Skript ist verschwunden
@thomas-braun sagte in Skript ist verschwunden:
Irgendwie alles wirr...
Konkrete Meldungen? Keine Nacherzählungen, Ein- wie Ausgaben aus dem Terminal zeigen.
euronicsxxlwunstorf@MacBook-Air ~ % ssh raspberrypi@raspberry1 ssh: Could not resolve hostname raspberry1: nodename nor servname provided, or not known
Und die beiden Versuche mit den IP-Adressen?
euronicsxxlwunstorf@MacBook-Air ~ % ssh raspberry1@192.168.178.92 @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY! Someone could be eavesdropping on you right now (man-in-the-middle attack)! It is also possible that a host key has just been changed. The fingerprint for the ED25519 key sent by the remote host is SHA256:3sTOBNgQAMfY39rJmMyhGFiWj/pbOqie/WjROh8IYFY. Please contact your system administrator. Add correct host key in /Users/euronicsxxlwunstorf/.ssh/known_hosts to get rid of this message. Offending ED25519 key in /Users/euronicsxxlwunstorf/.ssh/known_hosts:5 Host key for 192.168.178.92 has changed and you have requested strict checking. Host key verification failed. euronicsxxlwunstorf@MacBook-Air ~ % ssh raspberry1@192.168.178.100 @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY! Someone could be eavesdropping on you right now (man-in-the-middle attack)! It is also possible that a host key has just been changed. The fingerprint for the ED25519 key sent by the remote host is SHA256:3sTOBNgQAMfY39rJmMyhGFiWj/pbOqie/WjROh8IYFY. Please contact your system administrator. Add correct host key in /Users/euronicsxxlwunstorf/.ssh/known_hosts to get rid of this message. Offending ED25519 key in /Users/euronicsxxlwunstorf/.ssh/known_hosts:7 Host key for 192.168.178.100 has changed and you have requested strict checking. Host key verification failed.
euronicsxxlwunstorf@MacBook-Air ~ % ssh raspberry1@192.168.178.92 @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ WARNUNG: DIE IDENTIFIZIERUNG DES REMOTE-HOSTS HAT SICH GEÄNDERT! @ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ ES IST MÖGLICH, DASS JEMAND ETWAS BÖSES TUT! Jemand könnte Sie gerade belauschen (Man-in-the-Middle-Angriff)! Es ist auch möglich, dass gerade ein Host-Schlüssel geändert wurde. Der Fingerabdruck für den vom Remote-Host gesendeten ED25519-Schlüssel lautet SHA256:3sTOBNgQAMfY39rJmMyhGFiWj/pbOqie/WjROh8IYFY. Bitte wenden Sie sich an Ihren Systemadministrator. Fügen Sie den korrekten Host-Schlüssel in /Users/euronicsxxlwunstorf/.ssh/known_hosts hinzu, um diese Meldung zu entfernen. Anstößiger ED25519-Schlüssel in /Users/euronicsxxlwunstorf/.ssh/known_hosts:5 Der Host-Schlüssel für 192.168.178.92 hat sich geändert und Sie haben eine strenge Überprüfung angefordert. Die Überprüfung des Host-Schlüssels ist fehlgeschlagen. euronicsxxlwunstorf@MacBook-Air ~ % ssh raspberry1@192.168.178.100 @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ WARNUNG: DIE IDENTIFIZIERUNG DES REMOTE-HOSTS HAT SICH GEÄNDERT! @ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ ES IST MÖGLICH, DASS JEMAND ETWAS BÖSES TUT! Jemand könnte Sie gerade belauschen (Man-in-the-Middle-Angriff)! Es ist auch möglich, dass gerade ein Hostschlüssel geändert wurde. Der Fingerabdruck für den vom Remote-Host gesendeten ED25519-Schlüssel lautet SHA256:3sTOBNgQAMfY39rJmMyhGFiWj/pbOqie/WjROh8IYFY. Bitte wenden Sie sich an Ihren Systemadministrator. Fügen Sie den korrekten Hostschlüssel in /Users/euronicsxxlwunstorf/.ssh/known_hosts hinzu, um diese Meldung zu entfernen. Anstößiger ED25519-Schlüssel in /Users/euronicsxxlwunstorf/.ssh/known_hosts:7 Der Hostschlüssel für 192.168.178.100 wurde geändert und Sie haben eine strenge Überprüfung angefordert. Die Überprüfung des Hostschlüssels ist fehlgeschlagen.
Lösch die alten Einträge in der
Ich finde nichts mit diesem Namen
Das Verzeichnis ist 'versteckt'. Sieht man an dem führenden Punkt im Namen.
Ich hatte versteckte vor ein paar <tagen angezeigt, die erscheinen dann hell, dachte das ist noch an, weil ein Paar graue Kästchen drin waren, es war aber aus.
Es gibt ein known_hosts.old das ist leer und in dem known_hosts sind viele Sachen drin.
Kann ich das alles löschen ?
Keine Bildchen von Text...
Lösch die Zeilen mit den IPs des Raspberry raus.
Wer weiß was die andereen für Hosts sind. -
Wer weiß was die andereen für Hosts sind.OK, was man da alles beachten muss.
Jetzt weiter nach Deiner Beschreibung, die ist aber von 2022.
@karl-heinz1 STOPP
hier geht es weiter: https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
Ro75.
An der Technik, wie man eine ssh-Verbindung aufbaut hat sich auch seit Jahren nichts geändert. Das ist so simpel geblieben.
die ganze Zeile so übernehmen oder ohne das Grüne ?
Du hast es mit sinnfreien Bildchens, oder?
Ja bis dahin bin ich jetzt ohne Fehler. Updates sind durchgelaufen.
Ich will nur vermeiden das ich was falsch mache. Ich meine ich hatte früher bei der Zeile ein Problem, weil ich die einfach kopiert habe.
Dann lass den Schritt einfach aus.
OK das hat soweit geklappt, aber ich will ja die Daten vom IOBroker noch sichern und mit Admin komme ich nicht mehr in den IOBroker, weil Passwort oder Benutzername falsch sind, wird gemeldet.
Frage: muss ich da auch in der known_hosts die Sachen mit iobroker löschen, oder woran liegt das ?
@karl-heinz1 sagte in Skript ist verschwunden:
Nein, die known_hosts ist nur für SSH-Verbindungen zuständig. Mit dem ioBroker-Admin hat das nix zu tun
Was kann ich da machen ?
Man kann über die Kommandozeile das Login wieder rausnehmen.
Hab aber den Befehl dazu nicht parat.
