    4. Einbinden von Modbus - R4DCB08 sensoren
      Marc 3 last edited by
      Ok, sorry, nun nochmal richtig:
      modbus.4
      	2024-10-20 20:18:16.942	warn	Poll error count: 3 code: "ReadInputRegisters: Invalid FC 3"
      modbus.4
      	2024-10-20 20:18:16.632	debug	[DevID_3/inputRegs] Poll address 1 - 1 registers
      modbus.4
      	2024-10-20 20:18:16.631	debug	[DevID_3] Poll start ---------------------
      modbus.4
      	2024-10-20 20:18:06.577	warn	Poll error count: 2 code: "ReadInputRegisters: Invalid FC 3"
      modbus.4
      	2024-10-20 20:18:06.269	debug	[DevID_3/inputRegs] Poll address 1 - 1 registers
      modbus.4
      	2024-10-20 20:18:06.268	debug	[DevID_3] Poll start ---------------------
      modbus.4
      	2024-10-20 20:17:56.212	warn	Poll error count: 1 code: "ReadInputRegisters: Invalid FC 3"
      modbus.4
      	2024-10-20 20:17:55.174	error	Error response: 0
      modbus.4
      	2024-10-20 20:17:55.156	error	unknown function code: 0x51, 0x3
      modbus.4
      	2024-10-20 20:17:54.202	debug	[DevID_3/inputRegs] Poll address 1 - 1 registers
      modbus.4
      	2024-10-20 20:17:54.201	debug	Initialization of scale factors done!
      modbus.4
      	2024-10-20 20:17:54.194	debug	[DevID_3] Poll start ---------------------
      modbus.4
      	2024-10-20 20:17:54.192	info	Connected to slave
      modbus.4
      	2024-10-20 20:17:54.170	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.4
      	2024-10-20 20:17:53.674	info	Can not execute task "add" for ID undefined: The id is empty! Please provide a valid id. ({"name":"add","obj":{"type":"state","common":{"name":"","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":-40001,"deviceId":3,"type":"uint32be","len":2,"offset":0,"factor":1,"poll":true}}}
      modbus.4
      	2024-10-20 20:17:52.858	debug	Add undefined: {"type":"state","common":{"name":"","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":-40001,"deviceId":3,"type":"uint32be","len":2,"offset":0,"factor":1,"poll":true}}
      modbus.4
      	2024-10-20 20:17:52.856	error	Invalid object: {"type":"state","common":{"name":"","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":-40001,"deviceId":3,"type":"uint32be","len":2,"offset":0,"factor":1,"poll":true}}
      modbus.4
      	2024-10-20 20:17:52.856	error	Invalid data holdingRegisters/0: {"_address":-40001,"deviceId":3,"name":"Temp","description":"","unit":"°C","type":"uint32be","len":2,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":-40001,"fullId":"modbus.4.0"}
      modbus.4
      	2024-10-20 20:17:52.855	debug	Initialize Objects for holdingRegs: [{"_address":-40001,"deviceId":3,"name":"Temp","description":"","unit":"°C","type":"uint32be","len":2,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":-40001}]
      modbus.4
      	2024-10-20 20:17:52.851	debug	Add inputRegisters.1_Temp: {"_id":"inputRegisters.1_Temp","type":"state","common":{"name":"Temp","role":"value.temperature","type":"number","read":true,"write":false,"def":0,"unit":""},"native":{"regType":"inputRegs","address":1,"deviceId":3,"type":"uint16be","len":1,"offset":0,"factor":1}}
      modbus.4
      	2024-10-20 20:17:52.842	debug	Initialize Objects for inputRegs: [{"_address":"1","deviceId":3,"name":"Temp","description":"Temp","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value.temperature","room":"","cw":"","isScale":"","address":1,"id":"inputRegisters.1_Temp"}]
      modbus.4
      	2024-10-20 20:17:52.824	debug	Initialize Objects for coils: []
      modbus.4
      	2024-10-20 20:17:52.822	debug	Initialize Objects for disInputs: []
      modbus.4
      	2024-10-20 20:17:52.819	error	Invalid holdingRegisters address: -40001
      modbus.4
      	2024-10-20 20:17:52.215	info	starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.19.0, js-controller: 4.0.24
      modbus.4
      	2024-10-20 20:17:50.449	debug	Plugin sentry Initialize Plugin (enabled=true)
      modbus.4
      	2024-10-20 20:17:48.433	debug	States connected to redis: 127.0.0.1:9000
      modbus.4
      	2024-10-20 20:17:47.620	debug	States create User PubSub Client
      modbus.4
      	2024-10-20 20:17:47.618	debug	States create System PubSub Client
      modbus.4
      	2024-10-20 20:17:47.449	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      modbus.4
      	2024-10-20 20:17:47.255	debug	Objects connected to redis: 127.0.0.1:9001
      modbus.4
      	2024-10-20 20:17:46.901	debug	Objects client initialize lua scripts
      modbus.4
      	2024-10-20 20:17:46.119	debug	Objects create User PubSub Client
      modbus.4
      	2024-10-20 20:17:46.116	debug	Objects create System PubSub Client
      modbus.4
      	2024-10-20 20:17:46.039	debug	Objects client ready ... initialize now
      modbus.4
      	2024-10-20 20:17:45.459	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        Homoran Global Moderator Administrators @Marc 3 last edited by
        @marc-3 sagte in Einbinden von Modbus - R4DCB08 sensoren:
        Danke!
        jetzt gibt's schonmal eine Verbindung!
        aber
        hattest du was geändert?
        und was bei den Holdingregistern eingetragen?
          ja, das hatte ich mal auf "nichts" gestellt
          auch hier hab ich mal was ausprobiert, aber leider ohne Erfolg
          modbus.4
          	2024-10-20 20:30:06.239	warn	Poll error count: 4 code: "ReadInputRegisters: Invalid FC 3"
          modbus.4
          	2024-10-20 20:30:05.928	debug	[DevID_3/inputRegs] Poll address 1 - 1 registers
          modbus.4
          	2024-10-20 20:30:05.926	debug	[DevID_3] Poll start ---------------------
          modbus.4
          	2024-10-20 20:29:55.874	warn	Poll error count: 3 code: "ReadInputRegisters: Invalid FC 3"
          modbus.4
          	2024-10-20 20:29:55.563	debug	[DevID_3/inputRegs] Poll address 1 - 1 registers
          modbus.4
          	2024-10-20 20:29:55.562	debug	[DevID_3] Poll start ---------------------
          modbus.4
          	2024-10-20 20:29:45.510	warn	Poll error count: 2 code: "ReadInputRegisters: Invalid FC 3"
          modbus.4
          	2024-10-20 20:29:45.199	debug	[DevID_3/inputRegs] Poll address 1 - 1 registers
          modbus.4
          	2024-10-20 20:29:45.197	debug	[DevID_3] Poll start ---------------------
          modbus.4
          	2024-10-20 20:29:35.144	warn	Poll error count: 1 code: "ReadInputRegisters: Invalid FC 3"
          modbus.4
          	2024-10-20 20:29:34.102	error	unknown function code: 0x0, 0xc1
          modbus.4
          	2024-10-20 20:29:34.091	error	Error response: Value is not accepted by slave
          modbus.4
          	2024-10-20 20:29:34.089	error	Error response for FCx17: Illegal Data Value
          modbus.4
          	2024-10-20 20:29:33.339	debug	[DevID_3/inputRegs] Poll address 1 - 1 registers
          modbus.4
          	2024-10-20 20:29:33.338	debug	Initialization of scale factors done!
          modbus.4
          	2024-10-20 20:29:33.334	debug	[DevID_3] Poll start ---------------------
          modbus.4
          	2024-10-20 20:29:33.332	info	Connected to slave
          modbus.4
          	2024-10-20 20:29:33.304	debug	connect to serial /dev/ttyUSB0 with 9600
          modbus.4
          	2024-10-20 20:29:32.138	debug	Initialize Objects for holdingRegs: []
          modbus.4
          	2024-10-20 20:29:32.137	debug	Add inputRegisters.1_Temp: {"_id":"inputRegisters.1_Temp","type":"state","common":{"name":"Temp","role":"value.temperature","type":"number","read":true,"write":false,"def":0,"unit":""},"native":{"regType":"inputRegs","address":1,"deviceId":3,"type":"uint16be","len":1,"offset":0,"factor":1}}
          modbus.4
          	2024-10-20 20:29:32.135	debug	Initialize Objects for inputRegs: [{"_address":"1","deviceId":3,"name":"Temp","description":"Temp","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value.temperature","room":"","cw":"","isScale":"","address":1,"id":"inputRegisters.1_Temp"}]
          modbus.4
          	2024-10-20 20:29:32.134	debug	Initialize Objects for coils: []
          modbus.4
          	2024-10-20 20:29:32.127	debug	Initialize Objects for disInputs: []
          modbus.4
          	2024-10-20 20:29:31.305	info	starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.19.0, js-controller: 4.0.24
          modbus.4
          	2024-10-20 20:29:29.864	debug	Plugin sentry Initialize Plugin (enabled=true)
          modbus.4
          	2024-10-20 20:29:18.548	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          modbus.4
          	2024-10-20 20:29:18.547	debug	Plugin sentry destroyed
          modbus.4
          	2024-10-20 20:29:18.545	info	terminating
          modbus.4
          	2024-10-20 20:29:18.542	info	Got terminate signal TERMINATE_YOURSELF
          modbus.4
          	2024-10-20 20:28:50.621	debug	Cleaning up request fifo.
          modbus.4
          	2024-10-20 20:28:50.616	debug	Clearing timeout of the current request.
          modbus.4
          	2024-10-20 20:28:50.601	info	Disconnected from slave
            Homoran Global Moderator Administrators @Marc 3 last edited by Homoran
            ich kenne den Temperaturbereich nicht, abe u(nsigned) bedeutet ohne Vorzeichen.
            Das ist bei Temperaturen eigentlich unüblich
            nimm mal Int16be
            mach das weg!
            @homoran sagte in Einbinden von Modbus - R4DCB08 sensoren:
            immer nur mit einem probieren bis es läuft
            sobald auch nur ein Fehler drin ist, kommt kein einziger Wert
              Hab alles andere raus.
              Int16be hat aber nur eine Länge von 1, ich brauche aber eine Länge von 2. Der Temperaturwert sieht dann wie folgt aus: erste Ziffer 0 = +, 1=-. Rest ist Hex, muss in's Dec und *0,1. Gibt es dafür einen geeigneten Typ?
              modbus.4
              	2024-10-20 20:40:00.478	warn	Poll error count: 4 code: "ReadInputRegisters: Invalid FC 3"
              modbus.4
              	2024-10-20 20:40:00.141	debug	[DevID_3/inputRegs] Poll address 1 - 1 registers
              modbus.4
              	2024-10-20 20:40:00.139	debug	[DevID_3] Poll start ---------------------
              modbus.4
              	2024-10-20 20:39:50.087	warn	Poll error count: 3 code: "ReadInputRegisters: Invalid FC 3"
              modbus.4
              	2024-10-20 20:39:49.775	debug	[DevID_3/inputRegs] Poll address 1 - 1 registers
              modbus.4
              	2024-10-20 20:39:49.773	debug	[DevID_3] Poll start ---------------------
              modbus.4
              	2024-10-20 20:39:39.721	warn	Poll error count: 2 code: "ReadInputRegisters: Invalid FC 3"
              modbus.4
              	2024-10-20 20:39:39.418	debug	[DevID_3/inputRegs] Poll address 1 - 1 registers
              modbus.4
              	2024-10-20 20:39:39.416	debug	[DevID_3] Poll start ---------------------
              modbus.4
              	2024-10-20 20:39:29.362	warn	Poll error count: 1 code: "ReadInputRegisters: Invalid FC 3"
              modbus.4
              	2024-10-20 20:39:28.315	error	unknown function code: 0x0, 0xc3
              modbus.4
              	2024-10-20 20:39:28.303	error	Error response: Value is not accepted by slave
              modbus.4
              	2024-10-20 20:39:28.301	error	Error response for FCx17: Illegal Data Value
              modbus.4
              	2024-10-20 20:39:27.651	debug	[DevID_3/inputRegs] Poll address 1 - 1 registers
              modbus.4
              	2024-10-20 20:39:27.649	debug	Initialization of scale factors done!
              modbus.4
              	2024-10-20 20:39:27.645	debug	[DevID_3] Poll start ---------------------
              modbus.4
              	2024-10-20 20:39:27.641	info	Connected to slave
              modbus.4
              	2024-10-20 20:39:27.614	debug	connect to serial /dev/ttyUSB0 with 9600
              modbus.4
              	2024-10-20 20:39:26.378	debug	Initialize Objects for holdingRegs: []
              modbus.4
              	2024-10-20 20:39:26.377	debug	Add inputRegisters.1_Temp: {"_id":"inputRegisters.1_Temp","type":"state","common":{"name":"Temp","role":"value.temperature","type":"number","read":true,"write":false,"def":0,"unit":""},"native":{"regType":"inputRegs","address":1,"deviceId":3,"type":"int16be","len":1,"offset":0,"factor":1}}
              modbus.4
              	2024-10-20 20:39:26.376	debug	Initialize Objects for inputRegs: [{"_address":"1","deviceId":3,"name":"Temp","description":"Temp","unit":"","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value.temperature","room":"","cw":"","isScale":"","address":1,"id":"inputRegisters.1_Temp"}]
              modbus.4
              	2024-10-20 20:39:26.375	debug	Initialize Objects for coils: []
              modbus.4
              	2024-10-20 20:39:26.374	debug	Initialize Objects for disInputs: []
              modbus.4
              	2024-10-20 20:39:25.311	info	starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.19.0, js-controller: 4.0.24
              modbus.4
              	2024-10-20 20:39:23.754	debug	Plugin sentry Initialize Plugin (enabled=true)
              modbus.4
              	2024-10-20 20:39:22.063	debug	States connected to redis: 127.0.0.1:9000
              modbus.4
              	2024-10-20 20:39:21.413	debug	States create User PubSub Client
              modbus.4
              	2024-10-20 20:39:21.408	debug	States create System PubSub Client
              modbus.4
              	2024-10-20 20:39:21.181	debug	Redis States: Use Redis connection: 127.0.0.1:9000
              modbus.4
              	2024-10-20 20:39:21.000	debug	Objects connected to redis: 127.0.0.1:9001
              modbus.4
              	2024-10-20 20:39:20.900	debug	Objects client initialize lua scripts
              modbus.4
              	2024-10-20 20:39:20.303	debug	Objects create User PubSub Client
              modbus.4
              	2024-10-20 20:39:20.300	debug	Objects create System PubSub Client
              modbus.4
              	2024-10-20 20:39:20.184	debug	Objects client ready ... initialize now
              modbus.4
              	2024-10-20 20:39:19.773	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
              modbus.4
              	2024-10-20 20:39:12.156	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              modbus.4
              	2024-10-20 20:39:12.155	debug	Plugin sentry destroyed
              modbus.4
              	2024-10-20 20:39:12.153	info	terminating
              modbus.4
              	2024-10-20 20:39:12.150	info	Got terminate signal TERMINATE_YOURSELF
              modbus.4
              	2024-10-20 20:38:47.233	info	List of port: [{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyUSB0"}]
              modbus.4
              	2024-10-20 20:38:47.231	info	Check /dev/ttyUSB0 : true
              modbus.4
              	2024-10-20 20:38:47.230	info	Check /dev/ttyS3 : true
              modbus.4
              	2024-10-20 20:38:47.230	info	Check /dev/ttyS2 : true
              modbus.4
              	2024-10-20 20:38:47.229	info	Check /dev/ttyS1 : true
              modbus.4
              	2024-10-20 20:38:47.226	info	Check /dev/ttyS0 : true
              modbus.4
              	2024-10-20 20:38:47.221	info	Verify [{"path":"/dev/ttyUSB0","manufacturer":"FTDI","serialNumber":"A10OG1BO","pnpId":"usb-FTDI_FT232R_USB_UART_A10OG1BO-if00-port0","vendorId":"0403","productId":"6001"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS0"}]
              modbus.4
              	2024-10-20 20:38:29.263	debug	Cleaning up request fifo.
              modbus.4
              	2024-10-20 20:38:29.262	debug	Clearing timeout of the current request.
              modbus.4
              	2024-10-20 20:38:29.252	info	Disconnected from slave
                dann doch int32be 🤔 ich hab schief gedacht: 16bit sind 2 byte 😊
                hab gerade nachgesehen, stimmt!
                Bei länge von 2 hab ich auch (u)Int32be
                Da bin ich überfragt.
                Die fuunction codes erzeugt der Adapter
                fc3 ist
                Read Multiple Holding Registers fc3
                Quelle: https://en.m.wikipedia.org/wiki/Modbus
                wieso das noch auftritt wenn da nichts drin steht ???
                edit:
                trag die gleichen Werte mal statt bei inputRegisters bei Holdingregister ein
                manche Geräte wollen das so
                  Eingangs und Holding nun das gleiche:
                  Interessant is der "unkown function code: 0x0, 0xc0" das ergibt rund 19,2°C, was für meinen Keller realistisch ist und was auch der Wert des ersten Temp Sensors ist:
                  modbus.4
                  	2024-10-20 21:10:13.258	warn	Poll error count: 2 code: "ReadInputRegisters: Invalid FC 3"
                  modbus.4
                  	2024-10-20 21:10:12.965	debug	[DevID_3/inputRegs] Poll address 0 - 2 registers
                  modbus.4
                  	2024-10-20 21:10:12.963	debug	[DevID_3] Poll start ---------------------
                  modbus.4
                  	2024-10-20 21:10:02.902	warn	Poll error count: 1 code: "ReadInputRegisters: Invalid FC 3"
                  modbus.4
                  	2024-10-20 21:10:01.850	error	unknown function code: 0x0, 0xc0
                  modbus.4
                  	2024-10-20 21:10:01.836	error	Error response: Value is not accepted by slave
                  modbus.4
                  	2024-10-20 21:10:01.836	error	Error response for FCx17: Illegal Data Value
                  modbus.4
                  	2024-10-20 21:10:01.368	debug	[DevID_3/inputRegs] Poll address 0 - 2 registers
                  modbus.4
                  	2024-10-20 21:10:01.367	debug	Initialization of scale factors done!
                  modbus.4
                  	2024-10-20 21:10:01.360	debug	[DevID_3] Poll start ---------------------
                  modbus.4
                  	2024-10-20 21:10:01.355	info	Connected to slave
                  modbus.4
                  	2024-10-20 21:10:01.331	debug	connect to serial /dev/ttyUSB0 with 9600
                  modbus.4
                  	2024-10-20 21:09:59.175	debug	Add holdingRegisters.1_TempH: {"_id":"holdingRegisters.1_TempH","type":"state","common":{"name":"TempH","role":"level","type":"number","read":false,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":1,"deviceId":3,"type":"uint32be","len":2,"offset":0,"factor":1,"poll":""}}
                  modbus.4
                  	2024-10-20 21:09:59.173	debug	Initialize Objects for holdingRegs: [{"_address":"1","name":"TempH","description":"TempH","unit":"","type":"uint32be","len":2,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":"","wp":"","cw":"","isScale":"","address":1,"deviceId":3,"id":"holdingRegisters.1_TempH"}]
                  modbus.4
                  	2024-10-20 21:09:59.172	debug	Add inputRegisters.0_Temp: {"_id":"inputRegisters.0_Temp","type":"state","common":{"name":"Temp","role":"level","type":"number","read":true,"write":false,"def":0,"unit":""},"native":{"regType":"inputRegs","address":0,"deviceId":3,"type":"uint32be","len":2,"offset":0,"factor":1}}
                  modbus.4
                  	2024-10-20 21:09:59.170	debug	Initialize Objects for inputRegs: [{"_address":0,"name":"Temp","description":"Temp","unit":"","type":"uint32be","len":2,"factor":1,"offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":0,"deviceId":3,"id":"inputRegisters.0_Temp"}]
                  modbus.4
                  	2024-10-20 21:09:59.168	debug	Initialize Objects for coils: []
                  modbus.4
                  	2024-10-20 21:09:59.166	debug	Initialize Objects for disInputs: []
                  modbus.4
                  	2024-10-20 21:09:58.517	info	starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.19.0, js-controller: 4.0.24
                  modbus.4
                  	2024-10-20 21:09:57.170	debug	Plugin sentry Initialize Plugin (enabled=true)
                  modbus.4
                  	2024-10-20 21:09:46.117	debug	Cleaning up request fifo.
                  modbus.4
                  	2024-10-20 21:09:46.102	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  modbus.4
                  	2024-10-20 21:09:46.101	debug	Plugin sentry destroyed
                  modbus.4
                  	2024-10-20 21:09:46.099	info	terminating
                  Falls ich dich falsch verstanden hab und das Eingangsregister löschen soll und nur Holding:
                  modbus.4
                  	2024-10-20 21:18:59.090	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:58.045	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:57.007	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:55.964	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:54.940	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:53.901	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:53.367	debug	[DevID_3] Poll start ---------------------
                  modbus.4
                  	2024-10-20 21:18:52.861	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:51.821	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:50.782	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:49.742	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:48.717	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:47.664	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:46.638	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:45.599	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:44.559	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:43.520	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:43.313	debug	[DevID_3] Poll start ---------------------
                  modbus.4
                  	2024-10-20 21:18:42.482	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:41.439	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:40.415	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:39.375	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:38.335	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:37.295	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:36.258	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:35.224	debug	No current request.
                  modbus.4
                  	2024-10-20 21:18:34.179	error	unknown function code: 0x0, 0xc3
                  modbus.4
                  	2024-10-20 21:18:34.162	error	Error response: Value is not accepted by slave
                  modbus.4
                  	2024-10-20 21:18:34.161	error	Error response for FCx17: Illegal Data Value
                  modbus.4
                  	2024-10-20 21:18:33.258	debug	[DevID_3] Poll start ---------------------
                  modbus.4
                  	2024-10-20 21:18:33.255	info	Connected to slave
                  modbus.4
                  	2024-10-20 21:18:33.225	debug	connect to serial /dev/ttyUSB0 with 9600
                  modbus.4
                  	2024-10-20 21:18:32.240	debug	Remove old object modbus.4.inputRegisters.0_Temp
                  modbus.4
                  	2024-10-20 21:18:32.006	debug	Add holdingRegisters.1_TempH: {"_id":"holdingRegisters.1_TempH","type":"state","common":{"name":"TempH","role":"level","type":"number","read":false,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":1,"deviceId":3,"type":"uint32be","len":2,"offset":0,"factor":1,"poll":""}}
                  modbus.4
                  	2024-10-20 21:18:32.005	debug	Initialize Objects for holdingRegs: [{"_address":"1","name":"TempH","description":"TempH","unit":"","type":"uint32be","len":2,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":"","wp":"","cw":"","isScale":"","address":1,"deviceId":3,"id":"holdingRegisters.1_TempH"}]
                  modbus.4
                  	2024-10-20 21:18:32.004	debug	Initialize Objects for inputRegs: []
                  modbus.4
                  	2024-10-20 21:18:32.002	debug	Initialize Objects for coils: []
                  modbus.4
                  	2024-10-20 21:18:32.001	debug	Initialize Objects for disInputs: []
                  modbus.4
                  	2024-10-20 21:18:31.502	info	starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.19.0, js-controller: 4.0.24
                  modbus.4
                  	2024-10-20 21:18:29.259	debug	Plugin sentry Initialize Plugin (enabled=true)
                  modbus.4
                  	2024-10-20 21:18:18.042	debug	Cleaning up request fifo.
                  modbus.4
                  	2024-10-20 21:18:18.042	debug	Clearing timeout of the current request.
                  modbus.4
                  	2024-10-20 21:18:18.030	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  modbus.4
                  	2024-10-20 21:18:18.029	debug	Plugin sentry destroyed
                  modbus.4
                  	2024-10-20 21:18:18.027	info	terminating
                  modbus.4
                  	2024-10-20 21:18:18.022	info	Got terminate signal TERMINATE_YOURSELF
                    ja, aber Haken bei Abfrage setzen
                      Marc 3 last edited by Marc 3
                      wir kommen voran! die 12714179°C aktualisieren sich alle ~1 sekunde (alle 1 Sekunde wird der Wert tatsächlich gesendet, daher ist die Polltime quatsch, ABER!!!! es kommt was an)
                      Jetzt muss man das nur noch in 8 verschiedene Temperaturwerte aufdröseln, entsprechend umwandeln, dann hätten wir es schon.
                      12714179 in Hex sind C2 00 C3 und scheint die Antwort auf die Anfrage davor zu sein.
                      modbus.4
                      	2024-10-20 21:28:12.583	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:28:12.512	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:28:12.511	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:28:02.457	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:28:02.392	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:28:02.390	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:27:52.331	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:27:52.262	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:27:52.261	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:27:42.205	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:27:42.133	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:27:42.132	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:27:32.078	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:27:32.007	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:27:32.006	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:27:21.936	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:27:21.864	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:27:21.863	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:27:11.809	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:27:10.770	error	Error response: 0
                      modbus.4
                      	2024-10-20 21:27:10.755	error	Wrong CRC for frame: 3,3,16,0,193,0,194,0,195,0,193,0,192,0,191,0,195,3,3,16,0
                      modbus.4
                      	2024-10-20 21:27:09.720	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:27:09.719	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:26:59.668	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:26:59.596	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:26:59.595	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:26:49.542	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:26:49.471	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:26:49.470	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:26:39.416	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:26:39.346	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:26:39.345	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:26:29.289	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:26:28.249	error	Error response: 0
                      modbus.4
                      	2024-10-20 21:26:28.233	error	Wrong CRC for frame: 3,3,16,0,254,56,64,240,128,195,0,193,4,145,3,3,16,0,192,0,194
                      modbus.4
                      	2024-10-20 21:26:27.177	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:26:27.176	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:26:17.122	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:26:17.065	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:26:17.064	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:26:07.012	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:26:06.943	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:26:06.941	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:25:56.885	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:25:56.814	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:25:56.812	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:25:46.759	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:25:45.719	error	unknown function code: 0x0, 0xc0
                      modbus.4
                      	2024-10-20 21:25:45.703	error	Wrong CRC for frame: 3,3,16,0,192,0,194,0,195,0,193,17,91,3,3,16,0,192,0,194,0
                      modbus.4
                      	2024-10-20 21:25:44.658	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:25:44.657	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:25:34.602	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:25:34.533	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:25:34.532	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:25:24.476	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:25:24.408	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:25:24.407	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:25:14.350	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:25:14.277	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:25:14.276	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:25:04.223	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:25:03.202	error	Wrong CRC for frame: 3,3,16,0,192,0,194,0,195,0,193,0,192,0,192,0,195,0,193,4,209
                      modbus.4
                      	2024-10-20 21:25:03.179	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:25:03.178	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:24:53.123	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:24:53.048	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:24:53.047	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:24:42.995	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:24:42.925	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:24:42.924	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:24:32.869	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:24:32.796	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:24:32.795	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:24:22.742	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:24:22.722	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:24:22.719	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:24:12.664	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:24:12.597	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:24:12.594	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:24:02.539	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:24:02.471	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:24:02.470	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:23:52.413	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:23:52.349	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:23:52.347	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:23:42.290	debug	[DevID_3/holdingRegs] Poll address 1 DONE
                      modbus.4
                      	2024-10-20 21:23:41.245	error	Error response: 0
                      modbus.4
                      	2024-10-20 21:23:41.229	error	unknown function code: 0x5e, 0x3
                      modbus.4
                      	2024-10-20 21:23:40.529	error	Error response: Value is not accepted by slave
                      modbus.4
                      	2024-10-20 21:23:40.528	error	Error response for FCx17: Illegal Data Value
                      modbus.4
                      	2024-10-20 21:23:40.456	debug	[DevID_3/holdingRegs] Poll address 1 - 2 registers
                      modbus.4
                      	2024-10-20 21:23:40.454	debug	Initialization of scale factors done!
                      modbus.4
                      	2024-10-20 21:23:40.448	debug	[DevID_3] Poll start ---------------------
                      modbus.4
                      	2024-10-20 21:23:40.432	info	Connected to slave
                      modbus.4
                      	2024-10-20 21:23:40.383	debug	connect to serial /dev/ttyUSB0 with 9600
                      modbus.4
                      	2024-10-20 21:23:39.163	debug	Add holdingRegisters.1_TempH: {"_id":"holdingRegisters.1_TempH","type":"state","common":{"name":"TempH","role":"level","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":1,"deviceId":3,"type":"uint32be","len":2,"offset":0,"factor":1,"poll":true}}
                      modbus.4
                      	2024-10-20 21:23:39.159	debug	Initialize Objects for holdingRegs: [{"_address":"1","name":"TempH","description":"TempH","unit":"","type":"uint32be","len":2,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":1,"deviceId":3,"id":"holdingRegisters.1_TempH"}]
                      modbus.4
                      	2024-10-20 21:23:39.156	debug	Initialize Objects for inputRegs: []
                      modbus.4
                      	2024-10-20 21:23:39.144	debug	Initialize Objects for coils: []
                      modbus.4
                      	2024-10-20 21:23:39.133	debug	Initialize Objects for disInputs: []
                      modbus.4
                      	2024-10-20 21:23:38.554	info	starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.19.0, js-controller: 4.0.24
                      modbus.4
                      	2024-10-20 21:23:36.715	debug	Plugin sentry Initialize Plugin (enabled=true)
                      modbus.4
                      	2024-10-20 21:23:34.615	debug	States connected to redis: 127.0.0.1:9000
                      modbus.4
                      	2024-10-20 21:23:34.016	debug	States create User PubSub Client
                      modbus.4
                      	2024-10-20 21:23:34.014	debug	States create System PubSub Client
                      modbus.4
                      	2024-10-20 21:23:33.771	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                      modbus.4
                      	2024-10-20 21:23:33.401	debug	Objects connected to redis: 127.0.0.1:9001
                      modbus.4
                      	2024-10-20 21:23:33.082	debug	Objects client initialize lua scripts
                      modbus.4
                      	2024-10-20 21:23:32.281	debug	Objects create User PubSub Client
                      modbus.4
                      	2024-10-20 21:23:32.278	debug	Objects create System PubSub Client
                      modbus.4
                      	2024-10-20 21:23:32.160	debug	Objects client ready ... initialize now
                      modbus.4
                      	2024-10-20 21:23:31.770	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                      modbus.4
                      	2024-10-20 21:23:25.797	warn	get state error: Connection is closed.
                      modbus.4
                      	2024-10-20 21:23:25.284	debug	Cleaning up request fifo.
                      modbus.4
                      	2024-10-20 21:23:25.269	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        was ist denn das Intervall?
                        hier
                        https://forum.iobroker.net/post/1211358
                        waren es 10 Sekunden.
                        nee, das sind verschiedene Register pro Sensor
                        Möglicherweise ist auch nur das Zahlenformat falsch.
                        wenn du uint32 hast mal int32 nehmen oder umgekehrt
                          das ist die Dauer des polls von request bis zur Antwort
                            Es tut :
                            jetzt nur noch die Werte mit 0,1 multiplizieren und es ist erledigt 🙂
                              Expertenmodus (Kopf) aktivieren.
                              Spalte Faktor erscheint 🙂
                              also doch Int16!???
                                Homoran Global Moderator Administrators @Homoran last edited by
                                edit:
                                steht doch auch hier 🤦
                                fc3 ist Read Holdingregister
                                  Marc 3 @Homoran last edited by
                                  Naja, wenn man das lesen kann... Aber vielen Dank dir, für deine Unterstützung 🙂 nun läuft es.
                                  nächster Schritt, schauen, was passiert, wenn's über 25,5°C wird (Länge 1 = FF = 25,5°C)
                                  übernächster Schritt, alles über ModBus to ETH Adapter.
                                  Das alles aber erst, wenn ich wieder Zeit dafür hab.
                                  Vielen Dank nochmal und einen schönen Abend noch!
                                    das sollte dann zumindest mit den Modbusadapter Einstellungen klappen.
                                    Dann muss nur noch ™ der Konverter korrekt konfiguriert werden.
                                    dann doch Int32be??
                                    was kam denn jetzt dahei raus?
                                    gerne und dito!
                                      @Homoran Um das ganze nochmal abzuschließen.
                                      ja es ist Signed16BE, trotz dessen, dass es 4 Stellig ist. Bei 32 hatte ich das Problem, dass 2 Werte zusammen genommen wurden.
                                      Modbus Adapter per Ethernet hat heut auch geklappt.
                                      Als nächstes kommen noch meine weiteren Boards dran, dann kann ich endlich sehen, was meine Fußbodenheizung so macht. Wenn ich es von meinem Brettaufbau verteilt fest eingebaut habe 🙂
                                      (In jeden Verteiler kommt ein Board mich bis zu 8 Sensoren, und im Keller direkt an der Heizung auch an den Vor/Rücklauf.)
                                      Insgesamt hat mich das nun keine 100€ gekostet. Alternative und sicher einfacher wäre alles in KNX gewesen, aber preislich ist as über Modbus und den günstigen Sensoren kein Vergleich.
                                      405
