Test Adapter iobroker.Zigbee 1.10.10
hier mit der aktuellen 1.10.10:
Edit: Docker V10, js-controller 7.00host.iobroker 2024-10-19 22:29:09.887 info Restart adapter system.adapter.zigbee.0 because enabled host.iobroker 2024-10-19 22:29:09.887 error instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) host.iobroker 2024-10-19 22:29:09.887 error Caught by controller[2]: at Controller.onZclPayload (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:844:26) host.iobroker 2024-10-19 22:29:09.887 error Caught by controller[2]: at Controller.identifyUnknownDevice (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:543:26) host.iobroker 2024-10-19 22:29:09.887 error Caught by controller[2]: at ZStackAdapter.sendZdo (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:311:16) host.iobroker 2024-10-19 22:29:09.887 error Caught by controller[2]: at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:36:20) host.iobroker 2024-10-19 22:29:09.887 error Caught by controller[2]: at processTicksAndRejections (node:internal/process/task_queues:95:5) host.iobroker 2024-10-19 22:29:09.887 error Caught by controller[2]: at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:403:47 host.iobroker 2024-10-19 22:29:09.887 error Caught by controller[2]: at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:59:23) host.iobroker 2024-10-19 22:29:09.886 error Caught by controller[2]: Error: AREQ - ZDO - ieeeAddrRsp after 10000ms host.iobroker 2024-10-19 22:29:09.886 error Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: zigbee.0 2024-10-19 22:29:09.343 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee.0 2024-10-19 22:29:09.342 info terminating zigbee.0 2024-10-19 22:29:05.740 info Zigbee: disabling joining new devices. zigbee.0 2024-10-19 22:29:05.738 info cleaned everything up... zigbee.0 2024-10-19 22:29:05.733 error AREQ - ZDO - ieeeAddrRsp after 10000ms zigbee.0 2024-10-19 22:29:05.732 error Error: AREQ - ZDO - ieeeAddrRsp after 10000ms at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:59:23) at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:403:47 at processTicksAndRejections (node:internal/process/task_queues:95:5) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:36:20) at ZStackAdapter.sendZdo (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:311:16) at Controller.identifyUnknownDevice (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:543:26) at Controller.onZclPayload (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:844:26) zigbee.0 2024-10-19 22:29:05.720 error unhandled promise rejection: AREQ - ZDO - ieeeAddrRsp after 10000ms zigbee.0 2024-10-19 22:29:05.719 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). influxdb.0 2024-10-19 22:28:59.059 info Store 1001 buffered influxDB history points
@ilovegym sagte in Test Adapter iobroker.Zigbee 1.10.10:
Edit: Docker V10, js-controller 7.00- Welche Koordinator Hardware
- Welche Firmware auf dem Koordinator ?
cc26x2r1
Bitte installiert die aktuelle Version. Ich habe noch eine Anpassung durchgeführt.
A.
@asgothian Leider keine Änderung.
hmm etwas besser, aber es kommen keine Werte an..
startet jetzt, dann kommt empty object...host.iobroker 2024-10-20 00:12:06.413 info Restart adapter system.adapter.zigbee.0 because enabled host.iobroker 2024-10-20 00:12:06.412 error instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) host.iobroker 2024-10-20 00:12:06.412 error Caught by controller[4]: at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:383:37) host.iobroker 2024-10-20 00:12:06.412 error Caught by controller[4]: at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:10907:34) host.iobroker 2024-10-20 00:12:06.412 error Caught by controller[4]: at Zigbee.emit (node:domain:488:12) host.iobroker 2024-10-20 00:12:06.412 error Caught by controller[4]: at Zigbee.emit (node:events:531:35) host.iobroker 2024-10-20 00:12:06.412 error Caught by controller[4]: at Zigbee.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:16:48) host.iobroker 2024-10-20 00:12:06.412 error Caught by controller[4]: at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:84:34) host.iobroker 2024-10-20 00:12:06.412 error Caught by controller[4]: at Commands.getChannels (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:513:52) host.iobroker 2024-10-20 00:12:06.411 error Caught by controller[4]: at ZigbeeController.getChannelsEnergy (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:1020:41) host.iobroker 2024-10-20 00:12:06.411 error Caught by controller[4]: at Znp.request (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:276:34) host.iobroker 2024-10-20 00:12:06.411 error Caught by controller[4]: at Function.createRequest (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/zpiObject.ts:57:19) host.iobroker 2024-10-20 00:12:06.411 error Caught by controller[4]: Error: Command request 'mgmtNwkUpdateReq' from subsystem '5' not found host.iobroker 2024-10-20 00:12:06.411 error Caught by controller[4]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.iobroker 2024-10-20 00:12:06.411 error Caught by controller[3]: TICMeter: Exposes: No endpoint host.iobroker 2024-10-20 00:12:06.411 error Caught by controller[2]: zhc:lixee: Not able to detect the current tarif. Not filtering any expose... host.iobroker 2024-10-20 00:12:06.411 error Caught by controller[1]: zhc:lixee: Was not able to detect the Linky energy_phase. Default to single_phase host.iobroker 2024-10-20 00:12:06.410 error Caught by controller[0]: zhc:lixee: Was not able to detect the Linky linky_mode. Default to historique zigbee.0 2024-10-20 00:12:05.852 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee.0 2024-10-20 00:12:05.851 info terminating zigbee.0 2024-10-20 00:12:05.028 info Zigbee: disabling joining new devices. zigbee.0 2024-10-20 00:12:05.026 info cleaned everything up... zigbee.0 2024-10-20 00:12:05.021 error Command request 'mgmtNwkUpdateReq' from subsystem '5' not found zigbee.0 2024-10-20 00:12:05.021 error Error: Command request 'mgmtNwkUpdateReq' from subsystem '5' not found at Function.createRequest (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/zpiObject.ts:57:19) at Znp.request (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:276:34) at ZigbeeController.getChannelsEnergy (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:1020:41) at Commands.getChannels (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:513:52) at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:84:34) at Zigbee.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:16:48) at Zigbee.emit (node:events:531:35) at Zigbee.emit (node:domain:488:12) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:10907:34) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:383:37) zigbee.0 2024-10-20 00:12:04.924 error unhandled promise rejection: Command request 'mgmtNwkUpdateReq' from subsystem '5' not found zigbee.0 2024-10-20 00:12:04.924 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). tuya.0 2024-10-20 00:12:04.867 info bfd7260934b09826b5fki4: Error on Reconnect (7): connection timed out tuya.0 2024-10-20 00:12:03.019 info bfeeaa29ccb41608a6wp8h: Error on Reconnect (5): connection timed out tuya.0 2024-10-20 00:12:01.801 info bf173c5af3445d8de5ayds: Error on Reconnect (1): connection timed out zigbee.0 2024-10-20 00:12:00.459 error empty object! sonoff.0 2024-10-20 00:11:59.670 info Client [USBSwitch15] connected with secret 1729375919669_1883 zigbee.0 2024-10-20 00:11:59.227 error empty object! zigbee.0 2024-10-20 00:11:59.218 error empty object! zigbee.0 2024-10-20 00:11:59.179 error empty object! zigbee.0 2024-10-20 00:11:59.168 error empty object! zigbee.0 2024-10-20 00:11:59.116 error empty object! zigbee.0 2024-10-20 00:11:59.102 error empty object! zigbee.0 2024-10-20 00:11:59.098 error empty object! zigbee.0 2024-10-20 00:11:59.067 error empty object! zigbee.0 2024-10-20 00:11:59.023 error empty object! zigbee.0 2024-10-20 00:11:59.013 error empty object! zigbee.0 2024-10-20 00:11:58.980 error empty object! zigbee.0 2024-10-20 00:11:58.975 error empty object! zigbee.0 2024-10-20 00:11:58.929 error empty object! zigbee.0 2024-10-20 00:11:58.917 info List of port: [{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}] zigbee.0 2024-10-20 00:11:58.864 error empty object! zigbee.0 2024-10-20 00:11:58.860 error empty object! zigbee.0 2024-10-20 00:11:58.829 error empty object!
startet jetzt, dann kommt empty object...Kannst du beschreiben was du genau getan hast ?
Bei mir läuft der Adapter prinzipiell so, allerdings kann ich den hier geposteten Fehler erzwingen.
- Wie entsteht der Fehler bei Dir ?
- was passiert wenn du versuchst Zigbee-Geräte zu steuern ? Gibt es Fehlermeldungen im Log ?
- Wie sieht die Kommunikation mit einem Gerät bei Dir aus, wenn du wie @ritter ein Gerät für die Debug-Messages einträgst (Anleitung dazu weiter oben) ?
A.
frag nich.. ich hatte ja diese Testversion 1.10.9 aus deinem Repo die ganze Zeit laufen, lief auch zu 98% gut.
Jetzt startet der Zigbee gar nicht mehr, immer mit diesem Fehler, gerade von Git geladen:zigbee.0 2024-10-20 10:21:09.494 error Error herdsman start zigbee.0 2024-10-20 10:21:09.494 error Failed to start Zigbee zigbee.0 2024-10-20 10:21:09.493 error Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby (Error: AREQ - ZDO - stateChangeInd after 60000ms\n at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:59:23)\n at ZnpAdapterManager.beginCommissioning (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:370:31)\n at processTicksAndRejections (node:internal/process/task_queues:95:5)\n at ZnpAdapterManager.start (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:91:21)\n at ZStackAdapter.start (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:158:16)\n at Controller.start (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)\n at ZigbeeController.start (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:131:13)\n at Zigbee.doConnect (/opt/iobroker/node_modules/iobroker.zigbee/main.js:316:13))"
@ilovegym
gerade nochmal Adapter gestoppt, den TI power-resetted, in den Einstellungen des Adapters gesehen, dass bei Sendeleistung Sendeleistung stand, also anstatt normal, high usw. stand da Sendeleistung Sendeleistung drin..
Hab jetzt mal auf normal gestellt.. und der Adapter startet... -
@asgothian adapter ist gestartet, laeuft, aber alle Devices offline.
Hier mal eins auf Debug gesetzt:2024-10-20 10:38:31.240 - info: zigbee.0 (16360) starting. Version 1.10.10 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.0, js-controller: 7.0.0 2024-10-20 10:38:31.282 - info: zigbee.0 (16360) Starting Zigbee npm ... 2024-10-20 10:38:31.436 - info: zigbee.0 (16360) Installed Version: ioBroker/ioBroker.zigbee 2024-10-20 10:38:32.733 - info: zigbee.0 (16360) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}} 2024-10-20 10:38:32.733 - info: zigbee.0 (16360) Unable to disable LED, unsupported function. 2024-10-20 10:38:32.741 - info: zigbee.0 (16360) --> transmitPower : normal 2024-10-20 10:38:33.026 - info: zigbee.0 (16360) Currently 247 devices are joined: 2024-10-20 10:38:33.453 - info: sonoff.0 (1174) Client [USBSwitch15] connected with secret 1729413513415_6160 2024-10-20 10:38:33.588 - info: zigbee.0 (16360) 0x00158d00011083e8 (addr 4803): MFKZQ01LM - Aqara Cube (EndDevice) 2024-10-20 10:38:33.593 - info: zigbee.0 (16360) 0x00158d00042adb71 (addr 7040): SJCGQ11LM - Aqara Water leak sensor (EndDevice) 2024-10-20 10:38:33.595 - info: zigbee.0 (16360) 0x00158d00022daa58 (addr 24588): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.596 - info: zigbee.0 (16360) 0x00158d00022efe8a (addr 10197): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.596 - info: zigbee.0 (16360) 0x00158d0005d10648 (addr 10084): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.597 - info: zigbee.0 (16360) 0x00158d0002325709 (addr 17093): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.598 - info: zigbee.0 (16360) 0x00158d00020edd4a (addr 8765): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.598 - info: zigbee.0 (16360) 0x00158d00022efe3a (addr 44959): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.599 - info: zigbee.0 (16360) 0x00158d000255be9d (addr 28986): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice) 2024-10-20 10:38:33.600 - info: zigbee.0 (16360) 0x00158d0002289d91 (addr 3167): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice) 2024-10-20 10:38:33.600 - info: zigbee.0 (16360) 0x00158d0002b728d7 (addr 50115): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.601 - info: zigbee.0 (16360) 0x00158d0001245a23 (addr 12995): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.601 - info: zigbee.0 (16360) 0x04cf8cdf3c7d0f25 (addr 19206): GZCGQ01LM - Xiaomi Mi light sensor (EndDevice) 2024-10-20 10:38:33.602 - info: zigbee.0 (16360) 0x04cf8cdf3c78ccbd (addr 37431): GZCGQ01LM - Xiaomi Mi light sensor (EndDevice) 2024-10-20 10:38:33.602 - info: zigbee.0 (16360) 0x00158d0001f40701 (addr 17431): MCCGQ01LM - Xiaomi Mi door and window sensor (EndDevice) 2024-10-20 10:38:33.603 - info: zigbee.0 (16360) 0x00158d0001fa4d24 (addr 25921): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.604 - info: zigbee.0 (16360) 0x00158d0001e63db3 (addr 57819): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.604 - info: zigbee.0 (16360) 0x00158d0001f536ab (addr 24346): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.605 - info: zigbee.0 (16360) 0x00158d00032c0ff2 (addr 56767): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.605 - info: zigbee.0 (16360) 0x00158d0001a920f2 (addr 15393): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice) 2024-10-20 10:38:33.606 - info: zigbee.0 (16360) 0x00158d0002280fbe (addr 50294): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice) 2024-10-20 10:38:33.606 - info: zigbee.0 (16360) 0x04cf8cdf3c7d1801 (addr 38880): GZCGQ01LM - Xiaomi Mi light sensor (EndDevice) 2024-10-20 10:38:33.607 - info: zigbee.0 (16360) 0x04cf8cdf3c78a5f5 (addr 14379): GZCGQ01LM - Xiaomi Mi light sensor (EndDevice) 2024-10-20 10:38:33.607 - info: zigbee.0 (16360) 0x00158d000232d0ab (addr 16466): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.608 - info: zigbee.0 (16360) 0x00158d0002278b91 (addr 40132): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice) 2024-10-20 10:38:33.608 - info: zigbee.0 (16360) 0x00158d0001fa6c38 (addr 18271): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.609 - info: zigbee.0 (16360) 0x00158d000237c84c (addr 44377): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.609 - info: zigbee.0 (16360) 0x00158d0001bb8e47 (addr 31591): SJCGQ11LM - Aqara Water leak sensor (EndDevice) 2024-10-20 10:38:33.610 - info: zigbee.0 (16360) 0x00158d00023f3787 (addr 2485): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.610 - info: zigbee.0 (16360) 0x00158d0001f46f70 (addr 43937): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.611 - info: zigbee.0 (16360) 0x00158d0006f944f9 (addr 28162): SJCGQ11LM - Aqara Water leak sensor (EndDevice) 2024-10-20 10:38:33.612 - info: zigbee.0 (16360) 0x00158d00057fc8a4 (addr 5764): 371000001 - Paulmann SmartHome led spot tuneable white (Router) 2024-10-20 10:38:33.612 - info: zigbee.0 (16360) 0x00158d00024ee7c0 (addr 46689): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.613 - info: zigbee.0 (16360) 0x00158d00054276b5 (addr 4401): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice) 2024-10-20 10:38:33.614 - info: zigbee.0 (16360) 0x00158d0003495ba6 (addr 49186): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.614 - info: zigbee.0 (16360) 0x00158d000201c965 (addr 19255): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.615 - info: zigbee.0 (16360) 0x00158d00022f1480 (addr 9249): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.615 - info: zigbee.0 (16360) 0x00158d0002b5d5c8 (addr 58030): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.615 - info: zigbee.0 (16360) 0x00158d0002018617 (addr 36042): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.616 - info: zigbee.0 (16360) 0x00158d000200cfd1 (addr 40754): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.616 - info: zigbee.0 (16360) 0x00158d00022dab84 (addr 40011): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.617 - info: zigbee.0 (16360) 0x00158d0001dbc002 (addr 33235): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice) 2024-10-20 10:38:33.617 - info: zigbee.0 (16360) 0x00158d0001f40767 (addr 50712): MCCGQ01LM - Xiaomi Mi door and window sensor (EndDevice) 2024-10-20 10:38:33.618 - info: zigbee.0 (16360) 0x00158d0001dbbb73 (addr 50776): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice) 2024-10-20 10:38:33.618 - info: zigbee.0 (16360) 0x00158d0001dd4820 (addr 33469): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.618 - info: zigbee.0 (16360) 0x00158d0005cf42b3 (addr 26094): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.619 - info: zigbee.0 (16360) 0x00158d00027ce18e (addr 9232): MFKZQ01LM - Aqara Cube (EndDevice) 2024-10-20 10:38:33.619 - info: zigbee.0 (16360) 0x00158d000275dc7a (addr 9581): MFKZQ01LM - Aqara Cube (EndDevice) 2024-10-20 10:38:33.620 - info: zigbee.0 (16360) 0x00158d0002b49e19 (addr 16019): WXKG02LM_rev2 - Aqara Wireless remote switch (double rocker), 2018 model (EndDevice) 2024-10-20 10:38:33.620 - info: zigbee.0 (16360) 0x00158d0001d58d56 (addr 8293): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice) 2024-10-20 10:38:33.621 - info: zigbee.0 (16360) 0x00158d0002310183 (addr 25226): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.621 - info: zigbee.0 (16360) 0x00158d000237d2a4 (addr 39589): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.622 - info: zigbee.0 (16360) 0xe0798dfffe8d93b8 (addr 23959): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router) 2024-10-20 10:38:33.622 - info: zigbee.0 (16360) 0x00158d000232aa16 (addr 24079): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.623 - info: zigbee.0 (16360) 0x00158d0001c2025b (addr 37180): WXKG01LM - Xiaomi Mi wireless switch (EndDevice) 2024-10-20 10:38:33.623 - info: zigbee.0 (16360) 0x00158d00020e386c (addr 36436): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.624 - info: zigbee.0 (16360) 0x00158d000238693f (addr 60259): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.624 - info: zigbee.0 (16360) 0x00158d0002327f1b (addr 60990): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.624 - info: zigbee.0 (16360) 0x00158d000232cc33 (addr 32866): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.625 - info: zigbee.0 (16360) 0x00158d000273a07a (addr 8591): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.625 - info: zigbee.0 (16360) 0x00158d00022efe53 (addr 20447): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.626 - info: zigbee.0 (16360) 0x00158d000201c424 (addr 36727): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.626 - info: zigbee.0 (16360) 0x00158d0002a61db3 (addr 10566): MCCGQ01LM - Xiaomi Mi door and window sensor (EndDevice) 2024-10-20 10:38:33.626 - info: zigbee.0 (16360) 0x00158d00032ba8af (addr 59474): JTYJ-GD-01LM/BW - Xiaomi Mijia Honeywell smoke detector (EndDevice) 2024-10-20 10:38:33.627 - info: zigbee.0 (16360) 0x00158d00054cbc44 (addr 61339): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.627 - info: zigbee.0 (16360) 0x00158d0002ea6c32 (addr 24967): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.628 - info: zigbee.0 (16360) 0x00158d000232c479 (addr 9366): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.628 - info: zigbee.0 (16360) 0x00158d00034cc811 (addr 49714): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.629 - info: zigbee.0 (16360) 0x00158d000232063c (addr 28969): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.629 - info: zigbee.0 (16360) 0x00158d00024e8913 (addr 18390): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.630 - info: zigbee.0 (16360) 0x00158d0001e455ee (addr 61858): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.630 - info: zigbee.0 (16360) 0x00158d000232dae3 (addr 59674): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.631 - info: zigbee.0 (16360) 0x00158d00022da934 (addr 36495): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.631 - info: zigbee.0 (16360) 0x00158d00022f14ed (addr 215): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.631 - info: zigbee.0 (16360) 0x00158d00022d2c0e (addr 13316): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.632 - info: zigbee.0 (16360) 0x00158d0002329643 (addr 1740): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.632 - info: zigbee.0 (16360) 0x00158d000232a905 (addr 19605): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.633 - info: zigbee.0 (16360) 0x00158d00032d59fc (addr 12931): ZNCZ02LM - Xiaomi Mi smart plug (EndDevice) 2024-10-20 10:38:33.633 - info: zigbee.0 (16360) 0x588e81fffe2323bd (addr 39259): ZS110050078 - Linkind Door/window Sensor (EndDevice) 2024-10-20 10:38:33.634 - info: zigbee.0 (16360) 0x04cf8cdf3c7b02d2 (addr 17497): ZNCZ04LM - Xiaomi Mi smart plug EU (Router) 2024-10-20 10:38:33.634 - info: zigbee.0 (16360) 0x00158d00047d2647 (addr 27181): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice) 2024-10-20 10:38:33.634 - info: zigbee.0 (16360) 0x00158d000208ee42 (addr 37596): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.635 - info: zigbee.0 (16360) 0x00158d000255bfa2 (addr 49961): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice) 2024-10-20 10:38:33.635 - info: zigbee.0 (16360) 0x00158d0005d0c418 (addr 33604): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.636 - info: zigbee.0 (16360) 0x00158d0009f480e3 (addr 3320): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.637 - info: zigbee.0 (16360) 0x0015bc003100960d (addr 8528): SMSZB-120 - Develco Smoke detector with siren (EndDevice) 2024-10-20 10:38:33.638 - info: zigbee.0 (16360) 0x00158d0002d7955b (addr 16257): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.638 - info: zigbee.0 (16360) 0x00158d00022efe7d (addr 34496): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.639 - info: zigbee.0 (16360) 0x00158d0001e09ad4 (addr 34166): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.640 - info: zigbee.0 (16360) 0x00158d000897586e (addr 25931): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.640 - info: zigbee.0 (16360) 0x8cf681fffe5a0b56 (addr 9848): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) 2024-10-20 10:38:33.641 - info: zigbee.0 (16360) 0x00158d0004036d72 (addr 27962): JTYJ-GD-01LM/BW - Xiaomi Mijia Honeywell smoke detector (EndDevice) 2024-10-20 10:38:33.641 - info: zigbee.0 (16360) 0x00158d0004036dd5 (addr 38500): JTYJ-GD-01LM/BW - Xiaomi Mijia Honeywell smoke detector (EndDevice) 2024-10-20 10:38:33.642 - info: zigbee.0 (16360) 0x00158d0004036d92 (addr 26458): JTYJ-GD-01LM/BW - Xiaomi Mijia Honeywell smoke detector (EndDevice) 2024-10-20 10:38:33.642 - info: zigbee.0 (16360) 0x00158d00022d2bbe (addr 18004): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.642 - info: zigbee.0 (16360) 0x00158d00036b4cda (addr 44425): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.643 - info: zigbee.0 (16360) 0x00158d000247ec94 (addr 25492): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.644 - info: zigbee.0 (16360) 0x00158d0002325798 (addr 2351): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.644 - info: zigbee.0 (16360) 0x00158d00042ad980 (addr 20878): SJCGQ11LM - Aqara Water leak sensor (EndDevice) 2024-10-20 10:38:33.645 - info: zigbee.0 (16360) 0x00158d00053ec985 (addr 63537): MCCGQ01LM - Xiaomi Mi door and window sensor (EndDevice) 2024-10-20 10:38:33.645 - info: zigbee.0 (16360) 0x00158d0004910948 (addr 47132): MCCGQ01LM - Xiaomi Mi door and window sensor (EndDevice) 2024-10-20 10:38:33.645 - info: zigbee.0 (16360) 0x00158d00032bd9a5 (addr 8662): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.646 - info: zigbee.0 (16360) 0x00158d00044fec5e (addr 18503): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.647 - info: zigbee.0 (16360) 0x04cf8cdf3c7b0fdc (addr 18943): ZNCZ04LM - Xiaomi Mi smart plug EU (Router) 2024-10-20 10:38:33.647 - info: zigbee.0 (16360) 0x0015bc0031009604 (addr 42613): SMSZB-120 - Develco Smoke detector with siren (EndDevice) 2024-10-20 10:38:33.648 - info: zigbee.0 (16360) 0x2c1165fffec7fa43 (addr 37980): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) 2024-10-20 10:38:33.648 - info: zigbee.0 (16360) 0x00158d0002c39587 (addr 6275): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.649 - info: zigbee.0 (16360) 0x00158d0002e230ba (addr 12534): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.649 - info: zigbee.0 (16360) 0x00124b002a524a99 (addr 56949): SNZB-03 - SONOFF Motion sensor (EndDevice) 2024-10-20 10:38:33.650 - info: zigbee.0 (16360) 0x00158d0002a4ea25 (addr 45985): DJT11LM - Aqara Vibration sensor (EndDevice) 2024-10-20 10:38:33.650 - info: zigbee.0 (16360) 0x00158d00053ec625 (addr 32664): MCCGQ01LM - Xiaomi Mi door and window sensor (EndDevice) 2024-10-20 10:38:33.651 - info: zigbee.0 (16360) 0x00158d000387ef1d (addr 56573): 404001 - Müller Licht LED bulb E27 806 lumen, dimmable (Router) 2024-10-20 10:38:33.651 - info: zigbee.0 (16360) 0x00158d00029c04f1 (addr 29160): MCCGQ01LM - Xiaomi Mi door and window sensor (EndDevice) 2024-10-20 10:38:33.654 - info: zigbee.0 (16360) 0x00158d00030212a8 (addr 25106): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.655 - info: zigbee.0 (16360) 0x00158d0005229809 (addr 10473): JTYJ-GD-01LM/BW - Xiaomi Mijia Honeywell smoke detector (EndDevice) 2024-10-20 10:38:33.655 - info: zigbee.0 (16360) 0x00158d00053ec684 (addr 36999): MCCGQ01LM - Xiaomi Mi door and window sensor (EndDevice) 2024-10-20 10:38:33.656 - info: zigbee.0 (16360) 0x00158d0002a4e97a (addr 26754): DJT11LM - Aqara Vibration sensor (EndDevice) 2024-10-20 10:38:33.657 - info: zigbee.0 (16360) 0x00158d0002c3957a (addr 56544): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.657 - info: zigbee.0 (16360) 0x00158d0002c98638 (addr 27881): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.657 - info: zigbee.0 (16360) 0x00158d000319c202 (addr 27138): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.658 - info: zigbee.0 (16360) 0x00158d0002018f16 (addr 28477): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.659 - info: zigbee.0 (16360) 0x00158d0002c986f2 (addr 2332): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.659 - info: zigbee.0 (16360) 0x00158d0004857dbe (addr 31513): JTYJ-GD-01LM/BW - Xiaomi Mijia Honeywell smoke detector (EndDevice) 2024-10-20 10:38:33.660 - info: zigbee.0 (16360) 0x00158d000232cb6c (addr 97): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.660 - info: zigbee.0 (16360) 0x00158d00023e9030 (addr 52182): SJCGQ11LM - Aqara Water leak sensor (EndDevice) 2024-10-20 10:38:33.661 - info: zigbee.0 (16360) 0x00158d000237e696 (addr 38312): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.661 - info: zigbee.0 (16360) 0x54ef441000302725 (addr 19428): GZCGQ01LM - Xiaomi Mi light sensor (EndDevice) 2024-10-20 10:38:33.662 - info: zigbee.0 (16360) 0x00158d000286d63f (addr 35930): SJCGQ11LM - Aqara Water leak sensor (EndDevice) 2024-10-20 10:38:33.663 - info: zigbee.0 (16360) 0x04cf8cdf3c7db61c (addr 48769): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice) 2024-10-20 10:38:33.663 - info: zigbee.0 (16360) 0x04cf8cdf3c7c4a7c (addr 35669): WXCJKG12LM - Aqara Opple wireless switch (double band) (EndDevice) 2024-10-20 10:38:33.664 - info: zigbee.0 (16360) 0x00158d0008059cfb (addr 48558): SJCGQ11LM - Aqara Water leak sensor (EndDevice) 2024-10-20 10:38:33.664 - info: zigbee.0 (16360) 0x00158d00038bb932 (addr 63584): 404002 - Müller Licht Tint dim remote control (EndDevice) 2024-10-20 10:38:33.665 - info: zigbee.0 (16360) 0x00158d0005402670 (addr 61035): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.665 - info: zigbee.0 (16360) 0x00158d00044fd6f8 (addr 12359): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.666 - info: zigbee.0 (16360) 0x00158d00045fb6dc (addr 30895): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.666 - info: zigbee.0 (16360) 0x60a423fffe39de4e (addr 25007): TT001ZAV20 - Tuya Temperature & humidity sensor (EndDevice) 2024-10-20 10:38:33.667 - info: zigbee.0 (16360) 0x60a423fffe39d80d (addr 62437): TT001ZAV20 - Tuya Temperature & humidity sensor (EndDevice) 2024-10-20 10:38:33.667 - info: zigbee.0 (16360) 0x60a423fffe2dafe2 (addr 45046): TT001ZAV20 - Tuya Temperature & humidity sensor (EndDevice) 2024-10-20 10:38:33.668 - info: zigbee.0 (16360) 0x60a423fffe39ec56 (addr 34675): TT001ZAV20 - Tuya Temperature & humidity sensor (EndDevice) 2024-10-20 10:38:33.668 - info: zigbee.0 (16360) 0x00158d0008064403 (addr 49599): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.669 - info: zigbee.0 (16360) 0x00158d0001dffea5 (addr 20408): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.670 - info: zigbee.0 (16360) 0x00158d0001dfd06e (addr 34708): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.670 - info: zigbee.0 (16360) 0x00158d0001dfeed0 (addr 30647): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.671 - info: zigbee.0 (16360) 0x00158d0005052924 (addr 8505): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.672 - info: zigbee.0 (16360) 0x60a423fffe651f06 (addr 27808): TS0121_plug - Tuya 10A UK or 16A EU smart plug (Router) 2024-10-20 10:38:33.673 - info: zigbee.0 (16360) 0x60a423fffe61d14f (addr 32136): TS0121_plug - Tuya 10A UK or 16A EU smart plug (Router) 2024-10-20 10:38:33.674 - info: zigbee.0 (16360) 0x60a423fffe6214a4 (addr 15357): TS0121_plug - Tuya 10A UK or 16A EU smart plug (Router) 2024-10-20 10:38:33.674 - info: zigbee.0 (16360) 0x847127fffed314af (addr 18791): TS0044 - Tuya Wireless switch with 4 buttons (EndDevice) 2024-10-20 10:38:33.675 - info: zigbee.0 (16360) 0x847127fffedaa98c (addr 21309): TS0044 - Tuya Wireless switch with 4 buttons (EndDevice) 2024-10-20 10:38:33.675 - info: zigbee.0 (16360) 0x847127fffecfc43c (addr 3437): TS0044 - Tuya Wireless switch with 4 buttons (EndDevice) 2024-10-20 10:38:33.676 - info: zigbee.0 (16360) 0x00158d0001e4a41c (addr 63779): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.676 - info: zigbee.0 (16360) 0x54ef4410003012cd (addr 25400): GZCGQ01LM - Xiaomi Mi light sensor (EndDevice) 2024-10-20 10:38:33.677 - info: zigbee.0 (16360) 0x00158d0005052fc5 (addr 39590): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.677 - info: zigbee.0 (16360) 0x00158d000238c86f (addr 57843): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.678 - info: zigbee.0 (16360) 0x847127fffe27e9d0 (addr 1330): TS0044 - Tuya Wireless switch with 4 buttons (EndDevice) 2024-10-20 10:38:33.678 - info: zigbee.0 (16360) 0x00158d00038b894e (addr 38108): 404002 - Müller Licht Tint dim remote control (EndDevice) 2024-10-20 10:38:33.679 - info: zigbee.0 (16360) 0x84b4dbfffef358d7 (addr 22826): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router) 2024-10-20 10:38:33.679 - info: zigbee.0 (16360) -> Configuring 0xa4c138907173660d SNZB-04 2024-10-20 10:38:33.682 - info: zigbee.0 (16360) 0x04cf8cdf3c7d3803 (addr 25683): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice) 2024-10-20 10:38:33.682 - info: zigbee.0 (16360) 0x00158d0005c135bf (addr 33786): JTYJ-GD-01LM/BW - Xiaomi Mijia Honeywell smoke detector (EndDevice) 2024-10-20 10:38:33.683 - info: zigbee.0 (16360) 0x00158d0002437883 (addr 64834): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.683 - info: zigbee.0 (16360) 0x00158d0005c1376a (addr 9604): JTYJ-GD-01LM/BW - Xiaomi Mijia Honeywell smoke detector (EndDevice) 2024-10-20 10:38:33.683 - info: zigbee.0 (16360) 0x00124b00226080a8 (addr 18183): DIYRuZ_Flower - DIYRuZ Flower sensor (EndDevice) 2024-10-20 10:38:33.684 - info: zigbee.0 (16360) 0xa4c138f6e24e9518 (addr 10237): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice) 2024-10-20 10:38:33.684 - info: zigbee.0 (16360) 0xa4c13850d89c91d4 (addr 31791): TS0011_switch_module - Tuya 1 gang switch module - (without neutral) (EndDevice) 2024-10-20 10:38:33.684 - info: zigbee.0 (16360) 0xbc33acfffe058459 (addr 51483): HS1EB/HS1EB-E - HEIMAN Smart emergency button (EndDevice) 2024-10-20 10:38:33.685 - info: zigbee.0 (16360) 0x00158d0002b5309f (addr 53282): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.685 - info: zigbee.0 (16360) 0x84fd27fffebaba79 (addr 35919): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice) 2024-10-20 10:38:33.685 - info: zigbee.0 (16360) 0x00124b0022ff4bf2 (addr 33692): DIYRuZ_Flower - DIYRuZ Flower sensor (EndDevice) 2024-10-20 10:38:33.686 - info: zigbee.0 (16360) 0x00124b0022607ff4 (addr 46156): DIYRuZ_Flower - DIYRuZ Flower sensor (EndDevice) 2024-10-20 10:38:33.686 - info: zigbee.0 (16360) 0x00124b002257644d (addr 34417): DIYRuZ_Flower - DIYRuZ Flower sensor (EndDevice) 2024-10-20 10:38:33.687 - info: zigbee.0 (16360) 0x04cd15fffe7ff62f (addr 21404): E1812 - IKEA TRADFRI shortcut button (EndDevice) 2024-10-20 10:38:33.687 - info: zigbee.0 (16360) 0x00124b0022ff500c (addr 47760): DIYRuZ_Flower - DIYRuZ Flower sensor (EndDevice) 2024-10-20 10:38:33.687 - info: zigbee.0 (16360) 0x00124b0022ff5019 (addr 99): DIYRuZ_Flower - DIYRuZ Flower sensor (EndDevice) 2024-10-20 10:38:33.688 - info: zigbee.0 (16360) 0x0015bc00310096b8 (addr 54496): SMSZB-120 - Develco Smoke detector with siren (EndDevice) 2024-10-20 10:38:33.688 - info: zigbee.0 (16360) 0x0015bc0031009956 (addr 35937): SMSZB-120 - Develco Smoke detector with siren (EndDevice) 2024-10-20 10:38:33.689 - info: zigbee.0 (16360) 0x60a423fffe7085e5 (addr 49707): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice) 2024-10-20 10:38:33.689 - info: zigbee.0 (16360) 0x0015bc0031009708 (addr 8811): SMSZB-120 - Develco Smoke detector with siren (EndDevice) 2024-10-20 10:38:33.690 - info: zigbee.0 (16360) 0x0015bc00310097b8 (addr 18040): SMSZB-120 - Develco Smoke detector with siren (EndDevice) 2024-10-20 10:38:33.690 - info: zigbee.0 (16360) 0x0015bc003100965a (addr 42015): SMSZB-120 - Develco Smoke detector with siren (EndDevice) 2024-10-20 10:38:33.691 - info: zigbee.0 (16360) 0x00158d0005827d47 (addr 52072): 371232040 - Paulmann LED panels (Router) 2024-10-20 10:38:33.691 - info: zigbee.0 (16360) 0xa4c13894439e1934 (addr 54463): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice) 2024-10-20 10:38:33.692 - info: zigbee.0 (16360) 0xa4c1381bba0f4a1c (addr 36972): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router) 2024-10-20 10:38:33.693 - info: zigbee.0 (16360) 0x0015bc003100961f (addr 13371): SMSZB-120 - Develco Smoke detector with siren (EndDevice) 2024-10-20 10:38:33.693 - info: zigbee.0 (16360) 0x00158d00075f4e3d (addr 17853): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.694 - info: zigbee.0 (16360) 0x00158d00077533df (addr 12705): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.694 - info: zigbee.0 (16360) 0x00158d00042ad981 (addr 35923): SJCGQ11LM - Aqara Water leak sensor (EndDevice) 2024-10-20 10:38:33.695 - info: zigbee.0 (16360) 0xa4c1387e983fbbe5 (addr 41835): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router) 2024-10-20 10:38:33.695 - info: zigbee.0 (16360) 0x00158d00047d278e (addr 18698): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice) 2024-10-20 10:38:33.696 - info: zigbee.0 (16360) 0xb4e3f9fffed1a86c (addr 21272): E2001/E2002 - IKEA STYRBAR remote control (EndDevice) 2024-10-20 10:38:33.696 - info: zigbee.0 (16360) 0x04cd15fffe268b9b (addr 12743): E1812 - IKEA TRADFRI shortcut button (EndDevice) 2024-10-20 10:38:33.697 - info: zigbee.0 (16360) 0x847127fffe11062a (addr 7421): TS0215A_sos - Tuya SOS button (EndDevice) 2024-10-20 10:38:33.697 - info: zigbee.0 (16360) 0xa4c138de33384682 (addr 51670): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice) 2024-10-20 10:38:33.697 - info: zigbee.0 (16360) 0xa4c138a6c7567ee7 (addr 23739): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice) 2024-10-20 10:38:33.698 - info: zigbee.0 (16360) 0x680ae2fffee56802 (addr 7832): ZS1100400-IN-V1A02 - Linkind PIR motion sensor, wireless motion detector (EndDevice) 2024-10-20 10:38:33.699 - info: zigbee.0 (16360) 0xa4c138426b2558f7 (addr 46648): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router) 2024-10-20 10:38:33.699 - info: zigbee.0 (16360) 0x00158d0004036de7 (addr 56350): JTYJ-GD-01LM/BW - Xiaomi Mijia Honeywell smoke detector (EndDevice) 2024-10-20 10:38:33.700 - info: zigbee.0 (16360) 0xa4c138f6c5036b4b (addr 10061): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router) 2024-10-20 10:38:33.701 - info: zigbee.0 (16360) 0xa4c1385eec9c1b64 (addr 27424): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router) 2024-10-20 10:38:33.701 - info: zigbee.0 (16360) 0xa4c1388d6d1ced01 (addr 48092): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice) 2024-10-20 10:38:33.701 - info: zigbee.0 (16360) 0xa4c1382376f04085 (addr 2119): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice) 2024-10-20 10:38:33.701 - info: zigbee.0 (16360) 0xa4c138b3542a8f53 (addr 4148): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice) 2024-10-20 10:38:33.702 - info: zigbee.0 (16360) 0xa4c138e49b987eae (addr 63206): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice) 2024-10-20 10:38:33.702 - info: zigbee.0 (16360) 0xa4c1384c039fd50e (addr 45282): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice) 2024-10-20 10:38:33.702 - info: zigbee.0 (16360) 0xa4c13883d7b2a308 (addr 2304): TS0042 - Tuya Wireless switch with 2 buttons (EndDevice) 2024-10-20 10:38:33.703 - info: zigbee.0 (16360) 0x00158d000234b762 (addr 8037): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice) 2024-10-20 10:38:33.703 - info: zigbee.0 (16360) 0x00158d000233e9b8 (addr 13464): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice) 2024-10-20 10:38:33.703 - info: zigbee.0 (16360) 0x00158d00023d7ff0 (addr 54780): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice) 2024-10-20 10:38:33.704 - info: zigbee.0 (16360) 0x00158d00023cf008 (addr 44987): RTCGQ01LM - Xiaomi Mi motion sensor (EndDevice) 2024-10-20 10:38:33.704 - info: zigbee.0 (16360) 0xbc33acfffe08ff77 (addr 61290): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice) 2024-10-20 10:38:33.704 - info: zigbee.0 (16360) 0xbc33acfffe5d3a48 (addr 47051): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice) 2024-10-20 10:38:33.705 - info: zigbee.0 (16360) 0x04cf8cdf3c802917 (addr 64498): ZNCZ04LM - Xiaomi Mi smart plug EU (Router) 2024-10-20 10:38:33.705 - info: zigbee.0 (16360) 0x04cf8cdf3c803870 (addr 51062): ZNCZ04LM - Xiaomi Mi smart plug EU (Router) 2024-10-20 10:38:33.706 - info: zigbee.0 (16360) 0x04cf8cdf3c77dc49 (addr 32178): ZNCZ04LM - Xiaomi Mi smart plug EU (Router) 2024-10-20 10:38:33.706 - info: zigbee.0 (16360) 0x04cf8cdf3c8038bb (addr 28632): ZNCZ04LM - Xiaomi Mi smart plug EU (Router) 2024-10-20 10:38:33.706 - info: zigbee.0 (16360) 0x00158d000237c88f (addr 25455): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-10-20 10:38:33.707 - info: zigbee.0 (16360) 0x84fd27fffebabacd (addr 28744): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice) 2024-10-20 10:38:33.707 - info: zigbee.0 (16360) 0x00124b002a524ccb (addr 14812): SNZB-03 - SONOFF Motion sensor (EndDevice) 2024-10-20 10:38:33.707 - info: zigbee.0 (16360) 0x540f57fffe0f49de (addr 11785): HG06620 - Lidl Silvercrest garden spike with 2 sockets (Router) 2024-10-20 10:38:33.708 - info: zigbee.0 (16360) 0x540f57fffe0f341c (addr 60838): HG06620 - Lidl Silvercrest garden spike with 2 sockets (Router) 2024-10-20 10:38:33.708 - info: zigbee.0 (16360) 0x00158d000a823b63 (addr 26166): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.708 - info: zigbee.0 (16360) 0x540f57fffe2b26bf (addr 36694): HG06620 - Lidl Silvercrest garden spike with 2 sockets (Router) 2024-10-20 10:38:33.709 - info: zigbee.0 (16360) 0x00158d0009765328 (addr 12543): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice) 2024-10-20 10:38:33.709 - info: zigbee.0 (16360) 0x2c1165fffec8080d (addr 56620): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) 2024-10-20 10:38:33.709 - info: zigbee.0 (16360) 0x00124b002a654531 (addr 28102): SNZB-03 - SONOFF Motion sensor (EndDevice) 2024-10-20 10:38:33.710 - info: zigbee.0 (16360) 0x84b4dbfffeec9ace (addr 24796): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router) 2024-10-20 10:38:33.710 - info: zigbee.0 (16360) 0x2c1165fffec800f4 (addr 29834): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) 2024-10-20 10:38:33.711 - info: zigbee.0 (16360) 0x00158d000abda409 (addr 38181): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.711 - info: zigbee.0 (16360) 0x00158d000a8242d2 (addr 22546): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.711 - info: zigbee.0 (16360) 0x00158d000a824194 (addr 12036): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.712 - info: zigbee.0 (16360) 0x00158d000a822f77 (addr 11674): RTCGQ11LM - Aqara Motion sensor (EndDevice) 2024-10-20 10:38:33.712 - info: zigbee.0 (16360) 0x84b4dbfffef35708 (addr 29246): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router) 2024-10-20 10:38:33.713 - info: zigbee.0 (16360) 0x84b4dbfffecf289d (addr 50337): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router) 2024-10-20 10:38:33.713 - info: zigbee.0 (16360) 0x8cf681fffe5a0dba (addr 26521): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) 2024-10-20 10:38:33.714 - info: zigbee.0 (16360) 0x2c1165fffe5b4ff4 (addr 22916): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) 2024-10-20 10:38:33.714 - info: zigbee.0 (16360) 0xa4c138907173660d (addr 16286): SNZB-04 - SONOFF Contact sensor (EndDevice) 2024-10-20 10:38:33.715 - info: zigbee.0 (16360) 0xe0798dfffea87db0 (addr 12178): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router) 2024-10-20 10:38:33.715 - info: zigbee.0 (16360) 0x84ba20fffe77b161 (addr 54713): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router) 2024-10-20 10:38:33.716 - info: zigbee.0 (16360) 0xb4e3f9fffe05fa4c (addr 35948): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) 2024-10-20 10:38:33.716 - info: zigbee.0 (16360) 0x2c1165fffed743db (addr 17097): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) 2024-10-20 10:38:33.716 - info: zigbee.0 (16360) 0x2c1165fffec801c0 (addr 6186): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) 2024-10-20 10:38:33.717 - info: zigbee.0 (16360) 0x8cf681fffe4b74bb (addr 41987): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) 2024-10-20 10:38:33.717 - info: zigbee.0 (16360) 0x84b4dbfffef35752 (addr 62408): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router) 2024-10-20 10:38:33.718 - info: zigbee.0 (16360) 0x8cf681fffe5a09c2 (addr 6446): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) 2024-10-20 10:38:33.718 - info: zigbee.0 (16360) 0x847127fffe9b54dc (addr 36266): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router) 2024-10-20 10:38:33.719 - info: zigbee.0 (16360) 0x2c1165fffec80908 (addr 50356): FB21-001 - Lidl Livarno Lux switch and dimming light remote control (EndDevice) 2024-10-20 10:38:33.719 - info: zigbee.0 (16360) 0x84b4dbfffeec9b65 (addr 36348): 399629_2110 - Lidl Livarno Lux Ceiling Panel RGB+CCT (Router) 2024-10-20 10:38:33.720 - info: zigbee.0 (16360) 0x000d6f00162b1ba1 (addr 28536): HS2WD-E - HEIMAN Smart siren (Router) 2024-10-20 10:38:33.720 - info: zigbee.0 (16360) Zigbee started 2024-10-20 10:38:34.060 - info: zigbee.0 (16360) debug devices set to ["00158d000200cfd1"] 2024-10-20 10:38:34.716 - warn: zigbee.0 (16360) ELEVATED publishToState: message received '{"available":true}' from device 00158d000200cfd1 type 'RTCGQ11LM' 2024-10-20 10:38:34.716 - warn: zigbee.0 (16360) ELEVATED publishToState: value generated 'true' from device 00158d000200cfd1 for 'Available' 2024-10-20 10:38:34.716 - warn: zigbee.0 (16360) ELEVATED publishToState: message received '{"linkquality":10}' from device 00158d000200cfd1 type 'RTCGQ11LM' 2024-10-20 10:38:34.717 - warn: zigbee.0 (16360) ELEVATED publishToState: value generated '10' from device 00158d000200cfd1 for 'Link quality' 2024-10-20 10:38:36.020 - info: host.iobroker instance system.adapter.uv-protect.0 in version "0.6.3" started with pid 16384 2024-10-20 10:38:36.350 - info: sonoff.0 (1174) Client [USBSwitch11] connected with secret 1729413516331_2057 2024-10-20 10:38:36.478 - info: sonoff.0 (1174) Client [USBSwitch10] reconnected. Old secret 1729413455625_6393 ==> New secret 1729413516478_9810 2024-10-20 10:38:42.336 - info: tuya.0 (1396) 485606842cf43272918b: Connect locally to device 2024-10-20 10:38:42.336 - info: tuya.0 (1396) 485606842cf43272918b Init with IP=10.1.12.100, Key=3d7bdc1f319219bb, Version=3.3 2024-10-20 10:38:43.996 - info: admin.0 (3391) <== Disconnect system.user.admin from 192.168.0.21 2024-10-20 10:38:44.087 - warn: zigbee.0 (16360) DeviceConfigure: 0xa4c138907173660d SNZB-04 Failed to configure. When device works is all fine when not wake up the device and check again
In den Objekten kommt nix, die sind leer, das meine ich:
gerade mal das Pairing gestartet, das macht er, allerdings zaehlt er keinen Countdown, einfach im Fenster nur Paring startet
Im log, das Interessante, mein TI ist per Ethernet angebunden, und in der Config steht tcp://10.1.1.98:20108 :
zigbee.0 2024-10-20 10:47:47.976 info Zigbee: allowing new devices to join. zigbee.0 2024-10-20 10:47:44.748 info List of port: [{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
@ritter sagte in Test Adapter iobroker.Zigbee 1.10.10:
@asgothian Reicht info aus?
Ich werde aus der Info immer noch nicht schlau. Lt. dem was du gepostet hast gibt es keine Fehlermeldungen beim Versuch geräte zu schalten, auch wenn diese nicht reagieren. Allerdings habe ich die elevated nachrichten erweitert, und würde Dich bitten meinen Fork von
https://github.com/asgothian/ioBroker.zigbee
zu installieren und dann zu posten was an nachrichten auftaucht. Auch weiterhin wichtig: Gibt es innerhalb von 60 Sekunden von einer Anpassung die nicht bis zum Gerät kommt eine Fehlermeldung ?
@ilovegym Auch dich würde ich bitten den Test-Branch zu installieren, da bei Dir die Geräte auch nicht reagieren.
A.
Das er die Port-Liste liefert ist standard - der Adapter enumeriert alle seriellen Schnittstellen um dem Benutzer diese zur Auswahl anzubieten. Es werden alle gefundenen Ports auch im Log hinterlegt, da es oft mit der seriellen Anbindung Probleme gibt.
A.
es erfolgt einfach keine Communication mit dem Stick mehr - hab schon den baugleichen Ersatz mal dran gesteckt, das gleiche.
Weder wird der Countdown gestartet, noch wird irgendein Device ausgelesen.
Auch kommt beim Stick gar nicht viel an, bzw sind das meist innerhalb von Minuten einige MB:
Wichtig ist was der Adapter dazu sagt wenn du versuchst etwas an den Stick zu senden. Die Datenmengen sind immer gering.
Die Fehlermeldungen die der Adapter bringt bringen mir hoffentlich Informationen dazu was da schief geht.
Die Kommunikation ist aber nicht ganz unterbrochen, denn wenn man den Knopf an einer Funksteckdose drückt geht der Ein-Aus Schieber an der Zigbee Kachel mit nur nicht umgekehrt.
Dein Fehler und der von @ilovegym sind nicht gleich. Ich habe insbesondere die Log-Meldungen beim Senden erweitert und will sehen an welcher Stelle das schief geht.
A.
mal eine Steckdose eingeschaltet:
zigbee.0 2024-10-20 11:28:58.451 debug target: {"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":81,"inputClusters":[0,4,5,6,1794,2820],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genOnOff":{"attributes":{"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":1}},"genBasic":{"attributes":{"modelId":"TS0121","manufacturerName":"_TZ3000_g5xawfcq","stackVersion":0,"dateCode":""}},"seMetering":{"attributes":{"currentSummDelivered":[0,11339],"divisor":100,"multiplier":1}},"haElectricalMeasurement":{"attributes":{"acVoltageMultiplier":1,"acVoltageDivisor":1,"acCurrentMultiplier":1,"acCurrentDivisor":1000,"acPowerMultiplier":1,"acPowerDivisor":1,"rmsVoltage":225,"rmsCurrent":0,"activePower":0}}},"deviceIeeeAddress":"0x60a423fffe651f06","deviceNetworkAddress":27808,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b00219fc127","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00124b00219fc127","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00124b00219fc127","endpointID":1}],"_configuredReportings":[{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1],"manufacturerCode":null},{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5,"manufacturerCode":null},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50,"manufacturerCode":null},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10,"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x60a423fffe651f06"}} zigbee.0 2024-10-20 11:28:58.451 debug convert state, "ON", {} zigbee.0 2024-10-20 11:28:58.451 debug Type of toZigbee is 'object', Contains key ["zclcommand"] zigbee.0 2024-10-20 11:28:58.451 debug Type of toZigbee is 'object', Contains key ["reset"] zigbee.0 2024-10-20 11:28:58.451 debug Type of toZigbee is 'object', Contains key ["command"] zigbee.0 2024-10-20 11:28:58.451 debug Type of toZigbee is 'object', Contains key ["write"] zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["read"] zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["scene_rename"] zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["scene_remove_all"] zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["scene_remove"] zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["scene_add"] zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["scene_recall"] zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["scene_store"] zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["backlight_mode","indicator_mode"] zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["power_on_behavior","power_outage_memory"] zigbee.0 2024-10-20 11:28:58.450 debug Setting' converter to converter with key(s)'["state","on_time","off_wait_time"]} zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["state","on_time","off_wait_time"] zigbee.0 2024-10-20 11:28:58.449 debug entity: 0x60a423fffe651f06 TS0121_plug {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":147,"_applicationVersion":65,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":81,"inputClusters":[0,4,5,6,1794,2820],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genOnOff":{"attributes":{"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":1}},"genBasic":{"attributes":{"modelId":"TS0121","manufacturerName":"_TZ3000_g5xawfcq","stackVersion":0,"dateCode":""}},"seMetering":{"attributes":{"currentSummDelivered":[0,11339],"divisor":100,"multiplier":1}},"haElectricalMeasurement":{"attributes":{"acVoltageMultiplier":1,"acVoltageDivisor":1,"acCurrentMultiplier":1,"acCurrentDivisor":1000,"acPowerMultiplier":1,"acPowerDivisor":1,"rmsVoltage":225,"rmsCurrent":0,"activePower":0}}},"deviceIeeeAddress":"0x60a423fffe651f06","deviceNetworkAddress":27808,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b00219fc127","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00124b00219fc127","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00124b00219fc127","endpointID":1}],"_configuredReportings":[{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1],"manufacturerCode":null},{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5,"manufacturerCode":null},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50,"manufacturerCode":null},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10,"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x60a423fffe651f06"}}],"_hardwareVersion":1,"_ieeeAddr":"0x60a423fffe651f06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1728793934222,"_manufacturerID":4098,"_manufacturerName":"_TZ3000_g5xawfcq","_modelID":"TS0121","_networkAddress":27808,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":356340264}},"mapped":{"zigbeeModel":["TS0121"],"model":"TS0121_plug","description":"10A UK or 16A EU smart plug","whiteLabel":[{"vendor":"BlitzWolf","model":"BW-SHP13"},{"vendor":"Connecte","model":"4500990"},{"vendor":"Connecte","model":"4500991"},{"vendor":"Connecte","model":"4500992"},{"vendor":"Connecte","model":"4500993"}],"vendor":"Tuya","fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"],"options":[{"name":"state_action","label":"State action","access":2,"type":"binary","property":"state_action","description":"State actions will also be published as 'action' when true (default false).","value_on":true,"value_off":false}]},{"cluster":"haElectricalMeasurement","type":["attributeReport","readResponse"]},{"cluster":"seMetering","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior","power_outage_memory"]},{"key":["backlight_mode","indicator_mode"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"options":[{"name":"measurement_poll_interval","label":"Measurement poll interval","access":2,"type":"numeric","property":"measurement_poll_interval","description":"This device does not support reporting electric measurements so it is polled instead. The default poll interval is 60 seconds, set to -1 to disable.","value_min":-1},{"name":"power_calibration","label":"Power calibration","access":2,"type":"numeric","property":"power_calibration","description":"Calibrates the power value (percentual offset), takes into effect on next report of device."},{"name":"power_precision","label":"Power precision","access":2,"type":"numeric","property":"power_precision","description":"Number of digits after decimal point for power, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},{"name":"current_calibration","label":"Current calibration","access":2,"type":"numeric","property":"current_calibration","description":"Calibrates the current value (percentual offset), takes into effect on next report of device."},{"name":"current_precision","label":"Current precision","access":2,"type":"numeric","property":"current_precision","description":"Number of digits after decimal point for current, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},{"name":"voltage_calibration","label":"Voltage calibration","access":2,"type":"numeric","property":"voltage_calibration","description":"Calibrates the voltage value (percentual offset), takes into effect on next report of device."},{"name":"voltage_precision","label":"Voltage precision","access":2,"type":"numeric","property":"voltage_precision","description":"Number of digits after decimal point for voltage, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},{"name":"energy_calibration","label":"Energy calibration","access":2,"type":"numeric","property":"energy_calibration","description":"Calibrates the energy value (percentual offset), takes into effect on next report of device."},{"name":"energy_precision","label":"Energy precision","access":2,"type":"numeric","property":"energy_precision","description":"Number of digits after decimal point for energy, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},"[Circular]"],"exposes":[{"type":"switch","features":[{"name":"state","label":"State","access":7,"type":"binary","property":"state","description":"On/off state of the switch","value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"}]},{"name":"power","label":"Power","access":1,"type":"numeric","property":"power","description":"Instantaneous measured power","category":"diagnostic","unit":"W"},{"name":"current","label":"Current","access":1,"type":"numeric","property":"current","description":"Instantaneous measured electrical current","category":"diagnostic","unit":"A"},{"name":"voltage","label":"Voltage","access":1,"type":"numeric","property":"voltage","description":"Measured electrical potential value","category":"diagnostic","unit":"V"},{"name":"energy","label":"Energy","access":1,"type":"numeric","property":"energy","description":"Sum of consumed energy","unit":"kWh"},{"name":"power_outage_memory","label":"Power outage memory","access":7,"type":"enum","property":"power_outage_memory","description":"Recover state after power outage","values":["on","off","restore"]},{"name":"indicator_mode","label":"Indicator mode","access":7,"type":"enum","property":"indicator_mode","description":"LED indicator mode","values":["off","off/on","on/off"]},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x60a423fffe651f06"} zigbee.0 2024-10-20 11:28:58.448 debug publishFromState : 0x60a423fffe651f06 TS0121_plug [{"stateDesc":{"id":"state","prop":"state","name":"On/off state of the switch","role":"switch","write":true,"read":true,"type":"boolean","setattr":"state","readable":true,"writable":true},"value":true,"index":0,"timeout":0}] zigbee.0 2024-10-20 11:28:58.445 debug Change state 'state' at device 0x60a423fffe651f06 type 'TS0121_plug' zigbee.0 2024-10-20 11:28:58.440 debug User stateChange zigbee.0.60a423fffe651f06.state {"val":true,"ack":false,"ts":1729416538438,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1729416538438}
Edit:
dann kam das:zigbee.0 2024-10-20 11:29:25.384 debug DeviceAvailability:Non-pingable device 0x00158d00011083e8 lumi.sensor_cube was last seen '624802.431' seconds ago. zigbee.0 2024-10-20 11:28:58.451 debug target: {"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":81,"inputClusters":[0,4,5,6,1794,2820],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genOnOff":{"attributes":{"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":1}},"genBasic":{"attributes":{"modelId":"TS0121","manufacturerName":"_TZ3000_g5xawfcq","stackVersion":0,"dateCode":""}},"seMetering":{"attributes":{"currentSummDelivered":[0,11339],"divisor":100,"multiplier":1}},"haElectricalMeasurement":{"attributes":{"acVoltageMultiplier":1,"acVoltageDivisor":1,"acCurrentMultiplier":1,"acCurrentDivisor":1000,"acPowerMultiplier":1,"acPowerDivisor":1,"rmsVoltage":225,"rmsCurrent":0,"activePower":0}}},"deviceIeeeAddress":"0x60a423fffe651f06","deviceNetworkAddress":27808,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b00219fc127","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00124b00219fc127","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00124b00219fc127","endpointID":1}],"_configuredReportings":[{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1],"manufacturerCode":null},{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5,"manufacturerCode":null},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50,"manufacturerCode":null},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10,"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x60a423fffe651f06"}} zigbee.0 2024-10-20 11:28:58.451 debug convert state, "ON", {} zigbee.0 2024-10-20 11:28:58.451 debug Type of toZigbee is 'object', Contains key ["zclcommand"] zigbee.0 2024-10-20 11:28:58.451 debug Type of toZigbee is 'object', Contains key ["reset"] zigbee.0 2024-10-20 11:28:58.451 debug Type of toZigbee is 'object', Contains key ["command"] zigbee.0 2024-10-20 11:28:58.451 debug Type of toZigbee is 'object', Contains key ["write"] zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["read"] zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["scene_rename"] zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["scene_remove_all"] zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["scene_remove"] zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["scene_add"] zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["scene_recall"] zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["scene_store"] zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["backlight_mode","indicator_mode"] zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["power_on_behavior","power_outage_memory"] zigbee.0 2024-10-20 11:28:58.450 debug Setting' converter to converter with key(s)'["state","on_time","off_wait_time"]} zigbee.0 2024-10-20 11:28:58.450 debug Type of toZigbee is 'object', Contains key ["state","on_time","off_wait_time"]
@ilovegym sagte in Test Adapter iobroker.Zigbee 1.10.10:
Das hilft leider so gar nicht.
- Es ist nicht die von mir oben gewünschte Version mit den Zusatzausgaben
- der Adapter läuft im Debug - sprich es werden viel zu viele Meldungen gespeichert.
Bitte mach das was ich hier beschrieben habe.
A.
Bitteschoen:
Edit: nochmal die Version geprueft, habe ich von Github von deinem Repo geladen, wie du geschrieben hast.
Edit2: wie schon geschrieben, der Adapter kommuniziert NICHT mit dem Stick, er meckert jetzt zwar nicht mehr, dass er ihn nicht finden kann, aber es werden keine Daten transportiert.zigbee.0 2024-10-20 14:42:06.875 warn ELEVATED publishToState: value generated '0' from device 00158d000200cfd1 for 'Link quality' zigbee.0 2024-10-20 14:42:06.875 warn ELEVATED publishToState: message received '{"linkquality":0}' from device 00158d000200cfd1 type 'RTCGQ11LM' zigbee.0 2024-10-20 14:42:06.874 warn ELEVATED publishToState: value generated 'false' from device 00158d000200cfd1 for 'Available' zigbee.0 2024-10-20 14:42:06.874 warn ELEVATED publishToState: message received '{"available":false}' from device 00158d000200cfd1 type 'RTCGQ11LM' zigbee.0 2024-10-20 14:41:17.915 warn DeviceConfigure: 0xa4c138907173660d SNZB-04 Failed to configure. When device works is all fine when not wake up the device and check again
