    4. Änderungen iob CLI/Installer/Fixer mit Root Accounts
    • Feuersturm
      Feuersturm last edited by Feuersturm
      @apollon77 @Thomas-Braun
      Hier mein iob fix Auszug
      Bei dieser Abfrage konnte ich nichts eingeben:
      Your system is booting into 'graphical.target', which means that a user interface or desktop is available.
      Usually a server is running without a desktop to have more RAM available. Do you want to switch to 'multi-user.target'? (y/N)
      proxmox@ioB-Prod-Testsystem:~$ iob stop
      proxmox@ioB-Prod-Testsystem:~$ iob fix
      library: loaded
      Library version=2024-10-19
          Welcome to the ioBroker installation fixer!
          Script version: 2024-10-19
          You might need to enter your password a couple of times.
          Installing prerequisites (1/5)
      Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
      Get:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [128 kB]
      Get:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease [129 kB]
      Hit:4 https://apt.grafana.com stable InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Fetched 257 kB in 2s (128 kB/s)
      Reading package lists... Done
          Checking ioBroker user and directory permissions (2/5)
      Created /etc/sudoers.d/iobroker
      Fixing directory permissions...
          Check and cleanup npm temporary directories (3/5)
      Done.
          Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Compressed 2 JSONL files. Done
          Checking autostart (5/5)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
        Thomas Braun Most Active @Feuersturm last edited by
        @feuersturm
        Nochmal den
        iob fix
        laufen lassen. Dann müssste es funktionieren.
        L Feuersturm 2 Replies Last reply Reply Quote 0
          lindi200000 @Thomas Braun last edited by
          Moin, durch was wird die Zeitzone festgesetzt, welche die richtige ist? Oder vergleicht er nur die System Zeitzone mit der, die im iob hinterlegt ist?
            Shadowhunter23 @Thomas Braun last edited by Shadowhunter23
            Script v.2024-10-19
            *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer-container
                     Chassis: container ☐
              Virtualization: lxc
                      Kernel: Linux 6.8.12-2-pve
                Architecture: x86-64
            OS is similar to:
            model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
            Docker          : false
            Virtualization  : lxc
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             19:24:33 up  2:22,  2 users,  load average: 0.62, 0.51, 0.54
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Operating System is the current Debian stable version codenamed 'bookworm'!
            *** TIME AND TIMEZONES ***
                           Local time: Sun 2024-10-20 19:24:33 CEST
                       Universal time: Sun 2024-10-20 17:24:33 UTC
                             RTC time: n/a
                          NTP service: inactive
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            tobias
            HOME=/home/tobias
            GROUPS=tobias adm dialout sudo audio video plugdev users iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev redis
            *** DISPLAY-SERVER SETUP ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:             10G        3.9G        6.2G        491K        660M        6.9G
            Swap:             0B          0B          0B
            Total:           10G        3.9G        6.2G
            Active iob-Instances:   50
                    10240 M total memory
                     3694 M used memory
                     3601 M active memory
                      430 M inactive memory
                     5915 M free memory
                        0 M buffer memory
                      630 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            top - 19:24:34 up  2:22,  2 users,  load average: 0.57, 0.50, 0.54
            Tasks:  82 total,   1 running,  81 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :  10240.0 total,   5914.1 free,   3696.2 used,    630.2 buff/cache
            MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6543.8 avail Mem
            *** FAILED SERVICES ***
              UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
            * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
            LOAD   = Reflects whether the unit definition was properly loaded.
            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
            SUB    = The low-level unit activation state, values depend on unit type.
            1 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            dmesg: read kernel buffer failed: Operation not permitted
            No critical errors detected
            *** FILESYSTEM ***
            Filesystem                       Type      Size  Used Avail Use% Mounted on
            /dev/mapper/pve-vm--400--disk--0 ext4       20G  7.1G   12G  39% /
            none                             tmpfs     492K  4.0K  488K   1% /dev
            udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
            tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
            tmpfs                            tmpfs     3.1G  136K  3.1G   1% /run
            tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
            tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1000
            Show mounted filesystems:
            TARGET SOURCE                           FSTYPE OPTIONS
            /      /dev/mapper/pve-vm--400--disk--0 ext4   rw,relatime,stripe=16
            /var:
            784M    /var/
            525M    /var/lib
            374M    /var/lib/redis
            225M    /var/cache
            222M    /var/cache/apt
            Archived and active journals take up 32.0M in the file system.
            /opt/iobroker/backups:
            1.7G    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            143M    /opt/iobroker/iobroker-data/
            128M    /opt/iobroker/iobroker-data/files
            99M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
            16M     /opt/iobroker/iobroker-data/objects.jsonl
            12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
            7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
            7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
            5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
            USB-Devices by-id:
            No Devices found 'by-id'
            HINT:
            Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
            tcp
            HINT:
            Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
            tcp
            HINT:
            Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
            tcp
            HINT:
            Your zigbee.3 COM-Port is NOT matching 'by-id'. Please check your setting:
            tcp
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.18.0
            /usr/bin/node           v20.18.0
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            /usr/bin/corepack       0.29.3
            nodejs:
              Installed: 20.18.0-1nodesource1
              Candidate: 20.18.0-1nodesource1
              Version table:
             *** 20.18.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                    100 /var/lib/dpkg/status
                 20.17.0-1nodesource1 1001
                 20.16.0-1nodesource1 1001
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
                 18.19.0+dfsg-6~deb12u2 500
                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
                 18.19.0+dfsg-6~deb12u1 500
                    500 http://security.debian.org bookworm-security/main amd64 Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            At least one iobroker host is running.
            Objects type: redis
            States  type: redis
            Hosts:
            iobroker            iobroker (version: 7.0.0, hostname: iobroker      , alive, uptime: 915)
            Core adapters versions
            js-controller:  7.0.0
            admin:          7.2.6
            javascript:     8.8.3
            nodejs modules from github:     0
            Adapter State
            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
            + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
            + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
            + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
            + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
            + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
              system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
            + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
            + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
              system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
              system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
            + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.mytime.0                 : mytime                : iobroker                                 -  enabled
            + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
            + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
            + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
              system.adapter.octoprint.1              : octoprint             : iobroker                                 - disabled
              system.adapter.octoprint.2              : octoprint             : iobroker                                 - disabled
            + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
            + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
            + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
            + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
            + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
            + system.adapter.pushover.2               : pushover              : iobroker                                 -  enabled
            + system.adapter.rest-api.0               : rest-api              : iobroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
            + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
            + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
            + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
            + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
              system.adapter.sayit.4                  : sayit                 : iobroker                                 - disabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
            + system.adapter.text2command.1           : text2command          : iobroker                                 -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
            + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
              system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.wireguard.0              : wireguard             : iobroker                                 -  enabled
            + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.64:20108
            + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.69:20108
            + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.79:20108
            + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.63:20108
            + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.99:20108
            + instance is alive
            ioBroker-Repositories
            Active repo(s): beta
            Upgrade policy: none
            Installed ioBroker-Instances
            Used repository: beta
            Adapter    "admin"        : 7.2.6    , installed 7.2.6
            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
            Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
            Adapter    "backitup"     : 3.0.26   , installed 3.0.26
            Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
            Adapter    "device-watcher": 2.12.1  , installed 2.12.1
            Adapter    "email"        : 1.3.1    , installed 1.3.1
            Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
            Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
            Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
            Adapter    "ical"         : 1.15.0   , installed 1.15.0
            Adapter    "iot"          : 3.4.2    , installed 3.4.2
            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
            Controller "js-controller": 7.0.0    , installed 7.0.0
            Adapter    "lg-thinq"     : 1.0.2    , installed 1.0.2
            Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
            Adapter    "mytime"       : 0.7.12   , installed 0.7.12
            Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
            Adapter    "notification-manager": 1.3.0, installed 1.3.0
            Adapter    "nuki"         : 2.0.0    , installed 2.0.0
            Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
            Adapter    "operating-hours": 1.1.0  , installed 1.1.0
            Adapter    "ping"         : 1.7.9    , installed 1.7.9
            Adapter    "pushover"     : 4.1.0    , installed 4.1.0
            Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
            Adapter    "sayit"        : 5.0.0    , installed 5.0.0
            Adapter    "shelly"       : 8.4.0    , installed 8.4.0
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
            Adapter    "telegram"     : 3.9.0    , installed 3.9.0
            Adapter    "text2command" : 3.0.3    , installed 3.0.3
            Adapter    "trashschedule": 3.3.0    , installed 3.3.0
            Adapter    "tuya"         : 3.16.0   , installed 3.16.0
            Adapter    "vis-icontwo"  : 1.6.3    , installed 1.6.3
            Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
            Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
            Adapter    "web"          : 6.3.1    , installed 6.3.1
            Adapter    "wireguard"    : 1.7.0    , installed 1.7.0
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
            Objects and States
            Objects:        12688
            States:         11451
            Hit:1 http://security.debian.org bookworm-security InRelease
            Hit:2 http://deb.debian.org/debian bookworm InRelease
            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
            Hit:5 https://packages.redis.io/deb bookworm InRelease
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          118804393  1/init
            tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      103        118808671  153/redis-server 12
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       119406220  19507/io.shelly.1
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       119402442  19359/io.mqtt.0
            tcp        0      0 192.168.0.222:9092      0.0.0.0:*               LISTEN      1001       119406113  19404/io.nuki.0
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          118809613  384/master
            tcp6       0      0 :::22                   :::*                    LISTEN      0          118797944  1/init
            tcp6       0      0 :::111                  :::*                    LISTEN      0          118804395  1/init
            tcp6       0      0 :::80                   :::*                    LISTEN      0          118807395  176/apache2
            tcp6       0      0 :::3000                 :::*                    LISTEN      1001       119414480  19746/io.fullybrows
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          118809614  384/master
            tcp6       0      0 ::1:6379                :::*                    LISTEN      103        118808672  153/redis-server 12
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       119421507  20025/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       119405445  19057/io.admin.0
            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       119418303  19909/io.simple-api
            tcp6       0      0 :::8093                 :::*                    LISTEN      1001       119417319  19813/io.rest-api.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       119407980  19276/io.chromecast
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       119406158  19487/io.shelly.0
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       119406274  19527/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       119406275  19527/io.tuya.0
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          118804394  1/init
            udp6       0      0 :::111                  :::*                                0          118804396  1/init
            2024-10-20 19:12:02.053  - info: device-watcher.0 (19314) Instanz-Wachdog:
            iot.0: undefined
            2024-10-20 19:12:03.344  - info: host.iobroker instance system.adapter.sayit.0 in version "5.0.0" started with pid 19833
            2024-10-20 19:12:05.916  - info: device-watcher.0 (19314) Instanz-Wachdog:
            mytime.0: undefined
            2024-10-20 19:12:07.363  - info: host.iobroker instance system.adapter.sayit.1 in version "5.0.0" started with pid 19853
            2024-10-20 19:12:10.343  - info: device-watcher.0 (19314) Instanz-Wachdog:
            rest-api.0: undefined
            2024-10-20 19:12:11.352  - info: host.iobroker instance system.adapter.sayit.2 in version "5.0.0" started with pid 19868
            2024-10-20 19:12:15.343  - info: host.iobroker instance system.adapter.sayit.3 in version "5.0.0" started with pid 19888
            2024-10-20 19:12:19.378  - info: host.iobroker instance system.adapter.simple-api.0 in version "2.8.0" started with pid 19909
            2024-10-20 19:12:23.368  - info: host.iobroker instance system.adapter.text2command.0 in version "3.0.3" started with pid 19929
            2024-10-20 19:12:27.344  - info: host.iobroker instance system.adapter.text2command.1 in version "3.0.3" started with pid 19944
            2024-10-20 19:12:31.372  - info: host.iobroker instance system.adapter.trashschedule.0 in version "3.3.0" started with pid 19964
            2024-10-20 19:12:35.348  - info: host.iobroker instance system.adapter.vis-inventwo.0 in version "3.3.4" started with pid 19984
            2024-10-20 19:12:35.842  - info: vis-inventwo.0 (19984) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v20.18.0, js-controller: 7.0.0
            2024-10-20 19:12:40.913  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
            2024-10-20 19:12:43.341  - info: host.iobroker instance system.adapter.web.0 in version "6.3.1" started with pid 20025
            2024-10-20 19:12:53.557  - info: tuya.0 (19527) bfe605f9ac49c752847hcd: Error on Reconnect (7): connect EHOSTUNREACH 192.168.0.168:6668
            2024-10-20 19:12:54.000  - info: device-watcher.0 (19314) Instanz-Wachdog:
            web.0: undefined
            edit
            Hmm der Fehler von oben ist mir so noch nie aufgefallen und das System läuft als Container schon sehr lange.
              Thomas Braun Most Active @lindi200000 last edited by
              @lindi200000 sagte in Änderungen iob CLI/Installer/Fixer mit Root Accounts:
              Es wird geschaut, ob die Zeitzone entweder 'Etc/UTC' oder 'Europe/London' ist und dann wird vermutet, das die falsch ist. Sorry an alle Engländer, die den ioBroker verwenden.
              • Feuersturm
                Feuersturm @Thomas Braun last edited by
                @thomas-braun sagte in Änderungen iob CLI/Installer/Fixer mit Root Accounts:
                @feuersturm
                Nochmal den
                iob fix
                Stimmt, beim zweiten Durchlauf hält er dort an. Ich hab die Frage jetzt noch nicht beantwortet, dachte bisher, dass ich keine GUI installier habe.
                iob diag sagt mir auch Display Server: false. Wie ist hier der Zusammenhang zwischen Userinterace/desktop aus der iob fix meldung und dem Display Server @thomas-braun
                Script v.2024-10-19
                *** BASE SYSTEM ***
                 Static hostname: ioB-Prod-Testsystem
                         Chassis: container
                  Virtualization: lxc
                Operating System: Ubuntu 22.04.5 LTS
                          Kernel: Linux 6.5.13-1-pve
                OS is similar to: debian
                model name      : Intel(R) Celeron(R) CPU  N3150  @ 1.60GHz
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                 19:24:43 up 17 days, 21:43,  2 users,  load average: 2.50, 2.04, 1.96
                CPU threads: 4
                Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
                               Local time: Sun 2024-10-20 19:24:44 CEST
                           Universal time: Sun 2024-10-20 17:24:44 UTC
                                 RTC time: n/a
                          RTC in local TZ: no
                proxmox
                HOME=/home/proxmox
                GROUPS=proxmox sudo iobroker
                js-controller is not running
                Desktop:
                Terminal:       tty
                  @thomas-braun ok gut zu wissen, solange es nur eine Empfehlung vom fixer ist und nicht zwingend umgesetzt wird ist alles gut. Ich lasse meine Systeme alle auf utc laufen
                    Das ist falsch. Die TimeZone muss richtig gesetzt sein.
                    Die interne Uhr läuft natürlich auf UTC.
                    • Meister Mopper
                      Meister Mopper @Thomas Braun last edited by
                      Es sei denn, man beachtet diesen Umstand in allen scripts und den states, oder liege ich da falsch?
                        Thomas Braun Most Active @Meister Mopper last edited by Thomas Braun
                        @meister-mopper sagte in Änderungen iob CLI/Installer/Fixer mit Root Accounts:
                        Das muss dann aber auch in anderen Systemen (cloud-Services usw.) auch berücksichtigt sein. Das hast du aber nicht alles in der Hand.
                        Dadurch kommt es ja zu diesen Fehlern, das Dinge mit 1-2 Stunden Versatz durchgeführt werden. Oder so merkwürdige Netzwerkfehler, weil Pakete aus der Zukunft verworfen werden. Das ist ein ganz komplexes Thema.
                        Meister Mopper L 2 Replies Last reply Reply Quote 0
                          @feuersturm sagte in Änderungen iob CLI/Installer/Fixer mit Root Accounts:
                          Aber das BootTarget ist bestimmt 'graphical.target' und nicht 'multi-user.target'.
                          • Meister Mopper
                            Das hatte ich bisher so nicht betrachtet, ist aber schlüssig.
                            Ich habe hier alle Server auf Europe/Berlin, nur einen betreibe ich mit UTC (flightradar24 => die lieben Harmonie 😀 )
                            • Feuersturm
                              Mit googels Hilfe würde ich sagen, das stimmt, wobei ich noch nicht genau verstanden habe was da genau hinterhängt und wo der vorteil bei multiuser.target ist
                              proxmox@ioB-Prod-Testsystem:~$ systemctl get-default
                              graphical.target
                                @thomas-braun ich Frage, weil ich alle meine Server seit Jahren nur in UTC laufen lasse, somit muss ich mir nie Gedanken mache wegen Zeitumstellung etc .... , klar beim scripten muss man aufpassen, aber das erstmal nebensache.
                                  @feuersturm
                                  Man kann bei Linux-Systemen in verschiedene 'run level' bzw boot.targets booten.
                                  Server laufen in RunLevel3 bzw. 'multi-user', weil die halt keine graphische Oberfläche benötigen.
                                  Nur wenn du Briefe schreiben willst, Games zocken willst, einen Browser verwenden willst benötigst du eine GUI.
                                  Sonst nicht.
                                  Mit 'multi-user.target' wird also weniger Code ausgeführt, das spart Ressourcen und ist sicherer, weil Code der nicht läuft nicht abstürzen kann und keine Angriffsvektoren eröffnet.
                                    Thomas Braun Most Active @lindi200000 last edited by Thomas Braun
                                    Äh, genau DAZU ist doch die Datei 'tzdata' gedacht. Die macht das alles automatisch für die Zukunft und für die Vergangenheit und wird akribisch aktuell gehalten. Damit das aber alles richtig funktioniert muss die Zeitzone auch gesetzt sein.
                                    Vielleicht reden wir aber auch aneinander vorbei. Die RTC/Echtzeituhr auf einem Linux sollte natürlich auf UTC stehen. Die aktuelle lokale Zeit ist aber immer auf Basis der tzdata-Datei eine berechnete Zeit.
                                      Das kommt von Polkit. Der Code bei den systemd.services ist aber eigentlich gar nicht angepackt worden. Jedenfalls nicht von mir. Was ist denn das da für ein System?
                                      @apollon77
                                      Kannst du was dazu sagen ob der Code geändert wurde, ich hatte bisher keine Fehlermeldungen beim iob fix.
                                        Thomas Braun Most Active @Shadowhunter23 last edited by
                                        @shadowhunter23
                                        Da wird eine Authentifizierung getriggert, weil an den .service-Dateien erstmal nur der root herummachen darf.
                                        Auf Systemen mit einem laufenden DesktopEnvironment poppt dann da ein Fenster auf, auf headless-Kisten erscheint eine Abfrage in der Konsole.
                                        Ist polkitd installiert?
                                        apt policy polkitd
                                          tobias@iobroker:~$ apt policy polkitd
                                          polkitd:
                                            Installed: (none)
                                            Candidate: 122-3
                                            Version table:
                                               122-3 500
                                          tobias@iobroker:~$
                                            @shadowhunter23 sagte in Änderungen iob CLI/Installer/Fixer mit Root Accounts:
                                            Installed: (none)
                                            Dann weißte ja jetzt, warum die Datei vermisst wird
                                            202
                                            37724
