    4. Änderungen iob CLI/Installer/Fixer mit Root Accounts
      Thomas Braun Most Active @Feuersturm last edited by
      @feuersturm
      Nochmal den
      iob fix
      laufen lassen. Dann müssste es funktionieren.
      L Feuersturm 2 Replies Last reply Reply Quote 0
        lindi200000 @Thomas Braun last edited by
        Moin, durch was wird die Zeitzone festgesetzt, welche die richtige ist? Oder vergleicht er nur die System Zeitzone mit der, die im iob hinterlegt ist?
          Shadowhunter23 @Thomas Braun last edited by Shadowhunter23
          Script v.2024-10-19
          *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer-container
                   Chassis: container ☐
            Virtualization: lxc
                    Kernel: Linux 6.8.12-2-pve
              Architecture: x86-64
          OS is similar to:
          model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           19:24:33 up  2:22,  2 users,  load average: 0.62, 0.51, 0.54
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Operating System is the current Debian stable version codenamed 'bookworm'!
          *** TIME AND TIMEZONES ***
                         Local time: Sun 2024-10-20 19:24:33 CEST
                     Universal time: Sun 2024-10-20 17:24:33 UTC
                           RTC time: n/a
                        NTP service: inactive
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          tobias
          HOME=/home/tobias
          GROUPS=tobias adm dialout sudo audio video plugdev users iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev redis
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:             10G        3.9G        6.2G        491K        660M        6.9G
          Swap:             0B          0B          0B
          Total:           10G        3.9G        6.2G
          Active iob-Instances:   50
                  10240 M total memory
                   3694 M used memory
                   3601 M active memory
                    430 M inactive memory
                   5915 M free memory
                      0 M buffer memory
                    630 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          top - 19:24:34 up  2:22,  2 users,  load average: 0.57, 0.50, 0.54
          Tasks:  82 total,   1 running,  81 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  10240.0 total,   5914.1 free,   3696.2 used,    630.2 buff/cache
          MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6543.8 avail Mem
          *** FAILED SERVICES ***
            UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
          * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          1 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          dmesg: read kernel buffer failed: Operation not permitted
          No critical errors detected
          *** FILESYSTEM ***
          Filesystem                       Type      Size  Used Avail Use% Mounted on
          /dev/mapper/pve-vm--400--disk--0 ext4       20G  7.1G   12G  39% /
          none                             tmpfs     492K  4.0K  488K   1% /dev
          udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
          tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
          tmpfs                            tmpfs     3.1G  136K  3.1G   1% /run
          tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1000
          Show mounted filesystems:
          TARGET SOURCE                           FSTYPE OPTIONS
          /      /dev/mapper/pve-vm--400--disk--0 ext4   rw,relatime,stripe=16
          /var:
          784M    /var/
          525M    /var/lib
          374M    /var/lib/redis
          225M    /var/cache
          222M    /var/cache/apt
          Archived and active journals take up 32.0M in the file system.
          /opt/iobroker/backups:
          1.7G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          143M    /opt/iobroker/iobroker-data/
          128M    /opt/iobroker/iobroker-data/files
          99M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
          16M     /opt/iobroker/iobroker-data/objects.jsonl
          12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
          7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
          7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
          5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
          USB-Devices by-id:
          No Devices found 'by-id'
          HINT:
          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
          tcp
          HINT:
          Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
          tcp
          HINT:
          Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
          tcp
          HINT:
          Your zigbee.3 COM-Port is NOT matching 'by-id'. Please check your setting:
          tcp
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.18.0
          /usr/bin/node           v20.18.0
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.3
          nodejs:
            Installed: 20.18.0-1nodesource1
            Candidate: 20.18.0-1nodesource1
            Version table:
           *** 20.18.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org bookworm-security/main amd64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          At least one iobroker host is running.
          Objects type: redis
          States  type: redis
          Hosts:
          iobroker            iobroker (version: 7.0.0, hostname: iobroker      , alive, uptime: 915)
          Core adapters versions
          js-controller:  7.0.0
          admin:          7.2.6
          javascript:     8.8.3
          nodejs modules from github:     0
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
          + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
          + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
          + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
          + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
            system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
          + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.mytime.0                 : mytime                : iobroker                                 -  enabled
          + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
          + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
          + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
            system.adapter.octoprint.1              : octoprint             : iobroker                                 - disabled
            system.adapter.octoprint.2              : octoprint             : iobroker                                 - disabled
          + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
          + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
          + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
          + system.adapter.pushover.2               : pushover              : iobroker                                 -  enabled
          + system.adapter.rest-api.0               : rest-api              : iobroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
          + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
          + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
          + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
          + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
            system.adapter.sayit.4                  : sayit                 : iobroker                                 - disabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
          + system.adapter.text2command.1           : text2command          : iobroker                                 -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.wireguard.0              : wireguard             : iobroker                                 -  enabled
          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.64:20108
          + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.69:20108
          + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.79:20108
          + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.63:20108
          + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.99:20108
          + instance is alive
          ioBroker-Repositories
          Active repo(s): beta
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: beta
          Adapter    "admin"        : 7.2.6    , installed 7.2.6
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
          Adapter    "backitup"     : 3.0.26   , installed 3.0.26
          Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
          Adapter    "device-watcher": 2.12.1  , installed 2.12.1
          Adapter    "email"        : 1.3.1    , installed 1.3.1
          Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
          Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
          Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
          Adapter    "ical"         : 1.15.0   , installed 1.15.0
          Adapter    "iot"          : 3.4.2    , installed 3.4.2
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.0    , installed 7.0.0
          Adapter    "lg-thinq"     : 1.0.2    , installed 1.0.2
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "mytime"       : 0.7.12   , installed 0.7.12
          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
          Adapter    "notification-manager": 1.3.0, installed 1.3.0
          Adapter    "nuki"         : 2.0.0    , installed 2.0.0
          Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
          Adapter    "operating-hours": 1.1.0  , installed 1.1.0
          Adapter    "ping"         : 1.7.9    , installed 1.7.9
          Adapter    "pushover"     : 4.1.0    , installed 4.1.0
          Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
          Adapter    "sayit"        : 5.0.0    , installed 5.0.0
          Adapter    "shelly"       : 8.4.0    , installed 8.4.0
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
          Adapter    "telegram"     : 3.9.0    , installed 3.9.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
          Adapter    "vis-icontwo"  : 1.6.3    , installed 1.6.3
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
          Adapter    "web"          : 6.3.1    , installed 6.3.1
          Adapter    "wireguard"    : 1.7.0    , installed 1.7.0
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
          Objects and States
          Objects:        12688
          States:         11451
          Hit:1 http://security.debian.org bookworm-security InRelease
          Hit:2 http://deb.debian.org/debian bookworm InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
          Hit:5 https://packages.redis.io/deb bookworm InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          118804393  1/init
          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      103        118808671  153/redis-server 12
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       119406220  19507/io.shelly.1
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       119402442  19359/io.mqtt.0
          tcp        0      0 192.168.0.222:9092      0.0.0.0:*               LISTEN      1001       119406113  19404/io.nuki.0
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          118809613  384/master
          tcp6       0      0 :::22                   :::*                    LISTEN      0          118797944  1/init
          tcp6       0      0 :::111                  :::*                    LISTEN      0          118804395  1/init
          tcp6       0      0 :::80                   :::*                    LISTEN      0          118807395  176/apache2
          tcp6       0      0 :::3000                 :::*                    LISTEN      1001       119414480  19746/io.fullybrows
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          118809614  384/master
          tcp6       0      0 ::1:6379                :::*                    LISTEN      103        118808672  153/redis-server 12
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       119421507  20025/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       119405445  19057/io.admin.0
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       119418303  19909/io.simple-api
          tcp6       0      0 :::8093                 :::*                    LISTEN      1001       119417319  19813/io.rest-api.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       119407980  19276/io.chromecast
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       119406158  19487/io.shelly.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       119406274  19527/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       119406275  19527/io.tuya.0
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          118804394  1/init
          udp6       0      0 :::111                  :::*                                0          118804396  1/init
          2024-10-20 19:12:02.053  - info: device-watcher.0 (19314) Instanz-Wachdog:
          iot.0: undefined
          2024-10-20 19:12:03.344  - info: host.iobroker instance system.adapter.sayit.0 in version "5.0.0" started with pid 19833
          2024-10-20 19:12:05.916  - info: device-watcher.0 (19314) Instanz-Wachdog:
          mytime.0: undefined
          2024-10-20 19:12:07.363  - info: host.iobroker instance system.adapter.sayit.1 in version "5.0.0" started with pid 19853
          2024-10-20 19:12:10.343  - info: device-watcher.0 (19314) Instanz-Wachdog:
          rest-api.0: undefined
          2024-10-20 19:12:11.352  - info: host.iobroker instance system.adapter.sayit.2 in version "5.0.0" started with pid 19868
          2024-10-20 19:12:15.343  - info: host.iobroker instance system.adapter.sayit.3 in version "5.0.0" started with pid 19888
          2024-10-20 19:12:19.378  - info: host.iobroker instance system.adapter.simple-api.0 in version "2.8.0" started with pid 19909
          2024-10-20 19:12:23.368  - info: host.iobroker instance system.adapter.text2command.0 in version "3.0.3" started with pid 19929
          2024-10-20 19:12:27.344  - info: host.iobroker instance system.adapter.text2command.1 in version "3.0.3" started with pid 19944
          2024-10-20 19:12:31.372  - info: host.iobroker instance system.adapter.trashschedule.0 in version "3.3.0" started with pid 19964
          2024-10-20 19:12:35.348  - info: host.iobroker instance system.adapter.vis-inventwo.0 in version "3.3.4" started with pid 19984
          2024-10-20 19:12:35.842  - info: vis-inventwo.0 (19984) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v20.18.0, js-controller: 7.0.0
          2024-10-20 19:12:40.913  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
          2024-10-20 19:12:43.341  - info: host.iobroker instance system.adapter.web.0 in version "6.3.1" started with pid 20025
          2024-10-20 19:12:53.557  - info: tuya.0 (19527) bfe605f9ac49c752847hcd: Error on Reconnect (7): connect EHOSTUNREACH 192.168.0.168:6668
          2024-10-20 19:12:54.000  - info: device-watcher.0 (19314) Instanz-Wachdog:
          web.0: undefined
          edit
          Hmm der Fehler von oben ist mir so noch nie aufgefallen und das System läuft als Container schon sehr lange.
            Thomas Braun Most Active @lindi200000 last edited by
            @lindi200000 sagte in Änderungen iob CLI/Installer/Fixer mit Root Accounts:
            Es wird geschaut, ob die Zeitzone entweder 'Etc/UTC' oder 'Europe/London' ist und dann wird vermutet, das die falsch ist. Sorry an alle Engländer, die den ioBroker verwenden.
            • Feuersturm
              Feuersturm @Thomas Braun last edited by
              @thomas-braun sagte in Änderungen iob CLI/Installer/Fixer mit Root Accounts:
              @feuersturm
              Nochmal den
              iob fix
              Stimmt, beim zweiten Durchlauf hält er dort an. Ich hab die Frage jetzt noch nicht beantwortet, dachte bisher, dass ich keine GUI installier habe.
              iob diag sagt mir auch Display Server: false. Wie ist hier der Zusammenhang zwischen Userinterace/desktop aus der iob fix meldung und dem Display Server @thomas-braun
              Script v.2024-10-19
              *** BASE SYSTEM ***
               Static hostname: ioB-Prod-Testsystem
                       Chassis: container
                Virtualization: lxc
              Operating System: Ubuntu 22.04.5 LTS
                        Kernel: Linux 6.5.13-1-pve
              OS is similar to: debian
              model name      : Intel(R) Celeron(R) CPU  N3150  @ 1.60GHz
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
               19:24:43 up 17 days, 21:43,  2 users,  load average: 2.50, 2.04, 1.96
              CPU threads: 4
              Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
                             Local time: Sun 2024-10-20 19:24:44 CEST
                         Universal time: Sun 2024-10-20 17:24:44 UTC
                               RTC time: n/a
                        RTC in local TZ: no
              proxmox
              HOME=/home/proxmox
              GROUPS=proxmox sudo iobroker
              js-controller is not running
              Desktop:
              Terminal:       tty
                @thomas-braun ok gut zu wissen, solange es nur eine Empfehlung vom fixer ist und nicht zwingend umgesetzt wird ist alles gut. Ich lasse meine Systeme alle auf utc laufen
                  Das ist falsch. Die TimeZone muss richtig gesetzt sein.
                  Die interne Uhr läuft natürlich auf UTC.
                  • Meister Mopper
                    Meister Mopper @Thomas Braun last edited by
                    Es sei denn, man beachtet diesen Umstand in allen scripts und den states, oder liege ich da falsch?
                      Thomas Braun Most Active @Meister Mopper last edited by Thomas Braun
                      @meister-mopper sagte in Änderungen iob CLI/Installer/Fixer mit Root Accounts:
                      Das muss dann aber auch in anderen Systemen (cloud-Services usw.) auch berücksichtigt sein. Das hast du aber nicht alles in der Hand.
                      Dadurch kommt es ja zu diesen Fehlern, das Dinge mit 1-2 Stunden Versatz durchgeführt werden. Oder so merkwürdige Netzwerkfehler, weil Pakete aus der Zukunft verworfen werden. Das ist ein ganz komplexes Thema.
                      Meister Mopper L 2 Replies Last reply Reply Quote 0
                        @feuersturm sagte in Änderungen iob CLI/Installer/Fixer mit Root Accounts:
                        Aber das BootTarget ist bestimmt 'graphical.target' und nicht 'multi-user.target'.
                        • Meister Mopper
                          Das hatte ich bisher so nicht betrachtet, ist aber schlüssig.
                          Ich habe hier alle Server auf Europe/Berlin, nur einen betreibe ich mit UTC (flightradar24 => die lieben Harmonie 😀 )
                          • Feuersturm
                            Mit googels Hilfe würde ich sagen, das stimmt, wobei ich noch nicht genau verstanden habe was da genau hinterhängt und wo der vorteil bei multiuser.target ist
                            proxmox@ioB-Prod-Testsystem:~$ systemctl get-default
                            graphical.target
                              @thomas-braun ich Frage, weil ich alle meine Server seit Jahren nur in UTC laufen lasse, somit muss ich mir nie Gedanken mache wegen Zeitumstellung etc .... , klar beim scripten muss man aufpassen, aber das erstmal nebensache.
                                @feuersturm
                                Man kann bei Linux-Systemen in verschiedene 'run level' bzw boot.targets booten.
                                Server laufen in RunLevel3 bzw. 'multi-user', weil die halt keine graphische Oberfläche benötigen.
                                Nur wenn du Briefe schreiben willst, Games zocken willst, einen Browser verwenden willst benötigst du eine GUI.
                                Sonst nicht.
                                Mit 'multi-user.target' wird also weniger Code ausgeführt, das spart Ressourcen und ist sicherer, weil Code der nicht läuft nicht abstürzen kann und keine Angriffsvektoren eröffnet.
                                  Thomas Braun Most Active @lindi200000 last edited by Thomas Braun
                                  Äh, genau DAZU ist doch die Datei 'tzdata' gedacht. Die macht das alles automatisch für die Zukunft und für die Vergangenheit und wird akribisch aktuell gehalten. Damit das aber alles richtig funktioniert muss die Zeitzone auch gesetzt sein.
                                  Vielleicht reden wir aber auch aneinander vorbei. Die RTC/Echtzeituhr auf einem Linux sollte natürlich auf UTC stehen. Die aktuelle lokale Zeit ist aber immer auf Basis der tzdata-Datei eine berechnete Zeit.
                                    Das kommt von Polkit. Der Code bei den systemd.services ist aber eigentlich gar nicht angepackt worden. Jedenfalls nicht von mir. Was ist denn das da für ein System?
                                    @apollon77
                                    Kannst du was dazu sagen ob der Code geändert wurde, ich hatte bisher keine Fehlermeldungen beim iob fix.
                                      Thomas Braun Most Active @Shadowhunter23 last edited by
                                      @shadowhunter23
                                      Da wird eine Authentifizierung getriggert, weil an den .service-Dateien erstmal nur der root herummachen darf.
                                      Auf Systemen mit einem laufenden DesktopEnvironment poppt dann da ein Fenster auf, auf headless-Kisten erscheint eine Abfrage in der Konsole.
                                      Ist polkitd installiert?
                                      apt policy polkitd
                                        tobias@iobroker:~$ apt policy polkitd
                                        polkitd:
                                          Installed: (none)
                                          Candidate: 122-3
                                          Version table:
                                             122-3 500
                                        tobias@iobroker:~$
                                          @shadowhunter23 sagte in Änderungen iob CLI/Installer/Fixer mit Root Accounts:
                                          Installed: (none)
                                          Dann weißte ja jetzt, warum die Datei vermisst wird
                                            Warum ging das bisher? Oder wurde jetzt was geändert?
                                            1.2k
                                            202
                                            37724
