    3. Off Topic
    4. Proxmox
    5. Proxmox Neuling - Hilfestellungen
      chuck2941 @Thomas Braun last edited by
      @thomas-braun ja reicht auch, das externe Backup werde ich noch einrichten.
      Mir geht es hauptsächlich darum, warum mir als Speicher vom Hauptsystem nur 100GB angezeigt werden.
      Für den ioBroker habe ich 64GB festgelegt.
      Anscheinend wird dieser Speicher von den 1TB abgezogen.
        Homoran Global Moderator Administrators @chuck2941 last edited by
        @chuck2941 zeig mal iob diag in der Langfassung
          chuck2941 @Homoran last edited by
          @homoran ```
          Skript v.2024-08-12
          *** BASE SYSTEM ***
           Static hostname: ioBroker
                 Icon name: computer-container
                   Chassis: container ☐
            Virtualization: lxc
                    Kernel: Linux 6.8.12-2-pve
              Architecture: x86-64
          OS is similar to:
          model name	: Intel(R) Core(TM) i5-8500T CPU @ 2.10GHz
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           14:32:24 up 11 days, 20:27,  2 users,  load average: 0.75, 0.35, 0.28
          CPU threads: 3
          *** Time and Time Zones ***
                         Local time: Sat 2024-10-19 14:32:24 CEST
                     Universal time: Sat 2024-10-19 12:32:24 UTC
                           RTC time: n/a
                        NTP service: inactive
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          mbarf
          HOME=/home/mbarf
          GROUPS=mbarf sudo users iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev redis
          *** Display-Server-Setup ***
          Display-Server: false
          Desktop:
          Terminal: 	tty
          Boot Target: 	graphical.target
          *** MEMORY ***
          Mem:             12G        5.5G        4.8G        131K        2.3G        7.1G
          Swap:           1.6G         16M        1.6G
          Total:           14G        5.5G        6.4G
          Active iob-Instances: 	55
                  12000 M total memory
                   5205 M used memory
                   3571 M active memory
                   3557 M inactive memory
                   4621 M free memory
                      0 M buffer memory
                   2173 M swap cache
                   1500 M total swap
                     16 M used swap
                   1483 M free swap
          top - 14:32:24 up 11 days, 20:27,  2 users,  load average: 0.75, 0.35, 0.28
          Tasks:  87 total,   1 running,  86 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  12000.0 total,   4620.0 free,   5206.8 used,   2173.4 buff/cache
          MiB Swap:   1500.0 total,   1483.9 free,     16.1 used.   6793.2 avail Mem
          *** FAILED SERVICES ***
            UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
          * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
          * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          2 loaded units listed.
          *** FILESYSTEM ***
          Filesystem                       Type      Size  Used Avail Use% Mounted on
          /dev/mapper/pve-vm--100--disk--0 ext4       63G  8.6G   51G  15% /
          none                             tmpfs     492K  4.0K  488K   1% /dev
          udev                             devtmpfs   16G     0   16G   0% /dev/tty
          tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
          tmpfs                            tmpfs     6.3G  148K  6.3G   1% /run
          tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs                            tmpfs     3.2G     0  3.2G   0% /run/user/1000
          dmesg: read kernel buffer failed: Operation not permitted
          Show mounted filesystems:
          TARGET SOURCE                           FSTYPE OPTIONS
          /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
          /var:
          2.8G	/var/
          2.3G	/var/lib
          1.2G	/var/lib/influxdb/engine/data/ae559eccecd6aead/autogen
          Archived and active journals take up 15.7M in the file system.
          /opt/iobroker/backups:
          711M	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          69M	/opt/iobroker/iobroker-data/
          62M	/opt/iobroker/iobroker-data/files
          31M	/opt/iobroker/iobroker-data/files/backitup.admin
          31M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
          14M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
          7.0M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
          5.6M	/opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
          5.5M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
          5.0M	/opt/iobroker/iobroker-data/objects.jsonl
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d0b5d8e14945ed1182bbca8f0a86e0b4-if00-port0
          HINT:
          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
          /dev/ttyUSB0
          *** NodeJS-Installation ***
          /usr/bin/nodejs 	v20.18.0
          /usr/bin/node 		v20.18.0
          /usr/bin/npm 		10.8.2
          /usr/bin/npx 		10.8.2
          /usr/bin/corepack 	0.29.3
          nodejs:
            Installed: 20.18.0-1nodesource1
            Candidate: 20.18.0-1nodesource1
            Version table:
           *** 20.18.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org bookworm-security/main amd64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          At least one iobroker host is running.
          Objects type: redis
          States  type: redis
          Core adapters versions
          js-controller: 	6.0.11
          admin: 		7.1.5
          javascript: 	8.8.3
          nodejs modules from github: 	5
          +-- iobroker.energiefluss-erweitert@0.5.1-alpha.9 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#bcd9eb403fddf289985da5dcd92b1cc057ab9975)
          +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
          +-- iobroker.hue@3.12.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.hue.git#6fc77551f44d7d2c4ba6607f41e9317ee3bd853b)
          +-- iobroker.smart-eq@0.1.1 (git+ssh://git@github.com/TA2k/ioBroker.smart-eq.git#9eec31511c3b94b2281b5565abe75b3f4cab5f27)
          +-- iobroker.vesync@0.0.7 (git+ssh://git@github.com/TA2k/ioBroker.vesync.git#b0109fb28c94f7a3664eb0e599fd8359808a7b3e)
          Adapter State
          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
            system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
          + system.adapter.bydhvs.0                 : bydhvs                : ioBroker                                 -  enabled
          + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
          + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
          + system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
            system.adapter.devices.0                : devices               : ioBroker                                 - disabled
          + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
            system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
          + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
          + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: ioBroker                                 -  enabled
          + system.adapter.energiefluss-erweitert.2 : energiefluss-erweitert: ioBroker                                 -  enabled
          + system.adapter.evcc.0                   : evcc                  : ioBroker                                 -  enabled, port: 7070
            system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
            system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
          + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
          + system.adapter.govee-app.0              : govee-app             : ioBroker                                 -  enabled
          + system.adapter.history.0                : history               : ioBroker                                 -  enabled
          + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
          + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
            system.adapter.hue.1                    : hue                   : ioBroker                                 - disabled, port: 443
            system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker                                 - disabled
            system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
          + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
          + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
          + system.adapter.jarvis.0                 : jarvis                : ioBroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
          + system.adapter.meross.0                 : meross                : ioBroker                                 -  enabled
          + system.adapter.mihome-cloud.0           : mihome-cloud          : ioBroker                                 -  enabled
          + system.adapter.mihome-plug.0            : mihome-plug           : ioBroker                                 -  enabled, port: 54321
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
          + system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
            system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
          + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
          + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
          + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
          + system.adapter.reolink.0                : reolink               : ioBroker                                 -  enabled
          + system.adapter.reolink.1                : reolink               : ioBroker                                 -  enabled
            system.adapter.roborock.0               : roborock              : ioBroker                                 - disabled
          + system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.sma-em.0                 : sma-em                : ioBroker                                 -  enabled
          + system.adapter.smart-eq.0               : smart-eq              : ioBroker                                 -  enabled
          + system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.statistics.0             : statistics            : ioBroker                                 -  enabled
          + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
            system.adapter.tr-064.0                 : tr-064                : ioBroker                                 - disabled
          + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
            system.adapter.uv-protect.0             : uv-protect            : ioBroker                                 -  enabled
          + system.adapter.vesync.0                 : vesync                : ioBroker                                 -  enabled
            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 - disabled
            system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker                                 - disabled
            system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 - disabled
            system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: ioBroker                                 - disabled
            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 - disabled
          + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
            system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
            system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
            system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
            system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
          + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 -  enabled
          + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : ioBroker                                 -  enabled
          + system.adapter.wifilight.0              : wifilight             : ioBroker                                 -  enabled
            system.adapter.yr.0                     : yr                    : ioBroker                                 -  enabled
          + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/ttyUSB0
          + instance is alive
          ioBroker-Repositories
          │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
          Active repo(s): stable
          Upgrade policy: patch
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.1.5    , installed 7.1.5
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "backitup"     : 3.0.25   , installed 3.0.25
          Adapter    "birthdays"    : 3.0.1    , installed 3.0.1
          Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
          Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
          Adapter    "device-watcher": 2.12.1  , installed 2.12.1
          Adapter    "echarts"      : 1.9.2    , installed 1.9.2
          Adapter    "energiefluss-erweitert": 0.4.1, installed 0.5.1-alpha.9
          Adapter    "evcc"         : 0.1.1    , installed 0.1.1
          Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
          Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
          Adapter    "hmip"         : 1.24.3   , installed 1.24.3
          Adapter    "hue"          : 3.12.0   , installed 3.12.0
          Adapter    "ical"         : 1.15.0   , installed 1.15.0
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 6.0.11   , installed 6.0.11
          Adapter    "meross"       : 1.17.0   , installed 1.17.0
          Adapter    "mihome-cloud" : 0.1.0    , installed 0.1.0
          Adapter    "mihome-plug"  : 0.4.0    , installed 0.4.0
          Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
          Adapter    "modbus"       : 6.3.2    , installed 6.3.2
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "notification-manager": 1.2.1, installed 1.2.1
          Adapter    "openweathermap": 1.1.2   , installed 1.1.2
          Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
          Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
          Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
          Adapter    "reolink"      : 1.1.1    , installed 1.1.1
          Adapter    "roborock"     : 0.6.16   , installed 0.6.16
          Adapter    "scenes"       : 3.2.3    , installed 3.2.3
          Adapter    "shelly"       : 8.2.1    , installed 8.2.1
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "sma-em"       : 1.1.0    , installed 1.1.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "statistics"   : 2.4.0    , installed 2.4.0
          Adapter    "telegram"     : 3.9.0    , installed 3.9.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
          Adapter    "uv-protect"   : 0.6.3    , installed 0.6.3
          Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
          Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
          Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
          Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
          Adapter    "vis-2-widgets-jaeger-design": 1.2.7, installed 1.2.7
          Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
          Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
          Adapter    "wifilight"    : 1.2.2    , installed 1.2.2
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Adapter    "yr"           : 5.3.0    , installed 5.3.0
          Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
          Objects and States
          Objects: 	38520
          States: 	32729
          Hit:1 http://security.debian.org bookworm-security InRelease
          Hit:2 http://deb.debian.org/debian bookworm InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 https://repos.influxdata.com/debian stable InRelease
          Hit:5 https://repo.mosquitto.org/debian bookworm InRelease
          Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
          Get:7 https://dl.evcc.io/public/evcc/stable/deb/debian bookworm InRelease
          Hit:8 https://packages.redis.io/deb bookworm InRelease
          Fetched 5127 B in 1s (9083 B/s)
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          6002       1/init
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      106        37020902   106998/mosquitto
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       10565345   31511/io.shelly.1
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7142       303/master
          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      105        11267      130/redis-server 12
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       22969      1063/io.jarvis.0
          tcp6       0      0 :::7070                 :::*                    LISTEN      107        237188     2582/evcc
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7143       303/master
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27726      1289/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5000       329/io.admin.0
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       22013      1138/io.simple-api.
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        188058     2322/influxd
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       22130      1169/io.socketio.0
          tcp6       0      0 :::3000                 :::*                    LISTEN      1001       20768      1018/io.fullybrowse
          tcp6       0      0 :::22                   :::*                    LISTEN      0          8088       1/init
          tcp6       0      0 :::111                  :::*                    LISTEN      0          6004       1/init
          tcp6       0      0 ::1:6379                :::*                    LISTEN      105        11268      130/redis-server 12
          tcp6       0      0 :::1883                 :::*                    LISTEN      106        37020903   106998/mosquitto
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          6003       1/init
          udp        0    896 0.0.0.0:53421           0.0.0.0:*                           1001       14750      625/io.mihome-vacuu
          udp        0      0 0.0.0.0:53423           0.0.0.0:*                           1001       13729      610/io.mihome-plug.
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        236365     2582/evcc
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       7406129    22636/io.shelly.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       13973      761/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       13974      761/io.tuya.0
          udp        0      0 0.0.0.0:9522            0.0.0.0:*                           107        237172     2582/evcc
          udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1001       13929      746/io.sma-em.0
          udp6       0      0 :::111                  :::*                                0          6005       1/init
          udp6       0      0 :::5353                 :::*                                107        236366     2582/evcc
          2024-10-19 14:15:57.082  - info: host.ioBroker instance system.adapter.daswetter.0 having pid 116443 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-10-19 14:20:42.006  - info: host.ioBroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 116463
          2024-10-19 14:20:42.898  - info: dwd.0 (116463) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.0, js-controller: 6.0.11
          2024-10-19 14:20:43.161  - info: dwd.0 (116463) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-10-19 14:20:43.671  - info: host.ioBroker instance system.adapter.dwd.0 having pid 116463 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-10-19 14:25:42.007  - info: host.ioBroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 116483
          2024-10-19 14:25:42.910  - info: dwd.0 (116483) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.0, js-controller: 6.0.11
          2024-10-19 14:25:43.142  - info: dwd.0 (116483) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-10-19 14:25:43.654  - info: host.ioBroker instance system.adapter.dwd.0 having pid 116483 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-10-19 14:30:00.014  - info: host.ioBroker instance system.adapter.ical.1 in version "1.15.0" started with pid 116502
          2024-10-19 14:30:00.969  - info: ical.1 (116502) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
          2024-10-19 14:30:01.475  - info: ical.1 (116502) processing URL: Google Kalender Adi https://calendar.google.com/calendar/ical/adibarf%40gmail.com/private-80973f8c1152a2a1adf0eb6f039dcc1b/basic.ics
          2024-10-19 14:30:01.660  - info: ical.1 (116502) processing URL: Google Kalender Markus https://calendar.google.com/calendar/ical/markus.adi%40t-online.de/private-b0ec75a7ea2fd2cf30e535b1e12849db/basic.ics
          2024-10-19 14:30:06.828  - info: ical.1 (116502) Terminated (NO_ERROR): Without reason
          2024-10-19 14:30:07.339  - info: host.ioBroker instance system.adapter.ical.1 having pid 116502 terminated with code 0 (NO_ERROR)
          2024-10-19 14:30:42.007  - info: host.ioBroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 116517
          2024-10-19 14:30:42.905  - info: dwd.0 (116517) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.0, js-controller: 6.0.11
          2024-10-19 14:30:43.133  - info: dwd.0 (116517) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-10-19 14:30:43.643  - info: host.ioBroker instance system.adapter.dwd.0 having pid 116517 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-10-19 14:30:53.007  - info: host.ioBroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 116532
          2024-10-19 14:30:53.725  - info: daswetter.0 (116532) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
          2024-10-19 14:30:56.520  - info: daswetter.0 (116532) still wrong data structure from server received! repaired...
          2024-10-19 14:30:57.145  - info: daswetter.0 (116532) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
          2024-10-19 14:30:57.648  - info: daswetter.0 (116532) cleaned everything up...
          2024-10-19 14:30:57.657  - info: host.ioBroker instance system.adapter.daswetter.0 having pid 116532 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          iob diag has finished.
          Press any key for a summary
            crunchip Forum Testing Most Active @chuck2941 last edited by
            @chuck2941 sagte in Umzug von Raspberry 4 auf 5:
            Filesystem Type Size Used Avail Use% Mounted on /dev/mapper/pve-vm--100--disk--0 ext4 63G 8.6G 51G 15% /
            es werden hier aber nur ca. 100GB angezeigt,
            da stimmt doch hinten und vorne was nicht
            Swap: 1.6G 16M 1.6G
            genauso bei deinem Ram
            unabhängig davon hab ich nur quergelesen, weil`s um Proxmox geht, der Titel jedoch was ganz anderes sagt🤔
            C 1 Reply Last reply Reply Quote 1
              saeft_2003 Most Active @chuck2941 last edited by
              @chuck2941
              wie viel GB hat bei dir local und local-lvm?
              local hat bei mir 100GB und local-lvm 360GB bei einer 500GB SSD.
                chuck2941 @saeft_2003 last edited by
                @saeft_2003 local hat 100GB, local-lvm 855GB.
                  chuck2941 @crunchip last edited by
                  @crunchip ja den Titel habe ich so benannt weil ich ursprünglich auf einen Rapy 5 umsteigen wollte, ist dann aber auf Empfehlungen anders gekommen, soll ich ihn lieber umbenennen?
                  Bin mit Proxmox noch sehr unerfahren, habe im Moment wegen Renovierungen auch nicht so viel Zeit um mich in alles einzulesen.
                  ioBroker habe ich seit knapp 2 Jahren, wollte was neues ausprobieren.
                  Was meinst du damit das was mit dem RAM und sonst was nicht stimmt?
                    Habe die Überschrift jetzt mal geändert, vielleicht können dann mehr Leute auf mein Problem antworten!?
                      die Ausgabe von iob diag passt nicht im geringsten zu deinem screen aus deinem Beitrag
                      Swap: 1.6G, dein screen zeigt jedoch 8GB
                      dein Laufwerk hat laut screen knapp 100GB, davon rund 68% belegt, jedoch
                      diag zeigt
                       63G  8.6G   51G  15%
                      heißt, deine Platte ist 63Gb groß, davon 8.6Gb belegt
                        chuck2941 @crunchip last edited by chuck2941
                        @crunchip ich habe einen Container angelegt wo ioBroker läuft mit folgenden Daten
                        Das System hat 1TB Speicher und 32GB RAM und 6 Kerne insgesamt.
                          @chuck2941 ok und wo liegt jetzt genau das Problem bzw was funktioniert nicht?
                            @crunchip das mir hier als Laufwerksspeicher nur ca. 100GB Laufwerksspeicher angezeigt wird, müsste da nicht die 1TB angezeigt werden?
                            Ist doch die Übersicht von allem oder?
                              @chuck2941 zeig mal bitte die Ausgabe von
                              • pvdisplay
                              • vgdisplay
                              • lvdisplay
                                @crunchip
                                --- Physical volume ---
                                  PV Name               /dev/nvme0n1p3
                                  VG Name               pve
                                  PV Size               930.51 GiB / not usable 4.69 MiB
                                  Allocatable           yes
                                  PE Size               4.00 MiB
                                  Total PE              238210
                                  Free PE               4096
                                  Allocated PE          234114
                                  PV UUID               col1Mq-mjuv-7IaT-WTLb-PwF0-jbWc-J2Cb3c
                                --- Volume group ---
                                  VG Name               pve
                                  System ID
                                  Format                lvm2
                                  Metadata Areas        1
                                  Metadata Sequence No  77
                                  VG Access             read/write
                                  VG Status             resizable
                                  MAX LV                0
                                  Cur LV                6
                                  Open LV               5
                                  Max PV                0
                                  Cur PV                1
                                  Act PV                1
                                  VG Size               <930.51 GiB
                                  PE Size               4.00 MiB
                                  Total PE              238210
                                  Alloc PE / Size       234114 / <914.51 GiB
                                  Free  PE / Size       4096 / 16.00 GiB
                                  VG UUID               OHpOhh-JUJT-5Dm0-0xZc-rhks-m9xh-wnt4me
                                --- Logical volume ---
                                  LV Path                /dev/pve/vm-101-disk-1
                                  LV Name                vm-101-disk-1
                                  VG Name                pve
                                  LV UUID                iB5Xsv-Vkj1-Yfu3-q23C-ta35-6f7l-dJXnEE
                                  LV Write Access        read/write
                                  LV Creation host, time Barf, 2024-10-10 05:20:16 +0200
                                  LV Pool name           data
                                  LV Status              available
                                  # open                 1
                                  LV Size                32.00 GiB
                                  Mapped size            22.64%
                                  Current LE             8192
                                  Segments               1
                                  Allocation             inherit
                                  Read ahead sectors     auto
                                  - currently set to     256
                                  Block device           252:8
                                  crunchip Forum Testing Most Active @chuck2941 last edited by crunchip
                                  @chuck2941 sagte in Proxmox Neuling - Hilfestellungen:
                                  Logical volume
                                  da fehlt bisserl was, wie z.b. folgende
                                  /dev/pve/swap
                                  /dev/pve/root
                                  /dev/pve/vm-100
                                  der Rest oben passt eigentlich
                                    @crunchip
                                      LV Name                data
                                      VG Name                pve
                                      LV UUID                nAC5az-bexV-CvMx-jmUe-ER2J-YfA0-wxmMx7
                                      LV Write Access        read/write (activated read only)
                                      LV Creation host, time proxmox, 2024-10-05 15:04:24 +0200
                                      LV Pool metadata       data_tmeta
                                      LV Pool data           data_tdata
                                      LV Status              available
                                      # open                 0
                                      LV Size                794.30 GiB
                                      Allocated pool data    8.66%
                                      Allocated metadata     0.52%
                                      Current LE             203342
                                      Segments               1
                                      Allocation             inherit
                                      Block device           252:5
                                      LV Path                /dev/pve/swap
                                      LV Name                swap
                                      VG Name                pve
                                      LV UUID                pp6OnP-nmzc-jl7K-Aal8-KYIr-a9w0-iAob4k
                                      LV Creation host, time proxmox, 2024-10-05 15:04:06 +0200
                                      LV Status              available
                                      # open                 2
                                      LV Size                8.00 GiB
                                      Current LE             2048
                                      Segments               1
                                      Allocation             inherit
                                      Block device           252:0
                                      LV Path                /dev/pve/root
                                      LV Name                root
                                      VG Name                pve
                                      LV UUID                1p75hY-Xwzl-qqV7-b2um-Clpb-EZ2O-ufK5VO
                                      LV Status              available
                                      # open                 1
                                      LV Size                96.00 GiB
                                      Current LE             24576
                                      Segments               1
                                      Allocation             inherit
                                      Block device           252:1
                                      LV Path                /dev/pve/vm-100-disk-0
                                      LV Name                vm-100-disk-0
                                      VG Name                pve
                                      LV UUID                qtlj3O-Ik8u-V09O-Mh84-GhwZ-DhNS-P9VhuE
                                      LV Creation host, time Barf, 2024-10-05 15:26:21 +0200
                                      LV Pool name           data
                                      LV Status              available
                                      # open                 1
                                      LV Size                64.00 GiB
                                      Mapped size            96.10%
                                      Current LE             16384
                                      Segments               1
                                      Allocation             inherit
                                      Block device           252:6
                                      LV Path                /dev/pve/vm-101-disk-0
                                      LV Name                vm-101-disk-0
                                      VG Name                pve
                                      LV UUID                e9A1OZ-uWk9-zPcT-o0Qm-vvcO-f1S8-3ZGKrp
                                      LV Creation host, time Barf, 2024-10-10 05:20:15 +0200
                                      LV Pool name           data
                                      LV Status              available
                                      # open                 1
                                      LV Size                4.00 MiB
                                      Mapped size            0.00%
                                      Current LE             1
                                      Segments               1
                                      Allocation             inherit
                                      Block device           252:7
                                      VG Name                pve
                                      LV Pool name           data
                                      LV Status              available
                                      # open                 1
                                      LV Size                32.00 GiB
                                      Mapped size            22.64%
                                      Current LE             8192
                                      Segments               1
                                      Allocation             inherit
                                      Block device           252:8
                                      das hatte ich, glaube ich, vergessen
                                        /dev/pve/root
                                        passt doch, dein root(local) Laufwerk beträgt 96GB
                                        und dein (local)lvm 794.30GB
                                        du hast da aber auch noch ne /dev/pve/vm-101-disk-0 rum liegen, hattest du bei der VM Probleme? gelöscht, backup gemacht zurückgespielt...?
                                        weil deine jetzige VM, disk-1 verwendet, anstatt disk-0
                                        • Dr. Bakterius
                                          Dr. Bakterius Most Active @chuck2941 last edited by
                                          Ich habe bei mir eine 1TB SSD verbaut, es werden hier aber nur ca. 100GB angezeigt, kann mir jemand sagen warum?
                                          Das passt schon so. Proxmox teilt die Platte bei der Installation auf. Die 100 GB reserviert sich Proxmox für sich selbst (local). Der Rest (local-lvm) steht dann für VMs und LXCs zur Verfügung.
                                            Also ich verstehe das nicht, ja bin auch noch ein Anfänger aber ich habe jetzt eine 2TB SSD extern angebunden um dort die Backups zu sichern.
                                            Er zeigt mir nur die 100 GB an die fast voll sind.
                                            Was ist mit den restlichen 1,9TB?
                                            81.1k
                                            193
                                            33517
