/updated
                            2024-10-19 17:34:59.401  - info: host.All-In-One-RasPi iobroker npm-install: exit 0
                            2024-10-19 17:35:00.401  - warn: host.All-In-One-RasPi startInstance cannot find adapter "wmswebcontrol@0.1.2". Try to install it... 1 attempt
                            2024-10-19 17:35:00.402  - info: host.All-In-One-RasPi iobroker url TA2k/ioBroker.wmswebcontrol#b298042f51db69c5f49eb675adbc4f1147767ac5 wmswebcontrol using installedFrom
                            2024-10-19 17:35:01.240  - info: host.All-In-One-RasPi iobroker npm-install: install TA2k/ioBroker.wmswebcontrol#b298042f51db69c5f49eb675adbc4f1147767ac5
                            2024-10-19 17:35:01.353  - info: host.All-In-One-RasPi iobroker npm-install: NPM version: 10.8.2
                            2024-10-19 17:35:01.354  - info: host.All-In-One-RasPi iobroker npm-install: Installing TA2k/ioBroker.wmswebcontrol#b298042f51db69c5f49eb675adbc4f1147767ac5... (System call)
                            2024-10-19 17:35:10.860  - info: host.All-In-One-RasPi iobroker npm-install:
                            2024-10-19 17:35:10.860  - info: host.All-In-One-RasPi iobroker npm-install: added 15 packages in 9s
                            2024-10-19 17:35:10.861  - info: host.All-In-One-RasPi iobroker npm-install: 287 packages are looking for funding  run `npm fund` for details
                            2024-10-19 17:35:10.973  - info: host.All-In-One-RasPi iobroker npm-install: upload [4] wmswebcontrol.admin /opt/iobroker/node_modules/iobroker.wmswebcontrol/admin/admin.d.ts admin.d.ts video/mp2t2024-10-19 17:35:10.977  - info: host.All-In-One-RasPi iobroker npm-install: upload [3] wmswebcontrol.admin /opt/iobroker/node_modules/iobroker.wmswebcontrol/admin/index_m.html index_m.html text/html
                            2024-10-19 17:35:10.979  - info: host.All-In-One-RasPi iobroker npm-install: upload [2] wmswebcontrol.admin /opt/iobroker/node_modules/iobroker.wmswebcontrol/admin/style.css style.css text/css
                            2024-10-19 17:35:10.985  - info: host.All-In-One-RasPi iobroker npm-install: upload [1] wmswebcontrol.admin /opt/iobroker/node_modules/iobroker.wmswebcontrol/admin/wmswebcontrol.png wmswebcontrol.png image/png
                            2024-10-19 17:35:10.988  - info: host.All-In-One-RasPi iobroker npm-install: upload [0] wmswebcontrol.admin /opt/iobroker/node_modules/iobroker.wmswebcontrol/admin/words.js words.js application/javascript
                            2024-10-19 17:35:12.059  - info: host.All-In-One-RasPi iobroker npm-install: exit 0
                              @blacktigga
                              Ja, schaut gut aus. In der Zusammenfassung dürfte sowas drin stehen:
                              Nodejs-Installation:
                              /usr/bin/nodejs         v23.0.0
                              /usr/bin/node           v23.0.0
                              /usr/bin/npm            10.9.0
                              /usr/bin/npx            10.9.0
                              /usr/bin/corepack       0.29.4
                              Recommended versions are nodejs 20.18.0 and npm 10.8.2
                                Ja, das tut es...
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                Your nodejs installation is correc
                                  BlackTigga @BlackTigga last edited by
                                  @all
                                  Mit dem Raspi Pi5 läuft mein System jetzt wieder einwandfrei!!
                                  Dann lag es am Ende doch an der Performance meines Rock64.
                                  Vielen vielen Dank für Eure Unterstützung!
                                    Homoran Global Moderator Administrators @BlackTigga last edited by
                                    Eigentlich nicht.
                                    Der ist sehr leistungsfähig
                                    2042
